# # ChangeLog for c/src/ada-tests/support/unsigned32_io.ads in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 01:28:23 Mon, 02 Jun 1997 21:16:14 GMT Joel Sherrill [196a6b9] * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/support/status_io.ads (modified) * c/src/ada-tests/support/test_support.adb (modified) * c/src/ada-tests/support/test_support.ads (modified) * c/src/ada-tests/support/unsigned32_io.ads (modified) Changed license and copyright notice. Added "development" style CVS Id Mon, 02 Jun 1997 20:52:48 GMT Joel Sherrill [f3f06f79] * c/src/ada-tests/support/init.c (added) * c/src/ada-tests/support/status_io.ads (added) * c/src/ada-tests/support/test_support.adb (added) * c/src/ada-tests/support/test_support.ads (added) * c/src/ada-tests/support/unsigned32_io.ads (added) * c/src/ada/rtems.adb (added) * c/src/ada/rtems.ads (added) * cpukit/ada/rtems.adb (added) * cpukit/ada/rtems.ads (added) added new files from test area. This code has successfully been ...
