@8548fe0
02/18/99 18:36:05 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@0162910
12/14/98 23:15:38 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to rename all
.s …
4.104.114.84.95
@1d9f198a
12/14/98 23:15:08 |
Joel Sherrill |
.s …
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@e0713641
10/28/98 18:05:05 |
Joel Sherrill |
Removed per Eric Norum
4.104.114.84.95
@db88957
10/26/98 16:18:58 |
Joel Sherrill |
Patches done in conjunction with Juan Zamorano Flores …
4.104.114.84.95
@396286a
10/22/98 16:23:45 |
Joel Sherrill |
Patch from Eric Norum.
4.104.114.84.95
@bd3dec5
09/10/98 12:46:41 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
If you're getting …
4.104.114.84.95
@9a95524f
08/24/98 14:47:19 |
Joel Sherrill |
Cleanup patch from Eric Norum.
4.104.114.84.95
@d47de32
08/21/98 14:04:31 |
Joel Sherrill |
Update from Eric Norum.
4.104.114.84.95
@28e7d7fa
08/20/98 22:04:22 |
Joel Sherrill |
Patches from Eric Norum
4.104.114.84.95
@53ee76b
08/20/98 15:37:42 |
Joel Sherrill |
Removed stub implementation
4.104.114.84.95
@0280cb6
08/20/98 14:39:09 |
Joel Sherrill |
FreeBSD stack compiles for the first time (except libc/strsep.c)
4.104.114.84.95
@5094711
08/05/98 15:12:03 |
Joel Sherrill |
Fixed name of Buffer so this would compile.
4.104.114.84.95
@03c0961
07/24/98 16:18:39 |
Joel Sherrill |
Patch from David Fiddes <D.J.Fiddes@…>:
Here's a small …
4.104.114.84.95
@c91e032
07/23/98 19:32:01 |
Joel Sherrill |
Removed consolex from build list. This file should be obsoleted by …
4.104.114.84.95
@a90b990
07/06/98 18:44:32 |
Joel Sherrill |
Missed this file in the initial merge.
4.104.114.84.95
@b5bb3d6
07/06/98 14:52:30 |
Joel Sherrill |
Update from Geoffroy Montel (g_montel@…) to get in sync with …
4.104.114.84.95
@0e8c2000
07/02/98 18:07:09 |
Joel Sherrill |
Renamed old_start340.s to startfor340only.s
4.104.114.84.95
@132f194
07/01/98 22:03:20 |
Joel Sherrill |
Initial submission of gen68340 BSP (should run on a 68349) from …
4.104.114.84.95
@98100d2
06/27/98 17:09:47 |
Joel Sherrill |
Monstrous patch from Ralf Corsepius <corsepiu@…>. I have …
4.104.114.84.95
@c19a29b4
05/22/98 12:27:51 |
Joel Sherrill |
Added call to console_reserve_resources back in.
4.104.114.84.95
@a863c50
05/18/98 14:41:15 |
Joel Sherrill |
Updates from Pedro Romano.
4.104.114.84.95
@55951bc
05/04/98 12:40:21 |
Joel Sherrill |
Switched to termios callback structure.
4.104.114.84.95
@36a14a96
05/04/98 12:38:53 |
Joel Sherrill |
Patch from Eric Norum to switch to termios callback structure and
add …
4.104.114.84.95
@36aba21
05/02/98 12:11:23 |
Joel Sherrill |
removed warning for implicit declaration of resolve()
4.104.114.84.95
@269707e6
05/02/98 12:10:18 |
Joel Sherrill |
removed warning for `#ifdef' argument starts with a digit
4.104.114.84.95
@17f57736
05/02/98 12:09:11 |
Joel Sherrill |
removed warning for implicit declaration of boot_card()
4.104.114.84.95
@70ad028
04/15/98 22:09:28 |
Joel Sherrill |
update from Eric Norum
4.104.114.84.95
@bd9c3d1
04/15/98 20:50:31 |
Joel Sherrill |
Numerous changes which in total greatly reduced the amount of source …
4.104.114.84.95
@b6394ae
04/15/98 15:13:01 |
Joel Sherrill |
Transitioned to shared bsp_libc_init() and cleaned up comments.
4.104.114.84.95
@9b64c2d5
04/15/98 00:10:03 |
Joel Sherrill |
Per suggestion from Eric Norum, went from one initial extension set
to …
4.104.114.84.95
@c244a9ee
04/14/98 21:32:12 |
Joel Sherrill |
Stack checker extension now accounted for in confdefs.h
4.104.114.84.95
@3b89891
04/14/98 20:54:26 |
Joel Sherrill |
Now accounts for region used by RTEMS malloc and extension used
by newlib.
