# # ChangeLog for c/src/lib/libbsp/arm/csb336/network/lan91c11x.c in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 01:29:48 Sun, 29 Nov 2009 14:53:02 GMT Ralf Corsepius [32b8506] * c/src/lib/libbsp/arm/csb336/console/uart.c (modified) * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.c (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.h (modified) * c/src/lib/libbsp/arm/csb336/network/network.c (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/console/fbcons.c (modified) * c/src/lib/libbsp/arm/csb337/console/font8x16.h (modified) * c/src/lib/libbsp/arm/csb337/console/sed1356.c (modified) * c/src/lib/libbsp/arm/csb337/console/sed1356_16bit.h (modified) * c/src/lib/libbsp/arm/csb337/console/uarts.c (modified) * c/src/lib/libbsp/arm/csb337/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb337/network/network.c (modified) * c/src/lib/libbsp/arm/csb337/start/start.S (modified) * c/src/lib/libbsp/arm/csb337/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.h (modified) * c/src/lib/libbsp/arm/edb7312/start/start.S (modified) * c/src/lib/libbsp/arm/gba/irq/bsp_irq_init.c (modified) * c/src/lib/libbsp/arm/gba/start/start.S (modified) * c/src/lib/libbsp/arm/gdbarmsim/start/start.S (modified) * c/src/lib/libbsp/arm/gdbarmsim/startup/syscalls.c (modified) * c/src/lib/libbsp/arm/gp32/console/uart.c (modified) * c/src/lib/libbsp/arm/gp32/include/bsp.h (modified) * c/src/lib/libbsp/arm/gp32/smc/smc.c (modified) * c/src/lib/libbsp/arm/gp32/start/start.S (modified) * c/src/lib/libbsp/arm/gp32/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/gumstix/console/uarts.c (modified) * c/src/lib/libbsp/arm/gumstix/fb/fb.c (modified) * c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c (modified) * c/src/lib/libbsp/arm/gumstix/start/start.S (modified) * c/src/lib/libbsp/arm/gumstix/startup/memmap.c (modified) * c/src/lib/libbsp/arm/lpc24xx/clock/clock-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/dma.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc24xx/network/network.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm7/source/wifi_arm7.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm7/source/wifi_arm7.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ARP.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ARP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Config.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DHCP.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DHCP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DNS.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DNS.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Hub.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Hub.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ICMP.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ICMP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_IP.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_IP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_TCP.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_TCP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_UDP.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_UDP.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_memblock.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_memblock.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_sockets.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_sockets.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.c (modified) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/common/source/dsregs.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/common/source/spinlock.S (modified) * c/src/lib/libbsp/arm/nds/dswifi/common/source/spinlock.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/common/source/wifi_shared.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi7.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi9.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/include/netdb.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/include/netinet/in.h (modified) * c/src/lib/libbsp/arm/nds/dswifi/include/sgIP_errno.h (modified) * c/src/lib/libbsp/arm/nds/fb/fb.c (modified) * c/src/lib/libbsp/arm/nds/libfat/gba/include/fat.h (modified) * c/src/lib/libbsp/arm/nds/libfat/include/fat.h (modified) * c/src/lib/libbsp/arm/nds/libfat/nds/include/fat.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/bit_ops.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/cache.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/cache.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/common.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/directory.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/directory.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc_io.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_cf_common.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_cf_common.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_dldi.S (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_dldi.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3_common.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3_common.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sc_common.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sc_common.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd_s.S (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sd_common.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sd_common.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/fatdir.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/fatdir.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/fatfile.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/fatfile.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/file_allocation_table.