@c0d405ca
01/05/00 22:13:15 |
Joel Sherrill |
Added new message priority parameter as returned by core support routine.
4.104.114.84.95
@3a8b95e
01/05/00 21:32:57 |
Joel Sherrill |
Spacing corrected.
4.104.114.84.95
@db6ec79e
01/05/00 18:30:09 |
Joel Sherrill |
Fixed recursive release for mutexes with nesting allowed.
4.104.114.84.95
@b302d527
01/05/00 17:20:07 |
Jennifer.Averett |
+ Added return priority from message seize.
+ Changed priority to be …
4.104.114.84.95
@466b8882
01/05/00 17:18:51 |
Jennifer.Averett |
Added the recording of the submit type.
4.104.114.84.95
@58243b4
01/05/00 17:18:08 |
Jennifer.Averett |
+ Added return of the message priority.
4.104.114.84.95
@65800393
01/05/00 17:16:48 |
Jennifer.Averett |
Added priority conversion between POSIX and core.
4.104.114.84.95
@c5858ef
01/05/00 17:16:02 |
Jennifer.Averett |
Added priority conversion between POSIX and core priorities.
4.104.114.84.95
@3ebd4c1
01/05/00 17:13:50 |
Jennifer.Averett |
+ Changed priority to the POSIX priority type.
+ Added priority …
4.104.114.84.95
@fcd0c90
01/05/00 17:11:36 |
Jennifer.Averett |
+ Added check for reading from a write only queue.
+ Added ability to …
4.104.114.84.95
@cecd206
01/05/00 17:09:36 |
Jennifer.Averett |
+ Added check for name greater than PATH_MAX.
4.104.114.84.95
@e015106
01/05/00 17:08:56 |
Jennifer.Averett |
+ Changed to resonable default values for maxmsg and msgsize.
+ Added …
4.104.114.84.95
@f602eeb
01/05/00 17:07:52 |
Jennifer.Averett |
Added mqueuetranslatereturncode.c.
4.104.114.84.95
@864ac98
01/05/00 17:06:45 |
Jennifer.Averett |
Added routines to translate to and from the core message queue return …
4.104.114.84.95
@590eb87
01/04/00 17:08:16 |
Joel Sherrill |
Added this file to contain an example program.
4.104.114.84.95
@a148f56
01/04/00 14:00:38 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@1dfc188e
01/04/00 13:58:47 |
Joel Sherrill |
Removed unitialized variable warning.
4.104.114.84.95
@e065e8ae
01/03/00 16:52:50 |
Joel Sherrill |
Increased stack size to 4K per Eric Norum.
4.104.114.84.95
@20385957
01/03/00 14:01:02 |
Joel Sherrill |
Increased minimum stack size so all tests will run.
4.104.114.84.95
@2e97c01
12/23/99 22:11:01 |
Jennifer.Averett |
+ Added routine to remove from namespace.
4.104.114.84.95
@afebb3f
12/23/99 22:10:13 |
Jennifer.Averett |
4.104.114.84.95
@7fbef786
12/23/99 22:09:36 |
Jennifer.Averett |
+ Debugged.
4.104.114.84.95
@8f12d069
12/23/99 22:08:43 |
Jennifer.Averett |
+ Filled in routine.
4.104.114.84.95
@96d4aea
12/23/99 22:07:43 |
Jennifer.Averett |
+ Initial debug
4.104.114.84.95
@d4548d1
12/23/99 22:07:11 |
Jennifer.Averett |
+ Made work
+ Added checks for valid attribute maxmsg and msgsize
4.104.114.84.95
@e1786ee3
12/23/99 22:05:25 |
Jennifer.Averett |
+ Fixed errno response to match the POSIX manual.
4.104.114.84.95
@ed46b47
12/21/99 20:29:40 |
Joel Sherrill |
Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to …
4.104.114.84.95
@9ba1f0a
12/21/99 15:04:48 |
Joel Sherrill |
Patch rtems-rc-19991203-9.diff from Ralf Corsepius …
4.104.114.84.95
@db3e0108
12/21/99 14:32:00 |
Joel Sherrill |
Patch rtems-rc-19991203-6.diff from Ralf Corsepius …
4.104.114.84.95
@8b91282
12/21/99 14:27:52 |
Joel Sherrill |
Patch rtems-rc-19991203-5.diff from Ralf Corsepius …
4.104.114.84.95
@c629812
12/13/99 22:10:45 |
Joel Sherrill |
Removed warnings.
4.104.114.84.95
@da8ae79b
12/13/99 21:21:31 |
Joel Sherrill |
Warning removal patch from Philip A. Prindeville <philipp@…>.
