# # ChangeLog for c/src/ada/rtems.adb in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 06:56:42 Fri, 01 Feb 2002 18:58:21 GMT Joel Sherrill [7003847] * c/src/ada/ChangeLog (modified) * c/src/ada/rtems-multiprocessing.adb (added) * c/src/ada/rtems-multiprocessing.ads (added) * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/rtems-multiprocessing.adb (added) * cpukit/ada/rtems-multiprocessing.ads (added) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) 2001-02-01 Joel Sherrill * ... Thu, 21 Oct 1999 14:49:24 GMT Joel Sherrill [8f2cf931] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) Added Semaphore_Flush. Thu, 07 Oct 1999 16:17:41 GMT Joel Sherrill [1e3e81f] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) Added Is_Suspended method. Tue, 30 Sep 1997 14:44:28 GMT Joel Sherrill [63cebf6] * c/src/ada/rtems.adb (modified) * cpukit/ada/rtems.adb (modified) Fixed typos. Thu, 28 Aug 1997 22:23:10 GMT Joel Sherrill [ad9250cf] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) Fixed IO Manager calls to remove an argument which was used in 3.2.1 ... Thu, 10 Jul 1997 20:23:27 GMT Joel Sherrill [0b172df9] * c/src/ada/rtems.adb (modified) * cpukit/ada/rtems.adb (modified) fixed milliseconds and microseconds to tick conversion routines. Tue, 03 Jun 1997 18:07:30 GMT Joel Sherrill [6666ea88] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) Added True and False constants for RTEMS.Boolean types. This ... Tue, 03 Jun 1997 15:11:39 GMT Joel Sherrill [d348ad96] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) added more constants and fixed numer Tue, 03 Jun 1997 00:55:42 GMT Joel Sherrill [a6b44a8a] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) added Signal constants, Is_Status_Successful, and Attribute constants. Tue, 03 Jun 1997 00:33:48 GMT Joel Sherrill [7e3dcbc] * c/src/ada/rtems.adb (modified) * c/src/ada/rtems.ads (modified) * cpukit/ada/rtems.adb (modified) * cpukit/ada/rtems.ads (modified) added rtems_interrupt_level_attribute routien to return a properly ... Mon, 02 Jun 1997 20:52:48 GMT Joel Sherrill [f3f06f79] * c/src/ada-tests/support/init.c (added) * c/src/ada-tests/support/status_io.ads (added) * c/src/ada-tests/support/test_support.adb (added) * c/src/ada-tests/support/test_support.ads (added) * c/src/ada-tests/support/unsigned32_io.ads (added) * c/src/ada/rtems.adb (added) * c/src/ada/rtems.ads (added) * cpukit/ada/rtems.adb (added) * cpukit/ada/rtems.ads (added) added new files from test area. This code has successfully been ...
