# # ChangeLog for c/src/lib/libbsp/arm/acinclude.m4 in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 14:11:25 Thu, 14 Jan 2016 15:03:51 GMT Sebastian Huber [f2e0f8e] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/atsam/Makefile.am (added) * c/src/lib/libbsp/arm/atsam/README (added) * c/src/lib/libbsp/arm/atsam/bsp_specs (added) * c/src/lib/libbsp/arm/atsam/clock/systick-freq.c (added) * c/src/lib/libbsp/arm/atsam/configure.ac (added) * c/src/lib/libbsp/arm/atsam/console/console.c (added) * c/src/lib/libbsp/arm/atsam/console/debug-console.c (added) * c/src/lib/libbsp/arm/atsam/include/bsp.h (added) * c/src/lib/libbsp/arm/atsam/include/irq.h (added) * c/src/lib/libbsp/arm/atsam/include/pin-config.h (added) * c/src/lib/libbsp/arm/atsam/make/custom/atsamv.cfg (added) * c/src/lib/libbsp/arm/atsam/preinstall.am (added) * c/src/lib/libbsp/arm/atsam/startup/bspstart.c (added) * c/src/lib/libbsp/arm/atsam/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/atsam/startup/linkcmds (added) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.intsram (added) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.memory.in (added) * c/src/lib/libbsp/arm/atsam/startup/linkcmds.sdram (added) * c/src/lib/libbsp/arm/atsam/startup/pin-config.c (added) * c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h (added) * c/src/lib/libbsp/arm/shared/include/start.h (modified) bsp/atsam: New Close #2529. Sun, 13 Dec 2015 04:24:16 GMT Aun-Ali Zaidi [f2a228b] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/gp32/Makefile.am (deleted) * c/src/lib/libbsp/arm/gp32/README (deleted) * c/src/lib/libbsp/arm/gp32/bsp_specs (deleted) * c/src/lib/libbsp/arm/gp32/configure.ac (deleted) * c/src/lib/libbsp/arm/gp32/console/uart.c (deleted) * c/src/lib/libbsp/arm/gp32/include/bsp.h (deleted) * c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg (deleted) * c/src/lib/libbsp/arm/gp32/preinstall.am (deleted) * c/src/lib/libbsp/arm/gp32/smc/smc.c (deleted) * c/src/lib/libbsp/arm/gp32/smc/smc.h (deleted) * c/src/lib/libbsp/arm/gp32/start/start.S (deleted) * c/src/lib/libbsp/arm/gp32/startup/bspidle.c (deleted) * c/src/lib/libbsp/arm/gp32/startup/bspreset.c (deleted) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (deleted) * c/src/lib/libbsp/arm/gp32/startup/linkcmds (deleted) * c/src/lib/libbsp/arm/gp32/startup/memmap.c (deleted) arm/gp32: Remove updates #2451. Fri, 11 Dec 2015 23:21:26 GMT Aun-Ali Zaidi [c8a8a601] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/gba/Makefile.am (deleted) * c/src/lib/libbsp/arm/gba/README (deleted) * c/src/lib/libbsp/arm/gba/bsp_specs (deleted) * c/src/lib/libbsp/arm/gba/clock/clockdrv.c (deleted) * c/src/lib/libbsp/arm/gba/configure.ac (deleted) * c/src/lib/libbsp/arm/gba/console/conio.c (deleted) * c/src/lib/libbsp/arm/gba/console/console.c (deleted) * c/src/lib/libbsp/arm/gba/console/defaultfont.h (deleted) * c/src/lib/libbsp/arm/gba/include/arm_mode_bits.h (deleted) * c/src/lib/libbsp/arm/gba/include/asm_macros.h (deleted) * c/src/lib/libbsp/arm/gba/include/bsp.h (deleted) * c/src/lib/libbsp/arm/gba/include/conio.h (deleted) * c/src/lib/libbsp/arm/gba/include/gba.h (deleted) * c/src/lib/libbsp/arm/gba/include/gba_registers.h (deleted) * c/src/lib/libbsp/arm/gba/irq/irq.c (deleted) * c/src/lib/libbsp/arm/gba/irq/irq.h (deleted) * c/src/lib/libbsp/arm/gba/make/custom/gba.cfg (deleted) * c/src/lib/libbsp/arm/gba/preinstall.am (deleted) * c/src/lib/libbsp/arm/gba/start/logo.S (deleted) * c/src/lib/libbsp/arm/gba/start/start.S (deleted) * c/src/lib/libbsp/arm/gba/startup/bspgetworkarea.c (deleted) * c/src/lib/libbsp/arm/gba/startup/bspreset.c (deleted) * c/src/lib/libbsp/arm/gba/startup/bspstart.c (deleted) * c/src/lib/libbsp/arm/gba/startup/linkcmds (deleted) * c/src/lib/libbsp/arm/gba/timer/timer.c (deleted) arm/gba: Remove updates #2449. Fri, 11 Dec 2015 00:29:55 GMT Aun-Ali Zaidi [32c2cd2] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/nds/Makefile.am (deleted) * c/src/lib/libbsp/arm/nds/README (deleted) * c/src/lib/libbsp/arm/nds/block/block.c (deleted) * c/src/lib/libbsp/arm/nds/bsp_specs (deleted) * c/src/lib/libbsp/arm/nds/clock/clock.c (deleted) * c/src/lib/libbsp/arm/nds/configure.ac (deleted) * c/src/lib/libbsp/arm/nds/console/console.c (deleted) * c/src/lib/libbsp/arm/nds/coproc/coproc.S (deleted) * c/src/lib/libbsp/arm/nds/coproc/coproc.c (deleted) * c/src/lib/libbsp/arm/nds/coproc/coproc.ld (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm7/makefile (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm7/source/wifi_arm7.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm7/source/wifi_arm7.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/makefile (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ARP.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ARP.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Config.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DHCP.