# # ChangeLog for c/src/exec in rtems # # Generated by Trac 1.2.1.dev0 # 05/06/24 15:19:44 Thu, 23 Dec 1999 22:07:11 GMT Jennifer Averett [d4548d1] * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) + Made work + Added checks for valid attribute maxmsg and msgsize + ... Thu, 23 Dec 1999 22:05:25 GMT Jennifer Averett [e1786ee3] * c/src/exec/posix/src/mqueueclose.c (modified) * cpukit/posix/src/mqueueclose.c (modified) + Fixed errno response to match the POSIX manual. Tue, 21 Dec 1999 20:29:40 GMT Joel Sherrill [ed46b47] * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.h (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.h (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.h (modified) Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to ... Tue, 21 Dec 1999 15:04:48 GMT Joel Sherrill [9ba1f0a] * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) Patch rtems-rc-19991203-9.diff from Ralf Corsepius [db3e0108] * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/sapi/Makefile.am (modified) Patch rtems-rc-19991203-6.diff from Ralf Corsepius [8b91282] * c/src/exec/score/cpu/sh/rtems/score/iosh7045.h (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libcpu/sh/sh7045/include/io_types.h (modified) * c/src/lib/libcpu/sh/sh7045/include/iosh7045.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * make/custom/gensh2.cfg (modified) Patch rtems-rc-19991203-5.diff from Ralf Corsepius [c629812] * c/src/exec/libcsupport/src/ctermid.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libc/ctermid.c (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libmisc/monitor/mon-symbols.c (modified) * cpukit/libcsupport/src/ctermid.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) Removed warnings. Mon, 13 Dec 1999 21:21:31 GMT Joel Sherrill [da8ae79b] * c/src/exec/libcsupport/src/getcwd.c (modified) * c/src/lib/libbsp/i386/pc386/3c509/3c509.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c (modified) * c/src/lib/libbsp/i386/shared/comm/i386-stub-glue.c (modified) * c/src/lib/libbsp/i386/shared/comm/uart.c (modified) * c/src/lib/libc/getcwd.c (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * cpukit/libcsupport/src/getcwd.c (modified) Warning removal patch from Philip A. Prindeville . Mon, 13 Dec 1999 20:06:27 GMT Joel Sherrill [f9669ce5] * c/src/exec/score/cpu/sh/rtems/score/iosh7032.h (modified) * c/src/lib/libcpu/sh/sh7032/include/iosh7032.h (modified) Patch from Silverio Diquigiovanni to correct ... Mon, 13 Dec 1999 19:20:38 GMT Joel Sherrill [fc0b91c] * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) Patch from Eric Norum to make the NTP handler a ... Mon, 13 Dec 1999 17:22:18 GMT Joel Sherrill [6b79a071] * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) Patch from Jepsen Hans Peter to use ... Mon, 13 Dec 1999 17:03:37 GMT Joel Sherrill [809f4451] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Correction from Eric Norum for timeout in TFTP driver following bug ... Mon, 13 Dec 1999 15:29:20 GMT Joel Sherrill [7d91d72] * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/src/semcreate.c (modified) * c/src/exec/rtems/src/semtranslatereturncode.c (modified) * c/src/exec/score/src/coremutexseize.c (modified) * c/src/exec/score/src/coremutexsurrender.c (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sp29/Makefile.am (added) * c/src/tests/sptests/sp29/init.c (added) * c/src/tests/sptests/sp29/sp29.doc (added) * c/src/tests/sptests/sp29/sp29.scn (added) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/sp29/Makefile.am (added) * testsuites/sptests/sp29/init.c (added) * testsuites/sptests/sp29/sp29.doc (added) * testsuites/sptests/sp29/sp29.scn (added) First attempt at adding simple binary semaphore in addition to the ... Mon, 13 Dec 1999 14:49:38 GMT Joel Sherrill [d9230ea] * c/src/exec/libcsupport/src/error.c (modified) * c/src/lib/libc/error.c (modified) * cpukit/libcsupport/src/error.c (modified) Added RTEMS_IO_ERROR. Fri, 03 Dec 1999 13:31:56 GMT Joel Sherrill [fc81cc9] * aclocal/check-bsp-cache.m4 (added) * c/src/exec/score/cpu/powerpc/configure.in (added) Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius ... Fri, 03 Dec 1999 13:25:00 GMT Joel Sherrill [4090ebe] * Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/score/cpu/configure.in (deleted) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/configure.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/init.c (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * testsuites/psxtests/psxsem01/init.c (modified) Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius ... Thu, 02 Dec 1999 17:45:14 GMT Joel Sherrill [43283456] * c/src/exec/score/cpu/Makefile.am (added) * c/src/exec/score/cpu/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/Makefile.am (added) * c/src/exec/score/cpu/powerpc/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (added) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (added) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (added) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (added) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.in (deleted) * cpukit/score/cpu/Makefile.am (added) * cpukit/score/cpu/powerpc/Makefile.am (added) Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius ... Thu, 02 Dec 1999 14:31:19 GMT Joel Sherrill [acc25ee] * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.in (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/c_isr.inl (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.c (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.h (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu_asm.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.in (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/README (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/TODO (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/c_isr.inl (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.c (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.h (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu_asm.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/ppccache.c (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/rtems.S (added) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/console.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/console_reserve_resources.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/console_reserve_resources.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/bootloader/README (added) * c/src/lib/libbsp/powerpc/shared/bootloader/bootldr.h (added) * c/src/lib/libbsp/powerpc/shared/bootloader/em86.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/em86real.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/exception.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/head.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/lib.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/mm.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.h (added) * c/src/lib/libbsp/powerpc/shared/bootloader/ppcboot.lds (added) * c/src/lib/libbsp/powerpc/shared/bootloader/zlib.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/zlib.h (added) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/clock/p_clock.c (added) * c/src/lib/libbsp/powerpc/shared/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/console/console.c (moved) * c/src/lib/libbsp/powerpc/shared/console/consoleIo.h (added) * c/src/lib/libbsp/powerpc/shared/console/inch.c (added) * c/src/lib/libbsp/powerpc/shared/console/keyboard.h (added) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (added) * c/src/lib/libbsp/powerpc/shared/console/uart.c (added) * c/src/lib/libbsp/powerpc/shared/console/uart.h (added) * c/src/lib/libbsp/powerpc/shared/dec21140/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/dec21140/dec21140.c (added) * c/src/lib/libbsp/powerpc/shared/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (added) * c/src/lib/libbsp/powerpc/shared/include/nvram.h (added) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/irq/i8259.c (added) * c/src/lib/libbsp/powerpc/shared/irq/irq.c (added) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (added) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (added) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (added) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (added) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.h (added) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (added) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.h (added) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (added) * c/src/lib/libbsp/powerpc/shared/pci/pci.h (added) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/residual/pnp.h (added) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (added) * c/src/lib/libbsp/powerpc/shared/residual/residual.h (added) * c/src/lib/libbsp/powerpc/shared/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/start/start.S (added) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors.S (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors.h (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors_init.c (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/c_isr.inl (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.c (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.h (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu_asm.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/README (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/TODO (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/c_isr.inl (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.c (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.h (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu_asm.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ppccache.c (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems.S (added) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/asm_utils.S (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/mmuAsm.S (added) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.in (added) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (added) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.in (added) * c/src/lib/libcpu/powerpc/new_exception_processing/c_isr.inl (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.c (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.h (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/README (added) * c/src/lib/libcpu/powerpc/old-exceptions/TODO (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu.c (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/ppccache.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.in (added) * c/src/lib/libcpu/powerpc/old_exception_processing/README (added) * c/src/lib/libcpu/powerpc/old_exception_processing/TODO (added) * c/src/lib/libcpu/powerpc/old_exception_processing/c_isr.inl (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.h (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (added) * c/src/lib/libcpu/powerpc/old_exception_processing/ppccache.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/rtems.S (added) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/cpu.h (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme2307.cfg (modified) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Thu, 02 Dec 1999 14:10:14 GMT Joel Sherrill [4cf56006] * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (deleted) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Thu, 02 Dec 1999 14:00:01 GMT Joel Sherrill [e4ab88f] * c/src/exec/score/cpu/powerpc/mpc750/c_isr.inl (deleted) * c/src/exec/score/cpu/powerpc/mpc750/cpu.c (deleted) * c/src/exec/score/cpu/powerpc/mpc750/cpu.h (deleted) * c/src/exec/score/cpu/powerpc/mpc750/cpu_asm.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/README (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/bootldr.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/em86.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/em86real.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/exception.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/head.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/lib.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/misc.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/mm.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/pci.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/pci.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/ppcboot.lds (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/zlib.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/bootloader/zlib.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/clock/p_clock.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/consoleIo.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/inch.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/keyboard.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/polled_io.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/uart.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/uart.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/dec21140/dec21140.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/include/bsp.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/include/nvram.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/i8259.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/irq.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/irq.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/irq_asm.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/irq/irq_init.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/openpic/openpic.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/openpic/openpic.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/pci/pci.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/pci/pci.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/residual/pnp.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/residual/residual.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/residual/residual.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/start/start.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/startup/bspstart.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors.S (deleted) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors.h (deleted) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors_init.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/README (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/bootldr.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/em86.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/em86real.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/exception.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/head.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/lib.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/misc.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/mm.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/pci.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/pci.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/ppcboot.lds (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/zlib.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/zlib.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/p_clock.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/consoleIo.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/inch.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/keyboard.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/polled_io.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/uart.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/uart.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/dec21140/dec21140.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/nvram.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/i8259.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq_asm.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq_init.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/openpic.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/openpic.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/pci.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/pci.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/pnp.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/residual.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/residual.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/start.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspstart.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors.S (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors.h (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors_init.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/NOTES (deleted) * c/src/lib/libbsp/powerpc/mvme2307/README (deleted) * c/src/lib/libbsp/powerpc/mvme2307/boot/start.S (deleted) * c/src/lib/libbsp/powerpc/mvme2307/bsp_specs (deleted) * c/src/lib/libbsp/powerpc/mvme2307/clock/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/mvme2307/clock/ckinit.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/console/console.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/console/printk.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/include/bsp.h (deleted) * c/src/lib/libbsp/powerpc/mvme2307/include/coverhd.h (deleted) * c/src/lib/libbsp/powerpc/mvme2307/network/network.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/nvram/nvram.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/NOTES (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/interrupts.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/isa_interrupts.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/pci/pci.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspclean.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspstart.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/linkcmds (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/main.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/startup/setvec.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/timer/timer.c (deleted) * c/src/lib/libbsp/powerpc/mvme2307/times (deleted) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc750/clock/c_clock.c (deleted) * c/src/lib/libcpu/powerpc/mpc750/clock/c_clock.h (deleted) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc750/exceptions/asm_utils.S (deleted) * c/src/lib/libcpu/powerpc/mpc750/exceptions/raw_exception.c (deleted) * c/src/lib/libcpu/powerpc/mpc750/exceptions/raw_exception.h (deleted) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (deleted) * c/src/lib/libcpu/powerpc/mpc750/mmu/bat.c (deleted) * c/src/lib/libcpu/powerpc/mpc750/mmu/bat.h (deleted) * c/src/lib/libcpu/powerpc/mpc750/mmu/mmuAsm.S (deleted) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (deleted) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Thu, 02 Dec 1999 13:54:30 GMT Joel Sherrill [5554279] * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/README (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/TODO (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/c_isr.inl (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/cpu.c (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/cpu.h (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/cpu_asm.S (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/irq_stub.S (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/ppccache.c (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/rtems.S (deleted) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Wed, 01 Dec 1999 16:00:38 GMT Joel Sherrill [5d3da15b] * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) Removed debugging printfs. Wed, 01 Dec 1999 15:54:17 GMT Joel Sherrill [017061c] * c/src/exec/libnetworking/lib/tftpDriver.c (modified) * c/src/libnetworking/lib/tftpDriver.c (modified) * cpukit/libnetworking/lib/tftpDriver.c (modified) Patch from Eric Norum to fix a spot in the tftp ... Wed, 01 Dec 1999 15:05:26 GMT Joel Sherrill [955a9ba7] * c/src/exec/score/cpu/a29k/Makefile.am (added) * c/src/exec/score/cpu/a29k/Makefile.in (deleted) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (added) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/hppa1.1/Makefile.am (added) * c/src/exec/score/cpu/hppa1.1/Makefile.in (deleted) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (added) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/i386/Makefile.am (added) * c/src/exec/score/cpu/i386/Makefile.in (deleted) * c/src/exec/score/cpu/i386/rtems/Makefile.am (added) * c/src/exec/score/cpu/i386/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/mips/Makefile.am (added) * c/src/exec/score/cpu/mips/rtems/Makefile.am (added) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/mips64orion/Makefile.am (added) * c/src/exec/score/cpu/mips64orion/Makefile.in (deleted) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (added) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/Makefile.am (added) * c/src/exec/score/cpu/no_cpu/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (added) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (deleted) * cpukit/score/cpu/a29k/Makefile.am (added) * cpukit/score/cpu/hppa1.1/Makefile.am (added) * cpukit/score/cpu/i386/Makefile.am (added) * cpukit/score/cpu/mips/Makefile.am (added) * cpukit/score/cpu/mips64orion/Makefile.am (added) * cpukit/score/cpu/no_cpu/Makefile.am (added) Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius ... Wed, 01 Dec 1999 14:46:02 GMT Joel Sherrill [1972b1e] * c/src/exec/score/cpu/a29k/configure.in (added) * c/src/exec/score/cpu/hppa1.1/configure.in (added) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/i386/configure.in (added) * c/src/exec/score/cpu/i386/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/mips/configure.in (added) * c/src/exec/score/cpu/mips64orion/configure.in (added) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/configure.in (added) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (deleted) Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius ... Wed, 01 Dec 1999 14:31:36 GMT Joel Sherrill [7656140] * c/src/exec/score/cpu/a29k/wrap/Makefile.in (deleted) Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius ... Wed, 01 Dec 1999 14:22:12 GMT Joel Sherrill [ccf8925b] * c/src/exec/score/cpu/configure.in (modified) * c/src/exec/score/cpu/i960/Makefile.am (added) * c/src/exec/score/cpu/i960/Makefile.in (deleted) * c/src/exec/score/cpu/i960/configure.in (added) * c/src/exec/score/cpu/i960/rtems/Makefile.am (added) * c/src/exec/score/cpu/i960/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/Makefile.am (added) * c/src/exec/score/cpu/m68k/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/configure.in (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/sh/Makefile.am (added) * c/src/exec/score/cpu/sh/Makefile.in (deleted) * c/src/exec/score/cpu/sh/configure.in (added) * c/src/exec/score/cpu/sh/rtems/Makefile.am (added) * c/src/exec/score/cpu/sh/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/Makefile.am (added) * c/src/exec/score/cpu/sparc/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/configure.in (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/unix/Makefile.am (added) * c/src/exec/score/cpu/unix/Makefile.in (deleted) * c/src/exec/score/cpu/unix/configure.in (added) * c/src/exec/score/cpu/unix/rtems/Makefile.am (added) * c/src/exec/score/cpu/unix/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (deleted) * cpukit/score/cpu/i960/Makefile.am (added) * cpukit/score/cpu/m68k/Makefile.am (added) * cpukit/score/cpu/sh/Makefile.am (added) * cpukit/score/cpu/sparc/Makefile.am (added) * cpukit/score/cpu/unix/Makefile.am (added) Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius ... Wed, 01 Dec 1999 14:12:58 GMT Joel Sherrill [4a3757f] * c/src/exec/score/cpu/i960/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (deleted) Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius ... Tue, 30 Nov 1999 22:14:28 GMT Joel Sherrill [42881534] * c/src/exec/libnetworking/net/if_ppp.h (added) * c/src/exec/libnetworking/net/ppp-comp.h (added) * c/src/libnetworking/net/if_ppp.h (added) * c/src/libnetworking/net/ppp-comp.h (added) * cpukit/libnetworking/net/if_ppp.h (added) * cpukit/libnetworking/net/ppp-comp.h (added) Added missing files from PPP port. Tue, 30 Nov 1999 22:12:50 GMT Joel Sherrill [d0950ad] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/net/ppp_defs.h (added) * c/src/exec/libnetworking/sys/syslog.h (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/net/ppp_defs.h (added) * c/src/libnetworking/pppd/Makefile.in (added) * c/src/libnetworking/pppd/README (added) * c/src/libnetworking/pppd/STATUS (added) * c/src/libnetworking/pppd/auth.c (added) * c/src/libnetworking/pppd/cbcp.c (added) * c/src/libnetworking/pppd/cbcp.h (added) * c/src/libnetworking/pppd/ccp.c (added) * c/src/libnetworking/pppd/ccp.h (added) * c/src/libnetworking/pppd/chap.c (added) * c/src/libnetworking/pppd/chap.h (added) * c/src/libnetworking/pppd/chap_ms.c (added) * c/src/libnetworking/pppd/chap_ms.h (added) * c/src/libnetworking/pppd/chat.c (added) * c/src/libnetworking/pppd/demand.c (added) * c/src/libnetworking/pppd/fsm.c (added) * c/src/libnetworking/pppd/fsm.h (added) * c/src/libnetworking/pppd/ipcp.c (added) * c/src/libnetworking/pppd/ipcp.h (added) * c/src/libnetworking/pppd/ipxcp.c (added) * c/src/libnetworking/pppd/ipxcp.h (added) * c/src/libnetworking/pppd/lcp.c (added) * c/src/libnetworking/pppd/lcp.h (added) * c/src/libnetworking/pppd/magic.c (added) * c/src/libnetworking/pppd/magic.h (added) * c/src/libnetworking/pppd/main.c (added) * c/src/libnetworking/pppd/md4.c (added) * c/src/libnetworking/pppd/md4.h (added) * c/src/libnetworking/pppd/md5.c (added) * c/src/libnetworking/pppd/md5.h (added) * c/src/libnetworking/pppd/options.c (added) * c/src/libnetworking/pppd/patchlevel.h (added) * c/src/libnetworking/pppd/pathnames.h (added) * c/src/libnetworking/pppd/ppp_tty.c (added) * c/src/libnetworking/pppd/pppd.h (added) * c/src/libnetworking/pppd/rtems-ppp.c (added) * c/src/libnetworking/pppd/upap.c (added) * c/src/libnetworking/pppd/upap.h (added) * c/src/libnetworking/sys/syslog.h (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/net/ppp_defs.h (added) * cpukit/libnetworking/sys/syslog.h (modified) * cpukit/pppd/README (added) * cpukit/pppd/STATUS (added) * cpukit/pppd/auth.c (added) * cpukit/pppd/cbcp.c (added) * cpukit/pppd/cbcp.h (added) * cpukit/pppd/ccp.c (added) * cpukit/pppd/ccp.h (added) * cpukit/pppd/chap.c (added) * cpukit/pppd/chap.h (added) * cpukit/pppd/chap_ms.c (added) * cpukit/pppd/chap_ms.h (added) * cpukit/pppd/chat.c (added) * cpukit/pppd/demand.c (added) * cpukit/pppd/fsm.c (added) * cpukit/pppd/fsm.h (added) * cpukit/pppd/ipcp.c (added) * cpukit/pppd/ipcp.h (added) * cpukit/pppd/ipxcp.c (added) * cpukit/pppd/ipxcp.h (added) * cpukit/pppd/lcp.c (added) * cpukit/pppd/lcp.h (added) * cpukit/pppd/magic.c (added) * cpukit/pppd/magic.h (added) * cpukit/pppd/md4.c (added) * cpukit/pppd/md4.h (added) * cpukit/pppd/md5.c (added) * cpukit/pppd/md5.h (added) * cpukit/pppd/options.c (added) * cpukit/pppd/patchlevel.h (added) * cpukit/pppd/pathnames.h (added) * cpukit/pppd/pppd.h (added) * cpukit/pppd/upap.c (added) * cpukit/pppd/upap.h (added) Added port of ppp-2.3.5 from Tomasz Domin of ComArch ... Tue, 30 Nov 1999 16:52:21 GMT Joel Sherrill [1563d8c] * c/src/exec/libcsupport/src/libio.c (modified) * c/src/lib/libc/libio.c (modified) * cpukit/libcsupport/src/libio.c (modified) Removed duplicate definition of rtems_filesystem_umask. Tue, 30 Nov 1999 13:46:28 GMT Joel Sherrill [e4b25c4] * c/src/exec/libcsupport/src/ttyname.c (modified) * c/src/exec/libcsupport/src/ttyname_r.c (modified) * c/src/lib/libc/ttyname.c (modified) * c/src/lib/libc/ttyname_r.c (modified) * cpukit/libcsupport/src/ttyname.c (modified) * cpukit/libcsupport/src/ttyname_r.c (modified) Corrected so they would compile with POSIX disabled. Mon, 29 Nov 1999 15:45:11 GMT Joel Sherrill [1d9a2fc] * c/make/configure.in (modified) * c/src/exec/posix/include/rtems/posix/mutexmp.h (modified) * c/src/exec/posix/include/rtems/posix/semaphoremp.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/console.c (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/console.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (modified) * c/src/tests/Makefile.am (modified) * c/src/tests/itrontests/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.in (modified) * c/src/tests/itrontests/itronmbf01/Makefile.in (modified) * c/src/tests/itrontests/itronmbox01/Makefile.in (modified) * c/src/tests/itrontests/itronsem01/Makefile.in (modified) * c/src/tests/itrontests/itrontask01/Makefile.in (modified) * c/src/tests/itrontests/itrontask02/Makefile.in (modified) * c/src/tests/itrontests/itrontask03/Makefile.in (modified) * c/src/tests/itrontests/itrontask04/Makefile.in (modified) * c/src/tests/itrontests/itrontime01/Makefile.in (modified) * c/src/tests/mptests/Makefile.am (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (deleted) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/tmitrontests/Makefile.am (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmitrontests/include/timesys.h (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.in (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * cpukit/posix/include/rtems/posix/mutexmp.h (modified) * cpukit/posix/include/rtems/posix/semaphoremp.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * testsuites/Makefile.am (modified) * testsuites/itrontests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/tmitrontests/Makefile.am (modified) * testsuites/tmitrontests/include/timesys.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius [64f55e7] * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mutexmp.c (modified) * c/src/exec/posix/src/mutexsetprioceiling.c (modified) * c/src/exec/posix/src/mutexunlock.c (modified) * c/src/exec/posix/src/semaphoremp.c (modified) * c/src/exec/posix/src/sempost.c (modified) * c/src/exec/posix/src/semunlink.c (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mutexmp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/semaphoremp.c (modified) * cpukit/posix/src/sempost.c (modified) * cpukit/posix/src/semunlink.c (modified) Made sure POSIX would build with MP enabled. Mon, 29 Nov 1999 15:10:30 GMT Joel Sherrill [3dfe0b27] * c/src/exec/libcsupport/src/mount.c (modified) * c/src/lib/libc/mount.c (modified) * cpukit/libcsupport/src/mount.c (modified) Fixed spacing. Tue, 23 Nov 1999 16:02:26 GMT Joel Sherrill [63bdbbd] * c/src/exec/score/cpu/a29k/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (added) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (added) * c/src/exec/score/cpu/i386/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/Makefile.in (added) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i386/wrap/Makefile.in (added) * c/src/exec/score/cpu/i960/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/Makefile.in (added) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/i960/wrap/Makefile.in (added) * c/src/exec/score/cpu/m68k/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (added) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (added) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (added) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (added) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (added) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (added) * c/src/exec/score/cpu/sh/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/Makefile.in (added) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sh/wrap/Makefile.in (added) * c/src/exec/score/cpu/sparc/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (added) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (added) * c/src/exec/score/cpu/unix/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/Makefile.in (added) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (added) * c/src/exec/score/cpu/unix/wrap/Makefile.in (added) Readding files mistakenly removed. Tue, 23 Nov 1999 15:53:09 GMT Joel Sherrill [49da88c] * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/sapi/Makefile.am (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/host.cfg.in (modified) Patch rtems-rc-19991117-16.diff from Ralf Corsepius [748cdca9] * c/src/exec/score/cpu/powerpc/Makefile.in (added) Readding Makefile.in's accidentally removed. Tue, 23 Nov 1999 14:10:05 GMT Joel Sherrill [23e3f642] * automake/lib.am (added) * c/src/exec/librpc/src/Makefile.am (added) * c/src/librdbg/src/i386/any/Makefile.am (added) * c/src/librdbg/src/i386/pc386/Makefile.am (added) * c/src/librpc/src/Makefile.am (added) * c/src/librtems++/src/Makefile.am (added) * c/src/tests/samples/sample.am (added) * c/src/tests/sptests/spsize/size.scn (added) * c/src/tests/tmtests/tmtests.am (added) * c/src/wrapup/Makefile.am (added) * cpukit/librpc/src/Makefile.am (added) * testsuites/samples/sample.am (added) * testsuites/sptests/spsize/size.scn (added) * testsuites/tmtests/tmtests.am (added) Missed in previous automake conversion patches from Ralf Corsepius ... Tue, 23 Nov 1999 13:57:02 GMT Joel Sherrill [9f4868c] * Makefile.am (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * cpukit/httpd/Makefile.in (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/pc386.cfg (modified) * testsuites/psxtests/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) Miscellaneous patches from Ralf Corsepius ... Tue, 23 Nov 1999 13:29:04 GMT Joel Sherrill [fba12eb6] * c/src/exec/itron/src/Makefile.am (added) * c/src/exec/itron/src/Makefile.in (deleted) * c/src/exec/posix/Makefile.am (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (added) * c/src/exec/posix/optman/Makefile.in (deleted) * c/src/exec/posix/src/Makefile.am (added) * c/src/exec/posix/src/Makefile.in (deleted) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (added) * c/src/exec/rtems/optman/Makefile.in (deleted) * c/src/exec/rtems/src/Makefile.am (added) * c/src/exec/rtems/src/Makefile.in (deleted) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (added) * c/src/exec/sapi/optman/Makefile.in (deleted) * c/src/exec/sapi/src/Makefile.am (added) * c/src/exec/sapi/src/Makefile.in (deleted) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (deleted) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/i386/Makefile.in (deleted) * c/src/exec/score/cpu/i386/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/i386/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/i960/Makefile.in (deleted) * c/src/exec/score/cpu/i960/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/i960/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/mips64orion/Makefile.in (deleted) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (deleted) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/sh/Makefile.in (deleted) * c/src/exec/score/cpu/sh/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/sh/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (deleted) * c/src/exec/score/cpu/unix/Makefile.in (deleted) * c/src/exec/score/cpu/unix/rtems/Makefile.in (deleted) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (deleted) * c/src/exec/score/cpu/unix/wrap/Makefile.in (deleted) * c/src/exec/score/include/rtems/score/Makefile.am (moved) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/src/Makefile.am (added) * c/src/exec/score/src/Makefile.in (deleted) * c/src/exec/wrapup/itron/Makefile.am (added) * c/src/exec/wrapup/itron/Makefile.in (deleted) * c/src/exec/wrapup/posix/Makefile.am (added) * c/src/exec/wrapup/posix/Makefile.in (deleted) * c/src/exec/wrapup/rtems/Makefile.am (added) * c/src/exec/wrapup/rtems/Makefile.in (deleted) * c/src/optman/rtems/Makefile.am (added) * c/src/optman/sapi/Makefile.am (added) * cpukit/itron/src/Makefile.am (added) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/src/Makefile.am (added) * cpukit/rtems/src/Makefile.am (added) * cpukit/sapi/src/Makefile.am (added) * cpukit/score/src/Makefile.am (added) Patch rtems-rc-19991117-11.diff from Ralf Corsepius [7e642ba] * c/src/exec/libcsupport/src/Makefile.am (added) * c/src/lib/configure.in (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/boot/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libc/Makefile.am (added) * c/src/lib/libc/Makefile.in (deleted) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) Patch rtems-rc-19991117-9.diff from Ralf Corsepius [101e9b0] * c/src/exec/posix/src/semaphoredeletesupp.c (modified) * c/src/exec/posix/src/semdestroy.c (modified) * cpukit/posix/src/semaphoredeletesupp.c (modified) * cpukit/posix/src/semdestroy.c (modified) Fixed dispatching and cleaned up code. Mon, 22 Nov 1999 16:13:22 GMT Jennifer Averett [cb3c1718] * c/src/exec/posix/src/semunlink.c (modified) * cpukit/posix/src/semunlink.c (modified) + Corrected enable/disable of dispatch. + Cleaned up code. Mon, 22 Nov 1999 16:12:19 GMT Jennifer Averett [2545646] * c/src/exec/posix/src/semopen.c (modified) * cpukit/posix/src/semopen.c (modified) + Updated comments. + Corrected enable/disable of dispatch. Mon, 22 Nov 1999 16:11:35 GMT Jennifer Averett [94f81bbd] * c/src/exec/posix/src/seminit.c (modified) * cpukit/posix/src/seminit.c (modified) + Corrected bug in error check. Mon, 22 Nov 1999 16:10:25 GMT Jennifer Averett [2c3af4c5] * c/src/exec/posix/src/semclose.c (modified) * cpukit/posix/src/semclose.c (modified) + Added description of routine to comment. Mon, 22 Nov 1999 16:09:55 GMT Jennifer Averett [0ca4fc8] * c/src/exec/posix/src/semaphorewaitsupp.c (modified) * cpukit/posix/src/semaphorewaitsupp.c (modified) + Corrected error processing code. Mon, 22 Nov 1999 16:08:53 GMT Jennifer Averett [f85409c] * c/src/exec/posix/src/semaphorenametoid.c (modified) * cpukit/posix/src/semaphorenametoid.c (modified) + Added checks for NULL and NULL string names (for sem_open & ... Mon, 22 Nov 1999 16:07:02 GMT Jennifer Averett [0ebf5694] * c/src/exec/posix/src/semaphorecreatesupp.c (modified) * cpukit/posix/src/semaphorecreatesupp.c (modified) + Cleaned up comments. Mon, 22 Nov 1999 14:25:01 GMT Joel Sherrill [b7912a89] * c/src/exec/score/cpu/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/sim.h (modified) Changed name of W, X, and Y macros for fields in the Clock ... Mon, 22 Nov 1999 13:46:50 GMT Joel Sherrill [b22a19e] * c/src/exec/score/cpu/sh/ispsh7045.c (added) * c/src/exec/score/cpu/sh/rtems/score/iosh7045.h (added) * c/src/exec/score/cpu/sh/rtems/score/ispsh7045.h (added) * c/src/lib/libcpu/sh/sh7045/include/iosh7045.h (added) * c/src/lib/libcpu/sh/sh7045/include/ispsh7045.h (added) * c/src/lib/libcpu/sh/sh7045/score/ispsh7045.c (added) Adding files not added as part of merger of SH2 port. Mon, 22 Nov 1999 13:41:11 GMT Joel Sherrill [9608320] * aclocal/check-cpu.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * automake/local.am (modified) * c/src/Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/libchip/network/Makefile.am (added) * c/src/libchip/network/Makefile.in (deleted) * c/src/libchip/rtc/Makefile.am (added) * c/src/libchip/rtc/Makefile.in (deleted) * c/src/libchip/serial/Makefile.am (added) * c/src/libchip/serial/Makefile.in (deleted) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (added) * c/src/libmisc/cpuuse/Makefile.in (deleted) * c/src/libmisc/dummy/Makefile.am (added) * c/src/libmisc/dummy/Makefile.in (deleted) * c/src/libmisc/dumpbuf/Makefile.am (added) * c/src/libmisc/dumpbuf/Makefile.in (deleted) * c/src/libmisc/monitor/Makefile.am (added) * c/src/libmisc/monitor/Makefile.in (deleted) * c/src/libmisc/rtmonuse/Makefile.am (added) * c/src/libmisc/rtmonuse/Makefile.in (deleted) * c/src/libmisc/stackchk/Makefile.am (added) * c/src/libmisc/stackchk/Makefile.in (deleted) * c/src/libmisc/untar/Makefile.am (added) * c/src/libmisc/untar/Makefile.in (deleted) * c/src/libmisc/wrapup/Makefile.am (added) * c/src/libmisc/wrapup/Makefile.in (deleted) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/directory.cfg (modified) * c/src/make/lib.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (added) * cpukit/libmisc/dummy/Makefile.am (added) * cpukit/libmisc/dumpbuf/Makefile.am (added) * cpukit/libmisc/monitor/Makefile.am (added) * cpukit/libmisc/rtmonuse/Makefile.am (added) * cpukit/libmisc/stackchk/Makefile.am (added) * cpukit/libmisc/untar/Makefile.am (added) * cpukit/libmisc/wrapup/Makefile.am (added) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/sapi/include/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.dir (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/erc32.cfg (modified) * make/directory.cfg (modified) * make/lib.cfg (modified) * make/main.cfg (modified) * testsuites/tools/generic/Makefile.am (modified) Patch rtems-rc-19991117-4.diff from Ralf Corsepius [75f2b0b] * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) Small patch (rtems-rc-19991117-5.diff) from Ralf Corsepius ... Thu, 18 Nov 1999 21:30:12 GMT Joel Sherrill [97c465c] * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) Minor cleanup to reduce the code space. Thu, 18 Nov 1999 21:22:58 GMT Joel Sherrill [4a238002] * c/configure.in (modified) * c/src/exec/score/cpu/sh/cpu.c (modified) * c/src/exec/score/cpu/sh/cpu_asm.c (modified) * c/src/exec/score/cpu/sh/cpu_isps.c (deleted) * c/src/exec/score/cpu/sh/ispsh7032.c (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/sh/rtems/score/cpu_isps.h (deleted) * c/src/exec/score/cpu/sh/rtems/score/iosh7030.h (deleted) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/README (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/README (added) * c/src/lib/libbsp/sh/gensh2/bsp_specs (added) * c/src/lib/libbsp/sh/gensh2/console/Makefile.in (moved) * c/src/lib/libbsp/sh/gensh2/include/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (added) * c/src/lib/libbsp/sh/gensh2/include/coverhd.h (added) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/start/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/start/start.S (added) * c/src/lib/libbsp/sh/gensh2/start/start.ram (added) * c/src/lib/libbsp/sh/gensh2/start/start.rom (added) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/startup/bspclean.c (added) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (added) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (added) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds (added) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.ram (added) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.rom (added) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7032/console/console.c (deleted) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/ioqueue.h (deleted) * c/src/lib/libcpu/sh/sh7032/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sh7_sci.h (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7032/score/ispsh7032.c (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/clock/ckinit.c (added) * c/src/lib/libcpu/sh/sh7045/include/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/include/io_types.h (added) * c/src/lib/libcpu/sh/sh7045/include/null.h (added) * c/src/lib/libcpu/sh/sh7045/include/sci.h (added) * c/src/lib/libcpu/sh/sh7045/include/sh7_pfc.h (added) * c/src/lib/libcpu/sh/sh7045/include/sh7_sci.h (added) * c/src/lib/libcpu/sh/sh7045/null/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/null/close.c (added) * c/src/lib/libcpu/sh/sh7045/null/cntrl.c (added) * c/src/lib/libcpu/sh/sh7045/null/init.c (added) * c/src/lib/libcpu/sh/sh7045/null/open.c (added) * c/src/lib/libcpu/sh/sh7045/null/read.c (added) * c/src/lib/libcpu/sh/sh7045/null/write.c (added) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (added) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/timer/timer.c (added) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (added) Patch from "John M. Mills" with subsequent cleanup ... Thu, 18 Nov 1999 19:55:28 GMT Jennifer Averett [c38f5f16] * c/src/exec/posix/src/seminit.c (modified) * cpukit/posix/src/seminit.c (modified) Added EINVAL for passing a NULL pointer in. Thu, 18 Nov 1999 19:50:15 GMT Jennifer Averett [105d7872] * c/src/exec/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) Added routine to remove an object from the namespace. It just clears ... Thu, 18 Nov 1999 19:43:13 GMT Jennifer Averett [17879f4] * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/semaphorenametoid.c (modified) * c/src/exec/posix/src/semopen.c (modified) * c/src/exec/posix/src/semunlink.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/semaphorenametoid.c (modified) * cpukit/posix/src/semopen.c (modified) * cpukit/posix/src/semunlink.c (modified) + Debuged to the point that you could open, unlink and close a ... Thu, 18 Nov 1999 19:41:34 GMT Jennifer Averett [c9ae846] * c/src/exec/posix/inline/rtems/posix/semaphore.inl (modified) * cpukit/posix/inline/rtems/posix/semaphore.inl (modified) Added a routine to remove a semaphore name from its namespace. Wed, 17 Nov 1999 20:44:13 GMT Jennifer Averett [40fe60a3] * c/src/exec/score/src/objectclearname.c (modified) * cpukit/score/src/objectclearname.c (modified) Comment added. Wed, 17 Nov 1999 17:51:34 GMT Joel Sherrill [08311cc3] * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/clockdrv.h (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/iosupp.h (modified) * c/src/exec/libcsupport/include/motorola/mc68230.h (modified) * c/src/exec/libcsupport/include/rtems/libcsupport.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/include/timerdrv.h (modified) * c/src/exec/libcsupport/include/vmeintr.h (modified) * c/src/exec/libcsupport/include/zilog/z8036.h (modified) * c/src/exec/libcsupport/include/zilog/z8530.h (modified) * c/src/exec/libcsupport/include/zilog/z8536.h (modified) * c/src/exec/libcsupport/src/__brk.