# # ChangeLog for c/src/ada-tests in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 01:58:25 Thu, 29 Oct 1998 17:10:02 GMT Joel Sherrill [a47bd655] * c/src/ada-tests/support/init.c (modified) Cleanup. Wed, 04 Jun 1997 18:54:18 GMT Joel Sherrill [e7f86ef] * c/src/ada-tests/mptests/mp01/config.h (added) * c/src/ada-tests/mptests/mp01/mp01.adb (added) new file Tue, 03 Jun 1997 23:04:25 GMT Joel Sherrill [b42675f] * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm26/tm26.adb (modified) * c/src/ada-tests/tmtests/tm27/tm27.adb (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) corrected name of test suite Tue, 03 Jun 1997 23:00:45 GMT Joel Sherrill [1e97a20] * c/src/ada-tests/samples/hello/hello.adb (modified) fixed comment Tue, 03 Jun 1997 22:58:48 GMT Joel Sherrill [9b3853a] * c/src/ada-tests/samples/ticker/sptest.ads (modified) Removed configuration information. Tue, 03 Jun 1997 22:57:58 GMT Joel Sherrill [430d81a] * c/src/ada-tests/samples/base_sp/base_sp.adb (added) * c/src/ada-tests/samples/base_sp/config.h (added) * c/src/ada-tests/samples/ticker/config.h (added) * c/src/ada-tests/samples/ticker/ticker.adb (added) new file Tue, 03 Jun 1997 22:54:45 GMT Joel Sherrill [08c192b] * c/src/ada-tests/samples/base_sp/sptest.ads (modified) Removed Configuration Information. Tue, 03 Jun 1997 22:52:39 GMT Joel Sherrill [8640cc99] * c/src/ada-tests/samples/hello/config.h (added) * c/src/ada-tests/samples/hello/hello.adb (added) new files. Tue, 03 Jun 1997 22:52:34 GMT Joel Sherrill [4fd88bc] * c/src/ada-tests/samples/hello/sptest.ads (modified) Removed configuration information. Tue, 03 Jun 1997 22:49:47 GMT Joel Sherrill [5d0f4a56] * c/src/ada-tests/support/rtems_calling_overhead.ads (added) * c/src/ada-tests/support/time_test_support.adb (added) * c/src/ada-tests/support/time_test_support.ads (added) * c/src/ada-tests/support/timer_driver.adb (added) * c/src/ada-tests/support/timer_driver.ads (added) new files Tue, 03 Jun 1997 22:49:19 GMT Joel Sherrill [7c498800] * c/src/ada-tests/tmtests/tmoverhd/README (added) new file. Tue, 03 Jun 1997 22:47:47 GMT Joel Sherrill [8ed37e3c] * c/src/ada-tests/tmtests/tmoverhd/config.h (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) corrected to compile with the new binding. Tue, 03 Jun 1997 22:40:57 GMT Joel Sherrill [1b141533] * c/src/ada-tests/tmtests/tmck/config.h (modified) Corrected for this test. Tue, 03 Jun 1997 22:39:55 GMT Joel Sherrill [2bef691] * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) Added correct contents Tue, 03 Jun 1997 22:38:10 GMT Joel Sherrill [5363249] * c/src/ada-tests/tmtests/tm26/README (added) * c/src/ada-tests/tmtests/tm26/tmtest.adp (added) * c/src/ada-tests/tmtests/tm27/README (added) * c/src/ada-tests/tmtests/tmck/config.h (added) new file Tue, 03 Jun 1997 22:22:52 GMT Joel Sherrill [2ef9d4a] * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) Corrected maximum number of messages to be non-zero Tue, 03 Jun 1997 22:21:18 GMT Joel Sherrill [6e98a517] * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) removed reference to Stub Device Driver Tue, 03 Jun 1997 22:18:54 GMT Joel Sherrill [f94917d7] * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) Replaced prototype for Last_Task which was accidentally removed when ... Tue, 03 Jun 1997 22:16:25 GMT Joel Sherrill [46063740] * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) Changed RTEMS.Boolean to Standard.Boolean to avoid typing problems. Tue, 03 Jun 1997 22:11:55 GMT Joel Sherrill [e3b4ccd] * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) Fixed incorrect invocation of Message_Queue_Create Tue, 03 Jun 1997 22:10:18 GMT Joel Sherrill [79e0b6fd] * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) fixed typo which resulted in Message_Queue_Create being invoked ... Tue, 03 Jun 1997 22:08:59 GMT Joel Sherrill [688ecaa0] * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) Fixed calls to