@d14418b
10/06/97 21:28:18 |
Joel Sherrill |
Added _Thread_Enable_dispatch to already_timedout path on Wait_support.
4.104.114.84.95
@e8ee2f32
10/05/97 16:26:04 |
Joel Sherrill |
If the specified time period is less than a clock tick, then
it is …
4.104.114.84.95
@9b1f5678
08/22/97 19:11:02 |
Joel Sherrill |
Fixed infinite recursion bug in PTHREAD_MUTEX_INITIALIZER.
4.104.114.84.95
@799a5b9
08/22/97 19:10:44 |
Joel Sherrill |
Added commit about missing support for condition initializer.
4.104.114.84.95
@a2fa8c25
07/31/97 19:01:05 |
Joel Sherrill |
Added comment to indicate what the commented out C_PIECES indicated.
4.104.114.84.95
@a14d2af
07/09/97 23:52:08 |
Joel Sherrill |
Changed name from entry to thread_entry to be more compatible with
Ada …
4.104.114.84.95
@03f2154e
04/22/97 17:20:27 |
Joel Sherrill |
headers updated to reflect new style copyright notice as part
of …
4.104.114.84.95
@6881e0c
04/15/97 18:02:18 |
Joel Sherrill |
Reduced number of POSIX thread priorities from 255 to 254 to avoid …
4.104.114.84.95
@254b4450
04/01/97 23:07:52 |
Joel Sherrill |
This set of changes is the build of what was required to convert to …
4.104.114.84.95
@d627c0c4
03/10/97 16:57:08 |
Joel Sherrill |
created. Split getpid() from types.c to allow it to be overridden by …
4.104.114.84.95
@fec60e9
03/10/97 16:56:08 |
Joel Sherrill |
Fixed bug where the initial detachstate was not being set properly
4.104.114.84.95
@f926b34
03/08/97 03:51:55 |
Joel Sherrill |
Modified calls to _Thread_Change_priority to take a third argument. …
4.104.114.84.95
@232d6c1c
03/08/97 03:50:17 |
Joel Sherrill |
Removed getpid from this file and made it its own file. This lets it …
4.104.114.84.95
@5cdcbd2
03/08/97 03:47:34 |
Joel Sherrill |
Added commit to indicate exepcted _Thread_Dispatch_disable_level. …
4.104.114.84.95
@52d99d4a
01/28/97 23:33:22 |
Joel Sherrill |
Switch to using newlib's implementation of time().
4.104.114.84.95
@348ba42
09/30/96 20:14:08 |
Joel Sherrill |
changed stack size of posix initialization threads to double the …
4.104.114.84.95
@41be2e8
09/17/96 21:31:30 |
Joel Sherrill |
added routine _POSIX_Timespec_subtract
4.104.114.84.95
@aa48536
09/17/96 21:31:10 |
Joel Sherrill |
Added code to insure that the post switch extension was executed and …
4.104.114.84.95
@9093c3c
09/17/96 21:29:51 |
Joel Sherrill |
Corrected implementation of timed wait on condition variables. First …
4.104.114.84.95
@ded66f8
09/17/96 21:26:25 |
Joel Sherrill |
added prototype for _POSIX_Timespec_subtract
4.104.114.84.95
@3335420
09/08/96 16:22:05 |
Joel Sherrill |
moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to pthread.h so it …
4.104.114.84.95
@e7a36a9
09/08/96 16:21:48 |
Joel Sherrill |
Ada task stack size minimize is twice that for regular pthreads.
4.104.114.84.95
@ed5a518
09/08/96 16:21:16 |
Joel Sherrill |
moved PTHREAD_MINIMUM_STACK_SIZE from pthread.c to here so it would be …
4.104.114.84.95
@65c421f
09/05/96 20:45:05 |
Joel Sherrill |
default thread attributes: default value for inheritsched changed from …
4.104.114.84.95
@297be5c
09/05/96 20:41:10 |
Joel Sherrill |
pthread_mutex_setprioceiling: fixed bug where returned priority was
4.104.114.84.95
@9a5cbef0
09/05/96 20:29:07 |
Joel Sherrill |
nanosleep: negative value for tv_sec is no longer an error. It now
is …
4.104.114.84.95
@62bf651f
08/29/96 16:39:01 |
Joel Sherrill |
new file to support GNU Ada.
