# # ChangeLog for c/src/lib/libbsp/arm in rtems # # Generated by Trac 1.2.1.dev0 # 05/10/24 11:02:58 Mon, 20 Jun 2016 17:10:41 GMT Pavel Pisa [91043bf] * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) bsp/tms570: regenerate preinstall makefile by bootstrap -p. Mon, 07 Dec 2015 15:59:35 GMT Pavel Pisa [8df196f7] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) bsp/tms570: include complete peripheral initialization to SCI driver. ... Mon, 20 Jun 2016 16:55:49 GMT Pavel Pisa [6626efe6] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c (modified) bsp/tms570: update pinmux to provide support for initialization lists ... Mon, 20 Jun 2016 16:56:49 GMT Pavel Pisa [bc884f6] * c/src/lib/libbsp/arm/tms570/include/tms570-pins.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570ls3137zwt-pins.h (added) bsp/tms570: include package balls and PINMMR registers mapping for ... Sun, 19 Jun 2016 13:41:45 GMT Pavel Pisa [fa239ff2] * c/src/lib/libbsp/arm/raspberrypi/misc/vc.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h (modified) arm/raspberrypi: Ensure that buffers used for VC mail box ... Tue, 14 Jun 2016 08:56:09 GMT Sebastian Huber [b61d5cac] * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) bsps: Add CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR Add ... Thu, 02 Jun 2016 11:25:26 GMT Alexander Krutwig [033443c] * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/README (modified) * c/src/lib/libbsp/arm/atsam/configure.ac (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi.c (modified) * c/src/lib/libbsp/arm/atsam/preinstall.am (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.qspiflash (added) bsp/atsam: Support QSPI flash Mon, 11 Apr 2016 11:27:53 GMT Alexander Krutwig [15f0f9b] * c/src/lib/libbsp/arm/atsam/include/bsp.h (modified) * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (modified) atsam: Fix network interface PHY handling Close #2685. Wed, 12 Aug 2015 22:06:49 GMT YANG Qiao [6b5df95] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console-config.c (modified) * c/src/lib/libbsp/arm/raspberrypi/console/console_select.c (added) * c/src/lib/libbsp/arm/raspberrypi/console/fbcons.c (added) * c/src/lib/libbsp/arm/raspberrypi/console/fbcons.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (modified) arm/raspberrypi: add fbcons support for rpi bsp Wed, 12 Aug 2015 22:06:30 GMT YANG Qiao [c12069e] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/console/font_data.h (added) * c/src/lib/libbsp/arm/raspberrypi/console/outch.c (added) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) arm/raspberrypi: add video outchar support for rpi bsp Sat, 21 May 2016 22:18:03 GMT Pavel Pisa [c64d5f0d] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/bspgetworkarea.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds (modified) arm/raspberrypi: move MMU in front of application image to respect ... Wed, 12 Aug 2015 22:06:10 GMT YANG Qiao [c1a9f6a1] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/console/fb.c (added) * c/src/lib/libbsp/arm/raspberrypi/include/rpi-fb.h (added) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) arm/raspberrypi: add VideoCore framebuffer without initialization Sat, 21 May 2016 23:10:21 GMT Pavel Pisa [b96defd] * c/src/lib/libbsp/arm/raspberrypi/misc/vc.c (modified) arm/raspberrypi: Raspberry Pi v2 ALLOCATE_BUFFER VC4 operation ... Sat, 21 May 2016 21:50:31 GMT Pavel Pisa [de378ad] * c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c (modified) * c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/timer.c (modified) arm/raspberrypi: ensure that correct RPI_PERIPHERAL_BASE is provided ... Sat, 21 May 2016 01:10:06 GMT Pavel Pisa [4c59eebf] * c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c (modified) arm/raspberrypi: cmdline enhancement and early access workaround. ... Tue, 31 May 2016 08:25:25 GMT Sebastian Huber [dd2c57d4] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (deleted) * c/src/libchip/Makefile.am (modified) * c/src/libchip/network/README.dwmac (deleted) * c/src/libchip/network/dwmac-1000-core.c (deleted) * c/src/libchip/network/dwmac-1000-dma.c (deleted) * c/src/libchip/network/dwmac-1000-ethernet-mac-ops.c (deleted) * c/src/libchip/network/dwmac-common.h (deleted) * c/src/libchip/network/dwmac-core.c (deleted) * c/src/libchip/network/dwmac-core.h (deleted) * c/src/libchip/network/dwmac-desc-com.c (deleted) * c/src/libchip/network/dwmac-desc-com.h (deleted) * c/src/libchip/network/dwmac-desc-enh.c (deleted) * c/src/libchip/network/dwmac-desc.h (deleted) * c/src/libchip/network/dwmac-regs.h (deleted) * c/src/libchip/network/dwmac.c (deleted) * c/src/libchip/network/dwmac.h (deleted) * c/src/libchip/preinstall.am (modified) libchip: Remove dwmac network interface driver The network ... Tue, 31 May 2016 07:12:43 GMT Sebastian Huber [0546e65e] * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/powerpc/shared/include/linker-symbols.h (modified) bsps: Add defines for some linker subsections The GNU ld sort by ... Tue, 31 May 2016 07:10:24 GMT Sebastian Huber [ccda9459] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds.base (modified) bsps: Sort some sections first by alignment This helps to avoid ... Thu, 19 May 2016 09:36:15 GMT Pavel Pisa [8830bfe6] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/cmdline.c (added) arm/raspberrypi: add cmdline support for rpi bsp. Wed, 12 Aug 2015 22:05:34 GMT YANG Qiao [54c197a] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/include/vc.h (added) * c/src/lib/libbsp/arm/raspberrypi/misc/vc.c (added) * c/src/lib/libbsp/arm/raspberrypi/misc/vc_defines.h (added) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) arm/raspberrypi: add VideoCore frame buffer control support Wed, 12 Aug 2015 22:04:33 GMT YANG Qiao [33e39d31] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h (modified) * c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c (added) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (modified) arm/raspberrypi: add VideoCore mailbox support read and write Thu, 19 May 2016 08:34:18 GMT Pavel Pisa [1258229] * c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c (modified) arm/raspberrypi: add locking around GPIO pin function selection. ... Thu, 19 May 2016 08:29:28 GMT Pavel Pisa [4b62192f] * c/src/lib/libbsp/arm/raspberrypi/gpio/rpi-gpio.c (modified) * c/src/lib/libbsp/arm/raspberrypi/include/rpi-gpio.h (modified) arm/raspberrypi: correct GPIO pin