Message_Queue_Create to include maximum message size ... Tue, 03 Jun 1997 22:06:49 GMT Joel Sherrill [e17ffea] * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) Changed to variable length messages. Tue, 03 Jun 1997 21:48:57 GMT Joel Sherrill [bc35a6ef] * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0. Tue, 03 Jun 1997 21:46:18 GMT Joel Sherrill [1338cdb] * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) Changed type Task_Entry_Point to Task_Entry to be correct per 4.0.0. Tue, 03 Jun 1997 21:43:20 GMT Joel Sherrill [c7f646b5] * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) Fixed all references to Semaphore_Create to have the correct ... Tue, 03 Jun 1997 21:39:35 GMT Joel Sherrill [9db72b4] * c/src/ada-tests/tmtests/tm02/config.h (added) * c/src/ada-tests/tmtests/tm03/config.h (added) * c/src/ada-tests/tmtests/tm04/config.h (added) * c/src/ada-tests/tmtests/tm05/config.h (added) * c/src/ada-tests/tmtests/tm06/config.h (added) * c/src/ada-tests/tmtests/tm07/config.h (added) * c/src/ada-tests/tmtests/tm08/config.h (added) * c/src/ada-tests/tmtests/tm09/config.h (added) * c/src/ada-tests/tmtests/tm10/config.h (added) * c/src/ada-tests/tmtests/tm11/config.h (added) * c/src/ada-tests/tmtests/tm12/config.h (added) * c/src/ada-tests/tmtests/tm13/config.h (added) * c/src/ada-tests/tmtests/tm14/config.h (added) * c/src/ada-tests/tmtests/tm15/config.h (added) * c/src/ada-tests/tmtests/tm16/config.h (added) * c/src/ada-tests/tmtests/tm17/config.h (added) * c/src/ada-tests/tmtests/tm18/config.h (added) * c/src/ada-tests/tmtests/tm19/config.h (added) * c/src/ada-tests/tmtests/tm20/config.h (added) * c/src/ada-tests/tmtests/tm21/config.h (added) * c/src/ada-tests/tmtests/tm22/config.h (added) * c/src/ada-tests/tmtests/tm23/config.h (added) * c/src/ada-tests/tmtests/tm24/config.h (added) * c/src/ada-tests/tmtests/tm25/config.h (added) * c/src/ada-tests/tmtests/tm26/config.h (added) * c/src/ada-tests/tmtests/tm27/config.h (added) * c/src/ada-tests/tmtests/tm28/config.h (added) * c/src/ada-tests/tmtests/tm29/config.h (added) New file. Tue, 03 Jun 1997 21:27:16 GMT Joel Sherrill [4b067069] * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm07/tm07.adb (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm26/tm26.adb (modified) * c/src/ada-tests/tmtests/tm27/tm27.adb (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) new file Tue, 03 Jun 1997 20:24:11 GMT Joel Sherrill [b4be04e] * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm26/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm27/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) Removed Configuration Table information. Tue, 03 Jun 1997 20:20:39 GMT Joel Sherrill [7b93a327] * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) Corrected call to Semaphore_Create to have the proper calling sequence Tue, 03 Jun 1997 20:20:23 GMT Joel Sherrill [b67e6ec] * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) Removed Configuration Table information Tue, 03 Jun 1997 20:20:10 GMT Joel Sherrill [43437e97] * c/src/ada-tests/tmtests/tm01/config.h (added) * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) new file Tue, 03 Jun 1997 19:26:36 GMT Joel Sherrill [f222e9d4] * c/src/ada-tests/sptests/sp25/sptest.adb (modified) Removed unnecessary dependency on RTEMS_Test_Support which existed ... Tue, 03 Jun 1997 19:25:56 GMT Joel Sherrill [a1ceec8] * c/src/ada-tests/sptests/sp20/config.h (added) * c/src/ada-tests/sptests/sp21/config.h (added) * c/src/ada-tests/sptests/sp22/config.h (added) * c/src/ada-tests/sptests/sp23/config.h (added) * c/src/ada-tests/sptests/sp24/config.h (added) * c/src/ada-tests/sptests/sp25/config.h (added) new file Tue, 03 Jun 1997 19:21:25 GMT Joel Sherrill [be1618a] * c/src/ada-tests/sptests/sp21/sptest.ads (modified) removed reference to the Stub Device Driver Tue, 03 Jun 1997 19:18:15 GMT Joel Sherrill [d6a9988] * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) Changed