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/__sbrk.c (modified) * c/src/exec/libcsupport/src/__times.c (modified) * c/src/exec/libcsupport/src/access.c (modified) * c/src/exec/libcsupport/src/base_fs.c (modified) * c/src/exec/libcsupport/src/cfgetispeed.c (modified) * c/src/exec/libcsupport/src/cfgetospeed.c (modified) * c/src/exec/libcsupport/src/cfsetispeed.c (modified) * c/src/exec/libcsupport/src/cfsetospeed.c (modified) * c/src/exec/libcsupport/src/chdir.c (modified) * c/src/exec/libcsupport/src/chmod.c (modified) * c/src/exec/libcsupport/src/chown.c (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/ctermid.c (modified) * c/src/exec/libcsupport/src/dup.c (modified) * c/src/exec/libcsupport/src/dup2.c (modified) * c/src/exec/libcsupport/src/eval.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fs_null_handlers.c (modified) * c/src/exec/libcsupport/src/fstat.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/getdents.c (modified) * c/src/exec/libcsupport/src/hosterr.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/libio_sockets.c (modified) * c/src/exec/libcsupport/src/link.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/lstat.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/mkdir.c (modified) * c/src/exec/libcsupport/src/mkfifo.c (modified) * c/src/exec/libcsupport/src/mknod.c (modified) * c/src/exec/libcsupport/src/mount.c (modified) * c/src/exec/libcsupport/src/no_libc.c (modified) * c/src/exec/libcsupport/src/open.c (modified) * c/src/exec/libcsupport/src/pathconf.c (modified) * c/src/exec/libcsupport/src/pipe.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/readlink.c (modified) * c/src/exec/libcsupport/src/rewinddir.c (modified) * c/src/exec/libcsupport/src/rmdir.c (modified) * c/src/exec/libcsupport/src/seekdir.c (modified) * c/src/exec/libcsupport/src/stat.c (modified) * c/src/exec/libcsupport/src/symlink.c (modified) * c/src/exec/libcsupport/src/tcdrain.c (modified) * c/src/exec/libcsupport/src/tcflow.c (modified) * c/src/exec/libcsupport/src/tcflush.c (modified) * c/src/exec/libcsupport/src/tcgetattr.c (modified) * c/src/exec/libcsupport/src/tcgetprgrp.c (modified) * c/src/exec/libcsupport/src/tcsendbreak.c (modified) * c/src/exec/libcsupport/src/tcsetattr.c (modified) * c/src/exec/libcsupport/src/tcsetpgrp.c (modified) * c/src/exec/libcsupport/src/telldir.c (modified) * c/src/exec/libcsupport/src/truncate.c (modified) * c/src/exec/libcsupport/src/umask.c (modified) * c/src/exec/libcsupport/src/unixlibc.c (modified) * c/src/exec/libcsupport/src/unlink.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libcsupport/src/utime.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/exec/libfs/src/imfs/deviceio.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_chown.c (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_debug.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_eval.c (modified) * c/src/exec/libfs/src/imfs/imfs_fchmod.c (modified) * c/src/exec/libfs/src/imfs/imfs_fcntl.c (modified) * c/src/exec/libfs/src/imfs/imfs_fdatasync.c (modified) * c/src/exec/libfs/src/imfs/imfs_free.c (modified) * c/src/exec/libfs/src/imfs/imfs_fsunmount.c (modified) * c/src/exec/libfs/src/imfs/imfs_getchild.c (modified) * c/src/exec/libfs/src/imfs/imfs_gtkn.c (modified) * c/src/exec/libfs/src/imfs/imfs_handlers_device.c (modified) * c/src/exec/libfs/src/imfs/imfs_handlers_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_handlers_link.c (modified) * c/src/exec/libfs/src/imfs/imfs_handlers_memfile.c (modified) * c/src/exec/libfs/src/imfs/imfs_init.c (modified) * c/src/exec/libfs/src/imfs/imfs_initsupp.c (modified) * c/src/exec/libfs/src/imfs/imfs_link.c (modified) * c/src/exec/libfs/src/imfs/imfs_mknod.c (modified) * c/src/exec/libfs/src/imfs/imfs_mount.c (modified) * c/src/exec/libfs/src/imfs/imfs_ntype.c (modified) * c/src/exec/libfs/src/imfs/imfs_readlink.c (modified) * c/src/exec/libfs/src/imfs/imfs_rmnod.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_symlink.c (modified) * c/src/exec/libfs/src/imfs/imfs_unixstub.c (modified) * c/src/exec/libfs/src/imfs/imfs_unlink.c (modified) * c/src/exec/libfs/src/imfs/imfs_unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libfs/src/imfs/ioman.c (modified) * c/src/exec/libfs/src/imfs/memfile.c (modified) * c/src/exec/libfs/src/imfs/miniimfs_init.c (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * c/src/exec/posix/include/rtems/posix/condmp.h (modified) * c/src/exec/posix/include/rtems/posix/config.h (modified) * c/src/exec/posix/include/rtems/posix/intr.h (modified) * c/src/exec/posix/include/rtems/posix/key.h (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/posix/include/rtems/posix/mqueuemp.h (modified) * c/src/exec/posix/include/rtems/posix/mutex.h (modified) * c/src/exec/posix/include/rtems/posix/mutexmp.h (modified) * c/src/exec/posix/include/rtems/posix/posixapi.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/pthreadmp.h (modified) * c/src/exec/posix/include/rtems/posix/semaphore.h (modified) * c/src/exec/posix/include/rtems/posix/semaphoremp.h (modified) * c/src/exec/posix/include/rtems/posix/seterr.h (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/inline/rtems/posix/intr.inl (modified) * c/src/exec/posix/inline/rtems/posix/key.inl (modified) * c/src/exec/posix/inline/rtems/posix/mqueue.inl (modified) * c/src/exec/posix/inline/rtems/posix/mutex.inl (modified) * c/src/exec/posix/inline/rtems/posix/pthread.inl (modified) * c/src/exec/posix/inline/rtems/posix/semaphore.inl (modified) * c/src/exec/posix/src/alarm.c (modified) * c/src/exec/posix/src/kill.c (modified) * c/src/exec/posix/src/killinfo.c (modified) * c/src/exec/posix/src/pause.c (modified) * c/src/exec/posix/src/pthreadattrdestroy.c (modified) * c/src/exec/posix/src/pthreadattrgetdetachstate.c (modified) * c/src/exec/posix/src/pthreadattrgetinheritsched.c (modified) * c/src/exec/posix/src/pthreadattrgetschedparam.c (modified) * c/src/exec/posix/src/pthreadattrgetschedpolicy.c (modified) * c/src/exec/posix/src/pthreadattrgetscope.c (modified) * c/src/exec/posix/src/pthreadattrgetstackaddr.c (modified) * c/src/exec/posix/src/pthreadattrgetstacksize.c (modified) * c/src/exec/posix/src/pthreadattrinit.c (modified) * c/src/exec/posix/src/pthreadattrsetdetachstate.c (modified) * c/src/exec/posix/src/pthreadattrsetinheritsched.c (modified) * c/src/exec/posix/src/pthreadattrsetschedparam.c (modified) * c/src/exec/posix/src/pthreadattrsetschedpolicy.c (modified) * c/src/exec/posix/src/pthreadattrsetscope.c (modified) * c/src/exec/posix/src/pthreadattrsetstackaddr.c (modified) * c/src/exec/posix/src/pthreadattrsetstacksize.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/pthreaddetach.c (modified) * c/src/exec/posix/src/pthreadequal.c (modified) * c/src/exec/posix/src/pthreadexit.c (modified) * c/src/exec/posix/src/pthreadgetcpuclockid.c (modified) * c/src/exec/posix/src/pthreadgetcputime.c (modified) * c/src/exec/posix/src/pthreadgetschedparam.c (modified) * c/src/exec/posix/src/pthreadjoin.c (modified) * c/src/exec/posix/src/pthreadkill.c (modified) * c/src/exec/posix/src/pthreadonce.c (modified) * c/src/exec/posix/src/pthreadself.c (modified) * c/src/exec/posix/src/pthreadsetcputime.c (modified) * c/src/exec/posix/src/pthreadsetschedparam.c (modified) * c/src/exec/posix/src/pthreadsigmask.c (modified) * c/src/exec/posix/src/sigaction.c (modified) * c/src/exec/posix/src/sigaddset.c (modified) * c/src/exec/posix/src/sigdelset.c (modified) * c/src/exec/posix/src/sigemptyset.c (modified) * c/src/exec/posix/src/sigfillset.c (modified) * c/src/exec/posix/src/sigismember.c (modified) * c/src/exec/posix/src/signal_2.c (modified) * c/src/exec/posix/src/sigpending.c (modified) * c/src/exec/posix/src/sigprocmask.c (modified) * c/src/exec/posix/src/sigqueue.c (modified) * c/src/exec/posix/src/sigsuspend.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/sigwait.c (modified) * c/src/exec/posix/src/sigwaitinfo.c (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/asr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/clock.h (modified) * c/src/exec/rtems/include/rtems/rtems/config.h (modified) * c/src/exec/rtems/include/rtems/rtems/dpmem.h (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/eventset.h (modified) * c/src/exec/rtems/include/rtems/rtems/intr.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/modes.h (modified) * c/src/exec/rtems/include/rtems/rtems/mp.h (modified) * c/src/exec/rtems/include/rtems/rtems/msgmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/options.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/partmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/ratemon.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/regionmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/semmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/signalmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/status.h (modified) * c/src/exec/rtems/include/rtems/rtems/support.h (modified) * c/src/exec/rtems/include/rtems/rtems/taskmp.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/timer.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/event.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/message.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/options.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/part.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/region.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/status.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/support.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/asr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/dpmem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/event.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/eventset.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/message.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/modes.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/options.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/part.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/ratemon.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/region.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/sem.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/status.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/support.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/tasks.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/timer.inl (modified) * c/src/exec/rtems/optman/no-dpmem.c (modified) * c/src/exec/rtems/optman/no-event.c (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/optman/no-msg.c (modified) * c/src/exec/rtems/optman/no-part.c (modified) * c/src/exec/rtems/optman/no-region.c (modified) * c/src/exec/rtems/optman/no-rtmon.c (modified) * c/src/exec/rtems/optman/no-sem.c (modified) * c/src/exec/rtems/optman/no-signal.c (modified) * c/src/exec/rtems/optman/no-timer.c (modified) * c/src/exec/rtems/src/attr.c (modified) * c/src/exec/rtems/src/clockget.c (modified) * c/src/exec/rtems/src/clockset.c (modified) * c/src/exec/rtems/src/clocktick.c (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/dpmemcreate.c (modified) * c/src/exec/rtems/src/dpmemdelete.c (modified) * c/src/exec/rtems/src/dpmemexternal2internal.c (modified) * c/src/exec/rtems/src/dpmemident.c (modified) * c/src/exec/rtems/src/dpmeminternal2external.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/eventmp.c (modified) * c/src/exec/rtems/src/eventreceive.c (modified) * c/src/exec/rtems/src/eventseize.c (modified) * c/src/exec/rtems/src/eventsend.c (modified) * c/src/exec/rtems/src/eventsurrender.c (modified) * c/src/exec/rtems/src/eventtimeout.c (modified) * c/src/exec/rtems/src/intr.c (modified) * c/src/exec/rtems/src/intrbody.c (modified) * c/src/exec/rtems/src/intrcatch.c (modified) * c/src/exec/rtems/src/mp.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/msgmp.c (modified) * c/src/exec/rtems/src/msgqallocate.c (modified) * c/src/exec/rtems/src/msgqbroadcast.c (modified) * c/src/exec/rtems/src/msgqcreate.c (modified) * c/src/exec/rtems/src/msgqdelete.c (modified) * c/src/exec/rtems/src/msgqflush.c (modified) * c/src/exec/rtems/src/msgqgetnumberpending.c (modified) * c/src/exec/rtems/src/msgqident.c (modified) * c/src/exec/rtems/src/msgqreceive.c (modified) * c/src/exec/rtems/src/msgqsend.c (modified) * c/src/exec/rtems/src/msgqsubmit.c (modified) * c/src/exec/rtems/src/msgqtranslatereturncode.c (modified) * c/src/exec/rtems/src/msgqurgent.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/partcreate.c (modified) * c/src/exec/rtems/src/partdelete.c (modified) * c/src/exec/rtems/src/partgetbuffer.c (modified) * c/src/exec/rtems/src/partident.c (modified) * c/src/exec/rtems/src/partmp.c (modified) * c/src/exec/rtems/src/partreturnbuffer.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/ratemoncancel.c (modified) * c/src/exec/rtems/src/ratemoncreate.c (modified) * c/src/exec/rtems/src/ratemondelete.c (modified) * c/src/exec/rtems/src/ratemongetstatus.c (modified) * c/src/exec/rtems/src/ratemonident.c (modified) * c/src/exec/rtems/src/ratemonperiod.c (modified) * c/src/exec/rtems/src/ratemontimeout.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/regioncreate.c (modified) * c/src/exec/rtems/src/regiondelete.c (modified) * c/src/exec/rtems/src/regionextend.c (modified) * c/src/exec/rtems/src/regiongetsegment.c (modified) * c/src/exec/rtems/src/regiongetsegmentsize.c (modified) * c/src/exec/rtems/src/regionident.c (modified) * c/src/exec/rtems/src/regionmp.c (modified) * c/src/exec/rtems/src/regionreturnsegment.c (modified) * c/src/exec/rtems/src/rtclock.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/semcreate.c (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/semflush.c (modified) * c/src/exec/rtems/src/semident.c (modified) * c/src/exec/rtems/src/semmp.c (modified) * c/src/exec/rtems/src/semobtain.c (modified) * c/src/exec/rtems/src/semrelease.c (modified) * c/src/exec/rtems/src/semtranslatereturncode.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/signalcatch.c (modified) * c/src/exec/rtems/src/signalmp.c (modified) * c/src/exec/rtems/src/signalsend.c (modified) * c/src/exec/rtems/src/taskcreate.c (modified) * c/src/exec/rtems/src/taskdelete.c (modified) * c/src/exec/rtems/src/taskgetnote.c (modified) * c/src/exec/rtems/src/taskident.c (modified) * c/src/exec/rtems/src/taskinitusers.c (modified) * c/src/exec/rtems/src/taskissuspended.c (modified) * c/src/exec/rtems/src/taskmode.c (modified) * c/src/exec/rtems/src/taskmp.c (modified) * c/src/exec/rtems/src/taskrestart.c (modified) * c/src/exec/rtems/src/taskresume.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/tasksetnote.c (modified) * c/src/exec/rtems/src/tasksetpriority.c (modified) * c/src/exec/rtems/src/taskstart.c (modified) * c/src/exec/rtems/src/tasksuspend.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskwakeafter.c (modified) * c/src/exec/rtems/src/taskwakewhen.c (modified) * c/src/exec/rtems/src/timercancel.c (modified) * c/src/exec/rtems/src/timercreate.c (modified) * c/src/exec/rtems/src/timerdelete.c (modified) * c/src/exec/rtems/src/timerfireafter.c (modified) * c/src/exec/rtems/src/timerfirewhen.c (modified) * c/src/exec/rtems/src/timerident.c (modified) * c/src/exec/rtems/src/timerreset.c (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/extension.h (modified) * c/src/exec/sapi/include/rtems/fatal.h (modified) * c/src/exec/sapi/include/rtems/init.h (modified) * c/src/exec/sapi/include/rtems/io.h (modified) * c/src/exec/sapi/include/rtems/mptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h.in (modified) * c/src/exec/sapi/inline/rtems/extension.inl (modified) * c/src/exec/sapi/macros/rtems/extension.inl (modified) * c/src/exec/sapi/optman/no-ext.c (modified) * c/src/exec/sapi/optman/no-io.c (modified) * c/src/exec/sapi/src/debug.c (modified) * c/src/exec/sapi/src/entrytable.c (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/extension.c (modified) * c/src/exec/sapi/src/fatal.c (modified) * c/src/exec/sapi/src/io.c (modified) * c/src/exec/sapi/src/itronapi.c (modified) * c/src/exec/sapi/src/posixapi.c (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/exec/score/cpu/a29k/cpu.c (modified) * c/src/exec/score/cpu/a29k/cpu_asm.S (modified) * c/src/exec/score/cpu/a29k/rtems.c (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29ktypes.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/cpu_asm.h (modified) * c/src/exec/score/cpu/a29k/rtems/score/types.h (modified) * c/src/exec/score/cpu/hppa1.1/rtems.S (modified) * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu_asm.S (modified) * c/src/exec/score/cpu/i386/rtems.S (modified) * c/src/exec/score/cpu/i386/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i386/rtems/score/i386types.h (modified) * c/src/exec/score/cpu/i386/rtems/score/types.h (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu_asm.S (modified) * c/src/exec/score/cpu/i960/rtems.S (modified) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960types.h (modified) * c/src/exec/score/cpu/i960/rtems/score/types.h (modified) * c/src/exec/score/cpu/m68k/cpu.c (modified) * c/src/exec/score/cpu/m68k/cpu_asm.S (modified) * c/src/exec/score/cpu/m68k/rtems.S (modified) * c/src/exec/score/cpu/m68k/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68ktypes.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/types.h (modified) * c/src/exec/score/cpu/mips/cpu.c (modified) * c/src/exec/score/cpu/mips/cpu_asm.S (modified) * c/src/exec/score/cpu/mips/cpu_asm.h (modified) * c/src/exec/score/cpu/mips/rtems.c (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mipstypes.h (modified) * c/src/exec/score/cpu/mips/rtems/score/types.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.c (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.S (modified) * c/src/exec/score/cpu/mips64orion/cpu_asm.h (modified) * c/src/exec/score/cpu/mips64orion/rtems.c (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mipstypes.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/types.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu_asm.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cputypes.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/types.h (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu_asm.S (modified) * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/exec/score/cpu/sparc/rtems.S (modified) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparctypes.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/types.h (modified) * c/src/exec/score/cpu/unix/rtems/score/types.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unixtypes.h (modified) * c/src/exec/score/include/rtems/debug.h (modified) * c/src/exec/score/include/rtems/score/address.h (modified) * c/src/exec/score/include/rtems/score/apiext.h (modified) * c/src/exec/score/include/rtems/score/bitfield.h (modified) * c/src/exec/score/include/rtems/score/chain.h (modified) * c/src/exec/score/include/rtems/score/context.h (modified) * c/src/exec/score/include/rtems/score/copyrt.h (modified) * c/src/exec/score/include/rtems/score/coremsg.h (modified) * c/src/exec/score/include/rtems/score/coremutex.h (modified) * c/src/exec/score/include/rtems/score/coresem.h (modified) * c/src/exec/score/include/rtems/score/heap.h (modified) * c/src/exec/score/include/rtems/score/interr.h (modified) * c/src/exec/score/include/rtems/score/isr.h (modified) * c/src/exec/score/include/rtems/score/mpci.h (modified) * c/src/exec/score/include/rtems/score/mppkt.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/objectmp.h (modified) * c/src/exec/score/include/rtems/score/priority.h (modified) * c/src/exec/score/include/rtems/score/stack.h (modified) * c/src/exec/score/include/rtems/score/states.h (modified) * c/src/exec/score/include/rtems/score/sysstate.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/score/threadmp.h (modified) * c/src/exec/score/include/rtems/score/threadq.h (modified) * c/src/exec/score/include/rtems/score/tod.h (modified) * c/src/exec/score/include/rtems/score/tqdata.h (modified) * c/src/exec/score/include/rtems/score/userext.h (modified) * c/src/exec/score/include/rtems/score/watchdog.h (modified) * c/src/exec/score/include/rtems/score/wkspace.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/address.inl (modified) * c/src/exec/score/inline/rtems/score/chain.inl (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/inline/rtems/score/coremutex.inl (modified) * c/src/exec/score/inline/rtems/score/coresem.inl (modified) * c/src/exec/score/inline/rtems/score/heap.inl (modified) * c/src/exec/score/inline/rtems/score/isr.inl (modified) * c/src/exec/score/inline/rtems/score/mppkt.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/inline/rtems/score/objectmp.inl (modified) * c/src/exec/score/inline/rtems/score/priority.inl (modified) * c/src/exec/score/inline/rtems/score/stack.inl (modified) * c/src/exec/score/inline/rtems/score/states.inl (modified) * c/src/exec/score/inline/rtems/score/sysstate.inl (modified) * c/src/exec/score/inline/rtems/score/thread.inl (modified) * c/src/exec/score/inline/rtems/score/threadmp.inl (modified) * c/src/exec/score/inline/rtems/score/tod.inl (modified) * c/src/exec/score/inline/rtems/score/tqdata.inl (modified) * c/src/exec/score/inline/rtems/score/userext.inl (modified) * c/src/exec/score/inline/rtems/score/watchdog.inl (modified) * c/src/exec/score/inline/rtems/score/wkspace.inl (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/macros/rtems/score/chain.inl (modified) * c/src/exec/score/macros/rtems/score/coremsg.inl (modified) * c/src/exec/score/macros/rtems/score/coremutex.inl (modified) * c/src/exec/score/macros/rtems/score/coresem.inl (modified) * c/src/exec/score/macros/rtems/score/heap.inl (modified) * c/src/exec/score/macros/rtems/score/isr.inl (modified) * c/src/exec/score/macros/rtems/score/mppkt.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/objectmp.inl (modified) * c/src/exec/score/macros/rtems/score/priority.inl (modified) * c/src/exec/score/macros/rtems/score/stack.inl (modified) * c/src/exec/score/macros/rtems/score/states.inl (modified) * c/src/exec/score/macros/rtems/score/sysstate.inl (modified) * c/src/exec/score/macros/rtems/score/thread.inl (modified) * c/src/exec/score/macros/rtems/score/threadmp.inl (modified) * c/src/exec/score/macros/rtems/score/tod.inl (modified) * c/src/exec/score/macros/rtems/score/tqdata.