# # ChangeLog for c/src/lib/libbsp/m68k/gen68340/startup/linkcmds in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 07:03:24 Thu, 13 Jan 2000 20:45:07 GMT Joel Sherrill [b8c9883] * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/elflinkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/start/debugreset.S (modified) * c/src/lib/libbsp/m68k/ods68302/start/reset.S (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) All m68k BSPs now build with new ELF style linkcmds. Thu, 13 Jan 2000 15:07:03 GMT Joel Sherrill [9b2c969] * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/start/start.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (added) * c/src/lib/libbsp/m68k/shared/start.S (modified) Made sweep of changes to get all BSPs to the same point on the ... Wed, 12 Jan 2000 16:38:57 GMT Joel Sherrill [b2b4835] * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) Eric Norum submitted linker script and bsp_specs ... Wed, 01 Jul 1998 22:03:20 GMT Joel Sherrill [132f194] * c/src/lib/libbsp/m68k/gen68340/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/README (added) * c/src/lib/libbsp/m68k/gen68340/bsp_specs (added) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.s (added) * c/src/lib/libbsp/m68k/gen68340/console/console.c (added) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (added) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (added) * c/src/lib/libbsp/m68k/gen68340/include/coverhd.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m340timer.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m340uart.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m68340.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m68340.inc (added) * c/src/lib/libbsp/m68k/gen68340/include/m68349.inc (added) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/start/start340.s (added) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/start340/start340.s (added) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/init68340.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (added) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (added) * make/custom/gen68340.cfg (added) Initial submission of gen68340 BSP (should run on a 68349) from ...
