# # ChangeLog for c/src/lib/libbsp/arm in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 09:14:43 Wed, 04 Mar 2015 20:49:08 GMT Joel Sherrill [683ebac] * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) raspberrypi: Do not include default IRQ handler and BSP specific one ... Wed, 04 Mar 2015 20:01:52 GMT Joel Sherrill [a87e8b8d] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram-testsuite.tcfg: Add ftp01 Wed, 04 Mar 2015 20:00:16 GMT Joel Sherrill [8f49dda] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram.tcfg (deleted) lpc1768_mbed_ahb_ram.tcfg: Remove as it is a junk file This file ... Fri, 06 Mar 2015 16:35:40 GMT Joel Sherrill [cc69334f] * c/src/lib/libbsp/arm/lpc32xx/include/nand-mlc.h (modified) * cpukit/libfs/src/dosfs/dosfs.h (modified) * cpukit/libmisc/capture/capture.h (modified) * cpukit/libmisc/capture/captureimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/mainpage.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) Fix a number of minor Doxygen formatting issues Thu, 26 Feb 2015 20:31:27 GMT Martin Galvan [991fdb33] * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/bsp-start-init-registers.S (added) * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION This patch adds ... Fri, 20 Feb 2015 13:08:01 GMT Martin Galvan [dc9aaf7] * c/src/lib/libbsp/arm/shared/start/start.S (modified) ARM: Support VFP-D16 This patch allows the existing FPU code to ... Mon, 16 Feb 2015 10:55:03 GMT Sebastian Huber [c34f94f7] * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspsmp.c (modified) * c/src/lib/libbsp/shared/bspsmp.c (modified) * c/src/lib/libbsp/sparc/leon3/startup/bspsmp.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * testsuites/smptests/smpfatal08/init.c (modified) score: Add _CPU_SMP_Prepare_start_multitasking() Update #2268. Wed, 11 Feb 2015 23:36:34 GMT Joel Sherrill [5640dd5] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ftp01 Wed, 11 Feb 2015 23:34:44 GMT Joel Sherrill [79b45a1] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (modified) lpc1768_mbed-testsuite.tcfg: Add ftp01 Wed, 04 Feb 2015 17:20:27 GMT Pavel Pisa [cf4dfc1] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) arm/tms570: sci context has to be writable because it holds state ... Wed, 14 Jan 2015 22:23:16 GMT Joel Sherrill [b1dcae0] * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f105rc-testsuite.tcfg (modified) stm32f4/.../stm32f105rc-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:59 GMT Joel Sherrill [3d345508] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc24xx/.../lpc23xx_tli800-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:41 GMT Joel Sherrill [b302880e] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc24xx/.../lpc2362-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:26 GMT Joel Sherrill [05eaca8] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s6965-testsuite.tcfg (modified) lm3s69xx/.../lm3s6965-testsuite.tcfg: Add more tests Wed, 14 Jan 2015 22:22:09 GMT Joel Sherrill [c1c45f5] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) lm3s69xx/.../lm3s3749-testsuite.tcfg: Add more tests Fri, 23 Jan 2015 13:49:36 GMT Sebastian Huber [e6a7896f] * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (modified) bsp/altera-cyclone-v: Use proper free function Mon, 15 Dec 2014 12:35:26 GMT Ben Gras [1e587f7d] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libbsp/arm/beagle/irq.c (modified) * c/src/lib/libbsp/shared/console_control.c (modified) * c/src/lib/libbsp/shared/console_read.c (modified) * c/src/lib/libbsp/shared/console_write.c (modified) bsp/beagle: Fix some warnings The extra includes in console_*.c are ... Mon, 15 Dec 2014 06:40:04 GMT Sebastian Huber [3acc619] * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_1 (modified) bsp/lpc32xx: Fix memory map Fixes bug introduced with ... Thu, 04 Dec 2014 09:03:50 GMT Sebastian Huber [12072880] * c/configure.ac (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/csb336/configure.ac (modified) * c/src/lib/libbsp/arm/csb337/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/gba/configure.ac (modified) * c/src/lib/libbsp/arm/gdbarmsim/configure.ac (modified) * c/src/lib/libbsp/arm/gp32/configure.ac (modified) * c/src/lib/libbsp/arm/gumstix/configure.ac (modified) * c/src/lib/libbsp/arm/lm3s69xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc176x/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (modified) * c/src/lib/libbsp/arm/nds/configure.ac (modified) * c/src/lib/libbsp/arm/nds/tools/configure.ac (modified) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/rtl22xx/configure.ac (modified) * c/src/lib/libbsp/arm/smdk2410/configure.ac (modified) * c/src/lib/libbsp/arm/stm32f4/configure.ac (modified) * c/src/lib/libbsp/arm/tms570/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/avr/avrtest/configure.ac (modified) * c/src/lib/libbsp/avr/configure.ac (modified) * c/src/lib/libbsp/bfin/TLL6527M/configure.ac (modified) * c/src/lib/libbsp/bfin/bf537Stamp/configure.ac (modified) * c/src/lib/libbsp/bfin/configure.ac (modified) * c/src/lib/libbsp/bfin/eZKit533/configure.ac (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/lm32/configure.ac (modified) * c/src/lib/libbsp/lm32/lm32_evr/configure.ac (modified) * c/src/lib/libbsp/lm32/milkymist/configure.ac (modified) * c/src/lib/libbsp/m32c/configure.ac (modified) * c/src/lib/libbsp/m32c/m32cbsp/configure.ac (modified) * c/src/lib/libbsp/m32r/configure.ac (modified) * c/src/lib/libbsp/m32r/m32rsim/configure.ac (modified) * c/src/lib/libbsp/m68k/av5282/configure.ac (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/csb360/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/genmcf548x/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf52235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5225x/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5235/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5329/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/m68k/uC5282/configure.ac (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/csb350/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/hurricane/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/malta/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4925/configure.ac (modified) * c/src/lib/libbsp/mips/rbtx4938/configure.ac (modified) * c/src/lib/libbsp/moxie/configure.ac (modified) * c/src/lib/libbsp/moxie/moxiesim/configure.ac (modified) * c/src/lib/libbsp/nios2/configure.ac (modified) * c/src/lib/libbsp/nios2/nios2_iss/configure.ac (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or1k/configure.ac (modified) * c/src/lib/libbsp/or1k/or1ksim/configure.ac (modified) * c/src/lib/libbsp/powerpc/beatnik/configure.ac (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/ep1a/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen5200/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen83xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/haleakala/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc55xxevb/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme3100/configure.ac (modified) * c/src/lib/libbsp/powerpc/mvme5500/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/qemuppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/qoriq/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/ss555/configure.ac (modified) * c/src/lib/libbsp/powerpc/t32mppc/configure.ac (modified) * c/src/lib/libbsp/powerpc/tqm8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex4/configure.ac (modified) * c/src/lib/libbsp/powerpc/virtex5/configure.ac (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/leon2/configure.ac (modified) * c/src/lib/libbsp/sparc/leon3/configure.ac (modified) * c/src/lib/libbsp/sparc64/configure.ac (modified) * c/src/lib/libbsp/sparc64/niagara/configure.ac (modified) * c/src/lib/libbsp/sparc64/usiii/configure.ac (modified) * c/src/lib/libbsp/v850/configure.ac (modified) * c/src/lib/libbsp/v850/gdbv850sim/configure.ac (modified) * c/src/lib/libcpu/arm/configure.ac (modified) * c/src/lib/libcpu/bfin/configure.ac (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/lm32/configure.ac (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/nios2/configure.ac (modified) * c/src/lib/libcpu/or1k/configure.ac (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/lib/libcpu/sparc64/configure.ac (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/configure.ac (modified) * configure.ac (modified) * cpukit/configure.ac (modified) * doc/configure.ac (modified) * doc/tools/configure.ac (modified) * testsuites/configure.ac (modified) * testsuites/fstests/configure.ac (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/psxtmtests/configure.ac (modified) * testsuites/rhealstone/configure.ac (modified) * testsuites/samples/configure.ac (modified) * testsuites/smptests/configure.ac (modified) * testsuites/sptests/configure.ac (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/configure.ac (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/nios2/configure.ac (modified) * tools/cpu/sh/configure.ac (modified) Update bug report URL Thu, 04 Dec 2014 17:21:11 GMT Ben Gras [13d9029] * c/src/lib/libbsp/arm/beagle/clock.c (modified) * c/src/lib/libcpu/arm/shared/include/am335x.h (modified) beagle bsp: disable watchdog on am335x On recent u-boots, the ... Tue, 25 Nov 2014 07:40:20 GMT Sebastian Huber [cbc433c7] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/include/nocache-heap.h (deleted) * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv_devkit (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/mmu-config.c (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c (deleted) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (modified) * c/src/lib/libbsp/arm/csb336/startup/linkcmds (modified) * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb337 (modified) * c/src/lib/libbsp/arm/csb337/startup/linkcmds.csb637 (modified) * c/src/lib/libbsp/arm/edb7312/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gp32/startup/linkcmds (modified) * c/src/lib/libbsp/arm/gumstix/startup/linkcmds (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s3749 (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s6965 (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm3s6965_qemu (modified) * c/src/lib/libbsp/arm/lm3s69xx/startup/linkcmds.lm4f120 (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram (modified) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram_eth (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_ea_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_ea_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_plx800_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc17xx_plx800_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc2362 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc23xx_tli800 (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ea (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_ext (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_int (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_plx800_rom_int (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_1 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_mzx_stage_2 (modified) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_phycore (modified) * c/src/lib/libbsp/arm/nds/startup/linkcmds (modified) * c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/linkcmds (modified) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/arm/smdk2410/startup/linkcmds (modified) * c/src/lib/libbsp/arm/stm32f4/startup/linkcmds.stm32f105rc (modified) * c/src/lib/libbsp/arm/stm32f4/startup/linkcmds.stm32f4 (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.in (modified) bsps/arm: Add .nocache section This section can be use to provide a ... Tue, 25 Nov 2014 07:36:58 GMT Sebastian Huber [42fe0d3] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 avoid infinite loops Wed, 19 Nov 2014 14:30:24 GMT Sebastian Huber [50440c0] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspsmp.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspsmp.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) bsps/arm: Enable L2C for Cortex-A9 MPCore BSPs Wed, 19 Nov 2014 14:07:58 GMT Sebastian Huber [d1eb7b1] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 drop exclusive cache support Optimize locking. Wed, 19 Nov 2014 13:55:53 GMT Sebastian Huber [5f4f828] * c/src/lib/libbsp/arm/shared/include/arm-cache-l1.h (modified) bsps/arm: L1 cache support changes Wed, 19 Nov 2014 13:37:11 GMT Sebastian Huber [e492e7f8] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 compile-time errata 588369 Wed, 19 Nov 2014 13:29:27 GMT Sebastian Huber [52d24b00] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 compile-time errata 753970 Wed, 19 Nov 2014 13:19:13 GMT Sebastian Huber [55741886] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: L2C 310 exclusive config is fatal Wed, 19 Nov 2014 13:08:44 GMT Sebastian Huber [d53de34] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 use l2c_310_* prefix throughout Wed, 19 Nov 2014 13:05:36 GMT Sebastian Huber [861d315] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 use L2C_310_* prefix throughout Wed, 19 Nov 2014 11:24:07 GMT Sebastian Huber [f2fed0c1] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/shared/include/fatal.h (modified) bsps/arm: L2C 310 add compile time checks Simplify initialization. ... Wed, 19 Nov 2014 11:07:04 GMT Sebastian Huber [13f1462f] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 delete invalid link Wed, 19 Nov 2014 11:23:02 GMT Sebastian Huber [a9d6c20] * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) bsps/arm: L2C 310 simplify and remove white space Wed, 19 Nov 2014 10:51:33 GMT Sebastian Huber [957c075] * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (modified) * c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) bsps/arm: L2C 310 rename BSP_ARM_L2CC_BASE Rename BSP_ARM_L2CC_BASE ... Mon, 10 Nov 2014 12:46:32 GMT Sebastian Huber [45a63ee] * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/i2c.