@3267f95
01/08/16 21:54:20 |
Gedare Bloom |
i386: prepare for paravirtualized interrupts
5
@505dc61
01/08/16 21:28:45 |
Gedare Bloom |
i386: relocate fatal halt to bsp layer
5
@fd05a05
01/08/16 17:15:46 |
Gedare Bloom |
i386: move idle thread into BSP layer
5
@ca4602e
01/25/16 21:03:00 |
Sebastian Huber |
Use linker set for libio initialization
Update #2408.
5
@ccd5434
01/07/16 08:55:45 |
Sebastian Huber |
score: Introduce Thread_Entry_information
This avoids potential dead …
5
@d5154d0f
12/23/15 20:44:02 |
admin |
api: Remove deprecated Notepads
Notepads where a feature of RTEMS' …
5
@2858939a
12/09/15 11:03:49 |
Sebastian Huber |
bsps: Delete superfluous bsp_pretasking_hook()
Use the …
5
@37030e3
12/09/15 07:05:57 |
Sebastian Huber |
bsps: Call bsp_work_area_initialize() early
Call …
5
@bc792bb
10/16/15 06:26:44 |
Sebastian Huber |
basdefs.h: Add and use RTEMS_PACKED
5
@f97536d
10/16/15 06:21:48 |
Sebastian Huber |
basdefs.h: Add and use RTEMS_UNUSED
5
@f91fbbf4
09/30/15 13:30:09 |
Sebastian Huber |
bsps/i386: Interrupt server support
5
@9cff822a
07/16/15 15:40:05 |
Joel Sherrill |
Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guard
This was …
4.115
@becbeda
06/09/15 20:48:22 |
Joel Sherrill |
pc386/console/fb*.c: Use atomics to avoid dependency on pthreads
4.115
@6f793108
05/23/15 17:32:35 |
dolezj21 |
i386/pc386: default graphics driver changed from VGA to VESA based
4.115
@56399c3b
05/23/15 17:32:00 |
dolezj21 |
i386/pc386/VESA framebuffer driver: modified and extended …
4.115
@5a9c3c1
05/21/15 12:51:36 |
Joel Sherrill |
pc386/clock/ckinit.c: Remove prototyped but not defined warning
4.115
@75acd9e
04/01/15 13:33:25 |
alexander.krutwig |
bsps: Convert clock drivers to use a timecounter
Update #2271.
4.115
@7cdabc49
12/14/14 22:27:06 |
Joel Sherrill |
pc386: Add Edison base support
The current support for the Edison …
4.115
@0a36af04
12/14/14 22:45:08 |
Joel Sherrill |
pc386: Add BSP_ENABLE_COM1_COM4 BSP option
This allows the support …
4.115
@93546b8
12/11/14 21:16:34 |
Joel Sherrill |
pc386: Add BSP_ENABLE_IDE BSP option
This allows the IDE support to …
4.115
@607c854
12/11/14 20:49:49 |
Joel Sherrill |
pc386: Add BSP_ENABLE_VGA BSP option
This allows the VGA and keyboard …
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@e870941
12/04/14 08:38:27 |
Sebastian Huber |
libmisc: More useful default configuration
The dummy.c was a de-facto …
4.115
@038e1dba
12/03/14 23:56:39 |
dolezj21 |
i386: doxygen and comments related to VESA real mode framebuffer
4.115
@d78eac6
12/03/14 23:56:38 |
dolezj21 |
i386/pc386: cammelCase (struct and function names) to underscores, …
4.115
@4081032
12/02/14 22:36:59 |
Ben Gras |
pc386 bsp fix for default mode
If USE_VBE_RM is 0, …
4.115
@280f4ecc
11/20/14 16:05:02 |
Gedare Bloom |
autotools: regenerate preinstall.am for pc386
4.115
@067da5c
11/20/14 14:00:33 |
dolezj21 |
i386/pc386: VESA based frame buffer utilizing real mode interrupt 10h
4.115
@c5a74946
11/20/14 14:00:32 |
dolezj21 |
i386/pc386/include: header files for VESA BIOS EXTENSIONS and VESA …
4.115
@586c86c7
11/20/14 14:00:31 |
dolezj21 |
i386/shared/realmode_int: real mode interrupt interface
4.115
@ec494ff
11/20/14 14:00:26 |
dolezj21 |
i386/pc386: configurable size of descriptor tables
4.115
@46dde0fc
10/23/14 08:05:17 |
Sebastian Huber |
bsps: Move extern "C" to not cover includes
Some includes may use C++ …
4.115
@3785ed6c
10/14/14 00:08:36 |
Joel Sherrill |
i386/pc386: Fix warnings
4.115
@888fadaf
10/12/14 13:31:32 |
Joel Sherrill |
i386/pc386: Clean up and fix warnings
4.115
@4977f07e
10/09/14 17:56:18 |
Joel Sherrill |
i386/pc386: Eliminate multiple warnings
4.115
@6cd2074
09/04/14 15:08:25 |
Joel Sherrill |
pc386/.../bsp.h: Do not include crt.h
crt.h defines such lovely …
4.115
@8fbe2e6
09/04/14 13:59:49 |
Joel Sherrill |
Use correct prototype of benchmark_timer_read()
This change starts …
4.115
@59990cc
08/29/14 02:48:01 |
Chris Johns |
Regenerate all preinstall.am files.
