@ecf64a5e
09/10/14 14:17:02 |
Sebastian Huber |
bsps/arm: Add a9mpcore_clock_initialize_early()
This is necessary to …
4.115
@12ab8d6
09/10/14 09:15:44 |
Sebastian Huber |
bsps/arm: Fix get cache size
4.115
@4768ae0f
09/10/14 09:10:04 |
Sebastian Huber |
bsps/arm: Fix invalidate instruction cache
Do not invalidate the …
4.115
@0cd13bce
09/10/14 08:42:47 |
Sebastian Huber |
bsp/altera-cyclone-v: Add BSP_USE_UART_INTERRUPTS
4.115
@90f44cd2
09/10/14 08:41:35 |
Sebastian Huber |
bsps/arm: Fix GIC tm27 support
4.115
@f59e64f2
09/09/14 13:48:21 |
federico.casares |
arm/lpc176x: Adding "eth" linker script section.
4.115
@b8662cf
09/05/14 07:47:37 |
Sebastian Huber |
bsps/arm: Do not build unused file
4.115
@78364c7d
09/02/14 23:06:57 |
Joel Sherrill |
tms570/Makefile.am: Remove bad networking build info
4.115
@4761761c
09/02/14 23:05:15 |
Joel Sherrill |
lpc23xx_tli800-testsuite.tcfg: Add tests which do not link with debug …
4.115
@f58f6a7a
09/02/14 23:04:54 |
Joel Sherrill |
lpc2362-testsuite.tcfg: Add tests which do not link with debug enabled
4.115
@4058aa0f
09/02/14 23:04:40 |
Joel Sherrill |
lm3s3749-testsuite.tcfg: Add tests which do not link with debug enabled
4.115
@9f144dda
09/02/14 23:04:14 |
Joel Sherrill |
rtl22xx/.../bspreset.c: Eliminate warning for set not used variable
4.115
@88d9f1cb
09/02/14 23:04:01 |
Joel Sherrill |
lpc24xx/.../bspreset.c: Eliminate warning for set not used variable
4.115
@3e0638f1
09/02/14 23:03:37 |
Joel Sherrill |
lpc176x/.../bspreset.c: Eliminate warning for set not used variable
4.115
@6fc2ea37
09/02/14 23:03:22 |
Joel Sherrill |
lm3s69xx/.../bspreset.c: Eliminate warning for set not used variable
4.115
@08bcf01
09/02/14 23:02:49 |
Joel Sherrill |
smdk2410/.../bspreset.c: Eliminate warning for set not used variable
4.115
@59cb7e9
09/02/14 23:02:11 |
Joel Sherrill |
stm32f4/.../bspreset.c: Eliminate warning for set not used variable
4.115
@2f8c267
09/02/14 23:01:37 |
Joel Sherrill |
gp32/.../bspreset.c: Eliminate warning for set not used variable
4.115
@3d05302
09/02/14 23:01:17 |
Joel Sherrill |
csb337/.../bspreset.c: Eliminate warning for set not used variable
4.115
@be4992b1
09/02/14 23:00:44 |
Joel Sherrill |
raspberrypi: Use shared bspreset.c
4.115
@59990cc
08/29/14 02:48:01 |
Chris Johns |
Regenerate all preinstall.am files.
With this patch the preinstall.am …
4.115
@b597c0d
08/28/14 13:44:52 |
Joel Sherrill |
Apparently, at some point …
4.115
@d04cb124
08/28/14 04:34:10 |
Chris Johns |
arm: Add tests which fail to build with C++ enabled.
4.115
@5826a1b
08/28/14 00:08:00 |
Chris Johns |
preinstall: Regenerated files differ from the repo.
4.115
@6e60140d
08/27/14 16:00:07 |
Joel Sherrill |
nds/Makefile.am: Rework to avoid creating ltos of .rel files
This was …
4.115
@7d3a345
08/26/14 18:53:27 |
Joel Sherrill |
lpc40xx_ea_rom_int-testsuite.tcfg: New file
4.115
@614a088
08/27/14 10:04:26 |
Chris Johns |
arm/lm3s3749: Add tests that do not fit.
You need --enable-c++ for …
4.115
@76386c1
08/26/14 14:00:44 |
Sebastian Huber |
bsp/altera-cyclone-v: Add DMA support hwlib files
4.115
@9907dde
08/26/14 14:59:56 |
Sebastian Huber |
bsp/altera-cyclone-v: Update to hwlib 13.1
This version is …
4.115
@d13ce75
08/22/14 15:20:46 |
pisa |
bsp/tms570: implemented and tested initialization of Cortex-R …
4.115
@d5f5432
08/22/14 06:53:10 |
Christian.Mauderer |
libchip/dwmac: Make PHY address user configurable
This patch allows …
4.115
@66f1ca6
08/21/14 14:57:47 |
pisa |
bsp/tms570: disable huge memory demanding tests for internal RAM build …
4.115
@46265063
08/21/14 13:38:24 |
pisa |
bsp/tms570: implemented support functions to satisfy complete tests …
4.115
@2ed97d9
08/20/14 19:53:18 |
Joel Sherrill |
libbsp/arm/acinclude.m4: Regenerate for tms570
4.115
@4407ee6
08/20/14 15:24:23 |
kom541000 |
BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)
4.115
@0a66c126
08/16/14 14:15:17 |
Pavel Pisa |
lpc24xx/lpc17xx: lpc24xx_pin_set_function() keep LPC4088 W type pin in …
4.115
@6cdc090
08/10/14 16:35:27 |
Sebastian Huber |
bsp/lpc24xx: Add LPC40XX variants
4.115
@8ae37323
08/10/14 16:36:30 |
Sebastian Huber |
arm: Add support for FPv4-SP floating point unit
This floating point …
4.115
@81329f9
07/15/14 14:20:37 |
bsp/altera-cyclone-v: Add RTC driver.
