source: rtems/c/src/lib/libbsp/i386
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @d8ff793   03/19/99 22:27:02 Joel Sherrill Towards automake XI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @5906ac5   03/19/99 22:10:04 Joel Sherrill Towards automake X patch from Ralf Corsepius … 4.104.114.84.95
(edit) @1105818d   03/18/99 16:36:50 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: Erik Ivanenko pointed … 4.104.114.84.95
(edit) @4f6d73a   03/03/99 16:22:57 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…> to correct a bug … 4.104.114.84.95
(edit) @9d81380   03/01/99 23:50:22 Joel Sherrill Updated Ethernet driver from Erik Ivanenko … 4.104.114.84.95
(edit) @d6a5c81   02/24/99 15:26:38 Joel Sherrill Switch to using standard compile rule for assembly. 4.104.114.84.95
(edit) @c0438add   02/18/99 21:09:25 Joel Sherrill Renamed network to wd8003. 4.104.114.84.95
(edit) @1094cf0d   02/18/99 21:06:17 Joel Sherrill Patch from Emmanuel RAGUET <raguet@…> to add files that … 4.104.114.84.95
(edit) @3204a06   02/18/99 20:58:46 Joel Sherrill Added comments. 4.104.114.84.95
(edit) @51450d7   02/18/99 20:58:13 Joel Sherrill Added NE2000 Driver from Ian Lance Taylor <ian@…>. Comments: … 4.104.114.84.95
(edit) @8548fe0   02/18/99 18:36:05 Joel Sherrill Part of the automake VI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @e029467   02/18/99 15:16:37 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: You will find … 4.104.114.84.95
(edit) @7cc7a74   02/15/99 16:46:54 Joel Sherrill Patch from Eric Valette <valette@…> to correct _exit … 4.104.114.84.95
(edit) @97d6366   01/20/99 21:59:09 Joel Sherrill Changed call to rtems_close() to close(). 4.104.114.84.95
(edit) @c27b2d0d   01/20/99 18:55:50 Joel Sherrill Update of network driver from Erik Ivanenko … 4.104.114.84.95
(edit) @5f22d091   01/19/99 21:29:29 Joel Sherrill Removed referencing to network driver since it has not been merged yet. 4.104.114.84.95
(edit) @c1ee30f   01/04/99 16:24:59 Joel Sherrill Patch from D. V. Henkel-Wallace <gumby@…> to remove unused … 4.104.114.84.95
(edit) @96b46bf   01/04/99 16:23:29 Joel Sherrill Patch from D. V. Henkel-Wallace <gumby@…> to mark sav as unused. 4.104.114.84.95
(edit) @a54541d8   12/17/98 18:12:36 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to eliminate … 4.104.114.84.95
(edit) @7359911   12/15/98 19:40:27 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Some … 4.104.114.84.95
(edit) @0162910   12/14/98 23:15:38 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to rename all .s … 4.104.114.84.95
(edit) @b2e180b7   12/14/98 22:15:57 Joel Sherrill Renamed ASFLAGS to ASMFLAGS for consistency per suggestion from Ralf … 4.104.114.84.95
(edit) @97e2729d   11/23/98 17:38:09 Joel Sherrill Added --disable-multiprocessing flag and modified a lot of files to … 4.104.114.84.95
(edit) @967f3aaa   11/23/98 16:38:28 Joel Sherrill Added networking. 4.104.114.84.95
(edit) @20ad9e9d   11/23/98 14:28:09 Joel Sherrill New network driver from Erik Ivanenko <erik.ivanenko@…>. 4.104.114.84.95
(edit) @22fa5832   10/28/98 19:41:06 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: The RTEMS i386 stub … 4.104.114.84.95
(edit) @c77b2ca   10/22/98 17:30:12 Joel Sherrill Typos spotted by Ian Lance Taylor <ian@…>. 4.104.114.84.95
(edit) @db538d8   10/22/98 17:28:38 Joel Sherrill Added missing .rodata and *(.gnu.linkonce.r*) section. 4.104.114.84.95
(edit) @6278b8b   10/22/98 17:27:14 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: I noticed that in the … 4.104.114.84.95
(edit) @4cfdf321   10/15/98 14:38:10 Joel Sherrill Uncommented the conditional stuff for "good gas 16 bit code". 4.104.114.84.95
(edit) @42c0b9ee   10/07/98 14:54:02 Joel Sherrill NEXT_GAS should have been NEW_GAS. Spotted by Emmanuel Raguet … 4.104.114.84.95
(edit) @72640a3   10/06/98 20:56:13 Joel Sherrill Removed files pc386uart.h and pcibio.h from Makefile since they are … 4.104.114.84.95
