# # ChangeLog for c/src/lib/libbsp/arm/tms570/include in rtems # # Generated by Trac 1.2.1.dev0 # 03/28/24 08:17:01 Mon, 27 Mar 2017 10:09:21 GMT Sebastian Huber [de9f326] * c/src/lib/libbsp/arm/tms570/include/bsp.h (modified) bsp/tms570: Simplify Mon, 27 Mar 2017 10:08:19 GMT Sebastian Huber [b7262b2] * c/src/lib/libbsp/arm/tms570/include/bsp.h (modified) bsp/tms570: Remove OPERATION_COUNT define This is the wrong place ... Thu, 09 Mar 2017 12:23:54 GMT Sebastian Huber [5ca634e9] * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) bsp/tms570: Support printk() early Allow use of printk() early in ... Mon, 12 Sep 2016 08:46:58 GMT Pavel Pisa [5746f10] * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) arm/tms570: define base addresses of all TMS570LS3137 SPI interfaces. ... Mon, 20 Jun 2016 16:55:49 GMT Pavel Pisa [6626efe6] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c (modified) bsp/tms570: update pinmux to provide support for initialization lists ... Mon, 20 Jun 2016 16:56:49 GMT Pavel Pisa [bc884f6] * c/src/lib/libbsp/arm/tms570/include/tms570-pins.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570ls3137zwt-pins.h (added) bsp/tms570: include package balls and PINMMR registers mapping for ... Tue, 29 Mar 2016 18:10:50 GMT Joel Sherrill [e56090ef] * c/src/lib/libbsp/arm/tms570/include/bsp.h (modified) arm/tms570: Remove include of from and fix ... Fri, 25 Mar 2016 15:45:02 GMT Joel Sherrill [7dde6b48] * c/src/lib/libbsp/arm/tms570/include/bsp.h (modified) arm/tms570/include/bsp.h: Do not include Wed, 18 Nov 2015 17:45:32 GMT Premysl Houdek [3e1196d] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h (modified) * c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c (modified) bsp/tms570: unite code duplication in pinmux and clean SCI close per ... Thu, 12 Nov 2015 22:11:31 GMT Pavel Pisa [870ff8e9] * c/src/lib/libbsp/arm/tms570/include/tms570-pom.h (modified) * c/src/lib/libbsp/arm/tms570/irq/irq.c (modified) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (modified) * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (modified) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (modified) bsp/tms570: use POM only when application image does not start at ... Thu, 12 Nov 2015 22:11:28 GMT Premysl Houdek [e5d5767e] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h (added) * c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c (added) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) bsp/tms570: Pinmux support and EMAC pin definition added ... Thu, 12 Nov 2015 22:11:27 GMT Premysl Houdek [6302c61] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/irq.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h (deleted) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacc.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) bsp/tms570: EMAC control header file corrected and EMAC interrupt ... Fri, 17 Jul 2015 15:04:05 GMT Premysl Houdek [d6c67ad5] * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_adc.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_ccmsr.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_crc.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dcan.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dcc.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dma.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dmm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_efuse.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emif.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_esm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_flash.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_flex_ray.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_gio.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_htu.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_i2c.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_iomm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_lin.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_mdio.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_n2het.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pbist.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pcr.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pll.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pmm.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pom.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_rti.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_rtp.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sci.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_spi.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_stc.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sys.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sys2.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_tcr.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_tcram.h (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_vim.h (modified) bsp/tms570: skipped 32bit field definitions and corrected single bit ... Thu, 16 Jul 2015 12:14:32 GMT Premysl Houdek [069560a] * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pom.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-rti.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-vim.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (modified) bsp/tms570: source changes reflecting new headers. Signed-off-by: ... Thu, 16 Jul 2015 14:26:09 GMT Premysl Houdek [bea49c9] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_adc.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_ccmsr.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_crc.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dcan.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dcc.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dma.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_dmm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_efuse.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emac.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emacm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_emif.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_esm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_flash.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_flex_ray.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_gio.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_htu.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_i2c.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_iomm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_lin.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_mdio.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_n2het.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pbist.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pcr.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pll.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pmm.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_pom.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_rti.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_rtp.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sci.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_spi.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_stc.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sys.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_sys2.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_tcr.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_tcram.h (added) * c/src/lib/libbsp/arm/tms570/include/ti_herc/reg_vim.h (added) bsp/tms570: New/generated header files for TMS570 SoC peripherals ... Thu, 26 Mar 2015 20:16:38 GMT Martin Galvan [ec8f3cb] * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (modified) TMS570: Add board reset code to bsp_reset Wed, 04 Feb 2015 17:20:27 GMT Pavel Pisa [cf4dfc1] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) arm/tms570: sci context has to be writable because it holds state ... Tue, 07 Oct 2014 14:28:04 GMT Sebastian Huber [7fd5e89] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * doc/bsp_howto/console.t (modified) * testsuites/libtests/termios01/init.c (modified) termios: Partially hide rtems_termios_tty Move interrupt lock to ... Thu, 21 Aug 2014 13:38:24 GMT Pavel Pisa [46265063] * c/src/lib/libbsp/arm/tms570/Makefile.am (modified) * c/src/lib/libbsp/arm/tms570/clock/benchmark_timer.c (added) * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/arm/tms570/include/system-clocks.h (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg (modified) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg (modified) * c/src/lib/libbsp/arm/tms570/misc/cpucounterread.c (added) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) bsp/tms570: implemented support functions to satisfy complete tests ... Wed, 20 Aug 2014 15:24:23 GMT Premysl Houdek [4407ee6] * c/src/lib/libbsp/arm/tms570/Makefile.am (added) * c/src/lib/libbsp/arm/tms570/README (added) * c/src/lib/libbsp/arm/tms570/bsp_specs (added) * c/src/lib/libbsp/arm/tms570/clock/clock.c (added) * c/src/lib/libbsp/arm/tms570/configure.ac (added) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (added) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (added) * c/src/lib/libbsp/arm/tms570/include/bsp.h (added) * c/src/lib/libbsp/arm/tms570/include/irq.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-pom.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-rti.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-sci.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-vim.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570.h (added) * c/src/lib/libbsp/arm/tms570/irq/irq.c (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg (added) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (added) * c/src/lib/libbsp/arm/tms570/preinstall.am (added) * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (added) * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (added) * c/src/lib/libbsp/arm/tms570/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (added) BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137) ...
