# # ChangeLog for c/src/lib/libbsp/i960/rxgen960/include in rtems # # Generated by Trac 1.2.1.dev0 # 03/29/24 08:55:59 Tue, 21 Dec 1999 20:28:13 GMT Joel Sherrill [56018097] * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) Now use coverhd.h out of the libbsp/shared directory. Tue, 21 Dec 1999 20:10:04 GMT Joel Sherrill [0d6f0b4] * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (deleted) * c/src/lib/libbsp/bare/include/coverhd.h (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (deleted) * c/src/lib/libbsp/i386/pc386/include/coverhd.h (deleted) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (deleted) * c/src/lib/libbsp/i960/rxgen960/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (deleted) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (deleted) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/dmv177/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/ppcn_60x/include/coverhd.h (deleted) * c/src/lib/libbsp/shared/include/coverhd.h (deleted) * c/src/lib/libbsp/unix/posix/include/coverhd.h (deleted) Now use shared coverhd.h Wed, 27 Oct 1999 17:25:53 GMT Joel Sherrill [ae7325bd] * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/i960RP.h (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/console/console.c (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/include/rxgen960_config.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rxgen_romld.S (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/timer/timerisr.S (modified) * cpukit/score/cpu/i960/cpu.c (modified) rxgen960 now compiles -- may not link. Wed, 27 Oct 1999 16:27:34 GMT Joel Sherrill [2ea8df3] * c/src/lib/libbsp/i960/rxgen960/include/rxgen960_config.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/dram.ld (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/fault.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/faultret.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/i960.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/kkprintf.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/linkcmds (modified) * c/src/lib/libbsp/i960/rxgen960/startup/main.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/memchnl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/nmi.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/nulsystbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/pmc901_memmap.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom.ld (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_prcb.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rommon.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rxgen_romld.S (modified) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/time.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/types.h (modified) Added CVS Ids and a basic header. More header cleanup needed. Wed, 27 Oct 1999 16:19:24 GMT Joel Sherrill [919822f] * c/src/lib/libbsp/i960/rxgen960/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.in (modified) Replaced Makefile.in's with modified copies of cvme961 to get ... Wed, 27 Oct 1999 15:29:18 GMT Joel Sherrill [702c5f5] * c/ACKNOWLEDGEMENTS (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/i960RP.h (added) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/README (added) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (added) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/clock/ckinit.c (added) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/console/concntl.h (added) * c/src/lib/libbsp/i960/rxgen960/console/console.c (added) * c/src/lib/libbsp/i960/rxgen960/console/serial.c (added) * c/src/lib/libbsp/i960/rxgen960/console/serial.h (added) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (added) * c/src/lib/libbsp/i960/rxgen960/include/coverhd.h (added) * c/src/lib/libbsp/i960/rxgen960/include/rxgen960_config.h (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/addrconv.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/getcfg.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/lock.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/mpisr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/dram.ld (added) * c/src/lib/libbsp/i960/rxgen960/startup/exit.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/fault.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/faultret.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/i960.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/kkprintf.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/linkcmds (added) * c/src/lib/libbsp/i960/rxgen960/startup/main.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/memchnl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/nmi.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/nulsystbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/pmc901_memmap.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom.ld (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_prcb.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rommon.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rxgen_romld.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/save_systbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/setvec.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/time.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/types.h (added) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/timer/timer.c (added) * c/src/lib/libbsp/i960/rxgen960/timer/timerisr.s (added) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.in (added) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * make/custom/rxgen960.cfg (added) The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson ...
