@a24ef32
04/04/17 17:00:58 |
joel |
lpc32xx_mzx_stage_1-testsuite.tcfg: Add linpack
5
@ed08fa6
04/04/17 17:00:17 |
joel |
lm3s69xx/../*-testsuite.tcfg: Add linpack
5
@8fd97d2d
04/04/17 16:59:28 |
joel |
atsamv-testsuite.tcfg: Add linpack
5
@621808ea
04/04/17 16:58:19 |
joel |
rtl22xx/../*-testsuite.tcfg: Add linpack
5
@237e60b6
04/04/17 16:57:53 |
joel |
stm32f4/../*-testsuite.tcfg: Add linpack
5
@9bb8a92
04/04/17 16:57:14 |
joel |
tms570/../*-testsuite.tcfg: Add linpack
5
@1301468
04/03/17 10:51:51 |
Sebastian Huber |
bsps: Fix baud settings
Update #2897.
5
@cd3d747
03/27/17 06:01:38 |
Sebastian Huber |
arm: Optimize context switch
Set CPU_ENABLE_ROBUST_THREAD_DISPATCH to …
5
@bd7f099
03/27/17 11:53:01 |
Sebastian Huber |
bsp/tms570: Use shared benchmark timer
5
@e2191d6c
03/27/17 11:21:59 |
Sebastian Huber |
bsp/tms570: Simplify CPU counter support
Only touch the cycle counter …
5
@de9f326
03/27/17 10:09:21 |
Sebastian Huber |
bsp/tms570: Simplify <bsp.h>
5
@b7262b2
03/27/17 10:08:19 |
Sebastian Huber |
bsp/tms570: Remove OPERATION_COUNT define
This is the wrong place to …
5
@1c6926c1
03/21/17 19:39:48 |
kevin-kirspel |
termios: Synchronize with latest FreeBSD headers
Adding modified …
5
@c4b058ca
03/22/17 09:38:27 |
Sebastian Huber |
bsp/atsam: Fix DMA support of some drivers
5
@dc95663e
03/09/17 13:14:42 |
Sebastian Huber |
bsp/tms570: Fix CPU counter frequency
The CPU counter runs with the …
5
@5ca634e9
03/09/17 12:23:54 |
Sebastian Huber |
bsp/tms570: Support printk() early
Allow use of printk() early in the …
5
@ce5bcc87
03/08/17 06:20:48 |
Sebastian Huber |
bsp/beagle: Fix warnings
5
@f25c798
03/07/17 13:57:09 |
Sebastian Huber |
bsp/smdk2410: Fix format warning
5
@f82e9af7
03/07/17 13:55:58 |
Sebastian Huber |
bsp/lpc176x: Fix integer to pointer warnings
5
@65b63b2
03/07/17 13:40:45 |
Sebastian Huber |
bsp/altera-cyclone-v: Remove debug output
5
@2433a8ab
03/07/17 13:32:42 |
Sebastian Huber |
arm: Remove legacy execption support
5
@11f0d52
02/22/17 08:01:40 |
Sebastian Huber |
bsp/xilinx-zynq: Add interrupt support to UART
5
@6b2fcc4
02/21/17 09:30:30 |
Sebastian Huber |
bsp/xilinx-zynq: Use new Termios device driver
5
@7318e7db
02/15/17 12:41:02 |
Sebastian Huber |
bsp/lpc24xx: Remove debug output
5
@180107e9
01/30/17 10:33:31 |
Christian.Mauderer |
bsps/arm: Fix Cortex-M DWT CPU counter.
It is necessary to enable the …
5
@b43c2e8
01/24/17 14:40:31 |
kevin-kirspel |
Adding ARM VFP V2 support
5
@2f8f951b
01/23/17 13:51:27 |
kevin-kirspel |
bsp/lpc32xx: Fix interrupt controller suppport
Enable/Disable? vector …
5
@21267897
01/19/17 20:37:13 |
Gedare Bloom |
raspberrypi: fix math inside of sizeof
Move the subtraction of 1 for …
5
@70e8abf
01/19/17 20:34:18 |
Gedare Bloom |
raspberrypi: use signed int for return variable
Closes #2873.
5
@3f09d635
01/19/17 17:58:44 |
Gedare Bloom |
smdk2410: delete unused variables
Closes #2868.
