# # ChangeLog for c/src/ada-tests/mptests/mp01 in rtems # # Generated by Trac 1.2.1.dev0 # 03/29/24 05:10:58 Tue, 03 Sep 2002 18:31:23 GMT Joel Sherrill [addebe67] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (modified) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_mp/mptest.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (deleted) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (deleted) 2002-09-03 Joel Sherrill * base_mp ... Mon, 02 Sep 2002 05:19:01 GMT Ralf Corsepius [7625d9a3] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp01/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp02/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp02/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp03/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp03/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp04/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp04/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp05/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp05/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp06/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp06/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp07/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp07/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp08/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp08/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp09/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp09/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp10/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp10/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp11/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp11/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp12/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp12/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp13/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp13/node2/.cvsignore (added) * c/src/ada-tests/mptests/mp14/node1/.cvsignore (added) * c/src/ada-tests/mptests/mp14/node2/.cvsignore (added) * c/src/ada-tests/samples/base_mp/node1/.cvsignore (added) * c/src/ada-tests/samples/base_mp/node2/.cvsignore (added) 2002-09-02 Ralf Corsepius * ... Mon, 02 Sep 2002 05:08:57 GMT Ralf Corsepius [0c7ef52] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada-tests/mptests/Makefile.am (added) * c/src/ada-tests/mptests/mp01/Makefile.am (added) * c/src/ada-tests/mptests/mp01/node1/Makefile.am (added) * c/src/ada-tests/mptests/mp01/node2/Makefile.am (added) * c/src/ada-tests/samples/base_mp/Makefile.am (modified) * c/src/ada-tests/samples/base_mp/node1/Makefile.am (added) * c/src/ada-tests/samples/base_mp/node2/Makefile.am (added) 2002-09-02 Ralf Corsepius * ... Mon, 26 Aug 2002 14:27:21 GMT Joel Sherrill [190f5c23] * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/mptest.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) 2002-08-26 Joel Sherrill * ... Mon, 26 Aug 2002 05:51:56 GMT Ralf Corsepius [28cf529] * c/src/ada-tests/.cvsignore (added) * c/src/ada-tests/ChangeLog (added) * c/src/ada-tests/mptests/.cvsignore (added) * c/src/ada-tests/mptests/mp01/.cvsignore (added) * c/src/ada-tests/mptests/mp02/.cvsignore (added) * c/src/ada-tests/mptests/mp03/.cvsignore (added) * c/src/ada-tests/mptests/mp04/.cvsignore (added) * c/src/ada-tests/mptests/mp05/.cvsignore (added) * c/src/ada-tests/mptests/mp06/.cvsignore (added) * c/src/ada-tests/mptests/mp07/.cvsignore (added) * c/src/ada-tests/mptests/mp08/.cvsignore (added) * c/src/ada-tests/mptests/mp09/.cvsignore (added) * c/src/ada-tests/mptests/mp10/.cvsignore (added) * c/src/ada-tests/mptests/mp11/.cvsignore (added) * c/src/ada-tests/mptests/mp12/.cvsignore (added) * c/src/ada-tests/mptests/mp13/.cvsignore (added) * c/src/ada-tests/mptests/mp14/.cvsignore (added) * c/src/ada-tests/samples/.cvsignore (added) * c/src/ada-tests/samples/base_sp/.cvsignore (added) * c/src/ada-tests/samples/hello/.cvsignore (added) * c/src/ada-tests/samples/ticker/.cvsignore (added) * c/src/ada-tests/sptests/.cvsignore (added) * c/src/ada-tests/sptests/sp01/.cvsignore (added) * c/src/ada-tests/sptests/sp02/.cvsignore (added) * c/src/ada-tests/sptests/sp03/.cvsignore (added) * c/src/ada-tests/sptests/sp04/.cvsignore (added) * c/src/ada-tests/sptests/sp05/.cvsignore (added) * c/src/ada-tests/sptests/sp06/.cvsignore (added) * c/src/ada-tests/sptests/sp07/.cvsignore (added) * c/src/ada-tests/sptests/sp08/.cvsignore (added) * c/src/ada-tests/sptests/sp09/.cvsignore (added) * c/src/ada-tests/sptests/sp11/.cvsignore (added) * c/src/ada-tests/sptests/sp12/.cvsignore (added) * c/src/ada-tests/sptests/sp13/.cvsignore (added) * c/src/ada-tests/sptests/sp14/.cvsignore (added) * c/src/ada-tests/sptests/sp15/.cvsignore (added) * c/src/ada-tests/sptests/sp16/.cvsignore (added) * c/src/ada-tests/sptests/sp17/.cvsignore (added) * c/src/ada-tests/sptests/sp19/.cvsignore (added) * c/src/ada-tests/sptests/sp20/.cvsignore (added) * c/src/ada-tests/sptests/sp21/.cvsignore (added) * c/src/ada-tests/sptests/sp22/.cvsignore (added) * c/src/ada-tests/sptests/sp23/.cvsignore (added) * c/src/ada-tests/sptests/sp24/.cvsignore (added) * c/src/ada-tests/sptests/sp25/.cvsignore (added) * c/src/ada-tests/sptests/spsize/.cvsignore (added) * c/src/ada-tests/support/.cvsignore (added) * c/src/ada-tests/tmtests/.cvsignore (added) * c/src/ada-tests/tmtests/tm01/.cvsignore (added) * c/src/ada-tests/tmtests/tm02/.cvsignore (added) * c/src/ada-tests/tmtests/tm03/.cvsignore (added) * c/src/ada-tests/tmtests/tm04/.cvsignore (added) * c/src/ada-tests/tmtests/tm05/.cvsignore (added) * c/src/ada-tests/tmtests/tm06/.cvsignore (added) * c/src/ada-tests/tmtests/tm07/.cvsignore (added) * c/src/ada-tests/tmtests/tm08/.cvsignore (added) * c/src/ada-tests/tmtests/tm09/.cvsignore (added) * c/src/ada-tests/tmtests/tm10/.cvsignore (added) * c/src/ada-tests/tmtests/tm11/.cvsignore (added) * c/src/ada-tests/tmtests/tm12/.cvsignore (added) * c/src/ada-tests/tmtests/tm13/.cvsignore (added) * c/src/ada-tests/tmtests/tm14/.cvsignore (added) * c/src/ada-tests/tmtests/tm15/.cvsignore (added) * c/src/ada-tests/tmtests/tm16/.cvsignore (added) * c/src/ada-tests/tmtests/tm17/.cvsignore (added) * c/src/ada-tests/tmtests/tm18/.cvsignore (added) * c/src/ada-tests/tmtests/tm19/.cvsignore (added) * c/src/ada-tests/tmtests/tm20/.cvsignore (added) * c/src/ada-tests/tmtests/tm21/.cvsignore (added) * c/src/ada-tests/tmtests/tm22/.cvsignore (added) * c/src/ada-tests/tmtests/tm23/.cvsignore (added) * c/src/ada-tests/tmtests/tm24/.cvsignore (added) * c/src/ada-tests/tmtests/tm25/.cvsignore (added) * c/src/ada-tests/tmtests/tm26/.cvsignore (added) * c/src/ada-tests/tmtests/tm27/.cvsignore (added) * c/src/ada-tests/tmtests/tm28/.cvsignore (added) * c/src/ada-tests/tmtests/tm29/.cvsignore (added) * c/src/ada-tests/tmtests/tmck/.cvsignore (added) * c/src/ada-tests/tmtests/tmoverhd/.cvsignore (added) 2002-08-26 Ralf Corsepius * ... Wed, 04 Jun 1997 18:54:18 GMT Joel Sherrill [e7f86ef] * c/src/ada-tests/mptests/mp01/config.h (added) * c/src/ada-tests/mptests/mp01/mp01.adb (added) new file