# # ChangeLog for c/src/lib/libbsp/arm/tms570/console in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 15:43:29 Fri, 16 Sep 2016 10:58:06 GMT Sebastian Huber [55e0be36] * c/src/lib/libbsp/arm/atsam/console/console.c (modified) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/powerpc/t32mppc/console/console.c (modified) * c/src/lib/libbsp/shared/console-termios-init.c (modified) * c/src/lib/libbsp/shared/console-termios.c (modified) * c/src/lib/libbsp/shared/include/console-termios.h (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * testsuites/libtests/termios01/init.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) termios: Use IMFS nodes for new Termios devices This makes the new ... Fri, 22 Jul 2016 19:15:55 GMT Pavel Pisa [0055b65] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) bsp/tms570: ensure that change of SCI baudrate is not applied in the ... Mon, 07 Dec 2015 15:59:35 GMT Pavel Pisa [8df196f7] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) bsp/tms570: include complete peripheral initialization to SCI driver. ... Wed, 18 Nov 2015 17:45:32 GMT Premysl Houdek [3e1196d] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pinmux.h (modified) * c/src/lib/libbsp/arm/tms570/pinmux/pinmux.c (modified) bsp/tms570: unite code duplication in pinmux and clean SCI close per ... Thu, 12 Nov 2015 22:11:29 GMT Premysl Houdek [7e18dd9] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) bsp/tms570: fixed sci driver freeze when closing terminal bug ... Fri, 17 Jul 2015 15:04:06 GMT Premysl Houdek [b2c252b] * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (modified) bsp/tms570 Use bitfields instead of hard-coded values ... Thu, 16 Jul 2015 12:14:32 GMT Premysl Houdek [069560a] * c/src/lib/libbsp/arm/tms570/clock/clock.c (modified) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (modified) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/system-clocks.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-pom.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-rti.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-vim.h (modified) * c/src/lib/libbsp/arm/tms570/include/tms570.h (modified) * c/src/lib/libbsp/arm/tms570/preinstall.am (modified) * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (modified) bsp/tms570: source changes reflecting new headers. Signed-off-by: ... Wed, 04 Feb 2015 17:20:27 GMT Pavel Pisa [cf4dfc1] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) arm/tms570: sci context has to be writable because it holds state ... Tue, 07 Oct 2014 14:28:04 GMT Sebastian Huber [7fd5e89] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * c/src/lib/libbsp/sparc/shared/include/apbuart_termios.h (modified) * c/src/lib/libbsp/sparc/shared/uart/apbuart_termios.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termios_setbestbaud.c (modified) * cpukit/libnetworking/net/if_ppp.c (modified) * cpukit/libnetworking/net/ppp_tty.c (modified) * doc/bsp_howto/console.t (modified) * testsuites/libtests/termios01/init.c (modified) termios: Partially hide rtems_termios_tty Move interrupt lock to ... Tue, 07 Oct 2014 14:27:51 GMT Sebastian Huber [a830cb8] * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (modified) * c/src/lib/libbsp/sparc/leon3/console/console.c (modified) * cpukit/libcsupport/include/rtems/termiostypes.h (modified) * cpukit/libcsupport/src/termios.c (modified) * doc/bsp_howto/console.t (modified) * testsuites/libtests/termios01/init.c (modified) termios: Separate flow control from normal handler Wed, 20 Aug 2014 15:24:23 GMT Premysl Houdek [4407ee6] * c/src/lib/libbsp/arm/tms570/Makefile.am (added) * c/src/lib/libbsp/arm/tms570/README (added) * c/src/lib/libbsp/arm/tms570/bsp_specs (added) * c/src/lib/libbsp/arm/tms570/clock/clock.c (added) * c/src/lib/libbsp/arm/tms570/configure.ac (added) * c/src/lib/libbsp/arm/tms570/console/printk-support.c (added) * c/src/lib/libbsp/arm/tms570/console/tms570-sci.c (added) * c/src/lib/libbsp/arm/tms570/include/bsp.h (added) * c/src/lib/libbsp/arm/tms570/include/irq.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-pom.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-rti.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-sci-driver.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-sci.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570-vim.h (added) * c/src/lib/libbsp/arm/tms570/include/tms570.h (added) * c/src/lib/libbsp/arm/tms570/irq/irq.c (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk-testsuite.tcfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk.cfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_intram.cfg (added) * c/src/lib/libbsp/arm/tms570/make/custom/tms570ls3137_hdk_sdram.cfg (added) * c/src/lib/libbsp/arm/tms570/pom/tms570-pom.c (added) * c/src/lib/libbsp/arm/tms570/preinstall.am (added) * c/src/lib/libbsp/arm/tms570/startup/bspreset.c (added) * c/src/lib/libbsp/arm/tms570/startup/bspstart.c (added) * c/src/lib/libbsp/arm/tms570/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_intram (added) * c/src/lib/libbsp/arm/tms570/startup/linkcmds.tms570ls3137_hdk_sdram (added) BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137) ...
