@d058ce2
07/06/00 19:39:20 |
Joel Sherrill |
Added _Semaphore_Get_interrupt_disable.
4.104.114.84.95
@ab654be
07/06/00 19:35:44 |
Joel Sherrill |
Cleaned up to avoid disruptive use of inline conditionals.
4.104.114.84.95
@1b7e8c51
07/06/00 19:34:49 |
Joel Sherrill |
Switched to using _POSIX_Mutex_Get_interrupt_disable to improve …
4.104.114.84.95
@3ef54dc
07/06/00 19:33:52 |
Joel Sherrill |
Added support for converting a mutex id to a pointer and returning …
4.104.114.84.95
@21e2b2b
07/06/00 19:32:00 |
Joel Sherrill |
Reimplemented _Core_MUTEX_Seize to return with interrupts disabled
if …
4.104.114.84.95
@8d5b438b
07/06/00 19:27:03 |
Joel Sherrill |
Added _CORE_semaphore_Seize_isr_disable.
4.104.114.84.95
@c6f111b
07/06/00 19:14:34 |
Joel Sherrill |
Added _Objects_Get_isr_disable prototype and added numerous comments.
4.104.114.84.95
@1d9403a
07/06/00 19:13:31 |
Joel Sherrill |
Removed unnecessary parentheses.
4.104.114.84.95
@8a3278fc
07/06/00 19:11:15 |
Joel Sherrill |
Added objjectgetbyisr.c
4.104.114.84.95
@12aeaec6
07/06/00 19:10:30 |
Joel Sherrill |
The code that attempts to obtain a mutex has now been inlined. The …
4.104.114.84.95
@3b4413c0
07/06/00 19:09:27 |
Joel Sherrill |
Directly index local table to avoid error check.
4.104.114.84.95
@d895fe8
07/06/00 19:06:59 |
Joel Sherrill |
New file. Convert ID to pointer and return with interrupts -- not …
4.104.114.84.95
@42ed3004
07/06/00 19:01:58 |
Joel Sherrill |
Format of return line changed.
4.104.114.84.95
@8bc62aeb
07/03/00 18:44:12 |
Joel Sherrill |
Interrupt stack is allocated in _ISR_Handler_initialization not …
4.104.114.84.95
@0147d5e
07/03/00 15:49:58 |
Joel Sherrill |
Added blocked_count field to allow for optimizations.
4.104.114.84.95
@feb93ede
07/03/00 15:49:35 |
Joel Sherrill |
Changed extra_system_initialization_stack to …
4.104.114.84.95
@3af0828
07/02/00 12:29:47 |
Joel Sherrill |
Fixed stat_ino should be st_ino.
4.104.114.84.95
@068b6473
06/30/00 12:36:32 |
Joel Sherrill |
Patch from Chris Johns <cjohns@…> so the directory
read …
4.104.114.84.95
@e5d6705e
06/30/00 12:33:13 |
Joel Sherrill |
Patch from Chris Johns <cjohns@…> to add support for …
4.104.114.84.95
@195ae7ba
06/30/00 12:31:28 |
Joel Sherrill |
Patch from Chris Johns <cjohns@…> to add fchdir() …
4.104.114.84.95
@5532553
06/29/00 23:00:48 |
Joel Sherrill |
This is the initial addition of the port of RTEMS to the
Hitachi H8 …
4.104.114.84.95
@bbc38ba
06/29/00 22:35:17 |
Joel Sherrill |
Added H8 as IEEE whether this is true or not.
4.104.114.84.95
@63db533
06/29/00 22:34:55 |
Joel Sherrill |
Disabled #ident since the h8300-rtems binutils do not like the …
4.104.114.84.95
@09a6eba
06/29/00 22:34:30 |
Joel Sherrill |
Corrected prototype for xdrrec_endofrecord to match C body.
4.104.114.84.95
@6f6ddc00
06/29/00 22:33:05 |
Joel Sherrill |
Added RTEMS_CPU_HAS_16_BIT_ADDRESSES constant to disable code
that …
4.104.114.84.95
@9b6d173
06/29/00 16:05:15 |
Joel Sherrill |
Patch from Chris Johns <cjohns@…> to make sure the …
4.104.114.84.95
@e42a135
06/26/00 14:49:58 |
Joel Sherrill |
Patch from Chris Johns <cjohns@…> and
Jennifer Averett …
4.104.114.84.95
@5e0e012c
06/26/00 14:46:19 |
Joel Sherrill |
Jennifer Averett …
4.104.114.84.95
@ae9c16c
06/16/00 19:55:03 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…> to correct style of
names …
4.104.114.84.95
@d1716c98
06/15/00 22:02:28 |
Joel Sherrill |
Remove pragma align 4
4.104.114.84.95
@a3726b1
06/15/00 19:40:34 |
Joel Sherrill |
Fixing warning obtained by some users.
