Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/c/src/exec/posix
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @ed5a518   09/08/96 16:21:16 Joel Sherrill moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be … 4.104.114.84.95
(edit) @65c421f   09/05/96 20:45:05 Joel Sherrill default thread attributes: default value for inheritsched changed from … 4.104.114.84.95
(edit) @297be5c   09/05/96 20:41:10 Joel Sherrill pthread_mutex_setprioceiling: fixed bug where returned priority was … 4.104.114.84.95
(edit) @9a5cbef0   09/05/96 20:29:07 Joel Sherrill nanosleep: negative value for tv_sec is no longer an error. It now is … 4.104.114.84.95
(edit) @62bf651f   08/29/96 16:39:01 Joel Sherrill new file to support GNU Ada. currently the only routine in this file … 4.104.114.84.95
(edit) @b5c04b6   08/27/96 15:19:51 Joel Sherrill fixed typo .. changed == to != 4.104.114.84.95
(edit) @5a234809   08/27/96 15:19:33 Joel Sherrill check that we were passed a valid mutex and ignore errors from the … 4.104.114.84.95
(edit) @0b710dbb   08/23/96 14:47:58 Mark.Johannes pthread_create: changed EINVAL for no more threads back to EAGAIN 4.104.114.84.95
(edit) @c5c5f8c   08/19/96 15:30:25 Mark.Johannes Changed all EFAULTs to EINVALs 4.104.114.84.95
(edit) @02f041e   08/19/96 15:27:37 Mark.Johannes pthread_mutex_init: added error messages for NULL mutex and EBUSY 4.104.114.84.95
(edit) @9ac3e76   08/15/96 19:38:46 Mark.Johannes changed ENOMEM error message 4.104.114.84.95
(edit) @f3e19146   08/15/96 18:58:09 Joel Sherrill clock_gettime: changed assert condition to a standard error code … 4.104.114.84.95
(edit) @b03ab630   08/15/96 18:57:07 Joel Sherrill sched_rr_get_interval: converted assert condition into a standard … 4.104.114.84.95
(edit) @57dae56   08/15/96 18:56:09 Joel Sherrill added constant to indicate there is no mutex associated with this … 4.104.114.84.95
(edit) @de45ddc   08/15/96 16:29:00 Mark.Johannes pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO 4.104.114.84.95
(edit) @948721c   08/15/96 16:24:44 Mark.Johannes pthread_kill: moved check for SA_SIGINFO to allow for validation of … 4.104.114.84.95
(edit) @48e685c   08/15/96 16:22:59 Mark.Johannes fixed typo for NOTSUP -> ENOTSUP 4.104.114.84.95
(edit) @4e63ae5   08/14/96 17:20:45 Mark.Johannes commented of ENOTSUP until fixed in newlib 4.104.114.84.95
(edit) @aae1c932   08/14/96 17:20:03 Mark.Johannes pthread_cond_timedwait: added error cases for abstime 4.104.114.84.95
(edit) @dce801d   08/13/96 21:32:49 Mark.Johannes pthread_cond_destroy: added enable dispatch to EBUSY case 4.104.114.84.95
(edit) @95b76bc   08/13/96 21:10:06 Mark.Johannes pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First 4.104.114.84.95
(edit) @456b3769   08/13/96 20:50:54 Mark.Johannes pthread_cond_destroy: EBUSY case now uses Thread_queue_First 4.104.114.84.95
(edit) @392b35e   08/13/96 20:38:30 Joel Sherrill deleted a line for spacing correction 4.104.114.84.95
(edit) @48b40d8   08/13/96 19:53:51 Mark.Johannes _POSIX_Condition_variables_Wait_support: changed status of lock and … 4.104.114.84.95
(edit) @76f03c6   08/13/96 19:03:29 Mark.Johannes _POSIX_Condition_variables_Wait_support: fixed the timeout sequence. 4.104.114.84.95
(edit) @f48c9068   08/13/96 14:24:00 Joel Sherrill removed errors for TOD not set yet. made nanosleep return -1/EINTR … 4.104.114.84.95
(edit) @aac34f7b   08/13/96 14:23:16 Joel Sherrill added page break before sysconf() 4.104.114.84.95
(edit) @1087564   08/12/96 20:59:41 Joel Sherrill clock_getres: added error check for NULL pointer being passed in. 4.104.114.84.95
(edit) @3fbfbcd   08/12/96 20:48:13 Joel Sherrill sleep: wrong page number 4.104.114.84.95
(edit) @5f08fd6   08/12/96 19:55:09 Joel Sherrill nanosleep: verify rqtp parameter is non-NULL. nanosleep: return 0 … 4.104.114.84.95
(edit) @40cfab47   08/12/96 19:19:03 Joel Sherrill time: It is not an error if the TOD is not set. 4.104.114.84.95
(edit) @9b77fee   08/12/96 19:00:12 Mark.Johannes Wait_support: removed the calls to mutex core to posix status codes 4.104.114.84.95