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) bsp/xilinx-zynq: Add Cadence I2C bus driver Thu, 13 Nov 2014 09:12:32 GMT Sebastian Huber [bdf8fa76] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (modified) bsp/xilinx-zynq: Add zync_clock_cpu_1x() Thu, 13 Nov 2014 09:15:41 GMT Sebastian Huber [234d5c40] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (modified) bsp/xilinx-zynq: Rename BSP_ARM_A9MPCORE_UARTCLK Rename ... Wed, 12 Nov 2014 13:02:53 GMT Sebastian Huber [8100e71] * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) bsp/xilinx-zynq: Adjust BSP_ARM_A9MPCORE_PERIPHCLK Wed, 12 Nov 2014 12:57:24 GMT Sebastian Huber [f0c564c] * c/src/lib/libbsp/arm/shared/startup/linkcmds.armv4 (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Adjust stacks for ARMv4 Reduce non-IRQ stacks to size ... Wed, 12 Nov 2014 13:00:05 GMT Alan Cudmore [96a9f4c] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.h (added) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) ARM removed shared/abort from several ARM BSPs Wed, 05 Nov 2014 23:52:23 GMT Joel Sherrill [a373dc37] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add dl02 Wed, 05 Nov 2014 23:52:05 GMT Joel Sherrill [091c610] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add dl02 Wed, 05 Nov 2014 23:51:43 GMT Joel Sherrill [0b91cfbf] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add a handful more tests Wed, 05 Nov 2014 21:31:36 GMT Joel Sherrill [f9e4139] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add dl02 Tue, 04 Nov 2014 21:05:08 GMT Joel Sherrill [8d74b80e] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg (modified) lpc23xx_tli800-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 21:04:46 GMT Joel Sherrill [6d84a9f] * c/src/lib/libbsp/arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg (modified) lpc2362-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 21:04:28 GMT Joel Sherrill [a7812cdc] * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg (modified) lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add rbheap01 Tue, 04 Nov 2014 21:02:03 GMT Joel Sherrill [643e7cb8] * c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s3749-testsuite.tcfg (modified) lm3s3749-testsuite.tcfg: Add dl01 Tue, 04 Nov 2014 02:02:03 GMT Chris Johns [de5596b] * c/src/lib/libbsp/arm/beagle/preinstall.am (modified) Regenerated preinstall.am file. Mon, 03 Nov 2014 18:53:40 GMT Ben Gras [53dd6d61] * c/src/lib/libbsp/arm/beagle/Makefile.am (modified) * c/src/lib/libbsp/arm/beagle/README (modified) * c/src/lib/libbsp/arm/beagle/README.JTAG (added) * c/src/lib/libbsp/arm/beagle/TESTING (added) * c/src/lib/libbsp/arm/beagle/clock.c (added) * c/src/lib/libbsp/arm/beagle/clock/beagle-clock-config.c (deleted) * c/src/lib/libbsp/arm/beagle/configure.ac (modified) * c/src/lib/libbsp/arm/beagle/console/console-config.c (modified) * c/src/lib/libbsp/arm/beagle/include/beagle-clock-config.h (deleted) * c/src/lib/libbsp/arm/beagle/include/beagle-timer.h (deleted) * c/src/lib/libbsp/arm/beagle/include/beagle.h (deleted) * c/src/lib/libbsp/arm/beagle/include/boot.h (deleted) * c/src/lib/libbsp/arm/beagle/include/bsp.h (modified) * c/src/lib/libbsp/arm/beagle/include/i2c.h (modified) * c/src/lib/libbsp/arm/beagle/include/irq.h (modified) * c/src/lib/libbsp/arm/beagle/irq.c (added) * c/src/lib/libbsp/arm/beagle/irq/irq.c (deleted) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboardorig.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboardxm.cfg (moved) * c/src/lib/libbsp/arm/beagle/make/custom/beagleboneblack.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beaglebonewhite.cfg (added) * c/src/lib/libbsp/arm/beagle/misc/boot.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (modified) * c/src/lib/libbsp/arm/beagle/misc/restart.