@f7deb58
06/11/12 06:51:32 |
Sebastian Huber |
bsp/lpc24xx: Simplify EMC configuration
4.115
@d40b09d
06/06/12 13:03:37 |
Sebastian Huber |
bsp/lpc24xx: New BSP variants (PLX800 on LPC1778)
4.115
@7329f55
06/06/12 12:48:23 |
Sebastian Huber |
bsps/arm: Rename linkcmds.armv7 to linkcmds.armv7m
4.115
@c39148d6
06/14/12 12:27:58 |
Sebastian Huber |
libchip: Add support for NS16550 with FDR
4.115
@50fc8f6
06/13/12 07:44:32 |
Sebastian Huber |
sapi: Add nanoseconds_per_tick to configuration
Add …
4.115
@fd153c73
06/12/12 13:27:17 |
Sebastian Huber |
bsps: Replace NIRVANA region
Replace the "NIRVANA" region with the …
4.115
@721fe34
05/31/12 20:34:36 |
Joel Sherrill |
Fix C files which had two semi-colons at EOL
4.115
@daffa60
05/24/12 04:36:40 |
Ralf Corsepius |
Add bspopts.h.in.
4.115
@65c6425
05/03/12 17:24:46 |
Joel Sherrill |
Remove CVS Id Strings (manual edits after script)
These modifications …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@183af89
05/03/12 19:17:23 |
Joel Sherrill |
Miscellaneous - Clean up file headers so patterns followed
XXX
4.115
@42547e07
05/10/12 12:26:07 |
Joel Sherrill |
nds - Clock driver compiles again
4.115
@4523829a
05/10/12 12:25:29 |
Joel Sherrill |
nds/libnds - Fix missing prototype warning and formatting
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@2f54f8d5
05/04/12 06:51:43 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@fe530231
05/03/12 19:13:23 |
Joel Sherrill |
nds/linkcmds - Remove execute permission
4.115
@cfaa366
05/03/12 17:55:58 |
Joel Sherrill |
General - Remove extraneous blank line in license message
Many files …
4.115
@07896ad5
05/02/12 19:23:18 |
Joel Sherrill |
smdk2410 - Remove odd $Id$
4.115
@560dbd68
05/02/12 19:23:02 |
Joel Sherrill |
gp32 - Remove odd $Id$
4.115
@3c6d7ae
04/24/12 12:00:54 |
Sebastian Huber |
bsps/stackalloc: Use stack section symbols
4.115
@c24d9823
04/23/12 08:44:47 |
Sebastian Huber |
bsp/lpc24xx: Fix define name
4.115
@d2c665b7
04/20/12 13:29:00 |
Sebastian Huber |
bsps/arm: Make the Clock_isr() static again
4.115
@64c44c1
04/20/12 07:20:17 |
Sebastian Huber |
bsps/arm: Remove superfluous include
4.115
@b2d9478
04/19/12 18:15:17 |
Joel Sherrill |
lpc shared: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@556ac5a
04/19/12 18:15:03 |
Joel Sherrill |
armv7m shared: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@b7a4a38
04/19/12 17:52:46 |
Joel Sherrill |
nds: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@e1f81100
04/19/12 17:51:53 |
Joel Sherrill |
gba: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@7867bbd
04/19/12 17:51:03 |
Joel Sherrill |
edb7312: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@7be19f8
04/15/12 19:15:22 |
Sebastian Huber |
bsp/stm32f4: API changes
4.115
@228ece9
04/12/12 19:27:56 |
Sebastian Huber |
bsp/stm32f4: Add IO and RCC
4.115
@e230fb4
03/29/12 19:23:14 |
Sebastian Huber |
bsp/stm32f4: New BSP
4.115
@d8f05c83
03/26/12 16:41:45 |
Sebastian Huber |
bsps/arm: Add BSP_ARMV7M_SYSTICK_PRIORITY
4.115
@5ea637ed
03/26/12 16:40:31 |
Sebastian Huber |
