@1c62f74d
04/17/14 09:11:58 |
ralf.kirchner |
bsp/arm: Add L2 cache locking
This level 2 cache is a shared data and …
4.115
@bebcfa57
04/17/14 09:03:50 |
ralf.kirchner |
bsp/arm: Remove unused cache store methods
4.115
@db5a84d
04/17/14 08:59:47 |
ralf.kirchner |
bsp/arm: Correct cache misalignment handling
Correct misalignment …
4.115
@92e2757
04/17/14 08:37:10 |
ralf.kirchner |
bsp/arm: Correct L2 cache flushing
Correct misalignment handling and …
4.115
@cbd9e63
04/17/14 08:30:54 |
ralf.kirchner |
bsp/arm: Remove arm erratum 764369 from L2 cache
Arm erratum 764369 …
4.115
@9ee2ec5
04/17/14 07:43:30 |
ralf.kirchner |
bsp/arm: Consistenly same handling for flushing
It is importeant to …
4.115
@e331e69
04/16/14 14:07:13 |
ralf.kirchner |
bsp/arm: RTEMS_SMP to arm erratum 764369 detection
Move the RTEMS_SMP …
4.115
@707b6172
04/16/14 14:04:56 |
ralf.kirchner |
bsp/arm: Erratum 764369 after enabling SCU
Execute the SCU part of …
4.115
@d9e7d1e
04/16/14 12:27:36 |
ralf.kirchner |
bsp/arm: Correct detection of arm erratum 764368
4.115
@924b47a
04/17/14 07:21:36 |
ralf.kirchner |
bsp/arm: Cleanup L1 cache
4.115
@53e008b
04/10/14 13:48:05 |
Sebastian Huber |
score: SMP initialization changes
Add and use …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@fac9da63
03/09/14 13:22:55 |
Pavel Pisa |
bsps/arm: Add DP83848 PHY support to LPC Ethernet
4.115
@14c3cb6
02/21/14 13:59:57 |
Pavel Pisa |
bsps/arm: Add PHY detection to LPC Ethernet
4.115
@369bb13b
02/21/14 13:08:03 |
Pavel Pisa |
bsps/arm: Reset MII management in LPC Ethernet
Reduce MII clock to …
4.115
@9fcd1b35
02/17/14 09:22:16 |
ralf.kirchner |
bsp/arm: Add handling for level 2 L2C-310 cache controller
4.115
@0b74e10f
02/17/14 10:57:19 |
ralf.kirchner |
bsp/arm: Add SCU errata handling for L2C-310 cache
4.115
@b87bf0b
02/17/14 10:44:47 |
ralf.kirchner |
bsp/arm: Add arm-errata.h and arm-release-id.h
4.115
@f241977
02/17/14 12:27:11 |
ralf.kirchner |
bsp/arm: Add linker symbol bsp_processor_count
4.115
@a502d677
02/18/14 13:31:26 |
ralf.kirchner |
bsp/arm: Separate setup for translation table
4.115
@f5c10645
10/16/13 08:39:05 |
ralf.kirchner |
bsp/arm: Invalidate SCU
4.115
@34568acf
03/05/14 08:14:59 |
ralf.kirchner |
bsp/arm: SMP support for a9mpcore_clock_cleanup()
4.115
@17864a4
08/01/13 14:45:42 |
ralf.kirchner |
bsp/arm: Avoid warning
4.115
@4d9bd56
02/17/14 14:12:43 |
Sebastian Huber |
score: Rename rtems_smp_process_interrupt()
Rename …
4.115
@911b1d2
02/17/14 14:02:54 |
Sebastian Huber |
score: Rename rtems_smp_secondary_cpu_initialize()
Rename …
4.115
@f8ff2a0
02/17/14 13:31:32 |
Sebastian Huber |
score: Delete bsp_smp_broadcast_interrupt()
Since the per-CPU SMP …
4.115
@4627fcd
02/17/14 13:25:29 |
Sebastian Huber |
score: Rename bsp_smp_initialize()
Rename bsp_smp_initialize() into …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@382ea27b
02/13/14 09:04:05 |
Sebastian Huber |
bsps/arm: Fix Cortex-A9 MPCore nanoseconds handler
4.115
@0df8d7f2
02/10/14 11:21:24 |
Sebastian Huber |
bsps/arm: Use Global Timer for Cortex-A9 MPCore
Use the Global Timer …
4.115
@069e10c3
02/10/14 11:17:34 |
Sebastian Huber |
bsps/arm: Include missing header file
4.115
@960fd85
01/28/14 10:52:17 |
Sebastian Huber |
bsps: Thread-local storage (TLS) for linkcmds
4.115
@bba0e09
01/30/14 09:37:02 |
Sebastian Huber |
bsps: Fix barrier section definitions
4.115
@3a7f588
01/14/14 08:43:53 |
Sebastian Huber |
bsps/arm: Use _ARMV4_Exception_interrupt
This allows read-only vector …
4.115
@4ec210fe
01/13/14 12:18:26 |
Sebastian Huber |
bsps/arm: Use ALIGN_WITH_INPUT
The ALIGN_WITH_INPUT helps to make …
4.115
@5b85cca
01/01/14 18:40:31 |
Sebastian Huber |
bsps/arm: Use handlers for PL111 set up/tear down
4.115
@85f2486b
12/30/13 18:54:46 |
Joel Sherrill |
libbsp misc: Fix comment formatting
4.115
@b7212b9
12/23/13 02:07:02 |
zsoltisharkboy |
libbsp/arm: add doxygen to arm shared headers
4.115
@f466e56
12/19/13 03:49:11 |
Chris Johns |
arm/a9mpcore: Add support to get the clock via a weak linkage …
4.115
@4a9e52e
12/19/13 00:45:19 |
Chris Johns |
Fix the broken conflict from the revert.
