Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp/m68k/mvme147s
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @eba2e4f   11/01/00 21:19:23 Joel Sherrill 2000-11-01 Joel Sherrill <joel@…> * startup/bspstart.c: … 4.104.114.84.95
(edit) @e83378d   10/27/00 13:59:24 Joel Sherrill 2000-10-27 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @9f30a08b   09/29/00 14:25:46 Joel Sherrill 2000-09-29 Charles-Antoine Gauthier <charles.gauthier@…> * … 4.104.114.84.95
(edit) @b00a141   09/05/00 15:49:17 Joel Sherrill 2000-09-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @e94ad1fe   08/10/00 13:24:00 Joel Sherrill Adding ChangeLogs?. 4.104.114.84.95
(edit) @219d59d1   06/14/00 21:28:35 Joel Sherrill Enable data cache as well. 4.104.114.84.95
(edit) @5e77d129   06/14/00 20:32:44 Joel Sherrill Patch from John Cotton <john.cotton@…> to correct cache routine … 4.104.114.84.95
(edit) @e4d7169f   06/14/00 15:51:16 Joel Sherrill Must now pull in cache management code from libcpu. 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @e4c07444   04/13/00 14:47:15 Joel Sherrill Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @70810dc   02/08/00 22:33:25 Joel Sherrill Patches rtems-rc-20000204-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4e36a2f   01/31/00 15:27:02 Joel Sherrill Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from … 4.104.114.84.95
(edit) @b8c9883   01/13/00 20:45:07 Joel Sherrill All m68k BSPs now build with new ELF style linkcmds. 4.104.114.84.95
(edit) @9b2c969   01/13/00 15:07:03 Joel Sherrill Made sweep of changes to get all BSPs to the same point on the … 4.104.114.84.95
(edit) @b2b4835   01/12/00 16:38:57 Joel Sherrill Eric Norum <eric@…> submitted linker script and bsp_specs … 4.104.114.84.95
(edit) @737a599   01/12/00 16:05:58 Joel Sherrill Patch rtems-rc-20000104-15.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @bc2f04f   01/10/00 14:50:45 Joel Sherrill Patch rtems-rc-20000104-13.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @7068e246   01/10/00 14:29:44 Joel Sherrill Patch rtems-rc-20000104-10.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @48bfd992   11/30/99 19:58:02 Joel Sherrill Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h. … 4.104.114.84.95
(edit) @7e642ba   11/22/99 19:27:13 Joel Sherrill Patch rtems-rc-19991117-9.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @9608320   11/22/99 13:41:11 Joel Sherrill Patch rtems-rc-19991117-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @ac656f2d   11/16/99 14:15:56 Joel Sherrill Moved start code from lib/start to libbsp. 4.104.114.84.95
(edit) @01c36de   10/06/99 18:04:34 Joel Sherrill Added more sections and made minor modifications to let the linkcmds … 4.104.114.84.95
(edit) @e1d8abb   09/07/99 13:45:03 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @3a8915e   08/06/99 17:55:25 Joel Sherrill Patch rtems-rc-19990709-6-diff from Ralf Corsepius … 4.104.114.84.95
(edit) @1896a650   07/30/99 17:52:50 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The main topic … 4.104.114.84.95
(edit) @08b5f55   07/26/99 20:31:49 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: A bug in … 4.104.114.84.95
(edit) @6693a68   07/26/99 20:00:37 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @c8d9183   07/02/99 18:57:11 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> that splits … 4.104.114.84.95
(edit) @455d8552   06/24/99 17:53:16 Joel Sherrill Added dummy gnatinstallhandler code for all BSPs. This lets Ada … 4.104.114.84.95
(edit) @af84b968   05/27/99 18:53:02 Joel Sherrill Switched from picking up the .rel for each subdirectory in the BSP … 4.104.114.84.95
(edit) @196094eb   04/19/99 13:19:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This one is … 4.104.114.84.95
(edit) @3c0e80c3   04/06/99 22:07:36 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to preinstall all … 4.104.114.84.95
(edit) @d8ff793   03/19/99 22:27:02 Joel Sherrill Towards automake XI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @5906ac5   03/19/99 22:10:04 Joel Sherrill Towards automake X patch from Ralf Corsepius … 4.104.114.84.95
