@624133c
06/06/96 14:53:12 |
Joel Sherrill |
added Sporadic Server support
4.104.114.84.95
@ed10d76
06/06/96 14:52:53 |
Joel Sherrill |
added Sporadic_timer field to support sporadic server
4.104.114.84.95
@7aa4671
06/05/96 21:12:06 |
Joel Sherrill |
added cpu_time_budget field to Thread_Control and removed the global …
4.104.114.84.95
@7169852
06/05/96 18:34:48 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@23305a25
06/05/96 14:46:04 |
Joel Sherrill |
added support for the api providing the thread stack area
4.104.114.84.95
@98162c35
06/05/96 14:45:45 |
Joel Sherrill |
added boolean to indicate whether or not the stack area was provided …
4.104.114.84.95
@9b4e549
06/05/96 14:45:05 |
Joel Sherrill |
renamed Schedule to schedparam in the posix api control information.
4.104.114.84.95
@7189a40
06/05/96 14:44:03 |
Joel Sherrill |
added comments to to document the definition of posix priority
and how …
4.104.114.84.95
@09c1e31d
06/05/96 14:43:52 |
Joel Sherrill |
added comments to priority.h to document the definition of posix …
4.104.114.84.95
@2c207d1f
06/04/96 20:36:37 |
Joel Sherrill |
make PTHREAD_SCOPE_SYSTEM an unsupported value for contentionscope.
4.104.114.84.95
@65911c32
06/04/96 19:50:15 |
Joel Sherrill |
made sure _Thread_Enable_dispatch is not invoked in cases
where …
4.104.114.84.95
@56bd4a36
06/04/96 19:48:08 |
Joel Sherrill |
made sure routines which called _Objects_Get also called …
4.104.114.84.95
@230a0dcb
06/04/96 19:44:16 |
Joel Sherrill |
added some of the required functionality to pthread_setschedparam and …
4.104.114.84.95
@3ff4688
06/04/96 19:20:53 |
Joel Sherrill |
clean up pass
4.104.114.84.95
@6b067c4
06/04/96 19:15:28 |
Joel Sherrill |
renamed the local variable attrp to the_attr in pthread_create
4.104.114.84.95
@24adc5b
06/04/96 19:05:16 |
Joel Sherrill |
changed sched_rr_get_interval to use the interval to timespec routine.
4.104.114.84.95
@c48e0ee
06/04/96 16:15:59 |
Joel Sherrill |
added interpretation of scheduling policy and parameter information to …
4.104.114.84.95
@12c77ab
06/04/96 16:14:55 |
Joel Sherrill |
added scheduling policy and parameter information
4.104.114.84.95
@8f857992
06/03/96 22:08:18 |
Joel Sherrill |
added thread queue for list of threads waiting to join.
thread is …
4.104.114.84.95
@552a345d
06/03/96 22:07:14 |
Joel Sherrill |
4.104.114.84.95
@742b399
06/03/96 21:08:26 |
Joel Sherrill |
added priority ceiling support
4.104.114.84.95
@f39b01e
06/03/96 21:08:16 |
Joel Sherrill |
added an assert if a pthread_t is not the same size as an Objects_Id
4.104.114.84.95
@e811d68
06/03/96 21:06:51 |
Joel Sherrill |
deleted POSIX threads typedef masking Thread_Control
added initial …
4.104.114.84.95
@4427a64
06/03/96 21:06:12 |
Joel Sherrill |
4.104.114.84.95
@685f4d65
06/03/96 18:59:24 |
Joel Sherrill |
sleep moved into newlibc.c so the sleep.o object would not be in the …
4.104.114.84.95
@a26ee01c
06/03/96 18:27:48 |
Joel Sherrill |
nanosleep now fills in the time remaining structure.
4.104.114.84.95
@5b748a1
06/03/96 17:32:19 |
Joel Sherrill |
renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval
4.104.114.84.95
@5ff991e8
06/03/96 16:29:59 |
Joel Sherrill |
created ptimer.c and moved the timer_* routines out of time.c into ptimer.c
4.104.114.84.95
@a3828359
06/03/96 16:29:35 |
Joel Sherrill |
added constant for seconds between posix epoch (1970) and rtems epoch …
4.104.114.84.95
@f6e6ed8
06/03/96 15:49:22 |
Joel Sherrill |
changed so this file is usable from assembly files.
no longer uses …
4.104.114.84.95
@5e7b6272
05/31/96 23:27:45 |
Joel Sherrill |
renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the …
4.104.114.84.95
@c238a218
05/31/96 21:40:48 |
Joel Sherrill |
added checks to validate values passed to set attribute routines
4.104.114.84.95
@f31da72
05/31/96 20:57:17 |
Joel Sherrill |
fixed typo in merge of Eric Norum's patch
4.104.114.84.95
@c832429
05/31/96 19:02:13 |
Joel Sherrill |
added nanoseconds per second constant
4.104.114.84.95
@1e665a5
05/31/96 19:01:59 |
Joel Sherrill |
corrected minor problem in Eric Norum's changes in the bfffo macro.
