# # ChangeLog for c/src/exec in rtems # # Generated by Trac 1.2.1.dev0 # 03/29/24 14:04:58 Mon, 14 Dec 1998 23:15:38 GMT Joel Sherrill [0162910] * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/cpu_asm.S (moved) * c/src/exec/score/cpu/a29k/sig.S (moved) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.S (moved) * c/src/exec/score/cpu/hppa1.1/rtems.S (moved) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu_asm.S (moved) * c/src/exec/score/cpu/i386/rtems.S (moved) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/cpu_asm.S (moved) * c/src/exec/score/cpu/i960/rtems.S (moved) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/cpu_asm.S (moved) * c/src/exec/score/cpu/m68k/rtems.S (moved) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/cpu_asm.S (moved) * c/src/exec/score/cpu/powerpc/irq_stub.S (moved) * c/src/exec/score/cpu/powerpc/rtems.S (moved) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/cpu_asm.S (moved) * c/src/exec/score/cpu/sparc/rtems.S (moved) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/crt0.S (moved) * c/src/lib/libbsp/a29k/portsw/start/register.S (moved) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/start.S (moved) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/start.S (moved) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/ldsegs.S (moved) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (moved) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/videoAsm.S (moved) * c/src/lib/libbsp/i386/pc386/start/start.S (moved) * c/src/lib/libbsp/i386/pc386/start/start16.S (moved) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (moved) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (moved) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/start.S (moved) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.S (moved) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.S (moved) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (moved) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (moved) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/start340.S (moved) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.S (moved) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.S (moved) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timerisr.s (deleted) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/shared/start.S (moved) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/start.S (moved) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/dlentry.S (moved) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/flashentry.S (moved) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/dlentry.S (moved) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/flashentry.S (moved) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/consupp.S (moved) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/start.S (moved) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/startsim.S (moved) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/align_h.S (moved) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.S (moved) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/start.S (moved) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/start.S (moved) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/startsis.S (moved) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/milli.S (moved) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bindec.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/binstr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/bugfix.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/decbin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/do_func.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/gen_except.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/get_op.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/kernel_ex.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/res_func.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/round.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_skel.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sacos.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sasin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/satan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/satanh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/scale.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/scosh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/setox.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sgetem.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sint.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/slog2.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/slogn.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/smovecr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/srem_mod.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/ssin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/ssinh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stanh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sto_res.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stwotox.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/tbldo.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/util.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_bsun.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_fline.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_operr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_ovfl.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_snan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_store.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unfl.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unimp.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unsupp.S (moved) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/align_h.S (moved) * c/src/lib/libcpu/powerpc/ppc403/vectors/vectors.S (moved) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (moved) * c/src/lib/librdbg/i386/rdbg_cpu_asm.S (moved) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/a29k/crt0.S (added) * c/src/lib/start/a29k/register.S (added) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/i960/start.S (added) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/m68k/start.S (added) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/start/sh/start.S (added) * c/src/librdbg/src/i386/rdbg_cpu_asm.S (moved) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * cpukit/score/cpu/a29k/cpu_asm.S (added) * cpukit/score/cpu/a29k/sig.S (added) * cpukit/score/cpu/hppa1.1/cpu_asm.S (added) * cpukit/score/cpu/i386/cpu_asm.S (added) * cpukit/score/cpu/i960/cpu_asm.S (added) * cpukit/score/cpu/m68k/cpu_asm.S (added) * cpukit/score/cpu/sparc/cpu_asm.S (added) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from Ralf Corsepius to rename all .s ... Mon, 14 Dec 1998 23:01:43 GMT Joel Sherrill [e22d644] * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/write.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/write.c (modified) Corrected prototype to confirm to POSIX 1003.1b. Thu, 10 Dec 1998 23:31:54 GMT Joel Sherrill [cca4400] * VERSION (modified) * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/sys/sockio.h (modified) * c/src/exec/libcsupport/src/close.c (modified) * c/src/exec/libcsupport/src/fchmod.c (modified) * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/exec/libcsupport/src/fdatasync.c (modified) * c/src/exec/libcsupport/src/fpathconf.c (modified) * c/src/exec/libcsupport/src/fsync.c (modified) * c/src/exec/libcsupport/src/ftruncate.c (modified) * c/src/exec/libcsupport/src/ioctl.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/lseek.c (modified) * c/src/exec/libcsupport/src/read.c (modified) * c/src/exec/libcsupport/src/write.c (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/include/sys/sockio.h (modified) * c/src/lib/libc/close.c (modified) * c/src/lib/libc/fchmod.c (modified) * c/src/lib/libc/fcntl.c (modified) * c/src/lib/libc/fdatasync.c (modified) * c/src/lib/libc/fpathconf.c (modified) * c/src/lib/libc/fsync.c (modified) * c/src/lib/libc/ftruncate.c (modified) * c/src/lib/libc/ioctl.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/lib/libc/lseek.c (modified) * c/src/lib/libc/read.c (modified) * c/src/lib/libc/write.c (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/sys/sockio.h (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/sys/sockio.h (modified) * configure (modified) * configure.in (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/sys/sockio.h (modified) * cpukit/libcsupport/src/close.c (modified) * cpukit/libcsupport/src/fchmod.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) * cpukit/libcsupport/src/fdatasync.c (modified) * cpukit/libcsupport/src/fpathconf.c (modified) * cpukit/libcsupport/src/fsync.c (modified) * cpukit/libcsupport/src/ftruncate.c (modified) * cpukit/libcsupport/src/ioctl.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/lseek.c (modified) * cpukit/libcsupport/src/read.c (modified) * cpukit/libcsupport/src/write.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Merged Eric Norum's select patch that was based on 4.0 and resolved ... Thu, 10 Dec 1998 19:42:29 GMT Joel Sherrill [a3d0b8a] * c/src/exec/libcsupport/include/sys/sockio.h (modified) * c/src/exec/libnetworking/net/if.c (modified) * c/src/exec/libnetworking/net/if.h (modified) * c/src/exec/libnetworking/net/if_ethersubr.c (modified) * c/src/lib/include/sys/sockio.h (modified) * c/src/lib/libnetworking/net/if.c (modified) * c/src/lib/libnetworking/net/if.h (modified) * c/src/lib/libnetworking/net/if_ethersubr.c (modified) * c/src/lib/libnetworking/sys/sockio.h (modified) * c/src/libnetworking/net/if.c (modified) * c/src/libnetworking/net/if.h (modified) * c/src/libnetworking/net/if_ethersubr.c (modified) * c/src/libnetworking/sys/sockio.h (modified) * cpukit/libcsupport/include/sys/sockio.h (modified) * cpukit/libnetworking/net/if.c (modified) * cpukit/libnetworking/net/if.h (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) Patch from Ian Lance Taylor : From: Eric Norum ... Mon, 07 Dec 1998 17:45:48 GMT Joel Sherrill [2ffe30d] * c/src/exec/score/cpu/i386/rtems.s (modified) Patch from Ian Lance Taylor : This patch avoids a ... Mon, 07 Dec 1998 17:42:52 GMT Joel Sherrill [91b1c8e6] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Ian Lance Taylor : RTEMS permits using ... Fri, 04 Dec 1998 02:00:53 GMT Joel Sherrill [e203c04b] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 19981203 Thu, 03 Dec 1998 23:54:14 GMT Joel Sherrill [4721cf1] * c/Makefile.in (modified) * c/src/exec/librpc/include/rpc/auth.h (added) * c/src/exec/librpc/include/rpc/clnt.h (added) * c/src/exec/librpc/include/rpc/rpc.h (added) * c/src/exec/librpc/include/rpc/rpc_msg.h (added) * c/src/exec/librpc/include/rpc/svc.h (added) * c/src/exec/librpc/include/rpc/svc_auth.h (added) * c/src/exec/librpc/include/rpc/types.h (added) * c/src/exec/librpc/include/rpc/xdr.h (added) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/rdbg/i386/rdbg_f.h (added) * c/src/lib/include/rdbg/i386/reg.h (added) * c/src/lib/include/rdbg/rdbg.h (added) * c/src/lib/include/rdbg/servrpc.h (added) * c/src/lib/include/rpc/auth.h (added) * c/src/lib/include/rpc/clnt.h (added) * c/src/lib/include/rpc/rpc.h (added) * c/src/lib/include/rpc/rpc_msg.h (added) * c/src/lib/include/rpc/svc.h (added) * c/src/lib/include/rpc/svc_auth.h (added) * c/src/lib/include/rpc/types.h (added) * c/src/lib/include/rpc/xdr.h (added) * c/src/lib/librdbg/Makefile.in (added) * c/src/lib/librdbg/_servtgt.c (added) * c/src/lib/librdbg/awk.svc (added) * c/src/lib/librdbg/i386/excep.c (added) * c/src/lib/librdbg/i386/pc386/remdeb_f.x (added) * c/src/lib/librdbg/i386/rdbg_cpu_asm.s (added) * c/src/lib/librdbg/i386/rdbg_f.c (added) * c/src/lib/librdbg/ptrace.c (added) * c/src/lib/librdbg/rdbg.c (added) * c/src/lib/librdbg/remdeb.x (added) * c/src/lib/librdbg/servbkpt.c (added) * c/src/lib/librdbg/servcon.c (added) * c/src/lib/librdbg/servrpc.c (added) * c/src/lib/librdbg/servtgt.c (added) * c/src/lib/librdbg/servtsp.c (added) * c/src/lib/librdbg/servutil.c (added) * c/src/lib/librpc/Makefile.in (added) * c/src/lib/librpc/rpc_callmsg.c (added) * c/src/lib/librpc/rpc_prot.c (added) * c/src/lib/librpc/svc.c (added) * c/src/lib/librpc/svc_auth.c (added) * c/src/lib/librpc/svc_udp.c (added) * c/src/lib/librpc/xdr.c (added) * c/src/lib/librpc/xdr_array.c (added) * c/src/lib/librpc/xdr_mem.c (added) * c/src/lib/wrapup/Makefile.in (modified) * c/src/librdbg/include/rdbg/i386/rdbg_f.h (added) * c/src/librdbg/include/rdbg/i386/reg.h (added) * c/src/librdbg/include/rdbg/rdbg.h (added) * c/src/librdbg/include/rdbg/servrpc.h (added) * c/src/librdbg/src/Makefile.in (added) * c/src/librdbg/src/_servtgt.c (added) * c/src/librdbg/src/awk.svc (added) * c/src/librdbg/src/i386/any/remdeb_f.x (added) * c/src/librdbg/src/i386/excep.c (added) * c/src/librdbg/src/i386/pc386/remdeb_f.x (added) * c/src/librdbg/src/i386/rdbg_cpu_asm.s (added) * c/src/librdbg/src/i386/rdbg_f.c (added) * c/src/librdbg/src/ptrace.c (added) * c/src/librdbg/src/rdbg.c (added) * c/src/librdbg/src/remdeb.x (added) * c/src/librdbg/src/servbkpt.c (added) * c/src/librdbg/src/servcon.c (added) * c/src/librdbg/src/servrpc.c (added) * c/src/librdbg/src/servtgt.c (added) * c/src/librdbg/src/servtsp.c (added) * c/src/librdbg/src/servutil.c (added) * c/src/librpc/include/rpc/auth.h (added) * c/src/librpc/include/rpc/clnt.h (added) * c/src/librpc/include/rpc/rpc.h (added) * c/src/librpc/include/rpc/rpc_msg.h (added) * c/src/librpc/include/rpc/svc.h (added) * c/src/librpc/include/rpc/svc_auth.h (added) * c/src/librpc/include/rpc/types.h (added) * c/src/librpc/include/rpc/xdr.h (added) * c/src/librpc/src/Makefile.in (added) * c/src/librpc/src/rpc_callmsg.c (added) * c/src/librpc/src/rpc_prot.c (added) * c/src/librpc/src/svc.c (added) * c/src/librpc/src/svc_auth.c (added) * c/src/librpc/src/svc_udp.c (added) * c/src/librpc/src/xdr.c (added) * c/src/librpc/src/xdr_array.c (added) * c/src/librpc/src/xdr_mem.c (added) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/librpc/include/rpc/auth.h (added) * cpukit/librpc/include/rpc/clnt.h (added) * cpukit/librpc/include/rpc/rpc.h (added) * cpukit/librpc/include/rpc/rpc_msg.h (added) * cpukit/librpc/include/rpc/svc.h (added) * cpukit/librpc/include/rpc/svc_auth.h (added) * cpukit/librpc/include/rpc/types.h (added) * cpukit/librpc/include/rpc/xdr.h (added) * make/custom/default.cfg (modified) * make/target.cfg.in (modified) Patch from Emmanuel Raguet to add remote debug ... Thu, 03 Dec 1998 22:19:06 GMT Jennifer Averett [a4e2f08] * c/src/exec/libfs/src/imfs/imfs_fdatasync.c (added) * c/src/lib/libc/imfs_fdatasync.c (added) * c/src/libfs/src/imfs/imfs_fdatasync.c (added) * cpukit/libfs/src/imfs/imfs_fdatasync.c (added) Added imfs_fdatasync routine that gets called from both fdatasync and ... Thu, 03 Dec 1998 22:17:46 GMT Jennifer Averett [49629bd8] * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_handlers.c (modified) * c/src/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs.h (modified) Added a imfs fdatasync routine that gets called for fdatasync and ... Thu, 03 Dec 1998 22:17:26 GMT Jennifer Averett [5822f43] * c/src/exec/libcsupport/src/fcntl.c (modified) * c/src/lib/libc/fcntl.c (modified) * cpukit/libcsupport/src/fcntl.c (modified) Added source for F_DUPFD. Thu, 03 Dec 1998 22:17:13 GMT Jennifer Averett [7a3878b] * c/src/exec/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (modified) * c/src/exec/libcsupport/src/base_fs.c (modified) * c/src/exec/libfs/src/imfs/ioman.