# # ChangeLog for c/src/lib/libbsp/m68k/mvme136/bsp_specs in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 13:09:20 Wed, 11 Feb 1998 22:13:46 GMT Joel Sherrill [a858910] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/Templates/Makefile.leaf (modified) * make/compilers/gcc-target-default.cfg (modified) Incorporated Ralf Corsepius' idea for new -q flags to properly ... Sat, 20 Dec 1997 16:59:11 GMT Joel Sherrill [8fe6d358] * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Moved -qnolinkcmds option so arguments passed on the command line are ... Fri, 19 Dec 1997 14:48:19 GMT Joel Sherrill [f7fa7d7] * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds ... Wed, 08 Oct 1997 19:52:47 GMT Joel Sherrill [b546242] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/go32/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Modified to search RTEMS library before Newlib C library. Thu, 28 Aug 1997 21:54:59 GMT Joel Sherrill [e9932367] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/go32/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) Switched to new style which does not require hackspecs.awk. Tue, 28 Jan 1997 23:16:16 GMT Joel Sherrill [b1b5a7cb] * c/src/lib/libbsp/i386/force386/bsp_specs (added) * c/src/lib/libbsp/i386/go32/bsp_specs (added) * c/src/lib/libbsp/i386/i386ex/bsp_specs (added) * c/src/lib/libbsp/i960/cvme961/bsp_specs (added) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (added) * c/src/lib/libbsp/m68k/efi332/bsp_specs (added) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (added) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (added) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (added) * c/src/lib/libbsp/m68k/idp/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (added) * c/src/lib/libbsp/mips/p4000/bsp_specs (added) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (added) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (added) * c/src/lib/libbsp/sparc/erc32/bsp_specs (added) new file used by gcc 2.8.x -specs option