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DHCP.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DNS.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_DNS.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Hub.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_Hub.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ICMP.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_ICMP.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_IP.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_IP.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_TCP.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_TCP.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_UDP.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_UDP.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_memblock.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_memblock.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_sockets.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/sgIP_sockets.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.c (deleted) * c/src/lib/libbsp/arm/nds/dswifi/arm9/source/wifi_arm9.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/common/source/dsregs.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/common/source/spinlock.S (deleted) * c/src/lib/libbsp/arm/nds/dswifi/common/source/spinlock.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/common/source/wifi_shared.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/dswifi_license.txt (deleted) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi7.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi9.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/include/dswifi_version.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/include/netdb.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/include/netinet/in.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/include/sgIP_errno.h (deleted) * c/src/lib/libbsp/arm/nds/dswifi/makefile (deleted) * c/src/lib/libbsp/arm/nds/fb/fb.c (deleted) * c/src/lib/libbsp/arm/nds/include/bsp.h (deleted) * c/src/lib/libbsp/arm/nds/include/my_ipc.h (deleted) * c/src/lib/libbsp/arm/nds/include/sys/iosupport.h (deleted) * c/src/lib/libbsp/arm/nds/include/types.h (deleted) * c/src/lib/libbsp/arm/nds/irq/irq.c (deleted) * c/src/lib/libbsp/arm/nds/irq/irq.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/gba/include/fat.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/include/fat.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/nds/include/fat.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/bit_ops.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/cache.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/cache.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/common.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/directory.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/directory.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/disc_io.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_cf_common.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_cf_common.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_dldi.S (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_dldi.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_efa2.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_fcsr.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3_common.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3_common.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3cf.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_m3sd.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_mpcf.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_njsd.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_nmmc.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sc_common.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sc_common.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sccf.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_scsd_s.S (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sd_common.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/disc_io/io_sd_common.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/fatdir.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/fatdir.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/fatfile.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/fatfile.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/file_allocation_table.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/file_allocation_table.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/filetime.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/filetime.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/libfat.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/mem_allocate.h (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/partition.c (deleted) * c/src/lib/libbsp/arm/nds/libfat/source/partition.