# # ChangeLog for c/src/lib/libbsp/m68k/ods68302/bsp_specs in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 17:02:02 Wed, 11 Feb 1998 22:13:46 GMT Joel Sherrill [a858910] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/Templates/Makefile.leaf (modified) * make/compilers/gcc-target-default.cfg (modified) Incorporated Ralf Corsepius' idea for new -q flags to properly ... Sat, 20 Dec 1997 16:59:11 GMT Joel Sherrill [8fe6d358] * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Moved -qnolinkcmds option so arguments passed on the command line are ... Fri, 19 Dec 1997 14:48:19 GMT Joel Sherrill [f7fa7d7] * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds ... Wed, 08 Oct 1997 19:52:47 GMT Joel Sherrill [b546242] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/go32/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Modified to search RTEMS library before Newlib C library. Thu, 28 Aug 1997 21:54:59 GMT Joel Sherrill [e9932367] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/go32/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Switched to new style which does not require hackspecs.awk. Tue, 26 Aug 1997 18:10:59 GMT Joel Sherrill [12a17af3] * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) Corrected to compile with egcs. Thu, 31 Jul 1997 22:13:29 GMT Joel Sherrill [0074691a] * c/ACKNOWLEDGEMENTS (modified) * c/src/lib/include/rtems++/rtemsEvent.h (added) * c/src/lib/include/rtems++/rtemsInterrupt.h (added) * c/src/lib/include/rtems++/rtemsMessageQueue.h (added) * c/src/lib/include/rtems++/rtemsSemaphore.h (added) * c/src/lib/include/rtems++/rtemsStatusCode.h (added) * c/src/lib/include/rtems++/rtemsTask.h (added) * c/src/lib/include/rtems++/rtemsTaskMode.h (added) * c/src/lib/include/rtems++/rtemsTimer.h (added) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/README (added) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (added) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/console/console.c (added) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/include/bare.h (added) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (added) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (added) * c/src/lib/libbsp/m68k/ods68302/include/crc.h (added) * c/src/lib/libbsp/m68k/ods68302/include/debugport.h (added) * c/src/lib/libbsp/m68k/ods68302/include/m68302scc.h (added) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/start/cpuboot.c (added) * c/src/lib/libbsp/m68k/ods68302/start/debugreset.S (added) * c/src/lib/libbsp/m68k/ods68302/start/reset.S (added) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/start302/cpuboot.c (added) * c/src/lib/libbsp/m68k/ods68302/start302/debugreset.S (added) * c/src/lib/libbsp/m68k/ods68302/start302/reset.S (added) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/cpuboot.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/crc.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/debugger (added) * c/src/lib/libbsp/m68k/ods68302/startup/debugport.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/gdb-hooks.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (added) * c/src/lib/libbsp/m68k/ods68302/startup/m68302scc.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/memcheck.c (added) * c/src/lib/libbsp/m68k/ods68302/startup/rom (added) * c/src/lib/libbsp/m68k/ods68302/startup/trace.c (added) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (added) * c/src/lib/libbsp/m68k/ods68302/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (added) * c/src/lib/librtems++/Makefile.in (added) * c/src/lib/librtems++/README (added) * c/src/lib/librtems++/rtemsEvent.cc (added) * c/src/lib/librtems++/rtemsInterrupt.cc (added) * c/src/lib/librtems++/rtemsMessageQueue.cc (added) * c/src/lib/librtems++/rtemsSemaphore.cc (added) * c/src/lib/librtems++/rtemsStatusCode.cc (added) * c/src/lib/librtems++/rtemsTask.cc (added) * c/src/lib/librtems++/rtemsTimer.cc (added) * c/src/librtems++/README (added) * c/src/librtems++/include/rtems++/rtemsEvent.h (added) * c/src/librtems++/include/rtems++/rtemsInterrupt.h (added) * c/src/librtems++/include/rtems++/rtemsMessageQueue.h (added) * c/src/librtems++/include/rtems++/rtemsSemaphore.h (added) * c/src/librtems++/include/rtems++/rtemsStatusCode.h (added) * c/src/librtems++/include/rtems++/rtemsTask.h (added) * c/src/librtems++/include/rtems++/rtemsTaskMode.h (added) * c/src/librtems++/include/rtems++/rtemsTimer.h (added) * c/src/librtems++/src/Makefile.in (added) * c/src/librtems++/src/rtemsEvent.cc (added) * c/src/librtems++/src/rtemsInterrupt.cc (added) * c/src/librtems++/src/rtemsMessageQueue.cc (added) * c/src/librtems++/src/rtemsSemaphore.cc (added) * c/src/librtems++/src/rtemsStatusCode.cc (added) * c/src/librtems++/src/rtemsTask.cc (added) * c/src/librtems++/src/rtemsTimer.cc (added) * c/src/tests/libtests/rtems++/Init.cc (added) * c/src/tests/libtests/rtems++/Makefile.in (added) * c/src/tests/libtests/rtems++/System.h (added) * c/src/tests/libtests/rtems++/Task1.cc (added) * c/src/tests/libtests/rtems++/Task2.cc (added) * c/src/tests/libtests/rtems++/Task3.cc (added) * c/src/tests/libtests/rtems++/rtems++.doc (added) * c/src/tests/libtests/rtems++/rtems++.scn (added) * testsuites/libtests/rtems++/Init.cc (added) * testsuites/libtests/rtems++/System.h (added) * testsuites/libtests/rtems++/Task1.cc (added) * testsuites/libtests/rtems++/Task2.cc (added) * testsuites/libtests/rtems++/Task3.cc (added) * testsuites/libtests/rtems++/rtems++.doc (added) * testsuites/libtests/rtems++/rtems++.scn (added) Merged very large and much appreciated patch from Chris Johns ...