4.115
@3f9cd87d
07/14/14 14:33:52 |
bsp/altera-cyclone-v: Add a simple I2C driver.
4.115
@1642d27e
07/18/14 10:29:29 |
bsp/altera-cyclone-v: Add socal from hwlib.
Some of the headers from …
4.115
@6e868d87
07/16/14 20:43:05 |
Joel Sherrill |
Add More Testsuite Configuration Files and Update Existing Ones
The …
4.115
@6832a560
07/16/14 00:45:32 |
Chris Johns |
Common ARM A8 code.
4.115
@7ab6046
07/01/14 13:30:07 |
Sebastian Huber |
bsp/altera-cyclone-v: Move MMU configuration table
This makes it …
4.115
@9eb1994f
07/01/14 13:17:40 |
Sebastian Huber |
bsps/arm: Rename bsp_mm_config_table
Rename bsp_mm_config_table to …
4.115
@970aa80
06/12/14 09:18:48 |
Sebastian Huber |
bsp/realview-pbx-a9: Fix SMP startup
4.115
@cb42c9a
06/10/14 14:48:54 |
omgalvan.86 |
lm3s6965-testsuite.cfg: Add pppd.
When trying to compile RTEMS for …
4.115
@19260fb
06/09/14 14:27:18 |
martin.boretto |
bsp/lpc176x: New BSP
4.115
@c19342a7
06/05/14 14:19:21 |
Sebastian Huber |
bsps/arm: Fix Cortex-A9 MPCore clock driver
The nanoseconds extension …
4.115
@1468d70
06/05/14 08:03:55 |
Sebastian Huber |
bsp/altera-cyclone-v: Enable unified L2 cache
4.115
@2a1d86c
06/05/14 08:03:06 |
Sebastian Huber |
bsp/altera-cyclone-v: Move SMP support
4.115
@40599e7e
06/05/14 08:01:42 |
Sebastian Huber |
bsps/arm: Change L2 cache initialization
Do not touch the L1 caches …
4.115
@8fb685b
06/05/14 06:41:56 |
Sebastian Huber |
bsp/altera-cyclone-v: Simplify start hooks
Use …
4.115
@330ccc5
06/04/14 13:34:10 |
Sebastian Huber |
bsp/altera-cyclone-v: Change default baud
Use value for standard U-Boot.
4.115
@82054c80
06/04/14 13:33:42 |
Sebastian Huber |
bsp/altera-cyclone-v: Use NOLOAD for nocache sec
4.115
@9fa88124
06/04/14 09:12:01 |
Sebastian Huber |
bsp/altera-cyclone-v: Simplify MMU config table
4.115
@2d3caccf
06/05/14 11:22:08 |
Sebastian Huber |
bsps/arm: Define ARM_CP15_TEXT_SECTION
Define ARM_CP15_TEXT_SECTION …
4.115
@44fbca3
06/04/14 09:21:43 |
Sebastian Huber |
bsps/arm: Simplify L1 caches support
Delete superfluous/incorrect …
4.115
@82850b8
06/04/14 09:07:11 |
Sebastian Huber |
bsps/arm: Cortex-A9 MPCore start
Invalidate entire branch predictor array.
4.115
@e87ccf5
06/04/14 08:05:14 |
Sebastian Huber |
Enable SCU only on the boot processor.
4.115
@b938108b
06/04/14 08:03:40 |
Sebastian Huber |
Add …
4.115
@041bf16
06/04/14 07:56:49 |
Sebastian Huber |
bsps/arm: Simplify Cortex-A9 MPCore start
Add …
4.115
@4d58458
05/29/14 23:11:30 |
Chris Johns |
bsps/gdbarmsim: Add the missing bspstarthooks.c.
4.115
@5b45d51
05/24/14 00:17:11 |
Chris Johns |
bsps: Do not build tests that require a tick interrupt.