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/Makefile.arm7 (deleted) * c/src/lib/libbsp/arm/nds/libnds/Makefile.arm9 (deleted) * c/src/lib/libbsp/arm/nds/libnds/basicARM7/source/defaultARM7.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/default_font_bin.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/gbfs.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/audio.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/clock.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/serial.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm7/touch.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/background.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/boxtest.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/cache.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/console.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/exceptions.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/image.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/input.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/math.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/ndsmotion.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/pcx.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/postest.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/rumble.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/sound.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/sprite.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/trig_lut.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/video.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/arm9/videoGL.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/bios.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/card.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/dma.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/interrupts.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/ipc.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/jtypes.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/memory.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/registers_alt.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/reload.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/system.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/include/nds/timers.h (deleted) * c/src/lib/libbsp/arm/nds/libnds/libnds_license.txt (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/audio.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/clock.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/microphone.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/spi.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/touch.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm7/userSettings.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/COS.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/SIN.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/TAN.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/boxtest.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/console.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/dcache.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/default_font.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/exceptionHandler.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/exceptions.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/gurumeditation.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/icache.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/image.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/initSystem.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/keys.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/ndsmotion.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/pcx.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/rumble.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/sound.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/system.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/touch.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/video.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/arm9/videoGL.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/common/biosCalls.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/common/card.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/common/gbfs.c (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/common/interruptDispatcher.S (deleted) * c/src/lib/libbsp/arm/nds/libnds/source/common/interrupts.c (deleted) * c/src/lib/libbsp/arm/nds/make/custom/nds.cfg (deleted) * c/src/lib/libbsp/arm/nds/mk_libnds.sh (deleted) * c/src/lib/libbsp/arm/nds/patch.libnds (deleted) * c/src/lib/libbsp/arm/nds/preinstall.am (deleted) * c/src/lib/libbsp/arm/nds/rtc/rtc.c (deleted) * c/src/lib/libbsp/arm/nds/sound/sound.c (deleted) * c/src/lib/libbsp/arm/nds/sound/sound.h (deleted) * c/src/lib/libbsp/arm/nds/start/start.S (deleted) * c/src/lib/libbsp/arm/nds/startup/bspreset.c (deleted) * c/src/lib/libbsp/arm/nds/startup/bspstart.c (deleted) * c/src/lib/libbsp/arm/nds/startup/linkcmds (deleted) * c/src/lib/libbsp/arm/nds/timer/timer.c (deleted) * c/src/lib/libbsp/arm/nds/tools/Makefile.am (deleted) * c/src/lib/libbsp/arm/nds/tools/bin2s.c (deleted) * c/src/lib/libbsp/arm/nds/tools/configure.ac (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/arm7_sha1_homebrew.