currently the only routine in this file …
4.104.114.84.95
@b5c04b6
08/27/96 15:19:51 |
Joel Sherrill |
fixed typo .. changed == to !=
4.104.114.84.95
@5a234809
08/27/96 15:19:33 |
Joel Sherrill |
check that we were passed a valid mutex and ignore errors from the …
4.104.114.84.95
@0b710dbb
08/23/96 14:47:58 |
Mark.Johannes |
pthread_create: changed EINVAL for no more threads back to EAGAIN
4.104.114.84.95
@c5c5f8c
08/19/96 15:30:25 |
Mark.Johannes |
Changed all EFAULTs to EINVALs
4.104.114.84.95
@02f041e
08/19/96 15:27:37 |
Mark.Johannes |
pthread_mutex_init: added error messages for NULL mutex and EBUSY
4.104.114.84.95
@9ac3e76
08/15/96 19:38:46 |
Mark.Johannes |
changed ENOMEM error message
4.104.114.84.95
@f3e19146
08/15/96 18:58:09 |
Joel Sherrill |
clock_gettime: changed assert condition to a standard error code
4.104.114.84.95
@b03ab630
08/15/96 18:57:07 |
Joel Sherrill |
sched_rr_get_interval: converted assert condition into a standard …
4.104.114.84.95
@57dae56
08/15/96 18:56:09 |
Joel Sherrill |
added constant to indicate there is no mutex associated with this …
4.104.114.84.95
@de45ddc
08/15/96 16:29:00 |
Mark.Johannes |
pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO
4.104.114.84.95
@948721c
08/15/96 16:24:44 |
Mark.Johannes |
pthread_kill: moved check for SA_SIGINFO to allow for validation of …
4.104.114.84.95
@48e685c
08/15/96 16:22:59 |
Mark.Johannes |
fixed typo for NOTSUP -> ENOTSUP
4.104.114.84.95
@4e63ae5
08/14/96 17:20:45 |
Mark.Johannes |
commented of ENOTSUP until fixed in newlib
4.104.114.84.95
@aae1c932
08/14/96 17:20:03 |
Mark.Johannes |
pthread_cond_timedwait: added error cases for abstime
4.104.114.84.95
@dce801d
08/13/96 21:32:49 |
Mark.Johannes |
pthread_cond_destroy: added enable dispatch to EBUSY case
4.104.114.84.95
@95b76bc
08/13/96 21:10:06 |
Mark.Johannes |
pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First
4.104.114.84.95
@456b3769
08/13/96 20:50:54 |
Mark.Johannes |
pthread_cond_destroy: EBUSY case now uses Thread_queue_First
4.104.114.84.95
@392b35e
08/13/96 20:38:30 |
Joel Sherrill |
deleted a line for spacing correction
4.104.114.84.95
@48b40d8
08/13/96 19:53:51 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: changed status of lock and …
4.104.114.84.95
@76f03c6
08/13/96 19:03:29 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: fixed the timeout sequence.
4.104.114.84.95
@f48c9068
08/13/96 14:24:00 |
Joel Sherrill |
removed errors for TOD not set yet.
made nanosleep return -1/EINTR …
4.104.114.84.95
@aac34f7b
08/13/96 14:23:16 |
Joel Sherrill |
added page break before sysconf()
4.104.114.84.95
@1087564
08/12/96 20:59:41 |
Joel Sherrill |
clock_getres: added error check for NULL pointer being passed in.
4.104.114.84.95
@3fbfbcd
08/12/96 20:48:13 |
Joel Sherrill |
sleep: wrong page number
4.104.114.84.95
@5f08fd6
08/12/96 19:55:09 |
Joel Sherrill |
nanosleep: verify rqtp parameter is non-NULL.
nanosleep: return 0 …
4.104.114.84.95
@40cfab47
08/12/96 19:19:03 |
Joel Sherrill |
time: It is not an error if the TOD is not set.
4.104.114.84.95
@9b77fee
08/12/96 19:00:12 |
Mark.Johannes |
Wait_support: removed the calls to mutex core to posix status codes
4.104.114.84.95
@3b97b7a0
08/12/96 18:58:12 |
Mark.Johannes |
mutex.h: removes the promotion of core status code to POSXI status codes
4.104.114.84.95
@1402ee25
08/12/96 18:56:04 |
Joel Sherrill |
fixed spacing ; moved a dummy MP support routine to clean up printout.
4.104.114.84.95
@c7a9c66
08/12/96 18:06:27 |
Joel Sherrill |
_POSIX_Mutex_Get: made null id an error
4.104.114.84.95
@ccdf4c57
08/12/96 18:05:47 |
Joel Sherrill |
pthread_mutex_getprioceiling: added error check for null old_ceiling
4.104.114.84.95
@b1af454
08/12/96 17:41:37 |
Mark.Johannes |
mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status
4.104.114.84.95
@af04a791
08/12/96 17:40:56 |
Mark.Johannes |
_POSIX_Condition_variables_Wait_support: added …
4.104.114.84.95
@cdcea6ce
08/12/96 17:21:04 |
Mark.Johannes |
_POSIX_Condition_variables_Signal_support: added setting mutex back to …
4.104.114.84.95
@f126ae2
08/12/96 17:04:13 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: fixed typo
4.104.114.84.95
@db8e9011
08/12/96 17:02:39 |
Joel Sherrill |
pthread_mutexattr_setprioceiling: valid priority ceiling check looked …
4.104.114.84.95
@684c3c4
08/12/96 16:29:14 |
Joel Sherrill |
pthread_mutexattr_getprotocol: added check for attribute structure …
4.104.114.84.95
@b9444fb9
08/09/96 19:58:58 |
Joel Sherrill |
added code to catch NULL pointers for return values passed to get routines
4.104.114.84.95
@8699a70
08/09/96 18:45:10 |
Joel Sherrill |
sched_yield: was not invoking the dispatcher.
