@c8312b3
06/23/13 12:39:47 |
Sebastian Huber |
bsps/arm: Add PL111 support
4.115
@ca59217
06/28/13 07:03:11 |
Sebastian Huber |
bsps/arm: Set vector base on all processors
4.115
@a3a4cd5
06/26/13 07:40:44 |
Sebastian Huber |
bsps/arm: Move input sections
Move input sections to preserve order …
4.115
@4b83e8f1
06/21/13 07:59:27 |
Sebastian Huber |
bsps/arm: Fix set exception handler for ARMv7
4.115
@e18db9f
06/24/13 15:29:11 |
Sebastian Huber |
termios: Update due to API changes
Termios notifies now the driver …
4.115
@1df348b
06/24/13 09:00:36 |
Sebastian Huber |
bsps/arm: Rename function
Rename …
4.115
@cddb8f4
06/20/13 07:48:27 |
Ric Claus |
bsps/arm: Fix some GIC functions
4.115
@9a037da9
06/19/13 09:20:06 |
Sebastian Huber |
bsps/arm: Set vector base address if necessary
4.115
@db42c079
05/31/13 11:59:47 |
Sebastian Huber |
bsps/arm: Add SMP support
4.115
@0d671d70
05/27/13 10:43:53 |
Sebastian Huber |
bsps/arm: Move .fast_text section
Move the .fast_text section after …
4.115
@cab410f
05/21/13 12:19:24 |
Sebastian Huber |
bsps: Update due to linker changes
In case the VMA and LMA regions …
4.115
@cfd8d7a
05/08/13 07:30:31 |
Sebastian Huber |
arm: Support VFP-D32 and Neon
4.115
@12d182c4
05/06/13 12:01:10 |
Sebastian Huber |
bsps/arm: Fix register usage
4.115
@e37d57bc
05/06/13 08:59:07 |
Sebastian Huber |
bsps/arm: Add shared GIC tmtests/tm27 support
4.115
@33c98fd
05/06/13 08:20:26 |
Sebastian Huber |
bsps/arm: Remove superfluous parameter
4.115
@a91dc98b
04/26/13 13:06:32 |
Sebastian Huber |
bsp/realview-pbx-a9: New BSP
4.115
@9ce65803
05/02/13 11:37:30 |
Sebastian Huber |
bsps/arm: Copy vector table only if necessary
4.115
@27690ec3
05/02/13 11:36:03 |
Sebastian Huber |
bsps/arm: Move .vector section
The .vector section contains …
4.115
@ecf7dd9
05/02/13 09:41:22 |
Sebastian Huber |
bsps/arm: Move CP15 start initialization
4.115
@88cf23f8
04/30/13 13:23:45 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_exception_handler()
4.115
@037e8ae5
05/02/13 15:42:20 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_trans*_table_entries()
4.115
@962e0fac
05/02/13 09:18:09 |
Sebastian Huber |
bsps/arm: Add and use bsp_translation_table_base
4.115
@fb0584f
05/03/13 08:39:26 |
Sebastian Huber |
bsps/arm: Move implementation to inline functions
4.115
@8ac62c4
03/26/13 15:01:10 |
Sebastian Huber |
bsps/arm: Add thread-local storage (TLS) sections
4.115
@df6818f9
03/18/13 14:24:00 |
Sebastian Huber |
bsps: Support DWARF extension
4.115
@f12ef239
01/09/13 15:25:37 |
Sebastian Huber |
bsps/arm: Fix LPC Ethernet driver initialization
4.115
@04f399d
01/07/13 09:19:23 |
Sebastian Huber |
arm: Add and use _ARMV7M_Exception_default()
4.115
@13cf952
01/04/13 14:47:34 |
Sebastian Huber |
arm: Add and use default exception handler
Add and use …
4.115
@4592658
12/18/12 08:24:56 |
Sebastian Huber |
bsps/arm: Move promiscuous mode setting
4.115
@3f58ac7
12/17/12 14:41:53 |
Sebastian Huber |
bsps/arm: Add PHY up/down
All PHYs will be set to power up/down state …
4.115
@50233d37
12/17/12 10:12:20 |
Sebastian Huber |
bsps/arm: Add PHY timeout detection
4.115
@2cd48da
12/14/12 12:08:10 |
Sebastian Huber |
bsps/arm: Add interface down support
4.115
@e99893f9
12/14/12 11:17:15 |
Sebastian Huber |
bsps/arm: Prepare for interface down support
4.115
@573822b
12/14/12 11:07:28 |
Sebastian Huber |
bsps/arm: Use assert() instead of status macros
4.115
@5970dcc9
12/14/12 09:28:18 |
Sebastian Huber |
bsps/arm: Remove superfluous attributes
4.115
@e5a7f846
12/14/12 08:40:44 |
Sebastian Huber |
bsps/arm: Avoid mbuf migration in LPC ethernet
The receive task will …
4.115
@26e90fb1
10/30/12 16:42:17 |
Sebastian Huber |
libnetworking: Use system events
Add reserved system events …
4.115
@7f5ab84e
09/28/12 11:48:32 |
Sebastian Huber |
bsps/arm: Fix rtems_mii_ioctl() usage
4.115
@afd1967
09/24/12 10:51:47 |
Sebastian Huber |
bsps/arm: Add LPC_DMA_CHANNEL_COUNT
4.115
@7329f55
06/06/12 12:48:23 |
Sebastian Huber |
bsps/arm: Rename linkcmds.armv7 to linkcmds.armv7m
4.115
@fd153c73
06/12/12 13:27:17 |
Sebastian Huber |
bsps: Replace NIRVANA region
Replace the "NIRVANA" region with the …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@d2c665b7
04/20/12 13:29:00 |
Sebastian Huber |
bsps/arm: Make the Clock_isr() static again
4.115
@64c44c1
04/20/12 07:20:17 |
Sebastian Huber |
bsps/arm: Remove superfluous include
4.115
@b2d9478
04/19/12 18:15:17 |
Joel Sherrill |
lpc shared: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@556ac5a
04/19/12 18:15:03 |
Joel Sherrill |
armv7m shared: Clock driver clean up and ISR Handler Prototype Correction.