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/macros/rtems/score/watchdog.inl (modified) * c/src/exec/score/macros/rtems/score/wkspace.inl (modified) * c/src/exec/score/src/apiext.c (modified) * c/src/exec/score/src/chain.c (modified) * c/src/exec/score/src/coremsg.c (modified) * c/src/exec/score/src/coremsgbroadcast.c (modified) * c/src/exec/score/src/coremsgclose.c (modified) * c/src/exec/score/src/coremsgflush.c (modified) * c/src/exec/score/src/coremsgflushsupp.c (modified) * c/src/exec/score/src/coremsgseize.c (modified) * c/src/exec/score/src/coremsgsubmit.c (modified) * c/src/exec/score/src/coremutex.c (modified) * c/src/exec/score/src/coremutexflush.c (modified) * c/src/exec/score/src/coremutexseize.c (modified) * c/src/exec/score/src/coremutexsurrender.c (modified) * c/src/exec/score/src/coresem.c (modified) * c/src/exec/score/src/coresemflush.c (modified) * c/src/exec/score/src/coresemseize.c (modified) * c/src/exec/score/src/coresemsurrender.c (modified) * c/src/exec/score/src/coretod.c (modified) * c/src/exec/score/src/coretodset.c (modified) * c/src/exec/score/src/coretodtickle.c (modified) * c/src/exec/score/src/coretodtoseconds.c (modified) * c/src/exec/score/src/coretodvalidate.c (modified) * c/src/exec/score/src/heap.c (modified) * c/src/exec/score/src/heapallocate.c (modified) * c/src/exec/score/src/heapextend.c (modified) * c/src/exec/score/src/heapfree.c (modified) * c/src/exec/score/src/heapsizeofuserarea.c (modified) * c/src/exec/score/src/heapwalk.c (modified) * c/src/exec/score/src/interr.c (modified) * c/src/exec/score/src/isr.c (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/objectallocate.c (modified) * c/src/exec/score/src/objectallocatebyindex.c (modified) * c/src/exec/score/src/objectclearname.c (modified) * c/src/exec/score/src/objectcomparenameraw.c (modified) * c/src/exec/score/src/objectcomparenamestring.c (modified) * c/src/exec/score/src/objectcopynameraw.c (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/score/src/objectextendinformation.c (modified) * c/src/exec/score/src/objectfree.c (modified) * c/src/exec/score/src/objectget.c (modified) * c/src/exec/score/src/objectgetbyindex.c (modified) * c/src/exec/score/src/objectgetnext.c (modified) * c/src/exec/score/src/objectinitializeinformation.c (modified) * c/src/exec/score/src/objectmp.c (modified) * c/src/exec/score/src/objectnametoid.c (modified) * c/src/exec/score/src/objectshrinkinformation.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadchangepriority.c (modified) * c/src/exec/score/src/threadclearstate.c (modified) * c/src/exec/score/src/threadclose.c (modified) * c/src/exec/score/src/threadcreateidle.c (modified) * c/src/exec/score/src/threaddelayended.c (modified) * c/src/exec/score/src/threaddispatch.c (modified) * c/src/exec/score/src/threadevaluatemode.c (modified) * c/src/exec/score/src/threadget.c (modified) * c/src/exec/score/src/threadhandler.c (modified) * c/src/exec/score/src/threadidlebody.c (modified) * c/src/exec/score/src/threadinitialize.c (modified) * c/src/exec/score/src/threadloadenv.c (modified) * c/src/exec/score/src/threadmp.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/src/threadqdequeue.c (modified) * c/src/exec/score/src/threadqdequeuefifo.c (modified) * c/src/exec/score/src/threadqdequeuepriority.c (modified) * c/src/exec/score/src/threadqenqueue.c (modified) * c/src/exec/score/src/threadqenqueuefifo.c (modified) * c/src/exec/score/src/threadqenqueuepriority.c (modified) * c/src/exec/score/src/threadqextract.c (modified) * c/src/exec/score/src/threadqextractfifo.c (modified) * c/src/exec/score/src/threadqextractpriority.c (modified) * c/src/exec/score/src/threadqextractwithproxy.c (modified) * c/src/exec/score/src/threadqfirst.c (modified) * c/src/exec/score/src/threadqfirstfifo.c (modified) * c/src/exec/score/src/threadqfirstpriority.c (modified) * c/src/exec/score/src/threadqflush.c (modified) * c/src/exec/score/src/threadqtimeout.c (modified) * c/src/exec/score/src/threadready.c (modified) * c/src/exec/score/src/threadreset.c (modified) * c/src/exec/score/src/threadresettimeslice.c (modified) * c/src/exec/score/src/threadrestart.c (modified) * c/src/exec/score/src/threadresume.c (modified) * c/src/exec/score/src/threadrotatequeue.c (modified) * c/src/exec/score/src/threadsetpriority.c (modified) * c/src/exec/score/src/threadsetstate.c (modified) * c/src/exec/score/src/threadsettransient.c (modified) * c/src/exec/score/src/threadstackallocate.c (modified) * c/src/exec/score/src/threadstackfree.c (modified) * c/src/exec/score/src/threadstart.c (modified) * c/src/exec/score/src/threadstartmultitasking.c (modified) * c/src/exec/score/src/threadsuspend.c (modified) * c/src/exec/score/src/threadtickletimeslice.c (modified) * c/src/exec/score/src/threadyieldprocessor.c (modified) * c/src/exec/score/src/userext.c (modified) * c/src/exec/score/src/watchdog.c (modified) * c/src/exec/score/src/watchdogadjust.c (modified) * c/src/exec/score/src/watchdoginsert.c (modified) * c/src/exec/score/src/watchdogremove.c (modified) * c/src/exec/score/src/watchdogtickle.c (modified) * c/src/exec/score/src/wkspace.c (modified) * c/src/lib/include/clockdrv.h (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/iosupp.h (modified) * c/src/lib/include/motorola/mc68230.h (modified) * c/src/lib/include/rtems/libcsupport.h (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/timerdrv.h (modified) * c/src/lib/include/vmeintr.h (modified) * c/src/lib/include/zilog/z8036.h (modified) * c/src/lib/include/zilog/z8530.h (modified) * c/src/lib/include/zilog/z8536.h (modified) * c/src/lib/libbsp/a29k/portsw/console/console.c (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/include/coverhd.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/lock.c (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspclean.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/main.c (modified) * c/src/lib/libbsp/a29k/portsw/startup/setvec.c (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/bare/include/coverhd.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/coverhd.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/intr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/lock.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspclean.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/linkcmds (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/pc386/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/pc386/clock/rtc.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/include/coverhd.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.S (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/startup/linkcmds (modified) * c/src/lib/libbsp/i386/pc386/startup/sbrk.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/rtc.c (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/include/coverhd.h (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/timerisr.S (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/serial_gdb.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i960/cvme961/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/cvme961/console/console.c (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/include/coverhd.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/lock.c (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/i960/cvme961/start/start.S (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspclean.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/exit.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/linkcmds (modified) * c/src/lib/libbsp/i960/cvme961/startup/setvec.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timer.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/dmv152/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/startup/vmeintr.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timer.c (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/efi332/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi332/console/console.c (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/timer/timer.c (modified) * c/src/lib/libbsp/m68k/efi68k/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/efi68k/console/console.c (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/setvec.c (modified) * c/src/lib/libbsp/m68k/efi68k/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68302/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.S (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/m340timer.h (modified) * c/src/lib/libbsp/m68k/gen68340/include/m340uart.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (modified) * c/src/lib/libbsp/m68k/gen68340/start340/start340.S (modified) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.S (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (modified) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (modified) * c/src/lib/libbsp/m68k/gen68360/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/idp/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timer.c (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme136/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme136/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme147/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme147/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/lock.c (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/cTest.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.c (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/consolex.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/mvme167/include/page_table.h (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.S (modified) * c/src/lib/libbsp/m68k/ods68302/clock/ckinit.c (modified) * c/src/lib/libbsp/m68k/ods68302/console/console.c (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/include/coverhd.h (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspclean.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timer.c (modified) * c/src/lib/libbsp/m68k/shared/setvec.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/p4000/console/console.c (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/mips64orion/p4000/console/console.c (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/include/coverhd.h (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspclean.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/ckinit.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/console.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/coverhd.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/lock.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspclean.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/linkcmds (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/main.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/setvec.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timer.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/timerisr.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/helas403/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/clock/ckinit.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mvme2307/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/main.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/mvme2307/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/psim/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/include/coverhd.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspclean.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/psim/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/psim/tools/psim (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspclean.c (modified) * c/src/lib/libbsp/shared/bootcard.c (modified) * c/src/lib/libbsp/shared/bspclean.c (modified) * c/src/lib/libbsp/shared/bsplibc.c (modified) * c/src/lib/libbsp/shared/main.c (modified) * c/src/lib/libbsp/shared/sbrk.c (modified) * c/src/lib/libbsp/shmdr/addlq.c (modified) * c/src/lib/libbsp/shmdr/cnvpkt.c (modified) * c/src/lib/libbsp/shmdr/dump.c (modified) * c/src/lib/libbsp/shmdr/fatal.c (modified) * c/src/lib/libbsp/shmdr/getlq.c (modified) * c/src/lib/libbsp/shmdr/getpkt.c (modified) * c/src/lib/libbsp/shmdr/init.c (modified) * c/src/lib/libbsp/shmdr/initlq.c (modified) * c/src/lib/libbsp/shmdr/intr.c (modified) * c/src/lib/libbsp/shmdr/mpci.h (modified) * c/src/lib/libbsp/shmdr/mpisr.c (modified) * c/src/lib/libbsp/shmdr/poll.c (modified) * c/src/lib/libbsp/shmdr/receive.c (modified) * c/src/lib/libbsp/shmdr/retpkt.c (modified) * c/src/lib/libbsp/shmdr/send.c (modified) * c/src/lib/libbsp/shmdr/setckvec.c (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libbsp/sparc/erc32/clock/ckinit.c (modified) * c/src/lib/libbsp/sparc/erc32/console/console.c (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/console/debugputs.c (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/include/coverhd.h (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/setvec.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/timer.c (modified) * c/src/lib/libbsp/unix/posix/clock/clock.c (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/include/coverhd.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/addrconv.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/getcfg.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/intr.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/lock.c (modified) * c/src/lib/libbsp/unix/posix/shmsupp/mpisr.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspclean.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/exit.c (modified) * c/src/lib/libbsp/unix/posix/startup/setvec.c (modified) * c/src/lib/libbsp/unix/posix/timer/timer.c (modified) * c/src/lib/libc/__brk.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/__sbrk.c (modified) * c/src/lib/libc/__times.c (modified) * c/src/lib/libc/access.c (modified) * c/src/lib/libc/base_fs.c (modified) * c/src/lib/libc/cfgetispeed.c (modified) * c/src/lib/libc/cfgetospeed.c (modified) * c/src/lib/libc/cfsetispeed.c (modified) * c/src/lib/libc/cfsetospeed.c (modified) * c/src/lib/libc/chdir.c (modified) * c/src/lib/libc/chmod.c (modified) * c/src/lib/libc/chown.c (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/ctermid.c (modified) * c/src/lib/libc/deviceio.c (modified) * c/src/lib/libc/dup.c (modified) * c/src/lib/libc/dup2.c (modified) * c/src/lib/libc/eval.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fs_null_handlers.c (modified) * c/src/lib/libc/fstat.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/getdents.c (modified) * c/src/lib/libc/hosterr.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_chown.c (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_debug.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_eval.c (modified) * c/src/lib/libc/imfs_fchmod.c (modified) * c/src/lib/libc/imfs_fcntl.c (modified) * c/src/lib/libc/imfs_fdatasync.c (modified) * c/src/lib/libc/imfs_free.c (modified) * c/src/lib/libc/imfs_fsunmount.c (modified) * c/src/lib/libc/imfs_getchild.c (modified) * c/src/lib/libc/imfs_gtkn.c (modified) * c/src/lib/libc/imfs_handlers_device.c (modified) * c/src/lib/libc/imfs_handlers_directory.c (modified) * c/src/lib/libc/imfs_handlers_link.c (modified) * c/src/lib/libc/imfs_handlers_memfile.c (modified) * c/src/lib/libc/imfs_init.c (modified) * c/src/lib/libc/imfs_initsupp.c (modified) * c/src/lib/libc/imfs_link.c (modified) * c/src/lib/libc/imfs_mknod.c (modified) * c/src/lib/libc/imfs_mount.c (modified) * c/src/lib/libc/imfs_ntype.c (modified) * c/src/lib/libc/imfs_readlink.c (modified) * c/src/lib/libc/imfs_rmnod.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_symlink.c (modified) * c/src/lib/libc/imfs_unixstub.c (modified) * c/src/lib/libc/imfs_unlink.c (modified) * c/src/lib/libc/imfs_unmount.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/ioman.c (modified) * c/src/lib/libc/libcsupport.h (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/libio_sockets.c (modified) * c/src/lib/libc/link.c (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/lstat.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/memfile.c (modified) * c/src/lib/libc/miniimfs_init.c (modified) * c/src/lib/libc/mkdir.c (modified) * c/src/lib/libc/mkfifo.c (modified) * c/src/lib/libc/mknod.c (modified) * c/src/lib/libc/mount.c (modified) * c/src/lib/libc/no_libc.c (modified) * c/src/lib/libc/open.c (modified) * c/src/lib/libc/pathconf.c (modified) * c/src/lib/libc/pipe.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/readlink.c (modified) * c/src/lib/libc/rewinddir.c (modified) * c/src/lib/libc/rmdir.c (modified) * c/src/lib/libc/seekdir.c (modified) * c/src/lib/libc/stat.c (modified) * c/src/lib/libc/symlink.c (modified) * c/src/lib/libc/tcdrain.c (modified) * c/src/lib/libc/tcflow.c (modified) * c/src/lib/libc/tcflush.c (modified) * c/src/lib/libc/tcgetattr.c (modified) * c/src/lib/libc/tcgetprgrp.c (modified) * c/src/lib/libc/tcsendbreak.c (modified) * c/src/lib/libc/tcsetattr.c (modified) * c/src/lib/libc/tcsetpgrp.c (modified) * c/src/lib/libc/telldir.c (modified) * c/src/lib/libc/truncate.c (modified) * c/src/lib/libc/umask.c (modified) * c/src/lib/libc/unixlibc.c (modified) * c/src/lib/libc/unlink.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libc/utime.c (modified) * c/src/lib/libc/write.c (modified) * c/src/lib/libcpu/hppa1.1/clock/clock.c (modified) * c/src/lib/libcpu/hppa1.1/timer/timer.c (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c.polled (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7032/include/null.h (modified) * c/src/lib/libcpu/sh/sh7032/null/close.c (modified) * c/src/lib/libcpu/sh/sh7032/null/cntrl.c (modified) * c/src/lib/libcpu/sh/sh7032/null/init.c (modified) * c/src/lib/libcpu/sh/sh7032/null/open.c (modified) * c/src/lib/libcpu/sh/sh7032/null/read.c (modified) * c/src/lib/libcpu/sh/sh7032/null/write.c (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) * c/src/libchip/rtc/icm7170.c (modified) * c/src/libchip/rtc/icm7170.h (modified) * c/src/libchip/rtc/m48t08.c (modified) * c/src/libchip/rtc/m48t08.h (modified) * c/src/libchip/rtc/rtc.h (modified) * c/src/libchip/rtc/rtcprobe.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/mc68681.h (modified) * c/src/libchip/serial/mc68681_p.h (modified) * c/src/libchip/serial/serial.h (modified) * c/src/libchip/shmdr/addlq.c (modified) * c/src/libchip/shmdr/cnvpkt.c (modified) * c/src/libchip/shmdr/dump.c (modified) * c/src/libchip/shmdr/fatal.c (modified) * c/src/libchip/shmdr/getlq.c (modified) * c/src/libchip/shmdr/getpkt.c (modified) * c/src/libchip/shmdr/init.c (modified) * c/src/libchip/shmdr/initlq.c (modified) * c/src/libchip/shmdr/intr.c (modified) * c/src/libchip/shmdr/mpci.h (modified) * c/src/libchip/shmdr/mpisr.c (modified) * c/src/libchip/shmdr/poll.c (modified) * c/src/libchip/shmdr/receive.c (modified) * c/src/libchip/shmdr/retpkt.c (modified) * c/src/libchip/shmdr/send.c (modified) * c/src/libchip/shmdr/setckvec.c (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/libfs/src/imfs/deviceio.c (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_chown.c (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_debug.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_eval.c (modified) * c/src/libfs/src/imfs/imfs_fchmod.c (modified) * c/src/libfs/src/imfs/imfs_fcntl.c (modified) * c/src/libfs/src/imfs/imfs_fdatasync.c (modified) * c/src/libfs/src/imfs/imfs_free.c (modified) * c/src/libfs/src/imfs/imfs_fsunmount.c (modified) * c/src/libfs/src/imfs/imfs_getchild.c (modified) * c/src/libfs/src/imfs/imfs_gtkn.c (modified) * c/src/libfs/src/imfs/imfs_handlers_device.c (modified) * c/src/libfs/src/imfs/imfs_handlers_directory.c (modified) * c/src/libfs/src/imfs/imfs_handlers_link.c (modified) * c/src/libfs/src/imfs/imfs_handlers_memfile.c (modified) * c/src/libfs/src/imfs/imfs_init.c (modified) * c/src/libfs/src/imfs/imfs_initsupp.c (modified) * c/src/libfs/src/imfs/imfs_link.c (modified) * c/src/libfs/src/imfs/imfs_mknod.c (modified) * c/src/libfs/src/imfs/imfs_mount.c (modified) * c/src/libfs/src/imfs/imfs_ntype.c (modified) * c/src/libfs/src/imfs/imfs_readlink.c (modified) * c/src/libfs/src/imfs/imfs_rmnod.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_symlink.c (modified) * c/src/libfs/src/imfs/imfs_unixstub.c (modified) * c/src/libfs/src/imfs/imfs_unlink.c (modified) * c/src/libfs/src/imfs/imfs_unmount.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libfs/src/imfs/ioman.c (modified) * c/src/libfs/src/imfs/memfile.c (modified) * c/src/libfs/src/imfs/miniimfs_init.c (modified) * c/src/libmisc/cpuuse/cpuuse.c (modified) * c/src/libmisc/cpuuse/cpuuse.h (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/stackchk/check.c (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/stackchk/stackchk.h (modified) * c/src/optman/rtems/no-dpmem.c (modified) * c/src/optman/rtems/no-event.c (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/rtems/no-msg.c (modified) * c/src/optman/rtems/no-part.c (modified) * c/src/optman/rtems/no-region.c (modified) * c/src/optman/rtems/no-rtmon.c (modified) * c/src/optman/rtems/no-sem.c (modified) * c/src/optman/rtems/no-signal.c (modified) * c/src/optman/rtems/no-timer.c (modified) * c/src/optman/sapi/no-ext.c (modified) * c/src/optman/sapi/no-io.c (modified) * c/src/tests/libtests/cpuuse/init.c (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task1.c (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/task3.