Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/lib/libbsp/i386
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @9608320   11/22/99 13:41:11 Joel Sherrill Patch rtems-rc-19991117-4.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @08311cc3   11/17/99 17:51:34 Joel Sherrill Updated copyright notice. 4.104.114.84.95
(edit) @c8cad188   11/09/99 22:16:16 Joel Sherrill Removed. 4.104.114.84.95
(edit) @45544f0   10/27/99 20:50:57 Joel Sherrill Patch from Aleksey (Quality Quorum <qqi@…>) to increase … 4.104.114.84.95
(edit) @3abbfdb   10/27/99 19:27:05 Joel Sherrill Added $(EXEEXT) in attempt to help Cygwin install process. 4.104.114.84.95
(edit) @66a8c6f   10/26/99 15:21:01 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> to fix a small bug … 4.104.114.84.95
(edit) @99826740   10/26/99 01:35:36 Joel Sherrill Modifications from Erik Ivanenko <erik.ivanenko@…> to add … 4.104.114.84.95
(edit) @f70598c7   10/26/99 01:34:42 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…> to fix some … 4.104.114.84.95
(edit) @1f350ef9   10/06/99 20:54:06 Joel Sherrill Removed aclocal.m4 generated from aclocal macros 4.104.114.84.95
(edit) @54eccb1a   10/06/99 20:52:34 Joel Sherrill Removed configure generated from configure.in 4.104.114.84.95
(edit) @fce982a8   10/05/99 19:17:45 Joel Sherrill Corrected comment. 4.104.114.84.95
(edit) @b22feedc   10/05/99 18:38:04 Joel Sherrill Modified to remove reference to Force CPU386. Actually this was a … 4.104.114.84.95
(edit) @6d81ea3   10/05/99 14:20:12 Joel Sherrill Removed targets and configurations that are no longer functional and … 4.104.114.84.95
(edit) @4075af6f   10/05/99 13:49:54 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @811804fe   10/04/99 19:15:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to make fix bug … 4.104.114.84.95
(edit) @b62a92c   10/04/99 18:20:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The patch below … 4.104.114.84.95
(edit) @4f021c0   10/04/99 17:33:23 Joel Sherrill Removed Makefile.in generated from Makefile.am 4.104.114.84.95
(edit) @473b4e5   10/04/99 13:30:15 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @e1d8abb   09/07/99 13:45:03 Joel Sherrill Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius … 4.104.114.84.95
(edit) @1d4048b2   08/11/99 23:45:57 Joel Sherrill Patch from Tony R. Ambardar <tonya@…>: I'm attaching a … 4.104.114.84.95
(edit) @3a8915e   08/06/99 17:55:25 Joel Sherrill Patch rtems-rc-19990709-6-diff from Ralf Corsepius … 4.104.114.84.95
(edit) @a1c70a2   08/05/99 18:02:15 Joel Sherrill Fixed typo on report from Tony R. Ambardar <tonya@…>. 4.104.114.84.95
(edit) @783e8322   08/03/99 13:52:59 Joel Sherrill Patch from Eric Valette <valette@…> to fix interrupt … 4.104.114.84.95
(edit) @26eff5c   08/02/99 20:26:57 Joel Sherrill Fix By Joel based on suggestion from Ian Lance Taylor <ian@…> … 4.104.114.84.95
(edit) @1896a650   07/30/99 17:52:50 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: The main topic … 4.104.114.84.95
(edit) @aa9eb940   07/30/99 17:28:11 Joel Sherrill Fixed typos. 4.104.114.84.95
(edit) @38bfb0d   07/26/99 21:35:15 Joel Sherrill Patch from Eric Valette <valette@…> based on a tremendous … 4.104.114.84.95
(edit) @29e68b75   07/26/99 21:26:44 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This patch is … 4.104.114.84.95
(edit) @08b5f55   07/26/99 20:31:49 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: A bug in … 4.104.114.84.95
(edit) @eb299afc   07/26/99 20:20:22 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @6693a68   07/26/99 20:00:37 Joel Sherrill This is part of a major patch from Ralf Corsepius … 4.104.114.84.95
(edit) @c8d9183   07/02/99 18:57:11 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> that splits … 4.104.114.84.95
(edit) @455d8552   06/24/99 17:53:16 Joel Sherrill Added dummy gnatinstallhandler code for all BSPs. This lets Ada … 4.104.114.84.95