The following …
4.115
@7280fe3f
05/28/14 12:47:07 |
ralf.kirchner |
bsp/altera-cyclone-v: Cleanup
4.115
@12a4d085
05/28/14 12:47:06 |
ralf.kirchner |
bsp/altera-cyclone-v: Reduce size of nocache heap
Network mbufs and …
4.115
@bb70bea1
05/28/14 12:47:05 |
ralf.kirchner |
bsp/altera-cyclone-v: Cache mbufs and clusters
4.115
@32c8960
05/28/14 12:47:03 |
ralf.kirchner |
bsp/altera-cyclone-v: Enable L2 cache for network driver
4.115
@dda78f43
05/28/14 12:47:01 |
ralf.kirchner |
bsp/altera-vyclone-v: Broadcast cache maintenances
4.115
@5fd4e35f
05/28/14 12:47:02 |
ralf.kirchner |
bsp/arm: Broadcast cache maintenances
4.115
@97d0b9b
05/26/14 11:48:36 |
Chris Johns |
bsp/gdbarmsim: Switch to the standard arm/shared/startup.
Switch to …
4.115
@b3fb2ff
05/26/14 01:44:48 |
Chris Johns |
bsp/gdbarmsim: Change syscall functions to not clash with RTEMS …
4.115
@e9d98071
05/22/14 06:21:38 |
Chris Johns |
bsp/zynq: Add BSP_ZYNQ_RAM_LENGTH to allow a user to override the RAM …
4.115
@18bd35bc
05/22/14 06:15:34 |
Chris Johns |
bsps/zynq: Add BSP_ARM_A9MPCORE_UARTCLK to set the UART clock rate.
4.115
@c8b7b32
05/12/14 13:21:52 |
ralf.kirchner |
bsp/altera-caclone-v: Early printk support
Make sure printk can work …
4.115
@0034629
05/07/14 07:23:23 |
Sebastian Huber |
bsps/arm: Declare return types
4.115
@053abcda
04/23/14 23:38:43 |
Joel Sherrill |
multiple BSPs: Remove BSP_SMALL_MEMORY
4.115
@1461b648
05/04/14 22:12:52 |
Chris Johns |
testsuite: Add a per BSP test check for tests not to build.
Provide a …
4.115
@bc9a71b
04/30/14 08:06:11 |
ralf.kirchner |
bsp/altera-cyclone-v: Move mbufs and network clusters to uncached RAM
4.115
@ff13e0b
04/30/14 08:06:10 |
ralf.kirchner |
bsp/altera-cyclone-v: Increase size of nocache region and nocache heap …
4.115
@d60e760
04/22/14 07:45:39 |
Sebastian Huber |
bsps: Fix TLS support in linker command files
The TLS section symbols …
4.115
@d98eea0
04/17/14 09:27:23 |
ralf.kirchner |
bsp/arm: Cleanup L2 cache handling
4.115
@127634c
04/17/14 09:22:53 |
ralf.kirchner |
bsp/arm: Correct L2 cache enable method
4.115
@62fa1ea
04/17/14 09:19:48 |
ralf.kirchner |
bsp/arm: Add cache size methods
Add new methods which deliver the …
4.115
@1c62f74d
04/17/14 09:11:58 |
ralf.kirchner |
bsp/arm: Add L2 cache locking
This level 2 cache is a shared data and …
4.115
@bebcfa57
04/17/14 09:03:50 |
ralf.kirchner |
bsp/arm: Remove unused cache store methods
4.115
@db5a84d
04/17/14 08:59:47 |
ralf.kirchner |
bsp/arm: Correct cache misalignment handling
Correct misalignment …
4.115
@92e2757
04/17/14 08:37:10 |
ralf.kirchner |
bsp/arm: Correct L2 cache flushing
Correct misalignment handling and …
4.115
@cbd9e63
04/17/14 08:30:54 |
ralf.kirchner |
bsp/arm: Remove arm erratum 764369 from L2 cache
Arm erratum 764369 …
4.115
@9ee2ec5
04/17/14 07:43:30 |
ralf.kirchner |
bsp/arm: Consistenly same handling for flushing
It is importeant to …
4.115
@e331e69
04/16/14 14:07:13 |
ralf.kirchner |
bsp/arm: RTEMS_SMP to arm erratum 764369 detection
Move the RTEMS_SMP …
4.115
@707b6172
04/16/14 14:04:56 |
ralf.kirchner |
bsp/arm: Erratum 764369 after enabling SCU
Execute the SCU part of …
4.115
@d9e7d1e
04/16/14 12:27:36 |
ralf.kirchner |
bsp/arm: Correct detection of arm erratum 764368
4.115
@924b47a
04/17/14 07:21:36 |
ralf.kirchner |
bsp/arm: Cleanup L1 cache
4.115
@6ac3969
04/10/14 14:57:02 |
ralf.kirchner |
4.115
@782182eb
04/10/14 14:54:39 |
ralf.kirchner |
bsp/altera-cyclone-v: Change console baud rate
The baud rate of the …
4.115
@53e008b
04/10/14 13:48:05 |
Sebastian Huber |
score: SMP initialization changes
Add and use …
4.115
@cb5eaddf
04/10/14 09:02:52 |
Sebastian Huber |
rtems: Rename rtems_smp_get_current_processor()
Rename …
4.115
@e31e6b9
03/17/14 18:19:51 |
Joel Sherrill |
gba/include/bsp.h: Remove rtems_bsp_delay()
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