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/arm7_sha1_nintendo.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/banner.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/bigint.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/crc.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/default_icon.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/encryption.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/header.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/hook.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/little.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/loadme.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/logo.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndscreate.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndsextract.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndstool.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/ndstree.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/overlay.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/passme.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/passme_sram.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/passme_vhd1.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/passme_vhd2.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/raster.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/sha1.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/include/types.h (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/arm7_sha1_homebrew.c (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/arm7_sha1_nintendo.c (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/banner.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/bigint.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/compile_date.c (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/crc.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/default_icon.c (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/encryption.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/header.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/hook.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/loadme.c (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/logo.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndscodes.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndscreate.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndsextract.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndstool.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/ndstree.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/passme.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/passme_sram.c (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/raster.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/ndstool/source/sha1.cpp (deleted) * c/src/lib/libbsp/arm/nds/tools/runtest (deleted) * c/src/lib/libbsp/arm/nds/touchscreen/README.reco (deleted) * c/src/lib/libbsp/arm/nds/touchscreen/parser.c (deleted) * c/src/lib/libbsp/arm/nds/touchscreen/reco.c (deleted) * c/src/lib/libbsp/arm/nds/touchscreen/reco.h (deleted) * c/src/lib/libbsp/arm/nds/touchscreen/touchscreen.c (deleted) * c/src/lib/libbsp/arm/nds/touchscreen/touchscreen.h (deleted) * c/src/lib/libbsp/arm/nds/wifi/compat.c (deleted) * c/src/lib/libbsp/arm/nds/wifi/compat.h (deleted) * c/src/lib/libbsp/arm/nds/wifi/wifi.c (deleted) arm/nds: Remove updates #2450. Wed, 22 Aug 2012 12:39:02 GMT Claas Ziemke [7a66986] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/beagle/Makefile.am (added) * c/src/lib/libbsp/arm/beagle/README (added) * c/src/lib/libbsp/arm/beagle/bsp_specs (added) * c/src/lib/libbsp/arm/beagle/clock/beagle-clock-config.c (added) * c/src/lib/libbsp/arm/beagle/configure.ac (added) * c/src/lib/libbsp/arm/beagle/console/console-config.c (added) * c/src/lib/libbsp/arm/beagle/include/beagle-clock-config.h (added) * c/src/lib/libbsp/arm/beagle/include/beagle-timer.h (added) * c/src/lib/libbsp/arm/beagle/include/beagle.h (added) * c/src/lib/libbsp/arm/beagle/include/boot.h (added) * c/src/lib/libbsp/arm/beagle/include/bsp.h (added) * c/src/lib/libbsp/arm/beagle/include/i2c.h (added) * c/src/lib/libbsp/arm/beagle/include/irq.h (added) * c/src/lib/libbsp/arm/beagle/irq/irq.c (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagle.cfg (added) * c/src/lib/libbsp/arm/beagle/make/custom/beagle.inc (added) * c/src/lib/libbsp/arm/beagle/misc/boot.c (added) * c/src/lib/libbsp/arm/beagle/misc/i2c.c (added) * c/src/lib/libbsp/arm/beagle/misc/restart.c (added) * c/src/lib/libbsp/arm/beagle/misc/system-clocks.c (added) * c/src/lib/libbsp/arm/beagle/misc/timer.c (added) * c/src/lib/libbsp/arm/beagle/preinstall.am (added) * c/src/lib/libbsp/arm/beagle/rtc/rtc-config.c (added) * c/src/lib/libbsp/arm/beagle/simscripts/qemu-beagleboard.in (added) * c/src/lib/libbsp/arm/beagle/startup/bspreset.c (added) * c/src/lib/libbsp/arm/beagle/startup/bspstart.c (added) * c/src/lib/libbsp/arm/beagle/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/beagle/startup/linkcmds.beagle (added) Added BeagleBoard BSP Coding done in course of GSoC2012. Commit ... Wed, 20 Aug 2014 19:53:18 GMT Joel Sherrill [2ed97d9] * c/src/lib/libbsp/arm/acinclude.m4 (modified) libbsp/arm/acinclude.m4: Regenerate for tms570 Mon, 09 Jun 2014 14:27:18 GMT Martin Boretto [19260fb] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/lpc176x/Makefile.am (added) * c/src/lib/libbsp/arm/lpc176x/README (added) * c/src/lib/libbsp/arm/lpc176x/benchmark_timer/benchmark_timer.c (added) * c/src/lib/libbsp/arm/lpc176x/bsp_specs (added) * c/src/lib/libbsp/arm/lpc176x/configure.ac (added) * c/src/lib/libbsp/arm/lpc176x/console/console-config.c (added) * c/src/lib/libbsp/arm/lpc176x/gpio/gpio.c (added) * c/src/lib/libbsp/arm/lpc176x/include/bsp.h (added) * c/src/lib/libbsp/arm/lpc176x/include/common-types.h (added) * c/src/lib/libbsp/arm/lpc176x/include/dma.h (added) * c/src/lib/libbsp/arm/lpc176x/include/gpio-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/gpio.h (added) * c/src/lib/libbsp/arm/lpc176x/include/io-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/io.h (added) * c/src/lib/libbsp/arm/lpc176x/include/irq.h (added) * c/src/lib/libbsp/arm/lpc176x/include/lpc-clock-config.h (added) * c/src/lib/libbsp/arm/lpc176x/include/lpc176x.h (added) * c/src/lib/libbsp/arm/lpc176x/include/system-clocks.h (added) * c/src/lib/libbsp/arm/lpc176x/include/timer-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/timer.h (added) * c/src/lib/libbsp/arm/lpc176x/include/watchdog-defs.h (added) * c/src/lib/libbsp/arm/lpc176x/include/watchdog.h (added) * c/src/lib/libbsp/arm/lpc176x/irq/irq.c (added) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg (added) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed.cfg (added) * c/src/lib/libbsp/arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram.cfg (added) * c/src/lib/libbsp/arm/lpc176x/misc/bspidle.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/dma-copy.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/dma.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/io.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/restart.c (added) * c/src/lib/libbsp/arm/lpc176x/misc/system-clocks.c (added) * c/src/lib/libbsp/arm/lpc176x/preinstall.am (added) * c/src/lib/libbsp/arm/lpc176x/rtc/rtc-config.c (added) * c/src/lib/libbsp/arm/lpc176x/startup/bspreset.c (added) * c/src/lib/libbsp/arm/lpc176x/startup/bspstart.c (added) * c/src/lib/libbsp/arm/lpc176x/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed (added) * c/src/lib/libbsp/arm/lpc176x/startup/linkcmds.lpc1768_mbed_ahb_ram (added) * c/src/lib/libbsp/arm/lpc176x/timer/timer.c (added) * c/src/lib/libbsp/arm/lpc176x/watchdog/watchdog.c (added) bsp/lpc176x: New BSP Wed, 31 Jul 2013 07:45:59 GMT Ralf Kirchner [f73cfe99] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/altera-cyclone-v/Makefile.am (added) * c/src/lib/libbsp/arm/altera-cyclone-v/README (added) * c/src/lib/libbsp/arm/altera-cyclone-v/bsp_specs (added) * c/src/lib/libbsp/arm/altera-cyclone-v/configure.ac (added) * c/src/lib/libbsp/arm/altera-cyclone-v/console/console-config.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/include/bsp.h (added) * c/src/lib/libbsp/arm/altera-cyclone-v/include/irq.h (added) * c/src/lib/libbsp/arm/altera-cyclone-v/include/nocache-heap.h (added) * c/src/lib/libbsp/arm/altera-cyclone-v/include/tm27.h (added) * c/src/lib/libbsp/arm/altera-cyclone-v/make/custom/altcycv.inc (added) * c/src/lib/libbsp/arm/altera-cyclone-v/make/custom/altcycv_devkit.cfg (added) * c/src/lib/libbsp/arm/altera-cyclone-v/make/custom/altcycv_devkit_smp.cfg (added) * c/src/lib/libbsp/arm/altera-cyclone-v/network/network.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/preinstall.am (added) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspreset.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstart.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv (added) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv_devkit (added) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/linkcmds.altcycv_devkit_smp (added) * c/src/lib/libbsp/arm/altera-cyclone-v/startup/nocache-heap.c (added) bsp/altera-cyclone-v: New BSP Implemented so far: - nocache heap ... Mon, 06 May 2013 12:34:55 GMT Sebastian Huber [a94d46c8] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/xilinx-zynq/Makefile.am (added) * c/src/lib/libbsp/arm/xilinx-zynq/README (added) * c/src/lib/libbsp/arm/xilinx-zynq/bsp_specs (added) * c/src/lib/libbsp/arm/xilinx-zynq/configure.ac (added) * c/src/lib/libbsp/arm/xilinx-zynq/console/console-config.