(edit) @e72dfa23   06/18/99 14:30:09 Joel Sherrill Patch from Eric Valette <valette@…> based on bug report … 4.104.114.84.95
(edit) @8c92fa3   06/16/99 14:55:28 Joel Sherrill Patcg from Ralf Corsepius <corsepiu@…>: -- configure … 4.104.114.84.95
(edit) @d2d22780   06/15/99 22:46:44 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: > When I run … 4.104.114.84.95
(edit) @8e0dcade   06/15/99 22:01:04 Joel Sherrill Patch from Rosimildo DaSilva? <rdasilva@…> to make C++ … 4.104.114.84.95
(edit) @15aa5ffb   06/14/99 18:54:24 Joel Sherrill Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius … 4.104.114.84.95
(edit) @ba46ffa6   06/14/99 16:51:13 Joel Sherrill This is a large patch from Eric Valette <valette@…> that … 4.104.114.84.95
(edit) @af84b968   05/27/99 18:53:02 Joel Sherrill Switched from picking up the .rel for each subdirectory in the BSP … 4.104.114.84.95
(edit) @7398901   05/27/99 15:46:00 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @fbec4a1   05/18/99 17:33:52 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @44dd8a61   05/14/99 16:23:42 Joel Sherrill Added 3COM 3C509 driver from Rosimildo DaSilva? <rdasilva@…>. 4.104.114.84.95
(edit) @ddd22e5   05/11/99 15:15:03 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…> to correct 32 bit … 4.104.114.84.95
(edit) @8846bbd   04/28/99 13:59:11 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: I have made … 4.104.114.84.95
(edit) @16a384cf   04/23/99 16:35:11 Joel Sherrill New BSP from Tony R. Ambardar <tonya@…> from the University … 4.104.114.84.95
(edit) @1059abcd   04/19/99 15:37:36 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @7cdf7fc1   04/19/99 15:27:19 Joel Sherrill After discussion with Eric Norum <eric@…>, I added … 4.104.114.84.95
(edit) @196094eb   04/19/99 13:19:14 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This one is … 4.104.114.84.95
(edit) @c00fa38   04/16/99 18:17:31 Joel Sherrill Patch from Ralf Corsepius <corsepiu@@faw.uni-ulm.de>: 2) … 4.104.114.84.95
(edit) @98d051f   04/16/99 18:15:08 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: 1) … 4.104.114.84.95
(edit) @8cdb582   04/12/99 15:41:33 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: This patch … 4.104.114.84.95
(edit) @3c0e80c3   04/06/99 22:07:36 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to preinstall all … 4.104.114.84.95
(edit) @c5f2e5b   03/31/99 23:11:47 Joel Sherrill Regenerated. 4.104.114.84.95
(edit) @0e78ec3a   03/31/99 23:11:38 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @5cfcd7e   03/31/99 22:59:13 Joel Sherrill Removed warnings. 4.104.114.84.95
(edit) @a43ad5cd   03/30/99 15:54:37 Joel Sherrill Patch from Tony R. Ambardar <tonya@…> to add byte wide … 4.104.114.84.95
(edit) @23291e99   03/26/99 15:42:39 Joel Sherrill Patch from Rosimildo DaSilva? <rdasilva@…> and Emmanuel … 4.104.114.84.95
(edit) @aec5da4   03/25/99 21:42:52 Joel Sherrill Patch from Rosimildo DaSilva? <rdasilva@…>: Problem: … 4.104.114.84.95
(edit) @244ecd9   03/24/99 23:14:36 Joel Sherrill These files were not added as part of a recent patch from Ralf … 4.104.114.84.95
(edit) @9b8baa1   03/23/99 18:02:17 Joel Sherrill Automake II patch from Ralf Corsepius <corsepiu@…>. … 4.104.114.84.95
(edit) @d8ff793   03/19/99 22:27:02 Joel Sherrill Towards automake XI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @5906ac5   03/19/99 22:10:04 Joel Sherrill Towards automake X patch from Ralf Corsepius … 4.104.114.84.95
(edit) @1105818d   03/18/99 16:36:50 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: Erik Ivanenko pointed … 4.104.114.84.95
(edit) @4f6d73a   03/03/99 16:22:57 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…> to correct a bug … 4.104.114.84.95
(edit) @9d81380   03/01/99 23:50:22 Joel Sherrill Updated Ethernet driver from Erik Ivanenko … 4.104.114.84.95
(edit) @d6a5c81   02/24/99 15:26:38 Joel Sherrill Switch to using standard compile rule for assembly. 4.104.114.84.95
(edit) @c0438add   02/18/99 21:09:25 Joel Sherrill Renamed network to wd8003. 4.104.114.84.95