4.104.114.84.95
@8f95b5f
03/30/98 14:01:19 |
Joel Sherrill |
Moved bsp_postdriver_hook() to a shared file and made it a common …
4.104.114.84.95
@5e0fbcc
03/25/98 19:02:37 |
Joel Sherrill |
Moved memcpy to newlib/libc/machine/m68k
4.104.114.84.95
@c80add4
03/25/98 18:46:47 |
Joel Sherrill |
m68k software interrupt stack support from Chris Johns and Eric Norum.
4.104.114.84.95
@3ec7bfc
03/24/98 16:24:39 |
Joel Sherrill |
Rename hppa1_1 to hppa1.1 and switched to using XXX macros for
the …
4.104.114.84.95
@98bcbda3
03/23/98 18:35:41 |
Joel Sherrill |
Patches from Eric Norum:
Here are some patches to the gen68360 …
4.104.114.84.95
@e2a2ec60
03/21/98 15:37:18 |
Joel Sherrill |
Switch to using a shared main() for all of the embedded BSPs
based on …
4.104.114.84.95
@670b2edf
03/20/98 19:08:26 |
Joel Sherrill |
Fixed typo.
4.104.114.84.95
@0799dec
02/23/98 21:33:43 |
Joel Sherrill |
Patch from Eric Norum:
Here's another small patch. The changes to …
4.104.114.84.95
@96c73ab
02/19/98 23:02:16 |
Joel Sherrill |
While trying to work through this problem I …
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@f86ec42
02/17/98 23:35:54 |
Joel Sherrill |
Added .eh_frame, C++ constructor, and C++ destructor sections.
4.104.114.84.95
@a858910
02/11/98 22:13:46 |
Joel Sherrill |
Incorporated Ralf Corsepius' idea for new -q flags to properly support …
4.104.114.84.95
@5c3511e
01/30/98 21:49:51 |
Joel Sherrill |
Big patch form Ralf Corsepius described in this email:
Here is the …
4.104.114.84.95
@bd620fe
01/23/98 17:06:17 |
Joel Sherrill |
Added information about multilib problems.
4.104.114.84.95
@cb5bfe4
01/20/98 19:41:09 |
Joel Sherrill |
Removed CONFIG_DIR and PROJECT_HOME directories.
4.104.114.84.95
@6f9c75c3
01/16/98 16:56:48 |
Joel Sherrill |
Ralf Corsepius reported a number of missing CVS Id's:
> RTEMS is …
4.104.114.84.95
@35a1ec9
01/06/98 20:18:21 |
Joel Sherrill |
Updates from Eric Norum. Changed CPU CFLAG and went to a common name …
4.104.114.84.95
@c257ec4e
12/22/97 18:23:58 |
Joel Sherrill |
Fixes from Eric Norum. C++ support added in previous version was …
4.104.114.84.95
@608641e
12/22/97 17:29:51 |
Joel Sherrill |
Corrected prototypes for all termios console write driver entries to …
4.104.114.84.95
@8fe6d358
12/20/97 16:59:11 |
Joel Sherrill |
Moved -qnolinkcmds option so arguments passed on the command line are …
4.104.114.84.95
@1587af6
12/20/97 16:37:29 |
Joel Sherrill |
Update from Eric Norum to include C++ support.
4.104.114.84.95
@f7fa7d7
12/19/97 14:48:19 |
Joel Sherrill |
Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds …
4.104.114.84.95
@674c900
12/10/97 16:58:00 |
Joel Sherrill |
Modified a lot of files to take a first cut at supporting building …
4.104.114.84.95
@0f39365
11/30/97 18:36:13 |
Joel Sherrill |
Corrected call to rtems_termios_open.
4.104.114.84.95
@53cea31
11/18/97 22:32:00 |
Joel Sherrill |
Fixed assignment to dereference ch.
4.104.114.84.95
@d54de3f
11/18/97 22:31:37 |
Joel Sherrill |
Changed from DOS style CR/LF to Unix style.
4.104.114.84.95
@d24ceb3
11/15/97 18:15:36 |
Joel Sherrill |
interrupt driven change from Eric Norum
4.104.114.84.95
@cfefaa6e
10/23/97 18:48:35 |
Joel Sherrill |
Added TOD driver from Katsutoshi Shibuya.
4.104.114.84.95
@51961e4
10/23/97 18:48:01 |
Joel Sherrill |
Removed GEN68360_INIT.
4.104.114.84.95
@4106f7f
10/23/97 18:47:43 |
Joel Sherrill |
4.104.114.84.95
@aa239a7
10/23/97 18:47:23 |
Joel Sherrill |
Updated console driver to use new read routine conventions.