4.104.114.84.95
@f9669ce5
12/13/99 20:06:27 |
Joel Sherrill |
Patch from Silverio Diquigiovanni <silverio.di@…> to correct
TPC …
4.104.114.84.95
@fc0b91c
12/13/99 19:20:38 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to make the NTP handler a …
4.104.114.84.95
@6b79a071
12/13/99 17:22:18 |
Joel Sherrill |
Patch from Jepsen Hans Peter <hans_peter_jepsen@…> to
use …
4.104.114.84.95
@809f4451
12/13/99 17:03:37 |
Joel Sherrill |
Correction from Eric Norum for timeout in TFTP driver following bug …
4.104.114.84.95
@7d91d72
12/13/99 15:29:20 |
Joel Sherrill |
First attempt at adding simple binary semaphore in addition to the …
4.104.114.84.95
@d9230ea
12/13/99 14:49:38 |
Joel Sherrill |
Added RTEMS_IO_ERROR.
4.104.114.84.95
@fc81cc9
12/03/99 13:31:56 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius …
4.104.114.84.95
@4090ebe
12/03/99 13:25:00 |
Joel Sherrill |
4.104.114.84.95
@43283456
12/02/99 17:45:14 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius …
4.104.114.84.95
@acc25ee
12/02/99 14:31:19 |
Joel Sherrill |
Merged of mcp750 and mvme2307 BSP by Eric Valette …
4.104.114.84.95
@4cf56006
12/02/99 14:10:14 |
Joel Sherrill |
4.104.114.84.95
@e4ab88f
12/02/99 14:00:01 |
Joel Sherrill |
4.104.114.84.95
@5554279
12/02/99 13:54:30 |
Joel Sherrill |
4.104.114.84.95
@5d3da15b
12/01/99 16:00:38 |
Joel Sherrill |
Removed debugging printfs.
4.104.114.84.95
@017061c
12/01/99 15:54:17 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to fix a spot in the tftp …
4.104.114.84.95
@955a9ba7
12/01/99 15:05:26 |
Joel Sherrill |
4.104.114.84.95
@1972b1e
12/01/99 14:46:02 |
Joel Sherrill |
4.104.114.84.95
@7656140
12/01/99 14:31:36 |
Joel Sherrill |
4.104.114.84.95
@ccf8925b
12/01/99 14:22:12 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius …
4.104.114.84.95
@4a3757f
12/01/99 14:12:58 |
Joel Sherrill |
4.104.114.84.95
@42881534
11/30/99 22:14:28 |
Joel Sherrill |
Added missing files from PPP port.
4.104.114.84.95
@d0950ad
11/30/99 22:12:50 |
Joel Sherrill |
Added port of ppp-2.3.5 from Tomasz Domin <dot@…> of ComArch? …
4.104.114.84.95
@1563d8c
11/30/99 16:52:21 |
Joel Sherrill |
Removed duplicate definition of rtems_filesystem_umask.
4.104.114.84.95
@e4b25c4
11/30/99 13:46:28 |
Joel Sherrill |
Corrected so they would compile with POSIX disabled.
4.104.114.84.95
@1d9a2fc
11/29/99 15:45:11 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius …
4.104.114.84.95
@64f55e7
11/29/99 15:40:38 |
Joel Sherrill |
Made sure POSIX would build with MP enabled.
4.104.114.84.95
@3dfe0b27
11/29/99 15:10:30 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@63bdbbd
11/23/99 16:02:26 |
Joel Sherrill |
Readding files mistakenly removed.
4.104.114.84.95
@49da88c
11/23/99 15:53:09 |
Joel Sherrill |
Patch rtems-rc-19991117-16.diff from Ralf Corsepius …
4.104.114.84.95
@748cdca9
11/23/99 15:48:26 |
Joel Sherrill |
Readding Makefile.in's accidentally removed.
4.104.114.84.95
@23e3f642
11/23/99 14:10:05 |
Joel Sherrill |
Missed in previous automake conversion patches from Ralf Corsepius …
4.104.114.84.95
@9f4868c
11/23/99 13:57:02 |
Joel Sherrill |
Miscellaneous patches from Ralf Corsepius <corsepiu@…> …
4.104.114.84.95
@fba12eb6
11/23/99 13:29:04 |
Joel Sherrill |
Patch rtems-rc-19991117-11.diff from Ralf Corsepius …
4.104.114.84.95
@7e642ba
11/22/99 19:27:13 |
Joel Sherrill |
Patch rtems-rc-19991117-9.diff from Ralf Corsepius …
4.104.114.84.95
@101e9b0
11/22/99 16:14:00 |
Jennifer.Averett |
Fixed dispatching and cleaned up code.