function selection. Original ... Thu, 19 May 2016 08:24:46 GMT Pavel Pisa [e706a9d] * c/src/lib/libbsp/arm/raspberrypi/irq/irq.c (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (modified) arm/raspberrypi: ensure that RTEMS application image can be started ... Tue, 22 Mar 2016 22:13:30 GMT Joel Sherrill [e65c45c] * c/src/ada-tests/mptests/mp01/mptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada/rtems-clock.adb (modified) * c/src/ada/rtems-clock.ads (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/src/clockget.c (deleted) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spclockget/Makefile.am (deleted) * testsuites/sptests/spclockget/init.c (deleted) * testsuites/sptests/spclockget/spclockget.doc (deleted) * testsuites/sptests/spclockget/spclockget.scn (deleted) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) Obsolete rtems_clock_get() directive. This service was marked as ... Fri, 01 Apr 2016 06:33:29 GMT Sebastian Huber [d2c8693] * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (modified) bsp/atsam: Fix mbuf allocation Tue, 16 Feb 2016 13:11:09 GMT Alexander Krutwig [fb29ca55] * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/include/bsp.h (modified) * c/src/lib/libbsp/arm/atsam/network/if_atsam.c (added) bsp/atsam: Add network interface driver Tue, 22 Mar 2016 07:34:16 GMT Sebastian Huber [0bd49f1] * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c (modified) * c/src/lib/libbsp/arm/atsam/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in (modified) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram (modified) bsp/atsam: Add nocache region support Tue, 22 Mar 2016 07:29:59 GMT Sebastian Huber [935e9c7d] * c/src/lib/libbsp/arm/atsam/configure.ac (modified) bsp/atsam: Fix sizes of internal SRAM Wed, 30 Mar 2016 19:04:22 GMT Joel Sherrill [02f4c11] * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) arm/smdk2410/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [85fe6d04] * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) arm/rtl22xx/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [734d62e5] * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) arm/gdbarmsim/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [93acba9] * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) arm/edb7312/include/bsp.h: Do not include Wed, 30 Mar 2016 19:04:21 GMT Joel Sherrill [cf99f21] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) arm/csb336/include/bsp.h: Do not include Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [de4d32d] * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) arm/xilinx-zynq: Remove include of from and ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [e56090ef] * c/src/lib/libbsp/arm/tms570/include/bsp.h (modified) arm/tms570: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [272d421] * c/src/lib/libbsp/arm/stm32f4/include/bsp.h (modified) arm/stm32f4: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [59400251] * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) arm/smdk2410: Remove include of from and ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [da572a7] * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) arm/rtl22xx: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [a5fffb0] * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) arm/realview-pbx-a9: Remove include of from ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [aa78a0f] * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) arm/raspberrypi: Remove include of from and ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [c2b91e6] * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) arm/lpc32xx: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [ac933f9c] * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) arm/lpc24xx: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [8b52b1a] * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (modified) arm/lpc176x: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [9420bf0] * c/src/lib/libbsp/arm/lm3s69xx/include/bsp.h (modified) arm/lm3s69xx: Remove include of from and ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [66fed3d7] * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) arm/gumstix: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [2b22e73d] * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) arm/gdbarmsim: Remove include of from and ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [3d035d8] * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) arm/edb7312: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [748efe9] * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) arm/csb337: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:49 GMT Joel Sherrill [2fb6d161] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) arm/csb336: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:49 GMT Joel Sherrill [ad76eb32] * c/src/lib/libbsp/arm/atsam/console/console.c (modified) * c/src/lib/libbsp/arm/atsam/include/bsp.h (modified) arm/atsam: Remove include of from and fix ... Tue, 29 Mar 2016 18:10:08 GMT Joel Sherrill [64eedac] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) arm/altera-cyclone-v: Remove include of from ... Fri, 25 Mar 2016 15:45:03 GMT Joel Sherrill [9899c91b] * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) arm/xilinx-zynq/include/bsp.h: Do not include Fri, 25 Mar 2016 15:45:02 GMT Joel Sherrill [7dde6b48] * c/src/lib/libbsp/arm/tms570/include/bsp.h (modified) arm/tms570/include/bsp.h: Do not include Fri, 25 Mar 2016 15:45:01 GMT Joel Sherrill [c40f81d4] * c/src/lib/libbsp/arm/stm32f4/include/bsp.h (modified) arm/stm32f4/include/bsp.h: Do not include Fri, 25 Mar 2016 15:45:00 GMT Joel Sherrill [7f21dac] * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) arm/smdk2410/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:59 GMT Joel Sherrill [947985aa] * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) arm/rtl22xx/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:58 GMT Joel Sherrill [dbf08e3] * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) arm/realview-pbx-a9/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:57 GMT Joel Sherrill [ebc8a11] * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) arm/raspberrypi/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:54 GMT Joel Sherrill [4b9db426] * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (modified) arm/lpc32xx/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:52 