(edit) @dc6763c8   10/06/98 13:02:51 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> to add networking … 4.104.114.84.95
(edit) @0ebbf66   10/05/98 22:36:06 Joel Sherrill Large patch from Erik Ivanenko <erik.ivanenko@…> which moves … 4.104.114.84.95
(edit) @2c3840b   09/30/98 20:58:39 Joel Sherrill Added new autoconf test for i386 code16/code32 support. The guts of … 4.104.114.84.95
(edit) @4ca5bd8   09/30/98 17:27:57 Joel Sherrill Changed based on patch from pc386 linkcmds from Ian Lance Taylor … 4.104.114.84.95
(edit) @d1d47664   09/30/98 17:17:23 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: The pc386 linker … 4.104.114.84.95
(edit) @da38d8a   09/24/98 15:43:38 Joel Sherrill Removed superfluous initialization of PC video. 4.104.114.84.95
(edit) @32f3e34   09/24/98 13:55:18 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…>: Please find … 4.104.114.84.95
(edit) @287e9584   09/24/98 13:46:27 Joel Sherrill New version from Erik Ivanenko <erik.ivanenko@…>. 4.104.114.84.95
(edit) @5d17a64   09/23/98 13:43:14 Joel Sherrill Updated to remove bad comment. 4.104.114.84.95
(edit) @1cf2df40   09/23/98 13:25:37 Joel Sherrill Removed printk() references. 4.104.114.84.95
(edit) @479c86dd   09/23/98 13:22:43 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…>: Please find … 4.104.114.84.95
(edit) @8a496e46   09/23/98 13:20:34 Joel Sherrill Patch from Aleksey (Quality Quorum <qqi@…>): 1. … 4.104.114.84.95
(edit) @362b88e   09/23/98 13:17:23 Joel Sherrill Switched "NEW_GAS" flag. 4.104.114.84.95
(edit) @e62488d   09/21/98 01:29:19 Joel Sherrill New file from Emmanuel Raguet <raguet@…>. 4.104.114.84.95
(edit) @97d7b068   09/21/98 00:40:18 Joel Sherrill Update from Aleksey (Quality Quorum <qqi@…>) to pick up … 4.104.114.84.95
(edit) @75e44fa3   09/21/98 00:39:47 Joel Sherrill Removed by patch from Aleksey. 4.104.114.84.95
(edit) @3f929757   09/21/98 00:38:13 Joel Sherrill Patches from Aleksey which were not in 980911. I am sending you … 4.104.114.84.95
(edit) @c610a1f3   09/21/98 00:24:51 Joel Sherrill Update from Eric Valette <valette@…>: Here are patches … 4.104.114.84.95
(edit) @04bc5d9   09/21/98 00:23:02 Joel Sherrill Update from Erik Ivanenko <erik.ivanenko@…> to bring the … 4.104.114.84.95
(edit) @6bd0fe4   09/20/98 23:52:43 Joel Sherrill Patch from Eric Valette <valette@…>: Compiled and booted … 4.104.114.84.95
(edit) @b7e3949   09/10/98 12:28:59 Joel Sherrill Patch from Eric Valette <valette@…>. Most of this was … 4.104.114.84.95
(edit) @eff217e   09/10/98 12:16:39 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: After some good … 4.104.114.84.95
(edit) @d9d75fc   08/31/98 23:06:50 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: I have reworked … 4.104.114.84.95
(edit) @b285860   08/31/98 23:03:45 Joel Sherrill Patch from Eric Valette <valette@…>: Eric> NB : there … 4.104.114.84.95
(edit) @de9edc4   08/31/98 22:56:20 Joel Sherrill Patch from Eric Valette <valette@…>: Here is a brief … 4.104.114.84.95
(edit) @69036586   08/24/98 16:58:39 Joel Sherrill Patch from Eric Valette <valette@…>: Celso Labinaz … 4.104.114.84.95
(edit) @eb562f2   08/21/98 16:39:52 Joel Sherrill Patch from Eric Valette <valette@…>: Here is a patch … 4.104.114.84.95
(edit) @fd808ba   08/21/98 12:48:44 Joel Sherrill Fixed discrepancies noted by John Oleynick <johno@…>. 4.104.114.84.95
(edit) @28e7d7fa   08/20/98 22:04:22 Joel Sherrill Patches from Eric Norum 4.104.114.84.95
(edit) @8b2ee37c   08/19/98 20:09:59 Joel Sherrill Patch from Eric Valette <valette@…>: - Use the … 4.104.114.84.95
(edit) @0375c72   08/19/98 14:47:39 Joel Sherrill Patch from Aleksey <qqi@…>: This patch has same … 4.104.114.84.95
(edit) @2d7d605   08/19/98 14:41:23 Joel Sherrill Patch from Aleksey <qqi@…>: It fixes netboot build … 4.104.114.84.95
(edit) @bd8c8b2a   08/05/98 16:51:39 Joel Sherrill Patch from Eric Valette <valette@…> which brings the i386ex … 4.104.114.84.95
(edit) @ab0df696   08/05/98 15:15:46 Joel Sherrill Automatic CPU type detection code from Eric Valette … 4.104.114.84.95