4.104.114.84.95
@e72d995a
05/31/96 19:01:26 |
Joel Sherrill |
moved sleep() from psignal.c to unistd.c
implemented sigemptyset() …
4.104.114.84.95
@b927fba
05/31/96 18:59:57 |
Joel Sherrill |
commented out cancel handlers related items.
4.104.114.84.95
@285af80
05/31/96 18:59:31 |
Joel Sherrill |
moved attribute related constants into the rtems specific sys/types.h …
4.104.114.84.95
@7c55e06
05/30/96 20:48:33 |
Joel Sherrill |
Added nanoseconds constant
4.104.114.84.95
@5600661
05/30/96 20:48:10 |
Joel Sherrill |
First cut at implementing time, clock_gettime, clock_settime, …
4.104.114.84.95
@b169590e
05/30/96 20:34:46 |
Joel Sherrill |
added dummy versions of kill and getpid which assert(0) so that …
4.104.114.84.95
@53fd6e2
05/30/96 19:29:01 |
Joel Sherrill |
Eric Norum sent in new versions of the inline assembly macros which
do …
4.104.114.84.95
@be1c11ed
05/29/96 22:48:26 |
Joel Sherrill |
tests now specify whether using posix initialization threads table
or …
4.104.114.84.95
@dd32d883
05/29/96 22:46:05 |
Joel Sherrill |
posix initialization threads table was misnamed "posix initialization …
4.104.114.84.95
@7f72217e
05/29/96 21:27:26 |
Joel Sherrill |
comment clean up
4.104.114.84.95
@2a98af84
05/29/96 21:02:20 |
Joel Sherrill |
types.c: spacing
psignal.c: kill recognizes SIGABRT and exits to …
4.104.114.84.95
@5240c71c
05/29/96 20:58:45 |
Joel Sherrill |
fixed support for posix initialization threads table
4.104.114.84.95
@cfcfdf0
05/29/96 20:55:05 |
Joel Sherrill |
added pthread_exit
first posix thread ran
4.104.114.84.95
@5e0efa2b
05/29/96 20:50:52 |
Joel Sherrill |
cleaned up spacing and parentheses
4.104.114.84.95
@d835a35
05/29/96 19:28:15 |
Joel Sherrill |
spacing
4.104.114.84.95
@ece8c9a
05/29/96 19:28:01 |
Joel Sherrill |
first cut at pthread_create
4.104.114.84.95
@9c877c0d
05/29/96 18:46:46 |
Joel Sherrill |
addressed minimum stack size attribute.
There is a potential problem …
4.104.114.84.95
@98849f44
05/29/96 16:55:05 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@613cff6
05/29/96 16:54:52 |
Joel Sherrill |
removed all ifdef's on NOT_IMPLEMENTED.
4.104.114.84.95
@e941ea13
05/29/96 16:54:24 |
Joel Sherrill |
added entry point for posix initialization threads to the posix …
4.104.114.84.95
@d9a0689e
05/29/96 16:07:21 |
Joel Sherrill |
Addressed RTEMS API initialization tasks table in a system without …
4.104.114.84.95
@99f9dffa
05/29/96 16:05:28 |
Joel Sherrill |
Added default POSIX API configuration table.
4.104.114.84.95
@019bce7
05/29/96 16:05:06 |
Joel Sherrill |
It is now not an error to have 0 RTEMS initialization tasks since you …
4.104.114.84.95
@974ff40
05/29/96 16:04:31 |
Joel Sherrill |
renamed signal.c to psignal.c to avoid naming problems.