GMT Joel Sherrill [32971366] * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) arm/lpc24xx/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:43 GMT Joel Sherrill [98e910b4] * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (modified) arm/lpc176x/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:39 GMT Joel Sherrill [d41577c] * c/src/lib/libbsp/arm/lm3s69xx/include/bsp.h (modified) arm/lm3s69xx/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:34 GMT Joel Sherrill [30617a1] * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) arm/gumstix/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:30 GMT Joel Sherrill [846219a1] * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) arm/gdbarmsim/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:28 GMT Joel Sherrill [9604d7ed] * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) arm/edb7312/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:27 GMT Joel Sherrill [c14ece5c] * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) arm/csb337/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:26 GMT Joel Sherrill [85f20112] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) arm/csb336/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:25 GMT Joel Sherrill [413e6e1] * c/src/lib/libbsp/arm/atsam/include/bsp.h (modified) arm/atsam/include/bsp.h: Do not include Fri, 25 Mar 2016 15:44:23 GMT Joel Sherrill [77c0135] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) arm/altera-cyclone-v/include/bsp.h: Do not include Tue, 22 Mar 2016 14:58:04 GMT Joel Sherrill [1a738ed] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg (modified) lpc1768_mbed.cfg: Turn on per function sections Closes #2576. Thu, 17 Mar 2016 07:23:30 GMT Sebastian Huber [1547b623] * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (modified) bsp/realview_pbx_a9_qemu: Fix compiler flags Wed, 16 Mar 2016 00:36:26 GMT Joel Sherrill [78c9fe8] * c/src/lib/libbsp/arm/atsam/make/custom/atsamv-testsuite.tcfg (modified) atsamv-testsuite.tcfg: Add more tests Thu, 10 Mar 2016 20:12:53 GMT Joel Sherrill [5460722] * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq.inc (modified) arm/xilinx_zynq: Add per-section compilation and linking support ... Thu, 10 Mar 2016 19:35:14 GMT Joel Sherrill [9d431a0] * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137.inc (modified) arm/tms570: Add per-section compilation and linking support updates ... Thu, 10 Mar 2016 19:29:22 GMT Joel Sherrill [a006671a] * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4.cfg (modified) arm/stm32f4: Add per-section compilation and linking support ... Thu, 10 Mar 2016 19:25:13 GMT Joel Sherrill [e354ef11] * c/src/lib/libbsp/arm/smdk2410/make/custom/smdk2410.cfg (modified) arm/smdk2410: Add per-section compilation and linking support ... Thu, 10 Mar 2016 19:16:30 GMT Joel Sherrill [5fd3cc07] * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx.cfg (modified) * c/src/lib/libbsp/arm/rtl22xx/make/custom/rtl22xx_t.cfg (modified) arm/rtl22xx: Add per-section compilation and linking support ... Thu, 10 Mar 2016 19:08:26 GMT Joel Sherrill [07252899] * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (modified) arm/realview_pbx_a9_qemu: Add per-section compilation and linking ... Thu, 10 Mar 2016 18:31:37 GMT Joel Sherrill [fa9c057] * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.inc (modified) arm/raspberrypi: Add per-section compilation and linking suppo ... Thu, 10 Mar 2016 18:13:57 GMT Joel Sherrill [7276954] * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx.inc (modified) arm/lpc32xx: Add per-section compilation and linking suppo updates ... Thu, 10 Mar 2016 17:39:54 GMT Joel Sherrill [bfc87114] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc40xx.inc (modified) arm/lpc24xx (lpc40xx variants) Add per-section compilation and ... Thu, 10 Mar 2016 17:13:29 GMT Joel Sherrill [55159ee9] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc24xx.inc (modified) arm/lpc24xx (lpc24xx variants) Add per-section compilation and ... Thu, 10 Mar 2016 00:51:30 GMT Joel Sherrill [8467c31] * c/src/lib/libbsp/arm/atsam/make/custom/atsamv-testsuite.tcfg (added) atsamv-testsuite.tcfg: new file] Thu, 10 Mar 2016 15:36:16 GMT Joel Sherrill [4e059db8] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc17xx.inc (modified) arm/lpc24xx (lpc17xx variants): Add per-section compilation and ... Thu, 18 Feb 2016 07:36:16 GMT Sebastian Huber [90d8567] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/shared/smp/smp-imps.c (modified) * c/src/lib/libbsp/powerpc/qoriq/clock/clock-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/irq.h (modified) * c/src/lib/libbsp/powerpc/qoriq/irq/irq.c (modified) * c/src/lib/libbsp/shared/clockdrv_shell.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/leon3/include/leon.h (modified) * cpukit/score/include/rtems/score/smpimpl.h (modified) * cpukit/score/include/rtems/score/watchdogimpl.h (modified) * cpukit/score/src/kern_tc.c (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/watchdogtick.c (modified) score: Distribute clock tick to all online CPUs Update #2554. Tue, 01 Mar 2016 18:46:18 GMT Joel Sherrill [3f5e0961] * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/README (modified) * c/src/lib/libbsp/arm/smdk2410/console/uart.c (added) * c/src/lib/libbsp/arm/smdk2410/include/bsp.h (modified) * c/src/lib/libbsp/arm/smdk2410/preinstall.am (modified) * c/src/lib/libbsp/arm/smdk2410/smc/smc.c (added) * c/src/lib/libbsp/arm/smdk2410/smc/smc.h (added) * c/src/lib/libbsp/arm/smdk2410/start/start.S (added) * c/src/lib/libbsp/arm/smdk2410/startup/bspidle.c (added) * c/src/lib/libbsp/arm/smdk2410/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/smdk2410/startup/bspstart.c (added) * c/src/lib/libbsp/arm/smdk2410/startup/memmap.c (modified) smdk2410: Resurrect missing gp32 files When the gp32 BSP was ... Sat, 27 Feb 2016 23:19:33 GMT Martin Galvan [8c5c53f4] * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libcpu/arm/shared/include/omap3.h (modified) am335x irq handling improvement This patch makes the following ... Fri, 19 Feb 2016 18:24:03 GMT punitvara [42989d6] * c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c (modified) arm: Fixed typo in file bbb-gpio.c This patch fixes typo ... Sat, 06 Feb 2016 16:24:54 GMT Joel Sherrill [e41d8ce] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg (modified) arm/.../lpc1768_embed.cfg: Disable per