@541dfb2
01/29/97 00:22:24 |
Joel Sherrill |
Removed definitions which are now in targopts.h. This eliminates the …
4.104.114.84.95
@36dbb51
01/29/97 00:21:53 |
Joel Sherrill |
added type to macro to eliminate warning for untyped use of a register.
4.104.114.84.95
@3aa5029
01/29/97 00:14:15 |
Joel Sherrill |
Added comment.
4.104.114.84.95
@136b1e2
01/29/97 00:13:50 |
Joel Sherrill |
Removed defines now handled by targopts.h.
4.104.114.84.95
@ee7cf7d
01/29/97 00:13:11 |
Joel Sherrill |
Added include of rtems/score/cpu.h
4.104.114.84.95
@b9181082
01/29/97 00:13:00 |
Joel Sherrill |
Added include of targopts.h.
4.104.114.84.95
@985796a
01/29/97 00:12:31 |
Joel Sherrill |
Changed include of asm.h so it is in brackets not quotes. asm.h is
in …
4.104.114.84.95
@5ddfa53b
01/29/97 00:11:16 |
Joel Sherrill |
Fixed spacing on comments.
4.104.114.84.95
@375a6c0
01/29/97 00:10:28 |
Joel Sherrill |
Fixed spacing on comment.
4.104.114.84.95
@860e77a
01/29/97 00:09:49 |
Joel Sherrill |
Fixed comments.
Fixed so this file can be included from assembly code.
4.104.114.84.95
@95a1d50
01/29/97 00:08:14 |
Joel Sherrill |
Added comment.
4.104.114.84.95
@7446899
01/29/97 00:07:15 |
Joel Sherrill |
fixed spacing problem
4.104.114.84.95
@f7e46cf0
01/28/97 23:35:01 |
Joel Sherrill |
With the transition from command line macro definitions to targopts.h, …
4.104.114.84.95
@68d8873
01/28/97 23:33:40 |
Joel Sherrill |
removed include of unnecessary include file.
4.104.114.84.95
@52d99d4a
01/28/97 23:33:22 |
Joel Sherrill |
Switch to using newlib's implementation of time().
4.104.114.84.95
@fc5e2d73
01/15/97 20:21:48 |
Joel Sherrill |
fixed comments on vanilla 68000 SW interrupt stack (or the lack thereof)
4.104.114.84.95
@1019ae4
01/08/97 16:20:47 |
Joel Sherrill |
added some casts to reduce warnings reported by users with Microtec …
4.104.114.84.95
@0d051533
01/08/97 16:19:47 |
Joel Sherrill |
added type definitions for all supported task entry formats
4.104.114.84.95
@ffe316d
12/02/96 22:50:33 |
Joel Sherrill |
Suggested changes from Mark Jordan which eliminate warnings and errors …
4.104.114.84.95
@e1a06d1b
12/02/96 22:47:38 |
Joel Sherrill |
Changes to reflect new revision of erc32 per Jiri Gaisler's …
4.104.114.84.95
@6764c84
12/02/96 22:42:30 |
Joel Sherrill |
minor changes to eliminate warnings from C++ compilers per user …
4.104.114.84.95
@29d8227e
12/02/96 19:48:29 |
Joel Sherrill |
Updates from Derrick Ostertag <ostertag@…> to fix bug in …
4.104.114.84.95
@f4b7e297
12/02/96 19:43:22 |
Joel Sherrill |
Update from Chris Johns <cjohns@…> to add better support for …
4.104.114.84.95
@331d9e3b
11/08/96 20:08:52 |
Joel Sherrill |
Added asserts for unhandled conditions which need to result in error …
4.104.114.84.95
@9e406d9
10/15/96 21:58:32 |
Joel Sherrill |
added ENOSYS support
4.104.114.84.95
@27f0d424
10/15/96 21:38:43 |
Joel Sherrill |
added support for cpu time used field in tcb
4.104.114.84.95
@f8c6333
10/15/96 21:38:33 |
Joel Sherrill |
added cpu time used field to tcb
4.104.114.84.95
@2d0383b
10/14/96 19:17:37 |
Joel Sherrill |
patches to erc32.h to correct handling of timer mirror from Jiri Gaisler.
4.104.114.84.95
@355c262c
10/01/96 17:36:57 |
Joel Sherrill |
i386_nofp cpu model entry incorrectly had floating point enabled.
4.104.114.84.95
@855edec
09/30/96 20:15:01 |
Joel Sherrill |
fixed incorrect placement of CPU_STRUCTURE_ALIGNMENT macro.
4.104.114.84.95
@8880e9c7
09/30/96 20:14:27 |
Joel Sherrill |
changed version string to 3.6.0
4.104.114.84.95
@348ba42
09/30/96 20:14:08 |
Joel Sherrill |
changed stack size of posix initialization threads to double the …
4.104.114.84.95
@0c35efe
09/18/96 20:54:05 |
Joel Sherrill |
dummy function added to satisfy ANSI
4.104.114.84.95
@5e9a594
09/18/96 20:53:35 |
Joel Sherrill |
modified to support non-GNU compilers and to use calloc rather than …
4.104.114.84.95
@1f2d5df
09/18/96 20:52:47 |
Joel Sherrill |
added malloc_walk
miscellaneous corrections in casting.