(edit) @8548fe0   02/18/99 18:36:05 Joel Sherrill Part of the automake VI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @0162910   12/14/98 23:15:38 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to rename all .s … 4.104.114.84.95
(edit) @97e2729d   11/23/98 17:38:09 Joel Sherrill Added --disable-multiprocessing flag and modified a lot of files to … 4.104.114.84.95
(edit) @db88957   10/26/98 16:18:58 Joel Sherrill Patches done in conjunction with Juan Zamorano Flores … 4.104.114.84.95
(edit) @bd9c3d1   04/15/98 20:50:31 Joel Sherrill Numerous changes which in total greatly reduced the amount of source … 4.104.114.84.95
(edit) @b6394ae   04/15/98 15:13:01 Joel Sherrill Transitioned to shared bsp_libc_init() and cleaned up comments. 4.104.114.84.95
(edit) @9b64c2d5   04/15/98 00:10:03 Joel Sherrill Per suggestion from Eric Norum, went from one initial extension set to … 4.104.114.84.95
(edit) @c244a9ee   04/14/98 21:32:12 Joel Sherrill Stack checker extension now accounted for in confdefs.h 4.104.114.84.95
(edit) @3b89891   04/14/98 20:54:26 Joel Sherrill Now accounts for region used by RTEMS malloc and extension used by newlib. 4.104.114.84.95
(edit) @8f95b5f   03/30/98 14:01:19 Joel Sherrill Moved bsp_postdriver_hook() to a shared file and made it a common … 4.104.114.84.95
(edit) @e2a2ec60   03/21/98 15:37:18 Joel Sherrill Switch to using a shared main() for all of the embedded BSPs based on … 4.104.114.84.95
(edit) @60b791ad   02/17/98 23:46:28 Joel Sherrill updated copyright to 1998 4.104.114.84.95
(edit) @f86ec42   02/17/98 23:35:54 Joel Sherrill Added .eh_frame, C++ constructor, and C++ destructor sections. 4.104.114.84.95
(edit) @a858910   02/11/98 22:13:46 Joel Sherrill Incorporated Ralf Corsepius' idea for new -q flags to properly support … 4.104.114.84.95
(edit) @5c3511e   01/30/98 21:49:51 Joel Sherrill Big patch form Ralf Corsepius described in this email: Here is the … 4.104.114.84.95
(edit) @cb5bfe4   01/20/98 19:41:09 Joel Sherrill Removed CONFIG_DIR and PROJECT_HOME directories. 4.104.114.84.95
(edit) @8fe6d358   12/20/97 16:59:11 Joel Sherrill Moved -qnolinkcmds option so arguments passed on the command line are … 4.104.114.84.95
(edit) @f7fa7d7   12/19/97 14:48:19 Joel Sherrill Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds … 4.104.114.84.95
(edit) @674c900   12/10/97 16:58:00 Joel Sherrill Modified a lot of files to take a first cut at supporting building … 4.104.114.84.95
(edit) @b546242   10/08/97 19:52:47 Joel Sherrill Modified to search RTEMS library before Newlib C library. 4.104.114.84.95
(edit) @98e4ebf5   10/08/97 15:45:54 Joel Sherrill Fixed typo in the pointer to the license terms. 4.104.114.84.95
(edit) @a2016b99   10/08/97 14:42:08 Joel Sherrill Removed include directory at "build" point and the link of this … 4.104.114.84.95
(edit) @e9932367   08/28/97 21:54:59 Joel Sherrill Switched to new style which does not require hackspecs.awk. 4.104.114.84.95
(edit) @03f2154e   04/22/97 17:20:27 Joel Sherrill headers updated to reflect new style copyright notice as part of … 4.104.114.84.95
(edit) @9fbba98   04/16/97 17:47:48 Joel Sherrill Fixed path which points to shared directory for all BSPs. 4.104.114.84.95
(edit) @ecc4594   04/15/97 17:28:26 Joel Sherrill Removed many BSPs' copy of setvec.c and let them share the same … 4.104.114.84.95
(edit) @bc7d465   04/11/97 18:41:38 Joel Sherrill replaced linking of source from mvme147 drivers with use of vpath to … 4.104.114.84.95
(edit) @588c9ed   04/07/97 21:26:49 Joel Sherrill added cast to eliminate warning 4.104.114.84.95
(edit) @254b4450   04/01/97 23:07:52 Joel Sherrill This set of changes is the build of what was required to convert to … 4.104.114.84.95
(edit) @634e746   01/29/97 00:28:47 Joel Sherrill All RTEMS system call implementation renamed to be rtems_*. 4.104.114.84.95
(edit) @b1b5a7cb   01/28/97 23:16:16 Joel Sherrill new file used by gcc 2.8.x -specs option 4.104.114.84.95
(add) @afe99c2   09/18/96 14:17:54 Joel Sherrill new file submitted by Dominique le Campion. 4.104.114.84.95