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/init.c (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/malloctest/task1.c (modified) * c/src/tests/libtests/monitor/init.c (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Init.cc (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtems++/Task1.cc (modified) * c/src/tests/libtests/rtems++/Task2.cc (modified) * c/src/tests/libtests/rtems++/Task3.cc (modified) * c/src/tests/libtests/rtmonuse/getall.c (modified) * c/src/tests/libtests/rtmonuse/init.c (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/rtmonuse/task1.c (modified) * c/src/tests/libtests/stackchk/blow.c (modified) * c/src/tests/libtests/stackchk/init.c (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/stackchk/task1.c (modified) * c/src/tests/mptests/mp01/init.c (modified) * c/src/tests/mptests/mp01/node1/mp01.doc (modified) * c/src/tests/mptests/mp01/node2/mp01.doc (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp01/task1.c (modified) * c/src/tests/mptests/mp02/init.c (modified) * c/src/tests/mptests/mp02/node1/mp02.doc (modified) * c/src/tests/mptests/mp02/node2/mp02.doc (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp02/task1.c (modified) * c/src/tests/mptests/mp03/delay.c (modified) * c/src/tests/mptests/mp03/init.c (modified) * c/src/tests/mptests/mp03/node1/mp03.doc (modified) * c/src/tests/mptests/mp03/node2/mp03.doc (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp03/task1.c (modified) * c/src/tests/mptests/mp04/init.c (modified) * c/src/tests/mptests/mp04/node1/mp04.doc (modified) * c/src/tests/mptests/mp04/node2/mp04.doc (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp04/task1.c (modified) * c/src/tests/mptests/mp05/asr.c (modified) * c/src/tests/mptests/mp05/init.c (modified) * c/src/tests/mptests/mp05/node1/mp05.doc (modified) * c/src/tests/mptests/mp05/node2/mp05.doc (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp05/task1.c (modified) * c/src/tests/mptests/mp06/init.c (modified) * c/src/tests/mptests/mp06/node1/mp06.doc (modified) * c/src/tests/mptests/mp06/node2/mp06.doc (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp06/task1.c (modified) * c/src/tests/mptests/mp07/init.c (modified) * c/src/tests/mptests/mp07/node1/mp07.doc (modified) * c/src/tests/mptests/mp07/node2/mp07.doc (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp07/task1.c (modified) * c/src/tests/mptests/mp08/init.c (modified) * c/src/tests/mptests/mp08/node1/mp08.doc (modified) * c/src/tests/mptests/mp08/node2/mp08.doc (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp08/task1.c (modified) * c/src/tests/mptests/mp09/init.c (modified) * c/src/tests/mptests/mp09/node1/mp09.doc (modified) * c/src/tests/mptests/mp09/node2/mp09.doc (modified) * c/src/tests/mptests/mp09/recvmsg.c (modified) * c/src/tests/mptests/mp09/sendmsg.c (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp09/task1.c (modified) * c/src/tests/mptests/mp10/init.c (modified) * c/src/tests/mptests/mp10/node1/mp10.doc (modified) * c/src/tests/mptests/mp10/node2/mp10.doc (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp10/task1.c (modified) * c/src/tests/mptests/mp10/task2.c (modified) * c/src/tests/mptests/mp10/task3.c (modified) * c/src/tests/mptests/mp11/init.c (modified) * c/src/tests/mptests/mp11/node1/mp11.doc (modified) * c/src/tests/mptests/mp11/node2/mp11.doc (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/init.c (modified) * c/src/tests/mptests/mp12/node1/mp12.doc (modified) * c/src/tests/mptests/mp12/node2/mp12.doc (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/init.c (modified) * c/src/tests/mptests/mp13/node1/mp13.doc (modified) * c/src/tests/mptests/mp13/node2/mp13.doc (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp13/task1.c (modified) * c/src/tests/mptests/mp13/task2.c (modified) * c/src/tests/mptests/mp14/delay.c (modified) * c/src/tests/mptests/mp14/evtask1.c (modified) * c/src/tests/mptests/mp14/evtmtask.c (modified) * c/src/tests/mptests/mp14/exit.c (modified) * c/src/tests/mptests/mp14/init.c (modified) * c/src/tests/mptests/mp14/msgtask1.c (modified) * c/src/tests/mptests/mp14/node1/mp14.doc (modified) * c/src/tests/mptests/mp14/node2/mp14.doc (modified) * c/src/tests/mptests/mp14/pttask1.c (modified) * c/src/tests/mptests/mp14/smtask1.c (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/psx01/init.c (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx01/task.c (modified) * c/src/tests/psxtests/psx02/init.c (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx02/task.c (modified) * c/src/tests/psxtests/psx03/init.c (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx03/task.c (modified) * c/src/tests/psxtests/psx04/init.c (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx04/task1.c (modified) * c/src/tests/psxtests/psx04/task2.c (modified) * c/src/tests/psxtests/psx04/task3.c (modified) * c/src/tests/psxtests/psx05/init.c (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx05/task.c (modified) * c/src/tests/psxtests/psx05/task2.c (modified) * c/src/tests/psxtests/psx05/task3.c (modified) * c/src/tests/psxtests/psx06/init.c (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx06/task.c (modified) * c/src/tests/psxtests/psx06/task2.c (modified) * c/src/tests/psxtests/psx07/init.c (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx07/task.c (modified) * c/src/tests/psxtests/psx08/init.c (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx08/task1.c (modified) * c/src/tests/psxtests/psx08/task2.c (modified) * c/src/tests/psxtests/psx08/task3.c (modified) * c/src/tests/psxtests/psx09/init.c (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/init.c (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx10/task.c (modified) * c/src/tests/psxtests/psx10/task2.c (modified) * c/src/tests/psxtests/psx10/task3.c (modified) * c/src/tests/psxtests/psx11/init.c (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx11/task.c (modified) * c/src/tests/psxtests/psx12/init.c (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx12/task.c (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psx13/test.c (modified) * c/src/tests/psxtests/psxcancel/init.c (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/clock01.c (modified) * c/src/tests/psxtests/psxhdrs/clock02.c (modified) * c/src/tests/psxtests/psxhdrs/clock03.c (modified) * c/src/tests/psxtests/psxhdrs/clock04.c (modified) * c/src/tests/psxtests/psxhdrs/clock05.c (modified) * c/src/tests/psxtests/psxhdrs/clock06.c (modified) * c/src/tests/psxtests/psxhdrs/cond01.c (modified) * c/src/tests/psxtests/psxhdrs/cond02.c (modified) * c/src/tests/psxtests/psxhdrs/cond03.c (modified) * c/src/tests/psxtests/psxhdrs/cond04.c (modified) * c/src/tests/psxtests/psxhdrs/cond05.c (modified) * c/src/tests/psxtests/psxhdrs/cond06.c (modified) * c/src/tests/psxtests/psxhdrs/cond07.c (modified) * c/src/tests/psxtests/psxhdrs/cond08.c (modified) * c/src/tests/psxtests/psxhdrs/cond09.c (modified) * c/src/tests/psxtests/psxhdrs/cond10.c (modified) * c/src/tests/psxtests/psxhdrs/key01.c (modified) * c/src/tests/psxtests/psxhdrs/key02.c (modified) * c/src/tests/psxtests/psxhdrs/key03.c (modified) * c/src/tests/psxtests/psxhdrs/key04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex01.c (modified) * c/src/tests/psxtests/psxhdrs/mutex02.c (modified) * c/src/tests/psxtests/psxhdrs/mutex03.c (modified) * c/src/tests/psxtests/psxhdrs/mutex04.c (modified) * c/src/tests/psxtests/psxhdrs/mutex05.c (modified) * c/src/tests/psxtests/psxhdrs/mutex06.c (modified) * c/src/tests/psxtests/psxhdrs/mutex07.c (modified) * c/src/tests/psxtests/psxhdrs/mutex08.c (modified) * c/src/tests/psxtests/psxhdrs/mutex09.c (modified) * c/src/tests/psxtests/psxhdrs/mutex10.c (modified) * c/src/tests/psxtests/psxhdrs/mutex11.c (modified) * c/src/tests/psxtests/psxhdrs/mutex12.c (modified) * c/src/tests/psxtests/psxhdrs/mutex13.c (modified) * c/src/tests/psxtests/psxhdrs/mutex14.c (modified) * c/src/tests/psxtests/psxhdrs/mutex15.c (modified) * c/src/tests/psxtests/psxhdrs/mutex16.c (modified) * c/src/tests/psxtests/psxhdrs/proc01.c (modified) * c/src/tests/psxtests/psxhdrs/proc02.c (modified) * c/src/tests/psxtests/psxhdrs/proc03.c (modified) * c/src/tests/psxtests/psxhdrs/proc04.c (modified) * c/src/tests/psxtests/psxhdrs/proc05.c (modified) * c/src/tests/psxtests/psxhdrs/proc06.c (modified) * c/src/tests/psxtests/psxhdrs/proc07.c (modified) * c/src/tests/psxtests/psxhdrs/proc08.c (modified) * c/src/tests/psxtests/psxhdrs/proc09.c (modified) * c/src/tests/psxtests/psxhdrs/proc10.c (modified) * c/src/tests/psxtests/psxhdrs/proc11.c (modified) * c/src/tests/psxtests/psxhdrs/proc12.c (modified) * c/src/tests/psxtests/psxhdrs/proc13.c (modified) * c/src/tests/psxtests/psxhdrs/proc14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread01.c (modified) * c/src/tests/psxtests/psxhdrs/pthread02.c (modified) * c/src/tests/psxtests/psxhdrs/pthread03.c (modified) * c/src/tests/psxtests/psxhdrs/pthread04.c (modified) * c/src/tests/psxtests/psxhdrs/pthread05.c (modified) * c/src/tests/psxtests/psxhdrs/pthread06.c (modified) * c/src/tests/psxtests/psxhdrs/pthread07.c (modified) * c/src/tests/psxtests/psxhdrs/pthread08.c (modified) * c/src/tests/psxtests/psxhdrs/pthread09.c (modified) * c/src/tests/psxtests/psxhdrs/pthread10.c (modified) * c/src/tests/psxtests/psxhdrs/pthread11.c (modified) * c/src/tests/psxtests/psxhdrs/pthread12.c (modified) * c/src/tests/psxtests/psxhdrs/pthread13.c (modified) * c/src/tests/psxtests/psxhdrs/pthread14.c (modified) * c/src/tests/psxtests/psxhdrs/pthread15.c (modified) * c/src/tests/psxtests/psxhdrs/pthread16.c (modified) * c/src/tests/psxtests/psxhdrs/pthread17.c (modified) * c/src/tests/psxtests/psxhdrs/pthread18.c (modified) * c/src/tests/psxtests/psxhdrs/pthread19.c (modified) * c/src/tests/psxtests/psxhdrs/pthread20.c (modified) * c/src/tests/psxtests/psxhdrs/pthread21.c (modified) * c/src/tests/psxtests/psxhdrs/pthread22.c (modified) * c/src/tests/psxtests/psxhdrs/pthread23.c (modified) * c/src/tests/psxtests/psxhdrs/pthread24.c (modified) * c/src/tests/psxtests/psxhdrs/pthread25.c (modified) * c/src/tests/psxtests/psxhdrs/pthread26.c (modified) * c/src/tests/psxtests/psxhdrs/pthread27.c (modified) * c/src/tests/psxtests/psxhdrs/pthread28.c (modified) * c/src/tests/psxtests/psxhdrs/pthread29.c (modified) * c/src/tests/psxtests/psxhdrs/pthread30.c (modified) * c/src/tests/psxtests/psxhdrs/pthread31.c (modified) * c/src/tests/psxtests/psxhdrs/pthread32.c (modified) * c/src/tests/psxtests/psxhdrs/pthread33.c (modified) * c/src/tests/psxtests/psxhdrs/pthread34.c (modified) * c/src/tests/psxtests/psxhdrs/pthread35.c (modified) * c/src/tests/psxtests/psxhdrs/pthread36.c (modified) * c/src/tests/psxtests/psxhdrs/sched01.c (modified) * c/src/tests/psxtests/psxhdrs/sched02.c (modified) * c/src/tests/psxtests/psxhdrs/sched03.c (modified) * c/src/tests/psxtests/psxhdrs/sched04.c (modified) * c/src/tests/psxtests/psxhdrs/sched05.c (modified) * c/src/tests/psxtests/psxhdrs/sched06.c (modified) * c/src/tests/psxtests/psxhdrs/sched07.c (modified) * c/src/tests/psxtests/psxhdrs/sched08.c (modified) * c/src/tests/psxtests/psxhdrs/signal01.c (modified) * c/src/tests/psxtests/psxhdrs/signal02.c (modified) * c/src/tests/psxtests/psxhdrs/signal03.c (modified) * c/src/tests/psxtests/psxhdrs/signal04.c (modified) * c/src/tests/psxtests/psxhdrs/signal05.c (modified) * c/src/tests/psxtests/psxhdrs/signal06.c (modified) * c/src/tests/psxtests/psxhdrs/signal07.c (modified) * c/src/tests/psxtests/psxhdrs/signal08.c (modified) * c/src/tests/psxtests/psxhdrs/signal09.c (modified) * c/src/tests/psxtests/psxhdrs/signal10.c (modified) * c/src/tests/psxtests/psxhdrs/signal11.c (modified) * c/src/tests/psxtests/psxhdrs/signal12.c (modified) * c/src/tests/psxtests/psxhdrs/signal13.c (modified) * c/src/tests/psxtests/psxhdrs/signal14.c (modified) * c/src/tests/psxtests/psxhdrs/signal15.c (modified) * c/src/tests/psxtests/psxhdrs/signal16.c (modified) * c/src/tests/psxtests/psxhdrs/signal17.c (modified) * c/src/tests/psxtests/psxhdrs/signal18.c (modified) * c/src/tests/psxtests/psxhdrs/signal19.c (modified) * c/src/tests/psxtests/psxhdrs/signal20.c (modified) * c/src/tests/psxtests/psxhdrs/signal21.c (modified) * c/src/tests/psxtests/psxhdrs/signal22.c (modified) * c/src/tests/psxtests/psxhdrs/time01.c (modified) * c/src/tests/psxtests/psxhdrs/time02.c (modified) * c/src/tests/psxtests/psxhdrs/time03.c (modified) * c/src/tests/psxtests/psxhdrs/time04.c (modified) * c/src/tests/psxtests/psxhdrs/time05.c (modified) * c/src/tests/psxtests/psxhdrs/time06.c (modified) * c/src/tests/psxtests/psxhdrs/time07.c (modified) * c/src/tests/psxtests/psxhdrs/time08.c (modified) * c/src/tests/psxtests/psxhdrs/time09.c (modified) * c/src/tests/psxtests/psxhdrs/time10.c (modified) * c/src/tests/psxtests/psxhdrs/time11.c (modified) * c/src/tests/psxtests/psxhdrs/time12.c (modified) * c/src/tests/psxtests/psxhdrs/time13.c (modified) * c/src/tests/psxtests/psxhdrs/timer01.c (modified) * c/src/tests/psxtests/psxhdrs/timer02.c (modified) * c/src/tests/psxtests/psxhdrs/timer03.c (modified) * c/src/tests/psxtests/psxhdrs/timer04.c (modified) * c/src/tests/psxtests/psxhdrs/timer05.c (modified) * c/src/tests/psxtests/psxhdrs/timer06.c (modified) * c/src/tests/psxtests/psxmsgq01/init.c (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtime/test.c (modified) * c/src/tests/samples/README (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/node1/base_mp.doc (modified) * c/src/tests/samples/base_mp/node2/base_mp.doc (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/base_sp.doc (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/hello.doc (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/minimum/minimum.doc (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/paranoia.doc (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/ticker/ticker.doc (modified) * c/src/tests/sptests/sp01/init.c (modified) * c/src/tests/sptests/sp01/sp01.doc (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp01/task1.c (modified) * c/src/tests/sptests/sp02/init.c (modified) * c/src/tests/sptests/sp02/preempt.c (modified) * c/src/tests/sptests/sp02/sp02.doc (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp02/task1.c (modified) * c/src/tests/sptests/sp02/task2.c (modified) * c/src/tests/sptests/sp02/task3.c (modified) * c/src/tests/sptests/sp03/init.c (modified) * c/src/tests/sptests/sp03/sp03.doc (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp03/task1.c (modified) * c/src/tests/sptests/sp03/task2.c (modified) * c/src/tests/sptests/sp04/init.c (modified) * c/src/tests/sptests/sp04/sp04.doc (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/task1.c (modified) * c/src/tests/sptests/sp04/task2.c (modified) * c/src/tests/sptests/sp04/task3.c (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/init.c (modified) * c/src/tests/sptests/sp05/sp05.doc (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp05/task1.c (modified) * c/src/tests/sptests/sp05/task2.c (modified) * c/src/tests/sptests/sp05/task3.c (modified) * c/src/tests/sptests/sp06/init.c (modified) * c/src/tests/sptests/sp06/sp06.doc (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp06/task1.c (modified) * c/src/tests/sptests/sp06/task2.c (modified) * c/src/tests/sptests/sp06/task3.c (modified) * c/src/tests/sptests/sp07/init.c (modified) * c/src/tests/sptests/sp07/sp07.doc (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp07/task1.c (modified) * c/src/tests/sptests/sp07/task2.c (modified) * c/src/tests/sptests/sp07/task3.c (modified) * c/src/tests/sptests/sp07/task4.c (modified) * c/src/tests/sptests/sp07/taskexit.c (modified) * c/src/tests/sptests/sp07/tcreate.c (modified) * c/src/tests/sptests/sp07/tdelete.c (modified) * c/src/tests/sptests/sp07/trestart.c (modified) * c/src/tests/sptests/sp07/tstart.c (modified) * c/src/tests/sptests/sp08/init.c (modified) * c/src/tests/sptests/sp08/sp08.doc (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp08/task1.c (modified) * c/src/tests/sptests/sp09/delay.c (modified) * c/src/tests/sptests/sp09/init.c (modified) * c/src/tests/sptests/sp09/isr.c (modified) * c/src/tests/sptests/sp09/screen01.c (modified) * c/src/tests/sptests/sp09/screen02.c (modified) * c/src/tests/sptests/sp09/screen03.c (modified) * c/src/tests/sptests/sp09/screen04.c (modified) * c/src/tests/sptests/sp09/screen05.c (modified) * c/src/tests/sptests/sp09/screen06.c (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/screen09.c (modified) * c/src/tests/sptests/sp09/screen10.c (modified) * c/src/tests/sptests/sp09/screen11.c (modified) * c/src/tests/sptests/sp09/screen12.c (modified) * c/src/tests/sptests/sp09/screen13.c (modified) * c/src/tests/sptests/sp09/screen14.c (modified) * c/src/tests/sptests/sp09/sp09.doc (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp09/task1.c (modified) * c/src/tests/sptests/sp09/task2.c (modified) * c/src/tests/sptests/sp09/task3.c (modified) * c/src/tests/sptests/sp09/task4.c (modified) * c/src/tests/sptests/sp11/init.c (modified) * c/src/tests/sptests/sp11/sp11.doc (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp11/task1.c (modified) * c/src/tests/sptests/sp11/task2.c (modified) * c/src/tests/sptests/sp11/timer.c (modified) * c/src/tests/sptests/sp12/init.c (modified) * c/src/tests/sptests/sp12/pridrv.c (modified) * c/src/tests/sptests/sp12/pritask.c (modified) * c/src/tests/sptests/sp12/sp12.doc (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp12/task1.c (modified) * c/src/tests/sptests/sp12/task2.c (modified) * c/src/tests/sptests/sp12/task3.c (modified) * c/src/tests/sptests/sp12/task4.c (modified) * c/src/tests/sptests/sp12/task5.c (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/sp13.doc (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp13/task3.c (modified) * c/src/tests/sptests/sp14/asr.c (modified) * c/src/tests/sptests/sp14/init.c (modified) * c/src/tests/sptests/sp14/sp14.doc (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp14/task1.c (modified) * c/src/tests/sptests/sp14/task2.c (modified) * c/src/tests/sptests/sp15/init.c (modified) * c/src/tests/sptests/sp15/sp15.doc (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp15/task1.c (modified) * c/src/tests/sptests/sp16/init.c (modified) * c/src/tests/sptests/sp16/sp16.doc (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp16/task1.c (modified) * c/src/tests/sptests/sp16/task2.c (modified) * c/src/tests/sptests/sp16/task3.c (modified) * c/src/tests/sptests/sp16/task4.c (modified) * c/src/tests/sptests/sp16/task5.c (modified) * c/src/tests/sptests/sp17/asr.c (modified) * c/src/tests/sptests/sp17/init.c (modified) * c/src/tests/sptests/sp17/sp17.doc (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp17/task1.c (modified) * c/src/tests/sptests/sp17/task2.c (modified) * c/src/tests/sptests/sp19/first.c (modified) * c/src/tests/sptests/sp19/fptask.c (modified) * c/src/tests/sptests/sp19/fptest.h (modified) * c/src/tests/sptests/sp19/init.c (modified) * c/src/tests/sptests/sp19/inttest.h (modified) * c/src/tests/sptests/sp19/sp19.doc (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp19/task1.c (modified) * c/src/tests/sptests/sp20/getall.c (modified) * c/src/tests/sptests/sp20/init.c (modified) * c/src/tests/sptests/sp20/sp20.doc (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp20/task1.c (modified) * c/src/tests/sptests/sp21/init.c (modified) * c/src/tests/sptests/sp21/sp21.doc (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp21/task1.c (modified) * c/src/tests/sptests/sp22/delay.c (modified) * c/src/tests/sptests/sp22/init.c (modified) * c/src/tests/sptests/sp22/prtime.c (modified) * c/src/tests/sptests/sp22/sp22.doc (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp22/task1.c (modified) * c/src/tests/sptests/sp23/init.c (modified) * c/src/tests/sptests/sp23/sp23.doc (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp23/task1.c (modified) * c/src/tests/sptests/sp24/init.c (modified) * c/src/tests/sptests/sp24/resume.c (modified) * c/src/tests/sptests/sp24/sp24.doc (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp24/task1.c (modified) * c/src/tests/sptests/sp25/init.c (modified) * c/src/tests/sptests/sp25/sp25.doc (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp25/task1.c (modified) * c/src/tests/sptests/sp26/init.c (modified) * c/src/tests/sptests/sp26/sp26.doc (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp26/task1.c (modified) * c/src/tests/sptests/spfatal/fatal.c (modified) * c/src/tests/sptests/spfatal/init.c (modified) * c/src/tests/sptests/spfatal/puterr.c (modified) * c/src/tests/sptests/spfatal/spfatal.doc (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spfatal/task1.c (modified) * c/src/tests/sptests/spsize/getint.c (modified) * c/src/tests/sptests/spsize/init.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/tmacros.h (modified) * c/src/tests/support/stubdr/close.c (modified) * c/src/tests/support/stubdr/cntrl.c (modified) * c/src/tests/support/stubdr/init.c (modified) * c/src/tests/support/stubdr/open.c (modified) * c/src/tests/support/stubdr/read.c (modified) * c/src/tests/support/stubdr/stubdrv.h (modified) * c/src/tests/support/stubdr/write.c (modified) * c/src/tests/tmtests/include/timesys.h (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm01/task1.c (modified) * c/src/tests/tmtests/tm01/tm01.doc (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm02/task1.c (modified) * c/src/tests/tmtests/tm02/tm02.doc (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm03/task1.c (modified) * c/src/tests/tmtests/tm03/tm03.doc (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm04/task1.c (modified) * c/src/tests/tmtests/tm04/tm04.doc (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm05/task1.c (modified) * c/src/tests/tmtests/tm05/tm05.doc (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm06/task1.c (modified) * c/src/tests/tmtests/tm06/tm06.doc (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm07/task1.c (modified) * c/src/tests/tmtests/tm07/tm07.doc (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm08/task1.c (modified) * c/src/tests/tmtests/tm08/tm08.doc (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm09/tm09.doc (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm10/task1.c (modified) * c/src/tests/tmtests/tm10/tm10.doc (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm11/tm11.doc (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm12/tm12.doc (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm13/tm13.doc (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm14/tm14.doc (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm15/task1.c (modified) * c/src/tests/tmtests/tm15/tm15.doc (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm16/task1.c (modified) * c/src/tests/tmtests/tm16/tm16.doc (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm17/task1.c (modified) * c/src/tests/tmtests/tm17/tm17.doc (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm18/task1.c (modified) * c/src/tests/tmtests/tm18/tm18.doc (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm19/task1.c (modified) * c/src/tests/tmtests/tm19/tm19.doc (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm20/task1.c (modified) * c/src/tests/tmtests/tm20/tm20.doc (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm21/tm21.doc (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm22/tm22.doc (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm23/task1.c (modified) * c/src/tests/tmtests/tm23/tm23.doc (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm24/task1.c (modified) * c/src/tests/tmtests/tm24/tm24.doc (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm25/task1.c (modified) * c/src/tests/tmtests/tm25/tm25.doc (modified) * c/src/tests/tmtests/tm26/fptest.h (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/tests/tmtests/tm26/tm26.doc (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm27/task1.c (modified) * c/src/tests/tmtests/tm27/tm27.doc (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm28/task1.c (modified) * c/src/tests/tmtests/tm28/tm28.doc (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tm29/task1.c (modified) * c/src/tests/tmtests/tm29/tm29.doc (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmck/task1.c (modified) * c/src/tests/tmtests/tmck/tmck.doc (modified) * c/src/tests/tmtests/tmoverhd/dumrtems.h (modified) * c/src/tests/tmtests/tmoverhd/empty.c (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tmtests/tmoverhd/testtask.c (modified) * c/src/tests/tmtests/tmoverhd/tmoverhd.doc (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/clockdrv.h (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/iosupp.h (modified) * cpukit/libcsupport/include/motorola/mc68230.h (modified) * cpukit/libcsupport/include/rtems/libcsupport.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/include/timerdrv.h (modified) * cpukit/libcsupport/include/vmeintr.h (modified) * cpukit/libcsupport/include/zilog/z8036.h (modified) * cpukit/libcsupport/include/zilog/z8530.h (modified) * cpukit/libcsupport/include/zilog/z8536.h (modified) * cpukit/libcsupport/src/__brk.