# # ChangeLog for c/src/ada-tests in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 20:19:13 Thu, 04 Sep 2003 13:53:43 GMT Joel Sherrill [0e9fa39] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (modified) * c/src/ada-tests/support/init.c (modified) 2003-09-04 Joel Sherrill * ... Thu, 04 Sep 2003 13:25:16 GMT Joel Sherrill [f6bcc8f5] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/base_sp/base_sp.adb (modified) * c/src/ada-tests/samples/base_sp/config.h (modified) * c/src/ada-tests/samples/base_sp/sptest.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/hello/config.h (modified) * c/src/ada-tests/samples/hello/hello.adb (modified) * c/src/ada-tests/samples/hello/sptest.adb (modified) * c/src/ada-tests/samples/hello/sptest.ads (modified) * c/src/ada-tests/samples/ticker/config.h (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/samples/ticker/ticker.adb (modified) * c/src/ada-tests/sptests/sp01/config.h (modified) * c/src/ada-tests/sptests/sp01/sp01.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.ads (modified) * c/src/ada-tests/sptests/sp02/config.h (modified) * c/src/ada-tests/sptests/sp02/sp02.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/config.h (modified) * c/src/ada-tests/sptests/sp03/sp03.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/config.h (modified) * c/src/ada-tests/sptests/sp04/sp04.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/config.h (modified) * c/src/ada-tests/sptests/sp05/sp05.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/config.h (modified) * c/src/ada-tests/sptests/sp06/sp06.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/config.h (modified) * c/src/ada-tests/sptests/sp07/sp07.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/config.h (modified) * c/src/ada-tests/sptests/sp08/sp08.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/config.h (modified) * c/src/ada-tests/sptests/sp09/sp09.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/config.h (modified) * c/src/ada-tests/sptests/sp11/sp11.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/config.h (modified) * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/config.h (modified) * c/src/ada-tests/sptests/sp13/sp13.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/config.h (modified) * c/src/ada-tests/sptests/sp14/sp14.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/config.h (modified) * c/src/ada-tests/sptests/sp15/sp15.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/config.h (modified) * c/src/ada-tests/sptests/sp16/sp16.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/config.h (modified) * c/src/ada-tests/sptests/sp17/sp17.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/config.h (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/config.h (modified) * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp21/config.h (modified) * c/src/ada-tests/sptests/sp21/sp21.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/config.h (modified) * c/src/ada-tests/sptests/sp22/sp22.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/config.h (modified) * c/src/ada-tests/sptests/sp23/sp23.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/config.h (modified) * c/src/ada-tests/sptests/sp24/sp24.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/config.h (modified) * c/src/ada-tests/sptests/sp25/sp25.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spsize/spsize.adb (modified) * c/src/ada-tests/sptests/spsize/sptest.adb (modified) * c/src/ada-tests/sptests/spsize/sptest.ads (modified) * c/src/ada-tests/support/address_io.adb (modified) * c/src/ada-tests/support/address_io.ads (modified) * c/src/ada-tests/support/float_io.ads (modified) * c/src/ada-tests/support/fp.inc (modified) * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/support/integer.inc (modified) * c/src/ada-tests/support/rtems_calling_overhead.ads (modified) * c/src/ada-tests/support/status_io.ads (modified) * c/src/ada-tests/support/test_support.adb (modified) * c/src/ada-tests/support/test_support.ads (modified) * c/src/ada-tests/support/time_test_support.adb (modified) * c/src/ada-tests/support/time_test_support.ads (modified) * c/src/ada-tests/support/timer_driver.adb (modified) * c/src/ada-tests/support/timer_driver.ads (modified) * c/src/ada-tests/support/unsigned32_io.ads (modified) * c/src/ada-tests/tmtests/tm01/config.h (modified) * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm02/config.h (modified) * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/config.h (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/config.h (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/config.h (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/config.h (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/config.h (modified) * c/src/ada-tests/tmtests/tm07/tm07.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/config.h (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/config.h (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/config.h (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/config.h (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/config.h (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/config.h (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/config.h (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/config.h (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/config.h (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/config.h (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/config.h (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/config.h (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/config.h (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/config.h (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/config.h (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/config.h (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/config.h (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/config.h (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/config.h (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/config.h (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/config.h (modified) * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/config.h (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) 2003-09-04 Joel Sherrill * ... Mon, 11 Aug 2003 14:41:57 GMT Ralf Corsepius [74e2998] * ChangeLog (modified) * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/configure.ac (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/configure.ac (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/a29k/configure.ac (modified) * c/src/lib/libcpu/configure.ac (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/libchip/ChangeLog (modified) * c/src/libchip/configure.ac (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/configure.ac (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/optman/ChangeLog (modified) * c/src/optman/configure.ac (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/configure.ac (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/itrontests/configure.ac (modified) * c/src/tests/libtests/ChangeLog (modified) * c/src/tests/libtests/configure.ac (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/mptests/configure.ac (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/configure.ac (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/samples/configure.ac (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/configure.ac (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/configure.ac (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmitrontests/configure.ac (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tmtests/configure.ac (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/configure.ac (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/tests/tools/generic/configure.ac (modified) * configure.ac (modified) * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/configure.ac (modified) * contrib/solaris/ChangeLog (modified) * contrib/solaris/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/configure.ac (modified) * cpukit/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libmisc/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) * cpukit/score/cpu/a29k/ChangeLog (modified) * cpukit/score/cpu/a29k/configure.ac (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/configure.ac (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/configure.ac (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/configure.ac (modified) * cpukit/score/cpu/hppa1.1/ChangeLog (modified) * cpukit/score/cpu/hppa1.1/configure.ac (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/configure.ac (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/i960/configure.ac (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/configure.ac (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/configure.ac (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/mips64orion/configure.ac (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/configure.ac (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/or32/configure.ac (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/configure.ac (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/configure.ac (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/configure.ac (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/configure.ac (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/hppa1.1/ChangeLog (modified) * tools/cpu/hppa1.1/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) 2003-08-11 Ralf Corsepius * ... Fri, 18 Jul 2003 14:22:14 GMT Joel Sherrill [8f51fa52] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/samples/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/.cvsignore (deleted) * c/src/ada-tests/samples/base_mp/Makefile.am (deleted) * c/src/ada-tests/samples/base_mp/config.h (deleted) * c/src/ada-tests/samples/base_mp/mptest.adb (deleted) * c/src/ada-tests/samples/base_mp/mptest.ads (deleted) * c/src/ada-tests/samples/base_mp/node1/.cvsignore (deleted) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (deleted) * c/src/ada-tests/samples/base_mp/node1/base_mp.scn (deleted) * c/src/ada-tests/samples/base_mp/node2/.cvsignore (deleted) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (deleted) * c/src/ada-tests/samples/base_mp/node2/base_mp.scn (deleted) 2003-07-18 Joel Sherrill PR 426/ada ... Thu, 17 Jul 2003 20:14:56 GMT Joel Sherrill [4c29889] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/Makefile.am (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/mptests/.cvsignore (deleted) * c/src/ada-tests/mptests/Makefile.am (deleted) * c/src/ada-tests/mptests/mp01/.cvsignore (deleted) * c/src/ada-tests/mptests/mp01/Makefile.am (deleted) * c/src/ada-tests/mptests/mp01/config.h (deleted) * c/src/ada-tests/mptests/mp01/mp01.adb (deleted) * c/src/ada-tests/mptests/mp01/mptest.adb (deleted) * c/src/ada-tests/mptests/mp01/mptest.ads (deleted) * c/src/ada-tests/mptests/mp01/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (deleted) * c/src/ada-tests/mptests/mp01/node1/mp01.scn (deleted) * c/src/ada-tests/mptests/mp01/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (deleted) * c/src/ada-tests/mptests/mp01/node2/mp01.scn (deleted) * c/src/ada-tests/mptests/mp02/.cvsignore (deleted) * c/src/ada-tests/mptests/mp02/mptest.adb (deleted) * c/src/ada-tests/mptests/mp02/mptest.ads (deleted) * c/src/ada-tests/mptests/mp02/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp02/node1/mp02.scn (deleted) * c/src/ada-tests/mptests/mp02/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp02/node2/mp02.scn (deleted) * c/src/ada-tests/mptests/mp03/.cvsignore (deleted) * c/src/ada-tests/mptests/mp03/mptest.adb (deleted) * c/src/ada-tests/mptests/mp03/mptest.ads (deleted) * c/src/ada-tests/mptests/mp03/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp03/node1/mp03.scn (deleted) * c/src/ada-tests/mptests/mp03/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp03/node2/mp03.scn (deleted) * c/src/ada-tests/mptests/mp04/.cvsignore (deleted) * c/src/ada-tests/mptests/mp04/mptest.adb (deleted) * c/src/ada-tests/mptests/mp04/mptest.ads (deleted) * c/src/ada-tests/mptests/mp04/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp04/node1/mp04.scn (deleted) * c/src/ada-tests/mptests/mp04/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp04/node2/mp04.scn (deleted) * c/src/ada-tests/mptests/mp05/.cvsignore (deleted) * c/src/ada-tests/mptests/mp05/mptest.adb (deleted) * c/src/ada-tests/mptests/mp05/mptest.ads (deleted) * c/src/ada-tests/mptests/mp05/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp05/node1/mp05.scn (deleted) * c/src/ada-tests/mptests/mp05/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp05/node2/mp05.scn (deleted) * c/src/ada-tests/mptests/mp06/.cvsignore (deleted) * c/src/ada-tests/mptests/mp06/mptest.adb (deleted) * c/src/ada-tests/mptests/mp06/mptest.ads (deleted) * c/src/ada-tests/mptests/mp06/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp06/node1/mp06.scn (deleted) * c/src/ada-tests/mptests/mp06/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp06/node2/mp06.scn (deleted) * c/src/ada-tests/mptests/mp07/.cvsignore (deleted) * c/src/ada-tests/mptests/mp07/mptest.adb (deleted) * c/src/ada-tests/mptests/mp07/mptest.ads (deleted) * c/src/ada-tests/mptests/mp07/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp07/node1/mp07.scn (deleted) * c/src/ada-tests/mptests/mp07/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp07/node2/mp07.scn (deleted) * c/src/ada-tests/mptests/mp08/.cvsignore (deleted) * c/src/ada-tests/mptests/mp08/mptest.adb (deleted) * c/src/ada-tests/mptests/mp08/mptest.ads (deleted) * c/src/ada-tests/mptests/mp08/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp08/node1/mp08.scn (deleted) * c/src/ada-tests/mptests/mp08/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp08/node2/mp08.scn (deleted) * c/src/ada-tests/mptests/mp09/.cvsignore (deleted) * c/src/ada-tests/mptests/mp09/mptest.adb (deleted) * c/src/ada-tests/mptests/mp09/mptest.ads (deleted) * c/src/ada-tests/mptests/mp09/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp09/node1/mp09.scn (deleted) * c/src/ada-tests/mptests/mp09/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp09/node2/mp09.scn (deleted) * c/src/ada-tests/mptests/mp10/.cvsignore (deleted) * c/src/ada-tests/mptests/mp10/mptest.adb (deleted) * c/src/ada-tests/mptests/mp10/mptest.ads (deleted) * c/src/ada-tests/mptests/mp10/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp10/node1/mp10.scn (deleted) * c/src/ada-tests/mptests/mp10/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp10/node2/mp10.scn (deleted) * c/src/ada-tests/mptests/mp11/.cvsignore (deleted) * c/src/ada-tests/mptests/mp11/mptest.adb (deleted) * c/src/ada-tests/mptests/mp11/mptest.ads (deleted) * c/src/ada-tests/mptests/mp11/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp11/node1/mp11.scn (deleted) * c/src/ada-tests/mptests/mp11/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp11/node2/mp11.scn (deleted) * c/src/ada-tests/mptests/mp12/.cvsignore (deleted) * c/src/ada-tests/mptests/mp12/mptest.adb (deleted) * c/src/ada-tests/mptests/mp12/mptest.ads (deleted) * c/src/ada-tests/mptests/mp12/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp12/node1/mp12.scn (deleted) * c/src/ada-tests/mptests/mp12/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp12/node2/mp12.scn (deleted) * c/src/ada-tests/mptests/mp13/.cvsignore (deleted) * c/src/ada-tests/mptests/mp13/mptest.adb (deleted) * c/src/ada-tests/mptests/mp13/mptest.ads (deleted) * c/src/ada-tests/mptests/mp13/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp13/node1/mp13.scn (deleted) * c/src/ada-tests/mptests/mp13/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp13/node2/mp13.scn (deleted) * c/src/ada-tests/mptests/mp14/.cvsignore (deleted) * c/src/ada-tests/mptests/mp14/mptest.adb (deleted) * c/src/ada-tests/mptests/mp14/mptest.ads (deleted) * c/src/ada-tests/mptests/mp14/node1/.cvsignore (deleted) * c/src/ada-tests/mptests/mp14/node1/mp14.scn (deleted) * c/src/ada-tests/mptests/mp14/node2/.cvsignore (deleted) * c/src/ada-tests/mptests/mp14/node2/mp14.scn (deleted) * c/src/ada-tests/sptests/Makefile.am (modified) 2003-07-17 Joel Sherrill PR 425/ada ... Wed, 09 Jul 2003 10:26:23 GMT Ralf Corsepius [9a9b17d] * c/src/ada-tests/sptests/sp16/Makefile.am (modified) * c/src/ada-tests/sptests/sp17/Makefile.am (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp20/Makefile.am (modified) * c/src/ada-tests/sptests/sp21/Makefile.am (modified) * c/src/ada-tests/sptests/sp22/Makefile.am (modified) * c/src/ada-tests/sptests/sp23/Makefile.am (modified) * c/src/ada-tests/sptests/sp24/Makefile.am (modified) * c/src/ada-tests/sptests/sp25/Makefile.am (modified) * c/src/ada-tests/sptests/spsize/Makefile.am (modified) * c/src/ada-tests/tmtests/tm01/Makefile.am (modified) * c/src/ada-tests/tmtests/tm02/Makefile.am (modified) * c/src/ada-tests/tmtests/tm03/Makefile.am (modified) * c/src/ada-tests/tmtests/tm04/Makefile.am (modified) * c/src/ada-tests/tmtests/tm05/Makefile.am (modified) * c/src/ada-tests/tmtests/tm06/Makefile.am (modified) * c/src/ada-tests/tmtests/tm07/Makefile.am (modified) * c/src/ada-tests/tmtests/tm08/Makefile.am (modified) * c/src/ada-tests/tmtests/tm09/Makefile.am (modified) * c/src/ada-tests/tmtests/tm10/Makefile.am (modified) * c/src/ada-tests/tmtests/tm11/Makefile.am (modified) * c/src/ada-tests/tmtests/tm12/Makefile.am (modified) * c/src/ada-tests/tmtests/tm13/Makefile.am (modified) * c/src/ada-tests/tmtests/tm14/Makefile.am (modified) * c/src/ada-tests/tmtests/tm15/Makefile.am (modified) * c/src/ada-tests/tmtests/tm16/Makefile.am (modified) * c/src/ada-tests/tmtests/tm17/Makefile.am (modified) * c/src/ada-tests/tmtests/tm18/Makefile.am (modified) * c/src/ada-tests/tmtests/tm19/Makefile.am (modified) * c/src/ada-tests/tmtests/tm20/Makefile.am (modified) * c/src/ada-tests/tmtests/tm21/Makefile.am (modified) * c/src/ada-tests/tmtests/tm22/Makefile.am (modified) * c/src/ada-tests/tmtests/tm23/Makefile.am (modified) * c/src/ada-tests/tmtests/tm24/Makefile.am (modified) * c/src/ada-tests/tmtests/tm25/Makefile.am (modified) * c/src/ada-tests/tmtests/tm28/Makefile.am (modified) * c/src/ada-tests/tmtests/tm29/Makefile.am (modified) * c/src/ada-tests/tmtests/tmck/Makefile.am (modified) * c/src/ada-tests/tmtests/tmoverhd/Makefile.am (modified) Merger from trunk Wed, 09 Jul 2003 10:17:48 GMT Ralf Corsepius [a4b8cd02] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/ada.am (modified) * c/src/ada-tests/samples/base_sp/Makefile.am (modified) * c/src/ada-tests/samples/hello/Makefile.am (modified) * c/src/ada-tests/samples/ticker/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/Makefile.am (modified) * c/src/ada-tests/sptests/sp02/Makefile.am (modified) * c/src/ada-tests/sptests/sp03/Makefile.am (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) * c/src/ada-tests/sptests/sp05/Makefile.am (modified) * c/src/ada-tests/sptests/sp06/Makefile.am (modified) * c/src/ada-tests/sptests/sp07/Makefile.am (modified) * c/src/ada-tests/sptests/sp08/Makefile.am (modified) * c/src/ada-tests/sptests/sp09/Makefile.am (modified) * c/src/ada-tests/sptests/sp11/Makefile.am (modified) * c/src/ada-tests/sptests/sp12/Makefile.am (modified) * c/src/ada-tests/sptests/sp13/Makefile.am (modified) * c/src/ada-tests/sptests/sp14/Makefile.am (modified) * c/src/ada-tests/sptests/sp15/Makefile.am (modified) Merger from trunk Thu, 06 Mar 2003 10:45:24 GMT Ralf Corsepius [b18646c9] * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/configure.ac (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/configure.ac (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/a29k/configure.ac (modified) * c/src/lib/libcpu/configure.ac (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/libchip/ChangeLog (modified) * c/src/libchip/configure.ac (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/configure.ac (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/optman/ChangeLog (modified) * c/src/optman/configure.ac (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/configure.ac (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/itrontests/configure.ac (modified) * c/src/tests/libtests/ChangeLog (modified) * c/src/tests/libtests/configure.ac (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/mptests/configure.ac (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/configure.ac (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/samples/configure.ac (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/configure.ac (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/configure.ac (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmitrontests/configure.ac (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tmtests/configure.ac (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/configure.ac (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/tests/tools/generic/configure.ac (modified) 2003-03-06 Ralf Corsepius * ... Tue, 11 Feb 2003 11:47:49 GMT Ralf Corsepius [ccd81b60] * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada/ChangeLog (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/configure.ac (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/configure.ac (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/a29k/configure.ac (modified) * c/src/lib/libcpu/configure.ac (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/libchip/ChangeLog (modified) * c/src/libchip/configure.ac (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/configure.ac (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/optman/ChangeLog (modified) * c/src/optman/configure.ac (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/configure.ac (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/itrontests/configure.ac (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/mptests/configure.ac (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/configure.ac (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/samples/configure.ac (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/configure.ac (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/configure.ac (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmitrontests/configure.ac (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tmtests/configure.ac (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/configure.ac (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/tests/tools/generic/configure.ac (modified) * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/configure.ac (modified) * contrib/solaris/ChangeLog (modified) * contrib/solaris/configure.ac (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/ChangeLog (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/hppa1.1/ChangeLog (modified) * tools/cpu/hppa1.1/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) * tools/update/ChangeLog (modified) * tools/update/configure.ac (modified) 2003-02-11 Ralf Corsepius * ... Tue, 11 Feb 2003 11:11:33 GMT Ralf Corsepius [9b5c258] * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada/ChangeLog (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/configure.ac (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/configure.ac (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/a29k/configure.ac (modified) * c/src/lib/libcpu/configure.ac (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/libchip/ChangeLog (modified) * c/src/libchip/configure.ac (modified) * c/src/libnetworking/configure.ac (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/optman/ChangeLog (modified) * c/src/optman/configure.ac (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/configure.ac (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/itrontests/configure.ac (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/mptests/configure.ac (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/configure.ac (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/samples/configure.ac (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/configure.ac (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/configure.ac (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmitrontests/configure.ac (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tmtests/configure.ac (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/configure.ac (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/tests/tools/generic/configure.ac (modified) * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/configure.ac (modified) * contrib/solaris/ChangeLog (modified) * contrib/solaris/configure.ac (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/ChangeLog (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/hppa1.1/ChangeLog (modified) * tools/cpu/hppa1.1/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) * tools/update/ChangeLog (modified) * tools/update/configure.ac (modified) 2003-02-11 Ralf Corsepius * ... Fri, 03 Jan 2003 22:51:40 GMT Joel Sherrill [0f9e7f96] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/ada.am (modified) * c/src/ada-tests/samples/ticker/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/config.h (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) * c/src/ada-tests/sptests/sp04/config.h (modified) * c/src/ada-tests/support/init.c (modified) 2003-01-03 Joel Sherrill * ada.am, ... Fri, 03 Jan 2003 21:14:04 GMT Joel Sherrill [ea14663] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/Makefile.am (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/samples/Makefile.am (modified) 2003-01-03 Joel Sherrill * ... Fri, 06 Dec 2002 06:48:05 GMT Ralf Corsepius [f69283e2] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/optman/ChangeLog (modified) * c/src/optman/configure.ac (modified) 2002-12-06 Ralf Corsepius * ... Thu, 24 Oct 2002 22:34:22 GMT Joel Sherrill [698b292] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/hello/config.h (modified) * c/src/ada-tests/support/init.c (modified) 2002-10-24 Joel Sherrill * ... Mon, 21 Oct 2002 12:19:27 GMT Ralf Corsepius [8730f45] * .cvsignore (modified) * ChangeLog (modified) * c/make/.cvsignore (modified) * c/make/ChangeLog (modified) * c/src/ada-tests/.cvsignore (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/lib/.cvsignore (modified) * c/src/lib/ChangeLog (modified) * c/src/lib/libbsp/.cvsignore (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/.cvsignore (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/.cvsignore (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/arm/.cvsignore (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/.cvsignore (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/.cvsignore (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/.cvsignore (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/bare/.cvsignore (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/c4x/.cvsignore (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/h8300/.cvsignore (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/.cvsignore (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/.cvsignore (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/.cvsignore (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i960/.cvsignore (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/.cvsignore (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/.cvsignore (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/.cvsignore (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/m68k/.cvsignore (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/.cvsignore (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/.cvsignore (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/.cvsignore (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/.cvsignore (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/.cvsignore (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/.cvsignore (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/.cvsignore (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/.cvsignore (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/.cvsignore (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/mips/.cvsignore (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/.cvsignore (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/.cvsignore (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/.cvsignore (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/.cvsignore (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/or32/.cvsignore (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/.cvsignore (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/powerpc/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/.cvsignore (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/.cvsignore (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/.cvsignore (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/.cvsignore (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/.cvsignore (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/.cvsignore (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/.cvsignore (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/.cvsignore (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/.cvsignore (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/.cvsignore (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/sh/.cvsignore (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/.cvsignore (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/.cvsignore (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sparc/.cvsignore (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/.cvsignore (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libcpu/.cvsignore (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/.cvsignore (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/.cvsignore (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/i386/.cvsignore (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i960/.cvsignore (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/m68k/.cvsignore (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/.cvsignore (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/mips/.cvsignore (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/.cvsignore (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/powerpc/.cvsignore (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/.cvsignore (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sparc/.cvsignore (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/libchip/.cvsignore (modified) * c/src/libchip/ChangeLog (modified) * c/src/libmisc/.cvsignore (modified) * c/src/libmisc/ChangeLog (modified) * c/src/libnetworking/.cvsignore (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/librdbg/.cvsignore (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librtems++/.cvsignore (modified) * c/src/librtems++/ChangeLog (modified) * c/src/make/.cvsignore (modified) * c/src/make/ChangeLog (modified) * c/src/tests/.cvsignore (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/itrontests/.cvsignore (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/libtests/.cvsignore (modified) * c/src/tests/libtests/ChangeLog (modified) * c/src/tests/mptests/.cvsignore (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/psxtests/.cvsignore (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/samples/.cvsignore (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/sptests/.cvsignore (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/support/.cvsignore (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/tmitrontests/.cvsignore (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmtests/.cvsignore (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tools/.cvsignore (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/generic/.cvsignore (modified) * c/src/tests/tools/generic/ChangeLog (modified) * contrib/cygwin/.cvsignore (modified) * contrib/cygwin/ChangeLog (modified) * contrib/solaris/.cvsignore (modified) * contrib/solaris/ChangeLog (modified) * cpukit/libmisc/.cvsignore (modified) * cpukit/libmisc/ChangeLog (modified) * doc/.cvsignore (modified) * doc/ChangeLog (modified) * doc/tools/.cvsignore (modified) * doc/tools/ChangeLog (modified) * scripts/.cvsignore (modified) * scripts/ChangeLog (modified) * testsuites/.cvsignore (modified) * testsuites/ChangeLog (modified) * testsuites/itrontests/.cvsignore (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/libtests/.cvsignore (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/mptests/.cvsignore (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/psxtests/.cvsignore (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/samples/.cvsignore (modified) * testsuites/samples/ChangeLog (modified) * testsuites/sptests/.cvsignore (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/support/.cvsignore (modified) * testsuites/support/ChangeLog (modified) * testsuites/tmitrontests/.cvsignore (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmtests/.cvsignore (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tools/.cvsignore (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/generic/.cvsignore (modified) * testsuites/tools/generic/ChangeLog (modified) 2002-10-21 Ralf Corsepius * ... Wed, 09 Oct 2002 20:22:13 GMT Ralf Corsepius [ff8676ef] * c/src/ada-tests/.cvsignore (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/.cvsignore (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/optman/.cvsignore (modified) * c/src/optman/ChangeLog (modified) * doc/tools/.cvsignore (modified) * doc/tools/ChangeLog (modified) 2002-10-09 Ralf Corsepius * ... Sat, 14 Sep 2002 21:05:44 GMT Joel Sherrill [eefdc85] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/support/test_support.adb (modified) 2002-09-14 Joel Sherrill * ... Fri, 13 Sep 2002 17:34:10 GMT Joel Sherrill [d814e2c] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) 2002-09-13 Joel Sherrill * ... Fri, 13 Sep 2002 17:00:18 GMT Joel Sherrill [d7ff09b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/hello/Makefile.am (modified) 2002-09-13 Joel Sherrill * ... Sat, 07 Sep 2002 23:12:07 GMT Joel Sherrill [4e7ba21] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/base_mp/config.h (added) 2002-09-07 Joel Sherrill * ... Tue, 03 Sep 2002 18:31:23 GMT Joel Sherrill [addebe67] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_mp/mptest.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (deleted) 2002-09-03 Joel Sherrill * base_mp ... Mon, 02 Sep 2002 05:19:01 GMT Ralf Corsepius [7625d9a3] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp01/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp02/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp02/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp03/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp03/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp04/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp04/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp05/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp05/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp06/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp06/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp07/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp07/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp08/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp08/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp09/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp09/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp10/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp10/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp11/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp11/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp12/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp12/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp13/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp13/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp14/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp14/node2/.cvsignore (added) * c/src/ada-tests/samples/base_mp/node1/.cvsignore (added) * c/src/ada-tests/samples/base_mp/node2/.cvsignore (added) 2002-09-02 Ralf Corsepius * ... Mon, 02 Sep 2002 05:08:57 GMT Ralf Corsepius [0c7ef52] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/mptests/Makefile.am (added) * c/src/ada-tests/mptests/mp01/Makefile.am (added) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (added) * c/src/ada-tests/samples/base_mp/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (added) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (added) 2002-09-02 Ralf Corsepius * ... Fri, 30 Aug 2002 12:14:51 GMT Ralf Corsepius [2d9c50b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/tm20/Makefile.am (modified) 2002-08-30 Ralf Corsepius * ... Fri, 30 Aug 2002 12:09:48 GMT Joel Sherrill [b83fd620] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) 2002-08-30 Joel Sherrill * ... Wed, 28 Aug 2002 17:35:01 GMT Joel Sherrill [b29709d] * c/src/ada-tests/ChangeLog (modified) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 20:25:20 GMT Joel Sherrill [40edeae] * c/src/ada-tests/samples/base_mp/.cvsignore (added) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 17:06:30 GMT Ralf Corsepius [bf6fa0f4] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp09/Makefile.am (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp21/Makefile.am (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) 2002-08-27 Ralf Corsepius * ... Tue, 27 Aug 2002 14:05:45 GMT Joel Sherrill [cbb09503] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 13:35:42 GMT Ralf Corsepius [abe09384] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (modified) 2002-08-27 Ralf Corsepius * ... Tue, 27 Aug 2002 13:17:27 GMT Ralf Corsepius [d73a01fd] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp19/sptest.adb (deleted) 2002-08-27 Ralf Corsepius * ... Tue, 27 Aug 2002 13:12:04 GMT Joel Sherrill [e8c20a0] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 11:48:54 GMT Joel Sherrill [b0e8b47e] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sptest.adp (added) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 11:45:33 GMT Joel Sherrill [3634ed9] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/tm27/.cvsignore (deleted) 2002-08-27 Joel Sherrill * ... Tue, 27 Aug 2002 07:47:42 GMT Ralf Corsepius [f3013b8] * c/src/ada-tests/tmtests/tm26/.cvsignore (deleted) Removed Tue, 27 Aug 2002 06:57:46 GMT Ralf Corsepius [a846105] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/ada.am (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) 