# # ChangeLog for c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c in rtems # # Generated by Trac 1.2.1.dev0 # 03/28/24 20:06:39 Mon, 06 May 2013 07:59:16 GMT Sebastian Huber [f2e9d0d] * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (modified) bsp/raspberrypi: Use shared start code Mon, 06 May 2013 07:37:12 GMT Alan Cudmore [9159711] * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (modified) bsp/raspberrypi: Enable unaligned access Sat, 23 Mar 2013 18:13:07 GMT Alan Cudmore [c32b1ef] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (added) * c/src/lib/libbsp/arm/raspberrypi/README (added) * c/src/lib/libbsp/arm/raspberrypi/bsp_specs (added) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (added) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (added) * c/src/lib/libbsp/arm/raspberrypi/console/console-config.c (added) * c/src/lib/libbsp/arm/raspberrypi/console/usart.c (added) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/irq.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/mmu.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/usart.h (added) * c/src/lib/libbsp/arm/raspberrypi/irq/irq.c (added) * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg (added) * c/src/lib/libbsp/arm/raspberrypi/misc/timer.c (added) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds (added) bsp/raspberrypi: New BSP
