# # ChangeLog for c/src/lib/libbsp/arm/realview-pbx-a9/include in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 01:26:27 Fri, 31 May 2013 11:59:47 GMT Sebastian Huber [db42c079] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/README (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu_smp.cfg (added) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu (moved) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds.realview_pbx_a9_qemu_smp (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-smp.c (added) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-start.h (added) * c/src/lib/libbsp/arm/shared/include/arm-cp15-start.h (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (modified) * c/src/lib/libbsp/arm/shared/start/start.S (modified) * c/src/lib/libbsp/arm/shared/startup/linkcmds.base (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu_smp.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu (moved) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds.xilinx_zynq_a9_qemu_smp (added) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Add SMP support Fri, 31 May 2013 07:59:27 GMT Sebastian Huber [1dcf5fe] * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (modified) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (modified) * c/src/lib/libcpu/arm/shared/include/arm-cp15.h (modified) bsps/arm: Merge ARMv7 MMU section definitions Mon, 06 May 2013 08:59:07 GMT Sebastian Huber [e37d57bc] * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/include/tm27.h (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (modified) * c/src/lib/libbsp/arm/shared/include/arm-gic-tm27.h (added) bsps/arm: Add shared GIC tmtests/tm27 support Fri, 26 Apr 2013 13:06:32 GMT Sebastian Huber [a91dc98b] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/README (added) * c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs (added) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (added) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/tm27.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (added) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspreset.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstart.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (added) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (added) * c/src/lib/libbsp/arm/shared/arm-pl011.c (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011.h (added) bsp/realview-pbx-a9: New BSP
