# # ChangeLog for c/src/lib/libbsp/arm/realview-pbx-a9/make in rtems # # Generated by Trac 1.2.1.dev0 # 03/28/24 11:16:04 Wed, 08 May 2013 07:30:31 GMT Sebastian Huber [cfd8d7a] * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg (modified) * cpukit/score/cpu/arm/arm-context-validate.S (modified) * cpukit/score/cpu/arm/arm-context-volatile-clobber.S (modified) * cpukit/score/cpu/arm/arm-exception-frame-print.c (modified) * cpukit/score/cpu/arm/arm_exc_interrupt.S (modified) * cpukit/score/cpu/arm/armv4-exception-default.S (modified) * cpukit/score/cpu/arm/cpu.c (modified) * cpukit/score/cpu/arm/cpu_asm.S (modified) * cpukit/score/cpu/arm/rtems/score/arm.h (modified) * cpukit/score/cpu/arm/rtems/score/cpu.h (modified) arm: Support VFP-D32 and Neon Fri, 26 Apr 2013 13:06:32 GMT Sebastian Huber [a91dc98b] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/README (added) * c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs (added) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (added) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/tm27.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (added) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspreset.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstart.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (added) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (added) * c/src/lib/libbsp/arm/shared/arm-pl011.c (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011.h (added) bsp/realview-pbx-a9: New BSP