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/console/zynq-uart.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/bsp.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/irq.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/tm27.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart-regs.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/include/zynq-uart.h (added) * c/src/lib/libbsp/arm/xilinx-zynq/make/custom/xilinx_zynq_a9_qemu.cfg (added) * c/src/lib/libbsp/arm/xilinx-zynq/preinstall.am (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspreset.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstart.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/xilinx-zynq/startup/linkcmds (added) bsp/xilinx-zynq: New BSP Fri, 26 Apr 2013 13:06:32 GMT Sebastian Huber [a91dc98b] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/realview-pbx-a9/Makefile.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/README (added) * c/src/lib/libbsp/arm/realview-pbx-a9/bsp_specs (added) * c/src/lib/libbsp/arm/realview-pbx-a9/configure.ac (added) * c/src/lib/libbsp/arm/realview-pbx-a9/console/console-config.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/bsp.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/irq.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/include/tm27.h (added) * c/src/lib/libbsp/arm/realview-pbx-a9/make/custom/realview_pbx_a9_qemu.cfg (added) * c/src/lib/libbsp/arm/realview-pbx-a9/preinstall.am (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspreset.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstart.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/realview-pbx-a9/startup/linkcmds (added) * c/src/lib/libbsp/arm/shared/arm-a9mpcore-clock-config.c (added) * c/src/lib/libbsp/arm/shared/arm-gic-irq.c (added) * c/src/lib/libbsp/arm/shared/arm-pl011.c (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-a9mpcore-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-irq.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-gic.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011-regs.h (added) * c/src/lib/libbsp/arm/shared/include/arm-pl011.h (added) bsp/realview-pbx-a9: New BSP Sat, 23 Mar 2013 18:13:07 GMT Alan Cudmore [c32b1ef] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/raspberrypi/Makefile.am (added) * c/src/lib/libbsp/arm/raspberrypi/README (added) * c/src/lib/libbsp/arm/raspberrypi/bsp_specs (added) * c/src/lib/libbsp/arm/raspberrypi/clock/clockdrv.c (added) * c/src/lib/libbsp/arm/raspberrypi/configure.ac (added) * c/src/lib/libbsp/arm/raspberrypi/console/console-config.c (added) * c/src/lib/libbsp/arm/raspberrypi/console/usart.c (added) * c/src/lib/libbsp/arm/raspberrypi/include/bsp.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/irq.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/mmu.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h (added) * c/src/lib/libbsp/arm/raspberrypi/include/usart.h (added) * c/src/lib/libbsp/arm/raspberrypi/irq/irq.c (added) * c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg (added) * c/src/lib/libbsp/arm/raspberrypi/misc/timer.c (added) * c/src/lib/libbsp/arm/raspberrypi/preinstall.am (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspreset.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/raspberrypi/startup/linkcmds (added) bsp/raspberrypi: New BSP Thu, 29 Mar 2012 19:23:14 GMT Sebastian Huber [e230fb4] * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/stm32f4/Makefile.am (added) * c/src/lib/libbsp/arm/stm32f4/README (added) * c/src/lib/libbsp/arm/stm32f4/bsp_specs (added) * c/src/lib/libbsp/arm/stm32f4/configure.ac (added) * c/src/lib/libbsp/arm/stm32f4/console/console-config.c (added) * c/src/lib/libbsp/arm/stm32f4/console/usart.c (added) * c/src/lib/libbsp/arm/stm32f4/include/bsp.h (added) * c/src/lib/libbsp/arm/stm32f4/include/irq.h (added) * c/src/lib/libbsp/arm/stm32f4/include/stm32f4.h (added) * c/src/lib/libbsp/arm/stm32f4/include/usart.h (added) * c/src/lib/libbsp/arm/stm32f4/make/custom/stm32f4.cfg (added) * c/src/lib/libbsp/arm/stm32f4/preinstall.am (added) * c/src/lib/libbsp/arm/stm32f4/startup/bspreset.c (added) * c/src/lib/libbsp/arm/stm32f4/startup/bspstart.c (added) * c/src/lib/libbsp/arm/stm32f4/startup/bspstarthook.c (added) * c/src/lib/libbsp/arm/stm32f4/startup/linkcmds.stm32f4 (added) bsp/stm32f4: New BSP Sat, 24 Sep 2011 13:25:45 GMT Sebastian Huber [8f21cc0] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2011-09-24 Sebastian Huber ... Tue, 15 Dec 2009 15:20:47 GMT Thomas Doerfler [c468f18b] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/lpc24xx/ChangeLog (modified) * c/src/lib/libbsp/arm/lpc24xx/Makefile.am (modified) * c/src/lib/libbsp/arm/lpc24xx/configure.ac (modified) * c/src/lib/libbsp/arm/lpc24xx/console/console-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/i2c/i2c.c (modified) * c/src/lib/libbsp/arm/lpc24xx/include/bsp.