# # ChangeLog for c/src/lib/libbsp/m68k/efi68k in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 07:34:48 Tue, 18 Jun 1996 16:43:12 GMT Joel Sherrill [7d74395f] * c/src/lib/libbsp/m68k/efi68k/startup/efi68k_tcp.c (modified) corrected typo Tue, 28 May 1996 13:13:34 GMT Joel Sherrill [e6d4b1d] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/posix/headers/config.h (added) * c/src/exec/posix/include/rtems/posix/config.h (added) * c/src/exec/rtems/headers/config.h (added) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/config.h (added) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libmisc/monitor/mon-config.c (modified) * c/src/lib/libmisc/monitor/mon-itask.c (modified) * c/src/libmisc/monitor/mon-config.c (modified) * c/src/libmisc/monitor/mon-itask.c (modified) * c/src/tests/support/include/tmacros.h (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libmisc/monitor/mon-config.c (modified) * cpukit/libmisc/monitor/mon-itask.c (modified) * cpukit/posix/include/rtems/posix/config.h (added) * cpukit/rtems/include/rtems/rtems/config.h (added) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/rtemsapi.c (modified) * testsuites/support/include/tmacros.h (modified) added initial posix configuration support Wed, 21 Feb 1996 14:47:03 GMT Joel Sherrill [8cbbe312] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libc/newlibc.c (modified) * cpukit/libcsupport/src/newlibc.c (modified) Dispersal of internal thread handler resulted in the SYSI task being ... Wed, 20 Dec 1995 15:39:19 GMT Joel Sherrill [5c491aef] * c/src/exec/score/cpu/powerpc/README (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu_asm.s (modified) * c/src/exec/score/cpu/powerpc/irq_stub.s (modified) * c/src/exec/score/cpu/powerpc/ppc.h (modified) * c/src/exec/score/cpu/powerpc/ppctypes.h (modified) * c/src/exec/score/cpu/powerpc/rtems.s (modified) * c/src/exec/score/macros/rtems/score/tod.inl (modified) * c/src/exec/score/macros/rtems/score/tqdata.inl (modified) * c/src/exec/score/macros/rtems/score/watchdog.inl (modified) * c/src/exec/score/macros/tod.inl (modified) * c/src/exec/score/macros/tqdata.inl (modified) * c/src/exec/score/macros/watchdog.inl (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/README (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/dlentry.s (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/flashentry.s (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/setvec.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/README (modified) * c/src/lib/libbsp/unix/posix/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/intr.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/lock.c (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/support/stubdr/close.c (modified) * c/src/tests/support/stubdr/cntrl.c (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tools/generic/difftest (modified) * cpukit/score/macros/rtems/score/tod.inl (modified) * cpukit/score/macros/rtems/score/tqdata.inl (modified) * cpukit/score/macros/rtems/score/watchdog.inl (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm29/task1.c (modified) changes remerged after lost in disk crash -- recovered from snapshot, ... Tue, 19 Dec 1995 22:29:43 GMT Joel Sherrill [4442d21c] * c/src/lib/libbsp/m68k/efi68k/times (added) * c/src/lib/libbsp/m68k/gen68302/times (added) initial history lost in disk crash Mon, 30 Oct 1995 21:54:45 GMT Joel Sherrill [9700578] * c/ACKNOWLEDGEMENTS (modified) * c/src/exec/libcsupport/include/ringbuf.h (modified) * c/src/exec/posix/headers/intr.h (modified) * c/src/exec/posix/include/rtems/posix/intr.h (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/sparc/README (added) * c/src/exec/score/cpu/sparc/asm.h (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu_asm.s (modified) * c/src/exec/score/cpu/sparc/erc32.h (added) * c/src/exec/score/cpu/sparc/rtems.s (modified) * c/src/exec/score/cpu/sparc/sparc.h (modified) * c/src/exec/score/cpu/sparc/sparctypes.h (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/exec/score/headers/bitfield.h (modified) * c/src/exec/score/headers/context.h (modified) * c/src/exec/score/headers/isr.h (modified) * c/src/exec/score/headers/priority.h (modified) * c/src/exec/score/include/rtems/score/bitfield.h (modified) * c/src/exec/score/include/rtems/score/context.h (modified) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/inline/isr.inl (modified) * c/src/exec/score/inline/priority.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/macros/isr.inl (modified) * c/src/exec/score/macros/priority.inl (modified) * c/src/exec/score/macros/rtems/score/isr.inl (modified) * c/src/exec/score/macros/rtems/score/priority.inl (modified) * c/src/exec/score/src/thread.c (modified) * c/src/lib/include/ringbuf.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/start/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.s (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/console/duart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/clock/clock.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libcpu/sparc/include/erc32.h (added) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp11/sp11.scn (modified) * c/src/tests/sptests/sp11/task2.c (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/spsize/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * cpukit/libcsupport/include/ringbuf.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/rtems/src/event.c (modified) * cpukit/score/cpu/sparc/README (added) * cpukit/score/cpu/sparc/asm.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/macros/rtems/score/isr.inl (modified) * cpukit/score/macros/rtems/score/priority.inl (modified) * cpukit/score/src/thread.c (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp11/sp11.scn (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) SPARC port passes all tests Wed, 20 Sep 1995 15:05:19 GMT Joel Sherrill [486c329] * c/src/lib/libbsp/m68k/efi332/README (added) * c/src/lib/libbsp/m68k/efi332/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/efi332/console/console.c (added) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (added) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (added) * c/src/lib/libbsp/m68k/efi332/include/efi332.h (added) * c/src/lib/libbsp/m68k/efi332/spurious/spinit.c (added) * c/src/lib/libbsp/m68k/efi332/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (added) * c/src/lib/libbsp/m68k/efi332/timer/timer.c (added) * c/src/lib/libbsp/m68k/efi68k/README (added) * c/src/lib/libbsp/m68k/efi68k/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/efi68k/console/console.c (added) * c/src/lib/libbsp/m68k/efi68k/include/16550.h (added) * c/src/lib/libbsp/m68k/efi68k/include/DP8570A.h (added) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (added) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (added) * c/src/lib/libbsp/m68k/efi68k/include/efi68k.h (added) * c/src/lib/libbsp/m68k/efi68k/spurious/spinit.c (added) * c/src/lib/libbsp/m68k/efi68k/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/efi68k/startup/efi68k_tcp.c (added) * c/src/lib/libbsp/m68k/efi68k/startup/efi68k_wd.c (added) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (added) * c/src/lib/libbsp/m68k/efi68k/startup/m68k-stub.c (added) * c/src/lib/libbsp/m68k/efi68k/startup/setvec.c (added) * c/src/lib/libbsp/m68k/efi68k/timer/timer.c (added) Actually adding efi bsp's from John Gwynne after forgetting to ...
