# # ChangeLog for c/src/lib/libbsp/arm/nds/console in rtems # # Generated by Trac 1.2.1.dev0 # 06/17/24 19:32:25 Fri, 11 Feb 2011 11:48:20 GMT Ralf Corsepius [3af73566] * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.c (modified) * c/src/lib/libbsp/arm/nds/tools/bin2s.c (modified) 2011-02-11 Ralf Corsépius * ... Mon, 26 Apr 2010 02:28:02 GMT Joel Sherrill [af3fd0c6] * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) 2010-04-25 Joel Sherrill * ... Mon, 07 Dec 2009 16:22:43 GMT Ralf Corsepius [56aadea] * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) 2009-12-07 Ralf Corsépius * ... Mon, 07 Dec 2009 07:22:06 GMT Ralf Corsepius [7a26d40f] * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) 2009-12-07 Ralf Corsépius * ... Wed, 20 Aug 2008 16:31:41 GMT Joel Sherrill [9a85541] * c/src/lib/libbsp/arm/nds/ChangeLog (modified) * c/src/lib/libbsp/arm/nds/block/block.c (modified) * c/src/lib/libbsp/arm/nds/console/console.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ARP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Config.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DHCP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DNS.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Hub.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ICMP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_IP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_TCP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_UDP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_memblock.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi7.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi9.h (modified) * c/src/lib/libbsp/arm/nds/fb/fb.c (modified) * c/src/lib/libbsp/arm/nds/include/my_ipc.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc_io.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/exceptions.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/input.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/ndsmotion.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/videoGL.h (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (modified) * c/src/lib/libbsp/arm/nds/sound/sound.c (modified) * c/src/lib/libbsp/arm/nds/startup/start.c (modified) * c/src/lib/libbsp/arm/nds/touchscreen/reco.h (modified) * c/src/lib/libbsp/arm/nds/wifi/compat.c (modified) * c/src/lib/libbsp/arm/nds/wifi/compat.h (modified) 2008-08-20 Joel Sherrill * ... Wed, 16 Apr 2008 18:37:33 GMT Joel Sherrill [311dfa6] * c/src/lib/libbsp/arm/nds/ChangeLog (added) * c/src/lib/libbsp/arm/nds/Makefile.am (added) * c/src/lib/libbsp/arm/nds/README (added) * c/src/lib/libbsp/arm/nds/block/block.c (added) * c/src/lib/libbsp/arm/nds/bsp_specs (added) * c/src/lib/libbsp/arm/nds/clock/clock.c (added) * c/src/lib/libbsp/arm/nds/configure.ac (added) * c/src/lib/libbsp/arm/nds/console/console.c (added) * c/src/lib/libbsp/arm/nds/coproc/coproc.S (added) * c/src/lib/libbsp/arm/nds/coproc/coproc.c (added) * c/src/lib/libbsp/arm/nds/coproc/coproc.ld (added) * c/src/lib/libbsp/arm/nds/dswifi/arm7/makefile (added) * c/src/lib/libbsp/arm/nds/dswifi/arm7/source/wifi_arm7.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm7/source/wifi_arm7.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/makefile (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ARP.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ARP.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Config.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DHCP.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DHCP.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DNS.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DNS.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Hub.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Hub.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ICMP.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ICMP.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_IP.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_IP.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_TCP.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_TCP.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_UDP.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_UDP.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_memblock.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_memblock.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_sockets.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_sockets.h (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.c (added) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.h (added) * c/src/lib/libbsp/arm/nds/dswifi/common/source/dsregs.h (added) * c/src/lib/libbsp/arm/nds/dswifi/common/source/spinlock.h (added) * c/src/lib/libbsp/arm/nds/dswifi/common/source/spinlock.s (added) * c/src/lib/libbsp/arm/nds/dswifi/common/source/wifi_shared.h (added) * c/src/lib/libbsp/arm/nds/dswifi/dswifi_license.txt (added) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi7.h (added) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi9.h (added) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi_version.h (added) * c/src/lib/libbsp/arm/nds/dswifi/include/netdb.h (added) * c/src/lib/libbsp/arm/nds/dswifi/include/netinet/in.h (added) * c/src/lib/libbsp/arm/nds/dswifi/include/sgIP_errno.h (added) * c/src/lib/libbsp/arm/nds/dswifi/makefile (added) * c/src/lib/libbsp/arm/nds/fb/fb.c (added) * c/src/lib/libbsp/arm/nds/fb/fb.h (added) * c/src/lib/libbsp/arm/nds/include/bsp.h (added) * c/src/lib/libbsp/arm/nds/include/my_ipc.h (added) * c/src/lib/libbsp/arm/nds/include/sys/iosupport.h (added) * c/src/lib/libbsp/arm/nds/include/tm27.h (added) * c/src/lib/libbsp/arm/nds/include/types.h (added) * c/src/lib/libbsp/arm/nds/irq/irq.c (added) * c/src/lib/libbsp/arm/nds/irq/irq.h (added) * c/src/lib/libbsp/arm/nds/libfat/gba/include/fat.h (added) * c/src/lib/libbsp/arm/nds/libfat/include/fat.h (added) * c/src/lib/libbsp/arm/nds/libfat/nds/include/fat.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/bit_ops.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/cache.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/cache.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/common.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/directory.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/directory.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc_io.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_cf_common.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_cf_common.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_dldi.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_dldi.s (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3_common.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3_common.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sc_common.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sc_common.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd_s.s (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sd_common.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sd_common.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/fatdir.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/fatdir.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/fatfile.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/fatfile.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/file_allocation_table.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/file_allocation_table.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/filetime.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/filetime.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/libfat.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/mem_allocate.h (added) * c/src/lib/libbsp/arm/nds/libfat/source/partition.c (added) * c/src/lib/libbsp/arm/nds/libfat/source/partition.h (added) * c/src/lib/libbsp/arm/nds/libnds/Makefile.arm7 (added) * c/src/lib/libbsp/arm/nds/libnds/Makefile.arm9 (added) * c/src/lib/libbsp/arm/nds/libnds/basicARM7/source/defaultARM7.c (added) * c/src/lib/libbsp/arm/nds/libnds/include/default_font_bin.