# # ChangeLog for c/src/ada-tests/tmtests/tm13 in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 12:00:30 Tue, 03 Jun 1997 23:04:25 GMT Joel Sherrill [b42675f] * c/src/ada-tests/tmtests/tm01/tm01.adb (modified) * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm26/tm26.adb (modified) * c/src/ada-tests/tmtests/tm27/tm27.adb (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) * c/src/ada-tests/tmtests/tmck/tmck.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (modified) corrected name of test suite Tue, 03 Jun 1997 22:11:55 GMT Joel Sherrill [e3b4ccd] * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) Fixed incorrect invocation of Message_Queue_Create Tue, 03 Jun 1997 22:08:59 GMT Joel Sherrill [688ecaa0] * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) Fixed calls to Message_Queue_Create to include maximum message size ... Tue, 03 Jun 1997 22:06:49 GMT Joel Sherrill [e17ffea] * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) Changed to variable length messages. Tue, 03 Jun 1997 21:48:57 GMT Joel Sherrill [bc35a6ef] * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) Changed Task_Entry_Point to Task_Entry to be correct per 4.0.0. Tue, 03 Jun 1997 21:39:35 GMT Joel Sherrill [9db72b4] * c/src/ada-tests/tmtests/tm02/config.h (added) * c/src/ada-tests/tmtests/tm03/config.h (added) * c/src/ada-tests/tmtests/tm04/config.h (added) * c/src/ada-tests/tmtests/tm05/config.h (added) * c/src/ada-tests/tmtests/tm06/config.h (added) * c/src/ada-tests/tmtests/tm07/config.h (added) * c/src/ada-tests/tmtests/tm08/config.h (added) * c/src/ada-tests/tmtests/tm09/config.h (added) * c/src/ada-tests/tmtests/tm10/config.h (added) * c/src/ada-tests/tmtests/tm11/config.h (added) * c/src/ada-tests/tmtests/tm12/config.h (added) * c/src/ada-tests/tmtests/tm13/config.h (added) * c/src/ada-tests/tmtests/tm14/config.h (added) * c/src/ada-tests/tmtests/tm15/config.h (added) * c/src/ada-tests/tmtests/tm16/config.h (added) * c/src/ada-tests/tmtests/tm17/config.h (added) * c/src/ada-tests/tmtests/tm18/config.h (added) * c/src/ada-tests/tmtests/tm19/config.h (added) * c/src/ada-tests/tmtests/tm20/config.h (added) * c/src/ada-tests/tmtests/tm21/config.h (added) * c/src/ada-tests/tmtests/tm22/config.h (added) * c/src/ada-tests/tmtests/tm23/config.h (added) * c/src/ada-tests/tmtests/tm24/config.h (added) * c/src/ada-tests/tmtests/tm25/config.h (added) * c/src/ada-tests/tmtests/tm26/config.h (added) * c/src/ada-tests/tmtests/tm27/config.h (added) * c/src/ada-tests/tmtests/tm28/config.h (added) * c/src/ada-tests/tmtests/tm29/config.h (added) New file. Tue, 03 Jun 1997 21:27:16 GMT Joel Sherrill [4b067069] * c/src/ada-tests/tmtests/tm02/tm02.adb (modified) * c/src/ada-tests/tmtests/tm03/tm03.adb (modified) * c/src/ada-tests/tmtests/tm04/tm04.adb (modified) * c/src/ada-tests/tmtests/tm05/tm05.adb (modified) * c/src/ada-tests/tmtests/tm06/tm06.adb (modified) * c/src/ada-tests/tmtests/tm07/tm07.adb (modified) * c/src/ada-tests/tmtests/tm08/tm08.adb (modified) * c/src/ada-tests/tmtests/tm09/tm09.adb (modified) * c/src/ada-tests/tmtests/tm10/tm10.adb (modified) * c/src/ada-tests/tmtests/tm11/tm11.adb (modified) * c/src/ada-tests/tmtests/tm12/tm12.adb (modified) * c/src/ada-tests/tmtests/tm13/tm13.adb (modified) * c/src/ada-tests/tmtests/tm14/tm14.adb (modified) * c/src/ada-tests/tmtests/tm15/tm15.adb (modified) * c/src/ada-tests/tmtests/tm16/tm16.adb (modified) * c/src/ada-tests/tmtests/tm17/tm17.adb (modified) * c/src/ada-tests/tmtests/tm18/tm18.adb (modified) * c/src/ada-tests/tmtests/tm19/tm19.adb (modified) * c/src/ada-tests/tmtests/tm20/tm20.adb (modified) * c/src/ada-tests/tmtests/tm21/tm21.adb (modified) * c/src/ada-tests/tmtests/tm22/tm22.adb (modified) * c/src/ada-tests/tmtests/tm23/tm23.adb (modified) * c/src/ada-tests/tmtests/tm24/tm24.adb (modified) * c/src/ada-tests/tmtests/tm25/tm25.adb (modified) * c/src/ada-tests/tmtests/tm26/tm26.adb (modified) * c/src/ada-tests/tmtests/tm27/tm27.adb (modified) * c/src/ada-tests/tmtests/tm28/tm28.adb (modified) * c/src/ada-tests/tmtests/tm29/tm29.adb (modified) new file Tue, 03 Jun 1997 20:24:11 GMT Joel Sherrill [b4be04e] * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm26/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm27/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) Removed Configuration Table information. Mon, 02 Jun 1997 21:53:05 GMT Joel Sherrill [cf1ced66] * c/src/ada-tests/sptests/sp01/sp01.adb (added) * c/src/ada-tests/sptests/sp02/sp02.adb (added) * c/src/ada-tests/sptests/sp03/sp03.adb (added) * c/src/ada-tests/sptests/sp04/sp04.adb (added) * c/src/ada-tests/sptests/sp05/sp05.adb (added) * c/src/ada-tests/sptests/sp06/sp06.adb (added) * c/src/ada-tests/sptests/sp07/sp07.adb (added) * c/src/ada-tests/sptests/sp08/sp08.adb (added) * c/src/ada-tests/sptests/sp09/sp09.adb (added) * c/src/ada-tests/sptests/sp11/sp11.adb (added) * c/src/ada-tests/sptests/sp12/sp12.adb (added) * c/src/ada-tests/sptests/sp13/sp13.adb (added) * c/src/ada-tests/sptests/sp14/sp14.adb (added) * c/src/ada-tests/sptests/sp15/sp15.adb (added) * c/src/ada-tests/sptests/sp16/sp16.adb (added) * c/src/ada-tests/sptests/sp17/sp17.adb (added) * c/src/ada-tests/sptests/sp19/sp19.adb (added) * c/src/ada-tests/sptests/sp20/sp20.adb (added) * c/src/ada-tests/sptests/sp21/sp21.adb (added) * c/src/ada-tests/sptests/sp22/sp22.adb (added) * c/src/ada-tests/sptests/sp23/sp23.adb (added) * c/src/ada-tests/sptests/sp24/sp24.adb (added) * c/src/ada-tests/sptests/sp25/sp25.adb (added) * c/src/ada-tests/sptests/spsize/spsize.adb (added) * c/src/ada-tests/tmtests/tm01/tm01.adb (added) * c/src/ada-tests/tmtests/tm02/tm02.adb (added) * c/src/ada-tests/tmtests/tm03/tm03.adb (added) * c/src/ada-tests/tmtests/tm04/tm04.adb (added) * c/src/ada-tests/tmtests/tm05/tm05.adb (added) * c/src/ada-tests/tmtests/tm06/tm06.adb (added) * c/src/ada-tests/tmtests/tm07/tm07.adb (added) * c/src/ada-tests/tmtests/tm08/tm08.adb (added) * c/src/ada-tests/tmtests/tm09/tm09.adb (added) * c/src/ada-tests/tmtests/tm10/tm10.adb (added) * c/src/ada-tests/tmtests/tm11/tm11.adb (added) * c/src/ada-tests/tmtests/tm12/tm12.adb (added) * c/src/ada-tests/tmtests/tm13/tm13.adb (added) * c/src/ada-tests/tmtests/tm14/tm14.adb (added) * c/src/ada-tests/tmtests/tm15/tm15.adb (added) * c/src/ada-tests/tmtests/tm16/tm16.adb (added) * c/src/ada-tests/tmtests/tm17/tm17.adb (added) * c/src/ada-tests/tmtests/tm18/tm18.adb (added) * c/src/ada-tests/tmtests/tm19/tm19.adb (added) * c/src/ada-tests/tmtests/tm20/tm20.adb (added) * c/src/ada-tests/tmtests/tm21/tm21.adb (added) * c/src/ada-tests/tmtests/tm22/tm22.adb (added) * c/src/ada-tests/tmtests/tm23/tm23.adb (added) * c/src/ada-tests/tmtests/tm24/tm24.adb (added) * c/src/ada-tests/tmtests/tm25/tm25.adb (added) * c/src/ada-tests/tmtests/tm26/tm26.adb (added) * c/src/ada-tests/tmtests/tm27/tm27.adb (added) * c/src/ada-tests/tmtests/tm28/tm28.adb (added) * c/src/ada-tests/tmtests/tm29/tm29.adb (added) * c/src/ada-tests/tmtests/tmck/tmck.adb (added) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (added) new file - automatically generated by a script Mon, 02 Jun 1997 20:32:11 GMT Joel Sherrill [bf9ae83] * c/src/ada-tests/mptests/mp01/mptest.adb (modified) * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp02/mptest.adb (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp03/mptest.adb (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp04/mptest.adb (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp05/mptest.adb (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp06/mptest.adb (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp07/mptest.adb (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp08/mptest.adb (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp09/mptest.adb (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp10/mptest.adb (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp11/mptest.adb (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp12/mptest.adb (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp13/mptest.adb (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/hello/sptest.adb (modified) * c/src/ada-tests/samples/hello/sptest.ads (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.ads (modified) * c/src/ada-tests/sptests/sp02/sptest.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sptest.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/sptest.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/sptest.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/sptest.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/sptest.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/sptest.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/sptest.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/sptest.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/sptest.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/sptest.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/sptest.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spsize/sptest.adb (modified) * c/src/ada-tests/sptests/spsize/sptest.ads (modified) * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm26/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm27/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm27/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) modified copyright notice to be the same as RTEMS 4.0.0. changed ... Mon, 02 Jun 1997 20:19:03 GMT Joel Sherrill [6d4e604b] * c/src/ada-tests/mptests/mp01/mptest.adb (added) * c/src/ada-tests/mptests/mp01/mptest.ads (added) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp02/mptest.adb (added) * c/src/ada-tests/mptests/mp02/mptest.ads (added) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp03/mptest.adb (added) * c/src/ada-tests/mptests/mp03/mptest.ads (added) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp04/mptest.adb (added) * c/src/ada-tests/mptests/mp04/mptest.ads (added) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp05/mptest.adb (added) * c/src/ada-tests/mptests/mp05/mptest.ads (added) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp06/mptest.adb (added) * c/src/ada-tests/mptests/mp06/mptest.ads (added) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp07/mptest.adb (added) * c/src/ada-tests/mptests/mp07/mptest.ads (added) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp08/mptest.adb (added) * c/src/ada-tests/mptests/mp08/mptest.ads (added) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp09/mptest.adb (added) * c/src/ada-tests/mptests/mp09/mptest.ads (added) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp10/mptest.adb (added) * c/src/ada-tests/mptests/mp10/mptest.ads (added) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp11/mptest.adb (added) * c/src/ada-tests/mptests/mp11/mptest.ads (added) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp12/mptest.adb (added) * c/src/ada-tests/mptests/mp12/mptest.ads (added) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp13/mptest.adb (added) * c/src/ada-tests/mptests/mp13/mptest.ads (added) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp14/mptest.adb (added) * c/src/ada-tests/mptests/mp14/mptest.ads (added) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_mp/mptest.adb (added) * c/src/ada-tests/samples/base_mp/mptest.ads (added) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_sp/sptest.adb (added) * c/src/ada-tests/samples/base_sp/sptest.ads (added) * c/src/ada-tests/samples/hello/sptest.adb (added) * c/src/ada-tests/samples/hello/sptest.ads (added) * c/src/ada-tests/samples/ticker/sptest.adb (added) * c/src/ada-tests/samples/ticker/sptest.ads (added) * c/src/ada-tests/sptests/sp01/sptest.adb (added) * c/src/ada-tests/sptests/sp01/sptest.ads (added) * c/src/ada-tests/sptests/sp02/sptest.adb (added) * c/src/ada-tests/sptests/sp02/sptest.ads (added) * c/src/ada-tests/sptests/sp03/sptest.adb (added) * c/src/ada-tests/sptests/sp03/sptest.ads (added) * c/src/ada-tests/sptests/sp04/sptest.adb (added) * c/src/ada-tests/sptests/sp04/sptest.ads (added) * c/src/ada-tests/sptests/sp05/sptest.adb (added) * c/src/ada-tests/sptests/sp05/sptest.ads (added) * c/src/ada-tests/sptests/sp06/sptest.adb (added) * c/src/ada-tests/sptests/sp06/sptest.ads (added) * c/src/ada-tests/sptests/sp07/sptest.adb (added) * c/src/ada-tests/sptests/sp07/sptest.ads (added) * c/src/ada-tests/sptests/sp08/sptest.adb (added) * c/src/ada-tests/sptests/sp08/sptest.ads (added) * c/src/ada-tests/sptests/sp09/sptest.adb (added) * c/src/ada-tests/sptests/sp09/sptest.ads (added) * c/src/ada-tests/sptests/sp11/sptest.adb (added) * c/src/ada-tests/sptests/sp11/sptest.ads (added) * c/src/ada-tests/sptests/sp12/sptest.adb (added) * c/src/ada-tests/sptests/sp12/sptest.ads (added) * c/src/ada-tests/sptests/sp13/sptest.adb (added) * c/src/ada-tests/sptests/sp13/sptest.ads (added) * c/src/ada-tests/sptests/sp14/sptest.adb (added) * c/src/ada-tests/sptests/sp14/sptest.ads (added) * c/src/ada-tests/sptests/sp15/sptest.adb (added) * c/src/ada-tests/sptests/sp15/sptest.ads (added) * c/src/ada-tests/sptests/sp16/sptest.adb (added) * c/src/ada-tests/sptests/sp16/sptest.ads (added) * c/src/ada-tests/sptests/sp17/sptest.adb (added) * c/src/ada-tests/sptests/sp17/sptest.ads (added) * c/src/ada-tests/sptests/sp19/sptest.ads (added) * c/src/ada-tests/sptests/sp20/sptest.adb (added) * c/src/ada-tests/sptests/sp20/sptest.ads (added) * c/src/ada-tests/sptests/sp21/sptest.adb (added) * c/src/ada-tests/sptests/sp21/sptest.ads (added) * c/src/ada-tests/sptests/sp22/sptest.adb (added) * c/src/ada-tests/sptests/sp22/sptest.ads (added) * c/src/ada-tests/sptests/sp23/sptest.adb (added) * c/src/ada-tests/sptests/sp23/sptest.ads (added) * c/src/ada-tests/sptests/sp24/sptest.adb (added) * c/src/ada-tests/sptests/sp24/sptest.ads (added) * c/src/ada-tests/sptests/sp25/sptest.adb (added) * c/src/ada-tests/sptests/sp25/sptest.ads (added) * c/src/ada-tests/sptests/spsize/sptest.adb (added) * c/src/ada-tests/sptests/spsize/sptest.ads (added) * c/src/ada-tests/tmtests/tm01/tmtest.adb (added) * c/src/ada-tests/tmtests/tm01/tmtest.ads (added) * c/src/ada-tests/tmtests/tm02/tmtest.adb (added) * c/src/ada-tests/tmtests/tm02/tmtest.ads (added) * c/src/ada-tests/tmtests/tm03/tmtest.adb (added) * c/src/ada-tests/tmtests/tm03/tmtest.ads (added) * c/src/ada-tests/tmtests/tm04/tmtest.adb (added) * c/src/ada-tests/tmtests/tm04/tmtest.ads (added) * c/src/ada-tests/tmtests/tm05/tmtest.adb (added) * c/src/ada-tests/tmtests/tm05/tmtest.ads (added) * c/src/ada-tests/tmtests/tm06/tmtest.adb (added) * c/src/ada-tests/tmtests/tm06/tmtest.ads (added) * c/src/ada-tests/tmtests/tm07/tmtest.adb (added) * c/src/ada-tests/tmtests/tm07/tmtest.ads (added) * c/src/ada-tests/tmtests/tm08/tmtest.adb (added) * c/src/ada-tests/tmtests/tm08/tmtest.ads (added) * c/src/ada-tests/tmtests/tm09/tmtest.adb (added) * c/src/ada-tests/tmtests/tm09/tmtest.ads (added) * c/src/ada-tests/tmtests/tm10/tmtest.adb (added) * c/src/ada-tests/tmtests/tm10/tmtest.ads (added) * c/src/ada-tests/tmtests/tm11/tmtest.adb (added) * c/src/ada-tests/tmtests/tm11/tmtest.ads (added) * c/src/ada-tests/tmtests/tm12/tmtest.adb (added) * c/src/ada-tests/tmtests/tm12/tmtest.ads (added) * c/src/ada-tests/tmtests/tm13/tmtest.adb (added) * c/src/ada-tests/tmtests/tm13/tmtest.ads (added) * c/src/ada-tests/tmtests/tm14/tmtest.adb (added) * c/src/ada-tests/tmtests/tm14/tmtest.ads (added) * c/src/ada-tests/tmtests/tm15/tmtest.adb (added) * c/src/ada-tests/tmtests/tm15/tmtest.ads (added) * c/src/ada-tests/tmtests/tm16/tmtest.adb (added) * c/src/ada-tests/tmtests/tm16/tmtest.ads (added) * c/src/ada-tests/tmtests/tm17/tmtest.adb (added) * c/src/ada-tests/tmtests/tm17/tmtest.ads (added) * c/src/ada-tests/tmtests/tm18/tmtest.adb (added) * c/src/ada-tests/tmtests/tm18/tmtest.ads (added) * c/src/ada-tests/tmtests/tm19/tmtest.adb (added) * c/src/ada-tests/tmtests/tm19/tmtest.ads (added) * c/src/ada-tests/tmtests/tm20/tmtest.adb (added) * c/src/ada-tests/tmtests/tm20/tmtest.ads (added) * c/src/ada-tests/tmtests/tm21/tmtest.adb (added) * c/src/ada-tests/tmtests/tm21/tmtest.ads (added) * c/src/ada-tests/tmtests/tm22/tmtest.adb (added) * c/src/ada-tests/tmtests/tm22/tmtest.ads (added) * c/src/ada-tests/tmtests/tm23/tmtest.adb (added) * c/src/ada-tests/tmtests/tm23/tmtest.ads (added) * c/src/ada-tests/tmtests/tm24/tmtest.adb (added) * c/src/ada-tests/tmtests/tm24/tmtest.ads (added) * c/src/ada-tests/tmtests/tm25/tmtest.adb (added) * c/src/ada-tests/tmtests/tm25/tmtest.ads (added) * c/src/ada-tests/tmtests/tm26/tmtest.ads (added) * c/src/ada-tests/tmtests/tm27/tmtest.adb (added) * c/src/ada-tests/tmtests/tm27/tmtest.ads (added) * c/src/ada-tests/tmtests/tm28/tmtest.adb (added) * c/src/ada-tests/tmtests/tm28/tmtest.ads (added) * c/src/ada-tests/tmtests/tm29/tmtest.adb (added) * c/src/ada-tests/tmtests/tm29/tmtest.ads (added) * c/src/ada-tests/tmtests/tmck/tmtest.adb (added) * c/src/ada-tests/tmtests/tmck/tmtest.ads (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (added) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (added) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (added) Initial revision
