source: rtems/c/src/lib/libbsp/arm
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @f0c564c   11/12/14 12:57:24 Sebastian Huber bsps/arm: Adjust stacks for ARMv4 Reduce non-IRQ stacks to size zero. … 4.115
(edit) @96a9f4c   11/12/14 13:00:05 alan.cudmore ARM removed shared/abort from several ARM BSPs 4.115
(edit) @a373dc37   11/05/14 23:52:23 Joel Sherrill lpc23xx_tli800-testsuite.tcfg: Add dl02 4.115
(edit) @091c610   11/05/14 23:52:05 Joel Sherrill lpc2362-testsuite.tcfg: Add dl02 4.115
(edit) @0b91cfbf   11/05/14 23:51:43 Joel Sherrill lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests 4.115
(edit) @f9e4139   11/05/14 21:31:36 Joel Sherrill lm3s3749-testsuite.tcfg: Add dl02 4.115
(edit) @8d74b80e   11/04/14 21:05:08 Joel Sherrill lpc23xx_tli800-testsuite.tcfg: Add dl01 4.115
(edit) @6d84a9f   11/04/14 21:04:46 Joel Sherrill lpc2362-testsuite.tcfg: Add dl01 4.115
(edit) @a7812cdc   11/04/14 21:04:28 Joel Sherrill lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01 4.115
(edit) @643e7cb8   11/04/14 21:02:03 Joel Sherrill lm3s3749-testsuite.tcfg: Add dl01 4.115
(edit) @de5596b   11/04/14 02:02:03 Chris Johns Regenerated preinstall.am file. 4.115
(edit) @53dd6d61   11/03/14 18:53:40 Ben Gras BSP for several Beagle products Specifically the beagleboard, … 4.115
(edit) @7a66986   08/22/12 12:39:02 ziemke Added BeagleBoard? BSP Coding done in course of GSoC2012. Commit … 4.115
(edit) @513668f6   10/29/14 16:07:20 chrisn Added missing stm32f4xxxx_adc.h 4.115
(edit) @46dde0fc   10/23/14 08:05:17 Sebastian Huber bsps: Move extern "C" to not cover includes Some includes may use C++ … 4.115
(edit) @040ed0b4   10/18/14 08:55:37 chrisn bsp/stm32f4: Add header files Added register definition headers for … 4.115
(edit) @ddc8165   10/20/14 20:25:22 Joel Sherrill arm/raspberrypi: Fix warnings 4.115
(edit) @770e379   10/20/14 14:15:32 Joel Sherrill arm/csb337/console/fbcons.c: Fix warning 4.115
(edit) @5bdda7f   10/20/14 14:12:46 Joel Sherrill arm/gba/console/conio.c: Fix warning 4.115
(edit) @0f8ee10e   10/20/14 14:11:41 Joel Sherrill arm/edb7312: Fix warnings 4.115
(edit) @425fe40d   10/15/14 23:35:51 Joel Sherrill arm/lpc176x/misc/restart.c: Fix set but not used warning 4.115
(edit) @694debe   10/14/14 16:20:35 Joel Sherrill arm/rtl22xx/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @b3bb88be   10/14/14 16:20:35 Joel Sherrill arm/gumstix/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @c696430   10/14/14 16:20:35 Joel Sherrill arm/gp32/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @7c44572   10/14/14 16:20:35 Joel Sherrill arm/gba/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @61fde4a   10/14/14 16:20:35 Joel Sherrill arm/edb7312/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @c6120ac2   10/14/14 16:20:35 Joel Sherrill arm/csb337/startup/bspstart.c: Ensure bsp_start_default() is static 4.115
(edit) @23c3b3b2   10/14/14 21:50:54 Joel Sherrill c/src/lib/libbsp/arm/rtl22xx/console/uart.c 4.115
(edit) @fc137e7d   10/14/14 21:50:45 Joel Sherrill arm/csb337: Fix warnings 4.115
(edit) @494d2f1f   10/14/14 20:17:19 Joel Sherrill Remove unused pxa255/pmc, update csb337 and gumstix BSPs 4.115
(edit) @d6236971   10/13/14 19:10:11 Joel Sherrill gp32/startup/bspstart.c: Fix warnings 4.115
(edit) @c144c09   10/13/14 19:09:51 Joel Sherrill csb336/startup/bspstart.c: Fix warnings 4.115
(edit) @3c743901   10/13/14 18:20:35 Joel Sherrill arm/gp32/smc/smc.c: Remove unused sm_ECCEncode() and sm_status() 4.115
(edit) @57e8a0d   10/13/14 18:18:55 Joel Sherrill arm/gp32/smc/smc.c: Fix warnings and clean up 4.115
(edit) @116ef2e9   10/13/14 13:19:12 Sebastian Huber bsps/arm: Convert PL011 and PL050 console drivers Use Termios device API. 4.115