4.104.114.84.95
@2b409223
06/15/00 13:06:36 |
Joel Sherrill |
Patch rtems-rc-20000615-1-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@73e1db9
06/15/00 12:58:24 |
Joel Sherrill |
Moved <sys/cdefs.h> to lib/include so non-networking applications …
4.104.114.84.95
@730daa6
06/14/00 21:13:20 |
Joel Sherrill |
Moved <sys/cdefs.h> from libnetworking to lib/include so …
4.104.114.84.95
@9b05600
06/14/00 20:22:31 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@07f0442
06/14/00 20:21:51 |
Joel Sherrill |
Added include of options.h since it was not being picked up
by the …
4.104.114.84.95
@6f93bb4
06/14/00 17:18:18 |
Joel Sherrill |
Patch from Chris Johns <cjohns@…> to enhance network …
4.104.114.84.95
@ac815430
06/14/00 17:07:54 |
Joel Sherrill |
Patch rtems-rc-20000614-sh.tar.gz from Ralf Corsepius …
4.104.114.84.95
@61bd0301
06/14/00 15:52:24 |
Joel Sherrill |
Moved PowerPC cache management code to libcpu. Also compiled
mpc8xx …
4.104.114.84.95
@fdcb2b52
06/14/00 13:38:47 |
Joel Sherrill |
Thread iterator and libgjc support submitted too early.
4.104.114.84.95
@afd63b7
06/13/00 22:57:19 |
Joel Sherrill |
Added crude i960ka support.
4.104.114.84.95
@7d52750
06/13/00 22:14:16 |
Joel Sherrill |
New file.
4.104.114.84.95
@cf1f72e
06/13/00 21:53:38 |
Joel Sherrill |
Moved i386 and m68k cache management code to libcpu. Everything
now …
4.104.114.84.95
@80ad143b
06/13/00 21:42:55 |
Joel Sherrill |
Temporary hack to compile. Need to probably address definition
of all …
4.104.114.84.95
@2adcb4dd
06/13/00 21:41:45 |
Joel Sherrill |
4.104.114.84.95
@3ab61f0
06/12/00 21:34:51 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier …
4.104.114.84.95
@edc61d4
06/12/00 20:27:50 |
Joel Sherrill |
Fixed so hppa1.1 compiles with only problems in simhppa BSP.
4.104.114.84.95
@8ef3818
06/12/00 19:57:02 |
Joel Sherrill |
4.104.114.84.95
@ce5b291f
06/12/00 18:45:54 |
Joel Sherrill |
Works on Solaris and Linux.
4.104.114.84.95
@1bce637
06/12/00 16:37:04 |
Joel Sherrill |
Added printk as a generic, shared routine.
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@b27c15f
05/08/00 21:17:50 |
Joel Sherrill |
New file added on 4.5 branch
4.104.114.84.95
@31aa66a8
05/03/00 13:55:42 |
Joel Sherrill |
Added on 4.5 branch.
4.104.114.84.95
@f3c096a
05/01/00 14:57:46 |
Joel Sherrill |
Added on 4.5-branch
4.104.114.84.95
@84a90acf
04/29/00 19:41:47 |
Joel Sherrill |
New files.
4.104.114.84.95
@87ec19a3
04/29/00 19:13:19 |
Joel Sherrill |
New files added as part of librpc upgrade.
4.104.114.84.95
@5ad350a4
04/29/00 19:04:37 |
Joel Sherrill |
4.104.114.84.95
@775e786
04/29/00 18:50:41 |
Joel Sherrill |
New directory added as part of librpc upgrade.
4.104.114.84.95
@a4460152
04/28/00 17:42:16 |
Joel Sherrill |
New files added on 4.5 branch.
4.104.114.84.95
@e4c07444
04/13/00 14:47:15 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
4.104.114.84.95
@b6f9b5f1
03/01/00 18:08:53 |
Joel Sherrill |
Added routines to get and set C3x IOF register. The code is …
4.104.114.84.95
@8eacefcc
02/29/00 16:35:45 |
Joel Sherrill |
BSP now compiles and links with CAVSL board information. This …
4.104.114.84.95
@61ba9763
02/22/00 18:39:52 |
Joel Sherrill |
New port of RTEMS to TI C3x and C4x.