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__sbrk.c (modified) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/access.c (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libcsupport/src/cfgetispeed.c (modified) * cpukit/libcsupport/src/cfgetospeed.c (modified) * cpukit/libcsupport/src/cfsetispeed.c (modified) * cpukit/libcsupport/src/cfsetospeed.c (modified) * cpukit/libcsupport/src/chdir.c (modified) * cpukit/libcsupport/src/chmod.c (modified) * cpukit/libcsupport/src/chown.c (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/ctermid.c (modified) * cpukit/libcsupport/src/dup.c (modified) * cpukit/libcsupport/src/dup2.c (modified) * cpukit/libcsupport/src/eval.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fs_null_handlers.c (modified) * cpukit/libcsupport/src/fstat.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/hosterr.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/libio_sockets.c (modified) * cpukit/libcsupport/src/link.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/lstat.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/mkdir.c (modified) * cpukit/libcsupport/src/mkfifo.c (modified) * cpukit/libcsupport/src/mknod.c (modified) * cpukit/libcsupport/src/mount.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libcsupport/src/open.c (modified) * cpukit/libcsupport/src/pathconf.c (modified) * cpukit/libcsupport/src/pipe.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/readlink.c (modified) * cpukit/libcsupport/src/rewinddir.c (modified) * cpukit/libcsupport/src/rmdir.c (modified) * cpukit/libcsupport/src/seekdir.c (modified) * cpukit/libcsupport/src/stat.c (modified) * cpukit/libcsupport/src/symlink.c (modified) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcflow.c (modified) * cpukit/libcsupport/src/tcflush.c (modified) * cpukit/libcsupport/src/tcgetattr.c (modified) * cpukit/libcsupport/src/tcgetprgrp.c (modified) * cpukit/libcsupport/src/tcsendbreak.c (modified) * cpukit/libcsupport/src/tcsetattr.c (modified) * cpukit/libcsupport/src/tcsetpgrp.c (modified) * cpukit/libcsupport/src/telldir.c (modified) * cpukit/libcsupport/src/truncate.c (modified) * cpukit/libcsupport/src/umask.c (modified) * cpukit/libcsupport/src/unixlibc.c (modified) * cpukit/libcsupport/src/unlink.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libcsupport/src/utime.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libfs/src/imfs/deviceio.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_chown.c (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_debug.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_eval.c (modified) * cpukit/libfs/src/imfs/imfs_fchmod.c (modified) * cpukit/libfs/src/imfs/imfs_fcntl.c (modified) * cpukit/libfs/src/imfs/imfs_fdatasync.c (modified) * cpukit/libfs/src/imfs/imfs_free.c (modified) * cpukit/libfs/src/imfs/imfs_fsunmount.c (modified) * cpukit/libfs/src/imfs/imfs_getchild.c (modified) * cpukit/libfs/src/imfs/imfs_gtkn.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_device.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_directory.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_link.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_init.c (modified) * cpukit/libfs/src/imfs/imfs_initsupp.c (modified) * cpukit/libfs/src/imfs/imfs_link.c (modified) * cpukit/libfs/src/imfs/imfs_mknod.c (modified) * cpukit/libfs/src/imfs/imfs_mount.c (modified) * cpukit/libfs/src/imfs/imfs_ntype.c (modified) * cpukit/libfs/src/imfs/imfs_readlink.c (modified) * cpukit/libfs/src/imfs/imfs_rmnod.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_symlink.c (modified) * cpukit/libfs/src/imfs/imfs_unixstub.c (modified) * cpukit/libfs/src/imfs/imfs_unlink.c (modified) * cpukit/libfs/src/imfs/imfs_unmount.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) * cpukit/libfs/src/imfs/memfile.c (modified) * cpukit/libfs/src/imfs/miniimfs_init.c (modified) * cpukit/libmisc/cpuuse/cpuuse.c (modified) * cpukit/libmisc/cpuuse/cpuuse.h (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/stackchk/check.c (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/stackchk/stackchk.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/condmp.h (modified) * cpukit/posix/include/rtems/posix/config.h (modified) * cpukit/posix/include/rtems/posix/intr.h (modified) * cpukit/posix/include/rtems/posix/key.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mqueuemp.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/mutexmp.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/pthreadmp.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/include/rtems/posix/semaphoremp.h (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/inline/rtems/posix/intr.inl (modified) * cpukit/posix/inline/rtems/posix/key.inl (modified) * cpukit/posix/inline/rtems/posix/mqueue.inl (modified) * cpukit/posix/inline/rtems/posix/mutex.inl (modified) * cpukit/posix/inline/rtems/posix/pthread.inl (modified) * cpukit/posix/inline/rtems/posix/semaphore.inl (modified) * cpukit/posix/src/alarm.c (modified) * cpukit/posix/src/kill.c (modified) * cpukit/posix/src/killinfo.c (modified) * cpukit/posix/src/pause.c (modified) * cpukit/posix/src/pthreadattrdestroy.c (modified) * cpukit/posix/src/pthreadattrgetdetachstate.c (modified) * cpukit/posix/src/pthreadattrgetinheritsched.c (modified) * cpukit/posix/src/pthreadattrgetschedparam.c (modified) * cpukit/posix/src/pthreadattrgetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrgetscope.c (modified) * cpukit/posix/src/pthreadattrgetstackaddr.c (modified) * cpukit/posix/src/pthreadattrgetstacksize.c (modified) * cpukit/posix/src/pthreadattrinit.c (modified) * cpukit/posix/src/pthreadattrsetdetachstate.c (modified) * cpukit/posix/src/pthreadattrsetinheritsched.c (modified) * cpukit/posix/src/pthreadattrsetschedparam.c (modified) * cpukit/posix/src/pthreadattrsetschedpolicy.c (modified) * cpukit/posix/src/pthreadattrsetscope.c (modified) * cpukit/posix/src/pthreadattrsetstackaddr.c (modified) * cpukit/posix/src/pthreadattrsetstacksize.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetcpuclockid.c (modified) * cpukit/posix/src/pthreadgetcputime.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadonce.c (modified) * cpukit/posix/src/pthreadself.c (modified) * cpukit/posix/src/pthreadsetcputime.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsigmask.c (modified) * cpukit/posix/src/sigaction.c (modified) * cpukit/posix/src/sigaddset.c (modified) * cpukit/posix/src/sigdelset.c (modified) * cpukit/posix/src/sigemptyset.c (modified) * cpukit/posix/src/sigfillset.c (modified) * cpukit/posix/src/sigismember.c (modified) * cpukit/posix/src/signal_2.c (modified) * cpukit/posix/src/sigpending.c (modified) * cpukit/posix/src/sigprocmask.c (modified) * cpukit/posix/src/sigqueue.c (modified) * cpukit/posix/src/sigsuspend.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/sigwait.c (modified) * cpukit/posix/src/sigwaitinfo.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/include/rtems/rtems/clock.h (modified) * cpukit/rtems/include/rtems/rtems/config.h (modified) * cpukit/rtems/include/rtems/rtems/dpmem.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/eventset.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/modes.h (modified) * cpukit/rtems/include/rtems/rtems/mp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/options.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/ratemon.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/status.h (modified) * cpukit/rtems/include/rtems/rtems/support.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/timer.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/asr.inl (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/inline/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/inline/rtems/rtems/event.inl (modified) * cpukit/rtems/inline/rtems/rtems/eventset.inl (modified) * cpukit/rtems/inline/rtems/rtems/message.inl (modified) * cpukit/rtems/inline/rtems/rtems/modes.inl (modified) * cpukit/rtems/inline/rtems/rtems/options.inl (modified) * cpukit/rtems/inline/rtems/rtems/part.inl (modified) * cpukit/rtems/inline/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/inline/rtems/rtems/region.inl (modified) * cpukit/rtems/inline/rtems/rtems/sem.inl (modified) * cpukit/rtems/inline/rtems/rtems/status.inl (modified) * cpukit/rtems/inline/rtems/rtems/support.inl (modified) * cpukit/rtems/inline/rtems/rtems/tasks.inl (modified) * cpukit/rtems/inline/rtems/rtems/timer.inl (modified) * cpukit/rtems/macros/rtems/rtems/asr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/dpmem.inl (modified) * cpukit/rtems/macros/rtems/rtems/event.inl (modified) * cpukit/rtems/macros/rtems/rtems/eventset.inl (modified) * cpukit/rtems/macros/rtems/rtems/message.inl (modified) * cpukit/rtems/macros/rtems/rtems/modes.inl (modified) * cpukit/rtems/macros/rtems/rtems/options.inl (modified) * cpukit/rtems/macros/rtems/rtems/part.inl (modified) * cpukit/rtems/macros/rtems/rtems/ratemon.inl (modified) * cpukit/rtems/macros/rtems/rtems/region.inl (modified) * cpukit/rtems/macros/rtems/rtems/sem.inl (modified) * cpukit/rtems/macros/rtems/rtems/status.inl (modified) * cpukit/rtems/macros/rtems/rtems/support.inl (modified) * cpukit/rtems/macros/rtems/rtems/tasks.inl (modified) * cpukit/rtems/macros/rtems/rtems/timer.inl (modified) * cpukit/rtems/src/attr.c (modified) * cpukit/rtems/src/clockget.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/rtems/src/clocktick.c (modified) * cpukit/rtems/src/clocktodtoseconds.c (modified) * cpukit/rtems/src/clocktodvalidate.c (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/dpmemcreate.c (modified) * cpukit/rtems/src/dpmemdelete.c (modified) * cpukit/rtems/src/dpmemexternal2internal.c (modified) * cpukit/rtems/src/dpmemident.c (modified) * cpukit/rtems/src/dpmeminternal2external.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventreceive.c (modified) * cpukit/rtems/src/eventseize.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/eventtimeout.c (modified) * cpukit/rtems/src/intr.c (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/rtems/src/intrcatch.c (modified) * cpukit/rtems/src/mp.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqallocate.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqident.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqsubmit.c (modified) * cpukit/rtems/src/msgqtranslatereturncode.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partident.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/ratemoncancel.c (modified) * cpukit/rtems/src/ratemoncreate.c (modified) * cpukit/rtems/src/ratemondelete.c (modified) * cpukit/rtems/src/ratemongetstatus.c (modified) * cpukit/rtems/src/ratemonident.c (modified) * cpukit/rtems/src/ratemonperiod.c (modified) * cpukit/rtems/src/ratemontimeout.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/regiondelete.c (modified) * cpukit/rtems/src/regionextend.c (modified) * cpukit/rtems/src/regiongetsegment.c (modified) * cpukit/rtems/src/regiongetsegmentsize.c (modified) * cpukit/rtems/src/regionident.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/regionreturnsegment.c (modified) * cpukit/rtems/src/rtclock.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/semcreate.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semident.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetnote.c (modified) * cpukit/rtems/src/taskident.c (modified) * cpukit/rtems/src/taskinitusers.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/tasksetnote.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskwakeafter.c (modified) * cpukit/rtems/src/taskwakewhen.c (modified) * cpukit/rtems/src/timercancel.c (modified) * cpukit/rtems/src/timercreate.c (modified) * cpukit/rtems/src/timerdelete.c (modified) * cpukit/rtems/src/timerfireafter.c (modified) * cpukit/rtems/src/timerfirewhen.c (modified) * cpukit/rtems/src/timerident.c (modified) * cpukit/rtems/src/timerreset.c (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/include/rtems/extension.h (modified) * cpukit/sapi/include/rtems/fatal.h (modified) * cpukit/sapi/include/rtems/init.h (modified) * cpukit/sapi/include/rtems/io.h (modified) * cpukit/sapi/include/rtems/mptables.h (modified) * cpukit/sapi/include/rtems/sptables.h.in (modified) * cpukit/sapi/inline/rtems/extension.inl (modified) * cpukit/sapi/macros/rtems/extension.inl (modified) * cpukit/sapi/src/debug.c (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/extension.c (modified) * cpukit/sapi/src/fatal.c (modified) * cpukit/sapi/src/io.c (modified) * cpukit/sapi/src/itronapi.c (modified) * cpukit/sapi/src/posixapi.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/cpu/a29k/cpu.c (modified) * cpukit/score/cpu/a29k/cpu_asm.S (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/a29k/rtems/score/cpu.h (modified) * cpukit/score/cpu/a29k/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/a29k/rtems/score/types.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) * cpukit/score/cpu/i386/cpu_asm.S (modified) * cpukit/score/cpu/i386/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/rtems/score/types.h (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/i960/cpu_asm.S (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/i960/rtems/score/types.h (modified) * cpukit/score/cpu/m68k/cpu.c (modified) * cpukit/score/cpu/m68k/cpu_asm.S (modified) * cpukit/score/cpu/m68k/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/rtems/score/types.h (modified) * cpukit/score/cpu/mips/cpu.c (modified) * cpukit/score/cpu/mips/cpu_asm.S (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips/rtems/score/types.h (modified) * cpukit/score/cpu/mips64orion/cpu.c (modified) * cpukit/score/cpu/mips64orion/cpu_asm.S (modified) * cpukit/score/cpu/mips64orion/cpu_asm.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/types.h (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu_asm.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/types.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/score/cpu/unix/rtems/score/types.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/debug.h (modified) * cpukit/score/include/rtems/score/address.h (modified) * cpukit/score/include/rtems/score/apiext.h (modified) * cpukit/score/include/rtems/score/bitfield.h (modified) * cpukit/score/include/rtems/score/chain.h (modified) * cpukit/score/include/rtems/score/context.h (modified) * cpukit/score/include/rtems/score/copyrt.h (modified) * cpukit/score/include/rtems/score/coremsg.h (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coresem.h (modified) * cpukit/score/include/rtems/score/heap.h (modified) * cpukit/score/include/rtems/score/interr.h (modified) * cpukit/score/include/rtems/score/isr.h (modified) * cpukit/score/include/rtems/score/mpci.h (modified) * cpukit/score/include/rtems/score/mppkt.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/stack.h (modified) * cpukit/score/include/rtems/score/states.h (modified) * cpukit/score/include/rtems/score/sysstate.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/tod.h (modified) * cpukit/score/include/rtems/score/tqdata.h (modified) * cpukit/score/include/rtems/score/userext.h (modified) * cpukit/score/include/rtems/score/watchdog.h (modified) * cpukit/score/include/rtems/score/wkspace.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/inline/rtems/score/address.inl (modified) * cpukit/score/inline/rtems/score/chain.inl (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/coremutex.inl (modified) * cpukit/score/inline/rtems/score/coresem.inl (modified) * cpukit/score/inline/rtems/score/heap.inl (modified) * cpukit/score/inline/rtems/score/isr.inl (modified) * cpukit/score/inline/rtems/score/mppkt.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/inline/rtems/score/objectmp.inl (modified) * cpukit/score/inline/rtems/score/priority.inl (modified) * cpukit/score/inline/rtems/score/stack.inl (modified) * cpukit/score/inline/rtems/score/states.inl (modified) * cpukit/score/inline/rtems/score/sysstate.inl (modified) * cpukit/score/inline/rtems/score/thread.inl (modified) * cpukit/score/inline/rtems/score/threadmp.inl (modified) * cpukit/score/inline/rtems/score/tod.inl (modified) * cpukit/score/inline/rtems/score/tqdata.inl (modified) * cpukit/score/inline/rtems/score/userext.inl (modified) * cpukit/score/inline/rtems/score/watchdog.inl (modified) * cpukit/score/inline/rtems/score/wkspace.inl (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/macros/rtems/score/chain.inl (modified) * cpukit/score/macros/rtems/score/coremsg.inl (modified) * cpukit/score/macros/rtems/score/coremutex.inl (modified) * cpukit/score/macros/rtems/score/coresem.inl (modified) * cpukit/score/macros/rtems/score/heap.inl (modified) * cpukit/score/macros/rtems/score/isr.inl (modified) * cpukit/score/macros/rtems/score/mppkt.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/objectmp.inl (modified) * cpukit/score/macros/rtems/score/priority.inl (modified) * cpukit/score/macros/rtems/score/stack.inl (modified) * cpukit/score/macros/rtems/score/states.inl (modified) * cpukit/score/macros/rtems/score/sysstate.inl (modified) * cpukit/score/macros/rtems/score/thread.inl (modified) * cpukit/score/macros/rtems/score/threadmp.inl (modified) * cpukit/score/macros/rtems/score/tod.inl (modified) * cpukit/score/macros/rtems/score/tqdata.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/macros/rtems/score/watchdog.inl (modified) * cpukit/score/macros/rtems/score/wkspace.inl (modified) * cpukit/score/src/apiext.c (modified) * cpukit/score/src/chain.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgbroadcast.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgflush.c (modified) * cpukit/score/src/coremsgflushsupp.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexflush.c (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/coresemflush.c (modified) * cpukit/score/src/coresemseize.c (modified) * cpukit/score/src/coresemsurrender.c (modified) * cpukit/score/src/coretod.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/coretodtickle.c (modified) * cpukit/score/src/coretodtoseconds.c (modified) * cpukit/score/src/coretodvalidate.c (modified) * cpukit/score/src/heap.c (modified) * cpukit/score/src/heapallocate.c (modified) * cpukit/score/src/heapextend.c (modified) * cpukit/score/src/heapfree.c (modified) * cpukit/score/src/heapsizeofuserarea.c (modified) * cpukit/score/src/heapwalk.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isr.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/objectallocate.c (modified) * cpukit/score/src/objectallocatebyindex.c (modified) * cpukit/score/src/objectclearname.c (modified) * cpukit/score/src/objectcomparenameraw.c (modified) * cpukit/score/src/objectcomparenamestring.c (modified) * cpukit/score/src/objectcopynameraw.c (modified) * cpukit/score/src/objectcopynamestring.c (modified) * cpukit/score/src/objectextendinformation.c (modified) * cpukit/score/src/objectfree.c (modified) * cpukit/score/src/objectget.c (modified) * cpukit/score/src/objectgetbyindex.c (modified) * cpukit/score/src/objectgetnext.c (modified) * cpukit/score/src/objectinitializeinformation.c (modified) * cpukit/score/src/objectmp.c (modified) * cpukit/score/src/objectnametoid.c (modified) * cpukit/score/src/objectshrinkinformation.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadcreateidle.c (modified) * cpukit/score/src/threaddelayended.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadevaluatemode.c (modified) * cpukit/score/src/threadget.c (modified) * cpukit/score/src/threadhandler.c (modified) * cpukit/score/src/threadidlebody.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * cpukit/score/src/threadmp.c (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqdequeue.c (modified) * cpukit/score/src/threadqdequeuefifo.c (modified) * cpukit/score/src/threadqdequeuepriority.c (modified) * cpukit/score/src/threadqenqueue.c (modified) * cpukit/score/src/threadqenqueuefifo.c (modified) * cpukit/score/src/threadqenqueuepriority.c (modified) * cpukit/score/src/threadqextract.c (modified) * cpukit/score/src/threadqextractfifo.c (modified) * cpukit/score/src/threadqextractpriority.c (modified) * cpukit/score/src/threadqextractwithproxy.c (modified) * cpukit/score/src/threadqfirst.c (modified) * cpukit/score/src/threadqfirstfifo.c (modified) * cpukit/score/src/threadqfirstpriority.c (modified) * cpukit/score/src/threadqflush.c (modified) * cpukit/score/src/threadqtimeout.c (modified) * cpukit/score/src/threadready.c (modified) * cpukit/score/src/threadreset.c (modified) * cpukit/score/src/threadresettimeslice.c (modified) * cpukit/score/src/threadrestart.c (modified) * cpukit/score/src/threadresume.c (modified) * cpukit/score/src/threadrotatequeue.c (modified) * cpukit/score/src/threadsetpriority.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadsettransient.c (modified) * cpukit/score/src/threadstackallocate.c (modified) * cpukit/score/src/threadstackfree.c (modified) * cpukit/score/src/threadstart.c (modified) * cpukit/score/src/threadstartmultitasking.c (modified) * cpukit/score/src/threadsuspend.c (modified) * cpukit/score/src/threadtickletimeslice.c (modified) * cpukit/score/src/threadyieldprocessor.c (modified) * cpukit/score/src/userext.c (modified) * cpukit/score/src/watchdog.c (modified) * cpukit/score/src/watchdogadjust.c (modified) * cpukit/score/src/watchdoginsert.c (modified) * cpukit/score/src/watchdogremove.c (modified) * cpukit/score/src/watchdogtickle.c (modified) * cpukit/score/src/wkspace.c (modified) * testsuites/libtests/cpuuse/init.c (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task1.c (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/task3.