@87904ba
01/15/98 21:39:15 |
Joel Sherrill |
Error reported by Duncan Smith <dds@…>:
>> >>There is a …
4.104.114.84.95
@2872e0b
01/06/98 15:47:37 |
Joel Sherrill |
Changed initial settings of first time.
4.104.114.84.95
@b2225d7
01/06/98 15:40:35 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@4f7fd59
12/23/97 16:03:43 |
Joel Sherrill |
Added CONFIGURE_GNAT_KEYS to correct the number of keys configured
for …
4.104.114.84.95
@608641e
12/22/97 17:29:51 |
Joel Sherrill |
Corrected prototypes for all termios console write driver entries to …
4.104.114.84.95
@2ab1b3a
12/22/97 17:28:32 |
Joel Sherrill |
Now generating this file with autoconf to avoid having to embed so …
4.104.114.84.95
@86765ac
12/22/97 17:27:49 |
Joel Sherrill |
Changed invocation of size_rtems to match new autoconf'ed version.
4.104.114.84.95
@4bf453a
12/22/97 17:27:17 |
Joel Sherrill |
Changed from .align to .p2align to avoid differences in meaning of …
4.104.114.84.95
@bfa613b
12/22/97 15:06:49 |
Joel Sherrill |
Added lines to build sizeinfo.txt which is automatically generated now …
4.104.114.84.95
@674c900
12/10/97 16:58:00 |
Joel Sherrill |
Modified a lot of files to take a first cut at supporting building …
4.104.114.84.95
@01a5f6b2
12/06/97 15:09:30 |
Joel Sherrill |
Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were …
4.104.114.84.95
@7150f00f
12/01/97 22:06:48 |
Joel Sherrill |
Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto Romano …
4.104.114.84.95
@68732ef3
11/30/97 18:35:22 |
Joel Sherrill |
Corrected comment.
4.104.114.84.95
@80868140
11/29/97 17:51:27 |
Joel Sherrill |
Patch from Chris Johns to filter out the trace bit on CPU models
which …
4.104.114.84.95
@c7ca28cf
11/18/97 22:32:55 |
Joel Sherrill |
Removed warning under linux port.
4.104.114.84.95
@cb4cf6a7
11/18/97 22:30:51 |
Joel Sherrill |
Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request.
4.104.114.84.95
@d24ceb3
11/15/97 18:15:36 |
Joel Sherrill |
interrupt driven change from Eric Norum
4.104.114.84.95
@a307f79
11/10/97 17:50:50 |
Joel Sherrill |
Fixed prototype
4.104.114.84.95
@52e1708
11/10/97 17:31:11 |
Joel Sherrill |
Set return code to avoid spurious errors.
4.104.114.84.95
@5a5bd13b
10/24/97 19:29:01 |
Joel Sherrill |
added katsutoshi Shibuya
4.104.114.84.95
@51eb8d5
10/23/97 18:49:34 |
Joel Sherrill |
Changed prototype of read routine.
4.104.114.84.95
@b628637
10/23/97 15:10:13 |
Joel Sherrill |
Added prototype for console_reserve_resources.
4.104.114.84.95
@3ee825e8
10/23/97 15:00:32 |
Joel Sherrill |
fixed comment
4.104.114.84.95
@118a812
10/23/97 13:13:46 |
Joel Sherrill |
New termios.c from Eric Norum.
Added new entry point to add in per …
4.104.114.84.95
@cdfd74a5
10/21/97 18:37:58 |
Joel Sherrill |
Added check that return argument pointer for old_isr_handler was valid.
4.104.114.84.95
@a75c783
10/21/97 17:03:18 |
Joel Sherrill |
Converted from using a message queue for the raw input queue to using …
4.104.114.84.95
@55e1322
10/21/97 17:03:17 |
Joel Sherrill |
Added termios submission from Eric Norum and Katsutoshi Shibuya.
4.104.114.84.95
@ae35953d
10/21/97 16:18:03 |
Joel Sherrill |
4.104.114.84.95
@4fd61795
10/21/97 16:17:12 |
Joel Sherrill |
Added casts and fixed line break.
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@a2016b99
10/08/97 14:42:08 |
Joel Sherrill |
Removed include directory at "build" point and the link of this …
4.104.114.84.95
@b6770d1
10/06/97 21:29:29 |
Joel Sherrill |
Fixed comment.
4.104.114.84.95
@7e4938c
10/06/97 21:28:40 |
Joel Sherrill |
Make Post an atomic operation.
4.104.114.84.95
@d14418b
10/06/97 21:28:18 |
Joel Sherrill |
Added _Thread_Enable_dispatch to already_timedout path on Wait_support.