(edit) @1094cf0d   02/18/99 21:06:17 Joel Sherrill Patch from Emmanuel RAGUET <raguet@…> to add files that … 4.104.114.84.95
(edit) @3204a06   02/18/99 20:58:46 Joel Sherrill Added comments. 4.104.114.84.95
(edit) @51450d7   02/18/99 20:58:13 Joel Sherrill Added NE2000 Driver from Ian Lance Taylor <ian@…>. Comments: … 4.104.114.84.95
(edit) @8548fe0   02/18/99 18:36:05 Joel Sherrill Part of the automake VI patch from Ralf Corsepius … 4.104.114.84.95
(edit) @e029467   02/18/99 15:16:37 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: You will find … 4.104.114.84.95
(edit) @7cc7a74   02/15/99 16:46:54 Joel Sherrill Patch from Eric Valette <valette@…> to correct _exit … 4.104.114.84.95
(edit) @97d6366   01/20/99 21:59:09 Joel Sherrill Changed call to rtems_close() to close(). 4.104.114.84.95
(edit) @c27b2d0d   01/20/99 18:55:50 Joel Sherrill Update of network driver from Erik Ivanenko … 4.104.114.84.95
(edit) @5f22d091   01/19/99 21:29:29 Joel Sherrill Removed referencing to network driver since it has not been merged yet. 4.104.114.84.95
(edit) @c1ee30f   01/04/99 16:24:59 Joel Sherrill Patch from D. V. Henkel-Wallace <gumby@…> to remove unused … 4.104.114.84.95
(edit) @96b46bf   01/04/99 16:23:29 Joel Sherrill Patch from D. V. Henkel-Wallace <gumby@…> to mark sav as unused. 4.104.114.84.95
(edit) @a54541d8   12/17/98 18:12:36 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to eliminate … 4.104.114.84.95
(edit) @7359911   12/15/98 19:40:27 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Some … 4.104.114.84.95
(edit) @0162910   12/14/98 23:15:38 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…> to rename all .s … 4.104.114.84.95
(edit) @b2e180b7   12/14/98 22:15:57 Joel Sherrill Renamed ASFLAGS to ASMFLAGS for consistency per suggestion from Ralf … 4.104.114.84.95
(edit) @97e2729d   11/23/98 17:38:09 Joel Sherrill Added --disable-multiprocessing flag and modified a lot of files to … 4.104.114.84.95
(edit) @967f3aaa   11/23/98 16:38:28 Joel Sherrill Added networking. 4.104.114.84.95
(edit) @20ad9e9d   11/23/98 14:28:09 Joel Sherrill New network driver from Erik Ivanenko <erik.ivanenko@…>. 4.104.114.84.95
(edit) @22fa5832   10/28/98 19:41:06 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: The RTEMS i386 stub … 4.104.114.84.95
(edit) @c77b2ca   10/22/98 17:30:12 Joel Sherrill Typos spotted by Ian Lance Taylor <ian@…>. 4.104.114.84.95
(edit) @db538d8   10/22/98 17:28:38 Joel Sherrill Added missing .rodata and *(.gnu.linkonce.r*) section. 4.104.114.84.95
(edit) @6278b8b   10/22/98 17:27:14 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: I noticed that in the … 4.104.114.84.95
(edit) @4cfdf321   10/15/98 14:38:10 Joel Sherrill Uncommented the conditional stuff for "good gas 16 bit code". 4.104.114.84.95
(edit) @42c0b9ee   10/07/98 14:54:02 Joel Sherrill NEXT_GAS should have been NEW_GAS. Spotted by Emmanuel Raguet … 4.104.114.84.95
(edit) @72640a3   10/06/98 20:56:13 Joel Sherrill Removed files pc386uart.h and pcibio.h from Makefile since they are … 4.104.114.84.95
(edit) @dc6763c8   10/06/98 13:02:51 Joel Sherrill Patch from Emmanuel Raguet <raguet@…> to add networking … 4.104.114.84.95
(edit) @0ebbf66   10/05/98 22:36:06 Joel Sherrill Large patch from Erik Ivanenko <erik.ivanenko@…> which moves … 4.104.114.84.95
(edit) @2c3840b   09/30/98 20:58:39 Joel Sherrill Added new autoconf test for i386 code16/code32 support. The guts of … 4.104.114.84.95
(edit) @4ca5bd8   09/30/98 17:27:57 Joel Sherrill Changed based on patch from pc386 linkcmds from Ian Lance Taylor … 4.104.114.84.95
(edit) @d1d47664   09/30/98 17:17:23 Joel Sherrill Patch from Ian Lance Taylor <ian@…>: The pc386 linker … 4.104.114.84.95
(edit) @da38d8a   09/24/98 15:43:38 Joel Sherrill Removed superfluous initialization of PC video. 4.104.114.84.95
(edit) @32f3e34   09/24/98 13:55:18 Joel Sherrill Patch from Erik Ivanenko <erik.ivanenko@…>: Please find … 4.104.114.84.95