(edit) @ff8922c   10/12/14 20:22:27 Joel Sherrill arm/gba/console: Fix warnings and clean up 4.115
(edit) @d3c8245f   10/11/14 23:46:13 Joel Sherrill arm/smdk2410/startup/bspreset.c: Include <bsp/bootcard.h> 4.115
(edit) @b184c41   10/11/14 23:46:04 Joel Sherrill arm/rtl22xx/startup/bspreset.c: Include <bsp/bootcard.h> 4.115
(edit) @22ed84bc   10/11/14 23:45:57 Joel Sherrill arm/gumstix/startup/bspreset.c: Include <bsp/bootcard.h> 4.115
(edit) @10eac0e   10/11/14 23:45:47 Joel Sherrill arm/gp32/startup/bspreset.c: Include <bsp/bootcard.h> 4.115
(edit) @47240f2   10/11/14 23:45:39 Joel Sherrill arm/gba/startup/bspreset.c: Include <bsp/bootcard.h> 4.115
(edit) @c0662b6   10/11/14 23:45:32 Joel Sherrill arm/edb7312/startup/bspreset.c: Include <bsp/bootcard.h> 4.115
(edit) @7748d8d   10/11/14 23:44:50 Joel Sherrill arm/csb337/startup/bspreset.c: Include <bsp/bootcard.h> 4.115
(edit) @2faaf4b   10/13/14 14:11:02 Sebastian Huber bsps/arm: Move abort stack Move abort stack above the other exception … 4.115
(edit) @ef4c461   10/09/14 20:35:10 Joel Sherrill arm/nds: Warning clean up This patch eliminates most of the warnings … 4.115
(edit) @ab31e8e1   10/09/14 17:55:52 Joel Sherrill gumstix/include/bsp.h: Do not include libchip/serial to avoid … 4.115
(edit) @bc77bda   10/09/14 15:46:43 Joel Sherrill csb337/include/bsp.h: Do not include libchip/serial to avoid conflicts … 4.115
(edit) @6279149   10/08/14 21:04:56 Joel Sherrill Add console-polled.h and update all BSPs that should use it. The file … 4.115
(edit) @037b57a   10/10/14 09:54:55 Sebastian Huber arm: Fix warning 4.115
(edit) @8a3e8c1   10/10/14 08:39:09 Sebastian Huber bsp/stm32f4: Fix warning 4.115
(edit) @9e34ce0   10/10/14 08:26:40 Sebastian Huber bsp/lpc32xx: Fix warning 4.115
(edit) @a845b83   10/10/14 08:26:22 Sebastian Huber bsp/lpc24xx: Fix warnings 4.115
(edit) @d37ec8d8   10/07/14 22:21:35 Joel Sherrill arm/gba/startup/bspgetworkarea.c: Fix warning 4.115
(edit) @ba1d939   10/07/14 22:20:43 Joel Sherrill arm/shared/abort/abort.c: Fix warnings and clean up 4.115
(edit) @8aec7f5   10/07/14 22:20:14 Joel Sherrill arm/lpc24xx/misc/system-clocks.c: Fix warning 4.115
(edit) @d52494e   10/07/14 22:19:44 Joel Sherrill arm/lm3s69xx/startup/bspstart.c: Add include of <bsp/bootcard.h> to … 4.115
(edit) @bcc6c70   10/07/14 22:19:19 Joel Sherrill arm/gdbarmsim/irq/irq.c: Fix warnings 4.115
(edit) @1a829d3   10/07/14 22:18:57 Joel Sherrill arm/gdbarmsim/include/irq.h: Fix spacing 4.115
(edit) @237b3464   10/07/14 22:18:02 Joel Sherrill arm/gba/irq/irq.c: Fix warnings and clean up 4.115
(edit) @27144f44   10/07/14 22:17:38 Joel Sherrill arm/gba/clock/clockdrv.c: Fix warnings and clean up 4.115
(edit) @6ec438e   10/07/14 06:29:16 Sebastian Huber libchip/serial: Add alternative NS16550 driver Use the Termios device API. 4.115
(edit) @7fd5e89   10/07/14 14:28:04 Sebastian Huber termios: Partially hide rtems_termios_tty Move interrupt lock to … 4.115
(edit) @a830cb8   10/07/14 14:27:51 Sebastian Huber termios: Separate flow control from normal handler 4.115
(edit) @7db6953   09/21/14 18:07:41 Tomasz Gregorek bsp/stm32f4XXXX: System clock configuration Added simple math to … 4.115
(edit) @bdd6082   09/18/14 09:07:41 Sebastian Huber bsps: Fix build error Fix build error introduced in … 4.115
(edit) @8fbe2e6   09/04/14 13:59:49 Joel Sherrill Use correct prototype of benchmark_timer_read() This change starts … 4.115
(edit) @74493f05   09/11/14 13:05:02 Sebastian Huber bsps/arm: Delete obsolete compiler flags These flags are obsolete … 4.115
(edit) @ecf64a5e   09/10/14 14:17:02 Sebastian Huber bsps/arm: Add a9mpcore_clock_initialize_early() This is necessary to … 4.115