4.115
@1ab4f76
12/19/13 00:35:22 |
Chris Johns |
Revert "bsps/arm: Use ALIGN_WITH_INPUT"
This reverts commit …
4.115
@e4927ece
12/04/13 14:39:20 |
Sebastian Huber |
bsps: Simplify FreeBSD linker sets
4.115
@287bbb6
08/30/13 15:43:16 |
Sebastian Huber |
This requires at least Binutils 2.24.
4.115
@136a847
12/10/13 01:28:09 |
Chris Johns |
arm shared: Add bsp_translation_table_end the linker symbols.
4.115
@296c74e6
12/09/13 19:37:48 |
Daniel Ramirez |
doxygen: refactored doxygen in libbsp to illustrate new rule set
4.115
@2d6543d4
11/30/13 02:18:44 |
Daniel Ramirez |
doxygen: refactored doxygen in libbsp/arm/lpc32xx
This patch …
4.115
@98eb7e78
11/26/13 00:14:28 |
Daniel Ramirez |
raspberrypi doxygen refactoring
4.115
@a3b1fcd
11/14/13 14:55:51 |
Sebastian Huber |
4.115
@fbed79b
10/27/13 18:35:16 |
Sebastian Huber |
bsps/arm: Add ARMV7_CP15_START_DEFAULT_SECTIONS
4.115
@09d0c96b
10/27/13 17:58:42 |
Sebastian Huber |
bsps/arm: Move some MMU bit settings
The function …
4.115
@0f874ee
10/27/13 17:51:53 |
Sebastian Huber |
bsps/arm: Init trans tbl with invalid entries
4.115
@5ceefe1
09/28/13 08:08:25 |
Hesham Almatary |
Shared MMU initialization for ARM BSPs and RaspberryPi? MMU support
4.115
@a44917e
09/16/13 07:27:32 |
Ric Claus |
bsps/arm: Fix exception entries
4.115
@c32c80e
08/13/13 12:43:54 |
Sebastian Huber |
bsps/arm: Use proper default priority for GIC
Some GIC …
4.115
@ca63ae2
06/13/13 13:41:21 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Send_interrupt()
Delete bsp_smp_interrupt_cpu().
4.115
@39e51758
06/14/13 12:00:38 |
Sebastian Huber |
smp: Add and use _CPU_SMP_Get_current_processor()
Add and use …
4.115
@39234725
07/17/13 06:42:35 |
Ric Claus |
bsps/arm: Fix for top of the address space
4.115
@3ccaf3c
07/16/13 15:18:18 |
Sebastian Huber |
bsps: Use rtems_task_self()
4.115
@3b645c1
06/28/13 19:26:59 |
Sebastian Huber |
bsps/arm: Add PL050 support
4.115
@c8312b3
06/23/13 12:39:47 |
Sebastian Huber |
bsps/arm: Add PL111 support
4.115
@ca59217
06/28/13 07:03:11 |
Sebastian Huber |
bsps/arm: Set vector base on all processors
4.115
@a3a4cd5
06/26/13 07:40:44 |
Sebastian Huber |
bsps/arm: Move input sections
Move input sections to preserve order …
4.115
@4b83e8f1
06/21/13 07:59:27 |
Sebastian Huber |
bsps/arm: Fix set exception handler for ARMv7
4.115
@e18db9f
06/24/13 15:29:11 |
Sebastian Huber |
termios: Update due to API changes
Termios notifies now the driver …
4.115
@1df348b
06/24/13 09:00:36 |
Sebastian Huber |
bsps/arm: Rename function
Rename …
4.115
@cddb8f4
06/20/13 07:48:27 |
Ric Claus |
bsps/arm: Fix some GIC functions
4.115
@9a037da9
06/19/13 09:20:06 |
Sebastian Huber |
bsps/arm: Set vector base address if necessary
4.115
@db42c079
05/31/13 11:59:47 |
Sebastian Huber |
bsps/arm: Add SMP support
4.115
@0d671d70
05/27/13 10:43:53 |
Sebastian Huber |
bsps/arm: Move .fast_text section
Move the .fast_text section after …
4.115
@cab410f
05/21/13 12:19:24 |
Sebastian Huber |