mode and priority of initialization task. Tue, 03 Jun 1997 18:38:58 GMT Joel Sherrill [5687a1e9] * c/src/ada-tests/sptests/sp19/sp19.adb (modified) Changed attribute of Initialization Task to Floating_Point Tue, 03 Jun 1997 18:38:40 GMT Joel Sherrill [ac953f2] * c/src/ada-tests/sptests/sp19/README (added) * c/src/ada-tests/sptests/sp19/config.h (added) new files Tue, 03 Jun 1997 18:37:40 GMT Joel Sherrill [dc300df] * c/src/ada-tests/support/float_io.ads (added) * c/src/ada-tests/support/fp.inc (added) * c/src/ada-tests/support/integer.inc (added) new file Tue, 03 Jun 1997 18:28:38 GMT Joel Sherrill [82870ab] * c/src/ada-tests/sptests/sp03/config.h (added) * c/src/ada-tests/sptests/sp04/config.h (added) * c/src/ada-tests/sptests/sp05/config.h (added) * c/src/ada-tests/sptests/sp06/config.h (added) * c/src/ada-tests/sptests/sp07/config.h (added) * c/src/ada-tests/sptests/sp08/config.h (added) * c/src/ada-tests/sptests/sp09/config.h (added) * c/src/ada-tests/sptests/sp11/config.h (added) * c/src/ada-tests/sptests/sp12/config.h (added) * c/src/ada-tests/sptests/sp13/config.h (added) * c/src/ada-tests/sptests/sp14/config.h (added) * c/src/ada-tests/sptests/sp15/config.h (added) * c/src/ada-tests/sptests/sp16/config.h (added) * c/src/ada-tests/sptests/sp17/config.h (added) new file Tue, 03 Jun 1997 18:28:23 GMT Joel Sherrill [91c78ffd] * c/src/ada-tests/sptests/sp17/sptest.ads (modified) Changed from RTEMS.Boolean to Standard.Boolean to avoid problems. Tue, 03 Jun 1997 18:07:51 GMT Joel Sherrill [93bd518] * c/src/ada-tests/support/address_io.adb (added) * c/src/ada-tests/support/address_io.ads (added) new files Tue, 03 Jun 1997 18:06:46 GMT Joel Sherrill [9bec37b] * c/src/ada-tests/sptests/sp14/sptest.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) Switched to proper types for booleans and increased the stack space ... Tue, 03 Jun 1997 16:00:00 GMT Joel Sherrill [a7156d1] * c/src/ada-tests/sptests/sp13/sptest.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) Modifed to make the test run to completion. Primarily provided the ... Tue, 03 Jun 1997 15:40:24 GMT Joel Sherrill [98150020] * c/src/ada-tests/support/test_support.adb (modified) Commented out exception handling code since these routines are not ... Tue, 03 Jun 1997 15:39:28 GMT Joel Sherrill [4db9c861] * c/src/ada-tests/sptests/sp13/sptest.adb (modified) removed with of unchecked_conversion Tue, 03 Jun 1997 15:25:28 GMT Joel Sherrill [e351c26a] * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.adb (modified) sptest.adb: update Semaphore_Create calling sequence sp12.adb: ... Tue, 03 Jun 1997 15:12:23 GMT Joel Sherrill [c1ef834] * c/src/ada-tests/sptests/sp09/sp09.scn (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) Fixed problems which prevented the test from compiling and running to ... Tue, 03 Jun 1997 00:56:11 GMT Joel Sherrill [7d366f1c] * c/src/ada-tests/sptests/sp09/sptest.adb (modified) changed reference for Configuration Table from BSP to RTEMS. Tue, 03 Jun 1997 00:34:04 GMT Joel Sherrill [d0f426a1] * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/support/test_support.adb (modified) *** empty log message *** Tue, 03 Jun 1997 00:32:50 GMT Joel Sherrill [e56a2ef] * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) updated to run Tue, 03 Jun 1997 00:13:05 GMT Joel Sherrill [f2078ec] * c/src/ada-tests/sptests/sp01/sp01.adb (modified) * c/src/ada-tests/sptests/sp02/sp02.adb (modified) * c/src/ada-tests/sptests/sp03/sp03.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/README (added) * c/src/ada-tests/sptests/sp04/sp04.