@de45ddc
08/15/96 16:29:00 |
Mark.Johannes |
pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO
4.104.114.84.95
@948721c
08/15/96 16:24:44 |
Mark.Johannes |
pthread_kill: moved check for SA_SIGINFO to allow for validation of …
4.104.114.84.95
@48e685c
08/15/96 16:22:59 |
Mark.Johannes |
fixed typo for NOTSUP -> ENOTSUP
4.104.114.84.95
@4e63ae5
08/14/96 17:20:45 |
Mark.Johannes |
commented of ENOTSUP until fixed in newlib
4.104.114.84.95
@aae1c932
08/14/96 17:20:03 |
Mark.Johannes |
pthread_cond_timedwait: added error cases for abstime
4.104.114.84.95
@dce801d
08/13/96 21:32:49 |
Mark.Johannes |
pthread_cond_destroy: added enable dispatch to EBUSY case
4.104.114.84.95
@95b76bc
08/13/96 21:10:06 |
Mark.Johannes |
pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First
4.104.114.84.95
@456b3769
08/13/96 20:50:54 |
Mark.Johannes |
pthread_cond_destroy: EBUSY case now uses Thread_queue_First
4.104.114.84.95
@c53eb2c3
08/13/96 20:46:10 |
Mark.Johannes |
removed count from Thread_queue_Control
4.104.114.84.95
@a66fcc5
08/13/96 20:43:51 |
Mark.Johannes |
removed Thread_queue_Get_number_waiting
4.104.114.84.95
@392b35e
08/13/96 20:38:30 |
Joel Sherrill |
deleted a line for spacing correction
4.104.114.84.95
@48b40d8
08/13/96 19:53:51 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: changed status of lock and …
4.104.114.84.95
@76f03c6
08/13/96 19:03:29 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: fixed the timeout sequence.
4.104.114.84.95
@b2e8026
08/13/96 15:43:12 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@f48c9068
08/13/96 14:24:00 |
Joel Sherrill |
removed errors for TOD not set yet.
made nanosleep return -1/EINTR …
4.104.114.84.95
@aac34f7b
08/13/96 14:23:16 |
Joel Sherrill |
added page break before sysconf()
4.104.114.84.95
@1087564
08/12/96 20:59:41 |
Joel Sherrill |
clock_getres: added error check for NULL pointer being passed in.
4.104.114.84.95
@3fbfbcd
08/12/96 20:48:13 |
Joel Sherrill |
sleep: wrong page number
4.104.114.84.95
@702a31c
08/12/96 20:08:36 |
Joel Sherrill |
removed comment about NO_UNINITIALIZED_WARNINGS since that macro
no …
4.104.114.84.95
@5f08fd6
08/12/96 19:55:09 |
Joel Sherrill |
nanosleep: verify rqtp parameter is non-NULL.
nanosleep: return 0 …
4.104.114.84.95
@40cfab47
08/12/96 19:19:03 |
Joel Sherrill |
time: It is not an error if the TOD is not set.
4.104.114.84.95
@9b77fee
08/12/96 19:00:12 |
Mark.Johannes |
Wait_support: removed the calls to mutex core to posix status codes
4.104.114.84.95
@3b97b7a0
08/12/96 18:58:12 |
Mark.Johannes |
mutex.h: removes the promotion of core status code to POSXI status codes
4.104.114.84.95
@1402ee25
08/12/96 18:56:04 |
Joel Sherrill |
fixed spacing ; moved a dummy MP support routine to clean up printout.
4.104.114.84.95
@c7a9c66
08/12/96 18:06:27 |
Joel Sherrill |
_POSIX_Mutex_Get: made null id an error
4.104.114.84.95
@ccdf4c57
08/12/96 18:05:47 |
Joel Sherrill |
pthread_mutex_getprioceiling: added error check for null old_ceiling
4.104.114.84.95
@b1af454
08/12/96 17:41:37 |
Mark.Johannes |
mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status
4.104.114.84.95
@af04a791
08/12/96 17:40:56 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: added …
4.104.114.84.95
@cdcea6ce
08/12/96 17:21:04 |
Mark.Johannes |
_POSIX_Condition_variables_Signal_support: added setting mutex back to …
4.104.114.84.95
@f126ae2
08/12/96 17:04:13 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: fixed typo
4.104.114.84.95
@db8e9011
08/12/96 17:02:39 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: valid priority ceiling check looked …
4.104.114.84.95
@684c3c4
08/12/96 16:29:14 |
Joel Sherrill |
pthread_mutexattr_getprotocol: added check for attribute structure …
4.104.114.84.95
@b9444fb9
08/09/96 19:58:58 |
Joel Sherrill |
added code to catch NULL pointers for return values passed to get routines
4.104.114.84.95
@8699a70
08/09/96 18:45:10 |
Joel Sherrill |
sched_yield: was not invoking the dispatcher.