4.115
@d8f05c83
03/26/12 16:41:45 |
Sebastian Huber |
bsps/arm: Add BSP_ARMV7M_SYSTICK_PRIORITY
4.115
@5ea637ed
03/26/12 16:40:31 |
Sebastian Huber |
bsps/arm: Add BSP_ARMV7M_IRQ_PRIORITY_DEFAULT
4.115
@1aebb70
04/07/12 17:07:04 |
Sebastian Huber |
bsps: Update due to API changes
4.115
@bd0fb473
03/24/12 21:53:07 |
Sebastian Huber |
bsps: Shared ARMv7-M interrupt support
4.115
@34c61517
03/24/12 19:14:27 |
Sebastian Huber |
bsps: Shared ARMv7-M clock driver
4.115
@4c622e5
11/08/11 10:18:19 |
Sebastian Huber |
2011-11-08 Sebastian Huber <sebastian.huber@…>
4.115
@f6083f0
05/19/11 12:09:04 |
Sebastian Huber |
2011-05-19 Sebastian Huber <sebastian.huber@…>
4.115
@c4d9f313
03/28/11 12:27:29 |
Sebastian Huber |
2011-03-29 Sebastian Huber <sebastian.huber@…>
4.115
@305234f7
03/28/11 08:49:58 |
Sebastian Huber |
4.115
@2ee9d3d
02/11/11 11:49:52 |
Ralf Corsepius |
2011-02-11 Ralf Corsépius <ralf.corsepius@…>
4.115
@15ca4e7
01/28/11 20:29:35 |
Joel Sherrill |
2011-01-28 Joel Sherrill <joel.sherrilL@…>
4.115
@432a6388
01/26/11 12:21:26 |
Sebastian Huber |
2011-01-26 Sebastian Huber <sebastian.huber@…>
4.115
@6d4d934
12/16/10 13:35:26 |
Sebastian Huber |
2010-12-16 Sebastian Huber <sebastian.huber@…>
4.115
@e792ecf
12/03/10 10:09:59 |
Sebastian Huber |
2010-12-03 Sebastian Huber <sebastian.huber@…>
4.115
@a3579d3b
12/03/10 09:23:52 |
Sebastian Huber |
4.115
@9c2da80f
11/23/10 16:01:09 |
Sebastian Huber |
2010-11-23 Gedare Bloom <giddyup44@…>
PR 1719/cpukit
4.115
@b0cb645
06/23/10 08:04:00 |
Sebastian Huber |
2010-06-21 Sebastian Huber <sebastian.huber@…>
4.115
@c5d8d2dc
06/21/10 12:28:36 |
Sebastian Huber |
4.115
@c3dd440
05/20/10 14:33:16 |
Sebastian Huber |
2010-05-20 Sebastian Huber <sebastian.huber@…>
4.104.115
@439d00ca
04/30/10 13:21:08 |
Sebastian Huber |
2010-04-30 Sebastian Huber <sebastian.huber@…>
4.104.115
@c193baad
04/09/10 20:24:57 |
Thomas.Doerfler |
unify irq data types and code, merge s3c2400/s3c2410 support
4.104.115
@7a6f8d0
04/09/10 12:22:57 |
Thomas.Doerfler |
added dma header
added thumb support to start.S
updated documentation
4.104.115
@39c8fdb
01/12/10 15:03:22 |
Thomas.Doerfler |
add support for lpc32xx
4.104.115
@c468f18b
12/15/09 15:20:47 |
Thomas.Doerfler |
add support for LPC32xx
4.104.115
@6f01945
12/07/09 16:24:17 |
Ralf Corsepius |
2009-12-07 Ralf Corsépius <ralf.corsepiu@…>
4.104.115
@32b8506
11/29/09 14:53:02 |
Ralf Corsepius |
Whitespace removal.