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/system-clocks.c (deleted) * c/src/lib/libbsp/arm/beagle/misc/timer.c (deleted) * c/src/lib/libbsp/arm/beagle/preinstall.am (modified) * c/src/lib/libbsp/arm/beagle/rtc/rtc-config.c (deleted) * c/src/lib/libbsp/arm/beagle/simscripts/bbxm.cfg (added) * c/src/lib/libbsp/arm/beagle/simscripts/gdbinit.bbxm (added) * c/src/lib/libbsp/arm/beagle/simscripts/sdcard.sh (added) * c/src/lib/libbsp/arm/beagle/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c (added) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (modified) BSP for several Beagle products Specifically the beagleboard, ... Wed, 22 Aug 2012 12:39:02 GMT Claas Ziemke [7a66986] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (added) * c/src/lib/libbsp/arm/beagle/README (added) * c/src/lib/libbsp/arm/beagle/bsp_specs (added) * c/src/lib/libbsp/arm/beagle/clock/beagle-clock-config.c (added) * c/src/lib/libbsp/arm/beagle/configure.ac (added) * c/src/lib/libbsp/arm/beagle/console/console-config.c (added) * c/src/lib/libbsp/arm/beagle/include/beagle-clock-config.h (added) * c/src/lib/libbsp/arm/beagle/include/beagle-timer.h (added) * c/src/lib/libbsp/arm/beagle/include/beagle.h (added) * c/src/lib/libbsp/arm/beagle/include/boot.h (added) * c/src/lib/libbsp/arm/beagle/include/bsp.h (added) * c/src/lib/libbsp/arm/beagle/include/i2c.h (added) * c/src/lib/libbsp/arm/beagle/include/irq.h (added) * c/src/lib/libbsp/arm/beagle/irq/irq.c (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagle.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagle.inc (added) * c/src/lib/libbsp/arm/beagle/misc/boot.c (added) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (added) * c/src/lib/libbsp/arm/beagle/misc/restart.c (added) * c/src/lib/libbsp/arm/beagle/misc/system-clocks.c (added) * c/src/lib/libbsp/arm/beagle/misc/timer.c (added) * c/src/lib/libbsp/arm/beagle/preinstall.am (added) * c/src/lib/libbsp/arm/beagle/rtc/rtc-config.c (added) * c/src/lib/libbsp/arm/beagle/simscripts/qemu-beagleboard.in (added) * c/src/lib/libbsp/arm/beagle/startup/bspreset.c (added) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (added) * c/src/lib/libbsp/arm/beagle/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (added) Added BeagleBoard BSP Coding done in course of GSoC2012. Commit ... Wed, 29 Oct 2014 16:07:20 GMT Chris Nott [513668f6] * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_adc.h (added) Added missing stm32f4xxxx_adc.h Thu, 23 Oct 2014 08:05:17 GMT Sebastian Huber [46dde0fc] * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/gba/include/bsp.h (modified) * c/src/lib/libbsp/arm/gdbarmsim/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/avr/avrtest/include/bsp.h (modified) * c/src/lib/libbsp/bfin/TLL6527M/include/bsp.h (modified) * c/src/lib/libbsp/bfin/bf537Stamp/include/bsp.h (modified) * c/src/lib/libbsp/bfin/eZKit533/include/bsp.h (modified) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/m32c/m32cbsp/include/bsp.h (modified) * c/src/lib/libbsp/m32r/m32rsim/include/bsp.h (modified) * c/src/lib/libbsp/m68k/av5282/include/bsp.h (modified) * c/src/lib/libbsp/m68k/csb360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/genmcf548x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5206elite/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf52235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5225x/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5235/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mcf5329/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mrm332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (modified) * c/src/lib/libbsp/m68k/uC5282/include/bsp.h (modified) * c/src/lib/libbsp/mips/csb350/include/bsp.h (modified) * c/src/lib/libbsp/mips/genmongoosev/include/bsp.h (modified) * c/src/lib/libbsp/mips/hurricane/include/bsp.h (modified) * c/src/lib/libbsp/mips/jmr3904/include/bsp.h (modified) * c/src/lib/libbsp/mips/malta/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4925/include/bsp.h (modified) * c/src/lib/libbsp/mips/rbtx4938/include/bsp.h (modified) * c/src/lib/libbsp/moxie/moxiesim/include/bsp.h (modified) * c/src/lib/libbsp/nios2/nios2_iss/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/gen5200/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/haleakala/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/qemuppc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ss555/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex4/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/virtex5/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh4/include/bsp.h (modified) * c/src/lib/libbsp/sh/shsim/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon2/include/bsp.h (modified) * c/src/lib/libbsp/sparc/leon3/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/niagara/include/bsp.h (modified) * c/src/lib/libbsp/sparc64/usiii/include/bsp.h (modified) * c/src/lib/libbsp/v850/gdbv850sim/include/bsp.h (modified) bsps: Move extern "C" to not cover includes Some includes may use ... Sat, 18 Oct 2014 08:55:37 GMT Chris Nott [040ed0b4] * c/src/lib/libbsp/arm/stm32f4/Makefile.am (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_exti.