(edit) @3b97b7a0   08/12/96 18:58:12 Mark.Johannes mutex.h: removes the promotion of core status code to POSXI status codes 4.104.114.84.95
(edit) @1402ee25   08/12/96 18:56:04 Joel Sherrill fixed spacing ; moved a dummy MP support routine to clean up printout. 4.104.114.84.95
(edit) @c7a9c66   08/12/96 18:06:27 Joel Sherrill _POSIX_Mutex_Get: made null id an error 4.104.114.84.95
(edit) @ccdf4c57   08/12/96 18:05:47 Joel Sherrill pthread_mutex_getprioceiling: added error check for null old_ceiling … 4.104.114.84.95
(edit) @b1af454   08/12/96 17:41:37 Mark.Johannes mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status 4.104.114.84.95
(edit) @af04a791   08/12/96 17:40:56 Mark.Johannes _POSIX_Condition_variables_Wait_support: added … 4.104.114.84.95
(edit) @cdcea6ce   08/12/96 17:21:04 Mark.Johannes _POSIX_Condition_variables_Signal_support: added setting mutex back to … 4.104.114.84.95
(edit) @f126ae2   08/12/96 17:04:13 Joel Sherrill pthread_mutexattr_setprioceiling: fixed typo 4.104.114.84.95
(edit) @db8e9011   08/12/96 17:02:39 Joel Sherrill pthread_mutexattr_setprioceiling: valid priority ceiling check looked … 4.104.114.84.95
(edit) @684c3c4   08/12/96 16:29:14 Joel Sherrill pthread_mutexattr_getprotocol: added check for attribute structure … 4.104.114.84.95
(edit) @b9444fb9   08/09/96 19:58:58 Joel Sherrill added code to catch NULL pointers for return values passed to get routines 4.104.114.84.95
(edit) @8699a70   08/09/96 18:45:10 Joel Sherrill sched_yield: was not invoking the dispatcher. 4.104.114.84.95
(edit) @d858fdb   08/09/96 17:30:13 Joel Sherrill merged remote object id and invalid id error cases. 4.104.114.84.95
(edit) @567ac45   08/08/96 18:24:29 Mark.Johannes _POSIX_signals_Clear_signals: added this routine … 4.104.114.84.95
(edit) @f55d898   08/08/96 16:51:14 Joel Sherrill added ss_high_priority field to support sporadic server. 4.104.114.84.95
(edit) @2014063   08/07/96 22:06:08 Joel Sherrill sporadic server debugged and working. This required minor changes in … 4.104.114.84.95
(edit) @a14684c3   08/07/96 20:58:59 Mark.Johannes _POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case 4.104.114.84.95
(edit) @a61f1a46   08/06/96 16:24:41 Joel Sherrill _POSIX_Threads_Delete_extension: reorder to eliminate use of local … 4.104.114.84.95
(edit) @06883e13   08/06/96 16:24:06 Mark.Johannes POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority 4.104.114.84.95
(edit) @b521ae2   08/06/96 16:23:09 Joel Sherrill pthread_getspecific: use local variable so references to tcb are … 4.104.114.84.95
(edit) @22b4b2e   08/01/96 19:24:57 Joel Sherrill added page delimiters for comment blocks 4.104.114.84.95
(edit) @adae080a   07/15/96 14:02:14 Mark.Johannes Fixed default vectors initialization, sigaction which had a redundant … 4.104.114.84.95
(edit) @69c9543   07/04/96 18:09:23 Joel Sherrill basic test cases passed 4.104.114.84.95
(edit) @503dc058   07/03/96 14:20:03 Joel Sherrill switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" 4.104.114.84.95
(edit) @df8d1440   07/02/96 18:13:59 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @108ef35   06/15/96 19:55:39 Joel Sherrill initial modifications to support sigtimedwait. 4.104.114.84.95
(edit) @7f13a932   06/14/96 15:49:31 Joel Sherrill fields for init threads stuff said tasks. 4.104.114.84.95
(edit) @9e28da4   06/13/96 22:16:47 Mark.Johannes sigtimedwait passes initial test cases of timeout and simple satisfaction. 4.104.114.84.95
(edit) @c53cfd0f   06/13/96 20:46:15 Joel Sherrill added queued signals and cleaned up setting of process wide signals so … 4.104.114.84.95
(edit) @25a882a6   06/13/96 20:45:38 Joel Sherrill config.h: added maximum_queued_signals. psignal.h: fixed typo. 4.104.114.84.95
(edit) @b85649c4   06/13/96 16:42:21 Joel Sherrill basic test cases for kill() and alarm(). kill() in particular needs … 4.104.114.84.95
(edit) @7fc3029   06/13/96 16:39:28 Joel Sherrill added prototype for manager initialization routine. 4.104.114.84.95
(edit) @281ad52   06/12/96 22:49:14 Joel Sherrill basic kill() which send a signal to pthread_self() appears to work. 4.104.114.84.95