2002-08-27 Ralf Corsepius * ... Mon, 26 Aug 2002 17:25:59 GMT Joel Sherrill [c94a454] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/tm26/config.h (deleted) * c/src/ada-tests/tmtests/tm27/config.h (deleted) 2002-08-26 Joel Sherrill * tm27 and ... Mon, 26 Aug 2002 17:24:44 GMT Joel Sherrill [b2b7cfc9] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/tmtests/Makefile.am (modified) * c/src/ada-tests/tmtests/tm26/Makefile.am (deleted) * c/src/ada-tests/tmtests/tm26/README (deleted) * c/src/ada-tests/tmtests/tm26/tm26.adb (deleted) * c/src/ada-tests/tmtests/tm26/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm26/tmtest.adp (deleted) * c/src/ada-tests/tmtests/tm26/tmtest.ads (deleted) * c/src/ada-tests/tmtests/tm27/Makefile.am (deleted) * c/src/ada-tests/tmtests/tm27/README (deleted) * c/src/ada-tests/tmtests/tm27/tm27.adb (deleted) * c/src/ada-tests/tmtests/tm27/tmtest.adb (deleted) * c/src/ada-tests/tmtests/tm27/tmtest.ads (deleted) 2002-08-26 Joel Sherrill * tm27 and ... Mon, 26 Aug 2002 17:20:36 GMT Joel Sherrill [f435621b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (added) * c/src/ada-tests/sptests/sp19/sptest.adb (modified) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 14:27:21 GMT Joel Sherrill [190f5c23] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/mptest.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 13:44:35 GMT Joel Sherrill [8a0e8da] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp19/sptest.adb (moved) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 13:37:16 GMT Joel Sherrill [61cd8db] * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 10:10:43 GMT Ralf Corsepius [2085b08e] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 09:38:29 GMT Ralf Corsepius [7edb3d3a] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/Makefile.am (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/samples/base_mp/Makefile.am (modified) * c/src/ada-tests/sptests/sp01/Makefile.am (modified) * c/src/ada-tests/sptests/sp02/Makefile.am (modified) * c/src/ada-tests/sptests/sp03/Makefile.am (modified) * c/src/ada-tests/sptests/sp04/Makefile.am (modified) * c/src/ada-tests/sptests/sp05/Makefile.am (modified) * c/src/ada-tests/sptests/sp06/Makefile.am (modified) * c/src/ada-tests/sptests/sp07/Makefile.am (modified) * c/src/ada-tests/sptests/sp08/Makefile.am (modified) * c/src/ada-tests/sptests/sp09/Makefile.am (modified) * c/src/ada-tests/sptests/sp11/Makefile.am (modified) * c/src/ada-tests/sptests/sp12/Makefile.am (modified) * c/src/ada-tests/sptests/sp13/Makefile.am (modified) * c/src/ada-tests/sptests/sp14/Makefile.am (modified) * c/src/ada-tests/sptests/sp15/Makefile.am (modified) * c/src/ada-tests/sptests/sp16/Makefile.am (modified) * c/src/ada-tests/sptests/sp17/Makefile.am (modified) * c/src/ada-tests/sptests/sp19/Makefile.am (modified) * c/src/ada-tests/sptests/sp20/Makefile.am (modified) * c/src/ada-tests/sptests/sp21/Makefile.am (modified) * c/src/ada-tests/sptests/sp22/Makefile.am (modified) * c/src/ada-tests/sptests/sp23/Makefile.am (modified) * c/src/ada-tests/sptests/sp24/Makefile.am (modified) * c/src/ada-tests/sptests/sp25/Makefile.am (modified) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 09:27:51 GMT Ralf Corsepius [0270bc8] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/tmtests/Makefile.am (added) * c/src/ada-tests/tmtests/tm01/Makefile.am (added) * c/src/ada-tests/tmtests/tm02/Makefile.am (added) * c/src/ada-tests/tmtests/tm03/Makefile.am (added) * c/src/ada-tests/tmtests/tm04/Makefile.am (added) * c/src/ada-tests/tmtests/tm05/Makefile.am (added) * c/src/ada-tests/tmtests/tm06/Makefile.am (added) * c/src/ada-tests/tmtests/tm07/Makefile.am (added) * c/src/ada-tests/tmtests/tm08/Makefile.am (added) * c/src/ada-tests/tmtests/tm09/Makefile.am (added) * c/src/ada-tests/tmtests/tm10/Makefile.am (added) * c/src/ada-tests/tmtests/tm11/Makefile.am (added) * c/src/ada-tests/tmtests/tm12/Makefile.am (added) * c/src/ada-tests/tmtests/tm13/Makefile.am (added) * c/src/ada-tests/tmtests/tm14/Makefile.am (added) * c/src/ada-tests/tmtests/tm15/Makefile.am (added) * c/src/ada-tests/tmtests/tm16/Makefile.am (added) * c/src/ada-tests/tmtests/tm17/Makefile.am (added) * c/src/ada-tests/tmtests/tm18/Makefile.am (added) * c/src/ada-tests/tmtests/tm19/Makefile.am (added) * c/src/ada-tests/tmtests/tm20/Makefile.am (added) * c/src/ada-tests/tmtests/tm21/Makefile.am (added) * c/src/ada-tests/tmtests/tm22/Makefile.am (added) * c/src/ada-tests/tmtests/tm23/Makefile.am (added) * c/src/ada-tests/tmtests/tm24/Makefile.am (added) * c/src/ada-tests/tmtests/tm25/Makefile.am (added) * c/src/ada-tests/tmtests/tm26/Makefile.am (added) * c/src/ada-tests/tmtests/tm26/tmtest.adb (added) * c/src/ada-tests/tmtests/tm27/Makefile.am (added) * c/src/ada-tests/tmtests/tm28/Makefile.am (added) * c/src/ada-tests/tmtests/tm29/Makefile.am (added) * c/src/ada-tests/tmtests/tmck/Makefile.am (added) * c/src/ada-tests/tmtests/tmoverhd/Makefile.am (added) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 06:12:08 GMT Ralf Corsepius [2af6056] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/Makefile.am (added) * c/src/ada-tests/ada.am (added) * c/src/ada-tests/configure.ac (added) * c/src/ada-tests/samples/Makefile.am (added) * c/src/ada-tests/samples/base_mp/Makefile.am (added) * c/src/ada-tests/samples/base_sp/Makefile.am (added) * c/src/ada-tests/samples/hello/Makefile.am (added) * c/src/ada-tests/samples/ticker/Makefile.am (added) * c/src/ada-tests/support/Makefile.am (added) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 06:04:49 GMT Ralf Corsepius [1a5f405b] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/sptests/Makefile.am (added) * c/src/ada-tests/sptests/sp01/Makefile.am (added) * c/src/ada-tests/sptests/sp02/Makefile.am (added) * c/src/ada-tests/sptests/sp03/Makefile.am (added) * c/src/ada-tests/sptests/sp04/Makefile.am (added) * c/src/ada-tests/sptests/sp05/Makefile.am (added) * c/src/ada-tests/sptests/sp06/Makefile.am (added) * c/src/ada-tests/sptests/sp07/Makefile.am (added) * c/src/ada-tests/sptests/sp08/Makefile.am (added) * c/src/ada-tests/sptests/sp09/Makefile.am (added) * c/src/ada-tests/sptests/sp11/Makefile.am (added) * c/src/ada-tests/sptests/sp12/Makefile.am (added) * c/src/ada-tests/sptests/sp13/Makefile.am (added) * c/src/ada-tests/sptests/sp14/Makefile.am (added) * c/src/ada-tests/sptests/sp15/Makefile.am (added) * c/src/ada-tests/sptests/sp16/Makefile.am (added) * c/src/ada-tests/sptests/sp17/Makefile.am (added) * c/src/ada-tests/sptests/sp19/Makefile.am (added) * c/src/ada-tests/sptests/sp20/Makefile.am (added) * c/src/ada-tests/sptests/sp21/Makefile.am (added) * c/src/ada-tests/sptests/sp22/Makefile.am (added) * c/src/ada-tests/sptests/sp23/Makefile.am (added) * c/src/ada-tests/sptests/sp24/Makefile.am (added) * c/src/ada-tests/sptests/sp25/Makefile.am (added) * c/src/ada-tests/sptests/spsize/Makefile.am (added) 2002-08-26 Ralf Corsepius * ... Mon, 26 Aug 2002 05:51:56 GMT Ralf Corsepius [28cf529] * c/src/ada-tests/.cvsignore (added) * c/src/ada-tests/ChangeLog (added) * c/src/ada-tests/mptests/.cvsignore (added) * c/src/ada-tests/mptests/mp01/.cvsignore (added) * c/src/ada-tests/mptests/mp02/.cvsignore (added) * c/src/ada-tests/mptests/mp03/.cvsignore (added) * c/src/ada-tests/mptests/mp04/.cvsignore (added) * c/src/ada-tests/mptests/mp05/.cvsignore (added) * c/src/ada-tests/mptests/mp06/.cvsignore (added) * c/src/ada-tests/mptests/mp07/.cvsignore (added) * c/src/ada-tests/mptests/mp08/.cvsignore (added) * c/src/ada-tests/mptests/mp09/.cvsignore (added) * c/src/ada-tests/mptests/mp10/.cvsignore (added) * c/src/ada-tests/mptests/mp11/.cvsignore (added) * c/src/ada-tests/mptests/mp12/.cvsignore (added) * c/src/ada-tests/mptests/mp13/.cvsignore (added) * c/src/ada-tests/mptests/mp14/.cvsignore (added) * c/src/ada-tests/samples/.cvsignore (added) * c/src/ada-tests/samples/base_sp/.cvsignore (added) * c/src/ada-tests/samples/hello/.cvsignore (added) * c/src/ada-tests/samples/ticker/.cvsignore (added) * c/src/ada-tests/sptests/.cvsignore (added) * c/src/ada-tests/sptests/sp01/.cvsignore (added) * c/src/ada-tests/sptests/sp02/.cvsignore (added) * c/src/ada-tests/sptests/sp03/.cvsignore (added) * c/src/ada-tests/sptests/sp04/.cvsignore (added) * c/src/ada-tests/sptests/sp05/.cvsignore (added) * c/src/ada-tests/sptests/sp06/.cvsignore (added) * c/src/ada-tests/sptests/sp07/.cvsignore (added) * c/src/ada-tests/sptests/sp08/.cvsignore (added) * c/src/ada-tests/sptests/sp09/.cvsignore (added) * c/src/ada-tests/sptests/sp11/.cvsignore (added) * c/src/ada-tests/sptests/sp12/.cvsignore (added) * c/src/ada-tests/sptests/sp13/.cvsignore (added) * c/src/ada-tests/sptests/sp14/.cvsignore (added) * c/src/ada-tests/sptests/sp15/.cvsignore (added) * c/src/ada-tests/sptests/sp16/.cvsignore (added) * c/src/ada-tests/sptests/sp17/.cvsignore (added) * c/src/ada-tests/sptests/sp19/.cvsignore (added) * c/src/ada-tests/sptests/sp20/.cvsignore (added) * c/src/ada-tests/sptests/sp21/.cvsignore (added) * c/src/ada-tests/sptests/sp22/.cvsignore (added) * c/src/ada-tests/sptests/sp23/.cvsignore (added) * c/src/ada-tests/sptests/sp24/.cvsignore (added) * c/src/ada-tests/sptests/sp25/.cvsignore (added) * c/src/ada-tests/sptests/spsize/.cvsignore (added) * c/src/ada-tests/support/.cvsignore (added) * c/src/ada-tests/tmtests/.cvsignore (added) * c/src/ada-tests/tmtests/tm01/.cvsignore (added) * c/src/ada-tests/tmtests/tm02/.cvsignore (added) * c/src/ada-tests/tmtests/tm03/.cvsignore (added) * c/src/ada-tests/tmtests/tm04/.cvsignore (added) * c/src/ada-tests/tmtests/tm05/.cvsignore (added) * c/src/ada-tests/tmtests/tm06/.cvsignore (added) * c/src/ada-tests/tmtests/tm07/.cvsignore (added) * c/src/ada-tests/tmtests/tm08/.cvsignore (added) * c/src/ada-tests/tmtests/tm09/.cvsignore (added) * c/src/ada-tests/tmtests/tm10/.cvsignore (added) * c/src/ada-tests/tmtests/tm11/.cvsignore (added) * c/src/ada-tests/tmtests/tm12/.cvsignore (added) * c/src/ada-tests/tmtests/tm13/.cvsignore (added) * c/src/ada-tests/tmtests/tm14/.cvsignore (added) * c/src/ada-tests/tmtests/tm15/.cvsignore (added) * c/src/ada-tests/tmtests/tm16/.cvsignore (added) * c/src/ada-tests/tmtests/tm17/.cvsignore (added) * c/src/ada-tests/tmtests/tm18/.cvsignore (added) * c/src/ada-tests/tmtests/tm19/.cvsignore (added) * c/src/ada-tests/tmtests/tm20/.cvsignore (added) * c/src/ada-tests/tmtests/tm21/.cvsignore (added) * c/src/ada-tests/tmtests/tm22/.cvsignore (added) * c/src/ada-tests/tmtests/tm23/.cvsignore (added) * c/src/ada-tests/tmtests/tm24/.cvsignore (added) * c/src/ada-tests/tmtests/tm25/.cvsignore (added) * c/src/ada-tests/tmtests/tm26/.cvsignore (added) * c/src/ada-tests/tmtests/tm27/.cvsignore (added) * c/src/ada-tests/tmtests/tm28/.cvsignore (added) * c/src/ada-tests/tmtests/tm29/.cvsignore (added) * c/src/ada-tests/tmtests/tmck/.cvsignore (added) * c/src/ada-tests/tmtests/tmoverhd/.cvsignore (added) 2002-08-26 Ralf Corsepius * ... Thu, 29 Oct 1998 17:10:02 GMT Joel Sherrill [a47bd655] * c/src/ada-tests/support/init.c (modified) Cleanup. Wed, 04 Jun 1997 18:54:18 GMT Joel Sherrill [e7f86ef] * c/src/ada-tests/mptests/mp01/config.h (added) * c/src/ada-tests/mptests/mp01/mp01.adb (added) new file Tue, 03 Jun 1997 23:04:25 GMT Joel Sherrill [b42675f] * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm26/tm26.adb (modified) * c/src/ada-tests/tmtests/tm27/tm27.adb (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) corrected name of test suite Tue, 03 Jun 1997 23:00:45 GMT Joel Sherrill [1e97a20] * c/src/ada-tests/samples/hello/hello.adb (modified) fixed comment Tue, 03 Jun 1997 22:58:48 GMT Joel Sherrill [9b3853a] * c/src/ada-tests/samples/ticker/sptest.ads (modified) Removed configuration information. Tue, 03 Jun 1997 22:57:58 GMT Joel Sherrill [430d81a] * c/src/ada-tests/samples/base_sp/base_sp.adb (added) * c/src/ada-tests/samples/base_sp/config.h (added) * c/src/ada-tests/samples/ticker/config.h (added) * c/src/ada-tests/samples/ticker/ticker.adb (added) new file Tue, 03 Jun 1997 22:54:45 GMT Joel Sherrill [08c192b] * c/src/ada-tests/samples/base_sp/sptest.ads (modified) Removed Configuration Information. Tue, 03 Jun 1997 22:52:39 GMT Joel Sherrill [8640cc99] * c/src/ada-tests/samples/hello/config.h (added) * c/src/ada-tests/samples/hello/hello.adb (added) new files. Tue, 03 Jun 1997 22:52:34 GMT Joel Sherrill [4fd88bc] * c/src/ada-tests/samples/hello/sptest.ads (modified) Removed configuration information. Tue, 03 Jun 1997 22:49:47 GMT Joel Sherrill [5d0f4a56] * c/src/ada-tests/support/rtems_calling_overhead.ads (added) * c/src/ada-tests/support/time_test_support.adb (added) * c/src/ada-tests/support/time_test_support.ads (added) * c/src/ada-tests/support/timer_driver.adb (added) * c/src/ada-tests/support/timer_driver.ads (added) new files Tue, 03 Jun 1997 22:49:19 GMT Joel Sherrill [7c498800] * c/src/ada-tests/tmtests/tmoverhd/README (added) new file. Tue, 03 Jun 1997 22:47:47 GMT Joel Sherrill [8ed37e3c] * c/src/ada-tests/tmtests/tmoverhd/config.h (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) corrected to compile with the new binding. Tue, 03 Jun 1997 22:40:57 GMT Joel Sherrill [1b141533] * c/src/ada-tests/tmtests/tmck/config.h (modified) Corrected for this test. Tue, 03 Jun 1997 22:39:55 GMT Joel Sherrill [2bef691] * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) Added correct contents Tue, 03 Jun 1997 22:38:10 GMT Joel Sherrill [5363249] * c/src/ada-tests/tmtests/tm26/README (added) * c/src/ada-tests/tmtests/tm26/tmtest.adp (added) * c/src/ada-tests/tmtests/tm27/README (added) * c/src/ada-tests/tmtests/tmck/config.h (added) new file Tue, 03 Jun 1997 22:22:52 GMT Joel Sherrill [2ef9d4a] * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) Corrected maximum number of messages to be non-zero Tue, 03 Jun 1997 22:21:18 GMT Joel Sherrill [6e98a517] * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) removed reference to Stub Device Driver Tue, 03 Jun 1997 22:18:54 GMT Joel Sherrill [f94917d7] * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) Replaced prototype for Last_Task which was accidentally removed when ... Tue, 03 Jun 1997 22:16:25 GMT Joel Sherrill [46063740] * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems. Tue, 03 Jun 1997 22:11:55 GMT Joel Sherrill [e3b4ccd] * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) Fixed incorrect invocation of Message_Queue_Create Tue, 03 Jun 1997 22:10:18 GMT Joel Sherrill [79e0b6fd] * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) fixed typo which resulted in Message_Queue_Create being invoked ... Tue, 03 Jun 1997 22:08:59 GMT Joel Sherrill [688ecaa0] * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) Fixed calls to Message_Queue_Create to include maximum message size ... Tue, 03 Jun 1997 22:06:49 GMT Joel Sherrill [e17ffea] * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) Changed to variable length messages. Tue, 03 Jun 1997 21:48:57 GMT Joel Sherrill [bc35a6ef] * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0. Tue, 03 Jun 1997 21:46:18 GMT Joel Sherrill [1338cdb] * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0. Tue, 03 Jun 1997 21:43:20 GMT Joel Sherrill [c7f646b5] * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) Fixed all references to Semaphore_Create to have the correct ... Tue, 03 Jun 1997 21:39:35 GMT Joel Sherrill [9db72b4] * c/src/ada-tests/tmtests/tm02/config.h (added) * c/src/ada-tests/tmtests/tm03/config.h (added) * c/src/ada-tests/tmtests/tm04/config.h (added) * c/src/ada-tests/tmtests/tm05/config.h (added) * c/src/ada-tests/tmtests/tm06/config.h (added) * c/src/ada-tests/tmtests/tm07/config.h (added) * c/src/ada-tests/tmtests/tm08/config.h (added) * c/src/ada-tests/tmtests/tm09/config.h (added) * c/src/ada-tests/tmtests/tm10/config.h (added) * c/src/ada-tests/tmtests/tm11/config.h (added) * c/src/ada-tests/tmtests/tm12/config.h (added) * c/src/ada-tests/tmtests/tm13/config.h (added) * c/src/ada-tests/tmtests/tm14/config.h (added) * c/src/ada-tests/tmtests/tm15/config.h (added) * c/src/ada-tests/tmtests/tm16/config.h (added) * c/src/ada-tests/tmtests/tm17/config.h (added) * c/src/ada-tests/tmtests/tm18/config.h (added) * c/src/ada-tests/tmtests/tm19/config.h (added) * c/src/ada-tests/tmtests/tm20/config.h (added) * c/src/ada-tests/tmtests/tm21/config.h (added) * c/src/ada-tests/tmtests/tm22/config.h (added) * c/src/ada-tests/tmtests/tm23/config.h (added) * c/src/ada-tests/tmtests/tm24/config.h (added) * c/src/ada-tests/tmtests/tm25/config.h (added) * c/src/ada-tests/tmtests/tm26/config.h (added) * c/src/ada-tests/tmtests/tm27/config.h (added) * c/src/ada-tests/tmtests/tm28/config.h (added) * c/src/ada-tests/tmtests/tm29/config.h (added) New file. Tue, 03 Jun 1997 21:27:16 GMT Joel Sherrill [4b067069] * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm07/tm07.adb (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm26/tm26.adb (modified) * c/src/ada-tests/tmtests/tm27/tm27.adb (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) new file Tue, 03 Jun 1997 20:24:11 GMT Joel Sherrill [b4be04e] * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm26/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm27/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) Removed Configuration Table information. Tue, 03 Jun 1997 20:20:39 GMT Joel Sherrill [7b93a327] * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) Corrected call to Semaphore_Create to have the proper calling sequence Tue, 03 Jun 1997 20:20:23 GMT Joel Sherrill [b67e6ec] * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) Removed Configuration Table information Tue, 03 Jun 1997 20:20:10 GMT Joel Sherrill [43437e97] * c/src/ada-tests/tmtests/tm01/config.h (added) * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) new file Tue, 03 Jun 1997 19:26:36 GMT Joel Sherrill [f222e9d4] * c/src/ada-tests/sptests/sp25/sptest.adb (modified) Removed unnecessary dependency on RTEMS_Test_Support which existed ... Tue, 03 Jun 1997 19:25:56 GMT Joel Sherrill [a1ceec8] * c/src/ada-tests/sptests/sp20/config.h (added) * c/src/ada-tests/sptests/sp21/config.h (added) * c/src/ada-tests/sptests/sp22/config.h (added) * c/src/ada-tests/sptests/sp23/config.h (added) * c/src/ada-tests/sptests/sp24/config.h (added) * c/src/ada-tests/sptests/sp25/config.h (added) new file Tue, 03 Jun 1997 19:21:25 GMT Joel Sherrill [be1618a] * c/src/ada-tests/sptests/sp21/sptest.ads (modified) removed reference to the Stub Device Driver Tue, 03 Jun 1997 19:18:15 GMT Joel Sherrill [d6a9988] * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) Changed mode and priority of initialization task. Tue, 03 Jun 1997 18:38:58 GMT Joel Sherrill [5687a1e9] * c/src/ada-tests/sptests/sp19/sp19.adb (modified) Changed attribute of Initialization Task to Floating_Point Tue, 03 Jun 1997 18:38:40 GMT Joel Sherrill [ac953f2] * c/src/ada-tests/sptests/sp19/README (added) * c/src/ada-tests/sptests/sp19/config.h (added) new files Tue, 03 Jun 1997 18:37:40 GMT Joel Sherrill [dc300df] * c/src/ada-tests/support/float_io.ads (added) * c/src/ada-tests/support/fp.inc (added) * c/src/ada-tests/support/integer.inc (added) new file Tue, 03 Jun 1997 18:28:38 GMT Joel Sherrill [82870ab] * c/src/ada-tests/sptests/sp03/config.h (added) * c/src/ada-tests/sptests/sp04/config.h (added) * c/src/ada-tests/sptests/sp05/config.h (added) * c/src/ada-tests/sptests/sp06/config.h (added) * c/src/ada-tests/sptests/sp07/config.h (added) * c/src/ada-tests/sptests/sp08/config.h (added) * c/src/ada-tests/sptests/sp09/config.h (added) * c/src/ada-tests/sptests/sp11/config.h (added) * c/src/ada-tests/sptests/sp12/config.h (added) * c/src/ada-tests/sptests/sp13/config.h (added) * c/src/ada-tests/sptests/sp14/config.h (added) * c/src/ada-tests/sptests/sp15/config.h (added) * c/src/ada-tests/sptests/sp16/config.h (added) * c/src/ada-tests/sptests/sp17/config.h (added) new file Tue, 03 Jun 1997 18:28:23 GMT Joel Sherrill [91c78ffd] * c/src/ada-tests/sptests/sp17/sptest.ads (modified) Changed from RTEMS.Boolean to Standard.Boolean to avoid problems. Tue, 03 Jun 1997 18:07:51 GMT Joel Sherrill [93bd518] * c/src/ada-tests/support/address_io.adb (added) * c/src/ada-tests/support/address_io.ads (added) new files Tue, 03 Jun 1997 18:06:46 GMT Joel Sherrill [9bec37b] * c/src/ada-tests/sptests/sp14/sptest.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) Switched to proper types for booleans and increased the stack space ... Tue, 03 Jun 1997 16:00:00 GMT Joel Sherrill [a7156d1] * c/src/ada-tests/sptests/sp13/sptest.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) Modifed to make the test run to completion. Primarily provided the ... Tue, 03 Jun 1997 15:40:24 GMT Joel Sherrill [98150020] * c/src/ada-tests/support/test_support.adb (modified) Commented out exception handling code since these routines are not ... Tue, 03 Jun 1997 15:39:28 GMT Joel Sherrill [4db9c861] * c/src/ada-tests/sptests/sp13/sptest.adb (modified) removed with of unchecked_conversion Tue, 03 Jun 1997 15:25:28 GMT Joel Sherrill [e351c26a] * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.adb (modified) sptest.adb: update Semaphore_Create calling sequence sp12.adb: ... Tue, 03 Jun 1997 15:12:23 GMT Joel Sherrill [c1ef834] * c/src/ada-tests/sptests/sp09/sp09.scn (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) Fixed problems which prevented the test from compiling and running to ... Tue, 03 Jun 1997 00:56:11 GMT Joel Sherrill [7d366f1c] * c/src/ada-tests/sptests/sp09/sptest.adb (modified) changed reference for Configuration Table from BSP to RTEMS. Tue, 03 Jun 1997 00:34:04 GMT Joel Sherrill [d0f426a1] * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/support/test_support.adb (modified) *** empty log message *** Tue, 03 Jun 1997 00:32:50 GMT Joel Sherrill [e56a2ef] * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) updated to run Tue, 03 Jun 1997 00:13:05 GMT Joel Sherrill [f2078ec] * c/src/ada-tests/sptests/sp01/sp01.adb (modified) * c/src/ada-tests/sptests/sp02/sp02.adb (modified) * c/src/ada-tests/sptests/sp03/sp03.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/README (added) * c/src/ada-tests/sptests/sp04/sp04.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sp05.adb (modified) * c/src/ada-tests/sptests/sp06/sp06.adb (modified) * c/src/ada-tests/sptests/sp07/sp07.adb (modified) * c/src/ada-tests/sptests/sp08/sp08.adb (modified) * c/src/ada-tests/sptests/sp09/sp09.adb (modified) * c/src/ada-tests/sptests/sp11/sp11.adb (modified) * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp13/sp13.adb (modified) * c/src/ada-tests/sptests/sp14/sp14.adb (modified) * c/src/ada-tests/sptests/sp15/sp15.adb (modified) * c/src/ada-tests/sptests/sp16/sp16.adb (modified) * c/src/ada-tests/sptests/sp17/sp17.adb (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (modified) * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp21/sp21.adb (modified) * c/src/ada-tests/sptests/sp22/sp22.adb (modified) * c/src/ada-tests/sptests/sp23/sp23.adb (modified) * c/src/ada-tests/sptests/sp24/sp24.adb (modified) * c/src/ada-tests/sptests/sp25/sp25.adb (modified) * c/src/ada-tests/sptests/spsize/spsize.adb (modified) New style main procedure which creates the test's RTEMS ...
