@bc85fd5a
07/11/00 19:31:04 |
Joel Sherrill |
Reworked score/cpu/i960 so it can be safely compiled multilib. All …
4.104.114.84.95
@270e3cc
07/11/00 14:56:04 |
Joel Sherrill |
Patch rtems-rc-20000711-1-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@256cbec
07/10/00 19:12:07 |
Joel Sherrill |
Patch rtems-rc-20000708-1.diff from Ralf Corsepius …
4.104.114.84.95
@80e5391
07/07/00 19:36:14 |
Joel Sherrill |
Moved old_exception_processing and new_exception_processing …
4.104.114.84.95
@04e6f7bf
07/06/00 20:13:35 |
Joel Sherrill |
Patch rtems-rc-20000705-3.diff from Ralf Corsepius …
4.104.114.84.95
@8bc62aeb
07/03/00 18:44:12 |
Joel Sherrill |
Interrupt stack is allocated in _ISR_Handler_initialization not …
4.104.114.84.95
@feb93ede
07/03/00 15:49:35 |
Joel Sherrill |
Changed extra_system_initialization_stack to …
4.104.114.84.95
@5532553
06/29/00 23:00:48 |
Joel Sherrill |
This is the initial addition of the port of RTEMS to the
Hitachi H8 …
4.104.114.84.95
@d1716c98
06/15/00 22:02:28 |
Joel Sherrill |
Remove pragma align 4
4.104.114.84.95
@2b409223
06/15/00 13:06:36 |
Joel Sherrill |
Patch rtems-rc-20000615-1-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@ac815430
06/14/00 17:07:54 |
Joel Sherrill |
Patch rtems-rc-20000614-sh.tar.gz from Ralf Corsepius …
4.104.114.84.95
@61bd0301
06/14/00 15:52:24 |
Joel Sherrill |
Moved PowerPC cache management code to libcpu. Also compiled
mpc8xx …
4.104.114.84.95
@afd63b7
06/13/00 22:57:19 |
Joel Sherrill |
Added crude i960ka support.
4.104.114.84.95
@cf1f72e
06/13/00 21:53:38 |
Joel Sherrill |
Moved i386 and m68k cache management code to libcpu. Everything
now …
4.104.114.84.95
@3ab61f0
06/12/00 21:34:51 |
Joel Sherrill |
Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier …
4.104.114.84.95
@edc61d4
06/12/00 20:27:50 |
Joel Sherrill |
Fixed so hppa1.1 compiles with only problems in simhppa BSP.
4.104.114.84.95
@8ef3818
06/12/00 19:57:02 |
Joel Sherrill |
4.104.114.84.95
@ce5b291f
06/12/00 18:45:54 |
Joel Sherrill |
Works on Solaris and Linux.
4.104.114.84.95
@df49c60
06/12/00 15:00:15 |
Joel Sherrill |
Merged from 4.5.0-beta3a
4.104.114.84.95
@e4c07444
04/13/00 14:47:15 |
Joel Sherrill |
Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius …
4.104.114.84.95
@bf85b19
04/13/00 14:37:14 |
Joel Sherrill |
4.104.114.84.95
@b6f9b5f1
03/01/00 18:08:53 |
Joel Sherrill |
Added routines to get and set C3x IOF register. The code is …
4.104.114.84.95
@8eacefcc
02/29/00 16:35:45 |
Joel Sherrill |
BSP now compiles and links with CAVSL board information. This …
4.104.114.84.95
@61ba9763
02/22/00 18:39:52 |
Joel Sherrill |
New port of RTEMS to TI C3x and C4x.
4.104.114.84.95
@70810dc
02/08/00 22:33:25 |
Joel Sherrill |
Patches rtems-rc-20000204-0.diff from Ralf Corsepius …
4.104.114.84.95
@4e36a2f
01/31/00 15:27:02 |
Joel Sherrill |
Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from …
4.104.114.84.95
@4c46630
01/31/00 15:15:10 |
Joel Sherrill |
Patch rtems-rc-20000118-1.diff from Ralf Corsepius …
4.104.114.84.95
@318f591
01/27/00 14:37:17 |
Joel Sherrill |
Added after report from Quality Quorum <qqi@…> that …
4.104.114.84.95
@f13b1c4
01/23/00 18:22:02 |
Joel Sherrill |
Removing unused file accidentally left in CVS. Discovered by
Ralf …
4.104.114.84.95
@752badac
01/14/00 14:55:37 |
Joel Sherrill |
Removed warning.
4.104.114.84.95
@0312d81f
01/05/00 23:01:05 |
Joel Sherrill |
Fixed comment thanks to John M. Mills <jmills@…>.