(edit) @2291b71   06/12/96 17:45:01 Joel Sherrill initial implementation of blocking signal routines -- sigwait, … 4.104.114.84.95
(edit) @937808f5   06/11/96 22:55:39 Joel Sherrill added comment to make sure we add unblock of thread 4.104.114.84.95
(edit) @ea1a5bef   06/11/96 22:52:42 Joel Sherrill first attempt at adding algorithm to select the thread which will … 4.104.114.84.95
(edit) @20d099e   06/11/96 22:51:59 Joel Sherrill deleted field for signals_global_pending. 4.104.114.84.95
(edit) @c8f5ab5   06/11/96 20:43:55 Joel Sherrill tested blocking a signal, sending it to self, then unblocking it. … 4.104.114.84.95
(edit) @98ed15e   06/11/96 16:01:37 Joel Sherrill Basic signal functionality appears to work. pthread_kill() can … 4.104.114.84.95
(edit) @d0baf81   06/11/96 16:00:06 Joel Sherrill new file. 4.104.114.84.95
(edit) @494740c   06/10/96 21:04:14 Joel Sherrill added psignal.h 4.104.114.84.95
(edit) @fdec30b   06/10/96 20:47:23 Joel Sherrill first attempt at the routine which vectors signals. 4.104.114.84.95
(edit) @d03f192   06/10/96 20:46:36 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @05ce4e09   06/07/96 15:21:27 Joel Sherrill changed code which set errno and then returned -1 to use the macro … 4.104.114.84.95
(edit) @fa03f08   06/07/96 15:20:55 Joel Sherrill new file 4.104.114.84.95
(edit) @895efd9   06/07/96 13:54:23 Joel Sherrill key destructor is now run at correct point in pthread_exit() sequence … 4.104.114.84.95
(edit) @fce2e9d   06/06/96 21:27:33 Joel Sherrill in newlib now 4.104.114.84.95
(edit) @782bdfd   06/06/96 19:09:27 Joel Sherrill Removed assert's from routines which return the error ENOSYS. 4.104.114.84.95
(edit) @e754dd1d   06/06/96 17:54:37 Joel Sherrill process oriented scheduler routines now return ENOSYS 4.104.114.84.95
(edit) @5d9cb7e   06/06/96 17:24:44 Joel Sherrill removed timer_getoverrun() since it was also in ptimer.c 4.104.114.84.95
(edit) @0207c55   06/06/96 15:36:18 Joel Sherrill Made the implementation of pthread_equal conditional on RTEMS_DEBUG. … 4.104.114.84.95
(edit) @65a5c1b   06/06/96 15:32:49 Joel Sherrill completed pthread_setschedparam. 4.104.114.84.95
(edit) @624133c   06/06/96 14:53:12 Joel Sherrill added Sporadic Server support 4.104.114.84.95
(edit) @ed10d76   06/06/96 14:52:53 Joel Sherrill added Sporadic_timer field to support sporadic server 4.104.114.84.95
(edit) @9b4e549   06/05/96 14:45:05 Joel Sherrill renamed Schedule to schedparam in the posix api control information. … 4.104.114.84.95
(edit) @7189a40   06/05/96 14:44:03 Joel Sherrill added comments to to document the definition of posix priority and how … 4.104.114.84.95
(edit) @09c1e31d   06/05/96 14:43:52 Joel Sherrill added comments to priority.h to document the definition of posix … 4.104.114.84.95
(edit) @2c207d1f   06/04/96 20:36:37 Joel Sherrill make PTHREAD_SCOPE_SYSTEM an unsupported value for contentionscope. 4.104.114.84.95
(edit) @65911c32   06/04/96 19:50:15 Joel Sherrill made sure _Thread_Enable_dispatch is not invoked in cases where … 4.104.114.84.95
(edit) @56bd4a36   06/04/96 19:48:08 Joel Sherrill made sure routines which called _Objects_Get also called … 4.104.114.84.95
(edit) @230a0dcb   06/04/96 19:44:16 Joel Sherrill added some of the required functionality to pthread_setschedparam and … 4.104.114.84.95
(edit) @3ff4688   06/04/96 19:20:53 Joel Sherrill clean up pass 4.104.114.84.95
(edit) @6b067c4   06/04/96 19:15:28 Joel Sherrill renamed the local variable attrp to the_attr in pthread_create 4.104.114.84.95
(edit) @24adc5b   06/04/96 19:05:16 Joel Sherrill changed sched_rr_get_interval to use the interval to timespec routine. 4.104.114.84.95
(edit) @c48e0ee   06/04/96 16:15:59 Joel Sherrill added interpretation of scheduling policy and parameter information to … 4.104.114.84.95
(edit) @12c77ab   06/04/96 16:14:55 Joel Sherrill added scheduling policy and parameter information 4.104.114.84.95
(edit) @8f857992   06/03/96 22:08:18 Joel Sherrill added thread queue for list of threads waiting to join. thread is … 4.104.114.84.95
(edit) @552a345d   06/03/96 22:07:14 Joel Sherrill added thread queue for list of threads waiting to join. 4.104.114.84.95