function sections updates #2576. Mon, 25 Jan 2016 21:03:00 GMT Sebastian Huber [ca4602e] * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/csb336/Makefile.am (modified) * c/src/lib/libbsp/arm/csb337/Makefile.am (modified) * c/src/lib/libbsp/arm/edb7312/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/rtl22xx/Makefile.am (modified) * c/src/lib/libbsp/arm/smdk2410/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/bfin/TLL6527M/Makefile.am (modified) * c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am (modified) * c/src/lib/libbsp/bfin/eZKit533/Makefile.am (modified) * c/src/lib/libbsp/epiphany/epiphany_sim/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/lm32/lm32_evr/Makefile.am (modified) * c/src/lib/libbsp/lm32/milkymist/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m68k/av5282/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/genmcf548x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5206elite/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf52235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5225x/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5235/Makefile.am (modified) * c/src/lib/libbsp/m68k/mcf5329/Makefile.am (modified) * c/src/lib/libbsp/m68k/mrm332/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/uC5282/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/hurricane/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/malta/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4925/Makefile.am (modified) * c/src/lib/libbsp/mips/rbtx4938/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/or1k/generic_or1k/Makefile.am (modified) * c/src/lib/libbsp/powerpc/beatnik/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen5200/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/haleakala/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme3100/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mvme5500/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ss555/Makefile.am (modified) * c/src/lib/libbsp/powerpc/t32mppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/tqm8xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex4/Makefile.am (modified) * c/src/lib/libbsp/powerpc/virtex5/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh4/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bsplibc.c (deleted) * c/src/lib/libbsp/shared/bsppost.c (deleted) * c/src/lib/libbsp/shared/include/bootcard.h (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon2/Makefile.am (modified) * c/src/lib/libbsp/sparc/leon3/Makefile.am (modified) * c/src/lib/libbsp/sparc64/niagara/Makefile.am (modified) * c/src/lib/libbsp/sparc64/usiii/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/libio_helper_null.c (deleted) * cpukit/libcsupport/src/libio_init.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/sysinit.h (modified) * testsuites/fstests/fsnofs01/init.c (modified) * testsuites/sptests/spsysinit01/init.c (modified) Use linker set for libio initialization Update #2408. Thu, 21 Jan 2016 09:53:16 GMT Sebastian Huber [370cdefd] * c/src/lib/libbsp/arm/shared/armv7m/clock/armv7m-clock-config.c (modified) * cpukit/score/cpu/arm/rtems/score/armv7m.h (modified) arm: Use DWT CYCCNT for timecounter if available Thu, 14 Jan 2016 15:03:51 GMT Sebastian Huber [f2e0f8e] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (added) * c/src/lib/libbsp/arm/atsam/README (added) * c/src/lib/libbsp/arm/atsam/bsp_specs (added) * c/src/lib/libbsp/arm/atsam/clock/systick-freq.c (added) * c/src/lib/libbsp/arm/atsam/configure.ac (added) * c/src/lib/libbsp/arm/atsam/console/console.c (added) * c/src/lib/libbsp/arm/atsam/console/debug-console.c (added) * c/src/lib/libbsp/arm/atsam/include/bsp.h (added) * c/src/lib/libbsp/arm/atsam/include/irq.h (added) * c/src/lib/libbsp/arm/atsam/include/pin-config.h (added) * c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg (added) * c/src/lib/libbsp/arm/atsam/preinstall.am (added) * c/src/lib/libbsp/arm/atsam/startup/bspstart.c (added) * c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/atsam/startup/linkcmds (added) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram (added) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in (added) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram (added) * c/src/lib/libbsp/arm/atsam/startup/pin-config.c (added) * c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h (added) * c/src/lib/libbsp/arm/shared/include/start.h (modified) bsp/atsam: New Close #2529. Thu, 14 Jan 2016 14:48:44 GMT Sebastian Huber [c354fac] * c/src/lib/libbsp/arm/atsam/libraries/libboard/board.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libboard/board_v71_xult.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libboard/resources_v71/system_samv71.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_memories.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/dbg_console.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/compiler.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/chip.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/qspi_dma.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q19.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q20.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q21.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/mcan.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi_dma.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/tc.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/usart.c (modified) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/xdmad.c (modified) bsp/atsam: Port SAM Software Package to RTEMS Update #2529. Tue, 12 Jan 2016 14:34:31 GMT Sebastian Huber [e1eeb883] * c/src/lib/libbsp/arm/atsam/libraries/libboard/board.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/board_v71_xult.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/bmp.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/board_lowlevel.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/board_memories.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/cs2100.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/dbg_console.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/frame_buffer.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/gmacb_phy.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/gmii.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/ili9488.