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_flash.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_otgfs.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_pwr.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_rcc.h (modified) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_syscfg.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4xxxx_tim.h (added) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (modified) * c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c (modified) bsp/stm32f4: Add header files Added register definition headers for ... Mon, 20 Oct 2014 20:25:22 GMT Joel Sherrill [ddc8165] * c/src/lib/libbsp/arm/raspberrypi/console/usart.c (modified) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (modified) arm/raspberrypi: Fix warnings Mon, 20 Oct 2014 14:15:32 GMT Joel Sherrill [770e379] * c/src/lib/libbsp/arm/csb337/console/fbcons.c (modified) arm/csb337/console/fbcons.c: Fix warning Mon, 20 Oct 2014 14:12:46 GMT Joel Sherrill [5bdda7f] * c/src/lib/libbsp/arm/gba/console/conio.c (modified) arm/gba/console/conio.c: Fix warning Mon, 20 Oct 2014 14:11:41 GMT Joel Sherrill [0f8ee10e] * c/src/lib/libbsp/arm/edb7312/include/bsp.h (modified) * c/src/lib/libbsp/arm/edb7312/irq/bsp_irq_asm.S (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) arm/edb7312: Fix warnings Wed, 15 Oct 2014 23:35:51 GMT Joel Sherrill [425fe40d] * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (modified) arm/lpc176x/misc/restart.c: Fix set but not used warning Tue, 14 Oct 2014 16:20:35 GMT Joel Sherrill [694debe] * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) arm/rtl22xx/startup/bspstart.c: Ensure bsp_start_default() is static Tue, 14 Oct 2014 16:20:35 GMT Joel Sherrill [b3bb88be] * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) arm/gumstix/startup/bspstart.c: Ensure bsp_start_default() is static Tue, 14 Oct 2014 16:20:35 GMT Joel Sherrill [c696430] * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) arm/gp32/startup/bspstart.c: Ensure bsp_start_default() is static Tue, 14 Oct 2014 16:20:35 GMT Joel Sherrill [7c44572] * c/src/lib/libbsp/arm/gba/startup/bspstart.c (modified) arm/gba/startup/bspstart.c: Ensure bsp_start_default() is static Tue, 14 Oct 2014 16:20:35 GMT Joel Sherrill [61fde4a] * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) arm/edb7312/startup/bspstart.c: Ensure bsp_start_default() is static Tue, 14 Oct 2014 16:20:35 GMT Joel Sherrill [c6120ac2] * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) arm/csb337/startup/bspstart.c: Ensure bsp_start_default() is static Tue, 14 Oct 2014 21:50:54 GMT Joel Sherrill [23c3b3b2] * c/src/lib/libbsp/arm/rtl22xx/console/uart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) c/src/lib/libbsp/arm/rtl22xx/console/uart.c Tue, 14 Oct 2014 21:50:45 GMT Joel Sherrill [fc137e7d] * c/src/lib/libbsp/arm/csb337/console/sed1356.c (modified) * c/src/lib/libbsp/arm/csb337/startup/bspreset.c (modified) arm/csb337: Fix warnings Tue, 14 Oct 2014 20:17:19 GMT Joel Sherrill [494d2f1f] * c/src/lib/libbsp/arm/gumstix/Makefile.am (modified) * c/src/lib/libcpu/arm/Makefile.am (modified) * c/src/lib/libcpu/arm/pxa255/pmc/pmc.c (deleted) Remove unused pxa255/pmc, update csb337 and gumstix BSPs Mon, 13 Oct 2014 19:10:11 GMT Joel Sherrill [d6236971] * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) gp32/startup/bspstart.c: Fix warnings Mon, 13 Oct 2014 19:09:51 GMT Joel Sherrill [c144c09] * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) csb336/startup/bspstart.c: Fix warnings Mon, 13 Oct 2014 18:20:35 GMT Joel Sherrill [3c743901] * c/src/lib/libbsp/arm/gp32/smc/smc.c (modified) arm/gp32/smc/smc.c: Remove unused sm_ECCEncode() and sm_status() Mon, 13 Oct 2014 18:18:55 GMT Joel Sherrill [57e8a0d] * c/src/lib/libbsp/arm/gp32/smc/smc.c (modified) arm/gp32/smc/smc.c: Fix warnings and clean up Mon, 13 Oct 2014 13:19:12 GMT Sebastian Huber [116ef2e9] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl011.c (modified) * c/src/lib/libbsp/arm/shared/arm-pl050.