(edit) @12ab8d6   09/10/14 09:15:44 Sebastian Huber bsps/arm: Fix get cache size 4.115
(edit) @4768ae0f   09/10/14 09:10:04 Sebastian Huber bsps/arm: Fix invalidate instruction cache Do not invalidate the … 4.115
(edit) @0cd13bce   09/10/14 08:42:47 Sebastian Huber bsp/altera-cyclone-v: Add BSP_USE_UART_INTERRUPTS 4.115
(edit) @90f44cd2   09/10/14 08:41:35 Sebastian Huber bsps/arm: Fix GIC tm27 support 4.115
(edit) @f59e64f2   09/09/14 13:48:21 federico.casares arm/lpc176x: Adding "eth" linker script section. 4.115
(edit) @b8662cf   09/05/14 07:47:37 Sebastian Huber bsps/arm: Do not build unused file 4.115
(edit) @78364c7d   09/02/14 23:06:57 Joel Sherrill tms570/Makefile.am: Remove bad networking build info 4.115
(edit) @4761761c   09/02/14 23:05:15 Joel Sherrill lpc23xx_tli800-testsuite.tcfg: Add tests which do not link with debug … 4.115
(edit) @f58f6a7a   09/02/14 23:04:54 Joel Sherrill lpc2362-testsuite.tcfg: Add tests which do not link with debug enabled 4.115
(edit) @4058aa0f   09/02/14 23:04:40 Joel Sherrill lm3s3749-testsuite.tcfg: Add tests which do not link with debug enabled 4.115
(edit) @9f144dda   09/02/14 23:04:14 Joel Sherrill rtl22xx/.../bspreset.c: Eliminate warning for set not used variable 4.115
(edit) @88d9f1cb   09/02/14 23:04:01 Joel Sherrill lpc24xx/.../bspreset.c: Eliminate warning for set not used variable 4.115
(edit) @3e0638f1   09/02/14 23:03:37 Joel Sherrill lpc176x/.../bspreset.c: Eliminate warning for set not used variable 4.115
(edit) @6fc2ea37   09/02/14 23:03:22 Joel Sherrill lm3s69xx/.../bspreset.c: Eliminate warning for set not used variable 4.115
(edit) @08bcf01   09/02/14 23:02:49 Joel Sherrill smdk2410/.../bspreset.c: Eliminate warning for set not used variable 4.115
(edit) @59cb7e9   09/02/14 23:02:11 Joel Sherrill stm32f4/.../bspreset.c: Eliminate warning for set not used variable 4.115
(edit) @2f8c267   09/02/14 23:01:37 Joel Sherrill gp32/.../bspreset.c: Eliminate warning for set not used variable 4.115
(edit) @3d05302   09/02/14 23:01:17 Joel Sherrill csb337/.../bspreset.c: Eliminate warning for set not used variable 4.115
(edit) @be4992b1   09/02/14 23:00:44 Joel Sherrill raspberrypi: Use shared bspreset.c 4.115
(edit) @59990cc   08/29/14 02:48:01 Chris Johns Regenerate all preinstall.am files. With this patch the preinstall.am … 4.115
(edit) @b597c0d   08/28/14 13:44:52 Joel Sherrill Regenerate all preinstall.am files. Apparently, at some point … 4.115
(edit) @d04cb124   08/28/14 04:34:10 Chris Johns arm: Add tests which fail to build with C++ enabled. 4.115
(edit) @5826a1b   08/28/14 00:08:00 Chris Johns preinstall: Regenerated files differ from the repo. 4.115
(edit) @6e60140d   08/27/14 16:00:07 Joel Sherrill nds/Makefile.am: Rework to avoid creating ltos of .rel files This was … 4.115
(edit) @7d3a345   08/26/14 18:53:27 Joel Sherrill lpc40xx_ea_rom_int-testsuite.tcfg: New file 4.115
(edit) @614a088   08/27/14 10:04:26 Chris Johns arm/lm3s3749: Add tests that do not fit. You need --enable-c++ for … 4.115
(edit) @76386c1   08/26/14 14:00:44 Sebastian Huber bsp/altera-cyclone-v: Add DMA support hwlib files 4.115
(edit) @9907dde   08/26/14 14:59:56 Sebastian Huber bsp/altera-cyclone-v: Update to hwlib 13.1 This version is … 4.115
(edit) @d13ce75   08/22/14 15:20:46 pisa bsp/tms570: implemented and tested initialization of Cortex-R … 4.115
(edit) @d5f5432   08/22/14 06:53:10 Christian.Mauderer libchip/dwmac: Make PHY address user configurable This patch allows … 4.115
(edit) @66f1ca6   08/21/14 14:57:47 pisa bsp/tms570: disable huge memory demanding tests for internal RAM build … 4.115
(edit) @46265063   08/21/14 13:38:24 pisa bsp/tms570: implemented support functions to satisfy complete tests … 4.115