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/file_allocation_table.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/filetime.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/filetime.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/libfat.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/mem_allocate.h (modified) * c/src/lib/libbsp/arm/nds/libfat/source/partition.c (modified) * c/src/lib/libbsp/arm/nds/libfat/source/partition.h (modified) * c/src/lib/libbsp/arm/nds/libnds/basicARM7/source/defaultARM7.c (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/audio.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/clock.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/boxtest.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/cache.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/console.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/image.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/input.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/math.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/ndsmotion.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/pcx.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/postest.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/rumble.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/sound.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/sprite.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/trig_lut.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/video.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/videoGL.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/card.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/interrupts.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/registers_alt.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/reload.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/system.h (modified) * c/src/lib/libbsp/arm/nds/libnds/include/nds/timers.h (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/clock.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/userSettings.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/keys.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/pcx.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/rumble.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/sound.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/touch.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/biosCalls.S (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.S (modified) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (modified) * c/src/lib/libbsp/arm/nds/tools/bin2s.c (modified) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndstree.h (modified) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/sha1.h (modified) * c/src/lib/libbsp/arm/rtl22xx/console/uart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/rtl22xx/start/start.S (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/bsp.h (modified) * c/src/lib/libbsp/lm32/lm32_evr/include/coverhd.h (modified) * c/src/lib/libbsp/lm32/shared/clock/ckinit.c (modified) * c/src/lib/libbsp/lm32/shared/console/uart.c (modified) * c/src/lib/libbsp/lm32/shared/gdbstub/lm32-debug.S (modified) * c/src/lib/libbsp/lm32/shared/gdbstub/lm32-stub.c (modified) * c/src/lib/libbsp/lm32/shared/start/start.S (modified) * c/src/lib/libbsp/lm32/shared/tsmac/tsmac.c (modified) Whitespace removal. Tue, 06 Jan 2009 16:26:21 GMT Joel Sherrill [95ff1c3] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.c (modified) 2009-01-06 Joel Sherrill ... Wed, 12 Sep 2007 15:15:32 GMT Joel Sherrill [f3343c6e] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.c (modified) * c/src/lib/libbsp/arm/csb337/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/edb7312/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/irq/irq.c (modified) * c/src/lib/libbsp/arm/gba/irq/irq_init.c (modified) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/rtl22xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/shared/abort/abort.c (modified) * c/src/lib/libbsp/arm/shared/abort/simple_abort.c (modified) * c/src/lib/libbsp/arm/shared/irq/irq_init.c (modified) 2007-09-12 Joel Sherrill ... Mon, 12 Mar 2007 11:18:44 GMT Joel Sherrill [0c0ae29] * c/src/lib/libbsp/arm/csb336/ChangeLog (modified) * c/src/lib/libbsp/arm/csb336/include/bsp.h (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.c (modified) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.h (modified) * c/src/lib/libbsp/arm/csb336/network/network.c (modified) * c/src/lib/libbsp/arm/csb336/start/start.S (modified) * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/csb336/startup/exit.c (modified) * c/src/lib/libbsp/arm/csb336/startup/linkcmds (modified) * c/src/lib/libbsp/arm/csb336/startup/memmap.c (modified) 2007-03-12 Joel Sherrill * ... Thu, 15 Jul 2004 06:12:05 GMT Jay Monkman [1a3d1f3e] * c/src/lib/libbsp/arm/csb336/ChangeLog (added) * c/src/lib/libbsp/arm/csb336/Makefile.am (added) * c/src/lib/libbsp/arm/csb336/README (added) * c/src/lib/libbsp/arm/csb336/bsp_specs (added) * c/src/lib/libbsp/arm/csb336/configure.ac (added) * c/src/lib/libbsp/arm/csb336/console/uart.c (added) * c/src/lib/libbsp/arm/csb336/include/bsp.h (added) * c/src/lib/libbsp/arm/csb336/include/tm27.h (added) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.c (added) * c/src/lib/libbsp/arm/csb336/network/lan91c11x.h (added) * c/src/lib/libbsp/arm/csb336/network/network.c (added) * c/src/lib/libbsp/arm/csb336/start/start.S (added) * c/src/lib/libbsp/arm/csb336/startup/bspstart.c (added) * c/src/lib/libbsp/arm/csb336/startup/exit.c (added) * c/src/lib/libbsp/arm/csb336/startup/linkcmds (added) * c/src/lib/libbsp/arm/csb336/startup/memmap.c (added) * c/src/lib/libbsp/arm/csb336/times (added) 2004-07-15 Jay Monkman * ChangeLog, Makefile.am, ...