added mp …
4.104.114.84.95
@c627b2a3
05/28/96 21:40:52 |
Joel Sherrill |
split the inclusion of "EXTERN" data based on whether it was sapi, …
4.104.114.84.95
@c6fa38c0
05/28/96 19:29:51 |
Joel Sherrill |
added maximum keys
4.104.114.84.95
@7640525
05/28/96 19:29:02 |
Joel Sherrill |
added enumerated constant for the POSIX API as an error source
4.104.114.84.95
@5a18e04
05/28/96 19:28:32 |
Joel Sherrill |
added initial set of api extension callouts
4.104.114.84.95
@962c9b65
05/28/96 16:33:11 |
Joel Sherrill |
new file
4.104.114.84.95
@47d6b140
05/28/96 16:32:55 |
Joel Sherrill |
commented out interrupt support
4.104.114.84.95
@da33d26
05/28/96 16:18:34 |
Joel Sherrill |
added ifndef's for the POSIX maximum field in the POSIX api …
4.104.114.84.95
@d4b44877
05/28/96 16:17:01 |
Joel Sherrill |
added posix api initialization call to init.c
deleted a blank line in …
4.104.114.84.95
@8165b48f
05/28/96 16:16:28 |
Joel Sherrill |
comment cleanup
4.104.114.84.95
@52d9e4d1
05/28/96 16:16:11 |
Joel Sherrill |
added maximum keys
4.104.114.84.95
@2eba45d
05/28/96 14:16:45 |
Joel Sherrill |
made posix configuration information conditional so configurations …
4.104.114.84.95
@cb96372
05/28/96 13:24:58 |
Joel Sherrill |
changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. …
4.104.114.84.95
@e6d4b1d
05/28/96 13:13:34 |
Joel Sherrill |
added initial posix configuration support
4.104.114.84.95
@87a2a74
05/24/96 22:56:23 |
Joel Sherrill |
changed version to 3.5.17
4.104.114.84.95
@568ebf3
05/24/96 19:32:37 |
Joel Sherrill |
updates to fix typos
4.104.114.84.95
@8b2ecf85
05/23/96 15:37:38 |
Joel Sherrill |
updates from Tony Bennett
4.104.114.84.95
@a5f56a43
05/23/96 15:35:32 |
Joel Sherrill |
4.104.114.84.95
@859f17ce
05/23/96 15:35:26 |
Joel Sherrill |
invoke thread stack free routine instead of Workspace free.
4.104.114.84.95
@d196e48
05/23/96 15:34:54 |
Joel Sherrill |
updates from Tony Bennett.
Broke the setjmp/longjmp pair in the …
4.104.114.84.95
@ef006c1
05/22/96 22:34:18 |
Joel Sherrill |
Modified to correct variables which defined the range of object …
4.104.114.84.95
@f4719d5a
05/22/96 22:32:39 |
Joel Sherrill |
These files have been modified in the initial pass at getting the …
4.104.114.84.95
@05195890
05/22/96 22:31:51 |
Joel Sherrill |
4.104.114.84.95
@92262ab
05/10/96 20:23:27 |
Joel Sherrill |
fixed typo
4.104.114.84.95
@1c964ffa
05/08/96 21:53:50 |
Joel Sherrill |
4.104.114.84.95
@bf6661e
05/02/96 14:39:07 |
Joel Sherrill |
Updated version to 3.5.15.
4.104.114.84.95
@dce1c1a1
05/01/96 15:24:37 |
Joel Sherrill |
Updates from Eric Norum to use the mcpu32 flags and fix comments.
4.104.114.84.95
@a412622
04/24/96 21:21:14 |
Joel Sherrill |
changed version number to 3.5.14
4.104.114.84.95
@1543932
04/24/96 17:36:35 |
Joel Sherrill |
added comment regarding stack alignment issues to thread stack …
4.104.114.84.95
@8389628
04/22/96 16:53:46 |
Joel Sherrill |
4.104.114.84.95
@1f94ed6b
04/22/96 16:50:17 |
Joel Sherrill |
Updates from Tony Bennett.
4.104.114.84.95
@8faca06
04/22/96 16:46:36 |
Joel Sherrill |
thread.c: added support for optional user provided stack allocator
4.104.114.84.95
@6365f81
04/22/96 16:46:00 |
Joel Sherrill |
made initialization routine a regular subroutine
4.104.114.84.95
@a155b3c
04/22/96 16:45:47 |
Joel Sherrill |
interr.h: added stack allocater error code
wkspace.h: made …
4.104.114.84.95
@cc4c1fe4
04/22/96 16:44:54 |
Joel Sherrill |
added stack allocation fields to the cpu table
updates from Tony …
4.104.114.84.95
@96981e3a
04/22/96 16:44:04 |
Joel Sherrill |
4.104.114.84.95
@9a1ccb3
04/22/96 16:43:44 |
Joel Sherrill |
added CPU_M68K_EXTB_L …
4.104.114.84.95
@f581163a
04/22/96 16:30:30 |
Joel Sherrill |
4.104.114.84.95
@d0b7c4e6
04/22/96 16:30:02 |
Joel Sherrill |
updartes from Tony Bennett
4.104.114.84.95
@debe919
04/19/96 21:10:58 |
Joel Sherrill |
event.c: _Event_Manager_initialization no longer a static inline
4.104.114.84.95
@78b2ff1
04/19/96 21:10:38 |
Joel Sherrill |
4.104.114.84.95
@c26b62f
04/19/96 21:10:32 |
Joel Sherrill |
event.h: _Event_Manager_initialization no longer a static inline
4.104.114.84.95