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (modified) * c/src/lib/libc/base_fs.c (modified) * c/src/lib/libc/ioman.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (modified) * c/src/libfs/src/imfs/ioman.c (modified) * cpukit/include/rtems/libio_.h (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (modified) * cpukit/libcsupport/src/base_fs.c (modified) * cpukit/libfs/src/imfs/ioman.c (modified) Modifications for RTEMS_UNIX. Thu, 03 Dec 1998 21:55:33 GMT Joel Sherrill [31bce9b] * c/src/exec/sapi/headers/confdefs.h (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * cpukit/sapi/include/confdefs.h (modified) Moved stackchk.h to rtems subdirectory. Thu, 03 Dec 1998 21:53:25 GMT Joel Sherrill [ed0e74e] * c/src/exec/score/src/coremsg.c (modified) * cpukit/score/src/coremsg.c (modified) Corrected spacing. Thu, 03 Dec 1998 21:52:20 GMT Joel Sherrill [fdd9fe17] * c/src/exec/rtems/src/msg.c (modified) * cpukit/rtems/src/msg.c (modified) Corrected ifdef on RTEMS_MULTIPROCESSING so the queue is actually closed. Mon, 23 Nov 1998 19:39:45 GMT Joel Sherrill [d1ee44e] * c/src/exec/posix/include/sys/ioctl.h (added) * c/src/exec/posix/include/sys/utime.h (added) * c/src/exec/posix/sys/ioctl.h (added) * c/src/exec/posix/sys/utime.h (added) New files added as part of file system infrastructure effort. Mon, 23 Nov 1998 19:07:58 GMT Joel Sherrill [07a3253d] * c/src/exec/include/rtems/libio_.h (added) * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/include/rtems/libio_.h (added) * c/src/exec/libcsupport/src/CASES (added) * c/src/exec/libcsupport/src/TODO (added) * c/src/exec/libcsupport/src/__brk.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/__sbrk.c (added) * c/src/exec/libcsupport/src/__times.c (modified) * c/src/exec/libcsupport/src/access.c (added) * c/src/exec/libcsupport/src/base_fs.c (added) * c/src/exec/libcsupport/src/cfgetispeed.c (added) * c/src/exec/libcsupport/src/cfgetospeed.c (added) * c/src/exec/libcsupport/src/cfsetispeed.c (added) * c/src/exec/libcsupport/src/cfsetospeed.c (added) * c/src/exec/libcsupport/src/chdir.c (added) * c/src/exec/libcsupport/src/chmod.c (added) * c/src/exec/libcsupport/src/chown.c (added) * c/src/exec/libcsupport/src/close.c (added) * c/src/exec/libcsupport/src/closedir.c (modified) * c/src/exec/libcsupport/src/dup.c (added) * c/src/exec/libcsupport/src/dup2.c (added) * c/src/exec/libcsupport/src/eval.c (added) * c/src/exec/libcsupport/src/fchmod.c (added) * c/src/exec/libcsupport/src/fcntl.c (added) * c/src/exec/libcsupport/src/fdatasync.c (added) * c/src/exec/libcsupport/src/fpathconf.c (added) * c/src/exec/libcsupport/src/fstat.c (added) * c/src/exec/libcsupport/src/fsync.c (added) * c/src/exec/libcsupport/src/ftruncate.c (added) * c/src/exec/libcsupport/src/getdents.c (modified) * c/src/exec/libcsupport/src/hosterr.c (modified) * c/src/exec/libcsupport/src/ioctl.c (added) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/link.c (added) * c/src/exec/libcsupport/src/lseek.c (added) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/mkdir.c (added) * c/src/exec/libcsupport/src/mkfifo.c (added) * c/src/exec/libcsupport/src/mknod.c (added) * c/src/exec/libcsupport/src/mount.c (added) * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/libcsupport/src/no_libc.c (modified) * c/src/exec/libcsupport/src/open.c (added) * c/src/exec/libcsupport/src/opendir.c (modified) * c/src/exec/libcsupport/src/pathconf.c (added) * c/src/exec/libcsupport/src/pipe.c (added) * c/src/exec/libcsupport/src/read.c (added) * c/src/exec/libcsupport/src/readdir.c (modified) * c/src/exec/libcsupport/src/readlink.c (added) * c/src/exec/libcsupport/src/rewinddir.c (modified) * c/src/exec/libcsupport/src/rmdir.c (added) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/seekdir.c (modified) * c/src/exec/libcsupport/src/stat.c (added) * c/src/exec/libcsupport/src/symlink.c (added) * c/src/exec/libcsupport/src/tcdrain.c (modified) * c/src/exec/libcsupport/src/tcgetattr.c (added) * c/src/exec/libcsupport/src/tcsetattr.c (added) * c/src/exec/libcsupport/src/telldir.c (modified) * c/src/exec/libcsupport/src/truncate.c (added) * c/src/exec/libcsupport/src/umask.c (added) * c/src/exec/libcsupport/src/unixlibc.c (modified) * c/src/exec/libcsupport/src/unlink.c (added) * c/src/exec/libcsupport/src/unmount.c (added) * c/src/exec/libcsupport/src/utime.c (added) * c/src/exec/libcsupport/src/write.c (added) * c/src/exec/libfs/src/imfs/deviceio.c (added) * c/src/exec/libfs/src/imfs/imfs.h (added) * c/src/exec/libfs/src/imfs/imfs_chown.c (added) * c/src/exec/libfs/src/imfs/imfs_creat.c (added) * c/src/exec/libfs/src/imfs/imfs_debug.c (added) * c/src/exec/libfs/src/imfs/imfs_directory.c (added) * c/src/exec/libfs/src/imfs/imfs_eval.c (added) * c/src/exec/libfs/src/imfs/imfs_fchmod.c (added) * c/src/exec/libfs/src/imfs/imfs_free.c (added) * c/src/exec/libfs/src/imfs/imfs_getchild.c (added) * c/src/exec/libfs/src/imfs/imfs_gtkn.c (added) * c/src/exec/libfs/src/imfs/imfs_init.c (added) * c/src/exec/libfs/src/imfs/imfs_initsupp.c (added) * c/src/exec/libfs/src/imfs/imfs_link.c (added) * c/src/exec/libfs/src/imfs/imfs_mknod.c (added) * c/src/exec/libfs/src/imfs/imfs_mount.c (added) * c/src/exec/libfs/src/imfs/imfs_ntype.c (added) * c/src/exec/libfs/src/imfs/imfs_readlink.c (added) * c/src/exec/libfs/src/imfs/imfs_rmnod.c (added) * c/src/exec/libfs/src/imfs/imfs_stat.c (added) * c/src/exec/libfs/src/imfs/imfs_symlink.c (added) * c/src/exec/libfs/src/imfs/imfs_unlink.c (added) * c/src/exec/libfs/src/imfs/imfs_unmount.c (added) * c/src/exec/libfs/src/imfs/imfs_utime.c (added) * c/src/exec/libfs/src/imfs/ioman.c (added) * c/src/exec/libfs/src/imfs/memfile.c (added) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/src/getpid.c (modified) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/posix/sys/Makefile.in (modified) * c/src/exec/sapi/src/io.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/include/rtems/libio_.h (added) * c/src/lib/libbsp/shared/bsplibc.c (modified) * c/src/lib/libbsp/shared/bsppost.c (modified) * c/src/lib/libc/CASES (added) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/TODO (added) * c/src/lib/libc/__brk.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/__sbrk.c (added) * c/src/lib/libc/__times.c (modified) * c/src/lib/libc/access.c (added) * c/src/lib/libc/base_fs.c (added) * c/src/lib/libc/cfgetispeed.c (added) * c/src/lib/libc/cfgetospeed.c (added) * c/src/lib/libc/cfiospeed.c (deleted) * c/src/lib/libc/cfsetispeed.c (added) * c/src/lib/libc/cfsetospeed.c (added) * c/src/lib/libc/chdir.c (added) * c/src/lib/libc/chmod.c (added) * c/src/lib/libc/chown.c (added) * c/src/lib/libc/close.c (added) * c/src/lib/libc/closedir.c (modified) * c/src/lib/libc/deviceio.c (added) * c/src/lib/libc/dup.c (added) * c/src/lib/libc/dup2.c (added) * c/src/lib/libc/eval.c (added) * c/src/lib/libc/fchmod.c (added) * c/src/lib/libc/fcntl.c (added) * c/src/lib/libc/fdatasync.c (added) * c/src/lib/libc/fpathconf.c (added) * c/src/lib/libc/fstat.c (added) * c/src/lib/libc/fsync.c (added) * c/src/lib/libc/ftruncate.c (added) * c/src/lib/libc/getdents.c (modified) * c/src/lib/libc/hosterr.c (modified) * c/src/lib/libc/imfs.h (added) * c/src/lib/libc/imfs_chown.c (added) * c/src/lib/libc/imfs_creat.c (added) * c/src/lib/libc/imfs_debug.c (added) * c/src/lib/libc/imfs_directory.c (added) * c/src/lib/libc/imfs_eval.c (added) * c/src/lib/libc/imfs_fchmod.c (added) * c/src/lib/libc/imfs_free.c (added) * c/src/lib/libc/imfs_getchild.c (added) * c/src/lib/libc/imfs_gtkn.c (added) * c/src/lib/libc/imfs_handlers.c (added) * c/src/lib/libc/imfs_init.c (added) * c/src/lib/libc/imfs_initsupp.c (added) * c/src/lib/libc/imfs_link.c (added) * c/src/lib/libc/imfs_mknod.c (added) * c/src/lib/libc/imfs_mount.c (added) * c/src/lib/libc/imfs_ntype.c (added) * c/src/lib/libc/imfs_readlink.c (added) * c/src/lib/libc/imfs_rmnod.c (added) * c/src/lib/libc/imfs_stat.c (added) * c/src/lib/libc/imfs_symlink.c (added) * c/src/lib/libc/imfs_unlink.c (added) * c/src/lib/libc/imfs_unmount.c (added) * c/src/lib/libc/imfs_utime.c (added) * c/src/lib/libc/internal.h (deleted) * c/src/lib/libc/ioctl.c (added) * c/src/lib/libc/ioman.c (added) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/libio_.h (added) * c/src/lib/libc/link.c (added) * c/src/lib/libc/lseek.c (added) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/memfile.c (added) * c/src/lib/libc/mkdir.c (added) * c/src/lib/libc/mkfifo.c (added) * c/src/lib/libc/mknod.c (added) * c/src/lib/libc/mount.c (added) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libc/newlibif.c (deleted) * c/src/lib/libc/newlibifr.c (deleted) * c/src/lib/libc/no_libc.c (modified) * c/src/lib/libc/open.c (added) * c/src/lib/libc/opendir.c (modified) * c/src/lib/libc/pathconf.c (added) * c/src/lib/libc/pipe.c (moved) * c/src/lib/libc/read.c (added) * c/src/lib/libc/readdir.c (modified) * c/src/lib/libc/readlink.c (added) * c/src/lib/libc/rewinddir.c (modified) * c/src/lib/libc/rmdir.c (added) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/seekdir.c (modified) * c/src/lib/libc/stat.c (added) * c/src/lib/libc/support.c (deleted) * c/src/lib/libc/symlink.c (added) * c/src/lib/libc/syscalls.c (deleted) * c/src/lib/libc/tcattr.c (deleted) * c/src/lib/libc/tcdrain.c (modified) * c/src/lib/libc/tcgetattr.c (added) * c/src/lib/libc/tcsetattr.c (added) * c/src/lib/libc/telldir.c (modified) * c/src/lib/libc/truncate.c (added) * c/src/lib/libc/umask.c (added) * c/src/lib/libc/unixlibc.c (modified) * c/src/lib/libc/unlink.c (added) * c/src/lib/libc/unmount.c (added) * c/src/lib/libc/utime.c (added) * c/src/lib/libc/write.c (added) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libfs/src/imfs/deviceio.c (added) * c/src/libfs/src/imfs/imfs.h (added) * c/src/libfs/src/imfs/imfs_chown.c (added) * c/src/libfs/src/imfs/imfs_creat.c (added) * c/src/libfs/src/imfs/imfs_debug.c (added) * c/src/libfs/src/imfs/imfs_directory.c (added) * c/src/libfs/src/imfs/imfs_eval.c (added) * c/src/libfs/src/imfs/imfs_fchmod.c (added) * c/src/libfs/src/imfs/imfs_free.c (added) * c/src/libfs/src/imfs/imfs_getchild.c (added) * c/src/libfs/src/imfs/imfs_gtkn.c (added) * c/src/libfs/src/imfs/imfs_init.c (added) * c/src/libfs/src/imfs/imfs_initsupp.c (added) * c/src/libfs/src/imfs/imfs_link.c (added) * c/src/libfs/src/imfs/imfs_mknod.c (added) * c/src/libfs/src/imfs/imfs_mount.c (added) * c/src/libfs/src/imfs/imfs_ntype.c (added) * c/src/libfs/src/imfs/imfs_readlink.c (added) * c/src/libfs/src/imfs/imfs_rmnod.c (added) * c/src/libfs/src/imfs/imfs_stat.c (added) * c/src/libfs/src/imfs/imfs_symlink.c (added) * c/src/libfs/src/imfs/imfs_unlink.c (added) * c/src/libfs/src/imfs/imfs_unmount.c (added) * c/src/libfs/src/imfs/imfs_utime.c (added) * c/src/libfs/src/imfs/ioman.c (added) * c/src/libfs/src/imfs/memfile.c (added) * c/src/tests/sptests/spsize/size.c (modified) * configure (modified) * cpukit/include/rtems/libio_.h (added) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/include/rtems/libio_.h (added) * cpukit/libcsupport/src/CASES (added) * cpukit/libcsupport/src/TODO (added) * cpukit/libcsupport/src/__brk.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/__sbrk.c (added) * cpukit/libcsupport/src/__times.c (modified) * cpukit/libcsupport/src/access.c (added) * cpukit/libcsupport/src/base_fs.c (added) * cpukit/libcsupport/src/cfgetispeed.c (added) * cpukit/libcsupport/src/cfgetospeed.c (added) * cpukit/libcsupport/src/cfsetispeed.c (added) * cpukit/libcsupport/src/cfsetospeed.c (added) * cpukit/libcsupport/src/chdir.c (added) * cpukit/libcsupport/src/chmod.c (added) * cpukit/libcsupport/src/chown.c (added) * cpukit/libcsupport/src/close.c (added) * cpukit/libcsupport/src/closedir.c (modified) * cpukit/libcsupport/src/dup.c (added) * cpukit/libcsupport/src/dup2.c (added) * cpukit/libcsupport/src/eval.c (added) * cpukit/libcsupport/src/fchmod.c (added) * cpukit/libcsupport/src/fcntl.c (added) * cpukit/libcsupport/src/fdatasync.c (added) * cpukit/libcsupport/src/fpathconf.c (added) * cpukit/libcsupport/src/fstat.c (added) * cpukit/libcsupport/src/fsync.c (added) * cpukit/libcsupport/src/ftruncate.c (added) * cpukit/libcsupport/src/getdents.c (modified) * cpukit/libcsupport/src/hosterr.c (modified) * cpukit/libcsupport/src/ioctl.c (added) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/link.c (added) * cpukit/libcsupport/src/lseek.c (added) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/mkdir.c (added) * cpukit/libcsupport/src/mkfifo.c (added) * cpukit/libcsupport/src/mknod.c (added) * cpukit/libcsupport/src/mount.c (added) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libcsupport/src/no_libc.c (modified) * cpukit/libcsupport/src/open.c (added) * cpukit/libcsupport/src/opendir.c (modified) * cpukit/libcsupport/src/pathconf.c (added) * cpukit/libcsupport/src/pipe.c (added) * cpukit/libcsupport/src/read.c (added) * cpukit/libcsupport/src/readdir.c (modified) * cpukit/libcsupport/src/readlink.c (added) * cpukit/libcsupport/src/rewinddir.c (modified) * cpukit/libcsupport/src/rmdir.c (added) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/seekdir.c (modified) * cpukit/libcsupport/src/stat.c (added) * cpukit/libcsupport/src/symlink.c (added) * cpukit/libcsupport/src/tcdrain.c (modified) * cpukit/libcsupport/src/tcgetattr.c (added) * cpukit/libcsupport/src/tcsetattr.c (added) * cpukit/libcsupport/src/telldir.c (modified) * cpukit/libcsupport/src/truncate.c (added) * cpukit/libcsupport/src/umask.c (added) * cpukit/libcsupport/src/unixlibc.c (modified) * cpukit/libcsupport/src/unlink.c (added) * cpukit/libcsupport/src/unmount.c (added) * cpukit/libcsupport/src/utime.c (added) * cpukit/libcsupport/src/write.c (added) * cpukit/libfs/src/imfs/deviceio.c (added) * cpukit/libfs/src/imfs/imfs.h (added) * cpukit/libfs/src/imfs/imfs_chown.c (added) * cpukit/libfs/src/imfs/imfs_creat.c (added) * cpukit/libfs/src/imfs/imfs_debug.c (added) * cpukit/libfs/src/imfs/imfs_directory.c (added) * cpukit/libfs/src/imfs/imfs_eval.c (added) * cpukit/libfs/src/imfs/imfs_fchmod.c (added) * cpukit/libfs/src/imfs/imfs_free.c (added) * cpukit/libfs/src/imfs/imfs_getchild.c (added) * cpukit/libfs/src/imfs/imfs_gtkn.c (added) * cpukit/libfs/src/imfs/imfs_init.c (added) * cpukit/libfs/src/imfs/imfs_initsupp.c (added) * cpukit/libfs/src/imfs/imfs_link.c (added) * cpukit/libfs/src/imfs/imfs_mknod.c (added) * cpukit/libfs/src/imfs/imfs_mount.c (added) * cpukit/libfs/src/imfs/imfs_ntype.c (added) * cpukit/libfs/src/imfs/imfs_readlink.c (added) * cpukit/libfs/src/imfs/imfs_rmnod.c (added) * cpukit/libfs/src/imfs/imfs_stat.c (added) * cpukit/libfs/src/imfs/imfs_symlink.c (added) * cpukit/libfs/src/imfs/imfs_unlink.c (added) * cpukit/libfs/src/imfs/imfs_unmount.c (added) * cpukit/libfs/src/imfs/imfs_utime.c (added) * cpukit/libfs/src/imfs/ioman.c (added) * cpukit/libfs/src/imfs/memfile.c (added) * cpukit/posix/src/getpid.c (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/sapi/src/io.c (modified) * testsuites/sptests/spsize/size.c (modified) Added base version of file system infrastructure. This includes a ... Mon, 23 Nov 1998 17:38:09 GMT Joel Sherrill [97e2729d] * aclocal.m4 (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/headers/cond.h (modified) * c/src/exec/posix/headers/mqueue.h (modified) * c/src/exec/posix/headers/mutex.h (modified) * c/src/exec/posix/headers/pthread.h (modified) * c/src/exec/posix/headers/semaphore.h (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/posix/include/rtems/posix/mutex.