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/ili9488_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/ili9488_ebi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/ili9488_ebi_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/ili9488_reg.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/ili9488_spi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/ili9488_spi_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/image_sensor_inf.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/lcd_color.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/lcd_draw.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/lcd_font.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/lcd_font10x14.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/lcd_gimp_image.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/lcdd.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/led.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/math.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/mcan_config.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/rtc_calib.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/s25fl1.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/include/wm8904.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/resources_v71/system_samv71.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_lowlevel.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/board_memories.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libboard/source/dbg_console.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/chip.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/compiler.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/acc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/adc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/aes.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/afe_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/afec.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/dac_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/efc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/exceptions.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/flashd.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/gmac.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/gmacd.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/hsmci.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/icm.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/isi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/iso7816_4.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/mcan.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/mcid.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/mediaLB.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/mpu.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/pio.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/pio_capture.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/pio_it.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/pmc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/pwmc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/qspi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/qspi_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/rstc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/rtc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/rtt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_acc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_aes.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_afec.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_chipid.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_dacc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_efc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_gmac.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_gpbr.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_hsmci.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_icm.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_isi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_matrix.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_mcan.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_pio.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_pmc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_pwm.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_qspi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_rstc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_rswdt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_rtc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_rtt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_sdramc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_smc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_spi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_ssc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_supc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_tc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_trng.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_twihs.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_uart.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_usart.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_usbhs.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_utmi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_wdt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/component/component_xdmac.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70j19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70j20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70j21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70n19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70n20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70n21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70q19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70q20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/pio/pio_same70q21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70j21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70n21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/same70q21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/same70/system_same70.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_acc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_aes.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_afec.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_chipid.