# # ChangeLog for c/src/ada-tests/tmtests/tm02/tmtest.adb in rtems # # Generated by Trac 1.2.1.dev0 # 04/18/24 12:00:13 Mon, 02 Jun 1997 20:19:03 GMT Joel Sherrill [6d4e604b] * c/src/ada-tests/mptests/mp01/mptest.adb (added) * c/src/ada-tests/mptests/mp01/mptest.ads (added) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp02/mptest.adb (added) * c/src/ada-tests/mptests/mp02/mptest.ads (added) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp03/mptest.adb (added) * c/src/ada-tests/mptests/mp03/mptest.ads (added) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp04/mptest.adb (added) * c/src/ada-tests/mptests/mp04/mptest.ads (added) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp05/mptest.adb (added) * c/src/ada-tests/mptests/mp05/mptest.ads (added) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp06/mptest.adb (added) * c/src/ada-tests/mptests/mp06/mptest.ads (added) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp07/mptest.adb (added) * c/src/ada-tests/mptests/mp07/mptest.ads (added) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp08/mptest.adb (added) * c/src/ada-tests/mptests/mp08/mptest.ads (added) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp09/mptest.adb (added) * c/src/ada-tests/mptests/mp09/mptest.ads (added) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp10/mptest.adb (added) * c/src/ada-tests/mptests/mp10/mptest.ads (added) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp11/mptest.adb (added) * c/src/ada-tests/mptests/mp11/mptest.ads (added) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp12/mptest.adb (added) * c/src/ada-tests/mptests/mp12/mptest.ads (added) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp13/mptest.adb (added) * c/src/ada-tests/mptests/mp13/mptest.ads (added) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp14/mptest.adb (added) * c/src/ada-tests/mptests/mp14/mptest.ads (added) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_mp/mptest.adb (added) * c/src/ada-tests/samples/base_mp/mptest.ads (added) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_sp/sptest.adb (added) * c/src/ada-tests/samples/base_sp/sptest.ads (added) * c/src/ada-tests/samples/hello/sptest.adb (added) * c/src/ada-tests/samples/hello/sptest.ads (added) * c/src/ada-tests/samples/ticker/sptest.adb (added) * c/src/ada-tests/samples/ticker/sptest.ads (added) * c/src/ada-tests/sptests/sp01/sptest.adb (added) * c/src/ada-tests/sptests/sp01/sptest.ads (added) * c/src/ada-tests/sptests/sp02/sptest.adb (added) * c/src/ada-tests/sptests/sp02/sptest.ads (added) * c/src/ada-tests/sptests/sp03/sptest.adb (added) * c/src/ada-tests/sptests/sp03/sptest.ads (added) * c/src/ada-tests/sptests/sp04/sptest.adb (added) * c/src/ada-tests/sptests/sp04/sptest.ads (added) * c/src/ada-tests/sptests/sp05/sptest.adb (added) * c/src/ada-tests/sptests/sp05/sptest.ads (added) * c/src/ada-tests/sptests/sp06/sptest.adb (added) * c/src/ada-tests/sptests/sp06/sptest.ads (added) * c/src/ada-tests/sptests/sp07/sptest.adb (added) * c/src/ada-tests/sptests/sp07/sptest.ads (added) * c/src/ada-tests/sptests/sp08/sptest.adb (added) * c/src/ada-tests/sptests/sp08/sptest.ads (added) * c/src/ada-tests/sptests/sp09/sptest.adb (added) * c/src/ada-tests/sptests/sp09/sptest.ads (added) * c/src/ada-tests/sptests/sp11/sptest.adb (added) * c/src/ada-tests/sptests/sp11/sptest.ads (added) * c/src/ada-tests/sptests/sp12/sptest.adb (added) * c/src/ada-tests/sptests/sp12/sptest.ads (added) * c/src/ada-tests/sptests/sp13/sptest.adb (added) * c/src/ada-tests/sptests/sp13/sptest.ads (added) * c/src/ada-tests/sptests/sp14/sptest.adb (added) * c/src/ada-tests/sptests/sp14/sptest.ads (added) * c/src/ada-tests/sptests/sp15/sptest.adb (added) * c/src/ada-tests/sptests/sp15/sptest.ads (added) * c/src/ada-tests/sptests/sp16/sptest.adb (added) * c/src/ada-tests/sptests/sp16/sptest.ads (added) * c/src/ada-tests/sptests/sp17/sptest.adb (added) * c/src/ada-tests/sptests/sp17/sptest.ads (added) * c/src/ada-tests/sptests/sp19/sptest.ads (added) * c/src/ada-tests/sptests/sp20/sptest.adb (added) * c/src/ada-tests/sptests/sp20/sptest.ads (added) * c/src/ada-tests/sptests/sp21/sptest.adb (added) * c/src/ada-tests/sptests/sp21/sptest.ads (added) * c/src/ada-tests/sptests/sp22/sptest.adb (added) * c/src/ada-tests/sptests/sp22/sptest.ads (added) * c/src/ada-tests/sptests/sp23/sptest.adb (added) * c/src/ada-tests/sptests/sp23/sptest.ads (added) * c/src/ada-tests/sptests/sp24/sptest.adb (added) * c/src/ada-tests/sptests/sp24/sptest.ads (added) * c/src/ada-tests/sptests/sp25/sptest.adb (added) * c/src/ada-tests/sptests/sp25/sptest.ads (added) * c/src/ada-tests/sptests/spsize/sptest.adb (added) * c/src/ada-tests/sptests/spsize/sptest.ads (added) * c/src/ada-tests/tmtests/tm01/tmtest.adb (added) * c/src/ada-tests/tmtests/tm01/tmtest.ads (added) * c/src/ada-tests/tmtests/tm02/tmtest.adb (added) * c/src/ada-tests/tmtests/tm02/tmtest.ads (added) * c/src/ada-tests/tmtests/tm03/tmtest.adb (added) * c/src/ada-tests/tmtests/tm03/tmtest.ads (added) * c/src/ada-tests/tmtests/tm04/tmtest.adb (added) * c/src/ada-tests/tmtests/tm04/tmtest.ads (added) * c/src/ada-tests/tmtests/tm05/tmtest.adb (added) * c/src/ada-tests/tmtests/tm05/tmtest.ads (added) * c/src/ada-tests/tmtests/tm06/tmtest.adb (added) * c/src/ada-tests/tmtests/tm06/tmtest.ads (added) * c/src/ada-tests/tmtests/tm07/tmtest.adb (added) * c/src/ada-tests/tmtests/tm07/tmtest.ads (added) * c/src/ada-tests/tmtests/tm08/tmtest.adb (added) * c/src/ada-tests/tmtests/tm08/tmtest.ads (added) * c/src/ada-tests/tmtests/tm09/tmtest.adb (added) * c/src/ada-tests/tmtests/tm09/tmtest.ads (added) * c/src/ada-tests/tmtests/tm10/tmtest.adb (added) * c/src/ada-tests/tmtests/tm10/tmtest.ads (added) * c/src/ada-tests/tmtests/tm11/tmtest.adb (added) * c/src/ada-tests/tmtests/tm11/tmtest.ads (added) * c/src/ada-tests/tmtests/tm12/tmtest.adb (added) * c/src/ada-tests/tmtests/tm12/tmtest.ads (added) * c/src/ada-tests/tmtests/tm13/tmtest.adb (added) * c/src/ada-tests/tmtests/tm13/tmtest.ads (added) * c/src/ada-tests/tmtests/tm14/tmtest.adb (added) * c/src/ada-tests/tmtests/tm14/tmtest.ads (added) * c/src/ada-tests/tmtests/tm15/tmtest.adb (added) * c/src/ada-tests/tmtests/tm15/tmtest.ads (added) * c/src/ada-tests/tmtests/tm16/tmtest.adb (added) * c/src/ada-tests/tmtests/tm16/tmtest.ads (added) * c/src/ada-tests/tmtests/tm17/tmtest.adb (added) * c/src/ada-tests/tmtests/tm17/tmtest.ads (added) * c/src/ada-tests/tmtests/tm18/tmtest.adb (added) * c/src/ada-tests/tmtests/tm18/tmtest.ads (added) * c/src/ada-tests/tmtests/tm19/tmtest.adb (added) * c/src/ada-tests/tmtests/tm19/tmtest.ads (added) * c/src/ada-tests/tmtests/tm20/tmtest.adb (added) * c/src/ada-tests/tmtests/tm20/tmtest.ads (added) * c/src/ada-tests/tmtests/tm21/tmtest.adb (added) * c/src/ada-tests/tmtests/tm21/tmtest.ads (added) * c/src/ada-tests/tmtests/tm22/tmtest.adb (added) * c/src/ada-tests/tmtests/tm22/tmtest.ads (added) * c/src/ada-tests/tmtests/tm23/tmtest.adb (added) * c/src/ada-tests/tmtests/tm23/tmtest.ads (added) * c/src/ada-tests/tmtests/tm24/tmtest.adb (added) * c/src/ada-tests/tmtests/tm24/tmtest.ads (added) * c/src/ada-tests/tmtests/tm25/tmtest.adb (added) * c/src/ada-tests/tmtests/tm25/tmtest.ads (added) * c/src/ada-tests/tmtests/tm26/tmtest.ads (added) * c/src/ada-tests/tmtests/tm27/tmtest.adb (added) * c/src/ada-tests/tmtests/tm27/tmtest.ads (added) * c/src/ada-tests/tmtests/tm28/tmtest.adb (added) * c/src/ada-tests/tmtests/tm28/tmtest.ads (added) * c/src/ada-tests/tmtests/tm29/tmtest.adb (added) * c/src/ada-tests/tmtests/tm29/tmtest.ads (added) * c/src/ada-tests/tmtests/tmck/tmtest.adb (added) * c/src/ada-tests/tmtests/tmck/tmtest.ads (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (added) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (added) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (added) Initial revision