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/init.c (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/malloctest/task1.c (modified) * testsuites/libtests/monitor/init.c (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Init.cc (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtems++/Task1.cc (modified) * testsuites/libtests/rtems++/Task2.cc (modified) * testsuites/libtests/rtems++/Task3.cc (modified) * testsuites/libtests/rtmonuse/getall.c (modified) * testsuites/libtests/rtmonuse/init.c (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/rtmonuse/task1.c (modified) * testsuites/libtests/stackchk/blow.c (modified) * testsuites/libtests/stackchk/init.c (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/stackchk/task1.c (modified) * testsuites/mptests/mp01/init.c (modified) * testsuites/mptests/mp01/node1/mp01.doc (modified) * testsuites/mptests/mp01/node2/mp01.doc (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp01/task1.c (modified) * testsuites/mptests/mp02/init.c (modified) * testsuites/mptests/mp02/node1/mp02.doc (modified) * testsuites/mptests/mp02/node2/mp02.doc (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp02/task1.c (modified) * testsuites/mptests/mp03/delay.c (modified) * testsuites/mptests/mp03/init.c (modified) * testsuites/mptests/mp03/node1/mp03.doc (modified) * testsuites/mptests/mp03/node2/mp03.doc (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp03/task1.c (modified) * testsuites/mptests/mp04/init.c (modified) * testsuites/mptests/mp04/node1/mp04.doc (modified) * testsuites/mptests/mp04/node2/mp04.doc (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp04/task1.c (modified) * testsuites/mptests/mp05/asr.c (modified) * testsuites/mptests/mp05/init.c (modified) * testsuites/mptests/mp05/node1/mp05.doc (modified) * testsuites/mptests/mp05/node2/mp05.doc (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp05/task1.c (modified) * testsuites/mptests/mp06/init.c (modified) * testsuites/mptests/mp06/node1/mp06.doc (modified) * testsuites/mptests/mp06/node2/mp06.doc (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp06/task1.c (modified) * testsuites/mptests/mp07/init.c (modified) * testsuites/mptests/mp07/node1/mp07.doc (modified) * testsuites/mptests/mp07/node2/mp07.doc (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp07/task1.c (modified) * testsuites/mptests/mp08/init.c (modified) * testsuites/mptests/mp08/node1/mp08.doc (modified) * testsuites/mptests/mp08/node2/mp08.doc (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp08/task1.c (modified) * testsuites/mptests/mp09/init.c (modified) * testsuites/mptests/mp09/node1/mp09.doc (modified) * testsuites/mptests/mp09/node2/mp09.doc (modified) * testsuites/mptests/mp09/recvmsg.c (modified) * testsuites/mptests/mp09/sendmsg.c (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/mptests/mp10/init.c (modified) * testsuites/mptests/mp10/node1/mp10.doc (modified) * testsuites/mptests/mp10/node2/mp10.doc (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp10/task1.c (modified) * testsuites/mptests/mp10/task2.c (modified) * testsuites/mptests/mp10/task3.c (modified) * testsuites/mptests/mp11/init.c (modified) * testsuites/mptests/mp11/node1/mp11.doc (modified) * testsuites/mptests/mp11/node2/mp11.doc (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/init.c (modified) * testsuites/mptests/mp12/node1/mp12.doc (modified) * testsuites/mptests/mp12/node2/mp12.doc (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/init.c (modified) * testsuites/mptests/mp13/node1/mp13.doc (modified) * testsuites/mptests/mp13/node2/mp13.doc (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp13/task1.c (modified) * testsuites/mptests/mp13/task2.c (modified) * testsuites/mptests/mp14/delay.c (modified) * testsuites/mptests/mp14/evtask1.c (modified) * testsuites/mptests/mp14/evtmtask.c (modified) * testsuites/mptests/mp14/exit.c (modified) * testsuites/mptests/mp14/init.c (modified) * testsuites/mptests/mp14/msgtask1.c (modified) * testsuites/mptests/mp14/node1/mp14.doc (modified) * testsuites/mptests/mp14/node2/mp14.doc (modified) * testsuites/mptests/mp14/pttask1.c (modified) * testsuites/mptests/mp14/smtask1.c (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/psx01/init.c (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx01/task.c (modified) * testsuites/psxtests/psx02/init.c (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx02/task.c (modified) * testsuites/psxtests/psx03/init.c (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx03/task.c (modified) * testsuites/psxtests/psx04/init.c (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx04/task1.c (modified) * testsuites/psxtests/psx04/task2.c (modified) * testsuites/psxtests/psx04/task3.c (modified) * testsuites/psxtests/psx05/init.c (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx05/task.c (modified) * testsuites/psxtests/psx05/task2.c (modified) * testsuites/psxtests/psx05/task3.c (modified) * testsuites/psxtests/psx06/init.c (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx06/task.c (modified) * testsuites/psxtests/psx06/task2.c (modified) * testsuites/psxtests/psx07/init.c (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx07/task.c (modified) * testsuites/psxtests/psx08/init.c (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx08/task1.c (modified) * testsuites/psxtests/psx08/task2.c (modified) * testsuites/psxtests/psx08/task3.c (modified) * testsuites/psxtests/psx09/init.c (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/init.c (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx10/task.c (modified) * testsuites/psxtests/psx10/task2.c (modified) * testsuites/psxtests/psx10/task3.c (modified) * testsuites/psxtests/psx11/init.c (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx11/task.c (modified) * testsuites/psxtests/psx12/init.c (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx12/task.c (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psx13/test.c (modified) * testsuites/psxtests/psxcancel/init.c (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/clock01.c (modified) * testsuites/psxtests/psxhdrs/clock02.c (modified) * testsuites/psxtests/psxhdrs/clock03.c (modified) * testsuites/psxtests/psxhdrs/clock04.c (modified) * testsuites/psxtests/psxhdrs/clock05.c (modified) * testsuites/psxtests/psxhdrs/clock06.c (modified) * testsuites/psxtests/psxhdrs/cond01.c (modified) * testsuites/psxtests/psxhdrs/cond02.c (modified) * testsuites/psxtests/psxhdrs/cond03.c (modified) * testsuites/psxtests/psxhdrs/cond04.c (modified) * testsuites/psxtests/psxhdrs/cond05.c (modified) * testsuites/psxtests/psxhdrs/cond06.c (modified) * testsuites/psxtests/psxhdrs/cond07.c (modified) * testsuites/psxtests/psxhdrs/cond08.c (modified) * testsuites/psxtests/psxhdrs/cond09.c (modified) * testsuites/psxtests/psxhdrs/cond10.c (modified) * testsuites/psxtests/psxhdrs/key01.c (modified) * testsuites/psxtests/psxhdrs/key02.c (modified) * testsuites/psxtests/psxhdrs/key03.c (modified) * testsuites/psxtests/psxhdrs/key04.c (modified) * testsuites/psxtests/psxhdrs/mutex01.c (modified) * testsuites/psxtests/psxhdrs/mutex02.c (modified) * testsuites/psxtests/psxhdrs/mutex03.c (modified) * testsuites/psxtests/psxhdrs/mutex04.c (modified) * testsuites/psxtests/psxhdrs/mutex05.c (modified) * testsuites/psxtests/psxhdrs/mutex06.c (modified) * testsuites/psxtests/psxhdrs/mutex07.c (modified) * testsuites/psxtests/psxhdrs/mutex08.c (modified) * testsuites/psxtests/psxhdrs/mutex09.c (modified) * testsuites/psxtests/psxhdrs/mutex10.c (modified) * testsuites/psxtests/psxhdrs/mutex11.c (modified) * testsuites/psxtests/psxhdrs/mutex12.c (modified) * testsuites/psxtests/psxhdrs/mutex13.c (modified) * testsuites/psxtests/psxhdrs/mutex14.c (modified) * testsuites/psxtests/psxhdrs/mutex15.c (modified) * testsuites/psxtests/psxhdrs/mutex16.c (modified) * testsuites/psxtests/psxhdrs/proc01.c (modified) * testsuites/psxtests/psxhdrs/proc02.c (modified) * testsuites/psxtests/psxhdrs/proc03.c (modified) * testsuites/psxtests/psxhdrs/proc04.c (modified) * testsuites/psxtests/psxhdrs/proc05.c (modified) * testsuites/psxtests/psxhdrs/proc06.c (modified) * testsuites/psxtests/psxhdrs/proc07.c (modified) * testsuites/psxtests/psxhdrs/proc08.c (modified) * testsuites/psxtests/psxhdrs/proc09.c (modified) * testsuites/psxtests/psxhdrs/proc10.c (modified) * testsuites/psxtests/psxhdrs/proc11.c (modified) * testsuites/psxtests/psxhdrs/proc12.c (modified) * testsuites/psxtests/psxhdrs/proc13.c (modified) * testsuites/psxtests/psxhdrs/proc14.c (modified) * testsuites/psxtests/psxhdrs/pthread01.c (modified) * testsuites/psxtests/psxhdrs/pthread02.c (modified) * testsuites/psxtests/psxhdrs/pthread03.c (modified) * testsuites/psxtests/psxhdrs/pthread04.c (modified) * testsuites/psxtests/psxhdrs/pthread05.c (modified) * testsuites/psxtests/psxhdrs/pthread06.c (modified) * testsuites/psxtests/psxhdrs/pthread07.c (modified) * testsuites/psxtests/psxhdrs/pthread08.c (modified) * testsuites/psxtests/psxhdrs/pthread09.c (modified) * testsuites/psxtests/psxhdrs/pthread10.c (modified) * testsuites/psxtests/psxhdrs/pthread11.c (modified) * testsuites/psxtests/psxhdrs/pthread12.c (modified) * testsuites/psxtests/psxhdrs/pthread13.c (modified) * testsuites/psxtests/psxhdrs/pthread14.c (modified) * testsuites/psxtests/psxhdrs/pthread15.c (modified) * testsuites/psxtests/psxhdrs/pthread16.c (modified) * testsuites/psxtests/psxhdrs/pthread17.c (modified) * testsuites/psxtests/psxhdrs/pthread18.c (modified) * testsuites/psxtests/psxhdrs/pthread19.c (modified) * testsuites/psxtests/psxhdrs/pthread20.c (modified) * testsuites/psxtests/psxhdrs/pthread21.c (modified) * testsuites/psxtests/psxhdrs/pthread22.c (modified) * testsuites/psxtests/psxhdrs/pthread23.c (modified) * testsuites/psxtests/psxhdrs/pthread24.c (modified) * testsuites/psxtests/psxhdrs/pthread25.c (modified) * testsuites/psxtests/psxhdrs/pthread26.c (modified) * testsuites/psxtests/psxhdrs/pthread27.c (modified) * testsuites/psxtests/psxhdrs/pthread28.c (modified) * testsuites/psxtests/psxhdrs/pthread29.c (modified) * testsuites/psxtests/psxhdrs/pthread30.c (modified) * testsuites/psxtests/psxhdrs/pthread31.c (modified) * testsuites/psxtests/psxhdrs/pthread32.c (modified) * testsuites/psxtests/psxhdrs/pthread33.c (modified) * testsuites/psxtests/psxhdrs/pthread34.c (modified) * testsuites/psxtests/psxhdrs/pthread35.c (modified) * testsuites/psxtests/psxhdrs/pthread36.c (modified) * testsuites/psxtests/psxhdrs/sched01.c (modified) * testsuites/psxtests/psxhdrs/sched02.c (modified) * testsuites/psxtests/psxhdrs/sched03.c (modified) * testsuites/psxtests/psxhdrs/sched04.c (modified) * testsuites/psxtests/psxhdrs/sched05.c (modified) * testsuites/psxtests/psxhdrs/sched06.c (modified) * testsuites/psxtests/psxhdrs/sched07.c (modified) * testsuites/psxtests/psxhdrs/sched08.c (modified) * testsuites/psxtests/psxhdrs/signal01.c (modified) * testsuites/psxtests/psxhdrs/signal02.c (modified) * testsuites/psxtests/psxhdrs/signal03.c (modified) * testsuites/psxtests/psxhdrs/signal04.c (modified) * testsuites/psxtests/psxhdrs/signal05.c (modified) * testsuites/psxtests/psxhdrs/signal06.c (modified) * testsuites/psxtests/psxhdrs/signal07.c (modified) * testsuites/psxtests/psxhdrs/signal08.c (modified) * testsuites/psxtests/psxhdrs/signal09.c (modified) * testsuites/psxtests/psxhdrs/signal10.c (modified) * testsuites/psxtests/psxhdrs/signal11.c (modified) * testsuites/psxtests/psxhdrs/signal12.c (modified) * testsuites/psxtests/psxhdrs/signal13.c (modified) * testsuites/psxtests/psxhdrs/signal14.c (modified) * testsuites/psxtests/psxhdrs/signal15.c (modified) * testsuites/psxtests/psxhdrs/signal16.c (modified) * testsuites/psxtests/psxhdrs/signal17.c (modified) * testsuites/psxtests/psxhdrs/signal18.c (modified) * testsuites/psxtests/psxhdrs/signal19.c (modified) * testsuites/psxtests/psxhdrs/signal20.c (modified) * testsuites/psxtests/psxhdrs/signal21.c (modified) * testsuites/psxtests/psxhdrs/signal22.c (modified) * testsuites/psxtests/psxhdrs/time01.c (modified) * testsuites/psxtests/psxhdrs/time02.c (modified) * testsuites/psxtests/psxhdrs/time03.c (modified) * testsuites/psxtests/psxhdrs/time04.c (modified) * testsuites/psxtests/psxhdrs/time05.c (modified) * testsuites/psxtests/psxhdrs/time06.c (modified) * testsuites/psxtests/psxhdrs/time07.c (modified) * testsuites/psxtests/psxhdrs/time08.c (modified) * testsuites/psxtests/psxhdrs/time09.c (modified) * testsuites/psxtests/psxhdrs/time10.c (modified) * testsuites/psxtests/psxhdrs/time11.c (modified) * testsuites/psxtests/psxhdrs/time12.c (modified) * testsuites/psxtests/psxhdrs/time13.c (modified) * testsuites/psxtests/psxhdrs/timer01.c (modified) * testsuites/psxtests/psxhdrs/timer02.c (modified) * testsuites/psxtests/psxhdrs/timer03.c (modified) * testsuites/psxtests/psxhdrs/timer04.c (modified) * testsuites/psxtests/psxhdrs/timer05.c (modified) * testsuites/psxtests/psxhdrs/timer06.c (modified) * testsuites/psxtests/psxmsgq01/init.c (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtime/test.c (modified) * testsuites/samples/README (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/node1/base_mp.doc (modified) * testsuites/samples/base_mp/node2/base_mp.doc (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/base_sp.doc (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/hello.doc (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/minimum/minimum.doc (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/paranoia.doc (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/ticker/ticker.doc (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp01/task1.c (modified) * testsuites/sptests/sp02/init.c (modified) * testsuites/sptests/sp02/preempt.c (modified) * testsuites/sptests/sp02/sp02.doc (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp02/task1.c (modified) * testsuites/sptests/sp02/task2.c (modified) * testsuites/sptests/sp02/task3.c (modified) * testsuites/sptests/sp03/init.c (modified) * testsuites/sptests/sp03/sp03.doc (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp03/task1.c (modified) * testsuites/sptests/sp03/task2.c (modified) * testsuites/sptests/sp04/init.c (modified) * testsuites/sptests/sp04/sp04.doc (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/task1.c (modified) * testsuites/sptests/sp04/task2.c (modified) * testsuites/sptests/sp04/task3.c (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/init.c (modified) * testsuites/sptests/sp05/sp05.doc (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp05/task1.c (modified) * testsuites/sptests/sp05/task2.c (modified) * testsuites/sptests/sp05/task3.c (modified) * testsuites/sptests/sp06/init.c (modified) * testsuites/sptests/sp06/sp06.doc (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp06/task1.c (modified) * testsuites/sptests/sp06/task2.c (modified) * testsuites/sptests/sp06/task3.c (modified) * testsuites/sptests/sp07/init.c (modified) * testsuites/sptests/sp07/sp07.doc (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp07/task1.c (modified) * testsuites/sptests/sp07/task2.c (modified) * testsuites/sptests/sp07/task3.c (modified) * testsuites/sptests/sp07/task4.c (modified) * testsuites/sptests/sp07/taskexit.c (modified) * testsuites/sptests/sp07/tcreate.c (modified) * testsuites/sptests/sp07/tdelete.c (modified) * testsuites/sptests/sp07/trestart.c (modified) * testsuites/sptests/sp07/tstart.c (modified) * testsuites/sptests/sp08/init.c (modified) * testsuites/sptests/sp08/sp08.doc (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp08/task1.c (modified) * testsuites/sptests/sp09/delay.c (modified) * testsuites/sptests/sp09/init.c (modified) * testsuites/sptests/sp09/isr.c (modified) * testsuites/sptests/sp09/screen01.c (modified) * testsuites/sptests/sp09/screen02.c (modified) * testsuites/sptests/sp09/screen03.c (modified) * testsuites/sptests/sp09/screen04.c (modified) * testsuites/sptests/sp09/screen05.c (modified) * testsuites/sptests/sp09/screen06.c (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/screen09.c (modified) * testsuites/sptests/sp09/screen10.c (modified) * testsuites/sptests/sp09/screen11.c (modified) * testsuites/sptests/sp09/screen12.c (modified) * testsuites/sptests/sp09/screen13.c (modified) * testsuites/sptests/sp09/screen14.c (modified) * testsuites/sptests/sp09/sp09.doc (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp09/task1.c (modified) * testsuites/sptests/sp09/task2.c (modified) * testsuites/sptests/sp09/task3.c (modified) * testsuites/sptests/sp09/task4.c (modified) * testsuites/sptests/sp11/init.c (modified) * testsuites/sptests/sp11/sp11.doc (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp11/task1.c (modified) * testsuites/sptests/sp11/task2.c (modified) * testsuites/sptests/sp11/timer.c (modified) * testsuites/sptests/sp12/init.c (modified) * testsuites/sptests/sp12/pridrv.c (modified) * testsuites/sptests/sp12/pritask.c (modified) * testsuites/sptests/sp12/sp12.doc (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp12/task1.c (modified) * testsuites/sptests/sp12/task2.c (modified) * testsuites/sptests/sp12/task3.c (modified) * testsuites/sptests/sp12/task4.c (modified) * testsuites/sptests/sp12/task5.c (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/sp13.doc (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp13/task3.c (modified) * testsuites/sptests/sp14/asr.c (modified) * testsuites/sptests/sp14/init.c (modified) * testsuites/sptests/sp14/sp14.doc (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp14/task1.c (modified) * testsuites/sptests/sp14/task2.c (modified) * testsuites/sptests/sp15/init.c (modified) * testsuites/sptests/sp15/sp15.doc (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp15/task1.c (modified) * testsuites/sptests/sp16/init.c (modified) * testsuites/sptests/sp16/sp16.doc (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp16/task1.c (modified) * testsuites/sptests/sp16/task2.c (modified) * testsuites/sptests/sp16/task3.c (modified) * testsuites/sptests/sp16/task4.c (modified) * testsuites/sptests/sp16/task5.c (modified) * testsuites/sptests/sp17/asr.c (modified) * testsuites/sptests/sp17/init.c (modified) * testsuites/sptests/sp17/sp17.doc (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp17/task1.c (modified) * testsuites/sptests/sp17/task2.c (modified) * testsuites/sptests/sp19/first.c (modified) * testsuites/sptests/sp19/fptask.c (modified) * testsuites/sptests/sp19/fptest.h (modified) * testsuites/sptests/sp19/init.c (modified) * testsuites/sptests/sp19/inttest.h (modified) * testsuites/sptests/sp19/sp19.doc (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp19/task1.c (modified) * testsuites/sptests/sp20/getall.c (modified) * testsuites/sptests/sp20/init.c (modified) * testsuites/sptests/sp20/sp20.doc (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp20/task1.c (modified) * testsuites/sptests/sp21/init.c (modified) * testsuites/sptests/sp21/sp21.doc (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp21/task1.c (modified) * testsuites/sptests/sp22/delay.c (modified) * testsuites/sptests/sp22/init.c (modified) * testsuites/sptests/sp22/prtime.c (modified) * testsuites/sptests/sp22/sp22.doc (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp22/task1.c (modified) * testsuites/sptests/sp23/init.c (modified) * testsuites/sptests/sp23/sp23.doc (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp23/task1.c (modified) * testsuites/sptests/sp24/init.c (modified) * testsuites/sptests/sp24/resume.c (modified) * testsuites/sptests/sp24/sp24.doc (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp24/task1.c (modified) * testsuites/sptests/sp25/init.c (modified) * testsuites/sptests/sp25/sp25.doc (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp25/task1.c (modified) * testsuites/sptests/sp26/init.c (modified) * testsuites/sptests/sp26/sp26.doc (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp26/task1.c (modified) * testsuites/sptests/spfatal/fatal.c (modified) * testsuites/sptests/spfatal/init.c (modified) * testsuites/sptests/spfatal/puterr.c (modified) * testsuites/sptests/spfatal/spfatal.doc (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spfatal/task1.c (modified) * testsuites/sptests/spsize/getint.c (modified) * testsuites/sptests/spsize/init.c (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/support/include/tmacros.h (modified) * testsuites/tmtests/include/timesys.h (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm01/task1.c (modified) * testsuites/tmtests/tm01/tm01.doc (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm02/task1.c (modified) * testsuites/tmtests/tm02/tm02.doc (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm03/task1.c (modified) * testsuites/tmtests/tm03/tm03.doc (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm04/task1.c (modified) * testsuites/tmtests/tm04/tm04.doc (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm05/task1.c (modified) * testsuites/tmtests/tm05/tm05.doc (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm06/task1.c (modified) * testsuites/tmtests/tm06/tm06.doc (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm07/task1.c (modified) * testsuites/tmtests/tm07/tm07.doc (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm08/task1.c (modified) * testsuites/tmtests/tm08/tm08.doc (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm09/tm09.doc (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm10/task1.c (modified) * testsuites/tmtests/tm10/tm10.doc (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm11/tm11.doc (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm12/tm12.doc (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm13/tm13.doc (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm14/tm14.doc (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm15/task1.c (modified) * testsuites/tmtests/tm15/tm15.doc (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm16/task1.c (modified) * testsuites/tmtests/tm16/tm16.doc (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm17/task1.c (modified) * testsuites/tmtests/tm17/tm17.doc (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm18/task1.c (modified) * testsuites/tmtests/tm18/tm18.doc (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm19/task1.c (modified) * testsuites/tmtests/tm19/tm19.doc (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm20/task1.c (modified) * testsuites/tmtests/tm20/tm20.doc (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm21/tm21.doc (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm22/tm22.doc (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm23/task1.c (modified) * testsuites/tmtests/tm23/tm23.doc (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm24/task1.c (modified) * testsuites/tmtests/tm24/tm24.doc (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm25/task1.c (modified) * testsuites/tmtests/tm25/tm25.doc (modified) * testsuites/tmtests/tm26/fptest.h (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm26/tm26.doc (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm27/task1.c (modified) * testsuites/tmtests/tm27/tm27.doc (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm28/task1.c (modified) * testsuites/tmtests/tm28/tm28.doc (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tm29/task1.c (modified) * testsuites/tmtests/tm29/tm29.doc (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmck/task1.c (modified) * testsuites/tmtests/tmck/tmck.doc (modified) * testsuites/tmtests/tmoverhd/dumrtems.h (modified) * testsuites/tmtests/tmoverhd/empty.c (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tmtests/tmoverhd/testtask.c (modified) * testsuites/tmtests/tmoverhd/tmoverhd.doc (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/genoffsets.c (modified) * tools/cpu/unix/gensize.c (modified) Updated copyright notice. Wed, 17 Nov 1999 16:47:58 GMT Jennifer Averett [9d9a3dd] * c/src/exec/itron/include/itron.h (modified) * c/src/exec/itron/include/itronsys/eventflags.h (modified) * c/src/exec/itron/include/itronsys/fmempool.h (modified) * c/src/exec/itron/include/itronsys/intr.h (modified) * c/src/exec/itron/include/itronsys/mbox.h (modified) * c/src/exec/itron/include/itronsys/msgbuffer.h (modified) * c/src/exec/itron/include/itronsys/network.h (modified) * c/src/exec/itron/include/itronsys/port.h (modified) * c/src/exec/itron/include/itronsys/semaphore.h (modified) * c/src/exec/itron/include/itronsys/status.h (modified) * c/src/exec/itron/include/itronsys/sysmgmt.h (modified) * c/src/exec/itron/include/itronsys/task.h (modified) * c/src/exec/itron/include/itronsys/time.h (modified) * c/src/exec/itron/include/itronsys/types.h (modified) * c/src/exec/itron/include/itronsys/vmempool.h (modified) * c/src/exec/itron/include/rtems/itron/config.h (modified) * c/src/exec/itron/include/rtems/itron/eventflags.h (modified) * c/src/exec/itron/include/rtems/itron/fmempool.h (modified) * c/src/exec/itron/include/rtems/itron/intr.h (modified) * c/src/exec/itron/include/rtems/itron/itronapi.h (modified) * c/src/exec/itron/include/rtems/itron/mbox.h (modified) * c/src/exec/itron/include/rtems/itron/msgbuffer.h (modified) * c/src/exec/itron/include/rtems/itron/network.h (modified) * c/src/exec/itron/include/rtems/itron/object.h (modified) * c/src/exec/itron/include/rtems/itron/port.h (modified) * c/src/exec/itron/include/rtems/itron/semaphore.h (modified) * c/src/exec/itron/include/rtems/itron/sysmgmt.h (modified) * c/src/exec/itron/include/rtems/itron/task.h (modified) * c/src/exec/itron/include/rtems/itron/time.h (modified) * c/src/exec/itron/include/rtems/itron/vmempool.h (modified) * c/src/exec/itron/inline/rtems/itron/eventflags.inl (modified) * c/src/exec/itron/inline/rtems/itron/fmempool.inl (modified) * c/src/exec/itron/inline/rtems/itron/intr.inl (modified) * c/src/exec/itron/inline/rtems/itron/mbox.inl (modified) * c/src/exec/itron/inline/rtems/itron/msgbuffer.inl (modified) * c/src/exec/itron/inline/rtems/itron/network.inl (modified) * c/src/exec/itron/inline/rtems/itron/port.inl (modified) * c/src/exec/itron/inline/rtems/itron/semaphore.inl (modified) * c/src/exec/itron/inline/rtems/itron/sysmgmt.inl (modified) * c/src/exec/itron/inline/rtems/itron/task.inl (modified) * c/src/exec/itron/inline/rtems/itron/time.inl (modified) * c/src/exec/itron/inline/rtems/itron/vmempool.inl (modified) * c/src/exec/itron/src/can_wup.c (modified) * c/src/exec/itron/src/chg_pri.c (modified) * c/src/exec/itron/src/cre_mbf.c (modified) * c/src/exec/itron/src/cre_mbx.c (modified) * c/src/exec/itron/src/cre_sem.c (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/del_mbf.c (modified) * c/src/exec/itron/src/del_mbx.c (modified) * c/src/exec/itron/src/del_sem.c (modified) * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/dis_dsp.c (modified) * c/src/exec/itron/src/ena_dsp.