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_dacc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_efc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_gpbr.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_hsmci.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_icm.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_isi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_matrix.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_pio.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_pmc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_pwm.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_qspi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_rstc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_rswdt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_rtc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_rtt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_sdramc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_smc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_spi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_ssc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_supc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_tc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_trng.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_twihs.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_uart.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_usart.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_usbhs.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_utmi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_wdt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/component/component_xdmac.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70j19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70j20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70j21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70n19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70n20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70n21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70q19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70q20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/pio/pio_sams70q21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70j21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70n21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/sams70q21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sams70/system_sams70.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_acc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_aes.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_afec.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_chipid.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_dacc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_efc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_gmac.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_gpbr.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_hsmci.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_icm.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_isi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_matrix.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_mcan.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_mlb.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_pio.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_pmc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_pwm.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_qspi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_rstc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_rswdt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_rtc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_rtt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_sdramc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_smc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_spi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_ssc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_supc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_tc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_trng.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_twihs.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_uart.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_usart.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_usbhs.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_utmi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_wdt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/component/component_xdmac.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71j19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71j20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71j21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71n19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71n20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71n21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71q19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71q20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/pio/pio_samv71q21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71j21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71n21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q19.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q20.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/samv71q21.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/samv71/system_samv71.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/sdramc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/smc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/spi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/spi_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/ssc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/supc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/tc.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/timetick.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/trace.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/trng.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/twi.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/twid.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/uart.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/uart_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/usart.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/usart_dma.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/usbhs.