4.104.114.84.95
@b1c215e
09/18/96 20:52:16 |
Joel Sherrill |
added prototype for malloc_walk
4.104.114.84.95
@94218b8
09/18/96 20:51:48 |
Joel Sherrill |
loop to clear workspace memory changed to use sizeof rather than …
4.104.114.84.95
@56e0b88
09/18/96 20:50:58 |
Joel Sherrill |
corrected prototype of _Objects_Get_next
4.104.114.84.95
@3861130
09/18/96 20:50:27 |
Joel Sherrill |
uses address object rather than direct pointer arithmetic
4.104.114.84.95
@4944b5bf
09/18/96 20:50:04 |
Joel Sherrill |
OBJECTS_NAME_ALIGNMENT definition changed to use sizeof rather than …
4.104.114.84.95
@857c52f
09/18/96 20:49:36 |
Joel Sherrill |
MP_PACKET_MINIMUN_HETERO_CONVERSION definition changed to use sizeof …
4.104.114.84.95
@533f89f
09/18/96 20:48:56 |
Joel Sherrill |
modified declaration of CORE_message_queue_Buffer_control to avoid use …
4.104.114.84.95
@2069773
09/18/96 20:47:39 |
Joel Sherrill |
use address object to avoid direct pointer arithmetic
4.104.114.84.95
@d1193c7
09/18/96 20:47:31 |
Joel Sherrill |
corrected white space problems
added CPU_STRUCTURE_ALIGNMENT to …
4.104.114.84.95
@a4d97d94
09/18/96 20:45:27 |
Joel Sherrill |
new files submitted by Craig Lebakken (lebakken@…) and Derrick …
4.104.114.84.95
@1d9d044
09/17/96 21:33:07 |
Joel Sherrill |
Reversed logic in conditional to correctly distinguish between
FIFO …
4.104.114.84.95
@41be2e8
09/17/96 21:31:30 |
Joel Sherrill |
added routine _POSIX_Timespec_subtract
4.104.114.84.95
@aa48536
09/17/96 21:31:10 |
Joel Sherrill |
Added code to insure that the post switch extension was executed and …
4.104.114.84.95
@9093c3c
09/17/96 21:29:51 |
Joel Sherrill |
Corrected implementation of timed wait on condition variables. First …
4.104.114.84.95
@ded66f8
09/17/96 21:26:25 |
Joel Sherrill |
added prototype for _POSIX_Timespec_subtract
4.104.114.84.95
@cda277f
09/11/96 19:16:07 |
Joel Sherrill |
added $Id$ to file headers
cpu.h: added prototype for _CPU_ISR_Get_level()
4.104.114.84.95
@3335420
09/08/96 16:22:05 |
Joel Sherrill |
moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it …
4.104.114.84.95
@e7a36a9
09/08/96 16:21:48 |
Joel Sherrill |
Ada task stack size minimize is twice that for regular pthreads.
4.104.114.84.95
@ed5a518
09/08/96 16:21:16 |
Joel Sherrill |
moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be …
4.104.114.84.95
@f198c63
09/06/96 18:11:41 |
Joel Sherrill |
new file for MIPS port by Craig Lebakken (lebakken@…) and …
4.104.114.84.95
@7fea679b
09/06/96 15:16:19 |
Joel Sherrill |
changed _TOD_Is_set from a function to a boolean variable
4.104.114.84.95
@65c421f
09/05/96 20:45:05 |
Joel Sherrill |
default thread attributes: default value for inheritsched changed from …
4.104.114.84.95
@297be5c
09/05/96 20:41:10 |
Joel Sherrill |
pthread_mutex_setprioceiling: fixed bug where returned priority was
4.104.114.84.95
@9a5cbef0
09/05/96 20:29:07 |
Joel Sherrill |
nanosleep: negative value for tv_sec is no longer an error. It now
is …
4.104.114.84.95
@62bf651f
08/29/96 16:39:01 |
Joel Sherrill |
new file to support GNU Ada.