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/semaphore.h (modified) * c/src/exec/posix/src/cond.c (modified) * c/src/exec/posix/src/mutex.c (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/signal.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/types.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/src/coremsg.c (modified) * c/src/exec/score/src/coremutex.c (modified) * c/src/exec/score/src/coresem.c (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/monitor.h (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/monitor.h (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * configure (modified) * configure.in (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadq.c (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147s.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/simhppa.cfg (modified) * make/leaf.cfg (modified) * make/target.cfg.in (modified) * testsuites/sptests/spsize/size.c (modified) * tools/cpu/generic/size_rtems.in (modified) Added --disable-multiprocessing flag and modified a lot of files to ... Thu, 19 Nov 1998 20:23:34 GMT Joel Sherrill [8a9caa03] * c/src/exec/score/cpu/i386/cpu.h (modified) Renamed exception constants per requests from Erik Ivanenko ... Thu, 19 Nov 1998 17:35:49 GMT Joel Sherrill [847375f] * c/src/exec/libnetworking/kern/uipc_socket.c (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/sys/socketvar.h (modified) * c/src/exec/posix/src/psignal.c (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/src/thread.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/device-tree (modified) * c/src/lib/libbsp/powerpc/psim/startup/linkcmds (modified) * c/src/lib/libnetworking/kern/uipc_socket.c (modified) * c/src/lib/libnetworking/nfs/bootp_subr.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/sys/socketvar.h (modified) * c/src/libnetworking/kern/uipc_socket.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/sys/socketvar.h (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/sys/socketvar.h (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/thread.c (modified) Patch from Eric Norum : 1) Socket ... Thu, 29 Oct 1998 22:25:53 GMT Joel Sherrill [06fee20] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 4.0.0-AFCC Wed, 28 Oct 1998 19:25:12 GMT Joel Sherrill [b4e3b2b] * c/src/exec/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) Patch from Ian Lance Taylor . I just happened ... Wed, 28 Oct 1998 19:17:16 GMT Joel Sherrill [692b9f7] * aclocal.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * c/Makefile.in (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * make/custom/psim.cfg (modified) * make/target.cfg.in (modified) Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along ... Tue, 27 Oct 1998 19:33:26 GMT Joel Sherrill [c19a4847] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 4.0.0 Mon, 26 Oct 1998 16:24:59 GMT Joel Sherrill [415ea6a] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 4.0.0-beta4b Thu, 22 Oct 1998 16:15:40 GMT Joel Sherrill [d3b34d2] * c/src/exec/libcsupport/src/closedir.c (modified) * c/src/exec/libcsupport/src/opendir.c (modified) * c/src/exec/libcsupport/src/readdir.c (modified) * c/src/exec/libcsupport/src/rewinddir.c (modified) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/seekdir.c (modified) * c/src/exec/libcsupport/src/telldir.c (modified) * c/src/lib/libc/closedir.c (modified) * c/src/lib/libc/opendir.c (modified) * c/src/lib/libc/readdir.c (modified) * c/src/lib/libc/rewinddir.c (modified) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/seekdir.c (modified) * c/src/lib/libc/telldir.c (modified) * cpukit/libcsupport/src/closedir.c (modified) * cpukit/libcsupport/src/opendir.c (modified) * cpukit/libcsupport/src/readdir.c (modified) * cpukit/libcsupport/src/rewinddir.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/seekdir.c (modified) * cpukit/libcsupport/src/telldir.c (modified) Changed all of these to stubs. Thu, 15 Oct 1998 19:58:32 GMT Joel Sherrill [0a5e510] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 4.0.0-beta4a Wed, 14 Oct 1998 20:19:30 GMT Joel Sherrill [11cfb6f7] * c/build-tools/README (modified) * c/build-tools/install-if-change.in (added) * c/build-tools/lock-directory.in (added) * c/build-tools/rcs-clean.in (added) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/scripts/README (modified) * c/build-tools/scripts/install-if-change.in (added) * c/build-tools/scripts/lock-directory.in (added) * c/build-tools/scripts/rcs-clean.in (added) * c/build-tools/scripts/unlock-directory.in (added) * c/build-tools/unlock-directory.in (added) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (added) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/looptest.in (added) * c/src/lib/libbsp/unix/posix/tools/runtest.in (added) * c/src/lib/libbsp/unix/posix/tools/semdump.in (added) * c/src/lib/libbsp/unix/posix/tools/shmdump.in (added) * c/update-tools/Makefile.in (modified) * c/update-tools/update.in (added) * c/update-tools/word-replace.in (added) * configure (modified) * configure.in (modified) * make/rtems.cfg (added) * tools/build/README (modified) * tools/build/install-if-change.in (added) * tools/build/lock-directory.in (added) * tools/build/rcs-clean.in (added) * tools/build/scripts/Makefile.in (modified) * tools/build/scripts/README (modified) * tools/build/scripts/install-if-change.in (added) * tools/build/scripts/lock-directory.in (added) * tools/build/scripts/rcs-clean.in (added) * tools/build/scripts/unlock-directory.in (added) * tools/build/unlock-directory.in (added) * tools/cpu/generic/Makefile.in (modified) * tools/update/Makefile.in (modified) * tools/update/update.in (added) * tools/update/word-replace.in (added) Patch from Ralf Corsepius : 1. Rtems ... Tue, 13 Oct 1998 18:04:16 GMT Joel Sherrill [0cd2bd96] * c/src/exec/libcsupport/src/telldir.c (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/telldir.c (modified) * cpukit/libcsupport/src/telldir.c (modified) Added rest of opendir family and made it compile. Tue, 13 Oct 1998 16:07:38 GMT Joel Sherrill [928395e] * c/src/exec/libcsupport/src/closedir.c (added) * c/src/exec/libcsupport/src/rewinddir.c (added) * c/src/exec/libcsupport/src/scandir.c (added) * c/src/exec/libcsupport/src/seekdir.c (added) * c/src/exec/libcsupport/src/telldir.c (added) * c/src/lib/libc/closedir.c (added) * c/src/lib/libc/rewinddir.c (added) * c/src/lib/libc/scandir.c (added) * c/src/lib/libc/seekdir.c (added) * c/src/lib/libc/telldir.c (added) * cpukit/libcsupport/src/closedir.c (added) * cpukit/libcsupport/src/rewinddir.c (added) * cpukit/libcsupport/src/scandir.c (added) * cpukit/libcsupport/src/seekdir.c (added) * cpukit/libcsupport/src/telldir.c (added) New files. Tue, 13 Oct 1998 15:03:27 GMT Joel Sherrill [714137ef] * c/src/exec/score/cpu/sh/cpu_isps.c (modified) * c/src/exec/score/cpu/sh/ispsh7032.c (modified) * c/src/lib/libcpu/sh/sh7032/score/ispsh7032.c (modified) * make/custom/gensh1.cfg (modified) Patch from Ralf Corsepius to correct minor ... Mon, 12 Oct 1998 17:40:25 GMT Joel Sherrill [70b45c64] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 4.0.0-beta4 Mon, 12 Oct 1998 17:28:33 GMT Joel Sherrill [22bb7cd1] * c/src/exec/libcsupport/src/opendir.c (added) * c/src/exec/libcsupport/src/readdir.c (added) * c/src/lib/libc/opendir.c (added) * c/src/lib/libc/readdir.c (added) * cpukit/libcsupport/src/opendir.c (added) * cpukit/libcsupport/src/readdir.c (added) New files. Mon, 12 Oct 1998 17:21:12 GMT Joel Sherrill [b19cb17] * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) Added header files per request from Chris Johns to avoid problems in ... Tue, 06 Oct 1998 21:45:33 GMT Joel Sherrill [5ee9068] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 981006 Tue, 06 Oct 1998 20:55:28 GMT Joel Sherrill [d171f8a8] * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) Corrected assembly language to use constants instead of addresses. ... Tue, 06 Oct 1998 20:54:36 GMT Joel Sherrill [dff5b40] * c/src/exec/score/cpu/hppa1.1/cpu.h (modified) Added missing field (idle_task_stack_size) to CPU Table. Thu, 01 Oct 1998 21:44:31 GMT Joel Sherrill [388be68f] * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/lib/libc/malloc.c (modified) * cpukit/libcsupport/src/malloc.c (modified) Patch from Ian Lance Taylor : The reentrant ... Thu, 01 Oct 1998 20:22:37 GMT Joel Sherrill [f0bca9fb] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 981001 Thu, 01 Oct 1998 18:50:43 GMT Joel Sherrill [086836e1] * c/src/exec/score/cpu/powerpc/TODO (modified) * c/src/exec/score/cpu/powerpc/cpu.c (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/powerpc/ppc.h (modified) Patch from Thomas Doerfler to improve 403 support. ... Wed, 30 Sep 1998 13:02:30 GMT Joel Sherrill [17408b90] * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * make/custom/gen68360.cfg (modified) Patch from Eric Norum : I found that my ... Tue, 29 Sep 1998 12:15:08 GMT Joel Sherrill [766ed7c] * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) Patch from Eric Norum : Remember the ... Sun, 27 Sep 1998 16:37:16 GMT Joel Sherrill [cb646cb9] * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/src/wait.c (added) * c/src/exec/posix/src/waitpid.c (added) * cpukit/posix/src/wait.c (added) * cpukit/posix/src/waitpid.c (added) New files. Fri, 25 Sep 1998 13:28:28 GMT Joel Sherrill [b965227f] * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/src/execlp.c (modified) * c/src/exec/posix/src/execv.c (modified) * cpukit/posix/src/execlp.c (modified) * cpukit/posix/src/execv.c (modified) Now compiles. Fri, 25 Sep 1998 13:17:32 GMT Joel Sherrill [97149ba] * c/src/exec/posix/src/execl.c (added) * c/src/exec/posix/src/execle.c (added) * c/src/exec/posix/src/execlp.c (added) * c/src/exec/posix/src/execv.c (added) * c/src/exec/posix/src/execve.c (added) * c/src/exec/posix/src/execvp.c (added) * c/src/exec/posix/src/fork.c (added) * c/src/exec/posix/src/pthreadatfork.c (added) * cpukit/posix/src/execl.c (added) * cpukit/posix/src/execle.c (added) * cpukit/posix/src/execlp.c (added) * cpukit/posix/src/execv.c (added) * cpukit/posix/src/execve.c (added) * cpukit/posix/src/execvp.c (added) * cpukit/posix/src/fork.c (added) * cpukit/posix/src/pthreadatfork.c (added) Added ENOSYS stubs for a number of process routines. Wed, 23 Sep 1998 16:46:52 GMT Joel Sherrill [1fd26a5] * c/src/exec/score/tools/sh/sci.c (modified) * c/src/exec/score/tools/sh/shgen.c (modified) * tools/cpu/sh/sci.c (modified) * tools/cpu/sh/shgen.c (modified) Patch from Ralf Corsepius . Wed, 23 Sep 1998 16:41:00 GMT Joel Sherrill [ecc3fe3] * c/src/exec/score/cpu/a29k/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i960/cpu.h (modified) * c/src/exec/score/cpu/m68k/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/cpu.h (modified) * c/src/exec/score/cpu/powerpc/cpu.h (modified) * c/src/exec/score/cpu/sh/cpu.h (modified) * c/src/exec/score/cpu/sparc/cpu.h (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/src/thread.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/thread.c (modified) * testsuites/sptests/spsize/size.c (modified) IDLE task stack size now specified as a field in the CPU Table for ... Wed, 23 Sep 1998 16:34:23 GMT Joel Sherrill [3b93a2de] * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/lib/libc/malloc.c (modified) * cpukit/libcsupport/src/malloc.c (modified) Modifed to zero out the C heap if the CPU Table indicates that the ... Wed, 23 Sep 1998 13:43:44 GMT Joel Sherrill [87c857a9] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980923 Wed, 23 Sep 1998 13:20:34 GMT Joel Sherrill [8a496e46] * c/src/exec/libcsupport/include/rtems/libio.h (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/include/rtems/libio.h (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/shared/irq/idt.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libc/libio.h (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libcpu/i386/cpu.c (modified) * c/src/lib/libcpu/i386/idt.c (modified) * cpukit/libcsupport/include/rtems/libio.h (modified) * cpukit/libcsupport/src/termios.c (modified) * make/target.cfg.in (modified) Patch from Aleksey (Quality Quorum ): 1. ... Mon, 21 Sep 1998 16:38:20 GMT Joel Sherrill [af973e57] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980921 Mon, 21 Sep 1998 00:46:00 GMT Joel Sherrill [718dc95] * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/lib/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) Patch from Eric Norum : Here's a patch ... Mon, 21 Sep 1998 00:42:07 GMT Joel Sherrill [7ddcfb8c] * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) Patch from Eric Norum and David Fiddes to put ColdFire support in ... Mon, 21 Sep 1998 00:01:26 GMT Joel Sherrill [30ba752] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/cfiospeed.