5
@96ba863
01/17/17 23:56:19 |
joel |
arm/lpc32xx/*/lpc32xx_mzx_stage_1-testsuite.tcfg: Add dl05
5
@ddb28127
01/17/17 14:04:54 |
joel |
arm/stm32f4/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@9c834d1
01/17/17 14:04:33 |
joel |
arm/lpc24xx/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@ed1dcd2
01/17/17 14:04:13 |
joel |
arm/lpc32xx/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@2414497f
01/17/17 14:03:56 |
joel |
arm/lpc176x/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@6c42040
01/17/17 14:03:31 |
joel |
arm/lm3s69xx/*.tcfg: Add fsjffs2gc01 to excluded tests
5
@1fcdd639
01/12/17 22:12:51 |
joel |
powerpc/shared/linkcmds.base: Add .rela.rtemsroset and .rela.rtemsrwset
5
@2a583a00
01/16/17 12:13:36 |
Sebastian Huber |
atsam: Fix SC16IS752 documentation
5
@71f29c12
12/20/16 07:49:32 |
Sebastian Huber |
bsp/atsam: Use standard XDMA throughout
5
@4aba8d79
12/16/16 12:05:34 |
Sebastian Huber |
bsp/atsam: Use standard XDMA for QSPI support
5
@08f1d2f7
12/15/16 14:37:00 |
Sebastian Huber |
bsp/atsam: Add SC16IS752 support
5
@a5c56af
12/15/16 14:03:56 |
Sebastian Huber |
bsp/atsam: Move interrupt setup to PIO_Configure()
5
@a4936b5
12/15/16 13:55:45 |
Sebastian Huber |
bsp/atsam: System initialization for PIO IRQs
5
@8eb5fbb6
12/15/16 12:27:17 |
Sebastian Huber |
bsp/atsamv: Move XDMAD instance out of SPI driver
Use system …
5
@d1c771c
12/15/16 08:56:12 |
Sebastian Huber |
bsp/atsam: Move XDMA IRQ handler to XDMA module
The XDMA is shared by …
5
@cb59276
12/15/16 05:15:13 |
Sebastian Huber |
bsp/atsam: Use _Assert() instead of assert()
5
@fd12159
12/15/16 05:12:46 |
Sebastian Huber |
bsp/atsam: Use inline functions for XDMA access
5
@8dd83d3
12/14/16 10:52:01 |
Sebastian Huber |
bsp/atsam: Optimize SPI interrupt
5
@9686c614
12/14/16 10:42:28 |
Sebastian Huber |
bsp/atsam: Simplify SPI transfer status
5
@de7c171
12/14/16 08:41:30 |
Sebastian Huber |
bsp/atsam: Reduce context switches for SPI transf
5
@b52513b
12/14/16 07:32:02 |
Sebastian Huber |
bsp/atsam: Optimize SPI DMA transfer setup
5
@f104bd3
12/14/16 07:06:14 |
Sebastian Huber |
bsp/atsam: Simplify SPI DMA transfer setup
5
@49b6931
12/14/16 07:00:56 |
Sebastian Huber |
bsp/atsam: Simplify SPI DMA initialization
5
@d0452eb
12/14/16 06:46:18 |
Sebastian Huber |
bsp/atsam: Simplify SPI interrupt handler
5
@c78928f
12/14/16 06:44:34 |
Sebastian Huber |
bsp/atsam: Remove superfluous irq field
5
@9035630f
12/14/16 06:43:25 |
Sebastian Huber |
bsp/atsam: Remove duplicate SPI register field
5
@62e1e0ff
12/14/16 06:37:49 |
Sebastian Huber |
bsp/atsam: Simplify SPI initialization
5
@3afa95b
12/14/16 06:25:49 |
Sebastian Huber |
bsp/atsam: Hide details of SPI driver
5
@1505eca5
12/14/16 06:18:11 |
Sebastian Huber |
bsp/atsam: Align SPI API with PIO_Configure()
5
@5dd02e9
12/13/16 14:49:09 |
Sebastian Huber |
bsp/atsam: Avoid to power on/off the SPI module
5
@f74e2959
12/13/16 14:18:00 |
Sebastian Huber |
bsp/atsam: Speed up SPI DMA transfer start
5
@0396f60
12/13/16 13:28:57 |
Sebastian Huber |
bsp/atsam: Optimize transfer setup checks
5
@3417070d
12/13/16 13:28:32 |
Sebastian Huber |
bsp/atsam: No timeout for SPI DMA transfers
5
@6a9282d
12/09/16 09:49:49 |
Sebastian Huber |
Rename is_internal to always_set_to_false
Update #2825.
5
@28fda62
12/05/16 03:53:54 |
Chris Johns |
testsuite: Add test states to the testsuit configuration files.
5
@e629076
11/29/16 22:19:05 |
Chris Johns |
libdebugger: Build for ARM's without a CP15.
5
@8fd465e
11/24/16 22:45:35 |
Chris Johns |
arm/zynq: Wait for the UART TX FIFO to empty on reset.