bsps: Update due to linker changes
In case the VMA and LMA regions …
4.115
@cfd8d7a
05/08/13 07:30:31 |
Sebastian Huber |
arm: Support VFP-D32 and Neon
4.115
@12d182c4
05/06/13 12:01:10 |
Sebastian Huber |
bsps/arm: Fix register usage
4.115
@e37d57bc
05/06/13 08:59:07 |
Sebastian Huber |
bsps/arm: Add shared GIC tmtests/tm27 support
4.115
@33c98fd
05/06/13 08:20:26 |
Sebastian Huber |
bsps/arm: Remove superfluous parameter
4.115
@a91dc98b
04/26/13 13:06:32 |
Sebastian Huber |
bsp/realview-pbx-a9: New BSP
4.115
@9ce65803
05/02/13 11:37:30 |
Sebastian Huber |
bsps/arm: Copy vector table only if necessary
4.115
@27690ec3
05/02/13 11:36:03 |
Sebastian Huber |
bsps/arm: Move .vector section
The .vector section contains …
4.115
@ecf7dd9
05/02/13 09:41:22 |
Sebastian Huber |
bsps/arm: Move CP15 start initialization
4.115
@88cf23f8
04/30/13 13:23:45 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_exception_handler()
4.115
@037e8ae5
05/02/13 15:42:20 |
Sebastian Huber |
bsps/arm: Add arm_cp15_set_trans*_table_entries()
4.115
@962e0fac
05/02/13 09:18:09 |
Sebastian Huber |
bsps/arm: Add and use bsp_translation_table_base
4.115
@fb0584f
05/03/13 08:39:26 |
Sebastian Huber |
bsps/arm: Move implementation to inline functions
4.115
@8ac62c4
03/26/13 15:01:10 |
Sebastian Huber |
bsps/arm: Add thread-local storage (TLS) sections
4.115
@df6818f9
03/18/13 14:24:00 |
Sebastian Huber |
bsps: Support DWARF extension
4.115
@f12ef239
01/09/13 15:25:37 |
Sebastian Huber |
bsps/arm: Fix LPC Ethernet driver initialization
4.115
@04f399d
01/07/13 09:19:23 |
Sebastian Huber |
arm: Add and use _ARMV7M_Exception_default()
4.115
@13cf952
01/04/13 14:47:34 |
Sebastian Huber |
arm: Add and use default exception handler
Add and use …
4.115
@4592658
12/18/12 08:24:56 |
Sebastian Huber |
bsps/arm: Move promiscuous mode setting
4.115
@3f58ac7
12/17/12 14:41:53 |
Sebastian Huber |
bsps/arm: Add PHY up/down
All PHYs will be set to power up/down state …
4.115
@50233d37
12/17/12 10:12:20 |
Sebastian Huber |
bsps/arm: Add PHY timeout detection
4.115
@2cd48da
12/14/12 12:08:10 |
Sebastian Huber |
bsps/arm: Add interface down support
4.115
@e99893f9
12/14/12 11:17:15 |
Sebastian Huber |
bsps/arm: Prepare for interface down support
4.115
@573822b
12/14/12 11:07:28 |
Sebastian Huber |
bsps/arm: Use assert() instead of status macros
4.115
@5970dcc9
12/14/12 09:28:18 |
Sebastian Huber |
bsps/arm: Remove superfluous attributes
4.115
@e5a7f846
12/14/12 08:40:44 |
Sebastian Huber |
bsps/arm: Avoid mbuf migration in LPC ethernet
The receive task will …
4.115
@26e90fb1
10/30/12 16:42:17 |
Sebastian Huber |
libnetworking: Use system events
Add reserved system events …
4.115
@7f5ab84e
09/28/12 11:48:32 |
Sebastian Huber |
bsps/arm: Fix rtems_mii_ioctl() usage
4.115
@afd1967
09/24/12 10:51:47 |
Sebastian Huber |
bsps/arm: Add LPC_DMA_CHANNEL_COUNT
4.115
@7329f55
06/06/12 12:48:23 |
Sebastian Huber |
bsps/arm: Rename linkcmds.armv7 to linkcmds.armv7m
4.115
