@cb6b9ba
06/19/13 10:57:54 |
Sebastian Huber |
bsp/xilinx-zynq: Use magic UART baud divisor
Use a baud divisor …
4.115
@3f6a823
06/19/13 10:57:26 |
Sebastian Huber |
bsp/xilinx-zynq: Do not start transmitter break
4.115
@49bc9f81
06/18/13 07:18:21 |
Sebastian Huber |
bsp/xilinx-zynq: Use second UART for console
This is in now line with …
4.115
@cf46db85
06/17/13 07:57:42 |
Sebastian Huber |
bsps: Provide simple console selection
4.115
@8bed603
06/03/13 08:03:44 |
Sebastian Huber |
bsp/lm3s69xx: Typos
4.115
@db42c079
05/31/13 11:59:47 |
Sebastian Huber |
bsps/arm: Add SMP support
4.115
@1dcf5fe
05/31/13 07:59:27 |
Sebastian Huber |
bsps/arm: Merge ARMv7 MMU section definitions
4.115
@9984acd
05/13/13 07:42:51 |
Sebastian Huber |
bsps/arm: Add CLOCK_DRIVER_USE_FAST_IDLE option
4.115
@0d671d70
05/27/13 10:43:53 |
Sebastian Huber |
bsps/arm: Move .fast_text section
Move the .fast_text section after …
4.115
@cab410f
05/21/13 12:19:24 |
Sebastian Huber |
bsps: Update due to linker changes
In case the VMA and LMA regions …
4.115
@cfd8d7a
05/08/13 07:30:31 |
Sebastian Huber |
arm: Support VFP-D32 and Neon
4.115
@a94d46c8
05/06/13 12:34:55 |
Sebastian Huber |
bsp/xilinx-zynq: New BSP
4.115
@12d182c4
05/06/13 12:01:10 |
Sebastian Huber |
bsps/arm: Fix register usage
4.115
@e37d57bc
05/06/13 08:59:07 |
Sebastian Huber |
bsps/arm: Add shared GIC tmtests/tm27 support
4.115
@33c98fd
05/06/13 08:20:26 |
Sebastian Huber |
bsps/arm: Remove superfluous parameter
4.115
@f2e9d0d
05/06/13 07:59:16 |
Sebastian Huber |
bsp/raspberrypi: Use shared start code
4.115
@86b79fb
05/06/13 07:54:02 |
Sebastian Huber |
bsp/lm3s69xx: Fix initialization value
4.115
@9bc1913e
05/05/13 22:02:07 |
eugen |
bsp/lm3s69xx: Use interrupts for UART receive
This makes continuous …
4.115
@847e2cac
05/05/13 22:02:06 |
eugen |
bsp/lm3s69xx: More access macros for UART data register
Add mask for …
4.115
@9159711
05/06/13 07:37:12 |
alan.cudmore |
bsp/raspberrypi: Enable unaligned access
4.115
@a91dc98b
04/26/13 13:06:32 |
Sebastian Huber |
bsp/realview-pbx-a9: New BSP
4.115
@9ce65803
05/02/13 11:37:30 |
Sebastian Huber |
bsps/arm: Copy vector table only if necessary
4.115
@27690ec3
05/02/13 11:36:03 |
Sebastian Huber |
bsps/arm: Move .vector section
The .vector section contains …
4.115
@ecf7dd9
05/02/13 09:41:22 |
Sebastian Huber |
bsps/arm: Move CP15 start initialization
4.115
@88cf23f8
04/30/13 13:23:45 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_exception_handler()
4.115
@037e8ae5
05/02/13 15:42:20 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_trans*_table_entries()
4.115
@962e0fac
05/02/13 09:18:09 |
Sebastian Huber |
bsps/arm: Add and use bsp_translation_table_base
4.115
@fb0584f
05/03/13 08:39:26 |
Sebastian Huber |
bsps/arm: Move implementation to inline functions
4.115
@f22bba3
04/26/13 09:03:59 |
eugen |
bsp/lm3s69xx: New BSP variants
Add support for LM3S3749.
4.115
@39586f6
04/03/13 04:24:32 |
Sebastian Huber |
bsp/lpc24xx: Fix register address
4.115
@8ac62c4
03/26/13 15:01:10 |
Sebastian Huber |
bsps/arm: Add thread-local storage (TLS) sections
4.115
@c32b1ef
03/23/13 18:13:07 |
alan.cudmore |
bsp/raspberrypi: New BSP
4.115
@df6818f9
03/18/13 14:24:00 |
Sebastian Huber |
bsps: Support DWARF extension
4.115
@c2015b44
03/14/13 10:54:31 |
Sebastian Huber |
bsp/edb7312: Improve output char
The output char function used by …
4.115
@df3f0226
03/14/13 10:45:44 |
Sebastian Huber |
bsp/edb7312: Fix warnings
4.115
@fad2d38
03/08/13 20:55:06 |
Gedare Bloom |
RTEMS: Delete ChangeLog? files.
