@fd882ee
11/02/99 15:29:47 |
Joel Sherrill |
Now much closer to working.
4.104.114.84.95
@26c828f
11/02/99 15:29:04 |
Joel Sherrill |
Added assert in case _Objects_Get_information fails since this
should …
4.104.114.84.95
@2b95c07
11/02/99 15:28:02 |
Joel Sherrill |
Commented out lines causing warning.
4.104.114.84.95
@733a248
11/02/99 15:27:38 |
Joel Sherrill |
Added #define for SEM_FAILED.
4.104.114.84.95
@9d3a44b
11/02/99 15:27:20 |
Joel Sherrill |
Added include of <sys/siginfo.h>.
4.104.114.84.95
@f2422aa
11/02/99 15:26:46 |
Joel Sherrill |
Added message queues and semaphores.
4.104.114.84.95
@0910a251
11/01/99 20:31:25 |
Joel Sherrill |
Added name to id support routine.
4.104.114.84.95
@89b63972
11/01/99 18:02:44 |
Joel Sherrill |
Removed routines that had already been separated into their own files.
4.104.114.84.95
@b6c868e
10/25/99 16:05:34 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…>
to …
4.104.114.84.95
@812f440
10/21/99 16:38:49 |
Joel Sherrill |
Fixed core dump caused when output parameter (otimer) was NULL.
4.104.114.84.95
@1f350ef9
10/06/99 20:54:06 |
Joel Sherrill |
Removed aclocal.m4 generated from aclocal macros
4.104.114.84.95
@54eccb1a
10/06/99 20:52:34 |
Joel Sherrill |
Removed configure generated from configure.in
4.104.114.84.95
@4075af6f
10/05/99 13:49:54 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@811804fe
10/04/99 19:15:14 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to make fix bug …
4.104.114.84.95
@4f021c0
10/04/99 17:33:23 |
Joel Sherrill |
Removed Makefile.in generated from Makefile.am
4.104.114.84.95
@473b4e5
10/04/99 13:30:15 |
Joel Sherrill |
Regenerated.
4.104.114.84.95
@a24c280
09/09/99 21:22:36 |
Joel Sherrill |
Applied patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@e1d8abb
09/07/99 13:45:03 |
Joel Sherrill |
Ralf Corsepius …
4.104.114.84.95
@c935c5f
09/07/99 12:55:28 |
Joel Sherrill |
Removed by patch rtems-rc-19990820-6.diff.gz from
Ralf Corsepius …
4.104.114.84.95
@260b0c2
08/30/99 18:05:48 |
Joel Sherrill |
Patch from Charles-Antoine Gauthier <charles.gauthier@…> to …
4.104.114.84.95
@1896a650
07/30/99 17:52:50 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
The main topic …
4.104.114.84.95
@08b5f55
07/26/99 20:31:49 |
Joel Sherrill |
A bug in …
4.104.114.84.95
@6693a68
07/26/99 20:00:37 |
Joel Sherrill |
This is part of a major patch from Ralf Corsepius …
4.104.114.84.95
@ed1a0e51
07/01/99 22:57:23 |
Joel Sherrill |
Honor 0 as PID of caller.
4.104.114.84.95
@bb224a97
07/01/99 22:42:11 |
Joel Sherrill |
Added signal_2 file to contain signal(2).
4.104.114.84.95
@51e04a2c
07/01/99 22:28:30 |
Joel Sherrill |
New file to implement signal(2).
4.104.114.84.95
@a0b94685
05/14/99 14:43:53 |
Joel Sherrill |
Removed check for initialized ID at request of Rosimildo DaSilva? …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@16775a5
05/07/99 16:36:29 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…> to allow stacksize
of …
4.104.114.84.95
@c7aa9d6
04/26/99 18:22:08 |
Joel Sherrill |
Repairing damage and recovering changes including C++ wrappers..
4.104.114.84.95
@c8cfdcfe
04/26/99 18:04:46 |
Joel Sherrill |
Recovered changes since CVS file was corrupted.
4.104.114.84.95
@df3e78a
04/19/99 15:54:03 |
Joel Sherrill |
The default action for real-time signals is supposed to be …
4.104.114.84.95
@196094eb
04/19/99 13:19:14 |
Joel Sherrill |
This one is …
4.104.114.84.95
@a68e6b9
04/15/99 18:58:43 |
Joel Sherrill |
Updated version string.
4.104.114.84.95
@2df1974
04/15/99 18:58:27 |
Joel Sherrill |
Added include of rtems/posix/cancel.h.