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Patch from Eric Norum: I fixed the problems noted by Victor ... Fri, 11 Sep 1998 19:17:49 GMT Joel Sherrill [b29378e] * c/src/exec/libcsupport/include/motorola/mc68681.h (modified) * c/src/lib/include/motorola/mc68681.h (modified) * cpukit/libcsupport/include/motorola/mc68681.h (modified) Corrected spelling error. Fri, 11 Sep 1998 15:40:41 GMT Joel Sherrill [c5bb1e02] * VERSION (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980911 Fri, 11 Sep 1998 13:12:04 GMT Joel Sherrill [b3956369] * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) Patch from "David J. Fiddes" : I've ... Thu, 10 Sep 1998 12:43:00 GMT Joel Sherrill [23cdd84c] * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (modified) * c/src/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.c (modified) * cpukit/libnetworking/netinet/in_cksum_m68k.h (modified) Patch from David Fiddes to make this compile ... Thu, 10 Sep 1998 12:23:08 GMT Joel Sherrill [109b17f4] * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) Patch from Eric Norum to fix a cryptic error ... Mon, 31 Aug 1998 23:09:17 GMT Joel Sherrill [4cf89a8] * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) Fixed spacing. More comments from Eric Norum need to be addressed. Mon, 31 Aug 1998 23:06:50 GMT Joel Sherrill [d9d75fc] * c/src/exec/libcsupport/src/newlibc.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libc/newlibc.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libcsupport/src/newlibc.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) Patch from Emmanuel Raguet : I have reworked ... Mon, 31 Aug 1998 23:03:45 GMT Joel Sherrill [b285860] * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) Patch from Eric Valette : Eric> NB : ... Mon, 31 Aug 1998 22:53:42 GMT Joel Sherrill [85734b3] * c/src/exec/libcsupport/src/error.c (modified) * c/src/lib/libc/error.c (modified) * c/src/lib/libmisc/error/error.c (modified) * c/src/libmisc/error/error.c (modified) * cpukit/libcsupport/src/error.c (modified) Patch from Eric Norum : I think I ... Mon, 24 Aug 1998 17:32:58 GMT Joel Sherrill [7559232] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980824 Mon, 24 Aug 1998 14:50:00 GMT Joel Sherrill [ff0b008] * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * cpukit/rtems/include/rtems.h (modified) Added __RTEMS_INSIDE__ macro to insure that ".inl" files are ALWAYS ... Fri, 21 Aug 1998 18:19:29 GMT Joel Sherrill [4baa0f5] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980821 Fri, 21 Aug 1998 18:14:27 GMT Joel Sherrill [4de817d] * c/src/exec/libnetworking/netinet/in_cksum.c (modified) * c/src/exec/libnetworking/netinet/in_cksum_i386.c (added) * c/src/exec/libnetworking/netinet/in_cksum_m68k.c (added) * c/src/lib/libnetworking/netinet/in_cksum.c (modified) * c/src/lib/libnetworking/netinet/in_cksum_i386.c (added) * c/src/lib/libnetworking/netinet/in_cksum_m68k.c (added) * c/src/libnetworking/netinet/in_cksum.c (modified) * c/src/libnetworking/netinet/in_cksum_i386.c (added) * c/src/libnetworking/netinet/in_cksum_m68k.c (added) * cpukit/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum_i386.c (added) * cpukit/libnetworking/netinet/in_cksum_i386.h (added) * cpukit/libnetworking/netinet/in_cksum_m68k.c (added) * cpukit/libnetworking/netinet/in_cksum_m68k.h (added) Added i386 specific version of in_cksum.c and restructured the main ... Fri, 21 Aug 1998 17:42:25 GMT Joel Sherrill [aa2171b] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) Modified version number to recut snapshot. Fri, 21 Aug 1998 17:37:01 GMT Joel Sherrill [617a1a2d] * c/src/exec/libnetworking/netinet/in_cksum.c (modified) * c/src/lib/libnetworking/netinet/in_cksum.c (modified) * c/src/libnetworking/netinet/in_cksum.c (modified) * cpukit/libnetworking/netinet/in_cksum.c (modified) Another missing piece. Thanks Eric. Fri, 21 Aug 1998 17:09:04 GMT Joel Sherrill [025eb96e] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980821 Fri, 21 Aug 1998 16:54:17 GMT Joel Sherrill [7a035ebc] * c/src/exec/rtems/headers/attr.h (modified) * c/src/exec/rtems/include/rtems/rtems/attr.h (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/src/tasks.c (modified) * cpukit/rtems/include/rtems/rtems/attr.h (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/src/tasks.c (modified) Added system task attribute to allow one to create a task with "0" ... Fri, 21 Aug 1998 16:39:52 GMT Joel Sherrill [eb562f2] * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/start16.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.s (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * cpukit/score/cpu/i386/cpu.c (modified) Patch from Eric Valette : Here is a patch ... Fri, 21 Aug 1998 16:16:00 GMT Joel Sherrill [29381405] * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * cpukit/score/cpu/i386/cpu.c (modified) Spacing changes Fri, 21 Aug 1998 15:32:19 GMT Joel Sherrill [b3fd1641] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Fix from Eric Norum : "Thomas Doerfler" ... Fri, 21 Aug 1998 13:04:55 GMT Joel Sherrill [33679ec4] * c/src/exec/libnetworking/libc/res_send.c (modified) * c/src/exec/libnetworking/netinet/ip_input.c (modified) * c/src/exec/libnetworking/netinet/ip_mroute.c (modified) * c/src/exec/libnetworking/netinet/tcp_input.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/lib/libnetworking/libc/res_send.c (modified) * c/src/lib/libnetworking/netinet/ip_input.c (modified) * c/src/lib/libnetworking/netinet/ip_mroute.c (modified) * c/src/lib/libnetworking/netinet/tcp_input.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/libc/res_send.c (modified) * c/src/libnetworking/netinet/ip_input.c (modified) * c/src/libnetworking/netinet/ip_mroute.c (modified) * c/src/libnetworking/netinet/tcp_input.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/netinet/ip_input.c (modified) * cpukit/libnetworking/netinet/ip_mroute.c (modified) * cpukit/libnetworking/netinet/tcp_input.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) All warnings removed. Fri, 21 Aug 1998 12:52:08 GMT Joel Sherrill [bbdab89] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Added initialization of missing termios structure entries. Fri, 21 Aug 1998 12:51:29 GMT Joel Sherrill [ab09043a] * c/src/exec/libnetworking/libc/res_send.c (modified) * c/src/lib/libnetworking/libc/res_send.c (modified) * c/src/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) Fixed warning about pointer/integer conversion which turned out to be ... Thu, 20 Aug 1998 22:11:31 GMT Joel Sherrill [a9cfa238] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980820pm-BSD Thu, 20 Aug 1998 22:04:22 GMT Joel Sherrill [28e7d7fa] * c/Makefile.in (modified) * c/src/exec/libnetworking/arpa/inet.h (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/README (modified) * c/src/lib/libbsp/bare/do-bare-bsp-build (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/arpa/inet.h (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libnetworking/arpa/inet.h (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * make/Templates/Makefile.inc.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) Patches from Eric Norum Thu, 20 Aug 1998 21:56:40 GMT Joel Sherrill [96b39164] * c/src/exec/libnetworking/README (modified) * c/src/exec/libnetworking/arpa/ftp.h (modified) * c/src/exec/libnetworking/arpa/telnet.h (modified) * c/src/exec/libnetworking/bpfilter.h (modified) * c/src/exec/libnetworking/lib/README (modified) * c/src/exec/libnetworking/lib/getprotoby.c (modified) * c/src/exec/libnetworking/libc/addr2ascii.3 (modified) * c/src/exec/libnetworking/libc/addr2ascii.c (modified) * c/src/exec/libnetworking/libc/ascii2addr.c (modified) * c/src/exec/libnetworking/libc/byteorder.3 (modified) * c/src/exec/libnetworking/libc/gethostname.c (modified) * c/src/exec/libnetworking/libc/getnetent.3 (modified) * c/src/exec/libnetworking/libc/getproto.c (modified) * c/src/exec/libnetworking/libc/getprotoent.3 (modified) * c/src/exec/libnetworking/libc/getprotoent.c (modified) * c/src/exec/libnetworking/libc/getprotoname.c (modified) * c/src/exec/libnetworking/libc/getservbyname.c (modified) * c/src/exec/libnetworking/libc/getservbyport.c (modified) * c/src/exec/libnetworking/libc/getservent.c (modified) * c/src/exec/libnetworking/libc/inet_lnaof.c (modified) * c/src/exec/libnetworking/libc/inet_makeaddr.c (modified) * c/src/exec/libnetworking/libc/inet_netof.c (modified) * c/src/exec/libnetworking/libc/inet_network.c (modified) * c/src/exec/libnetworking/libc/inet_ntoa.c (modified) * c/src/exec/libnetworking/libc/iso_addr.3 (modified) * c/src/exec/libnetworking/libc/iso_addr.c (modified) * c/src/exec/libnetworking/libc/linkaddr.c (modified) * c/src/exec/libnetworking/libc/ns_addr.c (modified) * c/src/exec/libnetworking/libc/ns_ntoa.c (modified) * c/src/exec/libnetworking/libc/rcmd.c (modified) * c/src/exec/libnetworking/libc/recv.c (modified) * c/src/exec/libnetworking/libc/res_config.h (modified) * c/src/exec/libnetworking/libc/resolver.3 (modified) * c/src/exec/libnetworking/libc/send.c (modified) * c/src/exec/libnetworking/libc/strsep.c (modified) * c/src/exec/libnetworking/loop.h (modified) * c/src/exec/libnetworking/machine/conf.h (modified) * c/src/exec/libnetworking/machine/cpu.h (modified) * c/src/exec/libnetworking/machine/cpufunc.h (modified) * c/src/exec/libnetworking/machine/endian.h (modified) * c/src/exec/libnetworking/machine/limits.h (modified) * c/src/exec/libnetworking/machine/param.h (modified) * c/src/exec/libnetworking/machine/types.h (modified) * c/src/exec/libnetworking/machine/vmparam.h (modified) * c/src/exec/libnetworking/opt_ipfw.h (modified) * c/src/exec/libnetworking/opt_mrouting.h (modified) * c/src/exec/libnetworking/opt_tcpdebug.h (modified) * c/src/exec/libnetworking/rtems/issetugid.c (modified) * c/src/exec/libnetworking/rtems/rtems_bootp.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_glue.c (modified) * c/src/exec/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/exec/libnetworking/rtems/rtems_showroute.c (modified) * c/src/exec/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/rtems/sghostname.c (modified) * c/src/exec/libnetworking/sys/proc.h (modified) * c/src/exec/libnetworking/sys/resourcevar.h (modified) * c/src/exec/libnetworking/syslog.h (modified) * c/src/lib/libnetworking/CHANGELOG (modified) * c/src/lib/libnetworking/README (modified) * c/src/lib/libnetworking/arpa/ftp.h (modified) * c/src/lib/libnetworking/arpa/telnet.h (modified) * c/src/lib/libnetworking/bpfilter.h (modified) * c/src/lib/libnetworking/lib/README (modified) * c/src/lib/libnetworking/lib/getprotoby.c (modified) * c/src/lib/libnetworking/libc/addr2ascii.3 (modified) * c/src/lib/libnetworking/libc/addr2ascii.c (modified) * c/src/lib/libnetworking/libc/ascii2addr.c (modified) * c/src/lib/libnetworking/libc/byteorder.3 (modified) * c/src/lib/libnetworking/libc/gethostname.c (modified) * c/src/lib/libnetworking/libc/getnetent.3 (modified) * c/src/lib/libnetworking/libc/getproto.c (modified) * c/src/lib/libnetworking/libc/getprotoent.3 (modified) * c/src/lib/libnetworking/libc/getprotoent.c (modified) * c/src/lib/libnetworking/libc/getprotoname.c (modified) * c/src/lib/libnetworking/libc/getservbyname.c (modified) * c/src/lib/libnetworking/libc/getservbyport.c (modified) * c/src/lib/libnetworking/libc/getservent.c (modified) * c/src/lib/libnetworking/libc/inet_lnaof.c (modified) * c/src/lib/libnetworking/libc/inet_makeaddr.c (modified) * c/src/lib/libnetworking/libc/inet_netof.c (modified) * c/src/lib/libnetworking/libc/inet_network.c (modified) * c/src/lib/libnetworking/libc/inet_ntoa.c (modified) * c/src/lib/libnetworking/libc/iso_addr.3 (modified) * c/src/lib/libnetworking/libc/iso_addr.c (modified) * c/src/lib/libnetworking/libc/linkaddr.c (modified) * c/src/lib/libnetworking/libc/ns_addr.c (modified) * c/src/lib/libnetworking/libc/ns_ntoa.c (modified) * c/src/lib/libnetworking/libc/rcmd.c (modified) * c/src/lib/libnetworking/libc/recv.c (modified) * c/src/lib/libnetworking/libc/res_config.h (modified) * c/src/lib/libnetworking/libc/resolver.3 (modified) * c/src/lib/libnetworking/libc/send.c (modified) * c/src/lib/libnetworking/libc/strsep.c (modified) * c/src/lib/libnetworking/loop.h (modified) * c/src/lib/libnetworking/machine/conf.h (modified) * c/src/lib/libnetworking/machine/cpu.h (modified) * c/src/lib/libnetworking/machine/cpufunc.h (modified) * c/src/lib/libnetworking/machine/endian.h (modified) * c/src/lib/libnetworking/machine/limits.h (modified) * c/src/lib/libnetworking/machine/param.h (modified) * c/src/lib/libnetworking/machine/types.h (modified) * c/src/lib/libnetworking/machine/vmparam.h (modified) * c/src/lib/libnetworking/opt_ipfw.h (modified) * c/src/lib/libnetworking/opt_mrouting.h (modified) * c/src/lib/libnetworking/opt_tcpdebug.h (modified) * c/src/lib/libnetworking/rtems/issetugid.c (modified) * c/src/lib/libnetworking/rtems/rtems_bootp.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_glue.c (modified) * c/src/lib/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/lib/libnetworking/rtems/rtems_showroute.c (modified) * c/src/lib/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/rtems/sghostname.c (modified) * c/src/lib/libnetworking/sys/proc.h (modified) * c/src/lib/libnetworking/sys/resourcevar.h (modified) * c/src/lib/libnetworking/syslog.h (modified) * c/src/libnetworking/CHANGELOG (modified) * c/src/libnetworking/README (modified) * c/src/libnetworking/arpa/ftp.h (modified) * c/src/libnetworking/arpa/telnet.h (modified) * c/src/libnetworking/bpfilter.h (modified) * c/src/libnetworking/lib/README (modified) * c/src/libnetworking/lib/getprotoby.c (modified) * c/src/libnetworking/libc/addr2ascii.3 (modified) * c/src/libnetworking/libc/addr2ascii.c (modified) * c/src/libnetworking/libc/ascii2addr.c (modified) * c/src/libnetworking/libc/byteorder.3 (modified) * c/src/libnetworking/libc/gethostname.c (modified) * c/src/libnetworking/libc/getnetent.3 (modified) * c/src/libnetworking/libc/getproto.c (modified) * c/src/libnetworking/libc/getprotoent.3 (modified) * c/src/libnetworking/libc/getprotoent.c (modified) * c/src/libnetworking/libc/getprotoname.c (modified) * c/src/libnetworking/libc/getservbyname.c (modified) * c/src/libnetworking/libc/getservbyport.c (modified) * c/src/libnetworking/libc/getservent.c (modified) * c/src/libnetworking/libc/inet_lnaof.c (modified) * c/src/libnetworking/libc/inet_makeaddr.c (modified) * c/src/libnetworking/libc/inet_netof.c (modified) * c/src/libnetworking/libc/inet_network.c (modified) * c/src/libnetworking/libc/inet_ntoa.c (modified) * c/src/libnetworking/libc/iso_addr.3 (modified) * c/src/libnetworking/libc/iso_addr.c (modified) * c/src/libnetworking/libc/linkaddr.c (modified) * c/src/libnetworking/libc/ns_addr.c (modified) * c/src/libnetworking/libc/ns_ntoa.c (modified) * c/src/libnetworking/libc/rcmd.c (modified) * c/src/libnetworking/libc/recv.c (modified) * c/src/libnetworking/libc/res_config.h (modified) * c/src/libnetworking/libc/resolver.3 (modified) * c/src/libnetworking/libc/send.c (modified) * c/src/libnetworking/libc/strsep.c (modified) * c/src/libnetworking/loop.h (modified) * c/src/libnetworking/machine/conf.h (modified) * c/src/libnetworking/machine/cpu.h (modified) * c/src/libnetworking/machine/cpufunc.h (modified) * c/src/libnetworking/machine/endian.h (modified) * c/src/libnetworking/machine/limits.h (modified) * c/src/libnetworking/machine/param.h (modified) * c/src/libnetworking/machine/types.h (modified) * c/src/libnetworking/machine/vmparam.h (modified) * c/src/libnetworking/opt_ipfw.h (modified) * c/src/libnetworking/opt_mrouting.h (modified) * c/src/libnetworking/opt_tcpdebug.h (modified) * c/src/libnetworking/rtems/issetugid.c (modified) * c/src/libnetworking/rtems/rtems_bootp.