This commit deletes all RTEMS …
4.115
@77ac5785
02/12/13 08:27:01 |
Sebastian Huber |
bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS
4.115
@6a22637
02/08/13 13:23:22 |
Sebastian Huber |
bsp/lpc24xx: Move UART probes to separate files
4.115
@c8bd3cd
02/08/13 12:39:59 |
Sebastian Huber |
libchip/serial: Add const qualifier
4.115
@b1d1021
01/11/13 08:27:50 |
Sebastian Huber |
bsp/lpc32xx: Bypass the IrDA modem for UART6
4.115
@f12ef239
01/09/13 15:25:37 |
Sebastian Huber |
bsps/arm: Fix LPC Ethernet driver initialization
4.115
@1419a86
01/08/13 16:18:06 |
Joel Sherrill |
arm/smdk2410: Update to include bspidle.c
This BSP shares code with …
4.115
@b8051837
01/08/13 16:13:46 |
Joel Sherrill |
arm/gp32: Correct compilation error in BSP Idle Thread
Split BSP Idle …
4.115
@40340b2
01/07/13 15:00:52 |
Sebastian Huber |
bsp/lpc24xx: Declare conditionally
4.115
@dd46d67
01/07/13 13:57:32 |
Sebastian Huber |
bsp/lpc32xx: System reset after fatal conditions
4.115
@f1413c4
01/07/13 13:56:53 |
Sebastian Huber |
bsp/lpc24xx: System reset after fatal conditions
4.115
@2460cc7
01/07/13 13:56:18 |
Sebastian Huber |
bsp/lpc24xx: Request system reset for LPC17XX
4.115
@4cc629cd
01/07/13 13:55:54 |
Sebastian Huber |
bsp/lpc24xx: Add WWDT module defines
4.115
@04f399d
01/07/13 09:19:23 |
Sebastian Huber |
arm: Add and use _ARMV7M_Exception_default()
4.115
@0f7abd99
01/04/13 15:25:19 |
Sebastian Huber |
arm: Rename inline functions
Rename arm_status_irq_enable() to …
4.115
@8df0e91
01/04/13 15:22:18 |
Sebastian Huber |
arm: Move inline functions
4.115
@13cf952
01/04/13 14:47:34 |
Sebastian Huber |
arm: Add and use default exception handler
Add and use …
4.115
@370c2c80
01/04/13 12:06:51 |
Sebastian Huber |
arm: Rename arm_exc_interrupt()
Rename arm_exc_interrupt() to …
4.115
@9b2e7143
01/04/13 12:05:28 |
Sebastian Huber |
arm: Move prototypes to new file
Move bsp_interrupt_dispatch() and …
4.115
@4592658
12/18/12 08:24:56 |
Sebastian Huber |
bsps/arm: Move promiscuous mode setting
4.115
@3f58ac7
12/17/12 14:41:53 |
Sebastian Huber |
bsps/arm: Add PHY up/down
All PHYs will be set to power up/down state …
4.115
@50233d37
12/17/12 10:12:20 |
Sebastian Huber |
bsps/arm: Add PHY timeout detection
4.115
@2cd48da
12/14/12 12:08:10 |
Sebastian Huber |
bsps/arm: Add interface down support
4.115
@e99893f9
12/14/12 11:17:15 |
Sebastian Huber |
bsps/arm: Prepare for interface down support
4.115
@573822b
12/14/12 11:07:28 |
Sebastian Huber |
bsps/arm: Use assert() instead of status macros
4.115
@5970dcc9
12/14/12 09:28:18 |
Sebastian Huber |
bsps/arm: Remove superfluous attributes
4.115
@e5a7f846
12/14/12 08:40:44 |
Sebastian Huber |
bsps/arm: Avoid mbuf migration in LPC ethernet
The receive task will …
4.115
@c9562c5
12/18/12 10:18:40 |
Sebastian Huber |
bsp/lpc32xx: Add UART_CLKMODE settings
4.115
@380628ea
12/18/12 09:45:13 |
Sebastian Huber |
bsp/lpc32xx: Configure U4_TX pin for UART 4
4.115
@d1cf326
12/18/12 09:44:48 |
Sebastian Huber |
bsp/lpc32xx: Fix function prototype
4.115
@f25d31f
12/17/12 15:40:23 |
Sebastian Huber |
bsp/lpc32xx: Add idle thread body
4.115
@7371995
12/12/12 08:26:51 |
Sebastian Huber |