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl011.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-pl050.h (modified) bsps/arm: Convert PL011 and PL050 console drivers Use Termios ... Sun, 12 Oct 2014 20:22:27 GMT Joel Sherrill [ff8922c] * c/src/lib/libbsp/arm/gba/console/conio.c (modified) * c/src/lib/libbsp/arm/gba/console/console.c (modified) arm/gba/console: Fix warnings and clean up Sat, 11 Oct 2014 23:46:13 GMT Joel Sherrill [d3c8245f] * c/src/lib/libbsp/arm/smdk2410/startup/bspreset.c (modified) arm/smdk2410/startup/bspreset.c: Include Sat, 11 Oct 2014 23:46:04 GMT Joel Sherrill [b184c41] * c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c (modified) arm/rtl22xx/startup/bspreset.c: Include Sat, 11 Oct 2014 23:45:57 GMT Joel Sherrill [22ed84bc] * c/src/lib/libbsp/arm/gumstix/startup/bspreset.c (modified) arm/gumstix/startup/bspreset.c: Include Sat, 11 Oct 2014 23:45:47 GMT Joel Sherrill [10eac0e] * c/src/lib/libbsp/arm/gp32/startup/bspreset.c (modified) arm/gp32/startup/bspreset.c: Include Sat, 11 Oct 2014 23:45:39 GMT Joel Sherrill [47240f2] * c/src/lib/libbsp/arm/gba/startup/bspreset.c (modified) arm/gba/startup/bspreset.c: Include Sat, 11 Oct 2014 23:45:32 GMT Joel Sherrill [c0662b6] * c/src/lib/libbsp/arm/edb7312/startup/bspreset.c (modified) arm/edb7312/startup/bspreset.c: Include Sat, 11 Oct 2014 23:44:50 GMT Joel Sherrill [7748d8d] * c/src/lib/libbsp/arm/csb337/startup/bspreset.c (modified) arm/csb337/startup/bspreset.c: Include Mon, 13 Oct 2014 14:11:02 GMT Sebastian Huber [2faaf4b] * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) bsps/arm: Move abort stack Move abort stack above the other ... Thu, 09 Oct 2014 20:35:10 GMT Joel Sherrill [ef4c461] * c/src/lib/libbsp/arm/nds/Makefile.am (modified) * c/src/lib/libbsp/arm/nds/block/block.c (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) * c/src/lib/libbsp/arm/nds/coproc/coproc.c (modified) * c/src/lib/libbsp/arm/nds/include/bsp.h (modified) * c/src/lib/libbsp/arm/nds/irq/irq.c (modified) * c/src/lib/libbsp/arm/nds/irq/irq.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/initSystem.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/video.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (modified) * c/src/lib/libbsp/arm/nds/preinstall.am (modified) * c/src/lib/libbsp/arm/nds/rtc/rtc.c (modified) * c/src/lib/libbsp/arm/nds/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/parser.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/reco.c (modified) * c/src/libchip/serial/ns16550.c (modified) arm/nds: Warning clean up This patch eliminates most of the ... Thu, 09 Oct 2014 17:55:52 GMT Joel Sherrill [ab31e8e1] * c/src/lib/libbsp/arm/gumstix/include/bsp.h (modified) gumstix/include/bsp.h: Do not include libchip/serial to avoid ... Thu, 09 Oct 2014 15:46:43 GMT Joel Sherrill [bc77bda] * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) csb337/include/bsp.h: Do not include libchip/serial to avoid ... Wed, 08 Oct 2014 21:04:56 GMT Joel Sherrill [6279149] * c/src/lib/libbsp/arm/gdbarmsim/Makefile.am (modified) * c/src/lib/libbsp/arm/gdbarmsim/console/console-io.c (modified) * c/src/lib/libbsp/arm/gdbarmsim/preinstall.am (modified) * c/src/lib/libbsp/avr/avrtest/Makefile.am (modified) * c/src/lib/libbsp/avr/avrtest/console/console-io.c (modified) * c/src/lib/libbsp/avr/avrtest/preinstall.am (modified) * c/src/lib/libbsp/h8300/h8sim/Makefile.am (modified) * c/src/lib/libbsp/h8300/h8sim/console/console-io.c (modified) * c/src/lib/libbsp/h8300/h8sim/preinstall.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/Makefile.am (modified) * c/src/lib/libbsp/m32c/m32cbsp/console/console-io.c (modified) * c/src/lib/libbsp/m32c/m32cbsp/preinstall.am (modified) * c/src/lib/libbsp/m32r/m32rsim/Makefile.am (modified) * c/src/lib/libbsp/m32r/m32rsim/console/console-io.c (modified) * c/src/lib/libbsp/m32r/m32rsim/preinstall.am (modified) * c/src/lib/libbsp/m68k/csb360/Makefile.am (modified) * c/src/lib/libbsp/m68k/csb360/console/console-io.c (modified) * c/src/lib/libbsp/m68k/csb360/preinstall.am (modified) * c/src/lib/libbsp/mips/csb350/Makefile.am (modified) * c/src/lib/libbsp/mips/csb350/console/console-io.c (modified) * c/src/lib/libbsp/mips/csb350/preinstall.am (modified) * c/src/lib/libbsp/mips/jmr3904/Makefile.am (modified) * c/src/lib/libbsp/mips/jmr3904/console/console-io.c (modified) * c/src/lib/libbsp/mips/jmr3904/preinstall.am (modified) * c/src/lib/libbsp/moxie/moxiesim/Makefile.am (modified) * c/src/lib/libbsp/moxie/moxiesim/console/console-io.c (modified) * c/src/lib/libbsp/moxie/moxiesim/preinstall.