4.104.115
@82d7e92d
09/30/09 03:27:18 |
Ralf Corsepius |
2009-09-30 Ralf Corsépius <ralf.corsepius@…>
4.104.115
@091705c
09/18/09 08:06:32 |
Thomas.Doerfler |
Removed symbols and renamed sections.
Added bsp_start_memcpy(). …
4.104.115
@72f6cb06
07/17/09 15:10:27 |
Thomas.Doerfler |
remove obsolete files
4.104.115
@7ae2775
07/17/09 13:53:04 |
Thomas.Doerfler |
ARM bsp maintenance
4.104.115
@010e9336
04/28/09 06:23:04 |
Chris Johns |
2009-04-28 Chris Johns <chrisj@…>
4.104.115
@01d1ae3
03/12/09 14:18:32 |
Joel Sherrill |
2009-03-12 Joel Sherrill <joel.sherrill@…>
PR 1385/cpukit …
4.104.115
@bdc8d46
03/02/09 17:10:31 |
Joel Sherrill |
2009-03-02 Ray Xu <rayx.cn@…>
* shared/irq/irq_asm.S: Newer …
4.104.115
@949166d
02/27/09 12:12:08 |
Thomas.Doerfler |
added missing files
4.104.115
@9647f7fe
02/27/09 11:26:44 |
Thomas.Doerfler |
* README: Added NCS.
* Makefile.am, configure.ac, preinstall.am: …
4.104.115
@d4f6b30
09/22/08 21:49:32 |
Joel Sherrill |
2008-09-22 Joel Sherrill <joel.sherrill@…>
* acinclude.m4, …
4.104.115
@8dcfc0a
09/22/08 11:49:50 |
Thomas.Doerfler |
* empty log message *
4.104.115
@c47e486
09/19/08 21:14:05 |
Joel Sherrill |
2008-09-19 Joel Sherrill <joel.sherrill@…>
4.104.115
@02694aa
09/12/08 20:25:38 |
Joel Sherrill |
2008-09-12 Joel Sherrill <joel.sherrill@…>
4.104.115
@6bb1d1a2
08/18/08 21:15:04 |
Ralf Corsepius |
2008-08-18 Ralf Corsépius <ralf.corsepius@…>
4.104.114.95
@6579ae0
08/04/08 17:46:07 |
Joel Sherrill |
2008-08-04 Ray Xu <rayx.cn@…>
* shared/irq/irq_asm.S: …
4.104.114.95
@495c3e0
05/23/08 15:47:55 |
Joel Sherrill |
2008-05-23 Joel Sherrill <joel.sherrill@…>
4.104.114.95
@369730c
02/15/08 18:54:47 |
Joel Sherrill |
2008-02-15 Joel Sherrill <joel.sherrill@…>
4.104.114.95
@f28bbe5c
11/06/07 22:50:51 |
Joel Sherrill |
2007-11-03 Ray Xu <rayx.cn@…>
4.104.114.95
@f3343c6e
09/12/07 15:15:32 |
Joel Sherrill |
2007-09-12 Joel Sherrill <joel.sherrill@…>
PR 1257/bsps
4.104.114.84.95
@46ba602
09/08/07 17:22:28 |
Joel Sherrill |
2007-09-08 Joel Sherrill <joel.sherrill@…>
4.104.114.84.95
@89b7e69
06/13/07 21:20:50 |
Joel Sherrill |
2007-06-13 Ray Xu <rayx@…>
* shared/abort/simple_abort.c: …
4.104.114.84.95
@4008232
05/15/07 18:03:05 |
Joel Sherrill |
2007-05-15 Ray Xu <rayx@…>
* shared/abort/abort.c, …
4.104.114.84.95
@2bced8f
12/14/06 05:45:51 |
Ralf Corsepius |
Remove unused var.
4.104.114.84.95
@965c3924
06/03/06 03:24:00 |
Jay Monkman |
2006-06-02 Jay Monkman <jtm@…>
* shared/irq/irq_init.c: …
4.104.114.84.95
@b4156a3
10/16/05 07:41:07 |
Ralf Corsepius |
Remove.
4.104.114.84.95
@f05b2ac
04/21/04 16:01:48 |
Ralf Corsepius |
Remove duplicate white lines.
4.104.114.84.95
@6128a4a
04/21/04 10:43:04 |
Ralf Corsepius |
Remove stray white spaces.
4.104.114.84.95
@3239698
04/15/04 13:26:21 |
Ralf Corsepius |
4.104.114.84.95