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/io.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/irq.h (modified) * c/src/lib/libbsp/arm/lpc24xx/include/lpc24xx.h (modified) * c/src/lib/libbsp/arm/lpc24xx/irq/irq.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/dma.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/io.c (modified) * c/src/lib/libbsp/arm/lpc24xx/misc/timer.c (modified) * c/src/lib/libbsp/arm/lpc24xx/network/network.c (modified) * c/src/lib/libbsp/arm/lpc24xx/preinstall.am (modified) * c/src/lib/libbsp/arm/lpc24xx/rtc/rtc-config.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspreset.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstart.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/bspstarthooks.c (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ea (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_ram (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_ext (modified) * c/src/lib/libbsp/arm/lpc24xx/startup/linkcmds.lpc24xx_ncs_rom_int (modified) * c/src/lib/libbsp/arm/lpc32xx/.cvsignore (added) * c/src/lib/libbsp/arm/lpc32xx/ChangeLog (added) * c/src/lib/libbsp/arm/lpc32xx/Makefile.am (added) * c/src/lib/libbsp/arm/lpc32xx/README (added) * c/src/lib/libbsp/arm/lpc32xx/bsp_specs (added) * c/src/lib/libbsp/arm/lpc32xx/configure.ac (added) * c/src/lib/libbsp/arm/lpc32xx/console/console-config.c (added) * c/src/lib/libbsp/arm/lpc32xx/include/bsp.h (added) * c/src/lib/libbsp/arm/lpc32xx/include/bspopts.h.in (added) * c/src/lib/libbsp/arm/lpc32xx/include/irq-config.h (added) * c/src/lib/libbsp/arm/lpc32xx/include/irq.h (added) * c/src/lib/libbsp/arm/lpc32xx/include/lpc-clock-config.h (added) * c/src/lib/libbsp/arm/lpc32xx/include/lpc32xx.h (added) * c/src/lib/libbsp/arm/lpc32xx/irq/irq.c (added) * c/src/lib/libbsp/arm/lpc32xx/make/custom/lpc32xx_phycore.cfg (added) * c/src/lib/libbsp/arm/lpc32xx/misc/timer.c (added) * c/src/lib/libbsp/arm/lpc32xx/preinstall.am (added) * c/src/lib/libbsp/arm/lpc32xx/rtc/rtc-config.c (added) * c/src/lib/libbsp/arm/lpc32xx/startup/bspreset.c (added) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstart.c (added) * c/src/lib/libbsp/arm/lpc32xx/startup/bspstarthooks.c (added) * c/src/lib/libbsp/arm/lpc32xx/startup/linkcmds.lpc32xx_phycore (added) * c/src/lib/libbsp/arm/shared/include/linker-symbols.h (modified) * c/src/lib/libbsp/arm/shared/lpc/clock/lpc-clock-config.c (added) * c/src/lib/libbsp/arm/shared/lpc/include/lpc-timer.h (added) add support for LPC32xx Thu, 01 Oct 2009 21:48:53 GMT Joel Sherrill [880d394] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2009-10-01 Joel Sherrill * ... Thu, 04 Jun 2009 16:24:00 GMT Joel Sherrill [d2884e6] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2009-06-04 Xi Yang * ... Tue, 23 Sep 2008 14:07:42 GMT Joel Sherrill [8a6c480] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2008-09-23 Joel Sherrill * ... Mon, 22 Sep 2008 21:49:32 GMT Joel Sherrill [d4f6b30] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/shared/comm/console.c (modified) 2008-09-22 Joel Sherrill * ... Mon, 22 Sep 2008 11:28:39 GMT Thomas Doerfler [16d56686] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) lpc24xx: New BSP shared/startup/linkcmds.base, ... Tue, 06 May 2008 21:03:02 GMT Joel Sherrill [17fbf03b] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2008-05-06 Ray Xu * acinclude.m4: ... Wed, 16 Apr 2008 18:38:04 GMT Joel Sherrill [34dd9782] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2008-04-16 Matthieu Bucchianeri * ... Wed, 13 Jun 2007 19:46:11 GMT Joel Sherrill [58515e7] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2007-06-13 Joel Sherrill * ... Wed, 25 Apr 2007 13:04:37 GMT Ralf Corsepius [3544296] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2007-04-25 Ralf Corsépius * ... Wed, 06 Jul 2005 18:46:41 GMT Joel Sherrill [2732040d] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2005-07-06 Markku Puro * ... Fri, 11 Mar 2005 08:23:28 GMT Jay Monkman [3b9564a] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/vegaplus/.cvsignore (deleted) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (deleted) * c/src/lib/libbsp/arm/vegaplus/Makefile.am (deleted) * c/src/lib/libbsp/arm/vegaplus/bsp_specs (deleted) * c/src/lib/libbsp/arm/vegaplus/clock/clockdrv.c (deleted) * c/src/lib/libbsp/arm/vegaplus/configure.ac (deleted) * c/src/lib/libbsp/arm/vegaplus/include/.cvsignore (deleted) * c/src/lib/libbsp/arm/vegaplus/include/bsp.h (deleted) * c/src/lib/libbsp/arm/vegaplus/include/registers.h (deleted) * c/src/lib/libbsp/arm/vegaplus/include/tm27.h (deleted) * c/src/lib/libbsp/arm/vegaplus/irq/bsp_irq_asm.S (deleted) * c/src/lib/libbsp/arm/vegaplus/irq/bsp_irq_init.c (deleted) * c/src/lib/libbsp/arm/vegaplus/irq/irq.c (deleted) * c/src/lib/libbsp/arm/vegaplus/irq/irq.h (deleted) * c/src/lib/libbsp/arm/vegaplus/start/start.S (deleted) * c/src/lib/libbsp/arm/vegaplus/startup/bspstart.c (deleted) * c/src/lib/libbsp/arm/vegaplus/startup/exit.c (deleted) * c/src/lib/libbsp/arm/vegaplus/startup/linkcmds (deleted) 2005-03-11 Jay Monkman * ... Fri, 11 Mar 2005 07:27:56 GMT Jay Monkman [e8c785c6] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/gp32/.cvsignore (added) * c/src/lib/libbsp/arm/gp32/Makefile.am (added) * c/src/lib/libbsp/arm/gp32/README (added) * c/src/lib/libbsp/arm/gp32/bsp_specs (added) * c/src/lib/libbsp/arm/gp32/configure.ac (added) * c/src/lib/libbsp/arm/gp32/console/.cvsignore (added) * c/src/lib/libbsp/arm/gp32/console/conio.c (added) * c/src/lib/libbsp/arm/gp32/console/console.c (added) * c/src/lib/libbsp/arm/gp32/console/defaultfont.c (added) * c/src/lib/libbsp/arm/gp32/include/.cvsignore (added) * c/src/lib/libbsp/arm/gp32/include/bsp.h (added) * c/src/lib/libbsp/arm/gp32/include/conio.h (added) * c/src/lib/libbsp/arm/gp32/include/tm27.h (added) * c/src/lib/libbsp/arm/gp32/start/.cvsignore (added) * c/src/lib/libbsp/arm/gp32/start/start.S (added) * c/src/lib/libbsp/arm/gp32/startup/.cvsignore (added) * c/src/lib/libbsp/arm/gp32/startup/bspstart.c (added) * c/src/lib/libbsp/arm/gp32/startup/exit.c (added) * c/src/lib/libbsp/arm/gp32/startup/linkcmds (added) * c/src/lib/libbsp/arm/gp32/startup/memmap.c (added) 2005-03-11 Philippe Simons * ... Thu, 03 Mar 2005 10:42:14 GMT Ralf Corsepius [9b20008] * c/src/lib/libbsp/arm/acinclude.m4 (modified) arm_bare_bsp Thu, 15 Jul 2004 06:17:47 GMT Jay Monkman [3e8f70a] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2004-07-15 Jay Monkman * acinclude.m4: Added csb336 ... Thu, 12 Feb 2004 16:37:03 GMT Ralf Corsepius [717a34e9] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/acinclude.m4 (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/acinclude.m4 (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/acinclude.m4 (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/acinclude.m4 (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/acinclude.m4 (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/acinclude.m4 (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/acinclude.m4 (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/acinclude.m4 (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/acinclude.m4 (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/acinclude.m4 (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/acinclude.m4 (modified) 2004-02-12 Ralf Corsepius * ... Mon, 20 Oct 2003 13:39:41 GMT Ralf Corsepius [43e60f8] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/acinclude.m4 (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/acinclude.m4 (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/acinclude.m4 (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/acinclude.m4 (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/acinclude.m4 (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/acinclude.m4 (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/acinclude.m4 (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/acinclude.m4 (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/acinclude.m4 (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/acinclude.m4 (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/acinclude.m4 (modified) * c/src/lib/libbsp/unix/configure.ac (modified) 2003-10-20 Ralf Corsepius * ... Wed, 13 Nov 2002 17:56:19 GMT Joel Sherrill [673c750] * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/acinclude.m4 (modified) 2002-11-13 Jay Monkman * ... Wed, 10 Oct 2001 00:25:36 GMT Joel Sherrill [949b619] * c/src/lib/libbsp/a29k/acinclude.m4 (added) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/arm/acinclude.m4 (added) * c/src/lib/libbsp/arm/configure.in (modified) * c/src/lib/libbsp/c4x/acinclude.m4 (added) * c/src/lib/libbsp/c4x/configure.in (modified) * c/src/lib/libbsp/h8300/acinclude.m4 (added) * c/src/lib/libbsp/h8300/configure.in (modified) * c/src/lib/libbsp/hppa1.1/acinclude.m4 (added) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/i386/acinclude.m4 (added) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i960/acinclude.m4 (added) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/m68k/acinclude.m4 (added) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/mips/acinclude.m4 (added) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips64orion/acinclude.m4 (added) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/no_cpu/acinclude.m4 (added) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/powerpc/acinclude.m4 (added) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/sh/acinclude.m4 (added) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sparc/acinclude.m4 (added) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/unix/acinclude.m4 (added) * c/src/lib/libbsp/unix/configure.in (modified) 2001-10-09 Ralf Corsepius * ...