With this patch the preinstall.am …
4.115
@d60e760
04/22/14 07:45:39 |
Sebastian Huber |
bsps: Fix TLS support in linker command files
The TLS section symbols …
4.115
@31f1ef9d
03/17/14 18:25:47 |
Joel Sherrill |
pc386/include/bsp.h: Remove rtems_bsp_delay()
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@960fd85
01/28/14 10:52:17 |
Sebastian Huber |
bsps: Thread-local storage (TLS) for linkcmds
4.115
@fa01e0d0
12/30/13 16:48:57 |
radustoma |
i386/pc386: Add doxygen file headers.
4.115
@e4927ece
12/04/13 14:39:20 |
Sebastian Huber |
bsps: Simplify FreeBSD linker sets
4.115
@f7308976
09/16/13 19:31:52 |
Joel Sherrill |
pc386/console/conscfg.c: Fix spacing
4.115
@3109857c
08/26/13 19:26:50 |
Joel Sherrill |
bsps: Add and use CLOCK_DRIVER_ISRS_PER_TICK_VALUE
pc386 set …
4.115
@838d714
08/09/13 13:23:15 |
Sebastian Huber |
bsp/pc386: Provide local outb() for elink driver
4.115
@efdda565
08/09/13 04:18:17 |
Nick Withers |
Use $(EXEEXT) [defaults to "exe"] to generate binaries
4.115
@2bdcf4fd
07/26/13 14:53:39 |
Vipul Nayyar |
Updated legacy code in i386 pc386
4.115
@88c74ab
07/25/13 13:10:11 |
Sebastian Huber |
score: Merge tod implementation into one file
Delete …
4.115
@311ba73
06/23/13 15:50:55 |
Sebastian Huber |
framebuffer: Add and use FRAMEBUFFER_DEVICE_0_NAME
4.115
@5aa4ed9
04/30/13 17:31:29 |
Joel Sherrill |
i386: PR2010: Remove pc386 BSPs using soft-float
i386 soft-float is …
4.115
@df6818f9
03/18/13 14:24:00 |
Sebastian Huber |
bsps: Support DWARF extension
4.115
@fad2d38
03/08/13 20:55:06 |
Gedare Bloom |
RTEMS: Delete ChangeLog? files.
This commit deletes all RTEMS …
4.115
@c8bd3cd
02/08/13 12:39:59 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@a052181
11/14/12 08:59:10 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_EXIT
Include …
4.115
@26e90fb1
10/30/12 16:42:17 |
Sebastian Huber |
libnetworking: Use system events
Add reserved system events …
4.115
@f33873b
10/29/12 20:14:23 |
Sebastian Huber |
bsp/pc386: Typo
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@61af4b0b
10/15/12 04:00:20 |
Ralf Corsepius |
Include <rtems/framebuffer.h>.
4.115
@63241f8
09/28/12 21:37:58 |
Joel Sherrill |
pc386: Add Cirrus FB Driver to Makefile and configure.ac
The user has …
4.115
@f97e450
09/28/12 21:37:58 |
alex.sever.h |
FB driver for Cirrus GD5446 graphic hardware.
Implementation is …
4.115
@c717fda5
08/06/12 17:03:46 |
Gedare Bloom |
Revert "Add bspopts.h.in."
This reverts commit …
4.115
@bb2b825
07/19/12 13:47:55 |
Ralf Corsepius |
Require automake-1.12.2.
4.115
@0f77281
07/19/12 13:44:32 |
Ralf Corsepius |
Require autoconf-2.69.
4.115
@c2395717
07/14/12 19:26:20 |
Joel Sherrill |
sparc linkcmds.base: Add new FreeBSD TCP/IP stack sections
4.115
@bb08c0c8
05/30/12 18:10:43 |
Jennifer Averett |
pc386: Added sections for rtems-libbsd support.
4.115
@daffa60
05/24/12 04:36:40 |
Ralf Corsepius |
Add bspopts.h.in.