bsps/arm: Add BSP_ARMV7M_IRQ_PRIORITY_DEFAULT
4.115
@1aebb70
04/07/12 17:07:04 |
Sebastian Huber |
bsps: Update due to API changes
4.115
@a73884e9
03/24/12 21:56:37 |
Sebastian Huber |
bsp/lm3s69xx: Reflect new Qemu patch
4.115
@bd0fb473
03/24/12 21:53:07 |
Sebastian Huber |
bsps: Shared ARMv7-M interrupt support
4.115
@0f31fddc
03/24/12 21:01:08 |
Sebastian Huber |
bsps: Add shared default IRQ handler
4.115
@b2ee4d5f
03/24/12 20:04:40 |
Sebastian Huber |
bsp/lm3s69xx: Format
4.115
@954393ca
03/24/12 19:57:21 |
Sebastian Huber |
bsp/lm3s69xx: Use shared timer stub driver
4.115
@1ed238e
03/24/12 19:55:40 |
Sebastian Huber |
bsp/lm3s69xx: Use shared start.S
4.115
@34c61517
03/24/12 19:14:27 |
Sebastian Huber |
bsps: Shared ARMv7-M clock driver
4.115
@3c0e7f9b
03/24/12 19:06:49 |
Sebastian Huber |
bsp/lm3s69xx: New Qemu patch
4.115
@e8adc8e3
03/24/12 15:59:25 |
Sebastian Huber |
bsp/lpc24xx: Use proper clock value
4.115
@f3cdf279
03/24/12 15:58:31 |
Sebastian Huber |
bsp/lpc24xx: More CAN pin definitions
4.115
@4868c771
03/14/12 15:45:26 |
Sebastian Huber |
4.115
@8d8f363
02/21/12 15:24:37 |
Sebastian Huber |
LPC32XX: Typo
4.115
@e1ebfebf
02/11/12 20:15:06 |
Sebastian Huber |
Patches for Qemu 1.0.50
4.115
@14ee5a1e
02/11/12 20:10:12 |
Sebastian Huber |
Support for NXP LPC1700 family
4.115
@1f8771d2
02/07/12 21:11:50 |
Sebastian Huber |
Use proper ARMv7-M compiler flags.
4.115
@d6f947e
02/07/12 21:09:45 |
Sebastian Huber |
ARMv7-M Systick API change
4.115
@034b041
02/07/12 21:13:04 |
Sebastian Huber |
Fixed bug intoduced due to API changes.
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@3bbffec7
12/07/11 18:10:52 |
Ralf Corsepius |
2011-12-07 Ralf Corsépius <ralf.corsepius@…>
4.115
@f41fb2b
12/06/11 14:01:55 |
Sebastian Huber |
2011-12-06 Sebastian Huber <sebastian.huber@…>
4.115
@6dbbe5b8
12/06/11 13:52:48 |
Sebastian Huber |
4.115
@be8feba8
11/30/11 04:48:11 |
Joel Sherrill |
2011-11-29 Joel Sherrill <joel.sherrilL@…>
* Makefile.am: …
4.115
@4a6cc2a
11/08/11 10:39:46 |
Sebastian Huber |
2011-11-08 Sebastian Huber <sebastian.huber@…>
4.115
@4c622e5
11/08/11 10:18:19 |
Sebastian Huber |
4.115
@467c767
11/07/11 21:46:19 |
Joel Sherrill |
2011-11-07 Joel Sherrill <joel.sherrill@…>
PR 1953/bsps
4.115
@3dcdad4a
11/07/11 21:46:16 |
Joel Sherrill |
PR 1953/bsps
4.115
@18aa7150
11/07/11 08:33:14 |
Sebastian Huber |
2011-11-07 Sebastian Huber <sebastian.huber@…>
4.115
@47f56094
11/07/11 08:26:12 |
Sebastian Huber |
PR …
4.115
@1aa561d
10/18/11 18:28:37 |
Jennifer.Averett |
2011-10-18 Jennifer Averett <Jennifer.Averett@…>
PR …
4.115
@93b8c70
10/18/11 18:26:55 |
Jennifer.Averett |
PR …
4.115
@bdd3b637
10/18/11 18:26:36 |
Jennifer.Averett |
PR …
4.115
@a3931631
10/18/11 18:25:35 |
Jennifer.Averett |
PR …
4.115
@0a91018f
10/18/11 18:25:15 |
Jennifer.Averett |
PR …
4.115
@4f609eec
10/17/11 10:40:00 |
Sebastian Huber |
2011-10-17 Sebastian Huber <sebastian.huber@…>
4.115
@6ae51d2e
10/07/11 11:00:48 |
Ralf Corsepius |
2011-10-07 Ralf Corsépius <ralf.corsepius@…>
4.115
@88807662
09/30/11 10:08:12 |
Ralf Corsepius |
New (Missed during BSP-import).