bsp/lpc32xx: Fix console baud configuration
4.115
@1bb8782
12/06/12 16:44:55 |
Sebastian Huber |
bsp/gdbarmsim: Do not call bsp_cleanup()
4.115
@fd5c1eb
12/03/12 09:02:29 |
Sebastian Huber |
bsp/csb637: Fix memory map
4.115
@e168410
12/03/12 08:57:59 |
Sebastian Huber |
bsp/csb337: Fix memory map
4.115
@dd8df59
11/14/12 12:59:27 |
Sebastian Huber |
bsps: Interrupt initialization error is fatal
4.115
@a052181
11/14/12 08:59:10 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_EXIT
Include …
4.115
@12007d0
11/14/12 13:21:26 |
Sebastian Huber |
bsps: Include <bspopts.h> in <bsp.h>
4.115
@ef5f359
11/06/12 11:18:10 |
Sebastian Huber |
sapi: Delete duplicate declarations
4.115
@524473fd
11/06/12 11:05:26 |
Sebastian Huber |
bsp/nds: Do not change configuration
4.115
@9f0a68c
10/31/12 10:54:39 |
Sebastian Huber |
libblock: Block device transfer request API change
Add and use …
4.115
@26e90fb1
10/30/12 16:42:17 |
Sebastian Huber |
libnetworking: Use system events
Add reserved system events …
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@f7513a0
08/09/12 14:45:12 |
Sebastian Huber |
bsps: Remove unused bsp_libc_init() prototype
4.115
@2eb5d54c
10/12/12 13:24:32 |
Sebastian Huber |
bsps/arm: Add BSP_USB_OTG_TRANSCEIVER_I2C_ADDR
4.115
@f72b2de
10/12/12 08:06:15 |
Sebastian Huber |
bsp/lpc24xx: Fix PCLK clock divider calculation
4.115
@34d12d97
10/12/12 08:05:20 |
Sebastian Huber |
bsp/lpc24xx: Use 96MHz CCLK for LPC17XX EA BSP
This enables USB …
4.115
@e9e5b92d
10/12/12 08:04:28 |
Sebastian Huber |
bsp/lpc24xx: Evaluate LPC17XX pin type
New pin type …
4.115
@4275124
10/12/12 08:02:35 |
Sebastian Huber |
bsp/lpc24xx: Enable USB clock by PLL0 for LPC17XX
4.115
@6671ddd
10/12/12 07:40:15 |
Sebastian Huber |
bsp/lpc24xx: Fix warnings
4.115
@0e27119
10/11/12 20:52:18 |
Joel Sherrill |
Use proper 3 line form of license text
4.115
@7f5ab84e
09/28/12 11:48:32 |
Sebastian Huber |
bsps/arm: Fix rtems_mii_ioctl() usage
4.115
@afd1967
09/24/12 10:51:47 |
Sebastian Huber |
bsps/arm: Add LPC_DMA_CHANNEL_COUNT
4.115
@25802b42
08/13/12 13:32:03 |
Sebastian Huber |
bsp/lpc32xx: Specify scratch area alignment
4.115
@f5db5d2
08/13/12 13:24:03 |
Sebastian Huber |
bsp/lpc32xx: Stop unused DDRAM_CLK
4.115
@25a8c022
08/13/12 09:51:45 |
Sebastian Huber |
bsp/lpc32xx: Fix clock name
Rename lpc32xx_dram_clk() in …
4.115
@6cfe52f
07/25/12 13:51:21 |
Sebastian Huber |
bsp/lpc32xx: Add lpc32xx_select_nand_controller()
4.115
@833ac60
08/06/12 16:32:49 |
Sebastian Huber |
bsp/lpc24xx: Use USB RAM for fast data section
4.115
@c717fda5
08/06/12 17:03:46 |
Gedare Bloom |
Revert "Add bspopts.h.in."
This reverts commit …
4.115
@0ec2c36
07/19/12 15:02:16 |
Ralf Corsepius |
Use http://www.rtems.org/bugzilla as bug-URL.
4.115
@59bd5115
07/19/12 13:59:46 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@bb2b825
07/19/12 13:47:55 |
Ralf Corsepius |
Require automake-1.12.2.
4.115
@0f77281
07/19/12 13:44:32 |
Ralf Corsepius |
Require autoconf-2.69.
4.115
@a94bcc5a
06/15/12 11:44:08 |
Sebastian Huber |
bsp/lpc24xx: More flexible region configuration
4.115
@62b4fe1
06/15/12 11:07:52 |
Sebastian Huber |
bsp/lpc24xx: Fix timing for M29W320E70
4.115