4.104.114.84.95
@562e7ed1
02/11/00 15:54:47 |
Joel Sherrill |
Increased block size to 128 and added comments based on feedback from …
4.104.114.84.95
@70810dc
02/08/00 22:33:25 |
Joel Sherrill |
Patches rtems-rc-20000204-0.diff from Ralf Corsepius …
4.104.114.84.95
@bf24479
02/04/00 16:32:38 |
Joel Sherrill |
Incorrect error status returned. Noted by Andrew Klossner …
4.104.114.84.95
@edb2176
02/04/00 16:09:38 |
Joel Sherrill |
4.104.114.84.95
@b452a40
02/03/00 22:20:41 |
Joel Sherrill |
Changed behavior to match that expected by EPICS test code. Reported …
4.104.114.84.95
@4bf1801
02/03/00 13:21:38 |
Joel Sherrill |
Patches rtems-rc-20000118-7.diff from Ralf Corsepius …
4.104.114.84.95
@1382cea3
02/03/00 13:18:21 |
Joel Sherrill |
Fixed spelling errors.
4.104.114.84.95
@4e36a2f
01/31/00 15:27:02 |
Joel Sherrill |
Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from …
4.104.114.84.95
@4c46630
01/31/00 15:15:10 |
Joel Sherrill |
Patch rtems-rc-20000118-1.diff from Ralf Corsepius …
4.104.114.84.95
@318f591
01/27/00 14:37:17 |
Joel Sherrill |
Added after report from Quality Quorum <qqi@…> that …
4.104.114.84.95
@8d37343
01/23/00 19:07:02 |
Joel Sherrill |
Directive rtems_task_variable_get() added by Eric Norum.
4.104.114.84.95
@f13b1c4
01/23/00 18:22:02 |
Joel Sherrill |
Removing unused file accidentally left in CVS. Discovered by
Ralf …
4.104.114.84.95
@4a9b897
01/21/00 15:11:40 |
Joel Sherrill |
Patch from Eric Norum <eric@…> at the request of Jake …
4.104.114.84.95
@c941a98
01/21/00 15:07:55 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to implement this:
I'd …
4.104.114.84.95
@e570c761
01/21/00 14:49:31 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to remove warnings.
4.104.114.84.95
@e49ebbfa
01/14/00 18:37:59 |
Joel Sherrill |
Removed unused variable warning.
4.104.114.84.95
@4d1af20
01/14/00 18:37:30 |
Joel Sherrill |
Removed no prototype of kill() warning.
4.104.114.84.95
@752badac
01/14/00 14:55:37 |
Joel Sherrill |
Removed warning.
4.104.114.84.95
@53fb837a
01/13/00 19:25:15 |
Joel Sherrill |
POSIX message queues now include complete functionality including …
4.104.114.84.95
@9c1c778d
01/13/00 18:32:38 |
Jennifer.Averett |
+ Added comments
4.104.114.84.95
@d65c3768
01/13/00 18:32:09 |
Jennifer.Averett |
+ Added and yellow line tested …
4.104.114.84.95
@e7d76dc
01/13/00 18:23:42 |
Jennifer.Averett |
Added comment.
4.104.114.84.95
@d78c6fe3
01/13/00 18:22:32 |
Jennifer.Averett |
+ Comment cleanup
4.104.114.84.95
@661ff9a
01/13/00 18:22:09 |
Jennifer.Averett |
Removed referance to rtems error.
Added correct include file.
4.104.114.84.95
@b0461cd4
01/13/00 17:13:12 |
Jennifer.Averett |
Added comment to indicate this path does not occur.
4.104.114.84.95
@ea2c1d6
01/12/00 20:22:04 |
Jennifer.Averett |
+ Added code for waiting send
+ Yellow lined tested routine with Posix …
4.104.114.84.95
@e38cb52
01/12/00 18:47:22 |
Jennifer.Averett |
Debugged and yellow line tested routines.
4.104.114.84.95
@68b05694
01/12/00 18:46:54 |
Jennifer.Averett |
+ Modified return codes
+ Added messsage size check
+ Debugged and …
4.104.114.84.95
@bcbc50a
01/12/00 18:44:19 |
Jennifer.Averett |
+ Added signal processing.
+ Yellow line tested source.
4.104.114.84.95
@352d01e
01/12/00 18:43:21 |
Jennifer.Averett |
+ Modified to correct return codes.
+ Removed extra flag attribute …
4.104.114.84.95
@70329c80
01/12/00 18:41:14 |
Jennifer.Averett |
+ Changed call from core flush to core close routine. This flushes …
4.104.114.84.95
@399ba06
01/12/00 18:40:18 |
Jennifer.Averett |
+ Removed name validation code (this was already done in nametoid.
4.104.114.84.95
@7558283
01/11/00 15:43:16 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@4fa5eae
01/11/00 15:42:05 |
Joel Sherrill |
This code did not return properly when a process oriented signal
was …
4.104.114.84.95
@19642e2c
01/10/00 21:22:23 |
Joel Sherrill |
Removed definition of USHRT_MAX to remove lots of redefinition warnings.
4.104.114.84.95
@70af0ea1
01/10/00 18:47:58 |
Joel Sherrill |
Don't look at the object information structure for threads/tasks
for …
4.104.114.84.95