4.104.114.84.95
@e8ee2f32
10/05/97 16:26:04 |
Joel Sherrill |
If the specified time period is less than a clock tick, then
it is …
4.104.114.84.95
@f795ca90
09/21/97 17:44:50 |
Joel Sherrill |
Uncommented gettimeofday_r to resolve missing symbol.
4.104.114.84.95
@8f367d6b
09/19/97 18:31:05 |
Joel Sherrill |
Bug fix from Eric Norum:
After weeks of trying to figure why my …
4.104.114.84.95
@7d352a49
08/28/97 13:59:41 |
Joel Sherrill |
Added RTEMS_IO_ERROR status code.
4.104.114.84.95
@3473f605
08/27/97 20:33:49 |
Joel Sherrill |
Added error numbers and changed default error code from 0 to -1 for …
4.104.114.84.95
@e63e254e
08/22/97 19:19:07 |
Joel Sherrill |
Corrected bug per Katsutoshi Shibuya's report:
The definition of …
4.104.114.84.95
@b1459dc
08/22/97 19:17:09 |
Joel Sherrill |
Moved reentrant wrappers into their own file.
4.104.114.84.95
@78d87bd
08/22/97 19:16:47 |
Joel Sherrill |
Fixed iop/memory leak bug reported by Dan Dickey.
4.104.114.84.95
@9b1f5678
08/22/97 19:11:02 |
Joel Sherrill |
Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER.
4.104.114.84.95
@799a5b9
08/22/97 19:10:44 |
Joel Sherrill |
Added commit about missing support for condition initializer.
4.104.114.84.95
@0789abef
08/04/97 22:17:17 |
Joel Sherrill |
new implementation of mc68681.h
4.104.114.84.95
@b61e6e1
08/04/97 21:43:36 |
Joel Sherrill |
Added GNAT configuration parameters.
4.104.114.84.95
@28a4b1d
08/04/97 21:39:07 |
Joel Sherrill |
moved from main include directory
4.104.114.84.95
@b2fed481
08/02/97 17:55:09 |
Joel Sherrill |
Added these files to contain bodies for routines included in the API …
4.104.114.84.95
@9deb5b8b
08/01/97 18:12:11 |
Joel Sherrill |
Katsutoshi Shibuya (shibuya@…)of BU-Denken Co., Ltd. …
4.104.114.84.95
@91333c2
07/31/97 22:04:17 |
Joel Sherrill |
Merged very large and much appreciated patch from Chris Johns …
4.104.114.84.95
@e7d8b58
07/31/97 19:01:42 |
Joel Sherrill |
Added rtems_message_queue_get_number_pending directive.
4.104.114.84.95
@a2fa8c25
07/31/97 19:01:05 |
Joel Sherrill |
Added comment to indicate what the commented out C_PIECES indicated.
4.104.114.84.95
@e24e9b5
07/18/97 15:05:05 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@487c4f62
07/10/97 19:09:16 |
Joel Sherrill |
Strip the trace bit from the SR register when dispatching a thread …
4.104.114.84.95
@eb14a2ff
07/09/97 23:55:39 |
Joel Sherrill |
Repository damaged -- files readded.
4.104.114.84.95
@a14d2af
07/09/97 23:52:08 |
Joel Sherrill |
Changed name from entry to thread_entry to be more compatible with
Ada …
4.104.114.84.95
@2a02b0a
07/09/97 23:50:45 |
Joel Sherrill |
Added postswitch extension.
4.104.114.84.95
@b5fc21c
07/09/97 23:50:28 |
Joel Sherrill |
Added post switch extension.
4.104.114.84.95
@2c5d78b
07/09/97 23:46:59 |
Joel Sherrill |
Corrected typos and spacing.
4.104.114.84.95
@8fabc273
07/09/97 23:33:08 |
Joel Sherrill |
Added sp, sfc, and fpcsr register defines.
4.104.114.84.95
@00d2a828
05/28/97 20:36:35 |
Joel Sherrill |
Added support for context switching the data used by the gcc m68k …
4.104.114.84.95
@7922df59
05/27/97 18:27:59 |
Joel Sherrill |
changed version number to 4.1.0.
4.104.114.84.95
@e8cdda4
04/25/97 18:13:49 |
Joel Sherrill |
Corrected by adding check for NULL address passed into get_status …
4.104.114.84.95
@f8f5106
04/25/97 18:13:26 |
Joel Sherrill |
Added to comment header block to include new status directive.
4.104.114.84.95
@0a6fb22
04/22/97 20:19:25 |
Joel Sherrill |
Patch from Chris John <cjohns@…> to add use of a select …
4.104.114.84.95
@e0de6ef
04/22/97 20:19:12 |
Joel Sherrill |
promote TOD_MICROSECONDS_TO_TICKS through API as …
4.104.114.84.95
@f2545552
04/22/97 19:57:02 |
Joel Sherrill |
multiprocessing fixed on linux by fixing cpu.c so correct form of …
4.104.114.84.95
@e71ce071
04/22/97 17:47:16 |
Joel Sherrill |
updated with new license information per Tony Bennett.