4.104.114.84.95
@d858fdb
08/09/96 17:30:13 |
Joel Sherrill |
merged remote object id and invalid id error cases.
4.104.114.84.95
@567ac45
08/08/96 18:24:29 |
Mark.Johannes |
_POSIX_signals_Clear_signals: added this routine …
4.104.114.84.95
@f55d898
08/08/96 16:51:14 |
Joel Sherrill |
added ss_high_priority field to support sporadic server.
4.104.114.84.95
@2014063
08/07/96 22:06:08 |
Joel Sherrill |
sporadic server debugged and working. This required minor changes in …
4.104.114.84.95
@a14684c3
08/07/96 20:58:59 |
Mark.Johannes |
_POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case
4.104.114.84.95
@a61f1a46
08/06/96 16:24:41 |
Joel Sherrill |
_POSIX_Threads_Delete_extension: reorder to eliminate use of local …
4.104.114.84.95
@06883e13
08/06/96 16:24:06 |
Mark.Johannes |
POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority
4.104.114.84.95
@b521ae2
08/06/96 16:23:09 |
Joel Sherrill |
pthread_getspecific: use local variable so references to tcb are …
4.104.114.84.95
@22b4b2e
08/01/96 19:24:57 |
Joel Sherrill |
added page delimiters for comment blocks
4.104.114.84.95
@adae080a
07/15/96 14:02:14 |
Mark.Johannes |
Fixed default vectors initialization, sigaction which had a redundant …
4.104.114.84.95
@69c9543
07/04/96 18:09:23 |
Joel Sherrill |
basic test cases passed
4.104.114.84.95
@503dc058
07/03/96 14:20:03 |
Joel Sherrill |
switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"
4.104.114.84.95
@df8d1440
07/02/96 18:13:59 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@108ef35
06/15/96 19:55:39 |
Joel Sherrill |
initial modifications to support sigtimedwait.
4.104.114.84.95
@7f13a932
06/14/96 15:49:31 |
Joel Sherrill |
fields for init threads stuff said tasks.
4.104.114.84.95
@9e28da4
06/13/96 22:16:47 |
Mark.Johannes |
sigtimedwait passes initial test cases of timeout and simple satisfaction.
4.104.114.84.95
@c53cfd0f
06/13/96 20:46:15 |
Joel Sherrill |
added queued signals and cleaned up setting of process wide signals so …
4.104.114.84.95
@25a882a6
06/13/96 20:45:38 |
Joel Sherrill |
config.h: added maximum_queued_signals.
psignal.h: fixed typo.
4.104.114.84.95
@b85649c4
06/13/96 16:42:21 |
Joel Sherrill |
basic test cases for kill() and alarm().
kill() in particular needs …
4.104.114.84.95
@7fc3029
06/13/96 16:39:28 |
Joel Sherrill |
added prototype for manager initialization routine.
4.104.114.84.95
@281ad52
06/12/96 22:49:14 |
Joel Sherrill |
basic kill() which send a signal to pthread_self() appears to work.
4.104.114.84.95
@2291b71
06/12/96 17:45:01 |
Joel Sherrill |
initial implementation of blocking signal routines -- sigwait, …
4.104.114.84.95
@937808f5
06/11/96 22:55:39 |
Joel Sherrill |
added comment to make sure we add unblock of thread
4.104.114.84.95
@ea1a5bef
06/11/96 22:52:42 |
Joel Sherrill |
first attempt at adding algorithm to select the thread which will …
4.104.114.84.95
@20d099e
06/11/96 22:51:59 |
Joel Sherrill |
deleted field for signals_global_pending.
4.104.114.84.95
@c8f5ab5
06/11/96 20:43:55 |
Joel Sherrill |
tested blocking a signal, sending it to self, then unblocking it.
4.104.114.84.95
@98ed15e
06/11/96 16:01:37 |
Joel Sherrill |
Basic signal functionality appears to work. pthread_kill() can …
4.104.114.84.95
@d0baf81
06/11/96 16:00:06 |
Joel Sherrill |
new file.
4.104.114.84.95
@494740c
06/10/96 21:04:14 |
Joel Sherrill |
added psignal.h
4.104.114.84.95
@fdec30b
06/10/96 20:47:23 |
Joel Sherrill |
first attempt at the routine which vectors signals.
4.104.114.84.95
@d03f192
06/10/96 20:46:36 |
Joel Sherrill |
4.104.114.84.95
@05ce4e09
06/07/96 15:21:27 |
Joel Sherrill |
changed code which set errno and then returned -1 to use the macro …
4.104.114.84.95
@fa03f08
06/07/96 15:20:55 |
Joel Sherrill |
new file
4.104.114.84.95
@895efd9
06/07/96 13:54:23 |
Joel Sherrill |
key destructor is now run at correct point in pthread_exit() sequence …
4.104.114.84.95