4.104.114.84.95
@edd1329f
10/23/97 15:11:27 |
Joel Sherrill |
Overhauled console driver to use termios and to simultaneously support …
4.104.114.84.95
@f33a3f2a
10/16/97 21:06:47 |
Joel Sherrill |
Control and Data addresses were swapped for port A.
4.104.114.84.95
@d17d4d2f
10/15/97 21:27:00 |
Joel Sherrill |
Moved selection of console port to custom file.
4.104.114.84.95
@84ff8b7b
10/13/97 17:38:18 |
Joel Sherrill |
New version of this file from Eric Norum.
4.104.114.84.95
@a86443fb
10/09/97 18:33:46 |
Joel Sherrill |
Added search of libcpu and fpsp.
4.104.114.84.95
@b546242
10/08/97 19:52:47 |
Joel Sherrill |
Modified to search RTEMS library before Newlib C library.
4.104.114.84.95
@7de0960
10/08/97 18:19:43 |
Joel Sherrill |
Update from Eric Norum:
Change label names so they can be …
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@a2016b99
10/08/97 14:42:08 |
Joel Sherrill |
Removed include directory at "build" point and the link of this …
4.104.114.84.95
@6b4ca31
09/18/97 16:01:52 |
Joel Sherrill |
Merged changes from Eric Norum:
Enable 68360 watchdog. The …
4.104.114.84.95
@8f35817
09/15/97 18:52:26 |
Joel Sherrill |
eliminated potential for overfilling buffer on read
4.104.114.84.95
@8d05346
09/03/97 22:05:51 |
Joel Sherrill |
Fix from Eric Norum. Here is the comment:
Enable SDMA …
4.104.114.84.95
@e9932367
08/28/97 21:54:59 |
Joel Sherrill |
Switched to new style which does not require hackspecs.awk.
4.104.114.84.95
@f80faeb
08/27/97 20:33:11 |
Joel Sherrill |
Modified to support the BSP family concept.
4.104.114.84.95
@49c2f589
08/27/97 20:31:34 |
Joel Sherrill |
Modified to have correct address for vector table on multiple models.
4.104.114.84.95
@12a17af3
08/26/97 18:10:59 |
Joel Sherrill |
Corrected to compile with egcs.
4.104.114.84.95
@2d997375
08/22/97 13:08:56 |
Joel Sherrill |
start no longer a global symbol per Eric Norum's request.
Also, I …
4.104.114.84.95
@d074e12
08/04/97 22:22:59 |
Joel Sherrill |
Switched to new version of mc68681.h
4.104.114.84.95
@19fd334
08/04/97 22:22:31 |
Joel Sherrill |
moved mc68230.h from main include directory to motorola
4.104.114.84.95
@3dd8372
08/04/97 22:03:03 |
Joel Sherrill |
Corrected typo
4.104.114.84.95
@50b5f9d
08/04/97 21:57:06 |
Joel Sherrill |
Trying to support all models
4.104.114.84.95
@c74169bd
08/04/97 21:56:48 |
Joel Sherrill |
Trying to support all models.
4.104.114.84.95
@c9647b3
08/04/97 21:56:00 |
Joel Sherrill |
consolex built for all models.
4.104.114.84.95
@81d96577
08/04/97 21:55:30 |
Joel Sherrill |
moved header files into the motorola and zilog subdirectories
4.104.114.84.95
@669123e1
08/04/97 21:53:42 |
Joel Sherrill |
Correcting difference between mvme162lx and mvme162. All versions …
4.104.114.84.95
@02d0880
08/04/97 21:50:35 |
Joel Sherrill |
4.104.114.84.95
@033ec54
08/04/97 21:49:47 |
Joel Sherrill |
Modified to reflect changes in mc68681.h header file.
4.104.114.84.95
@b739617
08/04/97 21:45:27 |
Joel Sherrill |
Header files moved into zilog subdirectory.
4.104.114.84.95
@bcbd75d4
08/01/97 20:56:36 |
Joel Sherrill |
Added consolex to wrapup
4.104.114.84.95
@a7fcfd0
08/01/97 20:56:24 |
Joel Sherrill |
Corrected typo.
4.104.114.84.95
@adf7b5c4
08/01/97 20:15:02 |
Joel Sherrill |
Made to work.
4.104.114.84.95
@29a9e5d
08/01/97 20:14:57 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@9deb5b8b
08/01/97 18:12:11 |
Joel Sherrill |
Katsutoshi Shibuya (shibuya@…)of BU-Denken Co., Ltd. …
4.104.114.84.95
@0074691a
07/31/97 22:13:29 |
Joel Sherrill |
Merged very large and much appreciated patch from Chris Johns …
4.104.114.84.95
@bf3a7a5a
07/10/97 19:16:40 |
Joel Sherrill |
Added information on different MVME162 models.
4.104.114.84.95