4.104.114.84.95
@1dfc188e
01/04/00 13:58:47 |
Joel Sherrill |
Removed unitialized variable warning.
4.104.114.84.95
@e065e8ae
01/03/00 16:52:50 |
Joel Sherrill |
Increased stack size to 4K per Eric Norum.
4.104.114.84.95
@20385957
01/03/00 14:01:02 |
Joel Sherrill |
Increased minimum stack size so all tests will run.
4.104.114.84.95
@ed46b47
12/21/99 20:29:40 |
Joel Sherrill |
Moved PPC_Set_decrementer() and PPC_Get_timebase_register() to …
4.104.114.84.95
@8b91282
12/21/99 14:27:52 |
Joel Sherrill |
Patch rtems-rc-19991203-5.diff from Ralf Corsepius …
4.104.114.84.95
@f9669ce5
12/13/99 20:06:27 |
Joel Sherrill |
Patch from Silverio Diquigiovanni <silverio.di@…> to correct
TPC …
4.104.114.84.95
@6b79a071
12/13/99 17:22:18 |
Joel Sherrill |
Patch from Jepsen Hans Peter <hans_peter_jepsen@…> to
use …
4.104.114.84.95
@fc81cc9
12/03/99 13:31:56 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius …
4.104.114.84.95
@4090ebe
12/03/99 13:25:00 |
Joel Sherrill |
4.104.114.84.95
@43283456
12/02/99 17:45:14 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius …
4.104.114.84.95
@acc25ee
12/02/99 14:31:19 |
Joel Sherrill |
Merged of mcp750 and mvme2307 BSP by Eric Valette …
4.104.114.84.95
@4cf56006
12/02/99 14:10:14 |
Joel Sherrill |
4.104.114.84.95
@e4ab88f
12/02/99 14:00:01 |
Joel Sherrill |
4.104.114.84.95
@5554279
12/02/99 13:54:30 |
Joel Sherrill |
4.104.114.84.95
@955a9ba7
12/01/99 15:05:26 |
Joel Sherrill |
4.104.114.84.95
@1972b1e
12/01/99 14:46:02 |
Joel Sherrill |
4.104.114.84.95
@7656140
12/01/99 14:31:36 |
Joel Sherrill |
4.104.114.84.95
@ccf8925b
12/01/99 14:22:12 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius …
4.104.114.84.95
@4a3757f
12/01/99 14:12:58 |
Joel Sherrill |
4.104.114.84.95
@63bdbbd
11/23/99 16:02:26 |
Joel Sherrill |
Readding files mistakenly removed.
4.104.114.84.95
@748cdca9
11/23/99 15:48:26 |
Joel Sherrill |
Readding Makefile.in's accidentally removed.
4.104.114.84.95
@fba12eb6
11/23/99 13:29:04 |
Joel Sherrill |
Patch rtems-rc-19991117-11.diff from Ralf Corsepius …
4.104.114.84.95
@b7912a89
11/22/99 14:25:01 |
Joel Sherrill |
Changed name of W, X, and Y macros for fields in the Clock
Synthesizer …
4.104.114.84.95
@b22a19e
11/22/99 13:46:50 |
Joel Sherrill |
Adding files not added as part of merger of SH2 port.
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@75f2b0b
11/22/99 13:12:48 |
Joel Sherrill |
Small patch (rtems-rc-19991117-5.diff) from Ralf Corsepius …
4.104.114.84.95
@97c465c
11/18/99 21:30:12 |
Joel Sherrill |
Minor cleanup to reduce the code space.
4.104.114.84.95
@4a238002
11/18/99 21:22:58 |
Joel Sherrill |
Patch from "John M. Mills" <jmills@…> with subsequent cleanup …
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@c094542
11/16/99 16:07:17 |
Joel Sherrill |
Only check for System V IPC if multiprocessing is enabled. The unix …
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@458bd34
11/05/99 16:44:02 |
Joel Sherrill |
This is another pass at making sure that nothing outside the BSP …
4.104.114.84.95
@f817b02
11/04/99 18:05:09 |
Joel Sherrill |
The files in libcpu should not be directly dependent on any BSP. In …
4.104.114.84.95
@7046cdd
10/28/99 16:01:41 |
Joel Sherrill |
Patch rtems-rc-19991011-3.diff from Ralf Corsepius.
4.104.114.84.95
@ae7325bd
10/27/99 17:25:53 |
Joel Sherrill |
rxgen960 now compiles -- may not link.