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sp05.adb (modified) * c/src/ada-tests/sptests/sp06/sp06.adb (modified) * c/src/ada-tests/sptests/sp07/sp07.adb (modified) * c/src/ada-tests/sptests/sp08/sp08.adb (modified) * c/src/ada-tests/sptests/sp09/sp09.adb (modified) * c/src/ada-tests/sptests/sp11/sp11.adb (modified) * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp13/sp13.adb (modified) * c/src/ada-tests/sptests/sp14/sp14.adb (modified) * c/src/ada-tests/sptests/sp15/sp15.adb (modified) * c/src/ada-tests/sptests/sp16/sp16.adb (modified) * c/src/ada-tests/sptests/sp17/sp17.adb (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (modified) * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp21/sp21.adb (modified) * c/src/ada-tests/sptests/sp22/sp22.adb (modified) * c/src/ada-tests/sptests/sp23/sp23.adb (modified) * c/src/ada-tests/sptests/sp24/sp24.adb (modified) * c/src/ada-tests/sptests/sp25/sp25.adb (modified) * c/src/ada-tests/sptests/spsize/spsize.adb (modified) New style main procedure which creates the test's RTEMS ... Mon, 02 Jun 1997 23:47:05 GMT Joel Sherrill [8e7b810] * c/src/ada-tests/support/test_support.adb (modified) added subtract of 1 to Task_Number to account for the creation of ... Mon, 02 Jun 1997 23:46:41 GMT Joel Sherrill [ad9865e] * c/src/ada-tests/support/init.c (modified) *** empty log message *** Mon, 02 Jun 1997 22:41:03 GMT Joel Sherrill [529cdccd] * c/src/ada-tests/sptests/sp02/config.h (added) new file Mon, 02 Jun 1997 22:37:28 GMT Joel Sherrill [7f79b673] * c/src/ada-tests/sptests/sp01/sp01.adb (modified) * c/src/ada-tests/sptests/sp02/sp02.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/sp03.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/sp04.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sp05.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/sp06.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/sp07.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/sp08.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/sp09.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/sp11.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/sp13.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/sp14.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/sp15.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/sp16.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/sp17.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp21/sp21.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/sp22.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/sp23.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/sp24.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/sp25.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spsize/spsize.adb (modified) * c/src/ada-tests/sptests/spsize/sptest.ads (modified) readded body for "main" procedures Mon, 02 Jun 1997 22:14:51 GMT Joel Sherrill [77ff3d10] * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp21/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spsize/sptest.ads (modified) removed configuration table definition in Ada Mon, 02 Jun 1997 21:53:05 GMT Joel Sherrill [cf1ced66] * c/src/ada-tests/sptests/sp01/sp01.adb (added) * c/src/ada-tests/sptests/sp02/sp02.adb (added) * c/src/ada-tests/sptests/sp03/sp03.adb (added) * c/src/ada-tests/sptests/sp04/sp04.adb (added) * c/src/ada-tests/sptests/sp05/sp05.adb (added) * c/src/ada-tests/sptests/sp06/sp06.adb (added) * c/src/ada-tests/sptests/sp07/sp07.adb (added) * c/src/ada-tests/sptests/sp08/sp08.adb (added) * c/src/ada-tests/sptests/sp09/sp09.adb (added) * c/src/ada-tests/sptests/sp11/sp11.adb (added) * c/src/ada-tests/sptests/sp12/sp12.adb (added) * c/src/ada-tests/sptests/sp13/sp13.adb (added) * c/src/ada-tests/sptests/sp14/sp14.adb (added) * c/src/ada-tests/sptests/sp15/sp15.adb (added) * c/src/ada-tests/sptests/sp16/sp16.adb (added) * c/src/ada-tests/sptests/sp17/sp17.adb (added) * c/src/ada-tests/sptests/sp19/sp19.adb (added) * c/src/ada-tests/sptests/sp20/sp20.adb (added) * c/src/ada-tests/sptests/sp21/sp21.adb (added) * c/src/ada-tests/sptests/sp22/sp22.adb (added) * c/src/ada-tests/sptests/sp23/sp23.adb (added) * c/src/ada-tests/sptests/sp24/sp24.adb (added) * c/src/ada-tests/sptests/sp25/sp25.adb (added) * c/src/ada-tests/sptests/spsize/spsize.adb (added) * c/src/ada-tests/tmtests/tm01/tm01.adb (added) * c/src/ada-tests/tmtests/tm02/tm02.adb (added) * c/src/ada-tests/tmtests/tm03/tm03.adb (added) * c/src/ada-tests/tmtests/tm04/tm04.adb (added) * c/src/ada-tests/tmtests/tm05/tm05.adb (added) * c/src/ada-tests/tmtests/tm06/tm06.adb (added) * c/src/ada-tests/tmtests/tm07/tm07.adb (added) * c/src/ada-tests/tmtests/tm08/tm08.adb (added) * c/src/ada-tests/tmtests/tm09/tm09.adb (added) * c/src/ada-tests/tmtests/tm10/tm10.adb (added) * c/src/ada-tests/tmtests/tm11/tm11.adb (added) * c/src/ada-tests/tmtests/tm12/tm12.adb (added) * c/src/ada-tests/tmtests/tm13/tm13.adb (added) * c/src/ada-tests/tmtests/tm14/tm14.adb (added) * c/src/ada-tests/tmtests/tm15/tm15.adb (added) * c/src/ada-tests/tmtests/tm16/tm16.adb (added) * c/src/ada-tests/tmtests/tm17/tm17.adb (added) * c/src/ada-tests/tmtests/tm18/tm18.adb (added) * c/src/ada-tests/tmtests/tm19/tm19.adb (added) * c/src/ada-tests/tmtests/tm20/tm20.adb (added) * c/src/ada-tests/tmtests/tm21/tm21.adb (added) * c/src/ada-tests/tmtests/tm22/tm22.adb (added) * c/src/ada-tests/tmtests/tm23/tm23.adb (added) * c/src/ada-tests/tmtests/tm24/tm24.adb (added) * c/src/ada-tests/tmtests/tm25/tm25.adb (added) * c/src/ada-tests/tmtests/tm26/tm26.adb (added) * c/src/ada-tests/tmtests/tm27/tm27.adb (added) * c/src/ada-tests/tmtests/tm28/tm28.adb (added) * c/src/ada-tests/tmtests/tm29/tm29.adb (added) * c/src/ada-tests/tmtests/tmck/tmck.adb (added) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (added) new file - automatically generated by a script Mon, 02 Jun 1997 21:16:14 GMT Joel Sherrill [196a6b9] * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/support/status_io.ads (modified) * c/src/ada-tests/support/test_support.adb (modified) * c/src/ada-tests/support/test_support.ads (modified) * c/src/ada-tests/support/unsigned32_io.ads (modified) Changed license and copyright notice. Added "development" style CVS Id Mon, 02 Jun 1997 21:12:42 GMT Joel Sherrill [2b7fc9cc] * c/src/ada-tests/sptests/sp01/config.h (added) New file -- works in conjunction with support/init.c. Mon, 02 Jun 1997 20:59:29 GMT Joel Sherrill [b7c2ccc] * c/src/ada-tests/sptests/sp01/sptest.ads (modified) Removed Ada Configuration Table definition. Mon, 02 Jun 1997 20:57:52 GMT Joel Sherrill [9917d5da] * c/src/ada-tests/mptests/mp01/node1/mp01.scn (added) * c/src/ada-tests/mptests/mp01/node2/mp01.scn (added) * c/src/ada-tests/mptests/mp02/node1/mp02.scn (added) * c/src/ada-tests/mptests/mp02/node2/mp02.scn (added) * c/src/ada-tests/mptests/mp03/node1/mp03.scn (added) * c/src/ada-tests/mptests/mp03/node2/mp03.scn (added) * c/src/ada-tests/mptests/mp04/node1/mp04.scn (added) * c/src/ada-tests/mptests/mp04/node2/mp04.scn (added) * c/src/ada-tests/mptests/mp05/node1/mp05.scn (added) * c/src/ada-tests/mptests/mp05/node2/mp05.scn (added) * c/src/ada-tests/mptests/mp06/node1/mp06.scn (added) * c/src/ada-tests/mptests/mp06/node2/mp06.scn (added) * c/src/ada-tests/mptests/mp07/node1/mp07.scn (added) * c/src/ada-tests/mptests/mp07/node2/mp07.scn (added) * c/src/ada-tests/mptests/mp08/node1/mp08.scn (added) * c/src/ada-tests/mptests/mp08/node2/mp08.scn (added) * c/src/ada-tests/mptests/mp09/node1/mp09.scn (added) * c/src/ada-tests/mptests/mp09/node2/mp09.scn (added) * c/src/ada-tests/mptests/mp10/node1/mp10.scn (added) * c/src/ada-tests/mptests/mp10/node2/mp10.scn (added) * c/src/ada-tests/mptests/mp11/node1/mp11.scn (added) * c/src/ada-tests/mptests/mp11/node2/mp11.scn (added) * c/src/ada-tests/mptests/mp12/node1/mp12.scn (added) * c/src/ada-tests/mptests/mp12/node2/mp12.scn (added) * c/src/ada-tests/mptests/mp13/node1/mp13.scn (added) * c/src/ada-tests/mptests/mp13/node2/mp13.scn (added) * c/src/ada-tests/mptests/mp14/node1/mp14.scn (added) * c/src/ada-tests/mptests/mp14/node2/mp14.scn (added) * c/src/ada-tests/samples/base_mp/node1/base_mp.scn (added) * c/src/ada-tests/samples/base_mp/node2/base_mp.scn (added) * c/src/ada-tests/samples/base_sp/base_sp.scn (added) * c/src/ada-tests/samples/hello/hello.scn (added) * c/src/ada-tests/samples/ticker/ticker.scn (added) * c/src/ada-tests/sptests/sp01/sp01.scn (added) * c/src/ada-tests/sptests/sp02/sp02.scn (added) * c/src/ada-tests/sptests/sp03/sp03.scn (added) * c/src/ada-tests/sptests/sp04/sp04.scn (added) * c/src/ada-tests/sptests/sp05/sp05.scn (added) * c/src/ada-tests/sptests/sp06/sp06.scn (added) * c/src/ada-tests/sptests/sp07/sp07.scn (added) * c/src/ada-tests/sptests/sp08/sp08.scn (added) * c/src/ada-tests/sptests/sp09/sp09.scn (added) * c/src/ada-tests/sptests/sp11/sp11.scn (added) * c/src/ada-tests/sptests/sp12/sp12.scn (added) * c/src/ada-tests/sptests/sp13/sp13.scn (added) * c/src/ada-tests/sptests/sp14/sp14.scn (added) * c/src/ada-tests/sptests/sp15/sp15.scn (added) * c/src/ada-tests/sptests/sp16/sp16.scn (added) * c/src/ada-tests/sptests/sp17/sp17.scn (added) * c/src/ada-tests/sptests/sp19/sp19.scn (added) * c/src/ada-tests/sptests/sp20/sp20.scn (added) * c/src/ada-tests/sptests/sp21/sp21.scn (added) * c/src/ada-tests/sptests/sp22/sp22.scn (added) * c/src/ada-tests/sptests/sp23/sp23.scn (added) * c/src/ada-tests/sptests/sp24/sp24.scn (added) * c/src/ada-tests/sptests/sp25/sp25.scn (added) added screen files from 3.2.1 Mon, 02 Jun 1997 20:52:48 GMT Joel Sherrill [f3f06f79] * c/src/ada-tests/support/init.c (added) * c/src/ada-tests/support/status_io.ads (added) * c/src/ada-tests/support/test_support.adb (added) * c/src/ada-tests/support/test_support.ads (added) * c/src/ada-tests/support/unsigned32_io.ads (added) * c/src/ada/rtems.adb (added) * c/src/ada/rtems.ads (added) * cpukit/ada/rtems.adb (added) * cpukit/ada/rtems.ads (added) added new files from test area. This code has successfully been ... Mon, 02 Jun 1997 20:32:11 GMT Joel Sherrill [bf9ae83] * c/src/ada-tests/mptests/mp01/mptest.adb (modified) * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp02/mptest.adb (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp03/mptest.adb (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp04/mptest.adb (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp05/mptest.adb (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp06/mptest.adb (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp07/mptest.adb (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp08/mptest.adb (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp09/mptest.adb (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp10/mptest.adb (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp11/mptest.adb (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp12/mptest.adb (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp13/mptest.adb (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/hello/sptest.adb (modified) * c/src/ada-tests/samples/hello/sptest.ads (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.ads (modified) * c/src/ada-tests/sptests/sp02/sptest.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sptest.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/sptest.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/sptest.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/sptest.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/sptest.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/sptest.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/sptest.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/sptest.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/sptest.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/sptest.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/sptest.