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet.h (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_glue.c (modified) * c/src/libnetworking/rtems/rtems_showicmpstat.c (modified) * c/src/libnetworking/rtems/rtems_showifstat.c (modified) * c/src/libnetworking/rtems/rtems_showipstat.c (modified) * c/src/libnetworking/rtems/rtems_showmbuf.c (modified) * c/src/libnetworking/rtems/rtems_showroute.c (modified) * c/src/libnetworking/rtems/rtems_showtcpstat.c (modified) * c/src/libnetworking/rtems/rtems_showudpstat.c (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems/sghostname.c (modified) * c/src/libnetworking/sys/proc.h (modified) * c/src/libnetworking/sys/resourcevar.h (modified) * c/src/libnetworking/syslog.h (modified) * cpukit/libnetworking/README (modified) * cpukit/libnetworking/arpa/ftp.h (modified) * cpukit/libnetworking/arpa/telnet.h (modified) * cpukit/libnetworking/bpfilter.h (modified) * cpukit/libnetworking/lib/README (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/libc/addr2ascii.3 (modified) * cpukit/libnetworking/libc/addr2ascii.c (modified) * cpukit/libnetworking/libc/ascii2addr.c (modified) * cpukit/libnetworking/libc/byteorder.3 (modified) * cpukit/libnetworking/libc/gethostname.c (modified) * cpukit/libnetworking/libc/getnetent.3 (modified) * cpukit/libnetworking/libc/getproto.c (modified) * cpukit/libnetworking/libc/getprotoent.3 (modified) * cpukit/libnetworking/libc/getprotoent.c (modified) * cpukit/libnetworking/libc/getprotoname.c (modified) * cpukit/libnetworking/libc/getservbyname.c (modified) * cpukit/libnetworking/libc/getservbyport.c (modified) * cpukit/libnetworking/libc/getservent.c (modified) * cpukit/libnetworking/libc/inet_lnaof.c (modified) * cpukit/libnetworking/libc/inet_makeaddr.c (modified) * cpukit/libnetworking/libc/inet_netof.c (modified) * cpukit/libnetworking/libc/inet_network.c (modified) * cpukit/libnetworking/libc/inet_ntoa.c (modified) * cpukit/libnetworking/libc/iso_addr.3 (modified) * cpukit/libnetworking/libc/iso_addr.c (modified) * cpukit/libnetworking/libc/linkaddr.c (modified) * cpukit/libnetworking/libc/ns_addr.c (modified) * cpukit/libnetworking/libc/ns_ntoa.c (modified) * cpukit/libnetworking/libc/rcmd.c (modified) * cpukit/libnetworking/libc/recv.c (modified) * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/libc/resolver.3 (modified) * cpukit/libnetworking/libc/send.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/loop.h (modified) * cpukit/libnetworking/machine/conf.h (modified) * cpukit/libnetworking/machine/cpu.h (modified) * cpukit/libnetworking/machine/cpufunc.h (modified) * cpukit/libnetworking/machine/endian.h (modified) * cpukit/libnetworking/machine/limits.h (modified) * cpukit/libnetworking/machine/param.h (modified) * cpukit/libnetworking/machine/types.h (modified) * cpukit/libnetworking/machine/vmparam.h (modified) * cpukit/libnetworking/opt_ipfw.h (modified) * cpukit/libnetworking/opt_mrouting.h (modified) * cpukit/libnetworking/opt_tcpdebug.h (modified) * cpukit/libnetworking/rtems/issetugid.c (modified) * cpukit/libnetworking/rtems/rtems_bootp.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet.h (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showifstat.c (modified) * cpukit/libnetworking/rtems/rtems_showipstat.c (modified) * cpukit/libnetworking/rtems/rtems_showmbuf.c (modified) * cpukit/libnetworking/rtems/rtems_showroute.c (modified) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (modified) * cpukit/libnetworking/rtems/rtems_showudpstat.c (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/rtems/sghostname.c (modified) * cpukit/libnetworking/sys/proc.h (modified) * cpukit/libnetworking/sys/resourcevar.h (modified) * cpukit/libnetworking/syslog.h (modified) Added CVS Ids Thu, 20 Aug 1998 21:47:37 GMT Joel Sherrill [ff0f694d] * c/src/exec/libnetworking/kern/uipc_domain.c (modified) * c/src/exec/libnetworking/kern/uipc_socket.c (modified) * c/src/exec/libnetworking/lib/getprotoby.c (modified) * c/src/exec/libnetworking/lib/syslog.c (modified) * c/src/exec/libnetworking/libc/base64.c (modified) * c/src/exec/libnetworking/libc/gethostbydns.c (modified) * c/src/exec/libnetworking/libc/gethostnamadr.c (modified) * c/src/exec/libnetworking/libc/inet_addr.c (modified) * c/src/exec/libnetworking/libc/ns_name.c (modified) * c/src/exec/libnetworking/libc/ns_netint.c (modified) * c/src/exec/libnetworking/libc/ns_parse.c (modified) * c/src/exec/libnetworking/libc/ns_print.c (modified) * c/src/exec/libnetworking/libc/ns_ttl.c (modified) * c/src/exec/libnetworking/libc/res_config.h (modified) * c/src/exec/libnetworking/libc/res_debug.c (modified) * c/src/exec/libnetworking/libc/res_init.c (modified) * c/src/exec/libnetworking/libc/res_mkupdate.c (modified) * c/src/exec/libnetworking/libc/res_query.c (modified) * c/src/exec/libnetworking/libc/res_send.c (modified) * c/src/exec/libnetworking/libc/res_update.c (modified) * c/src/exec/libnetworking/libc/strsep.c (modified) * c/src/exec/libnetworking/net/if_ethersubr.c (modified) * c/src/exec/libnetworking/net/route.c (modified) * c/src/exec/libnetworking/net/rtsock.c (modified) * c/src/exec/libnetworking/netinet/in_pcb.c (modified) * c/src/exec/libnetworking/netinet/tcp_debug.c (modified) * c/src/exec/libnetworking/netinet/tcp_subr.c (modified) * c/src/exec/libnetworking/netinet/udp_usrreq.c (modified) * c/src/exec/libnetworking/nfs/bootp_subr.c (modified) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/libkern.h (modified) * c/src/exec/libnetworking/sys/param.h (modified) * c/src/exec/libnetworking/sys/syslimits.h (modified) * c/src/lib/libnetworking/kern/uipc_domain.c (modified) * c/src/lib/libnetworking/kern/uipc_socket.c (modified) * c/src/lib/libnetworking/lib/getprotoby.c (modified) * c/src/lib/libnetworking/lib/syslog.c (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/libc/base64.c (modified) * c/src/lib/libnetworking/libc/gethostbydns.c (modified) * c/src/lib/libnetworking/libc/gethostnamadr.c (modified) * c/src/lib/libnetworking/libc/inet_addr.c (modified) * c/src/lib/libnetworking/libc/ns_name.c (modified) * c/src/lib/libnetworking/libc/ns_netint.c (modified) * c/src/lib/libnetworking/libc/ns_parse.c (modified) * c/src/lib/libnetworking/libc/ns_print.c (modified) * c/src/lib/libnetworking/libc/ns_ttl.c (modified) * c/src/lib/libnetworking/libc/res_config.h (modified) * c/src/lib/libnetworking/libc/res_debug.c (modified) * c/src/lib/libnetworking/libc/res_init.c (modified) * c/src/lib/libnetworking/libc/res_mkupdate.c (modified) * c/src/lib/libnetworking/libc/res_query.c (modified) * c/src/lib/libnetworking/libc/res_send.c (modified) * c/src/lib/libnetworking/libc/res_update.c (modified) * c/src/lib/libnetworking/libc/strsep.c (modified) * c/src/lib/libnetworking/net/if_ethersubr.c (modified) * c/src/lib/libnetworking/net/route.c (modified) * c/src/lib/libnetworking/net/rtsock.c (modified) * c/src/lib/libnetworking/netinet/in_pcb.c (modified) * c/src/lib/libnetworking/netinet/tcp_debug.c (modified) * c/src/lib/libnetworking/netinet/tcp_subr.c (modified) * c/src/lib/libnetworking/netinet/udp_usrreq.c (modified) * c/src/lib/libnetworking/nfs/bootp_subr.c (modified) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/libnetworking/sys/libkern.h (modified) * c/src/lib/libnetworking/sys/param.h (modified) * c/src/lib/libnetworking/sys/syslimits.h (modified) * c/src/libnetworking/kern/uipc_domain.c (modified) * c/src/libnetworking/kern/uipc_socket.c (modified) * c/src/libnetworking/lib/getprotoby.c (modified) * c/src/libnetworking/lib/syslog.c (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/libc/base64.c (modified) * c/src/libnetworking/libc/gethostbydns.c (modified) * c/src/libnetworking/libc/gethostnamadr.c (modified) * c/src/libnetworking/libc/inet_addr.c (modified) * c/src/libnetworking/libc/ns_name.c (modified) * c/src/libnetworking/libc/ns_netint.c (modified) * c/src/libnetworking/libc/ns_parse.c (modified) * c/src/libnetworking/libc/ns_print.c (modified) * c/src/libnetworking/libc/ns_ttl.c (modified) * c/src/libnetworking/libc/res_config.h (modified) * c/src/libnetworking/libc/res_debug.c (modified) * c/src/libnetworking/libc/res_init.c (modified) * c/src/libnetworking/libc/res_mkupdate.c (modified) * c/src/libnetworking/libc/res_query.c (modified) * c/src/libnetworking/libc/res_send.c (modified) * c/src/libnetworking/libc/res_update.c (modified) * c/src/libnetworking/libc/strsep.c (modified) * c/src/libnetworking/net/if_ethersubr.c (modified) * c/src/libnetworking/net/route.c (modified) * c/src/libnetworking/net/rtsock.c (modified) * c/src/libnetworking/netinet/in_pcb.c (modified) * c/src/libnetworking/netinet/tcp_debug.c (modified) * c/src/libnetworking/netinet/tcp_subr.c (modified) * c/src/libnetworking/netinet/udp_usrreq.c (modified) * c/src/libnetworking/nfs/bootp_subr.c (modified) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/sys/libkern.h (modified) * c/src/libnetworking/sys/param.h (modified) * c/src/libnetworking/sys/syslimits.h (modified) * cpukit/libnetworking/kern/uipc_domain.c (modified) * cpukit/libnetworking/kern/uipc_socket.c (modified) * cpukit/libnetworking/lib/getprotoby.c (modified) * cpukit/libnetworking/lib/syslog.c (modified) * cpukit/libnetworking/libc/base64.c (modified) * cpukit/libnetworking/libc/gethostbydns.c (modified) * cpukit/libnetworking/libc/gethostnamadr.c (modified) * cpukit/libnetworking/libc/inet_addr.c (modified) * cpukit/libnetworking/libc/ns_name.c (modified) * cpukit/libnetworking/libc/ns_netint.c (modified) * cpukit/libnetworking/libc/ns_parse.c (modified) * cpukit/libnetworking/libc/ns_print.c (modified) * cpukit/libnetworking/libc/ns_ttl.c (modified) * cpukit/libnetworking/libc/res_config.h (modified) * cpukit/libnetworking/libc/res_debug.c (modified) * cpukit/libnetworking/libc/res_init.c (modified) * cpukit/libnetworking/libc/res_mkupdate.c (modified) * cpukit/libnetworking/libc/res_query.c (modified) * cpukit/libnetworking/libc/res_send.c (modified) * cpukit/libnetworking/libc/res_update.c (modified) * cpukit/libnetworking/libc/strsep.c (modified) * cpukit/libnetworking/net/if_ethersubr.c (modified) * cpukit/libnetworking/net/route.c (modified) * cpukit/libnetworking/net/rtsock.c (modified) * cpukit/libnetworking/netinet/in_pcb.c (modified) * cpukit/libnetworking/netinet/tcp_debug.c (modified) * cpukit/libnetworking/netinet/tcp_subr.c (modified) * cpukit/libnetworking/netinet/udp_usrreq.c (modified) * cpukit/libnetworking/nfs/bootp_subr.c (modified) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/libkern.h (modified) * cpukit/libnetworking/sys/param.h (modified) * cpukit/libnetworking/sys/syslimits.h (modified) Fixed many warnings. Thu, 20 Aug 1998 16:04:58 GMT Joel Sherrill [50ea4814] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980820-BSD Thu, 20 Aug 1998 14:39:09 GMT Joel Sherrill [0280cb6] * c/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) FreeBSD stack compiles for the first time (except libc/strsep.c) Thu, 20 Aug 1998 14:37:17 GMT Joel Sherrill [3f098aed] * c/src/exec/libnetworking/machine/conf.h (added) * c/src/exec/libnetworking/machine/cpu.h (added) * c/src/exec/libnetworking/machine/cpufunc.h (added) * c/src/exec/libnetworking/machine/endian.h (added) * c/src/exec/libnetworking/machine/in_cksum.h (added) * c/src/exec/libnetworking/machine/limits.h (added) * c/src/exec/libnetworking/machine/param.h (added) * c/src/exec/libnetworking/machine/types.h (added) * c/src/exec/libnetworking/machine/vmparam.h (added) * c/src/lib/libnetworking/include/Makefile.in (added) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/machine/conf.h (added) * c/src/lib/libnetworking/machine/cpu.h (added) * c/src/lib/libnetworking/machine/cpufunc.h (added) * c/src/lib/libnetworking/machine/endian.h (added) * c/src/lib/libnetworking/machine/in_cksum.h (added) * c/src/lib/libnetworking/machine/limits.h (added) * c/src/lib/libnetworking/machine/param.h (added) * c/src/lib/libnetworking/machine/types.h (added) * c/src/lib/libnetworking/machine/vmparam.h (added) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (added) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/machine/conf.h (added) * c/src/libnetworking/machine/cpu.h (added) * c/src/libnetworking/machine/cpufunc.h (added) * c/src/libnetworking/machine/endian.h (added) * c/src/libnetworking/machine/in_cksum.h (added) * c/src/libnetworking/machine/limits.h (added) * c/src/libnetworking/machine/param.h (added) * c/src/libnetworking/machine/types.h (added) * c/src/libnetworking/machine/vmparam.h (added) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * cpukit/libnetworking/machine/conf.h (added) * cpukit/libnetworking/machine/cpu.h (added) * cpukit/libnetworking/machine/cpufunc.h (added) * cpukit/libnetworking/machine/endian.h (added) * cpukit/libnetworking/machine/in_cksum.h (added) * cpukit/libnetworking/machine/limits.h (added) * cpukit/libnetworking/machine/param.h (added) * cpukit/libnetworking/machine/types.h (added) * cpukit/libnetworking/machine/vmparam.h (added) FreeBSD stack compiles for the first time (except libc/strsep.c). Wed, 19 Aug 1998 21:32:28 GMT Joel Sherrill [39e6e65a] * c/src/exec/libcsupport/include/sys/filio.h (added) * c/src/exec/libcsupport/include/sys/ioctl.h (added) * c/src/exec/libcsupport/include/sys/sockio.h (added) * c/src/exec/libnetworking/README (added) * c/src/exec/libnetworking/arpa/ftp.h (added) * c/src/exec/libnetworking/arpa/inet.h (added) * c/src/exec/libnetworking/arpa/nameser.h (added) * c/src/exec/libnetworking/arpa/nameser_compat.h (added) * c/src/exec/libnetworking/arpa/telnet.h (added) * c/src/exec/libnetworking/bpfilter.h (added) * c/src/exec/libnetworking/kern/kern_subr.c (added) * c/src/exec/libnetworking/kern/uipc_domain.c (added) * c/src/exec/libnetworking/kern/uipc_mbuf.c (added) * c/src/exec/libnetworking/kern/uipc_socket.c (added) * c/src/exec/libnetworking/kern/uipc_socket2.c (added) * c/src/exec/libnetworking/lib/README (added) * c/src/exec/libnetworking/lib/getprotoby.c (added) * c/src/exec/libnetworking/lib/syslog.c (added) * c/src/exec/libnetworking/lib/tftpDriver.c (added) * c/src/exec/libnetworking/libc/addr2ascii.3 (added) * c/src/exec/libnetworking/libc/addr2ascii.c (added) * c/src/exec/libnetworking/libc/ascii2addr.c (added) * c/src/exec/libnetworking/libc/base64.c (added) * c/src/exec/libnetworking/libc/byteorder.3 (added) * c/src/exec/libnetworking/libc/ether_addr.c (added) * c/src/exec/libnetworking/libc/ethers.3 (added) * c/src/exec/libnetworking/libc/gethostbydns.c (added) * c/src/exec/libnetworking/libc/gethostbyht.c (added) * c/src/exec/libnetworking/libc/gethostbyname.3 (added) * c/src/exec/libnetworking/libc/gethostbynis.c (added) * c/src/exec/libnetworking/libc/gethostnamadr.c (added) * c/src/exec/libnetworking/libc/gethostname.c (added) * c/src/exec/libnetworking/libc/getnetbydns.c (added) * c/src/exec/libnetworking/libc/getnetbyht.c (added) * c/src/exec/libnetworking/libc/getnetbynis.c (added) * c/src/exec/libnetworking/libc/getnetent.3 (added) * c/src/exec/libnetworking/libc/getnetnamadr.c (added) * c/src/exec/libnetworking/libc/getproto.c (added) * c/src/exec/libnetworking/libc/getprotoent.3 (added) * c/src/exec/libnetworking/libc/getprotoent.c (added) * c/src/exec/libnetworking/libc/getprotoname.c (added) * c/src/exec/libnetworking/libc/getservbyname.c (added) * c/src/exec/libnetworking/libc/getservbyport.c (added) * c/src/exec/libnetworking/libc/getservent.3 (added) * c/src/exec/libnetworking/libc/getservent.c (added) * c/src/exec/libnetworking/libc/herror.c (added) * c/src/exec/libnetworking/libc/inet.3 (added) * c/src/exec/libnetworking/libc/inet_addr.c (added) * c/src/exec/libnetworking/libc/inet_lnaof.c (added) * c/src/exec/libnetworking/libc/inet_makeaddr.c (added) * c/src/exec/libnetworking/libc/inet_net_ntop.c (added) * c/src/exec/libnetworking/libc/inet_net_pton.c (added) * c/src/exec/libnetworking/libc/inet_neta.c (added) * c/src/exec/libnetworking/libc/inet_netof.c (added) * c/src/exec/libnetworking/libc/inet_network.c (added) * c/src/exec/libnetworking/libc/inet_ntoa.c (added) * c/src/exec/libnetworking/libc/inet_ntop.c (added) * c/src/exec/libnetworking/libc/inet_pton.c (added) * c/src/exec/libnetworking/libc/iso_addr.3 (added) * c/src/exec/libnetworking/libc/iso_addr.c (added) * c/src/exec/libnetworking/libc/linkaddr.3 (added) * c/src/exec/libnetworking/libc/linkaddr.c (added) * c/src/exec/libnetworking/libc/map_v4v6.c (added) * c/src/exec/libnetworking/libc/ns.3 (added) * c/src/exec/libnetworking/libc/ns_addr.c (added) * c/src/exec/libnetworking/libc/ns_name.c (added) * c/src/exec/libnetworking/libc/ns_netint.c (added) * c/src/exec/libnetworking/libc/ns_ntoa.c (added) * c/src/exec/libnetworking/libc/ns_parse.c (added) * c/src/exec/libnetworking/libc/ns_print.c (added) * c/src/exec/libnetworking/libc/ns_ttl.c (added) * c/src/exec/libnetworking/libc/nsap_addr.c (added) * c/src/exec/libnetworking/libc/rcmd.3 (added) * c/src/exec/libnetworking/libc/rcmd.c (added) * c/src/exec/libnetworking/libc/recv.c (added) * c/src/exec/libnetworking/libc/res_comp.c (added) * c/src/exec/libnetworking/libc/res_config.h (added) * c/src/exec/libnetworking/libc/res_data.c (added) * c/src/exec/libnetworking/libc/res_debug.c (added) * c/src/exec/libnetworking/libc/res_init.c (added) * c/src/exec/libnetworking/libc/res_mkquery.c (added) * c/src/exec/libnetworking/libc/res_mkupdate.c (added) * c/src/exec/libnetworking/libc/res_query.c (added) * c/src/exec/libnetworking/libc/res_send.c (added) * c/src/exec/libnetworking/libc/res_stubs.c (added) * c/src/exec/libnetworking/libc/res_update.c (added) * c/src/exec/libnetworking/libc/resolver.3 (added) * c/src/exec/libnetworking/libc/send.c (added) * c/src/exec/libnetworking/libc/strsep.c (added) * c/src/exec/libnetworking/loop.h (added) * c/src/exec/libnetworking/net/bpf.h (added) * c/src/exec/libnetworking/net/ethernet.h (added) * c/src/exec/libnetworking/net/if.c (added) * c/src/exec/libnetworking/net/if.h (added) * c/src/exec/libnetworking/net/if_arp.h (added) * c/src/exec/libnetworking/net/if_dl.h (added) * c/src/exec/libnetworking/net/if_ethersubr.c (added) * c/src/exec/libnetworking/net/if_llc.h (added) * c/src/exec/libnetworking/net/if_loop.c (added) * c/src/exec/libnetworking/net/if_types.h (added) * c/src/exec/libnetworking/net/netisr.h (added) * c/src/exec/libnetworking/net/radix.c (added) * c/src/exec/libnetworking/net/radix.h (added) * c/src/exec/libnetworking/net/raw_cb.c (added) * c/src/exec/libnetworking/net/raw_cb.h (added) * c/src/exec/libnetworking/net/raw_usrreq.c (added) * c/src/exec/libnetworking/net/route.c (added) * c/src/exec/libnetworking/net/route.h (added) * c/src/exec/libnetworking/net/rtsock.c (added) * c/src/exec/libnetworking/netdb.h (added) * c/src/exec/libnetworking/netinet/icmp_var.h (added) * c/src/exec/libnetworking/netinet/if_ether.c (added) * c/src/exec/libnetworking/netinet/if_ether.h (added) * c/src/exec/libnetworking/netinet/igmp.c (added) * c/src/exec/libnetworking/netinet/igmp.h (added) * c/src/exec/libnetworking/netinet/igmp_var.h (added) * c/src/exec/libnetworking/netinet/in.c (added) * c/src/exec/libnetworking/netinet/in.h (added) * c/src/exec/libnetworking/netinet/in_cksum.c (added) * c/src/exec/libnetworking/netinet/in_pcb.c (added) * c/src/exec/libnetworking/netinet/in_pcb.h (added) * c/src/exec/libnetworking/netinet/in_proto.c (added) * c/src/exec/libnetworking/netinet/in_rmx.c (added) * c/src/exec/libnetworking/netinet/in_systm.h (added) * c/src/exec/libnetworking/netinet/in_var.h (added) * c/src/exec/libnetworking/netinet/ip.h (added) * c/src/exec/libnetworking/netinet/ip_divert.c (added) * c/src/exec/libnetworking/netinet/ip_fw.c (added) * c/src/exec/libnetworking/netinet/ip_fw.h (added) * c/src/exec/libnetworking/netinet/ip_icmp.c (added) * c/src/exec/libnetworking/netinet/ip_icmp.h (added) * c/src/exec/libnetworking/netinet/ip_input.c (added) * c/src/exec/libnetworking/netinet/ip_mroute.c (added) * c/src/exec/libnetworking/netinet/ip_mroute.h (added) * c/src/exec/libnetworking/netinet/ip_output.c (added) * c/src/exec/libnetworking/netinet/ip_var.h (added) * c/src/exec/libnetworking/netinet/raw_ip.c (added) * c/src/exec/libnetworking/netinet/tcp.h (added) * c/src/exec/libnetworking/netinet/tcp_debug.c (added) * c/src/exec/libnetworking/netinet/tcp_debug.h (added) * c/src/exec/libnetworking/netinet/tcp_fsm.h (added) * c/src/exec/libnetworking/netinet/tcp_input.c (added) * c/src/exec/libnetworking/netinet/tcp_output.c (added) * c/src/exec/libnetworking/netinet/tcp_seq.h (added) * c/src/exec/libnetworking/netinet/tcp_subr.c (added) * c/src/exec/libnetworking/netinet/tcp_timer.c (added) * c/src/exec/libnetworking/netinet/tcp_timer.h (added) * c/src/exec/libnetworking/netinet/tcp_usrreq.c (added) * c/src/exec/libnetworking/netinet/tcp_var.h (added) * c/src/exec/libnetworking/netinet/tcpip.h (added) * c/src/exec/libnetworking/netinet/udp.h (added) * c/src/exec/libnetworking/netinet/udp_usrreq.c (added) * c/src/exec/libnetworking/netinet/udp_var.h (added) * c/src/exec/libnetworking/nfs/bootp_subr.c (added) * c/src/exec/libnetworking/nfs/krpc.h (added) * c/src/exec/libnetworking/nfs/nfs.h (added) * c/src/exec/libnetworking/nfs/nfsdiskless.h (added) * c/src/exec/libnetworking/nfs/nfsproto.h (added) * c/src/exec/libnetworking/nfs/rpcv2.h (added) * c/src/exec/libnetworking/nfs/xdr_subs.h (added) * c/src/exec/libnetworking/opt_ipfw.h (added) * c/src/exec/libnetworking/opt_mrouting.h (added) * c/src/exec/libnetworking/opt_tcpdebug.h (added) * c/src/exec/libnetworking/poll.h (added) * c/src/exec/libnetworking/resolv.h (added) * c/src/exec/libnetworking/rtems/issetugid.c (added) * c/src/exec/libnetworking/rtems/rtems_bootp.c (added) * c/src/exec/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/exec/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/exec/libnetworking/rtems/rtems_glue.c (added) * c/src/exec/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showifstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showipstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/exec/libnetworking/rtems/rtems_showroute.c (added) * c/src/exec/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/exec/libnetworking/rtems/rtems_syscall.c (added) * c/src/exec/libnetworking/rtems/sghostname.c (added) * c/src/exec/libnetworking/rtems/tftp.h (added) * c/src/exec/libnetworking/sys/buf.h (added) * c/src/exec/libnetworking/sys/callout.h (added) * c/src/exec/libnetworking/sys/conf.h (added) * c/src/exec/libnetworking/sys/domain.h (added) * c/src/exec/libnetworking/sys/kernel.h (added) * c/src/exec/libnetworking/sys/libkern.h (added) * c/src/exec/libnetworking/sys/malloc.h (added) * c/src/exec/libnetworking/sys/mbuf.h (added) * c/src/exec/libnetworking/sys/mount.h (added) * c/src/exec/libnetworking/sys/param.h (added) * c/src/exec/libnetworking/sys/proc.h (added) * c/src/exec/libnetworking/sys/protosw.h (added) * c/src/exec/libnetworking/sys/queue.h (added) * c/src/exec/libnetworking/sys/reboot.h (added) * c/src/exec/libnetworking/sys/resourcevar.h (added) * c/src/exec/libnetworking/sys/rtprio.h (added) * c/src/exec/libnetworking/sys/select.h (added) * c/src/exec/libnetworking/sys/signalvar.h (added) * c/src/exec/libnetworking/sys/socket.h (added) * c/src/exec/libnetworking/sys/socketvar.h (added) * c/src/exec/libnetworking/sys/sysctl.h (added) * c/src/exec/libnetworking/sys/syslimits.h (added) * c/src/exec/libnetworking/sys/syslog.h (added) * c/src/exec/libnetworking/sys/systm.h (added) * c/src/exec/libnetworking/sys/ttydefaults.h (added) * c/src/exec/libnetworking/sys/ucred.h (added) * c/src/exec/libnetworking/sys/uio.h (added) * c/src/exec/libnetworking/syslog.h (added) * c/src/exec/libnetworking/vm/vm.h (added) * c/src/exec/libnetworking/vm/vm_extern.h (added) * c/src/exec/libnetworking/vm/vm_kern.h (added) * c/src/exec/libnetworking/vm/vm_param.h (added) * c/src/lib/include/sys/filio.h (added) * c/src/lib/include/sys/ioctl.h (added) * c/src/lib/include/sys/sockio.h (added) * c/src/lib/libnetworking/CHANGELOG (added) * c/src/lib/libnetworking/README (added) * c/src/lib/libnetworking/arpa/ftp.h (added) * c/src/lib/libnetworking/arpa/inet.h (added) * c/src/lib/libnetworking/arpa/nameser.h (added) * c/src/lib/libnetworking/arpa/nameser_compat.h (added) * c/src/lib/libnetworking/arpa/telnet.h (added) * c/src/lib/libnetworking/bpfilter.h (added) * c/src/lib/libnetworking/kern/kern_subr.c (added) * c/src/lib/libnetworking/kern/uipc_domain.c (added) * c/src/lib/libnetworking/kern/uipc_mbuf.c (added) * c/src/lib/libnetworking/kern/uipc_socket.c (added) * c/src/lib/libnetworking/kern/uipc_socket2.c (added) * c/src/lib/libnetworking/lib/README (added) * c/src/lib/libnetworking/lib/getprotoby.c (added) * c/src/lib/libnetworking/lib/syslog.c (added) * c/src/lib/libnetworking/lib/tftpDriver.c (added) * c/src/lib/libnetworking/libc/addr2ascii.3 (added) * c/src/lib/libnetworking/libc/addr2ascii.c (added) * c/src/lib/libnetworking/libc/ascii2addr.c (added) * c/src/lib/libnetworking/libc/base64.c (added) * c/src/lib/libnetworking/libc/byteorder.3 (added) * c/src/lib/libnetworking/libc/ether_addr.c (added) * c/src/lib/libnetworking/libc/ethers.3 (added) * c/src/lib/libnetworking/libc/gethostbydns.c (added) * c/src/lib/libnetworking/libc/gethostbyht.c (added) * c/src/lib/libnetworking/libc/gethostbyname.3 (added) * c/src/lib/libnetworking/libc/gethostbynis.c (added) * c/src/lib/libnetworking/libc/gethostnamadr.c (added) * c/src/lib/libnetworking/libc/gethostname.c (added) * c/src/lib/libnetworking/libc/getnetbydns.c (added) * c/src/lib/libnetworking/libc/getnetbyht.c (added) * c/src/lib/libnetworking/libc/getnetbynis.c (added) * c/src/lib/libnetworking/libc/getnetent.3 (added) * c/src/lib/libnetworking/libc/getnetnamadr.c (added) * c/src/lib/libnetworking/libc/getproto.c (added) * c/src/lib/libnetworking/libc/getprotoent.3 (added) * c/src/lib/libnetworking/libc/getprotoent.c (added) * c/src/lib/libnetworking/libc/getprotoname.c (added) * c/src/lib/libnetworking/libc/getservbyname.c (added) * c/src/lib/libnetworking/libc/getservbyport.c (added) * c/src/lib/libnetworking/libc/getservent.3 (added) * c/src/lib/libnetworking/libc/getservent.c (added) * c/src/lib/libnetworking/libc/herror.c (added) * c/src/lib/libnetworking/libc/inet.3 (added) * c/src/lib/libnetworking/libc/inet_addr.c (added) * c/src/lib/libnetworking/libc/inet_lnaof.c (added) * c/src/lib/libnetworking/libc/inet_makeaddr.c (added) * c/src/lib/libnetworking/libc/inet_net_ntop.c (added) * c/src/lib/libnetworking/libc/inet_net_pton.c (added) * c/src/lib/libnetworking/libc/inet_neta.c (added) * c/src/lib/libnetworking/libc/inet_netof.c (added) * c/src/lib/libnetworking/libc/inet_network.c (added) * c/src/lib/libnetworking/libc/inet_ntoa.c (added) * c/src/lib/libnetworking/libc/inet_ntop.c (added) * c/src/lib/libnetworking/libc/inet_pton.c (added) * c/src/lib/libnetworking/libc/iso_addr.3 (added) * c/src/lib/libnetworking/libc/iso_addr.c (added) * c/src/lib/libnetworking/libc/linkaddr.3 (added) * c/src/lib/libnetworking/libc/linkaddr.c (added) * c/src/lib/libnetworking/libc/map_v4v6.c (added) * c/src/lib/libnetworking/libc/ns.3 (added) * c/src/lib/libnetworking/libc/ns_addr.c (added) * c/src/lib/libnetworking/libc/ns_name.c (added) * c/src/lib/libnetworking/libc/ns_netint.c (added) * c/src/lib/libnetworking/libc/ns_ntoa.c (added) * c/src/lib/libnetworking/libc/ns_parse.c (added) * c/src/lib/libnetworking/libc/ns_print.c (added) * c/src/lib/libnetworking/libc/ns_ttl.c (added) * c/src/lib/libnetworking/libc/nsap_addr.c (added) * c/src/lib/libnetworking/libc/rcmd.3 (added) * c/src/lib/libnetworking/libc/rcmd.c (added) * c/src/lib/libnetworking/libc/recv.c (added) * c/src/lib/libnetworking/libc/res_comp.c (added) * c/src/lib/libnetworking/libc/res_config.h (added) * c/src/lib/libnetworking/libc/res_data.c (added) * c/src/lib/libnetworking/libc/res_debug.c (added) * c/src/lib/libnetworking/libc/res_init.c (added) * c/src/lib/libnetworking/libc/res_mkquery.c (added) * c/src/lib/libnetworking/libc/res_mkupdate.c (added) * c/src/lib/libnetworking/libc/res_query.c (added) * c/src/lib/libnetworking/libc/res_send.c (added) * c/src/lib/libnetworking/libc/res_stubs.c (added) * c/src/lib/libnetworking/libc/res_update.c (added) * c/src/lib/libnetworking/libc/resolver.3 (added) * c/src/lib/libnetworking/libc/send.c (added) * c/src/lib/libnetworking/libc/strsep.c (added) * c/src/lib/libnetworking/loop.h (added) * c/src/lib/libnetworking/net/bpf.h (added) * c/src/lib/libnetworking/net/ethernet.h (added) * c/src/lib/libnetworking/net/if.c (added) * c/src/lib/libnetworking/net/if.h (added) * c/src/lib/libnetworking/net/if_arp.h (added) * c/src/lib/libnetworking/net/if_dl.h (added) * c/src/lib/libnetworking/net/if_ethersubr.c (added) * c/src/lib/libnetworking/net/if_llc.h (added) * c/src/lib/libnetworking/net/if_loop.c (added) * c/src/lib/libnetworking/net/if_types.h (added) * c/src/lib/libnetworking/net/netisr.h (added) * c/src/lib/libnetworking/net/radix.c (added) * c/src/lib/libnetworking/net/radix.h (added) * c/src/lib/libnetworking/net/raw_cb.c (added) * c/src/lib/libnetworking/net/raw_cb.h (added) * c/src/lib/libnetworking/net/raw_usrreq.c (added) * c/src/lib/libnetworking/net/route.c (added) * c/src/lib/libnetworking/net/route.h (added) * c/src/lib/libnetworking/net/rtsock.c (added) * c/src/lib/libnetworking/netdb.h (added) * c/src/lib/libnetworking/netinet/icmp_var.h (added) * c/src/lib/libnetworking/netinet/if_ether.c (added) * c/src/lib/libnetworking/netinet/if_ether.h (added) * c/src/lib/libnetworking/netinet/igmp.c (added) * c/src/lib/libnetworking/netinet/igmp.h (added) * c/src/lib/libnetworking/netinet/igmp_var.h (added) * c/src/lib/libnetworking/netinet/in.c (added) * c/src/lib/libnetworking/netinet/in.h (added) * c/src/lib/libnetworking/netinet/in_cksum.c (added) * c/src/lib/libnetworking/netinet/in_pcb.c (added) * c/src/lib/libnetworking/netinet/in_pcb.h (added) * c/src/lib/libnetworking/netinet/in_proto.c (added) * c/src/lib/libnetworking/netinet/in_rmx.c (added) * c/src/lib/libnetworking/netinet/in_systm.h (added) * c/src/lib/libnetworking/netinet/in_var.h (added) * c/src/lib/libnetworking/netinet/ip.h (added) * c/src/lib/libnetworking/netinet/ip_divert.c (added) * c/src/lib/libnetworking/netinet/ip_fw.c (added) * c/src/lib/libnetworking/netinet/ip_fw.h (added) * c/src/lib/libnetworking/netinet/ip_icmp.c (added) * c/src/lib/libnetworking/netinet/ip_icmp.h (added) * c/src/lib/libnetworking/netinet/ip_input.c (added) * c/src/lib/libnetworking/netinet/ip_mroute.c (added) * c/src/lib/libnetworking/netinet/ip_mroute.h (added) * c/src/lib/libnetworking/netinet/ip_output.c (added) * c/src/lib/libnetworking/netinet/ip_var.h (added) * c/src/lib/libnetworking/netinet/raw_ip.c (added) * c/src/lib/libnetworking/netinet/tcp.h (added) * c/src/lib/libnetworking/netinet/tcp_debug.c (added) * c/src/lib/libnetworking/netinet/tcp_debug.h (added) * c/src/lib/libnetworking/netinet/tcp_fsm.h (added) * c/src/lib/libnetworking/netinet/tcp_input.c (added) * c/src/lib/libnetworking/netinet/tcp_output.c (added) * c/src/lib/libnetworking/netinet/tcp_seq.h (added) * c/src/lib/libnetworking/netinet/tcp_subr.c (added) * c/src/lib/libnetworking/netinet/tcp_timer.c (added) * c/src/lib/libnetworking/netinet/tcp_timer.h (added) * c/src/lib/libnetworking/netinet/tcp_usrreq.c (added) * c/src/lib/libnetworking/netinet/tcp_var.h (added) * c/src/lib/libnetworking/netinet/tcpip.h (added) * c/src/lib/libnetworking/netinet/udp.h (added) * c/src/lib/libnetworking/netinet/udp_usrreq.c (added) * c/src/lib/libnetworking/netinet/udp_var.h (added) * c/src/lib/libnetworking/nfs/bootp_subr.c (added) * c/src/lib/libnetworking/nfs/krpc.h (added) * c/src/lib/libnetworking/nfs/nfs.h (added) * c/src/lib/libnetworking/nfs/nfsdiskless.h (added) * c/src/lib/libnetworking/nfs/nfsproto.h (added) * c/src/lib/libnetworking/nfs/rpcv2.h (added) * c/src/lib/libnetworking/nfs/xdr_subs.h (added) * c/src/lib/libnetworking/opt_ipfw.h (added) * c/src/lib/libnetworking/opt_mrouting.h (added) * c/src/lib/libnetworking/opt_tcpdebug.h (added) * c/src/lib/libnetworking/poll.h (added) * c/src/lib/libnetworking/resolv.h (added) * c/src/lib/libnetworking/rtems/issetugid.c (added) * c/src/lib/libnetworking/rtems/rtems_bootp.c (added) * c/src/lib/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/lib/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/lib/libnetworking/rtems/rtems_glue.c (added) * c/src/lib/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showifstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showipstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/lib/libnetworking/rtems/rtems_showroute.c (added) * c/src/lib/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/lib/libnetworking/rtems/rtems_syscall.c (added) * c/src/lib/libnetworking/rtems/sghostname.c (added) * c/src/lib/libnetworking/rtems/tftp.h (added) * c/src/lib/libnetworking/sys/buf.h (added) * c/src/lib/libnetworking/sys/callout.h (added) * c/src/lib/libnetworking/sys/cdefs.h (added) * c/src/lib/libnetworking/sys/conf.h (added) * c/src/lib/libnetworking/sys/domain.h (added) * c/src/lib/libnetworking/sys/filio.h (added) * c/src/lib/libnetworking/sys/ioccom.h (added) * c/src/lib/libnetworking/sys/ioctl.h (added) * c/src/lib/libnetworking/sys/kernel.h (added) * c/src/lib/libnetworking/sys/libkern.h (added) * c/src/lib/libnetworking/sys/malloc.h (added) * c/src/lib/libnetworking/sys/mbuf.h (added) * c/src/lib/libnetworking/sys/mount.h (added) * c/src/lib/libnetworking/sys/param.h (added) * c/src/lib/libnetworking/sys/proc.h (added) * c/src/lib/libnetworking/sys/protosw.h (added) * c/src/lib/libnetworking/sys/queue.h (added) * c/src/lib/libnetworking/sys/reboot.h (added) * c/src/lib/libnetworking/sys/resourcevar.h (added) * c/src/lib/libnetworking/sys/rtprio.h (added) * c/src/lib/libnetworking/sys/select.h (added) * c/src/lib/libnetworking/sys/signalvar.h (added) * c/src/lib/libnetworking/sys/socket.h (added) * c/src/lib/libnetworking/sys/socketvar.h (added) * c/src/lib/libnetworking/sys/sockio.h (added) * c/src/lib/libnetworking/sys/sysctl.h (added) * c/src/lib/libnetworking/sys/syslimits.h (added) * c/src/lib/libnetworking/sys/syslog.h (added) * c/src/lib/libnetworking/sys/systm.h (added) * c/src/lib/libnetworking/sys/ttycom.h (added) * c/src/lib/libnetworking/sys/ttydefaults.h (added) * c/src/lib/libnetworking/sys/ucred.h (added) * c/src/lib/libnetworking/sys/uio.h (added) * c/src/lib/libnetworking/syslog.h (added) * c/src/lib/libnetworking/vm/vm.h (added) * c/src/lib/libnetworking/vm/vm_extern.h (added) * c/src/lib/libnetworking/vm/vm_kern.h (added) * c/src/lib/libnetworking/vm/vm_param.h (added) * c/src/libnetworking/CHANGELOG (added) * c/src/libnetworking/README (added) * c/src/libnetworking/arpa/ftp.h (added) * c/src/libnetworking/arpa/inet.h (added) * c/src/libnetworking/arpa/nameser.h (added) * c/src/libnetworking/arpa/nameser_compat.h (added) * c/src/libnetworking/arpa/telnet.h (added) * c/src/libnetworking/bpfilter.h (added) * c/src/libnetworking/kern/kern_subr.c (added) * c/src/libnetworking/kern/uipc_domain.c (added) * c/src/libnetworking/kern/uipc_mbuf.c (added) * c/src/libnetworking/kern/uipc_socket.c (added) * c/src/libnetworking/kern/uipc_socket2.c (added) * c/src/libnetworking/lib/README (added) * c/src/libnetworking/lib/getprotoby.c (added) * c/src/libnetworking/lib/syslog.c (added) * c/src/libnetworking/lib/tftpDriver.c (added) * c/src/libnetworking/libc/addr2ascii.3 (added) * c/src/libnetworking/libc/addr2ascii.c (added) * c/src/libnetworking/libc/ascii2addr.c (added) * c/src/libnetworking/libc/base64.c (added) * c/src/libnetworking/libc/byteorder.3 (added) * c/src/libnetworking/libc/ether_addr.c (added) * c/src/libnetworking/libc/ethers.3 (added) * c/src/libnetworking/libc/gethostbydns.c (added) * c/src/libnetworking/libc/gethostbyht.c (added) * c/src/libnetworking/libc/gethostbyname.3 (added) * c/src/libnetworking/libc/gethostbynis.c (added) * c/src/libnetworking/libc/gethostnamadr.c (added) * c/src/libnetworking/libc/gethostname.c (added) * c/src/libnetworking/libc/getnetbydns.c (added) * c/src/libnetworking/libc/getnetbyht.c (added) * c/src/libnetworking/libc/getnetbynis.c (added) * c/src/libnetworking/libc/getnetent.3 (added) * c/src/libnetworking/libc/getnetnamadr.c (added) * c/src/libnetworking/libc/getproto.c (added) * c/src/libnetworking/libc/getprotoent.3 (added) * c/src/libnetworking/libc/getprotoent.c (added) * c/src/libnetworking/libc/getprotoname.c (added) * c/src/libnetworking/libc/getservbyname.c (added) * c/src/libnetworking/libc/getservbyport.c (added) * c/src/libnetworking/libc/getservent.3 (added) * c/src/libnetworking/libc/getservent.c (added) * c/src/libnetworking/libc/herror.c (added) * c/src/libnetworking/libc/inet.3 (added) * c/src/libnetworking/libc/inet_addr.c (added) * c/src/libnetworking/libc/inet_lnaof.c (added) * c/src/libnetworking/libc/inet_makeaddr.c (added) * c/src/libnetworking/libc/inet_net_ntop.c (added) * c/src/libnetworking/libc/inet_net_pton.c (added) * c/src/libnetworking/libc/inet_neta.c (added) * c/src/libnetworking/libc/inet_netof.c (added) * c/src/libnetworking/libc/inet_network.c (added) * c/src/libnetworking/libc/inet_ntoa.c (added) * c/src/libnetworking/libc/inet_ntop.c (added) * c/src/libnetworking/libc/inet_pton.c (added) * c/src/libnetworking/libc/iso_addr.3 (added) * c/src/libnetworking/libc/iso_addr.c (added) * c/src/libnetworking/libc/linkaddr.3 (added) * c/src/libnetworking/libc/linkaddr.c (added) * c/src/libnetworking/libc/map_v4v6.c (added) * c/src/libnetworking/libc/ns.3 (added) * c/src/libnetworking/libc/ns_addr.c (added) * c/src/libnetworking/libc/ns_name.c (added) * c/src/libnetworking/libc/ns_netint.c (added) * c/src/libnetworking/libc/ns_ntoa.c (added) * c/src/libnetworking/libc/ns_parse.c (added) * c/src/libnetworking/libc/ns_print.c (added) * c/src/libnetworking/libc/ns_ttl.c (added) * c/src/libnetworking/libc/nsap_addr.c (added) * c/src/libnetworking/libc/rcmd.3 (added) * c/src/libnetworking/libc/rcmd.c (added) * c/src/libnetworking/libc/recv.c (added) * c/src/libnetworking/libc/res_comp.c (added) * c/src/libnetworking/libc/res_config.h (added) * c/src/libnetworking/libc/res_data.c (added) * c/src/libnetworking/libc/res_debug.c (added) * c/src/libnetworking/libc/res_init.c (added) * c/src/libnetworking/libc/res_mkquery.c (added) * c/src/libnetworking/libc/res_mkupdate.c (added) * c/src/libnetworking/libc/res_query.c (added) * c/src/libnetworking/libc/res_send.c (added) * c/src/libnetworking/libc/res_stubs.c (added) * c/src/libnetworking/libc/res_update.c (added) * c/src/libnetworking/libc/resolver.3 (added) * c/src/libnetworking/libc/send.c (added) * c/src/libnetworking/libc/strsep.c (added) * c/src/libnetworking/loop.h (added) * c/src/libnetworking/net/bpf.h (added) * c/src/libnetworking/net/ethernet.h (added) * c/src/libnetworking/net/if.c (added) * c/src/libnetworking/net/if.h (added) * c/src/libnetworking/net/if_arp.h (added) * c/src/libnetworking/net/if_dl.h (added) * c/src/libnetworking/net/if_ethersubr.c (added) * c/src/libnetworking/net/if_llc.h (added) * c/src/libnetworking/net/if_loop.c (added) * c/src/libnetworking/net/if_types.h (added) * c/src/libnetworking/net/netisr.h (added) * c/src/libnetworking/net/radix.c (added) * c/src/libnetworking/net/radix.h (added) * c/src/libnetworking/net/raw_cb.c (added) * c/src/libnetworking/net/raw_cb.h (added) * c/src/libnetworking/net/raw_usrreq.c (added) * c/src/libnetworking/net/route.c (added) * c/src/libnetworking/net/route.h (added) * c/src/libnetworking/net/rtsock.c (added) * c/src/libnetworking/netdb.h (added) * c/src/libnetworking/netinet/icmp_var.h (added) * c/src/libnetworking/netinet/if_ether.c (added) * c/src/libnetworking/netinet/if_ether.h (added) * c/src/libnetworking/netinet/igmp.c (added) * c/src/libnetworking/netinet/igmp.h (added) * c/src/libnetworking/netinet/igmp_var.h (added) * c/src/libnetworking/netinet/in.c (added) * c/src/libnetworking/netinet/in.h (added) * c/src/libnetworking/netinet/in_cksum.c (added) * c/src/libnetworking/netinet/in_pcb.c (added) * c/src/libnetworking/netinet/in_pcb.h (added) * c/src/libnetworking/netinet/in_proto.c (added) * c/src/libnetworking/netinet/in_rmx.c (added) * c/src/libnetworking/netinet/in_systm.h (added) * c/src/libnetworking/netinet/in_var.h (added) * c/src/libnetworking/netinet/ip.h (added) * c/src/libnetworking/netinet/ip_divert.c (added) * c/src/libnetworking/netinet/ip_fw.c (added) * c/src/libnetworking/netinet/ip_fw.h (added) * c/src/libnetworking/netinet/ip_icmp.c (added) * c/src/libnetworking/netinet/ip_icmp.h (added) * c/src/libnetworking/netinet/ip_input.c (added) * c/src/libnetworking/netinet/ip_mroute.c (added) * c/src/libnetworking/netinet/ip_mroute.h (added) * c/src/libnetworking/netinet/ip_output.c (added) * c/src/libnetworking/netinet/ip_var.h (added) * c/src/libnetworking/netinet/raw_ip.c (added) * c/src/libnetworking/netinet/tcp.h (added) * c/src/libnetworking/netinet/tcp_debug.c (added) * c/src/libnetworking/netinet/tcp_debug.h (added) * c/src/libnetworking/netinet/tcp_fsm.h (added) * c/src/libnetworking/netinet/tcp_input.c (added) * c/src/libnetworking/netinet/tcp_output.c (added) * c/src/libnetworking/netinet/tcp_seq.h (added) * c/src/libnetworking/netinet/tcp_subr.c (added) * c/src/libnetworking/netinet/tcp_timer.c (added) * c/src/libnetworking/netinet/tcp_timer.h (added) * c/src/libnetworking/netinet/tcp_usrreq.c (added) * c/src/libnetworking/netinet/tcp_var.h (added) * c/src/libnetworking/netinet/tcpip.h (added) * c/src/libnetworking/netinet/udp.h (added) * c/src/libnetworking/netinet/udp_usrreq.c (added) * c/src/libnetworking/netinet/udp_var.h (added) * c/src/libnetworking/nfs/bootp_subr.c (added) * c/src/libnetworking/nfs/krpc.h (added) * c/src/libnetworking/nfs/nfs.h (added) * c/src/libnetworking/nfs/nfsdiskless.h (added) * c/src/libnetworking/nfs/nfsproto.h (added) * c/src/libnetworking/nfs/rpcv2.h (added) * c/src/libnetworking/nfs/xdr_subs.h (added) * c/src/libnetworking/opt_ipfw.h (added) * c/src/libnetworking/opt_mrouting.h (added) * c/src/libnetworking/opt_tcpdebug.h (added) * c/src/libnetworking/poll.h (added) * c/src/libnetworking/resolv.h (added) * c/src/libnetworking/rtems/issetugid.c (added) * c/src/libnetworking/rtems/rtems_bootp.c (added) * c/src/libnetworking/rtems/rtems_bsdnet.h (added) * c/src/libnetworking/rtems/rtems_bsdnet_internal.h (added) * c/src/libnetworking/rtems/rtems_glue.c (added) * c/src/libnetworking/rtems/rtems_showicmpstat.c (added) * c/src/libnetworking/rtems/rtems_showifstat.c (added) * c/src/libnetworking/rtems/rtems_showipstat.c (added) * c/src/libnetworking/rtems/rtems_showmbuf.c (added) * c/src/libnetworking/rtems/rtems_showroute.c (added) * c/src/libnetworking/rtems/rtems_showtcpstat.c (added) * c/src/libnetworking/rtems/rtems_showudpstat.c (added) * c/src/libnetworking/rtems/rtems_syscall.c (added) * c/src/libnetworking/rtems/sghostname.c (added) * c/src/libnetworking/rtems/tftp.h (added) * c/src/libnetworking/sys/buf.h (added) * c/src/libnetworking/sys/callout.h (added) * c/src/libnetworking/sys/cdefs.h (added) * c/src/libnetworking/sys/conf.h (added) * c/src/libnetworking/sys/domain.h (added) * c/src/libnetworking/sys/filio.h (added) * c/src/libnetworking/sys/ioccom.h (added) * c/src/libnetworking/sys/ioctl.h (added) * c/src/libnetworking/sys/kernel.h (added) * c/src/libnetworking/sys/libkern.h (added) * c/src/libnetworking/sys/malloc.h (added) * c/src/libnetworking/sys/mbuf.h (added) * c/src/libnetworking/sys/mount.h (added) * c/src/libnetworking/sys/param.h (added) * c/src/libnetworking/sys/proc.h (added) * c/src/libnetworking/sys/protosw.h (added) * c/src/libnetworking/sys/queue.h (added) * c/src/libnetworking/sys/reboot.h (added) * c/src/libnetworking/sys/resourcevar.h (added) * c/src/libnetworking/sys/rtprio.h (added) * c/src/libnetworking/sys/select.h (added) * c/src/libnetworking/sys/signalvar.h (added) * c/src/libnetworking/sys/socket.h (added) * c/src/libnetworking/sys/socketvar.h (added) * c/src/libnetworking/sys/sockio.h (added) * c/src/libnetworking/sys/sysctl.h (added) * c/src/libnetworking/sys/syslimits.h (added) * c/src/libnetworking/sys/syslog.h (added) * c/src/libnetworking/sys/systm.h (added) * c/src/libnetworking/sys/ttycom.h (added) * c/src/libnetworking/sys/ttydefaults.h (added) * c/src/libnetworking/sys/ucred.h (added) * c/src/libnetworking/sys/uio.h (added) * c/src/libnetworking/syslog.h (added) * c/src/libnetworking/vm/vm.h (added) * c/src/libnetworking/vm/vm_extern.h (added) * c/src/libnetworking/vm/vm_kern.h (added) * c/src/libnetworking/vm/vm_param.h (added) * cpukit/libcsupport/include/sys/filio.h (added) * cpukit/libcsupport/include/sys/ioctl.h (added) * cpukit/libcsupport/include/sys/sockio.h (added) * cpukit/libnetworking/README (added) * cpukit/libnetworking/arpa/ftp.h (added) * cpukit/libnetworking/arpa/inet.h (added) * cpukit/libnetworking/arpa/nameser.h (added) * cpukit/libnetworking/arpa/nameser_compat.h (added) * cpukit/libnetworking/arpa/telnet.h (added) * cpukit/libnetworking/bpfilter.h (added) * cpukit/libnetworking/kern/kern_subr.c (added) * cpukit/libnetworking/kern/uipc_domain.c (added) * cpukit/libnetworking/kern/uipc_mbuf.c (added) * cpukit/libnetworking/kern/uipc_socket.c (added) * cpukit/libnetworking/kern/uipc_socket2.c (added) * cpukit/libnetworking/lib/README (added) * cpukit/libnetworking/lib/getprotoby.c (added) * cpukit/libnetworking/lib/syslog.c (added) * cpukit/libnetworking/lib/tftpDriver.c (added) * cpukit/libnetworking/libc/addr2ascii.3 (added) * cpukit/libnetworking/libc/addr2ascii.c (added) * cpukit/libnetworking/libc/ascii2addr.c (added) * cpukit/libnetworking/libc/base64.c (added) * cpukit/libnetworking/libc/byteorder.3 (added) * cpukit/libnetworking/libc/ether_addr.c (added) * cpukit/libnetworking/libc/ethers.3 (added) * cpukit/libnetworking/libc/gethostbydns.c (added) * cpukit/libnetworking/libc/gethostbyht.c (added) * cpukit/libnetworking/libc/gethostbyname.3 (added) * cpukit/libnetworking/libc/gethostbynis.c (added) * cpukit/libnetworking/libc/gethostnamadr.c (added) * cpukit/libnetworking/libc/gethostname.c (added) * cpukit/libnetworking/libc/getnetbydns.c (added) * cpukit/libnetworking/libc/getnetbyht.c (added) * cpukit/libnetworking/libc/getnetbynis.c (added) * cpukit/libnetworking/libc/getnetent.3 (added) * cpukit/libnetworking/libc/getnetnamadr.c (added) * cpukit/libnetworking/libc/getproto.c (added) * cpukit/libnetworking/libc/getprotoent.3 (added) * cpukit/libnetworking/libc/getprotoent.c (added) * cpukit/libnetworking/libc/getprotoname.c (added) * cpukit/libnetworking/libc/getservbyname.c (added) * cpukit/libnetworking/libc/getservbyport.c (added) * cpukit/libnetworking/libc/getservent.3 (added) * cpukit/libnetworking/libc/getservent.c (added) * cpukit/libnetworking/libc/herror.c (added) * cpukit/libnetworking/libc/inet.3 (added) * cpukit/libnetworking/libc/inet_addr.c (added) * cpukit/libnetworking/libc/inet_lnaof.c (added) * cpukit/libnetworking/libc/inet_makeaddr.c (added) * cpukit/libnetworking/libc/inet_net_ntop.c (added) * cpukit/libnetworking/libc/inet_net_pton.c (added) * cpukit/libnetworking/libc/inet_neta.c (added) * cpukit/libnetworking/libc/inet_netof.c (added) * cpukit/libnetworking/libc/inet_network.c (added) * cpukit/libnetworking/libc/inet_ntoa.c (added) * cpukit/libnetworking/libc/inet_ntop.c (added) * cpukit/libnetworking/libc/inet_pton.c (added) * cpukit/libnetworking/libc/iso_addr.3 (added) * cpukit/libnetworking/libc/iso_addr.c (added) * cpukit/libnetworking/libc/linkaddr.3 (added) * cpukit/libnetworking/libc/linkaddr.c (added) * cpukit/libnetworking/libc/map_v4v6.c (added) * cpukit/libnetworking/libc/ns.3 (added) * cpukit/libnetworking/libc/ns_addr.c (added) * cpukit/libnetworking/libc/ns_name.c (added) * cpukit/libnetworking/libc/ns_netint.c (added) * cpukit/libnetworking/libc/ns_ntoa.c (added) * cpukit/libnetworking/libc/ns_parse.c (added) * cpukit/libnetworking/libc/ns_print.c (added) * cpukit/libnetworking/libc/ns_ttl.c (added) * cpukit/libnetworking/libc/nsap_addr.c (added) * cpukit/libnetworking/libc/rcmd.3 (added) * cpukit/libnetworking/libc/rcmd.c (added) * cpukit/libnetworking/libc/recv.c (added) * cpukit/libnetworking/libc/res_comp.c (added) * cpukit/libnetworking/libc/res_config.h (added) * cpukit/libnetworking/libc/res_data.c (added) * cpukit/libnetworking/libc/res_debug.c (added) * cpukit/libnetworking/libc/res_init.c (added) * cpukit/libnetworking/libc/res_mkquery.c (added) * cpukit/libnetworking/libc/res_mkupdate.c (added) * cpukit/libnetworking/libc/res_query.c (added) * cpukit/libnetworking/libc/res_send.c (added) * cpukit/libnetworking/libc/res_stubs.c (added) * cpukit/libnetworking/libc/res_update.c (added) * cpukit/libnetworking/libc/resolver.3 (added) * cpukit/libnetworking/libc/send.c (added) * cpukit/libnetworking/libc/strsep.c (added) * cpukit/libnetworking/loop.h (added) * cpukit/libnetworking/net/bpf.h (added) * cpukit/libnetworking/net/ethernet.h (added) * cpukit/libnetworking/net/if.c (added) * cpukit/libnetworking/net/if.h (added) * cpukit/libnetworking/net/if_arp.h (added) * cpukit/libnetworking/net/if_dl.h (added) * cpukit/libnetworking/net/if_ethersubr.c (added) * cpukit/libnetworking/net/if_llc.h (added) * cpukit/libnetworking/net/if_loop.c (added) * cpukit/libnetworking/net/if_types.h (added) * cpukit/libnetworking/net/netisr.h (added) * cpukit/libnetworking/net/radix.c (added) * cpukit/libnetworking/net/radix.h (added) * cpukit/libnetworking/net/raw_cb.c (added) * cpukit/libnetworking/net/raw_cb.h (added) * cpukit/libnetworking/net/raw_usrreq.c (added) * cpukit/libnetworking/net/route.c (added) * cpukit/libnetworking/net/route.h (added) * cpukit/libnetworking/net/rtsock.c (added) * cpukit/libnetworking/netdb.h (added) * cpukit/libnetworking/netinet/icmp_var.h (added) * cpukit/libnetworking/netinet/if_ether.c (added) * cpukit/libnetworking/netinet/if_ether.h (added) * cpukit/libnetworking/netinet/igmp.c (added) * cpukit/libnetworking/netinet/igmp.h (added) * cpukit/libnetworking/netinet/igmp_var.h (added) * cpukit/libnetworking/netinet/in.c (added) * cpukit/libnetworking/netinet/in.h (added) * cpukit/libnetworking/netinet/in_cksum.c (added) * cpukit/libnetworking/netinet/in_pcb.c (added) * cpukit/libnetworking/netinet/in_pcb.h (added) * cpukit/libnetworking/netinet/in_proto.c (added) * cpukit/libnetworking/netinet/in_rmx.c (added) * cpukit/libnetworking/netinet/in_systm.h (added) * cpukit/libnetworking/netinet/in_var.h (added) * cpukit/libnetworking/netinet/ip.h (added) * cpukit/libnetworking/netinet/ip_divert.c (added) * cpukit/libnetworking/netinet/ip_fw.c (added) * cpukit/libnetworking/netinet/ip_fw.h (added) * cpukit/libnetworking/netinet/ip_icmp.c (added) * cpukit/libnetworking/netinet/ip_icmp.h (added) * cpukit/libnetworking/netinet/ip_input.c (added) * cpukit/libnetworking/netinet/ip_mroute.c (added) * cpukit/libnetworking/netinet/ip_mroute.h (added) * cpukit/libnetworking/netinet/ip_output.c (added) * cpukit/libnetworking/netinet/ip_var.h (added) * cpukit/libnetworking/netinet/raw_ip.c (added) * cpukit/libnetworking/netinet/tcp.h (added) * cpukit/libnetworking/netinet/tcp_debug.c (added) * cpukit/libnetworking/netinet/tcp_debug.h (added) * cpukit/libnetworking/netinet/tcp_fsm.h (added) * cpukit/libnetworking/netinet/tcp_input.c (added) * cpukit/libnetworking/netinet/tcp_output.c (added) * cpukit/libnetworking/netinet/tcp_seq.h (added) * cpukit/libnetworking/netinet/tcp_subr.c (added) * cpukit/libnetworking/netinet/tcp_timer.c (added) * cpukit/libnetworking/netinet/tcp_timer.h (added) * cpukit/libnetworking/netinet/tcp_usrreq.c (added) * cpukit/libnetworking/netinet/tcp_var.h (added) * cpukit/libnetworking/netinet/tcpip.h (added) * cpukit/libnetworking/netinet/udp.h (added) * cpukit/libnetworking/netinet/udp_usrreq.c (added) * cpukit/libnetworking/netinet/udp_var.h (added) * cpukit/libnetworking/nfs/bootp_subr.c (added) * cpukit/libnetworking/nfs/krpc.h (added) * cpukit/libnetworking/nfs/nfs.h (added) * cpukit/libnetworking/nfs/nfsdiskless.h (added) * cpukit/libnetworking/nfs/nfsproto.h (added) * cpukit/libnetworking/nfs/rpcv2.h (added) * cpukit/libnetworking/nfs/xdr_subs.h (added) * cpukit/libnetworking/opt_ipfw.h (added) * cpukit/libnetworking/opt_mrouting.h (added) * cpukit/libnetworking/opt_tcpdebug.h (added) * cpukit/libnetworking/poll.h (added) * cpukit/libnetworking/resolv.h (added) * cpukit/libnetworking/rtems/issetugid.c (added) * cpukit/libnetworking/rtems/rtems_bootp.c (added) * cpukit/libnetworking/rtems/rtems_bsdnet.h (added) * cpukit/libnetworking/rtems/rtems_bsdnet_internal.h (added) * cpukit/libnetworking/rtems/rtems_glue.c (added) * cpukit/libnetworking/rtems/rtems_showicmpstat.c (added) * cpukit/libnetworking/rtems/rtems_showifstat.c (added) * cpukit/libnetworking/rtems/rtems_showipstat.c (added) * cpukit/libnetworking/rtems/rtems_showmbuf.c (added) * cpukit/libnetworking/rtems/rtems_showroute.c (added) * cpukit/libnetworking/rtems/rtems_showtcpstat.c (added) * cpukit/libnetworking/rtems/rtems_showudpstat.c (added) * cpukit/libnetworking/rtems/rtems_syscall.c (added) * cpukit/libnetworking/rtems/sghostname.c (added) * cpukit/libnetworking/rtems/tftp.h (added) * cpukit/libnetworking/sys/buf.h (added) * cpukit/libnetworking/sys/callout.h (added) * cpukit/libnetworking/sys/conf.h (added) * cpukit/libnetworking/sys/domain.h (added) * cpukit/libnetworking/sys/kernel.h (added) * cpukit/libnetworking/sys/libkern.h (added) * cpukit/libnetworking/sys/malloc.h (added) * cpukit/libnetworking/sys/mbuf.h (added) * cpukit/libnetworking/sys/mount.h (added) * cpukit/libnetworking/sys/param.h (added) * cpukit/libnetworking/sys/proc.h (added) * cpukit/libnetworking/sys/protosw.h (added) * cpukit/libnetworking/sys/queue.h (added) * cpukit/libnetworking/sys/reboot.h (added) * cpukit/libnetworking/sys/resourcevar.h (added) * cpukit/libnetworking/sys/rtprio.h (added) * cpukit/libnetworking/sys/select.h (added) * cpukit/libnetworking/sys/signalvar.h (added) * cpukit/libnetworking/sys/socket.h (added) * cpukit/libnetworking/sys/socketvar.h (added) * cpukit/libnetworking/sys/sysctl.h (added) * cpukit/libnetworking/sys/syslimits.h (added) * cpukit/libnetworking/sys/syslog.h (added) * cpukit/libnetworking/sys/systm.h (added) * cpukit/libnetworking/sys/ttydefaults.h (added) * cpukit/libnetworking/sys/ucred.h (added) * cpukit/libnetworking/sys/uio.h (added) * cpukit/libnetworking/syslog.h (added) * cpukit/libnetworking/vm/vm.h (added) * cpukit/libnetworking/vm/vm_extern.h (added) * cpukit/libnetworking/vm/vm_kern.h (added) * cpukit/libnetworking/vm/vm_param.h (added) Base files Wed, 19 Aug 1998 20:25:21 GMT Joel Sherrill [26b5c77f] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980819 Wed, 19 Aug 1998 20:09:59 GMT Joel Sherrill [8b2ee37c] * c/src/exec/score/cpu/i386/cpu.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq.c (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.s (modified) * cpukit/score/cpu/i386/cpu.c (modified) Patch from Eric Valette : - Use the ... Wed, 19 Aug 1998 20:02:10 GMT Joel Sherrill [7549e14] * c/src/exec/score/tools/unix/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) Fixed obsolete reference to BSDINSTALL. Wed, 19 Aug 1998 12:56:20 GMT Joel Sherrill [06fa582] * aclocal.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * c/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/update-tools/Makefile.in (modified) * configure (modified) * make/host.cfg.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/update/Makefile.in (modified) Patches from Ralf Corsepius and myself to ... Wed, 19 Aug 1998 12:41:22 GMT Joel Sherrill [f2226f44] * c/src/exec/score/cpu/m68k/m68k.h (modified) Added 68060 definition from Chris Johns. Thu, 13 Aug 1998 22:03:14 GMT Joel Sherrill [43abd4d] * c/src/exec/score/tools/unix/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) Fixed preinstall stanza so the prebuild works. Thu, 13 Aug 1998 14:23:37 GMT Joel Sherrill [26e5cd4] * c/src/exec/score/cpu/m68k/m68k.h (modified) Patch from Chris Johns . Comments follow: Here is ... Sat, 08 Aug 1998 16:51:16 GMT Joel Sherrill [18c2320] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 980808 Sat, 08 Aug 1998 16:26:35 GMT Joel Sherrill [7e2187f4] * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) changed version to 9800808 Wed, 05 Aug 1998 16:51:39 GMT Joel Sherrill [bd8c8b2a] * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/exec/score/cpu/i386/i386.h (modified) * c/src/lib/libbsp/i386/i386ex/clock/ckinit.c (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/start/start.s (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timer.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.s (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (added) * c/src/lib/libbsp/i386/shared/io/bspIo.h (added) * c/src/lib/libbsp/i386/shared/io/printk.c (added) * c/src/lib/libbsp/i386/shared/irq/irq.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_init.c (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/cpuModel.h (modified) * c/src/lib/libcpu/i386/displayCpu.c (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) Patch from Eric Valette which brings the ... Wed, 05 Aug 1998 15:15:46 GMT Joel Sherrill [ab0df696] * c/src/exec/score/cpu/i386/asm.h (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/bsp.h (modified) * c/src/lib/libbsp/i386/force386/startup/setvec.c (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/startup/setvec.c (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/cpuModel.S (added) * c/src/lib/libcpu/i386/cpuModel.h (added) * c/src/lib/libcpu/i386/displayCpu.c (added) * c/src/lib/libcpu/i386/registers.h (added) * cpukit/score/cpu/i386/asm.h (modified) * cpukit/score/cpu/i386/rtems/asm.h (modified) Automatic CPU type detection code from Eric Valette ... Wed, 05 Aug 1998 15:11:33 GMT Joel Sherrill [4d11a92f] * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) Redid Makefiles to properly do a preinstall. There was remnants of ... Sat, 01 Aug 1998 14:40:51 GMT Joel Sherrill [5ef4fae] * c/src/exec/score/cpu/m68k/asm.h (modified) * c/src/exec/score/cpu/m68k/rtems.s (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) Merged patch from David Fiddes to add ColdFire ... Thu, 30 Jul 1998 18:06:51 GMT Joel Sherrill [41d07439] * c/src/exec/score/cpu/i386/Makefile.in (modified) Patch from Eric Valette : Now that Joel ... Tue, 28 Jul 1998 16:49:36 GMT Joel Sherrill [bd7c547] * c/src/exec/libcsupport/src/termios.c (modified) * c/src/lib/libc/termios.c (modified) * cpukit/libcsupport/src/termios.c (modified) Closed window thanks to patch from Eric Norum.