4.104.114.84.95
@da41ecbc
04/15/99 18:58:02 |
Joel Sherrill |
Removed alarm(), killinfo() and pause() because they are now in their …
4.104.114.84.95
@93994fdb
04/15/99 18:57:31 |
Joel Sherrill |
Now compiles and is included in normal build even though it is …
4.104.114.84.95
@0f4e074
04/15/99 18:57:02 |
Joel Sherrill |
Cleaned up.
4.104.114.84.95
@3afecf8
04/15/99 18:56:42 |
Joel Sherrill |
Now compiles and is included in normal build even though it is untested.
4.104.114.84.95
@3090760
04/15/99 18:55:55 |
Joel Sherrill |
Now compile files that previously existed but were not built because …
4.104.114.84.95
@24a9af6
04/15/99 18:55:14 |
Joel Sherrill |
Now install header files that existed but were not previously installed.
4.104.114.84.95
@8a2943aa
04/15/99 18:54:40 |
Joel Sherrill |
Now install some header files that existed but were not previously …
4.104.114.84.95
@053acd70
04/15/99 18:54:16 |
Joel Sherrill |
Now install utsname.h.
4.104.114.84.95
@d0f53fe
04/15/99 18:54:01 |
Joel Sherrill |
Enabled cancellation information in POSIX API thread extension structure.
4.104.114.84.95
@02d46fa
04/15/99 18:53:35 |
Joel Sherrill |
Added set_errno_and_return_minus_one_cast.
4.104.114.84.95
@39daf58
04/15/99 18:53:22 |
Joel Sherrill |
Added in some header files that existed but were not previously installed.
4.104.114.84.95
@82f490f
04/12/99 20:24:56 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct the …
4.104.114.84.95
@d115315
04/12/99 15:36:07 |
Joel Sherrill |
Added line to initialize timer_max.
4.104.114.84.95
@e53c4a3
04/06/99 15:45:21 |
Joel Sherrill |
Cleaning up unused files.
4.104.114.84.95
@5c95996
03/31/99 22:09:11 |
Joel Sherrill |
When compiled in debug mode, the POSIX threads inline file was not …
4.104.114.84.95
@5c6c4c2
03/30/99 17:41:26 |
Joel Sherrill |
Fixed typo where _POSIX_signals_Clear_process_signals was not …
4.104.114.84.95
@0bf2ff8
03/24/99 23:15:20 |
Joel Sherrill |
utime.h moved to c/src/lib/include/sys since it is needed by some libc …
4.104.114.84.95
@a432c4b7
03/24/99 22:52:47 |
Joel Sherrill |
Fix based on bug report from Ralf Corsepius <corsepiu@…>: …
4.104.114.84.95
@d8ff793
03/19/99 22:27:02 |
Joel Sherrill |
Towards automake XI patch from Ralf Corsepius …
4.104.114.84.95
@e069cdc3
03/01/99 15:18:26 |
Joel Sherrill |
Part of the automake VI patch from Ralf Corsepius …
4.104.114.84.95
@8548fe0
02/18/99 18:36:05 |
Joel Sherrill |
4.104.114.84.95
@dae18b5
02/10/99 17:22:16 |
Joel Sherrill |
POSIX timer support.
4.104.114.84.95
@aee3d68
02/10/99 17:03:46 |
Joel Sherrill |
POSIX timer support modifications.
4.104.114.84.95
@0747e2d
02/03/99 16:22:18 |
Joel Sherrill |
POSIX Timers submitted by Juan Zamorano Flores …
4.104.114.84.95
@07d880f4
01/31/99 20:45:31 |
Joel Sherrill |
Split psignal.c into many more files. This reduced the amount of …
4.104.114.84.95
@d90df9aa
01/26/99 16:00:04 |
Joel Sherrill |
Added include of <rtems/posix/priority.h> so a macro would expand
and …
4.104.114.84.95
@03598b1
01/25/99 23:20:52 |
Joel Sherrill |
Split most of POSIX Threads Manager into multiple files.
4.104.114.84.95
@535db3ae
01/25/99 23:20:39 |
Joel Sherrill |
Added enough prototypes to allow most of POSIX Threads Manager to be …
4.104.114.84.95
@b33d8a2
01/19/99 17:38:13 |
Joel Sherrill |
Moved sys/ioctl.h to libc support
4.104.114.84.95
@afa3c8f
12/15/98 20:04:04 |
Joel Sherrill |
Added files as part of move
4.104.114.84.95
@62184317
12/15/98 00:55:28 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to reorganize …
4.104.114.84.95
@063a19a
12/15/98 00:24:30 |
Joel Sherrill |
Moved around per Ralf Corsepius as preparation for automake
4.104.114.84.95
@d1ee44e
11/23/98 19:39:45 |
Joel Sherrill |
New files added as part of file system infrastructure effort.