(edit) @dbab462   07/24/98 16:09:51 Joel Sherrill Patch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @dbaf51a   07/23/98 22:13:10 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: Here is a patch … 4.104.114.84.95
(edit) @67a2288   07/23/98 22:02:34 Joel Sherrill Patch from Eric VALETTE <valette@…>: Here is a … 4.104.114.84.95
(edit) @dbfa3148   07/10/98 15:43:18 Joel Sherrill Patch from Quality Quorum <qqi@…>. Comments: … 4.104.114.84.95
(edit) @5d18fb0   06/27/98 18:51:49 Joel Sherrill PC386 BSP enhancements from Aleksey Romanov (Quality Quorum … 4.104.114.84.95
(edit) @98100d2   06/27/98 17:09:47 Joel Sherrill Monstrous patch from Ralf Corsepius <corsepiu@…>. I have … 4.104.114.84.95
(edit) @d13b247   06/25/98 18:42:30 Joel Sherrill Clean up from Aleksey Romanov (Quality Quorum <qqi@…>). … 4.104.114.84.95
(edit) @70b0d66   06/04/98 13:08:02 Joel Sherrill Added support for -qrtems_debug flag. 4.104.114.84.95
(edit) @3c7916f   06/03/98 19:00:57 Joel Sherrill Update from Pedro Romano <pmcnr@…> with an attempt … 4.104.114.84.95
(edit) @5184958   06/03/98 18:47:44 Joel Sherrill Update from Pedro Romano <pmcnr@…> which replaces … 4.104.114.84.95
(edit) @1278ea1   05/27/98 22:09:47 Joel Sherrill Deleted blank lines. 4.104.114.84.95
(edit) @bb6d368   05/27/98 22:09:39 Joel Sherrill Added "speaker on" debug code. 4.104.114.84.95
(edit) @4050a7f   05/27/98 19:34:37 Joel Sherrill Numerous changes including the following: + DEBUG_EARLY_START … 4.104.114.84.95
(edit) @339cc25   05/27/98 19:24:57 Joel Sherrill Moved rtemsReboot() to console/inch.c. 4.104.114.84.95
(edit) @a92adc6   05/27/98 19:20:55 Joel Sherrill Deleted HEAP_SIZE constant. 4.104.114.84.95
(edit) @37eacd7   05/27/98 19:20:38 Joel Sherrill Removed illegally formatted comments. 4.104.114.84.95
(edit) @8d62ece8   05/27/98 19:19:31 Joel Sherrill Moved rtemsReboot() to here from exit.c. This appears to have been … 4.104.114.84.95
(edit) @90cf4cc   05/21/98 16:49:51 Joel Sherrill Corrected license notices per Eric's permission 4.104.114.84.95
(edit) @941f6f3   05/21/98 16:46:05 Joel Sherrill New file from Eric Valette 4.104.114.84.95
(edit) @2efdd08   05/20/98 17:06:57 Joel Sherrill Patch from Ralf Corseipus to fix latent configure problems suddenly … 4.104.114.84.95
(edit) @98c73895   05/18/98 16:43:36 Joel Sherrill New file from Pedro Romano 4.104.114.84.95
(edit) @a863c50   05/18/98 14:41:15 Joel Sherrill Updates from Pedro Romano. 4.104.114.84.95
(edit) @7d78f40   05/18/98 14:40:59 Joel Sherrill New file. 4.104.114.84.95
(edit) @5ee559ac   05/04/98 12:37:35 Joel Sherrill Corrected and added sections to link cleanly under i386-rtemself. 4.104.114.84.95
(edit) @96d56b3   04/27/98 18:42:04 Joel Sherrill Update from Pedro Romano <pmcnr@…>. 4.104.114.84.95
(edit) @bd9c3d1   04/15/98 20:50:31 Joel Sherrill Numerous changes which in total greatly reduced the amount of source … 4.104.114.84.95
(edit) @b6394ae   04/15/98 15:13:01 Joel Sherrill Transitioned to shared bsp_libc_init() and cleaned up comments. 4.104.114.84.95
(edit) @9b64c2d5   04/15/98 00:10:03 Joel Sherrill Per suggestion from Eric Norum, went from one initial extension set to … 4.104.114.84.95
(edit) @c244a9ee   04/14/98 21:32:12 Joel Sherrill Stack checker extension now accounted for in confdefs.h 4.104.114.84.95
(edit) @3b89891   04/14/98 20:54:26 Joel Sherrill Now accounts for region used by RTEMS malloc and extension used by newlib. 4.104.114.84.95
(edit) @8f95b5f   03/30/98 14:01:19 Joel Sherrill Moved bsp_postdriver_hook() to a shared file and made it a common … 4.104.114.84.95
(edit) @6937fd82   03/30/98 13:59:07 Joel Sherrill Renamed crt0.o to crt0_go32.o to avoid build problems. 4.104.114.84.95
(edit) @33442772   03/30/98 13:42:13 Joel Sherrill Update from "erik.ivanenko" <erik.ivanenko@…>. Also removed … 4.104.114.84.95
(edit) @4e01c9c   03/21/98 15:44:26 Joel Sherrill Added BSP specific start since it had become VERY complex to attempt … 4.104.114.84.95