4.104.114.84.95
@d858fdb
08/09/96 17:30:13 |
Joel Sherrill |
merged remote object id and invalid id error cases.
4.104.114.84.95
@2a9a479
08/08/96 18:27:11 |
Mark.Johannes |
CORE_mutex_Status: added CORE_MUTEX_STATUS_CEILING_VIOLATED to enum
4.104.114.84.95
@567ac45
08/08/96 18:24:29 |
Mark.Johannes |
_POSIX_signals_Clear_signals: added this routine …
4.104.114.84.95
@66e519c1
08/08/96 16:52:24 |
Joel Sherrill |
ERC32_Force_interrupt implementation replaced per Jiri Gaisler's …
4.104.114.84.95
@f55d898
08/08/96 16:51:14 |
Joel Sherrill |
added ss_high_priority field to support sporadic server.
4.104.114.84.95
@b67f5bfb
08/08/96 12:35:20 |
Mark.Johannes |
_MPCI_Register_packet_processor: changed protoype first parameter type …
4.104.114.84.95
@6b722e2
08/08/96 12:32:50 |
Mark.Johannes |
_MPCI_Register_packet_processor: Changed prototype of fist parameter …
4.104.114.84.95
@3fd3da4
08/08/96 12:31:01 |
Mark.Johannes |
_MPCI_Register_packet_processor: changes first parameter type to …
4.104.114.84.95
@2014063
08/07/96 22:06:08 |
Joel Sherrill |
sporadic server debugged and working. This required minor changes in …
4.104.114.84.95
@a14684c3
08/07/96 20:58:59 |
Mark.Johannes |
_POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case
4.104.114.84.95
@cc757fe
08/07/96 20:57:28 |
Mark.Johannes |
_CORE_Mutex_seize: added checks for priority ceiling violation, also …
4.104.114.84.95
@4bab8e2d
08/06/96 17:45:12 |
Joel Sherrill |
get_errno: no longer needed by gnat runtime
4.104.114.84.95
@0f99198
08/06/96 16:26:11 |
Mark.Johannes |
_CORE_mutex_Seize: added change priority case if the mutex was obtained.
4.104.114.84.95
@a61f1a46
08/06/96 16:24:41 |
Joel Sherrill |
_POSIX_Threads_Delete_extension: reorder to eliminate use of local …
4.104.114.84.95
@06883e13
08/06/96 16:24:06 |
Mark.Johannes |
POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority
4.104.114.84.95
@b521ae2
08/06/96 16:23:09 |
Joel Sherrill |
pthread_getspecific: use local variable so references to tcb are …
4.104.114.84.95
@22b4b2e
08/01/96 19:24:57 |
Joel Sherrill |
added page delimiters for comment blocks
4.104.114.84.95
@16bae52
08/01/96 15:06:00 |
Joel Sherrill |
added 3 nops following write to wim since a restore following it is …
4.104.114.84.95
@adae080a
07/15/96 14:02:14 |
Mark.Johannes |
Fixed default vectors initialization, sigaction which had a redundant …
4.104.114.84.95
@69c9543
07/04/96 18:09:23 |
Joel Sherrill |
basic test cases passed
4.104.114.84.95
@e21cf313
07/03/96 14:24:07 |
Joel Sherrill |
another attempt at the rtems_posix_api ifdef
4.104.114.84.95
@503dc058
07/03/96 14:20:03 |
Joel Sherrill |
switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"
4.104.114.84.95
@5fc0dc1
07/03/96 14:19:09 |
Joel Sherrill |
changed version
4.104.114.84.95
@df8d1440
07/02/96 18:13:59 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@8d7a1d76
06/18/96 19:06:58 |
Joel Sherrill |
minor changes to insure the few posix-ish routines needed in non-posix …
4.104.114.84.95
@108ef35
06/15/96 19:55:39 |
Joel Sherrill |
initial modifications to support sigtimedwait.
4.104.114.84.95
@7f13a932
06/14/96 15:49:31 |
Joel Sherrill |
fields for init threads stuff said tasks.
4.104.114.84.95
@9e28da4
06/13/96 22:16:47 |
Mark.Johannes |
sigtimedwait passes initial test cases of timeout and simple satisfaction.
4.104.114.84.95
@4334949
06/13/96 21:01:21 |
Mark.Johannes |
added maximum_queued_signals to _POSIX_Default_configuration
4.104.114.84.95
@eb0551f
06/13/96 20:47:31 |
Joel Sherrill |
added posix configuration parameter maximum_queued_signals.
4.104.114.84.95
@3a075f5
06/13/96 20:46:43 |
Joel Sherrill |
now passing maximum_queued_signals to posix signals manager initialization
4.104.114.84.95
@c53cfd0f
06/13/96 20:46:15 |
Joel Sherrill |
added queued signals and cleaned up setting of process wide signals so …
4.104.114.84.95
@25a882a6
06/13/96 20:45:38 |
Joel Sherrill |
config.h: added maximum_queued_signals.
psignal.h: fixed typo.