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/video.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/wdt.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdma_hardware_interface.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmac.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/include/xdmad.h (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/acc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/aes.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/afe_dma.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/afec.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/dac_dma.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/efc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/exceptions.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/flashd.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/gmac.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/gmacd.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/hsmci.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/icm.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/isi.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/mcan.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/mediaLB.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/mpu.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/pio.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/pio_capture.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/pio_it.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/pmc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/pwmc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/qspi_dma.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/rstc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/rtc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/rtt.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/sdramc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/spi.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/spi_dma.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/ssc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/supc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/tc.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/trng.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/twi.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/twid.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/uart.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/uart_dma.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/usart.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/usart_dma.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/wdt.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/xdma_hardware_interface.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/xdmac.c (added) * c/src/lib/libbsp/arm/atsam/libraries/libchip/source/xdmad.c (added) * c/src/lib/libbsp/arm/atsam/utils/utility.h (added) bsp/atsam: Import SAM Software Package Import selected files of the ... Wed, 13 Jan 2016 13:07:41 GMT Sebastian Huber [76a51c68] * c/src/lib/libbsp/arm/shared/armv7m/irq/armv7m-irq.c (modified) bsps/arm: Copy vector table only if necessary Tue, 12 Jan 2016 13:44:10 GMT Sebastian Huber [b32a9cd] * c/src/lib/libbsp/arm/lm3s69xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c (deleted) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspreset-armv4.c (moved) * c/src/lib/libbsp/arm/shared/armv7m/startup/bspreset.c (moved) bsps/arm: Use common ARMv7-M bsp_reset() Tue, 12 Jan 2016 13:20:29 GMT Sebastian Huber [2916a33] * c/src/lib/libbsp/arm/shared/CMSIS/Include/arm_common_tables.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/arm_const_structs.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/arm_math.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/cmsis_armcc.h (added) * c/src/lib/libbsp/arm/shared/CMSIS/Include/cmsis_armcc_V6.h (added) * c/src/lib/libbsp/arm/shared/CMSIS/Include/cmsis_gcc.h (added) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm0.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm0plus.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm3.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm4.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cm7.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cmFunc.h (added) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cmInstr.h (added) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_cmSimd.h (added) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_sc000.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/Include/core_sc300.h (moved) * c/src/lib/libbsp/arm/shared/CMSIS/README (added) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/arm_const_structs.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/arm_math.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/core_cm0.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/core_cm3.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/core_cm4.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/core_cmFunc.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/core_cmInstr.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/core_cmSimd.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/core_sc000.h (deleted) * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Include/core_sc300.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Include/arm_common_tables.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Include/core_cm0plus.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Include/core_cm7.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Include/core_cmFunc.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Include/core_cmInstr.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Include/core_cmSimd.h (deleted) bsps/arm: Update CMSIS/Include Remove duplicate and outdated files. Tue, 12 Jan 2016 13:00:16 GMT Sebastian Huber [bbccdb5] * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/Lib/license.txt (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Lib/GCC/libarm_cortexM4lf_math.a (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/Lib/license.txt (deleted) bsps/arm: Delete binary CMSIS/Lib Build the library from source instead. Tue, 12 Jan 2016 12:58:08 GMT Sebastian Huber [dc3813c3] * c/src/lib/libbsp/arm/stm32f4x/hal/CMSIS/RTOS/Template/cmsis_os.h (deleted) * c/src/lib/libbsp/arm/stm32f7x/hal/CMSIS/RTOS/Template/cmsis_os.h (deleted) bsps/arm: Delete template CMSIS/RTOS