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/Makefile.am (modified) * c/src/lib/libbsp/nios2/nios2_iss/console/console.c (modified) * c/src/lib/libbsp/nios2/nios2_iss/preinstall.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/console-io.c (modified) * c/src/lib/libbsp/powerpc/psim/preinstall.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qemuppc/console/console-io.c (modified) * c/src/lib/libbsp/powerpc/qemuppc/preinstall.am (modified) * c/src/lib/libbsp/sh/shsim/Makefile.am (modified) * c/src/lib/libbsp/sh/shsim/console/console-io.c (modified) * c/src/lib/libbsp/sh/shsim/preinstall.am (modified) * c/src/lib/libbsp/shared/console-polled.c (modified) * c/src/lib/libbsp/shared/include/console-polled.h (added) * c/src/lib/libbsp/v850/gdbv850sim/Makefile.am (modified) * c/src/lib/libbsp/v850/gdbv850sim/console/console-io.c (modified) * c/src/lib/libbsp/v850/gdbv850sim/preinstall.am (modified) Add console-polled.h and update all BSPs that should use it. The ... Fri, 10 Oct 2014 09:54:55 GMT Sebastian Huber [037b57a] * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Fix warning Fri, 10 Oct 2014 08:39:09 GMT Sebastian Huber [8a3e8c1] * c/src/lib/libbsp/arm/stm32f4/i2c/i2c.c (modified) bsp/stm32f4: Fix warning Fri, 10 Oct 2014 08:26:40 GMT Sebastian Huber [9e34ce0] * c/src/lib/libbsp/arm/lpc32xx/misc/nand-mlc.c (modified) bsp/lpc32xx: Fix warning Fri, 10 Oct 2014 08:26:22 GMT Sebastian Huber [a845b83] * c/src/lib/libbsp/arm/lpc24xx/misc/restart.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c (modified) bsp/lpc24xx: Fix warnings Tue, 07 Oct 2014 22:21:35 GMT Joel Sherrill [d37ec8d8] * c/src/lib/libbsp/arm/gba/startup/bspgetworkarea.c (modified) arm/gba/startup/bspgetworkarea.c: Fix warning Tue, 07 Oct 2014 22:20:43 GMT Joel Sherrill [ba1d939] * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) arm/shared/abort/abort.c: Fix warnings and clean up Tue, 07 Oct 2014 22:20:14 GMT Joel Sherrill [8aec7f5] * c/src/lib/libbsp/arm/lpc24xx/misc/system-clocks.c (modified) arm/lpc24xx/misc/system-clocks.c: Fix warning Tue, 07 Oct 2014 22:19:44 GMT Joel Sherrill [d52494e] * c/src/lib/libbsp/arm/lm3s69xx/startup/bspstart.c (modified) arm/lm3s69xx/startup/bspstart.c: Add include of to ... Tue, 07 Oct 2014 22:19:19 GMT Joel Sherrill [bcc6c70] * c/src/lib/libbsp/arm/gdbarmsim/irq/irq.c (modified) arm/gdbarmsim/irq/irq.c: Fix warnings Tue, 07 Oct 2014 22:18:57 GMT Joel Sherrill [1a829d3] * c/src/lib/libbsp/arm/gdbarmsim/include/irq.h (modified) arm/gdbarmsim/include/irq.h: Fix spacing Tue, 07 Oct 2014 22:18:02 GMT Joel Sherrill [237b3464] * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) arm/gba/irq/irq.c: Fix warnings and clean up Tue, 07 Oct 2014 22:17:38 GMT Joel Sherrill [27144f44] * c/src/lib/libbsp/arm/gba/clock/clockdrv.c (modified) arm/gba/clock/clockdrv.c: Fix warnings and clean up Tue, 07 Oct 2014 06:29:16 GMT Sebastian Huber [6ec438e] * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-1.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-2.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/uart-probe-3.c (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc32xx/console/hsu.c (modified) * c/src/lib/libbsp/arm/lpc32xx/include/hsu.h (added) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/Makefile.am (modified) * c/src/lib/libbsp/powerpc/gen83xx/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/gen83xx/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/qoriq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/qoriq/console/console-config.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-master.c (modified) * c/src/lib/libbsp/powerpc/qoriq/console/uart-bridge-slave.c (modified) * c/src/lib/libbsp/powerpc/qoriq/include/uart-bridge.h (modified) * c/src/lib/libbsp/powerpc/qoriq/startup/bspstart.c (modified) * c/src/libchip/Makefile.am (modified) * c/src/libchip/serial/ns16550-context.c (added) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.h (modified) * c/src/libchip/serial/ns16550_p.h (modified) libchip/serial: Add alternative NS16550 driver Use the Termios ... Tue, 07 Oct 2014 14:28:04 GMT Sebastian Huber [7fd5e89] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * doc/bsp_howto/console.t (modified) * testsuites/libtests/termios01/init.c (modified) termios: Partially hide rtems_termios_tty Move interrupt lock to ...
