@e706a9d
05/19/16 08:24:46 |
Pavel Pisa |
arm/raspberrypi: ensure that RTEMS application image can be started by …
5
@aa78a0f
03/29/16 18:10:50 |
joel |
arm/raspberrypi: Remove include of <rtems/console.h> from <bsp.h> and …
5
@ebc8a11
03/25/16 15:44:57 |
joel |
arm/raspberrypi/include/bsp.h: Do not include <rtems/clockdrv.h>
5
@fa9c057
03/10/16 18:31:37 |
joel |
arm/raspberrypi: Add per-section compilation and linking suppo
5
@ca4602e
01/25/16 21:03:00 |
Sebastian Huber |
Use linker set for libio initialization
Update #2408.
5
@4200a36a
12/30/15 00:09:34 |
soja-lists |
bsp/raspberrypi: Move assignment outside if-condition
Assignment was …
5
@687463d
12/03/15 20:56:31 |
soja-lists |
Store task_id of the current thread for the ISR before waiting for the …
5
@2858939a
12/09/15 11:03:49 |
Sebastian Huber |
bsps: Delete superfluous bsp_pretasking_hook()
Use the …
5
@2502e26d
11/03/15 17:00:15 |
Ben Gras |
Leftover gpio function rename
Rename rtems_bsp_select_specific_io to …
5
@5c337d7e
10/21/15 15:33:44 |
Sudarshan Rajagopalan |
Fixes GPIO APIs Naming Convention and Comments
Closes #2435.
5
@7aca0fe
09/05/15 20:53:16 |
andre.lousa.marques |
RaspberryPi?: Added I2C and SPI bus support.
Further documentation can …
5
@f7ea9579
08/15/15 18:52:28 |
Added GPIO API sources to rpi Makefile
5
@b09a578
08/17/15 10:42:27 |
Closes ticket #2390, and also updates the RPI implementation.
makes …
5
@61e7c69
07/27/15 16:01:44 |
Raspberry Pi implementation for the RTEMS GPIO API.
Added support for …
5
@e77f6254
07/07/15 20:33:51 |
summerspam |
RaspberryPi?: Use rtems_configuration_get_microseconds_per_tick to set …
4.115
@0afac6a
05/20/15 17:11:41 |
Joel Sherrill |
Multiple bsp_specs: Change *(old_endfile) to %(old_endfile)
Fix typo. …
4.115
@75acd9e
04/01/15 13:33:25 |
alexander.krutwig |
bsps: Convert clock drivers to use a timecounter
Update #2271.
4.115
@044c7d82
04/07/15 20:06:32 |
alan.cudmore |
Add hardware FPU flags for Raspberry Pi 2 BSP
4.115
@71260b4
03/15/15 16:04:06 |
alan.cudmore |
preliminary Raspberry Pi Model 2 support
This patch adds a BSP …
4.115
@683ebac
03/04/15 20:49:08 |
Joel Sherrill |
raspberrypi: Do not include default IRQ handler and BSP specific one
4.115
@12072880
12/04/14 09:03:50 |
Sebastian Huber |
Update bug report URL
4.115
@cbc433c7
11/25/14 07:40:20 |
Sebastian Huber |
bsps/arm: Add .nocache section
This section can be use to provide a …
4.115
@96a9f4c
11/12/14 13:00:05 |
alan.cudmore |
ARM removed shared/abort from several ARM BSPs
4.115
@ddc8165
10/20/14 20:25:22 |
Joel Sherrill |
arm/raspberrypi: Fix warnings
4.115
@bdd6082
09/18/14 09:07:41 |
Sebastian Huber |
bsps: Fix build error
Fix build error introduced in …
4.115
@8fbe2e6
09/04/14 13:59:49 |
Joel Sherrill |
Use correct prototype of benchmark_timer_read()
This change starts …
4.115
@be4992b1
09/02/14 23:00:44 |
Joel Sherrill |
raspberrypi: Use shared bspreset.c
4.115
@b597c0d
08/28/14 13:44:52 |
Joel Sherrill |
Regenerate all preinstall.am files.
Apparently, at some point …
4.115
@9eb1994f
07/01/14 13:17:40 |
Sebastian Huber |
bsps/arm: Rename bsp_mm_config_table
Rename bsp_mm_config_table to …
4.115
@2d3caccf
06/05/14 11:22:08 |
Sebastian Huber |
bsps/arm: Define ARM_CP15_TEXT_SECTION
Define ARM_CP15_TEXT_SECTION …
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@f2a8b60
02/26/14 08:19:17 |
ralf.kirchner |
bsp/raspberrypi: Add arm-errata.h and arm-release-id.h
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@296c74e6
12/09/13 19:37:48 |
Daniel Ramirez |
doxygen: refactored doxygen in libbsp to illustrate new rule set
4.115
@98eb7e78
11/26/13 00:14:28 |
Daniel Ramirez |
raspberrypi doxygen refactoring
4.115
@f074a4d
10/27/13 18:27:44 |
Sebastian Huber |
bsps/arm: ARMV7_MMU_DATA_READ_WRITE_SHAREABLE
Delete …
4.115
@7ad725f2
10/14/13 13:34:58 |
Hesham Almatary |
Modify raspberrypi mm_config_table to map GPIO and registers.
Changes …
4.115
@5ceefe1
09/28/13 08:08:25 |
Hesham Almatary |
Shared MMU initialization for ARM BSPs and RaspberryPi? MMU support
4.115
@38d94f56
09/16/13 19:31:28 |
Joel Sherrill |
raspberrypi.cfg: Remove CVS Id
4.115
@efdda565
08/09/13 04:18:17 |
Nick Withers |
Use $(EXEEXT) [defaults to "exe"] to generate binaries
4.115
@f2e9d0d
05/06/13 07:59:16 |
Sebastian Huber |
bsp/raspberrypi: Use shared start code
4.115
@9159711
05/06/13 07:37:12 |
alan.cudmore |
bsp/raspberrypi: Enable unaligned access
4.115
@c32b1ef
03/23/13 18:13:07 |
alan.cudmore |
bsp/raspberrypi: New BSP
4.115