4.104.114.84.95
@702c5f5
10/27/99 15:29:18 |
Joel Sherrill |
The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson …
4.104.114.84.95
@e54a7d33
10/26/99 16:22:55 |
Joel Sherrill |
Patch from Gerwin Pfab <pb@…> to leave dispatching …
4.104.114.84.95
@9a986282
10/26/99 14:39:57 |
Joel Sherrill |
Increased minimum stack size to ensure that there are no problems …
4.104.114.84.95
@1f350ef9
10/06/99 20:54:06 |
Joel Sherrill |
Removed aclocal.m4 generated from aclocal macros
4.104.114.84.95
@54eccb1a
10/06/99 20:52:34 |
Joel Sherrill |
Removed configure generated from configure.in
4.104.114.84.95
@30f7ff9
10/05/99 19:11:57 |
Joel Sherrill |
Removed targets and configurations that are no longer functional
and …
4.104.114.84.95
@4075af6f
10/05/99 13:49:54 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@d83c39dc
10/05/99 13:08:41 |
Joel Sherrill |
Bug report and fix from Jay Kulpinski <jskulpin@…> where …
4.104.114.84.95
@473b4e5
10/04/99 13:30:15 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@a24c280
09/09/99 21:22:36 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Ralf Corsepius …
4.104.114.84.95
@d392168
08/26/99 21:14:20 |
Joel Sherrill |
Typo causing compilation failure spotted by Ralf Corsepius and
fixed …
4.104.114.84.95
@71f16a4
08/19/99 22:07:00 |
Joel Sherrill |
Support for MPC505 from Sergei Organov <osv@…>. His patch was …
4.104.114.84.95
@f2180e0f
08/18/99 20:00:05 |
Joel Sherrill |
Patch from Jimen Ching <jimen@…>:
Please take a look at …
4.104.114.84.95
@e8367362
08/18/99 19:57:40 |
Joel Sherrill |
Slightly cleaner way to switch on the CPU model.
4.104.114.84.95
@ea562ee9
08/12/99 18:22:17 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
After …
4.104.114.84.95
@981b99f
08/10/99 16:41:44 |
Joel Sherrill |
Patch from Eric Valette <valette@…> and Emmanuel Raguet …
4.104.114.84.95
@6805640e
07/29/99 23:01:15 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…>
to …
4.104.114.84.95
@08b5f55
07/26/99 20:31:49 |
Joel Sherrill |
A bug in …
4.104.114.84.95
@6693a68
07/26/99 20:00:37 |
Joel Sherrill |
This is part of a major patch from Ralf Corsepius …
4.104.114.84.95
@b73e57b
07/09/99 17:08:48 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…>:
+ interrupt …
4.104.114.84.95
@64b29600
07/01/99 18:57:15 |
Joel Sherrill |
Removed hack to set USER_LABEL_PREFIX since late model gcc's and …
4.104.114.84.95
@15aa5ffb
06/14/99 18:54:24 |
Joel Sherrill |
Patch ("FIX: no_cpu/no_bsp") from Ralf Corsepius …
4.104.114.84.95
@ba46ffa6
06/14/99 16:51:13 |
Joel Sherrill |
This is a large patch from Eric Valette <valette@…> that …
4.104.114.84.95
@923b45c
06/11/99 14:21:17 |
Joel Sherrill |
Fixed Makefile.in to not attempt to install rtems.o twice from two …
4.104.114.84.95
@8f3c1d20
05/28/99 16:08:18 |
Joel Sherrill |
At the request of Gumby, the cpu is now halted rather than spinning
on …
4.104.114.84.95
@326378bf
05/27/99 15:44:20 |
Joel Sherrill |
Corrected so rtems.o is built and installed on all targets.
4.104.114.84.95
@5a064dca
05/18/99 17:41:16 |
Joel Sherrill |
Patch from Daniel Kelley <dank@…>:
I found a small buglet …
4.104.114.84.95
@0995b6f
05/17/99 23:48:34 |
Joel Sherrill |
Reworked to avoid pulling in the jump point entry in EVERY executable.
4.104.114.84.95
@c2463d9
04/19/99 21:02:31 |
Joel Sherrill |
Intel i960HA support submitted by Jimen Ching <jimen@…> …
4.104.114.84.95
@196094eb
04/19/99 13:19:14 |
Joel Sherrill |
This one is …
4.104.114.84.95
@3084de2
04/07/99 15:57:05 |
Joel Sherrill |
MPC821 support and PPC patches from Andrew Bray …
4.104.114.84.95
@8cc57f6
03/31/99 23:24:51 |
Joel Sherrill |
Modified to be valid m68k code on all CPU models.
4.104.114.84.95
@73b943bc
03/31/99 23:21:19 |
Joel Sherrill |
Fixed paths to include files so this will build.
4.104.114.84.95