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/gbfs.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/audio.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/clock.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/serial.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/touch.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/background.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/boxtest.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/cache.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/console.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/exceptions.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/image.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/input.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/math.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/ndsmotion.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/pcx.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/postest.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/rumble.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/sound.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/sprite.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/trig_lut.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/video.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/videoGL.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/bios.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/card.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/dma.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/interrupts.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/ipc.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/jtypes.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/memory.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/registers_alt.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/reload.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/system.h (added) * c/src/lib/libbsp/arm/nds/libnds/include/nds/timers.h (added) * c/src/lib/libbsp/arm/nds/libnds/libnds_license.txt (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/audio.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/clock.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/microphone.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/spi.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/userSettings.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/COS.bin (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/COS.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/SIN.bin (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/SIN.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/TAN.bin (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/TAN.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/dcache.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/default_font.bin (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/default_font.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/exceptionHandler.S (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/exceptionHandler.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/exceptions.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/icache.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/initSystem.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/keys.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/pcx.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/rumble.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/sound.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/system.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/touch.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/video.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/common/biosCalls.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c (added) * c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.s (added) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (added) * c/src/lib/libbsp/arm/nds/mk_libnds.sh (added) * c/src/lib/libbsp/arm/nds/patch.libnds (added) * c/src/lib/libbsp/arm/nds/preinstall.am (added) * c/src/lib/libbsp/arm/nds/rtc/rtc.c (added) * c/src/lib/libbsp/arm/nds/sound/sound.c (added) * c/src/lib/libbsp/arm/nds/sound/sound.h (added) * c/src/lib/libbsp/arm/nds/start/start.S (added) * c/src/lib/libbsp/arm/nds/startup/linkcmds (added) * c/src/lib/libbsp/arm/nds/startup/start.c (added) * c/src/lib/libbsp/arm/nds/timer/timer.c (added) * c/src/lib/libbsp/arm/nds/tools/Makefile.am (added) * c/src/lib/libbsp/arm/nds/tools/bin2s (added) * c/src/lib/libbsp/arm/nds/tools/bin2s.c (added) * c/src/lib/libbsp/arm/nds/tools/configure.ac (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/arm7_sha1_homebrew.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/arm7_sha1_nintendo.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/banner.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/bigint.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/crc.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/default_icon.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/encryption.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/header.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/hook.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/little.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/loadme.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/logo.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndscreate.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndsextract.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndstool.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndstree.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/overlay.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/passme.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/passme_sram.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/passme_vhd1.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/passme_vhd2.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/raster.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/sha1.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/types.h (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/arm7_sha1_homebrew.c (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/arm7_sha1_nintendo.c (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/banner.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/bigint.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/compile_date.c (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/crc.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/default_icon.c (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/encryption.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/header.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/hook.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/loadme.c (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/logo.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndscodes.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndscreate.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndsextract.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndstool.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndstree.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/passme.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/passme_sram.c (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/raster.cpp (added) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/sha1.cpp (added) * c/src/lib/libbsp/arm/nds/tools/runtest (added) * c/src/lib/libbsp/arm/nds/touchscreen/README.reco (added) * c/src/lib/libbsp/arm/nds/touchscreen/parser.c (added) * c/src/lib/libbsp/arm/nds/touchscreen/reco.c (added) * c/src/lib/libbsp/arm/nds/touchscreen/reco.h (added) * c/src/lib/libbsp/arm/nds/touchscreen/touchscreen.c (added) * c/src/lib/libbsp/arm/nds/touchscreen/touchscreen.h (added) * c/src/lib/libbsp/arm/nds/wifi/compat.c (added) * c/src/lib/libbsp/arm/nds/wifi/compat.h (added) * c/src/lib/libbsp/arm/nds/wifi/wifi.c (added) 2008-04-16 Matthieu Bucchianeri * ...