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/exd_tsk.c (modified) * c/src/exec/itron/src/ext_tsk.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/get_tid.c (modified) * c/src/exec/itron/src/itronintr.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/itrontime.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/mboxtranslatereturncode.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/msgbuffertranslatereturncode.c (modified) * c/src/exec/itron/src/network.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/prcv_mbf.c (modified) * c/src/exec/itron/src/prcv_mbx.c (modified) * c/src/exec/itron/src/preq_sem.c (modified) * c/src/exec/itron/src/psnd_mbf.c (modified) * c/src/exec/itron/src/rcv_mbf.c (modified) * c/src/exec/itron/src/rcv_mbx.c (modified) * c/src/exec/itron/src/ref_mbf.c (modified) * c/src/exec/itron/src/ref_mbx.c (modified) * c/src/exec/itron/src/ref_sem.c (modified) * c/src/exec/itron/src/ref_tsk.c (modified) * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rot_rdq.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * c/src/exec/itron/src/sig_sem.c (modified) * c/src/exec/itron/src/slp_tsk.c (modified) * c/src/exec/itron/src/snd_mbf.c (modified) * c/src/exec/itron/src/snd_mbx.c (modified) * c/src/exec/itron/src/sta_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/sysmgmt.c (modified) * c/src/exec/itron/src/task.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * c/src/exec/itron/src/trcv_mbf.c (modified) * c/src/exec/itron/src/trcv_mbx.c (modified) * c/src/exec/itron/src/tslp_tsk.c (modified) * c/src/exec/itron/src/tsnd_mbf.c (modified) * c/src/exec/itron/src/twai_sem.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/itron/src/wai_sem.c (modified) * c/src/exec/itron/src/wup_tsk.c (modified) * c/src/tests/itrontests/itronhello/init.c (modified) * c/src/tests/itrontests/itronhello/itronhello.doc (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/init.c (modified) * c/src/tests/itrontests/itronmbf01/itronmbf01.doc (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/init.c (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/itronsem01.doc (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/init.c (modified) * c/src/tests/itrontests/itrontask01/itrontask01.doc (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask01/task1.c (modified) * c/src/tests/itrontests/itrontask02/dormant.c (modified) * c/src/tests/itrontests/itrontask02/init.c (modified) * c/src/tests/itrontests/itrontask02/itrontask02.doc (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/init.c (modified) * c/src/tests/itrontests/itrontask03/itrontask03.doc (modified) * c/src/tests/itrontests/itrontask03/preempt.c (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask03/task1.c (modified) * c/src/tests/itrontests/itrontask03/task2.c (modified) * c/src/tests/itrontests/itrontask03/task3.c (modified) * c/src/tests/itrontests/itrontask04/init.c (modified) * c/src/tests/itrontests/itrontask04/itrontask04.doc (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontask04/task1.c (modified) * c/src/tests/itrontests/itrontask04/task2.c (modified) * c/src/tests/itrontests/itrontask04/task3.c (modified) * c/src/tests/itrontests/itrontime01/init.c (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * cpukit/itron/include/itron.h (modified) * cpukit/itron/include/itronsys/eventflags.h (modified) * cpukit/itron/include/itronsys/fmempool.h (modified) * cpukit/itron/include/itronsys/intr.h (modified) * cpukit/itron/include/itronsys/mbox.h (modified) * cpukit/itron/include/itronsys/msgbuffer.h (modified) * cpukit/itron/include/itronsys/network.h (modified) * cpukit/itron/include/itronsys/port.h (modified) * cpukit/itron/include/itronsys/semaphore.h (modified) * cpukit/itron/include/itronsys/status.h (modified) * cpukit/itron/include/itronsys/sysmgmt.h (modified) * cpukit/itron/include/itronsys/task.h (modified) * cpukit/itron/include/itronsys/time.h (modified) * cpukit/itron/include/itronsys/types.h (modified) * cpukit/itron/include/itronsys/vmempool.h (modified) * cpukit/itron/include/rtems/itron/config.h (modified) * cpukit/itron/include/rtems/itron/eventflags.h (modified) * cpukit/itron/include/rtems/itron/fmempool.h (modified) * cpukit/itron/include/rtems/itron/intr.h (modified) * cpukit/itron/include/rtems/itron/itronapi.h (modified) * cpukit/itron/include/rtems/itron/mbox.h (modified) * cpukit/itron/include/rtems/itron/msgbuffer.h (modified) * cpukit/itron/include/rtems/itron/network.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/port.h (modified) * cpukit/itron/include/rtems/itron/semaphore.h (modified) * cpukit/itron/include/rtems/itron/sysmgmt.h (modified) * cpukit/itron/include/rtems/itron/task.h (modified) * cpukit/itron/include/rtems/itron/time.h (modified) * cpukit/itron/include/rtems/itron/vmempool.h (modified) * cpukit/itron/inline/rtems/itron/eventflags.inl (modified) * cpukit/itron/inline/rtems/itron/fmempool.inl (modified) * cpukit/itron/inline/rtems/itron/intr.inl (modified) * cpukit/itron/inline/rtems/itron/mbox.inl (modified) * cpukit/itron/inline/rtems/itron/msgbuffer.inl (modified) * cpukit/itron/inline/rtems/itron/network.inl (modified) * cpukit/itron/inline/rtems/itron/port.inl (modified) * cpukit/itron/inline/rtems/itron/semaphore.inl (modified) * cpukit/itron/inline/rtems/itron/sysmgmt.inl (modified) * cpukit/itron/inline/rtems/itron/task.inl (modified) * cpukit/itron/inline/rtems/itron/time.inl (modified) * cpukit/itron/inline/rtems/itron/vmempool.inl (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/cre_mbf.c (modified) * cpukit/itron/src/cre_mbx.c (modified) * cpukit/itron/src/cre_sem.c (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/del_mbf.c (modified) * cpukit/itron/src/del_mbx.c (modified) * cpukit/itron/src/del_sem.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/dis_dsp.c (modified) * cpukit/itron/src/ena_dsp.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/exd_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/get_tid.c (modified) * cpukit/itron/src/itronintr.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/itrontime.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/mboxtranslatereturncode.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/msgbuffertranslatereturncode.c (modified) * cpukit/itron/src/network.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/prcv_mbf.c (modified) * cpukit/itron/src/prcv_mbx.c (modified) * cpukit/itron/src/preq_sem.c (modified) * cpukit/itron/src/psnd_mbf.c (modified) * cpukit/itron/src/rcv_mbf.c (modified) * cpukit/itron/src/rcv_mbx.c (modified) * cpukit/itron/src/ref_mbf.c (modified) * cpukit/itron/src/ref_mbx.c (modified) * cpukit/itron/src/ref_sem.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/sig_sem.c (modified) * cpukit/itron/src/slp_tsk.c (modified) * cpukit/itron/src/snd_mbf.c (modified) * cpukit/itron/src/snd_mbx.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/sysmgmt.c (modified) * cpukit/itron/src/task.c (modified) * cpukit/itron/src/ter_tsk.c (modified) * cpukit/itron/src/trcv_mbf.c (modified) * cpukit/itron/src/trcv_mbx.c (modified) * cpukit/itron/src/tslp_tsk.c (modified) * cpukit/itron/src/tsnd_mbf.c (modified) * cpukit/itron/src/twai_sem.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/itron/src/wai_sem.c (modified) * cpukit/itron/src/wup_tsk.c (modified) * testsuites/itrontests/itronhello/init.c (modified) * testsuites/itrontests/itronhello/itronhello.doc (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/init.c (modified) * testsuites/itrontests/itronmbf01/itronmbf01.doc (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/init.c (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/itronsem01.doc (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/init.c (modified) * testsuites/itrontests/itrontask01/itrontask01.doc (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask01/task1.c (modified) * testsuites/itrontests/itrontask02/dormant.c (modified) * testsuites/itrontests/itrontask02/init.c (modified) * testsuites/itrontests/itrontask02/itrontask02.doc (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/init.c (modified) * testsuites/itrontests/itrontask03/itrontask03.doc (modified) * testsuites/itrontests/itrontask03/preempt.c (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask03/task1.c (modified) * testsuites/itrontests/itrontask03/task2.c (modified) * testsuites/itrontests/itrontask03/task3.c (modified) * testsuites/itrontests/itrontask04/init.c (modified) * testsuites/itrontests/itrontask04/itrontask04.doc (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontask04/task1.c (modified) * testsuites/itrontests/itrontask04/task2.c (modified) * testsuites/itrontests/itrontask04/task3.c (modified) * testsuites/itrontests/itrontime01/init.c (modified) * testsuites/itrontests/itrontime01/system.h (modified) + Updated copyright information. Wed, 17 Nov 1999 15:24:11 GMT Joel Sherrill [5e96e917] * c/src/exec/itron/include/itronsys/mbox.h (modified) * c/src/exec/itron/include/rtems/itron/mbox.h (modified) * c/src/exec/itron/src/cre_mbx.c (added) * c/src/exec/itron/src/del_mbx.c (added) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/mboxtranslatereturncode.c (added) * c/src/exec/itron/src/prcv_mbx.c (added) * c/src/exec/itron/src/rcv_mbx.c (added) * c/src/exec/itron/src/ref_mbx.c (added) * c/src/exec/itron/src/snd_mbx.c (added) * c/src/exec/itron/src/trcv_mbx.c (added) * cpukit/itron/include/itronsys/mbox.h (modified) * cpukit/itron/include/rtems/itron/mbox.h (modified) * cpukit/itron/src/cre_mbx.c (added) * cpukit/itron/src/del_mbx.c (added) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/mboxtranslatereturncode.c (added) * cpukit/itron/src/prcv_mbx.c (added) * cpukit/itron/src/rcv_mbx.c (added) * cpukit/itron/src/ref_mbx.c (added) * cpukit/itron/src/snd_mbx.c (added) * cpukit/itron/src/trcv_mbx.c (added) Updated Mailbox Manager submitted and split into multiple files. Wed, 17 Nov 1999 14:56:18 GMT Joel Sherrill [1c10acc] * c/src/exec/itron/src/mbox.c (modified) * cpukit/itron/src/mbox.c (modified) Update from Andrew D. McDowell with ... Tue, 16 Nov 1999 22:56:38 GMT Joel Sherrill [aad726e] * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) Moved task_variable pointer to basic shared part of TCB instead of ... Tue, 16 Nov 1999 22:47:23 GMT Jennifer Averett [4efe2b7a] * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) Added check to return passed if task is not suspended. Tue, 16 Nov 1999 22:46:55 GMT Jennifer Averett [0fa51b5b] * c/src/exec/itron/src/sus_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) Added code to catch the error of suspend count exceding the counter ... Tue, 16 Nov 1999 22:45:51 GMT Jennifer Averett [9181246] * c/src/exec/libcsupport/src/utime.c (modified) * c/src/lib/libc/utime.c (modified) * cpukit/libcsupport/src/utime.c (modified) Fixed bug. Tue, 16 Nov 1999 22:45:33 GMT Jennifer Averett [18c3155] * c/src/exec/libfs/src/imfs/imfs_handlers_memfile.c (modified) * c/src/lib/libc/imfs_handlers_memfile.c (modified) * c/src/libfs/src/imfs/imfs_handlers_memfile.c (modified) * cpukit/libfs/src/imfs/imfs_handlers_memfile.c (modified) Added handler for fsync. For the memfile it is the same as the data sync. Tue, 16 Nov 1999 16:14:37 GMT Joel Sherrill [65a38bc] * c/src/exec/libnetworking/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/libnetworking/Makefile.am (modified) Web server uses the POSIX API. Therefor, it must be disabled when ... Tue, 16 Nov 1999 16:13:26 GMT Joel Sherrill [ce18601a] * c/src/exec/libcsupport/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * cpukit/libcsupport/Makefile.am (modified) Removed start subdirectory and distributed contents to the ... Tue, 16 Nov 1999 16:10:39 GMT Joel Sherrill [0cb7cb9] * c/src/exec/score/src/threadclose.c (modified) * c/src/exec/score/src/threadinitialize.c (modified) * c/src/exec/score/src/threadstart.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadstart.c (modified) Added comments. Tue, 16 Nov 1999 16:09:50 GMT Joel Sherrill [d3fdf459] * c/src/exec/score/src/threadrestart.c (modified) * cpukit/score/src/threadrestart.c (modified) Now use _Thread_Reset(). Tue, 16 Nov 1999 16:08:10 GMT Joel Sherrill [88cb6b2] * c/src/exec/score/src/Makefile.in (modified) Added threadreset.c. Tue, 16 Nov 1999 16:07:52 GMT Joel Sherrill [f6d0821] * c/src/exec/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) Added prototype for _Thread_Reset() and numerous comments. Tue, 16 Nov 1999 16:07:17 GMT Joel Sherrill [c094542] * c/src/exec/score/cpu/configure.in (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) Only check for System V IPC if multiprocessing is enabled. The unix ... Tue, 16 Nov 1999 16:04:51 GMT Joel Sherrill [f4b76ab5] * c/src/exec/sapi/include/rtems/sptables.h.in (modified) * cpukit/sapi/include/rtems/sptables.h.in (modified) Fixed so can be included multiple times in the executive source. Tue, 16 Nov 1999 16:03:21 GMT Joel Sherrill [31473b7] * c/src/exec/libcsupport/src/utsname.c (modified) * c/src/exec/posix/src/utsname.c (modified) * c/src/lib/libc/utsname.c (modified) * cpukit/libcsupport/src/utsname.c (modified) Works now. Removed times() since the version in the C Library ... Tue, 16 Nov 1999 16:01:54 GMT Joel Sherrill [165fe39] * c/src/exec/posix/src/setsid.c (modified) * cpukit/posix/src/setsid.c (modified) Return a reasonable error other than ENOSYS. Tue, 16 Nov 1999 16:01:32 GMT Joel Sherrill [7fec3b7a] * c/src/exec/posix/src/pthreadsetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) Added call to _Watchdog_Remove to remove the sporadic timer. It was ... Tue, 16 Nov 1999 16:00:11 GMT Joel Sherrill [2c0e896e] * c/src/exec/posix/src/Makefile.in (modified) Moved utsname from "build for now" (unimplemented files) to the main ... Tue, 16 Nov 1999 15:58:21 GMT Joel Sherrill [d280ce18] * c/src/exec/itron/include/rtems/itron/msgbuffer.h (modified) * cpukit/itron/include/rtems/itron/msgbuffer.h (modified) Comment fixed when adding prototype for ... Tue, 16 Nov 1999 15:52:49 GMT Joel Sherrill [bd462d1] * c/src/exec/score/src/threadreset.c (added) * cpukit/score/src/threadreset.c (added) New file. Tue, 16 Nov 1999 15:28:03 GMT Joel Sherrill [817031f] * c/src/exec/libcsupport/src/ttyname_r.c (added) * c/src/lib/libc/ttyname_r.c (added) * cpukit/libcsupport/src/ttyname_r.c (added) New file. Tue, 16 Nov 1999 15:27:52 GMT Joel Sherrill [c7016198] * c/src/exec/libcsupport/src/ctermid.c (added) * c/src/exec/libcsupport/src/tcgetprgrp.c (added) * c/src/exec/libcsupport/src/tcsendbreak.c (added) * c/src/exec/libcsupport/src/tcsetpgrp.c (added) * c/src/exec/libcsupport/src/ttyname.c (added) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/ctermid.c (added) * c/src/lib/libc/tcgetprgrp.c (added) * c/src/lib/libc/tcsendbreak.c (added) * c/src/lib/libc/tcsetpgrp.c (added) * c/src/lib/libc/ttyname.c (added) * cpukit/libcsupport/src/ctermid.c (added) * cpukit/libcsupport/src/tcgetprgrp.c (added) * cpukit/libcsupport/src/tcsendbreak.c (added) * cpukit/libcsupport/src/tcsetpgrp.c (added) * cpukit/libcsupport/src/ttyname.c (added) Added. Tue, 16 Nov 1999 15:26:29 GMT Joel Sherrill [b88691c] * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/lib/libc/scandir.c (modified) * cpukit/libcsupport/src/scandir.c (modified) Source and destination arguments to strncpy were swapped. This ... Mon, 15 Nov 1999 22:19:51 GMT Joel Sherrill [80fd699] * c/src/exec/posix/src/sysconf.c (modified) * cpukit/posix/src/sysconf.c (modified) Removed nanosleep() since it is now in its own file. Mon, 15 Nov 1999 21:37:56 GMT Jennifer Averett [40aac29] * c/src/exec/itron/include/rtems/itron/object.h (modified) * cpukit/itron/include/rtems/itron/object.h (modified) Returned third parameter for a NULL name to the objects open call. Mon, 15 Nov 1999 21:35:14 GMT Jennifer Averett [25789705] * c/src/exec/itron/src/can_wup.c (modified) * c/src/exec/itron/src/chg_pri.c (modified) * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/ref_tsk.c (modified) * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rot_rdq.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * c/src/exec/itron/src/sta_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * cpukit/itron/src/can_wup.c (modified) * cpukit/itron/src/chg_pri.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/ref_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rot_rdq.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/ter_tsk.c (modified) + Fixed files to consistantly use a case of the location after calls ... Mon, 15 Nov 1999 21:31:28 GMT Jennifer Averett [1ae60eb4] * c/src/exec/itron/src/ext_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) + Modified to use new Thread_Reset routine instead of the restart method. Mon, 15 Nov 1999 17:15:58 GMT Joel Sherrill [9da0994] * c/src/exec/itron/src/Makefile.in (modified) * c/src/exec/itron/src/cre_mbf.c (added) * c/src/exec/itron/src/del_mbf.c (added) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/msgbuffertranslatereturncode.c (added) * c/src/exec/itron/src/prcv_mbf.c (added) * c/src/exec/itron/src/psnd_mbf.c (added) * c/src/exec/itron/src/rcv_mbf.c (added) * c/src/exec/itron/src/ref_mbf.c (added) * c/src/exec/itron/src/snd_mbf.c (added) * c/src/exec/itron/src/trcv_mbf.c (added) * c/src/exec/itron/src/tsnd_mbf.c (added) * cpukit/itron/src/cre_mbf.c (added) * cpukit/itron/src/del_mbf.c (added) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/msgbuffertranslatereturncode.c (added) * cpukit/itron/src/prcv_mbf.c (added) * cpukit/itron/src/psnd_mbf.c (added) * cpukit/itron/src/rcv_mbf.c (added) * cpukit/itron/src/ref_mbf.c (added) * cpukit/itron/src/snd_mbf.c (added) * cpukit/itron/src/trcv_mbf.c (added) * cpukit/itron/src/tsnd_mbf.c (added) Split ITRON Message Buffer Manager into multiple files. Mon, 15 Nov 1999 16:39:01 GMT Joel Sherrill [fb27af76] * c/src/exec/itron/src/Makefile.in (modified) * c/src/exec/itron/src/cre_sem.c (added) * c/src/exec/itron/src/del_sem.c (added) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/preq_sem.c (added) * c/src/exec/itron/src/ref_sem.c (added) * c/src/exec/itron/src/sig_sem.c (added) * c/src/exec/itron/src/twai_sem.c (added) * c/src/exec/itron/src/wai_sem.c (added) * cpukit/itron/src/cre_sem.c (added) * cpukit/itron/src/del_sem.c (added) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/preq_sem.c (added) * cpukit/itron/src/ref_sem.c (added) * cpukit/itron/src/sig_sem.c (added) * cpukit/itron/src/twai_sem.c (added) * cpukit/itron/src/wai_sem.c (added) Split ITRON semaphore manager into multiple files. Fri, 12 Nov 1999 21:23:34 GMT Joel Sherrill [d8f3f65b] * c/src/exec/itron/src/del_tsk.c (modified) * c/src/exec/itron/src/frsm_tsk.c (modified) * c/src/exec/itron/src/sus_tsk.c (modified) * c/src/exec/itron/src/ter_tsk.c (modified) * cpukit/itron/src/del_tsk.c (modified) * cpukit/itron/src/frsm_tsk.c (modified) * cpukit/itron/src/sus_tsk.c (modified) * cpukit/itron/src/ter_tsk.c (modified) + Changed validation of the_thread to validation of location. + ... Fri, 12 Nov 1999 21:21:09 GMT Joel Sherrill [2979c28] * c/src/exec/itron/src/sta_tsk.c (modified) * cpukit/itron/src/sta_tsk.c (modified) + Changed validation of the_thread to validation of location. + ... Fri, 12 Nov 1999 21:20:04 GMT Joel Sherrill [3971537] * c/src/exec/itron/src/rel_wai.c (modified) * c/src/exec/itron/src/rsm_tsk.c (modified) * cpukit/itron/src/rel_wai.c (modified) * cpukit/itron/src/rsm_tsk.c (modified) + Changed validation of the_thread to validation of location. Fri, 12 Nov 1999 21:18:36 GMT Joel Sherrill [037a7b1] * c/src/exec/itron/src/ref_tsk.c (modified) * cpukit/itron/src/ref_tsk.c (modified) + Moved error checks to before the disable dispatch where possible. Fri, 12 Nov 1999 21:16:45 GMT Joel Sherrill [0c5ab522] * c/src/exec/itron/src/ext_tsk.c (modified) * cpukit/itron/src/ext_tsk.c (modified) Added comment about the E_CTX error condition (Implementation dependent). Fri, 12 Nov 1999 21:15:12 GMT Joel Sherrill [c257429f] * c/src/exec/itron/src/cre_tsk.c (modified) * cpukit/itron/src/cre_tsk.c (modified) + Moved error checks to before the dispatch disable where possible. ... Fri, 12 Nov 1999 21:13:52 GMT Joel Sherrill [2183b65] * c/src/exec/itron/src/chg_pri.c (modified) * cpukit/itron/src/chg_pri.c (modified) + Modified correct return path to call _ITRON_return_errorno( E_OK ) ...
