# # ChangeLog for c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 10:53:49 Mon, 26 Jul 1999 21:26:44 GMT Joel Sherrill [29e68b75] * Makefile.am (modified) * Makefile.in (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * c/Makefile.am (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/pc386/tools/binpatch.c (deleted) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/make/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/directory.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/README (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * make/custom/ts_386ex.cfg (modified) * make/directory.cfg (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * tools/Makefile.in (modified) * tools/build/Makefile.am (modified) * tools/build/Makefile.in (modified) * tools/build/binpatch.c (modified) * tools/build/config.h.in (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/configure (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/configure (modified) * tools/cpu/unix/configure.in (modified) * tools/update/Makefile.in (modified) Patch from Ralf Corsepius : This patch ... Mon, 26 Jul 1999 20:20:22 GMT Joel Sherrill [eb299afc] * Makefile.am (added) * aclocal/bsp-alias.m4 (added) * aclocal/check-newlib.m4 (added) * aclocal/check-rdbg.m4 (added) * aclocal/enable-rtemsbsp.m4 (added) * aclocal/project-root.m4 (added) * aclocal/target.m4 (added) * c/Makefile.am (added) * c/aclocal.m4 (added) * c/configure (added) * c/configure.in (added) * c/src/Makefile.am (added) * c/src/aclocal.m4 (added) * c/src/configure (added) * c/src/configure.in (added) * c/src/exec/aclocal.m4 (added) * c/src/exec/configure (added) * c/src/exec/configure.in (added) * c/src/lib/aclocal.m4 (added) * c/src/lib/configure (added) * c/src/lib/configure.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/aclocal.m4 (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (added) * c/src/make/Makefile.am (added) * c/src/make/Makefile.in (added) * c/src/make/Makefile.inc.in (added) * c/src/make/Templates/Makefile.am (added) * c/src/make/Templates/Makefile.dir (added) * c/src/make/Templates/Makefile.in (added) * c/src/make/Templates/Makefile.leaf (added) * c/src/make/Templates/Makefile.lib (added) * c/src/make/aclocal.m4 (added) * c/src/make/compilers/Makefile.am (added) * c/src/make/compilers/Makefile.in (added) * c/src/make/compilers/gcc.cfg.in (added) * c/src/make/configure (added) * c/src/make/configure.in (added) * c/src/make/custom/Makefile.am (added) * c/src/make/custom/Makefile.in (added) * c/src/make/custom/default.cfg.in (added) * c/src/make/main.cfg.in (added) * c/src/make/target.cfg.in (added) * c/src/tests/aclocal.m4 (added) * c/src/tests/configure (added) * c/src/tests/configure.in (added) * make/Makefile.am (added) * make/Templates/Makefile.am (added) * make/Templates/Makefile.in (added) * make/compilers/Makefile.am (added) * make/compilers/Makefile.in (added) * make/custom/Makefile.am (added) * make/custom/Makefile.in (added) * tools/Makefile.am (added) * tools/Makefile.in (added) * tools/cpu/Makefile.am (added) * tools/cpu/aclocal.m4 (added) * tools/cpu/configure (added) * tools/cpu/configure.in (added) This is part of a major patch from Ralf Corsepius [16a384cf] * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/README (added) * c/src/lib/libbsp/i386/ts_386ex/bsp_specs (added) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/clock/ckinit.c (added) * c/src/lib/libbsp/i386/ts_386ex/clock/rtc.c (added) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (added) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (added) * c/src/lib/libbsp/i386/ts_386ex/include/coverhd.h (added) * c/src/lib/libbsp/i386/ts_386ex/include/wd80x3.h (added) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/network/ne2000.c (added) * c/src/lib/libbsp/i386/ts_386ex/start/80386ex.h (added) * c/src/lib/libbsp/i386/ts_386ex/start/80386ex.inc (added) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/start/macros.inc (added) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (added) * c/src/lib/libbsp/i386/ts_386ex/start/ts_1325.inc (added) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/startup/README (added) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (added) * c/src/lib/libbsp/i386/ts_386ex/startup/linkcmds (added) * c/src/lib/libbsp/i386/ts_386ex/startup/setvec.c (added) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/timer/timer.c (added) * c/src/lib/libbsp/i386/ts_386ex/timer/timerisr.S (added) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/README (added) * c/src/lib/libbsp/i386/ts_386ex/tools/coff2bin (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/loader.com (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/loader_hybrid_com.asm (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/ts1325.inc (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.ts_386ex (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/i386_ports.adb (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/i386_ports.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-button.adb (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-button.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-led.adb (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-led.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-parallel.adb (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325-parallel.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325.ads (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/ts1325_test.adb (added) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (added) * make/custom/ts_386ex.cfg (added) New BSP from Tony R. Ambardar from the University ...