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spsize/sptest.adb (modified) * c/src/ada-tests/sptests/spsize/sptest.ads (modified) * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm26/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm27/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm27/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) modified copyright notice to be the same as RTEMS 4.0.0. changed ... Mon, 02 Jun 1997 20:19:03 GMT Joel Sherrill [6d4e604b] * c/src/ada-tests/mptests/mp01/mptest.adb (added) * c/src/ada-tests/mptests/mp01/mptest.ads (added) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp02/mptest.adb (added) * c/src/ada-tests/mptests/mp02/mptest.ads (added) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp03/mptest.adb (added) * c/src/ada-tests/mptests/mp03/mptest.ads (added) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp04/mptest.adb (added) * c/src/ada-tests/mptests/mp04/mptest.ads (added) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp05/mptest.adb (added) * c/src/ada-tests/mptests/mp05/mptest.ads (added) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp06/mptest.adb (added) * c/src/ada-tests/mptests/mp06/mptest.ads (added) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp07/mptest.adb (added) * c/src/ada-tests/mptests/mp07/mptest.ads (added) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp08/mptest.adb (added) * c/src/ada-tests/mptests/mp08/mptest.ads (added) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp09/mptest.adb (added) * c/src/ada-tests/mptests/mp09/mptest.ads (added) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp10/mptest.adb (added) * c/src/ada-tests/mptests/mp10/mptest.ads (added) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp11/mptest.adb (added) * c/src/ada-tests/mptests/mp11/mptest.ads (added) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp12/mptest.adb (added) * c/src/ada-tests/mptests/mp12/mptest.ads (added) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp13/mptest.adb (added) * c/src/ada-tests/mptests/mp13/mptest.ads (added) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp14/mptest.adb (added) * c/src/ada-tests/mptests/mp14/mptest.ads (added) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_mp/mptest.adb (added) * c/src/ada-tests/samples/base_mp/mptest.ads (added) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_sp/sptest.adb (added) * c/src/ada-tests/samples/base_sp/sptest.ads (added) * c/src/ada-tests/samples/hello/sptest.adb (added) * c/src/ada-tests/samples/hello/sptest.ads (added) * c/src/ada-tests/samples/ticker/sptest.adb (added) * c/src/ada-tests/samples/ticker/sptest.ads (added) * c/src/ada-tests/sptests/sp01/sptest.adb (added) * c/src/ada-tests/sptests/sp01/sptest.ads (added) * c/src/ada-tests/sptests/sp02/sptest.adb (added) * c/src/ada-tests/sptests/sp02/sptest.ads (added) * c/src/ada-tests/sptests/sp03/sptest.adb (added) * c/src/ada-tests/sptests/sp03/sptest.ads (added) * c/src/ada-tests/sptests/sp04/sptest.adb (added) * c/src/ada-tests/sptests/sp04/sptest.ads (added) * c/src/ada-tests/sptests/sp05/sptest.adb (added) * c/src/ada-tests/sptests/sp05/sptest.ads (added) * c/src/ada-tests/sptests/sp06/sptest.adb (added) * c/src/ada-tests/sptests/sp06/sptest.ads (added) * c/src/ada-tests/sptests/sp07/sptest.adb (added) * c/src/ada-tests/sptests/sp07/sptest.ads (added) * c/src/ada-tests/sptests/sp08/sptest.adb (added) * c/src/ada-tests/sptests/sp08/sptest.ads (added) * c/src/ada-tests/sptests/sp09/sptest.adb (added) * c/src/ada-tests/sptests/sp09/sptest.ads (added) * c/src/ada-tests/sptests/sp11/sptest.adb (added) * c/src/ada-tests/sptests/sp11/sptest.ads (added) * c/src/ada-tests/sptests/sp12/sptest.adb (added) * c/src/ada-tests/sptests/sp12/sptest.ads (added) * c/src/ada-tests/sptests/sp13/sptest.adb (added) * c/src/ada-tests/sptests/sp13/sptest.ads (added) * c/src/ada-tests/sptests/sp14/sptest.adb (added) * c/src/ada-tests/sptests/sp14/sptest.ads (added) * c/src/ada-tests/sptests/sp15/sptest.adb (added) * c/src/ada-tests/sptests/sp15/sptest.ads (added) * c/src/ada-tests/sptests/sp16/sptest.adb (added) * c/src/ada-tests/sptests/sp16/sptest.ads (added) * c/src/ada-tests/sptests/sp17/sptest.adb (added) * c/src/ada-tests/sptests/sp17/sptest.ads (added) * c/src/ada-tests/sptests/sp19/sptest.ads (added) * c/src/ada-tests/sptests/sp20/sptest.adb (added) * c/src/ada-tests/sptests/sp20/sptest.ads (added) * c/src/ada-tests/sptests/sp21/sptest.adb (added) * c/src/ada-tests/sptests/sp21/sptest.ads (added) * c/src/ada-tests/sptests/sp22/sptest.adb (added) * c/src/ada-tests/sptests/sp22/sptest.ads (added) * c/src/ada-tests/sptests/sp23/sptest.adb (added) * c/src/ada-tests/sptests/sp23/sptest.ads (added) * c/src/ada-tests/sptests/sp24/sptest.adb (added) * c/src/ada-tests/sptests/sp24/sptest.ads (added) * c/src/ada-tests/sptests/sp25/sptest.adb (added) * c/src/ada-tests/sptests/sp25/sptest.ads (added) * c/src/ada-tests/sptests/spsize/sptest.adb (added) * c/src/ada-tests/sptests/spsize/sptest.ads (added) * c/src/ada-tests/tmtests/tm01/tmtest.adb (added) * c/src/ada-tests/tmtests/tm01/tmtest.ads (added) * c/src/ada-tests/tmtests/tm02/tmtest.adb (added) * c/src/ada-tests/tmtests/tm02/tmtest.ads (added) * c/src/ada-tests/tmtests/tm03/tmtest.adb (added) * c/src/ada-tests/tmtests/tm03/tmtest.ads (added) * c/src/ada-tests/tmtests/tm04/tmtest.adb (added) * c/src/ada-tests/tmtests/tm04/tmtest.ads (added) * c/src/ada-tests/tmtests/tm05/tmtest.adb (added) * c/src/ada-tests/tmtests/tm05/tmtest.ads (added) * c/src/ada-tests/tmtests/tm06/tmtest.adb (added) * c/src/ada-tests/tmtests/tm06/tmtest.ads (added) * c/src/ada-tests/tmtests/tm07/tmtest.adb (added) * c/src/ada-tests/tmtests/tm07/tmtest.ads (added) * c/src/ada-tests/tmtests/tm08/tmtest.adb (added) * c/src/ada-tests/tmtests/tm08/tmtest.ads (added) * c/src/ada-tests/tmtests/tm09/tmtest.adb (added) * c/src/ada-tests/tmtests/tm09/tmtest.ads (added) * c/src/ada-tests/tmtests/tm10/tmtest.adb (added) * c/src/ada-tests/tmtests/tm10/tmtest.ads (added) * c/src/ada-tests/tmtests/tm11/tmtest.adb (added) * c/src/ada-tests/tmtests/tm11/tmtest.ads (added) * c/src/ada-tests/tmtests/tm12/tmtest.adb (added) * c/src/ada-tests/tmtests/tm12/tmtest.ads (added) * c/src/ada-tests/tmtests/tm13/tmtest.adb (added) * c/src/ada-tests/tmtests/tm13/tmtest.ads (added) * c/src/ada-tests/tmtests/tm14/tmtest.adb (added) * c/src/ada-tests/tmtests/tm14/tmtest.ads (added) * c/src/ada-tests/tmtests/tm15/tmtest.adb (added) * c/src/ada-tests/tmtests/tm15/tmtest.ads (added) * c/src/ada-tests/tmtests/tm16/tmtest.adb (added) * c/src/ada-tests/tmtests/tm16/tmtest.ads (added) * c/src/ada-tests/tmtests/tm17/tmtest.adb (added) * c/src/ada-tests/tmtests/tm17/tmtest.ads (added) * c/src/ada-tests/tmtests/tm18/tmtest.adb (added) * c/src/ada-tests/tmtests/tm18/tmtest.ads (added) * c/src/ada-tests/tmtests/tm19/tmtest.adb (added) * c/src/ada-tests/tmtests/tm19/tmtest.ads (added) * c/src/ada-tests/tmtests/tm20/tmtest.adb (added) * c/src/ada-tests/tmtests/tm20/tmtest.ads (added) * c/src/ada-tests/tmtests/tm21/tmtest.adb (added) * c/src/ada-tests/tmtests/tm21/tmtest.ads (added) * c/src/ada-tests/tmtests/tm22/tmtest.adb (added) * c/src/ada-tests/tmtests/tm22/tmtest.ads (added) * c/src/ada-tests/tmtests/tm23/tmtest.adb (added) * c/src/ada-tests/tmtests/tm23/tmtest.ads (added) * c/src/ada-tests/tmtests/tm24/tmtest.adb (added) * c/src/ada-tests/tmtests/tm24/tmtest.ads (added) * c/src/ada-tests/tmtests/tm25/tmtest.adb (added) * c/src/ada-tests/tmtests/tm25/tmtest.ads (added) * c/src/ada-tests/tmtests/tm26/tmtest.ads (added) * c/src/ada-tests/tmtests/tm27/tmtest.adb (added) * c/src/ada-tests/tmtests/tm27/tmtest.ads (added) * c/src/ada-tests/tmtests/tm28/tmtest.adb (added) * c/src/ada-tests/tmtests/tm28/tmtest.ads (added) * c/src/ada-tests/tmtests/tm29/tmtest.adb (added) * c/src/ada-tests/tmtests/tm29/tmtest.ads (added) * c/src/ada-tests/tmtests/tmck/tmtest.adb (added) * c/src/ada-tests/tmtests/tmck/tmtest.ads (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (added) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (added) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (added) Initial revision