4.104.114.84.95
@84ff7c23
04/22/97 17:42:17 |
Joel Sherrill |
File changed to reflect change in license and copyright.
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@5bf6ffb
04/16/97 17:34:40 |
Joel Sherrill |
Added FPSP support for MC68040
4.104.114.84.95
@6881e0c
04/15/97 18:02:18 |
Joel Sherrill |
Reduced number of POSIX thread priorities from 255 to 254 to avoid …
4.104.114.84.95
@e39e6f7
04/09/97 20:05:59 |
Joel Sherrill |
added code to prevent attempts to clean up the library when rtems is
down.
4.104.114.84.95
@3fc076d
04/09/97 20:04:52 |
Joel Sherrill |
added support for tracking thread cpu usage.
4.104.114.84.95
@192259f
04/09/97 20:04:36 |
Joel Sherrill |
enhanced printf statements
4.104.114.84.95
@48e34595
04/09/97 20:04:22 |
Joel Sherrill |
corrected spacing.
4.104.114.84.95
@bbb846b
04/09/97 20:03:59 |
Joel Sherrill |
added SYSTEM_STATE_SHUTDOWN
4.104.114.84.95
@eafd698
04/09/97 20:03:35 |
Joel Sherrill |
enhanced rtems_shutdown_executive to insure that no attempt will
be …
4.104.114.84.95
@113ef9fc
04/09/97 20:02:29 |
Joel Sherrill |
added support for statistics on rate monotonic periods.
4.104.114.84.95
@e2d79559
04/09/97 14:05:50 |
Joel Sherrill |
Added ka9q tcpip stack and network driver for the gen68360. This …
4.104.114.84.95
@bd71da7
04/07/97 21:30:42 |
Joel Sherrill |
removed noreturn attribute to eliminate warnings.
4.104.114.84.95
@d6ba279
04/07/97 21:24:02 |
Joel Sherrill |
added initialization of variable to eliminate warning.
4.104.114.84.95
@c6e895df
04/07/97 21:22:59 |
Joel Sherrill |
added ifdef around variables to eliminate warnings when cross
4.104.114.84.95
@12d6f14
04/07/97 21:22:15 |
Joel Sherrill |
added "ifndef" to avoid redefinition warning.
4.104.114.84.95
@424ab48
04/07/97 21:21:55 |
Joel Sherrill |
added volatile to Switch_necessary structure member to avoid warning.
4.104.114.84.95
@d911f4c2
04/07/97 21:21:21 |
Joel Sherrill |
added test to avoid spurious error
4.104.114.84.95
@4e8c5a6b
04/07/97 21:20:57 |
Joel Sherrill |
added prototype for missing routine.
4.104.114.84.95
@d749165
04/07/97 21:20:48 |
Joel Sherrill |
added "return" to eliminate warning.
4.104.114.84.95
@2ff1d549
04/07/97 21:20:35 |
Joel Sherrill |
4.104.114.84.95
@82ab443e
04/07/97 21:20:16 |
Joel Sherrill |
added prototypes for two assembly language routines to eliminate warnings.
4.104.114.84.95
@32ef3dc
04/07/97 21:19:59 |
Joel Sherrill |
commented out sccs_id to eliminate warning.
4.104.114.84.95
@11259ab7
04/07/97 21:19:15 |
Joel Sherrill |
added plea for someone to implement software stack switching for …
4.104.114.84.95
@77d20fb
04/07/97 21:18:50 |
Joel Sherrill |
Replaced warning message for cpus which do not have hardware support …
4.104.114.84.95
@2e4bc8b4
04/07/97 21:17:42 |
Joel Sherrill |
initialized variable to eliminate warning
4.104.114.84.95
@94784cf8
04/07/97 21:16:47 |
Joel Sherrill |
changed signed int to unsigned to eliminate warning
4.104.114.84.95
@17c4511
04/07/97 21:16:31 |
Joel Sherrill |
added "ifndef" for ASM to avoid redefinition warnings.
4.104.114.84.95
@9a11e1f
04/02/97 14:58:19 |
Joel Sherrill |
was checking for null cpu_table -- short have been checking …
4.104.114.84.95
@254b4450
04/01/97 23:07:52 |
Joel Sherrill |
This set of changes is the build of what was required to convert to …
4.104.114.84.95
@c43b34c
03/11/97 15:42:14 |
Joel Sherrill |
modified _Chain_Insert_unprotected to have the form required to be …
4.104.114.84.95
@0302021
03/11/97 15:41:19 |
Joel Sherrill |
swapped increment of _ISR_Nest_level and _Thread_Dispatch_disable_level
4.104.114.84.95