currently the only routine in this file …
4.104.114.84.95
@b5c04b6
08/27/96 15:19:51 |
Joel Sherrill |
fixed typo .. changed == to !=
4.104.114.84.95
@5a234809
08/27/96 15:19:33 |
Joel Sherrill |
check that we were passed a valid mutex and ignore errors from the …
4.104.114.84.95
@0b710dbb
08/23/96 14:47:58 |
Mark.Johannes |
pthread_create: changed EINVAL for no more threads back to EAGAIN
4.104.114.84.95
@c5c5f8c
08/19/96 15:30:25 |
Mark.Johannes |
Changed all EFAULTs to EINVALs
4.104.114.84.95
@02f041e
08/19/96 15:27:37 |
Mark.Johannes |
pthread_mutex_init: added error messages for NULL mutex and EBUSY
4.104.114.84.95
@cd3868cd
08/15/96 21:09:02 |
Joel Sherrill |
updates from Tony Bennett (tbennett@…)
4.104.114.84.95
@0600e86f
08/15/96 21:05:21 |
Joel Sherrill |
_Thread_Start_multitasking: added code to initialize the floating …
4.104.114.84.95
@9ac3e76
08/15/96 19:38:46 |
Mark.Johannes |
changed ENOMEM error message
4.104.114.84.95
@f3e19146
08/15/96 18:58:09 |
Joel Sherrill |
clock_gettime: changed assert condition to a standard error code
4.104.114.84.95
@b03ab630
08/15/96 18:57:07 |
Joel Sherrill |
sched_rr_get_interval: converted assert condition into a standard …
4.104.114.84.95
@57dae56
08/15/96 18:56:09 |
Joel Sherrill |
added constant to indicate there is no mutex associated with this …
4.104.114.84.95
@de45ddc
08/15/96 16:29:00 |
Mark.Johannes |
pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO
4.104.114.84.95
@948721c
08/15/96 16:24:44 |
Mark.Johannes |
pthread_kill: moved check for SA_SIGINFO to allow for validation of …
4.104.114.84.95
@48e685c
08/15/96 16:22:59 |
Mark.Johannes |
fixed typo for NOTSUP -> ENOTSUP
4.104.114.84.95
@4e63ae5
08/14/96 17:20:45 |
Mark.Johannes |
commented of ENOTSUP until fixed in newlib
4.104.114.84.95
@aae1c932
08/14/96 17:20:03 |
Mark.Johannes |
pthread_cond_timedwait: added error cases for abstime
4.104.114.84.95
@dce801d
08/13/96 21:32:49 |
Mark.Johannes |
pthread_cond_destroy: added enable dispatch to EBUSY case
4.104.114.84.95
@95b76bc
08/13/96 21:10:06 |
Mark.Johannes |
pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First
4.104.114.84.95
@456b3769
08/13/96 20:50:54 |
Mark.Johannes |
pthread_cond_destroy: EBUSY case now uses Thread_queue_First
4.104.114.84.95
@c53eb2c3
08/13/96 20:46:10 |
Mark.Johannes |
removed count from Thread_queue_Control
4.104.114.84.95
@a66fcc5
08/13/96 20:43:51 |
Mark.Johannes |
removed Thread_queue_Get_number_waiting
4.104.114.84.95
@392b35e
08/13/96 20:38:30 |
Joel Sherrill |
deleted a line for spacing correction
4.104.114.84.95
@48b40d8
08/13/96 19:53:51 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: changed status of lock and …
4.104.114.84.95
@76f03c6
08/13/96 19:03:29 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: fixed the timeout sequence.
4.104.114.84.95
@b2e8026
08/13/96 15:43:12 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@f48c9068
08/13/96 14:24:00 |
Joel Sherrill |
removed errors for TOD not set yet.
made nanosleep return -1/EINTR …
4.104.114.84.95
@aac34f7b
08/13/96 14:23:16 |
Joel Sherrill |
added page break before sysconf()
4.104.114.84.95
@1087564
08/12/96 20:59:41 |
Joel Sherrill |
clock_getres: added error check for NULL pointer being passed in.
4.104.114.84.95
@3fbfbcd
08/12/96 20:48:13 |
Joel Sherrill |
sleep: wrong page number
4.104.114.84.95
@702a31c
08/12/96 20:08:36 |
Joel Sherrill |
removed comment about NO_UNINITIALIZED_WARNINGS since that macro
no …
4.104.114.84.95
@5f08fd6
08/12/96 19:55:09 |
Joel Sherrill |
nanosleep: verify rqtp parameter is non-NULL.
nanosleep: return 0 …
4.104.114.84.95
@40cfab47
08/12/96 19:19:03 |
Joel Sherrill |
time: It is not an error if the TOD is not set.
4.104.114.84.95
@9b77fee
08/12/96 19:00:12 |
Mark.Johannes |
Wait_support: removed the calls to mutex core to posix status codes
4.104.114.84.95
@3b97b7a0
08/12/96 18:58:12 |
Mark.Johannes |
mutex.h: removes the promotion of core status code to POSXI status codes
4.104.114.84.95
@1402ee25
08/12/96 18:56:04 |
Joel Sherrill |
fixed spacing ; moved a dummy MP support routine to clean up printout.
4.104.114.84.95
@c7a9c66
08/12/96 18:06:27 |
Joel Sherrill |
_POSIX_Mutex_Get: made null id an error
4.104.114.84.95
@ccdf4c57
08/12/96 18:05:47 |
Joel Sherrill |
pthread_mutex_getprioceiling: added error check for null old_ceiling
4.104.114.84.95
@b1af454
08/12/96 17:41:37 |
Mark.Johannes |
mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status
4.104.114.84.95
@af04a791
08/12/96 17:40:56 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: added …
4.104.114.84.95
@cdcea6ce
08/12/96 17:21:04 |
Mark.Johannes |
_POSIX_Condition_variables_Signal_support: added setting mutex back to …
4.104.114.84.95