4.104.114.84.95
@07a3253d
11/23/98 19:07:58 |
Joel Sherrill |
Added base version of file system infrastructure. This includes a …
4.104.114.84.95
@97e2729d
11/23/98 17:38:09 |
Joel Sherrill |
Added --disable-multiprocessing flag and modified a lot of files to …
4.104.114.84.95
@847375f
11/19/98 17:35:49 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
1) Socket timeout …
4.104.114.84.95
@cb646cb9
09/27/98 16:37:16 |
Joel Sherrill |
New files.
4.104.114.84.95
@b965227f
09/25/98 13:28:28 |
Joel Sherrill |
Now compiles.
4.104.114.84.95
@97149ba
09/25/98 13:17:32 |
Joel Sherrill |
Added ENOSYS stubs for a number of process routines.
4.104.114.84.95
@ff0b008
08/24/98 14:50:00 |
Joel Sherrill |
Added RTEMS_INSIDE macro to insure that ".inl" files are ALWAYS …
4.104.114.84.95
@cb1b853d
06/18/98 19:01:57 |
Joel Sherrill |
All task delete API level services were incorrectly assuming that the …
4.104.114.84.95
@20fff72
04/27/98 13:46:45 |
Joel Sherrill |
Moved POSIX_signals_Siginfo_node structure definition to …
4.104.114.84.95
@9f0dfea
04/27/98 13:46:18 |
Joel Sherrill |
Changed POSIX_SIGNALS_h to RTEMS_POSIX_SIGNALS_h to avoid conflict …
4.104.114.84.95
@a456074d
04/03/98 18:44:44 |
Joel Sherrill |
Made these have real constants.
4.104.114.84.95
@60b791ad
02/17/98 23:46:28 |
Joel Sherrill |
updated copyright to 1998
4.104.114.84.95
@5c3511e
01/30/98 21:49:51 |
Joel Sherrill |
Big patch form Ralf Corsepius described in this email:
Here is the …
4.104.114.84.95
@cb5bfe4
01/20/98 19:41:09 |
Joel Sherrill |
Removed CONFIG_DIR and PROJECT_HOME directories.
4.104.114.84.95
@674c900
12/10/97 16:58:00 |
Joel Sherrill |
Modified a lot of files to take a first cut at supporting building …
4.104.114.84.95
@98e4ebf5
10/08/97 15:45:54 |
Joel Sherrill |
Fixed typo in the pointer to the license terms.
4.104.114.84.95
@a2016b99
10/08/97 14:42:08 |
Joel Sherrill |
Removed include directory at "build" point and the link of this …
4.104.114.84.95
@d14418b
10/06/97 21:28:18 |
Joel Sherrill |
Added _Thread_Enable_dispatch to already_timedout path on Wait_support.
4.104.114.84.95
@e8ee2f32
10/05/97 16:26:04 |
Joel Sherrill |
If the specified time period is less than a clock tick, then
it is …
4.104.114.84.95
@9b1f5678
08/22/97 19:11:02 |
Joel Sherrill |
Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER.
4.104.114.84.95
@799a5b9
08/22/97 19:10:44 |
Joel Sherrill |
Added commit about missing support for condition initializer.
4.104.114.84.95
@a2fa8c25
07/31/97 19:01:05 |
Joel Sherrill |
Added comment to indicate what the commented out C_PIECES indicated.
4.104.114.84.95
@a14d2af
07/09/97 23:52:08 |
Joel Sherrill |
Changed name from entry to thread_entry to be more compatible with
Ada …
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@6881e0c
04/15/97 18:02:18 |
Joel Sherrill |
Reduced number of POSIX thread priorities from 255 to 254 to avoid …
4.104.114.84.95
@254b4450
04/01/97 23:07:52 |
Joel Sherrill |
This set of changes is the build of what was required to convert to …
4.104.114.84.95
@d627c0c4
03/10/97 16:57:08 |
Joel Sherrill |
created. Split getpid() from types.c to allow it to be overridden by …
4.104.114.84.95
@fec60e9
03/10/97 16:56:08 |
Joel Sherrill |
Fixed bug where the initial detachstate was not being set properly
4.104.114.84.95
@f926b34
03/08/97 03:51:55 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@232d6c1c
03/08/97 03:50:17 |
Joel Sherrill |
Removed getpid from this file and made it its own file. This lets it …
4.104.114.84.95
@5cdcbd2
03/08/97 03:47:34 |
Joel Sherrill |
Added commit to indicate exepcted _Thread_Dispatch_disable_level. …
4.104.114.84.95
@52d99d4a
01/28/97 23:33:22 |
Joel Sherrill |
Switch to using newlib's implementation of time().
4.104.114.84.95
