# # ChangeLog for c/src/lib/libbsp/h8300 in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 17:04:26 Mon, 31 Jul 2000 19:23:21 GMT Joel Sherrill [3631dad8] * c/src/lib/libbsp/h8300/h8sim/console/console-io.c (modified) * c/src/lib/libbsp/h8300/h8sim/startup/bspstart.c (modified) * c/src/lib/libbsp/h8300/h8sim/startup/linkcmds (modified) Closer to linking. h8300-rtems-ld now core dumps. Thu, 13 Jul 2000 15:05:38 GMT Joel Sherrill [b8a30d07] * Makefile.am (modified) * aclocal/check-itron.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (added) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/h8300/h8sim/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/i960sim/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/libmisc/configure.in (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/itrontests/itrontests.am (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/libtests/libtests.am (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mptests.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/psxtests/psxtests.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/sample.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sptests.am (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmitrontests/tmitrontests.am (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tmtests/tmtests.am (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * testsuites/itrontests/itrontests.am (modified) * testsuites/libtests/libtests.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mptests.am (modified) * testsuites/psxtests/psxtests.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/sample.am (modified) * testsuites/sptests/sptests.am (modified) * testsuites/tmitrontests/tmitrontests.am (modified) * testsuites/tmtests/tmtests.am (modified) Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius [79ef2d81] * c/src/lib/libbsp/h8300/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/.cvsignore (added) New file. Thu, 06 Jul 2000 20:07:34 GMT Joel Sherrill [501d312] * c/src/lib/libbsp/h8300/Makefile.am (added) * c/src/lib/libbsp/h8300/configure.in (added) * c/src/lib/libbsp/h8300/h8sim/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/bsp_specs (added) * c/src/lib/libbsp/h8300/h8sim/configure.in (added) * c/src/lib/libbsp/h8300/h8sim/console/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/console/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/console/console-io.c (added) * c/src/lib/libbsp/h8300/h8sim/include/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/include/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (added) * c/src/lib/libbsp/h8300/h8sim/start/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/start/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/start/start.S (added) * c/src/lib/libbsp/h8300/h8sim/startup/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/startup/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/startup/__main.c (added) * c/src/lib/libbsp/h8300/h8sim/startup/bspstart.c (added) * c/src/lib/libbsp/h8300/h8sim/startup/linkcmds (added) * c/src/lib/libbsp/h8300/h8sim/wrapup/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/wrapup/Makefile.am (added) * make/custom/h8sim.cfg (added) Added baseline for h8 simulator BSP to support the simulator in gdb 5.0