4.104.114.84.95
@cb3c1718
11/22/99 16:13:22 |
Jennifer.Averett |
+ Corrected enable/disable of dispatch.
+ Cleaned up code.
4.104.114.84.95
@2545646
11/22/99 16:12:19 |
Jennifer.Averett |
+ Updated comments.
4.104.114.84.95
@94f81bbd
11/22/99 16:11:35 |
Jennifer.Averett |
+ Corrected bug in error check.
4.104.114.84.95
@2c3af4c5
11/22/99 16:10:25 |
Jennifer.Averett |
+ Added description of routine to comment.
4.104.114.84.95
@0ca4fc8
11/22/99 16:09:55 |
Jennifer.Averett |
+ Corrected error processing code.
4.104.114.84.95
@f85409c
11/22/99 16:08:53 |
Jennifer.Averett |
+ Added checks for NULL and NULL string names (for sem_open & sem_unlink).
4.104.114.84.95
@0ebf5694
11/22/99 16:07:02 |
Jennifer.Averett |
+ Cleaned up comments.
4.104.114.84.95
@b7912a89
11/22/99 14:25:01 |
Joel Sherrill |
Changed name of W, X, and Y macros for fields in the Clock
Synthesizer …
4.104.114.84.95
@b22a19e
11/22/99 13:46:50 |
Joel Sherrill |
Adding files not added as part of merger of SH2 port.
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@75f2b0b
11/22/99 13:12:48 |
Joel Sherrill |
Small patch (rtems-rc-19991117-5.diff) from Ralf Corsepius …
4.104.114.84.95
@97c465c
11/18/99 21:30:12 |
Joel Sherrill |
Minor cleanup to reduce the code space.
4.104.114.84.95
@4a238002
11/18/99 21:22:58 |
Joel Sherrill |
Patch from "John M. Mills" <jmills@…> with subsequent cleanup …
4.104.114.84.95
@c38f5f16
11/18/99 19:55:28 |
Jennifer.Averett |
Added EINVAL for passing a NULL pointer in.
4.104.114.84.95
@105d7872
11/18/99 19:50:15 |
Jennifer.Averett |
Added routine to remove an object from the namespace. It just clears …
4.104.114.84.95
@17879f4
11/18/99 19:43:13 |
Jennifer.Averett |
+ Debuged to the point that you could open, unlink and close a …
4.104.114.84.95
@c9ae846
11/18/99 19:41:34 |
Jennifer.Averett |
Added a routine to remove a semaphore name from its namespace.
4.104.114.84.95
@40fe60a3
11/17/99 20:44:13 |
Jennifer.Averett |
Comment added.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@9d9a3dd
11/17/99 16:47:58 |
Jennifer.Averett |
+ Updated copyright information.
4.104.114.84.95
@5e96e917
11/17/99 15:24:11 |
Joel Sherrill |
Updated Mailbox Manager submitted and split into multiple files.
4.104.114.84.95
@1c10acc
11/17/99 14:56:18 |
Joel Sherrill |
Update from Andrew D. McDowell? <amcdowel@…> with …
4.104.114.84.95
@aad726e
11/16/99 22:56:38 |
Joel Sherrill |
Moved task_variable pointer to basic shared part of TCB instead of …
4.104.114.84.95
@4efe2b7a
11/16/99 22:47:23 |
Jennifer.Averett |
Added check to return passed if task is not suspended.
4.104.114.84.95
@0fa51b5b
11/16/99 22:46:55 |
Jennifer.Averett |
Added code to catch the error of suspend count exceding the counter value.
4.104.114.84.95
@9181246
11/16/99 22:45:51 |
Jennifer.Averett |
Fixed bug.
4.104.114.84.95
@18c3155
11/16/99 22:45:33 |
Jennifer.Averett |
Added handler for fsync. For the memfile it is the same as the data sync.
4.104.114.84.95
@65a38bc
11/16/99 16:14:37 |
Joel Sherrill |
Web server uses the POSIX API. Therefor, it must be disabled when the …
4.104.114.84.95
@ce18601a
11/16/99 16:13:26 |
Joel Sherrill |
Removed start subdirectory and distributed contents to the appropriate …
4.104.114.84.95
@0cb7cb9
11/16/99 16:10:39 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@d3fdf459
11/16/99 16:09:50 |
Joel Sherrill |
Now use _Thread_Reset().
4.104.114.84.95
@88cb6b2
11/16/99 16:08:10 |
Joel Sherrill |
Added threadreset.c.
4.104.114.84.95
@f6d0821
11/16/99 16:07:52 |
Joel Sherrill |
Added prototype for _Thread_Reset() and numerous comments.
4.104.114.84.95