4.115
@8f21cc0
09/24/11 13:25:45 |
Sebastian Huber |
2011-09-24 Sebastian Huber <sebastian.huber@…>
4.115
@e263c16
09/24/11 13:23:42 |
Sebastian Huber |
4.115
@82525a75
09/22/11 07:09:07 |
Sebastian Huber |
2011-09-22 Sebastian Huber <sebastian.huber@…>
4.115
@61860b57
08/23/11 07:43:11 |
Sebastian Huber |
2011-08-23 Julien Delange <julien.delange@…>
4.115
@8c43f3d
08/22/11 14:09:55 |
Sebastian Huber |
2011-08-22 Sebastian Huber <sebastian.huber@…>
4.115
@7b46d7a
08/15/11 08:12:49 |
Sebastian Huber |
2011-08-15 Julien Delange <julien.delange@…>
* irq/irq.c: …
4.115
@2a514e80
08/08/11 12:36:15 |
Sebastian Huber |
2011-08-08 Sebastian Huber <sebastian.huber@…>
4.115
@18a0c56
08/08/11 12:33:22 |
Sebastian Huber |
4.115
@3ca8c6bc
08/01/11 06:36:37 |
Sebastian Huber |
2011-08-01 Sebastian Huber <sebastian.huber@…>
4.115
@acb692d3
07/21/11 15:32:08 |
Sebastian Huber |
2011-07-21 Sebastian Huber <sebastian.huber@…>
4.115
@542d350e
07/04/11 09:26:19 |
Sebastian Huber |
2011-07-04 Sebastian Huber <sebastian.huber@…>
4.115
@03d2108
07/01/11 13:05:06 |
Sebastian Huber |
2011-07-01 Stephan Hoffmann <sho@…>
Sebastian Huber …
4.115
@30a45737
06/19/11 10:34:09 |
Ralf Corsepius |
2011-06-19 Ralf Corsépius <ralf.corsepius@…>
* Makefile.am: …
4.115
@1f7d0cca
06/19/11 08:12:17 |
Ralf Corsepius |
* Makefile.am: …
4.115
@25874f0
06/07/11 08:00:30 |
Sebastian Huber |
2011-06-07 Sebastian Huber <sebastian.huber@…>
4.115
@d74ed4a
05/19/11 12:30:00 |
Sebastian Huber |
2011-05-19 Sebastian Huber <sebastian.huber@…>
4.115
@76134c5
05/19/11 12:11:36 |
Sebastian Huber |
4.115
@f6083f0
05/19/11 12:09:04 |
Sebastian Huber |
4.115
@c4d9f313
03/28/11 12:27:29 |
Sebastian Huber |
2011-03-29 Sebastian Huber <sebastian.huber@…>
4.115
@f437107
03/28/11 09:00:01 |
Sebastian Huber |
4.115
@305234f7
03/28/11 08:49:58 |
Sebastian Huber |
4.115
@a5082ff8
03/16/11 17:13:20 |
Joel Sherrill |
2011-03-16 Joel Sherrill <joel.sherrill@…>
* README: Add …
4.115
@c446d7c
02/21/11 12:56:34 |
Sebastian Huber |
2011-02-21 Sebastian Huber <sebastian.huber@…>
4.115
@21400c98
02/21/11 12:54:58 |
Sebastian Huber |
Typo.
4.115
@60eac06e
02/21/11 12:54:45 |
Sebastian Huber |
2010-02-21 Sebastian Huber <sebastian.huber@…>
4.115
@c1e5bed
02/11/11 13:07:39 |
Ralf Corsepius |
2011-02-11 Ralf Corsépius <ralf.corsepius@…>
4.115
@2ee9d3d
02/11/11 11:49:52 |
Ralf Corsepius |
4.115
@d390156
02/11/11 11:48:22 |
Ralf Corsepius |
4.115
@3af73566
02/11/11 11:48:20 |
Ralf Corsepius |
4.115
@35ad0b4
02/11/11 11:48:17 |
Ralf Corsepius |
* irq/irq.c, …
4.115
