# # ChangeLog for c/src/ada-tests/sptests/sp08/sp08.adb in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 23:20:22 Tue, 03 Jun 1997 00:13:05 GMT Joel Sherrill [f2078ec] * c/src/ada-tests/sptests/sp01/sp01.adb (modified) * c/src/ada-tests/sptests/sp02/sp02.adb (modified) * c/src/ada-tests/sptests/sp03/sp03.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/README (added) * c/src/ada-tests/sptests/sp04/sp04.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sp05.adb (modified) * c/src/ada-tests/sptests/sp06/sp06.adb (modified) * c/src/ada-tests/sptests/sp07/sp07.adb (modified) * c/src/ada-tests/sptests/sp08/sp08.adb (modified) * c/src/ada-tests/sptests/sp09/sp09.adb (modified) * c/src/ada-tests/sptests/sp11/sp11.adb (modified) * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp13/sp13.adb (modified) * c/src/ada-tests/sptests/sp14/sp14.adb (modified) * c/src/ada-tests/sptests/sp15/sp15.adb (modified) * c/src/ada-tests/sptests/sp16/sp16.adb (modified) * c/src/ada-tests/sptests/sp17/sp17.adb (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (modified) * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp21/sp21.adb (modified) * c/src/ada-tests/sptests/sp22/sp22.adb (modified) * c/src/ada-tests/sptests/sp23/sp23.adb (modified) * c/src/ada-tests/sptests/sp24/sp24.adb (modified) * c/src/ada-tests/sptests/sp25/sp25.adb (modified) * c/src/ada-tests/sptests/spsize/spsize.adb (modified) New style main procedure which creates the test's RTEMS ... Mon, 02 Jun 1997 22:37:28 GMT Joel Sherrill [7f79b673] * c/src/ada-tests/sptests/sp01/sp01.adb (modified) * c/src/ada-tests/sptests/sp02/sp02.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/sp03.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/sp04.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sp05.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/sp06.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/sp07.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/sp08.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/sp09.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/sp11.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/sp12.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/sp13.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/sp14.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/sp15.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/sp16.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/sp17.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/sp19.adb (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/sp20.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp21/sp21.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/sp22.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/sp23.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/sp24.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/sp25.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spsize/spsize.adb (modified) * c/src/ada-tests/sptests/spsize/sptest.ads (modified) readded body for "main" procedures Mon, 02 Jun 1997 21:53:05 GMT Joel Sherrill [cf1ced66] * c/src/ada-tests/sptests/sp01/sp01.adb (added) * c/src/ada-tests/sptests/sp02/sp02.adb (added) * c/src/ada-tests/sptests/sp03/sp03.adb (added) * c/src/ada-tests/sptests/sp04/sp04.adb (added) * c/src/ada-tests/sptests/sp05/sp05.adb (added) * c/src/ada-tests/sptests/sp06/sp06.adb (added) * c/src/ada-tests/sptests/sp07/sp07.adb (added) * c/src/ada-tests/sptests/sp08/sp08.adb (added) * c/src/ada-tests/sptests/sp09/sp09.adb (added) * c/src/ada-tests/sptests/sp11/sp11.adb (added) * c/src/ada-tests/sptests/sp12/sp12.adb (added) * c/src/ada-tests/sptests/sp13/sp13.adb (added) * c/src/ada-tests/sptests/sp14/sp14.adb (added) * c/src/ada-tests/sptests/sp15/sp15.adb (added) * c/src/ada-tests/sptests/sp16/sp16.adb (added) * c/src/ada-tests/sptests/sp17/sp17.adb (added) * c/src/ada-tests/sptests/sp19/sp19.adb (added) * c/src/ada-tests/sptests/sp20/sp20.adb (added) * c/src/ada-tests/sptests/sp21/sp21.adb (added) * c/src/ada-tests/sptests/sp22/sp22.adb (added) * c/src/ada-tests/sptests/sp23/sp23.adb (added) * c/src/ada-tests/sptests/sp24/sp24.adb (added) * c/src/ada-tests/sptests/sp25/sp25.adb (added) * c/src/ada-tests/sptests/spsize/spsize.adb (added) * c/src/ada-tests/tmtests/tm01/tm01.adb (added) * c/src/ada-tests/tmtests/tm02/tm02.adb (added) * c/src/ada-tests/tmtests/tm03/tm03.adb (added) * c/src/ada-tests/tmtests/tm04/tm04.adb (added) * c/src/ada-tests/tmtests/tm05/tm05.adb (added) * c/src/ada-tests/tmtests/tm06/tm06.adb (added) * c/src/ada-tests/tmtests/tm07/tm07.adb (added) * c/src/ada-tests/tmtests/tm08/tm08.adb (added) * c/src/ada-tests/tmtests/tm09/tm09.adb (added) * c/src/ada-tests/tmtests/tm10/tm10.adb (added) * c/src/ada-tests/tmtests/tm11/tm11.adb (added) * c/src/ada-tests/tmtests/tm12/tm12.adb (added) * c/src/ada-tests/tmtests/tm13/tm13.adb (added) * c/src/ada-tests/tmtests/tm14/tm14.adb (added) * c/src/ada-tests/tmtests/tm15/tm15.adb (added) * c/src/ada-tests/tmtests/tm16/tm16.adb (added) * c/src/ada-tests/tmtests/tm17/tm17.adb (added) * c/src/ada-tests/tmtests/tm18/tm18.adb (added) * c/src/ada-tests/tmtests/tm19/tm19.adb (added) * c/src/ada-tests/tmtests/tm20/tm20.adb (added) * c/src/ada-tests/tmtests/tm21/tm21.adb (added) * c/src/ada-tests/tmtests/tm22/tm22.adb (added) * c/src/ada-tests/tmtests/tm23/tm23.adb (added) * c/src/ada-tests/tmtests/tm24/tm24.adb (added) * c/src/ada-tests/tmtests/tm25/tm25.adb (added) * c/src/ada-tests/tmtests/tm26/tm26.adb (added) * c/src/ada-tests/tmtests/tm27/tm27.adb (added) * c/src/ada-tests/tmtests/tm28/tm28.adb (added) * c/src/ada-tests/tmtests/tm29/tm29.adb (added) * c/src/ada-tests/tmtests/tmck/tmck.adb (added) * c/src/ada-tests/tmtests/tmoverhd/tmoverhd.adb (added) new file - automatically generated by a script