5
@562b0a0
11/24/16 09:49:17 |
Sebastian Huber |
bsps/arm: Add Cortex-M DWT CPU counter
5
@31427276
11/23/16 06:47:00 |
Sebastian Huber |
bsp/lpc23xx_tli800: Disable tar01 test
Close #2824.
5
@04bd261
11/13/16 14:18:58 |
Sebastian Huber |
arm: Use TPIDRPRW for current per-CPU control
Use the previously …
5
@bb5d97f3
11/17/16 13:56:53 |
bsp/atsamv: Make size of nocache-memory configurable.
5
@fc718cb8
10/22/16 15:46:56 |
jcmarsh |
Updated xilinx_zynq_a9_qemu bsp README instructions.
5
@24fe213
10/17/16 12:36:49 |
alexander.krutwig |
atsam: multiple messages on one cs low level
5
@f45ddeea
10/13/16 05:51:55 |
Sebastian Huber |
bsp/atsamv: Fix typo
5
@a899549e
10/05/16 12:04:23 |
Sebastian Huber |
bsp/atsam: Provide default buffer counts
5
@10eedb9f
10/05/16 12:04:07 |
Sebastian Huber |
bsp/atsam: Fix PHY detection
5
@425f6cfa
09/22/16 07:56:06 |
pisa |
arm/tms570: document BSP setup with included hardware initialization.
5
@aae17bf3
09/22/16 07:48:26 |
pisa |
arm/tms570: update bootstrap generated preinstall.am
5
@98b6874
09/22/16 07:23:17 |
pisa |
arm/tms570: include TMS570_USE_HWINIT_STARTUP option to select bare …
5
@29430a3
09/22/16 07:50:59 |
pisa |
arm/tms570: include hardware initialization and selftest based on Ti …
5
@5746f10
09/12/16 08:46:58 |
pisa |
arm/tms570: define base addresses of all TMS570LS3137 SPI interfaces.
5
@a396ed4
09/17/16 15:09:11 |
pisa |
bsps/arm: Export bsp_start_hook_0_done symbol from ARM start.S.
The …
5
@55e0be36
09/16/16 10:58:06 |
Sebastian Huber |
termios: Use IMFS nodes for new Termios devices
This makes the new …
5
@0ab86d09
09/13/16 14:32:51 |
alexander.krutwig |
bsp/atsam: Add SPI bus driver
5
@c186de5c
09/14/16 12:46:03 |
alexander.krutwig |
bsp/atsam: Use normal memory for QSPI flash area
This is a …
5
@5eb769ca
09/08/16 21:40:21 |
pisa |
arm/raspberrypi: define bsp_reset to restart board by watchdog.
5
@d4160618
09/07/16 03:59:16 |
Chris Johns |
testsuite: Add libdl/dl05 reloc test.
5
@531924d
09/08/16 05:24:29 |
Sebastian Huber |
bsp/raspberrypi: Rename file
5
@5d369c85
09/03/16 12:10:52 |
pisa |
arm/raspberrypi: use GPU/system timer as clock source.
It has …
5
@40f49d1
09/03/16 12:04:16 |
pisa |
arm/raspberrypi: correct and extend definitions for GPU timer.
5
@df2ee9d
09/07/16 18:28:33 |
pisa |
arm/raspberrypi: basic BCM2836 SMP implementation.
The BSP support is …
5
@38a5385
09/01/16 19:55:51 |
pisa |
arm/raspberrypi: propagate number of configured CPUs into linker script.
5
@dfbedf3
09/01/16 19:40:09 |
pisa |
arm/raspberrypi: rename linkcmds to linkcmds.in to allow their …
5
@4c53be1
09/03/16 01:37:36 |
pisa |
arm/raspberrypi: more definitions of BCM2836 core local peripherals.
5
@bf62c39
09/03/16 00:26:10 |
krohini1593 |
arm/raspberrypi: include definitions of BCM2836 SMP mailboxes.
5
@5c494641
09/02/16 23:30:47 |
pisa |
bsps/arm: remove lock in arm_cp15_set_translation_table_entries().
5
@b9cc5aa
08/22/16 08:41:33 |
bsp/atsam: Add SDRAM IS42S16320F-7BL.
5
@beb289e
08/19/16 09:59:12 |
bsp/atsam: Move ram init values to structure.
5
@cac586e6
09/06/16 08:55:09 |
Sebastian Huber |
bsp/xilinx-zynq: Avoid duplicate declaration
5
@caf2cbd
08/16/16 05:49:41 |
Chris Johns |
arm/xilinx_zynq: Start the second core when an SMP build.
5