4.104.114.84.95
@1b17790c
06/13/96 16:43:39 |
Joel Sherrill |
Added code so post context switch extensions can be run on every …
4.104.114.84.95
@e89f8cac
06/13/96 16:42:51 |
Joel Sherrill |
Added include so _POSIX_signals_Manager_initialization is prototyped.
4.104.114.84.95
@b85649c4
06/13/96 16:42:21 |
Joel Sherrill |
basic test cases for kill() and alarm().
kill() in particular needs …
4.104.114.84.95
@7fc3029
06/13/96 16:39:28 |
Joel Sherrill |
added prototype for manager initialization routine.
4.104.114.84.95
@da4b6e8
06/12/96 22:50:03 |
Joel Sherrill |
use exit() from newlib by default.
4.104.114.84.95
@2e0ebd11
06/12/96 22:49:33 |
Joel Sherrill |
added initialization of posix signal manager.
4.104.114.84.95
@281ad52
06/12/96 22:49:14 |
Joel Sherrill |
basic kill() which send a signal to pthread_self() appears to work.
4.104.114.84.95
@4a1bc34b
06/12/96 17:45:34 |
Joel Sherrill |
added waiting for signal state.
4.104.114.84.95
@2291b71
06/12/96 17:45:01 |
Joel Sherrill |
initial implementation of blocking signal routines -- sigwait, …
4.104.114.84.95
@937808f5
06/11/96 22:55:39 |
Joel Sherrill |
added comment to make sure we add unblock of thread
4.104.114.84.95
@ea1a5bef
06/11/96 22:52:42 |
Joel Sherrill |
first attempt at adding algorithm to select the thread which will …
4.104.114.84.95
@20d099e
06/11/96 22:51:59 |
Joel Sherrill |
deleted field for signals_global_pending.
4.104.114.84.95
@c8f5ab5
06/11/96 20:43:55 |
Joel Sherrill |
tested blocking a signal, sending it to self, then unblocking it.
4.104.114.84.95
@12aeff91
06/11/96 16:03:15 |
Joel Sherrill |
Interruptible by signals state was added to the STATES_BLOCKED set. …
4.104.114.84.95
@98ed15e
06/11/96 16:01:37 |
Joel Sherrill |
Basic signal functionality appears to work. pthread_kill() can …
4.104.114.84.95
@d0baf81
06/11/96 16:00:06 |
Joel Sherrill |
new file.
4.104.114.84.95
@494740c
06/10/96 21:04:14 |
Joel Sherrill |
added psignal.h
4.104.114.84.95
@0f63c86
06/10/96 20:47:56 |
Joel Sherrill |
added code to _Thread_Clear_state to check if the state was not …
4.104.114.84.95
@fdec30b
06/10/96 20:47:23 |
Joel Sherrill |
first attempt at the routine which vectors signals.
4.104.114.84.95
@d03f192
06/10/96 20:46:36 |
Joel Sherrill |
4.104.114.84.95
@81daab3
06/07/96 15:22:19 |
Joel Sherrill |
added states for "join at exit" and "interruptible by signal"
4.104.114.84.95
@05ce4e09
06/07/96 15:21:27 |
Joel Sherrill |
changed code which set errno and then returned -1 to use the macro …
4.104.114.84.95
@fa03f08
06/07/96 15:20:55 |
Joel Sherrill |
new file
4.104.114.84.95
@895efd9
06/07/96 13:54:23 |
Joel Sherrill |
key destructor is now run at correct point in pthread_exit() sequence …
4.104.114.84.95
@fce2e9d
06/06/96 21:27:33 |
Joel Sherrill |
in newlib now
4.104.114.84.95
@782bdfd
06/06/96 19:09:27 |
Joel Sherrill |
Removed assert's from routines which return the error ENOSYS.
4.104.114.84.95
@09b1f1a
06/06/96 17:57:39 |
Joel Sherrill |
patch from Tony Bennett on the ifdef for O_NDELAY
4.104.114.84.95
@e754dd1d
06/06/96 17:54:37 |
Joel Sherrill |
process oriented scheduler routines now return ENOSYS
4.104.114.84.95
@5d9cb7e
06/06/96 17:24:44 |
Joel Sherrill |
removed timer_getoverrun() since it was also in ptimer.c
4.104.114.84.95
@0207c55
06/06/96 15:36:18 |
Joel Sherrill |
Made the implementation of pthread_equal conditional on RTEMS_DEBUG. …
4.104.114.84.95
@65a5c1b
06/06/96 15:32:49 |
Joel Sherrill |
completed pthread_setschedparam.
4.104.114.84.95
@ebd40c0
06/06/96 14:55:08 |
Joel Sherrill |
Added Sporadic Server support to posix threads which required changes …
4.104.114.84.95
@2f200c7
06/06/96 14:55:01 |
Joel Sherrill |
4.104.114.84.95