4.115
@65c6425
05/03/12 17:24:46 |
Joel Sherrill |
Remove CVS Id Strings (manual edits after script)
These modifications …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@eb7c6a84
05/10/12 16:17:59 |
Joel Sherrill |
pc386 - Clock driver compiles again plus clean up
The clock drivers …
4.115
@a049ca0f
05/04/12 06:51:43 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@0089173
05/02/12 19:22:46 |
Joel Sherrill |
pc386 - Remove odd $Id$
4.115
@8d0913b8
03/29/12 20:53:16 |
Joel Sherrill |
PC386 - Add files missed in previous commit
4.115
@2cc30b0d
03/29/12 20:28:13 |
Joel Sherrill |
PC386 Add RTD316 and Exar 17D15x multi-port serial card support
4.115
@0f31fddc
03/24/12 21:01:08 |
Sebastian Huber |
bsps: Add shared default IRQ handler
4.115
@184a612e
02/02/12 14:17:25 |
Joel Sherrill |
Merge remote branch 'remotes/origin/gitignore'
4.115
@52694844
02/01/12 21:03:18 |
Joel Sherrill |
Improve comments on console select patch.
4.115
@d1887baf
02/01/12 21:02:03 |
Joel Sherrill |
4.115
@441b90e
02/01/12 20:32:28 |
Jennifer.Averett |
Correct run-time selection of console port.
This was broken by …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@bf5d715
12/09/11 13:12:40 |
Ralf Corsepius |
2011-12-09 Ralf Corsépius <ralf.corsepius@…>
* console/vt.c: …
4.115
@ba5df99c
12/09/11 07:20:28 |
Ralf Corsepius |
4.115
@1c0b8d7
11/18/11 20:11:08 |
Jennifer.Averett |
2011-11-18 Jennifer Averett <Jennifer.Averett@…>
PR 1925 …
4.115
@c145d73
10/17/11 12:37:24 |
Ralf Corsepius |
2011-10-17 Ralf Corsépius <ralf.corsepius@…>
4.115
@50d1c45d
08/29/11 21:36:02 |
Joel Sherrill |
2011-08-29 Joel Sherrill <joel.sherrilL@…>
* configure.ac: …
4.115
@8a7ed82
08/01/11 13:41:37 |
Jennifer.Averett |
2011-08-01 Jennifer Averett <Jennifer.Averett@…>
PR 1802 …
4.115
@5e8bfe2
07/20/11 16:50:19 |
Jennifer.Averett |
2011-07-20 Jennifer Averett <Jennifer.Averett@…>
4.115
@7521e43
07/14/11 15:07:21 |
Jennifer.Averett |
2011-07-14 Jennifer Averett <Jennifer.Averett@…>
4.115
@1ca5402
07/14/11 14:44:59 |
Joel Sherrill |
2011-07-14 Till Straumann <strauman@…>
PR 1833/bsps …
4.115
@58679ac
07/14/11 14:44:47 |
Jennifer.Averett |
* make/custom/pcp4.cfg: New file.
4.115
@89d6aa9
06/19/11 21:16:36 |
Ralf Corsepius |
2011-06-19 Ralf Corsépius <ralf.corsepius@…>
* Makefile.am: …
4.115
@dc1c997b
05/25/11 14:38:45 |
Jennifer.Averett |
2011-05-25 Jennifer Averett <Jennifer.Averett@…>
PR …
4.115
@2bda489e
04/11/11 11:55:42 |
Sebastian Huber |
2011-04-11 Keith Robertson <kjrobert at alumni dot uwaterloo dot ca>
4.115
@20546ace
03/16/11 20:05:26 |
Joel Sherrill |
2011-03-16 Jennifer Averett <jennifer.averett@…>
PR …
4.115
@1fef02ca
03/14/11 14:57:00 |
Joel Sherrill |
2011-03-14 Joel Sherrill <joel.sherrill@…>
PR 1762/cpukit …
4.115
@13e4ab64
03/04/11 21:56:45 |
Joel Sherrill |
2011-03-04 Joel Sherrill <joel.sherrilL@…>
4.115
@6a1176a2
02/25/11 10:53:29 |
Ralf Corsepius |
2011-02-25 Ralf Corsépius <ralf.corsepius@…>
* configure.ac: …
4.115
@528483ed
02/11/11 12:04:30 |
Ralf Corsepius |
2011-02-11 Ralf Corsépius <ralf.corsepius@…>
4.115
@ad6b881
02/09/11 15:57:29 |
Joel Sherrill |
2011-02-09 Jennifer Averett <jennifer.averett@…>
4.115