Tue, 03 Jun 1997 00:34:04 GMT Joel Sherrill [d0f426a1] * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/support/init.c (modified) * c/src/ada-tests/support/test_support.adb (modified) *** empty log message *** Mon, 02 Jun 1997 20:57:52 GMT Joel Sherrill [9917d5da] * c/src/ada-tests/mptests/mp01/node1/mp01.scn (added) * c/src/ada-tests/mptests/mp01/node2/mp01.scn (added) * c/src/ada-tests/mptests/mp02/node1/mp02.scn (added) * c/src/ada-tests/mptests/mp02/node2/mp02.scn (added) * c/src/ada-tests/mptests/mp03/node1/mp03.scn (added) * c/src/ada-tests/mptests/mp03/node2/mp03.scn (added) * c/src/ada-tests/mptests/mp04/node1/mp04.scn (added) * c/src/ada-tests/mptests/mp04/node2/mp04.scn (added) * c/src/ada-tests/mptests/mp05/node1/mp05.scn (added) * c/src/ada-tests/mptests/mp05/node2/mp05.scn (added) * c/src/ada-tests/mptests/mp06/node1/mp06.scn (added) * c/src/ada-tests/mptests/mp06/node2/mp06.scn (added) * c/src/ada-tests/mptests/mp07/node1/mp07.scn (added) * c/src/ada-tests/mptests/mp07/node2/mp07.scn (added) * c/src/ada-tests/mptests/mp08/node1/mp08.scn (added) * c/src/ada-tests/mptests/mp08/node2/mp08.scn (added) * c/src/ada-tests/mptests/mp09/node1/mp09.scn (added) * c/src/ada-tests/mptests/mp09/node2/mp09.scn (added) * c/src/ada-tests/mptests/mp10/node1/mp10.scn (added) * c/src/ada-tests/mptests/mp10/node2/mp10.scn (added) * c/src/ada-tests/mptests/mp11/node1/mp11.scn (added) * c/src/ada-tests/mptests/mp11/node2/mp11.scn (added) * c/src/ada-tests/mptests/mp12/node1/mp12.scn (added) * c/src/ada-tests/mptests/mp12/node2/mp12.scn (added) * c/src/ada-tests/mptests/mp13/node1/mp13.scn (added) * c/src/ada-tests/mptests/mp13/node2/mp13.scn (added) * c/src/ada-tests/mptests/mp14/node1/mp14.scn (added) * c/src/ada-tests/mptests/mp14/node2/mp14.scn (added) * c/src/ada-tests/samples/base_mp/node1/base_mp.scn (added) * c/src/ada-tests/samples/base_mp/node2/base_mp.scn (added) * c/src/ada-tests/samples/base_sp/base_sp.scn (added) * c/src/ada-tests/samples/hello/hello.scn (added) * c/src/ada-tests/samples/ticker/ticker.scn (added) * c/src/ada-tests/sptests/sp01/sp01.scn (added) * c/src/ada-tests/sptests/sp02/sp02.scn (added) * c/src/ada-tests/sptests/sp03/sp03.scn (added) * c/src/ada-tests/sptests/sp04/sp04.scn (added) * c/src/ada-tests/sptests/sp05/sp05.scn (added) * c/src/ada-tests/sptests/sp06/sp06.scn (added) * c/src/ada-tests/sptests/sp07/sp07.scn (added) * c/src/ada-tests/sptests/sp08/sp08.scn (added) * c/src/ada-tests/sptests/sp09/sp09.scn (added) * c/src/ada-tests/sptests/sp11/sp11.scn (added) * c/src/ada-tests/sptests/sp12/sp12.scn (added) * c/src/ada-tests/sptests/sp13/sp13.scn (added) * c/src/ada-tests/sptests/sp14/sp14.scn (added) * c/src/ada-tests/sptests/sp15/sp15.scn (added) * c/src/ada-tests/sptests/sp16/sp16.scn (added) * c/src/ada-tests/sptests/sp17/sp17.scn (added) * c/src/ada-tests/sptests/sp19/sp19.scn (added) * c/src/ada-tests/sptests/sp20/sp20.scn (added) * c/src/ada-tests/sptests/sp21/sp21.scn (added) * c/src/ada-tests/sptests/sp22/sp22.scn (added) * c/src/ada-tests/sptests/sp23/sp23.scn (added) * c/src/ada-tests/sptests/sp24/sp24.scn (added) * c/src/ada-tests/sptests/sp25/sp25.scn (added) added screen files from 3.2.1 Mon, 02 Jun 1997 20:32:11 GMT Joel Sherrill [bf9ae83] * c/src/ada-tests/mptests/mp01/mptest.adb (modified) * c/src/ada-tests/mptests/mp01/mptest.ads (modified) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp02/mptest.adb (modified) * c/src/ada-tests/mptests/mp02/mptest.ads (modified) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp03/mptest.adb (modified) * c/src/ada-tests/mptests/mp03/mptest.ads (modified) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp04/mptest.adb (modified) * c/src/ada-tests/mptests/mp04/mptest.ads (modified) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp05/mptest.adb (modified) * c/src/ada-tests/mptests/mp05/mptest.ads (modified) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp06/mptest.adb (modified) * c/src/ada-tests/mptests/mp06/mptest.ads (modified) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp07/mptest.adb (modified) * c/src/ada-tests/mptests/mp07/mptest.ads (modified) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp08/mptest.adb (modified) * c/src/ada-tests/mptests/mp08/mptest.ads (modified) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp09/mptest.adb (modified) * c/src/ada-tests/mptests/mp09/mptest.ads (modified) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp10/mptest.adb (modified) * c/src/ada-tests/mptests/mp10/mptest.ads (modified) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp11/mptest.adb (modified) * c/src/ada-tests/mptests/mp11/mptest.ads (modified) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp12/mptest.adb (modified) * c/src/ada-tests/mptests/mp12/mptest.ads (modified) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp13/mptest.adb (modified) * c/src/ada-tests/mptests/mp13/mptest.ads (modified) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.adb (modified) * c/src/ada-tests/mptests/mp14/mptest.ads (modified) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.adb (modified) * c/src/ada-tests/samples/base_mp/mptest.ads (modified) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.adb (modified) * c/src/ada-tests/samples/base_sp/sptest.ads (modified) * c/src/ada-tests/samples/hello/sptest.adb (modified) * c/src/ada-tests/samples/hello/sptest.ads (modified) * c/src/ada-tests/samples/ticker/sptest.adb (modified) * c/src/ada-tests/samples/ticker/sptest.ads (modified) * c/src/ada-tests/sptests/sp01/sptest.adb (modified) * c/src/ada-tests/sptests/sp01/sptest.ads (modified) * c/src/ada-tests/sptests/sp02/sptest.adb (modified) * c/src/ada-tests/sptests/sp02/sptest.ads (modified) * c/src/ada-tests/sptests/sp03/sptest.adb (modified) * c/src/ada-tests/sptests/sp03/sptest.ads (modified) * c/src/ada-tests/sptests/sp04/sptest.adb (modified) * c/src/ada-tests/sptests/sp04/sptest.ads (modified) * c/src/ada-tests/sptests/sp05/sptest.adb (modified) * c/src/ada-tests/sptests/sp05/sptest.ads (modified) * c/src/ada-tests/sptests/sp06/sptest.adb (modified) * c/src/ada-tests/sptests/sp06/sptest.ads (modified) * c/src/ada-tests/sptests/sp07/sptest.adb (modified) * c/src/ada-tests/sptests/sp07/sptest.ads (modified) * c/src/ada-tests/sptests/sp08/sptest.adb (modified) * c/src/ada-tests/sptests/sp08/sptest.ads (modified) * c/src/ada-tests/sptests/sp09/sptest.adb (modified) * c/src/ada-tests/sptests/sp09/sptest.ads (modified) * c/src/ada-tests/sptests/sp11/sptest.adb (modified) * c/src/ada-tests/sptests/sp11/sptest.ads (modified) * c/src/ada-tests/sptests/sp12/sptest.adb (modified) * c/src/ada-tests/sptests/sp12/sptest.ads (modified) * c/src/ada-tests/sptests/sp13/sptest.adb (modified) * c/src/ada-tests/sptests/sp13/sptest.ads (modified) * c/src/ada-tests/sptests/sp14/sptest.adb (modified) * c/src/ada-tests/sptests/sp14/sptest.ads (modified) * c/src/ada-tests/sptests/sp15/sptest.adb (modified) * c/src/ada-tests/sptests/sp15/sptest.ads (modified) * c/src/ada-tests/sptests/sp16/sptest.adb (modified) * c/src/ada-tests/sptests/sp16/sptest.ads (modified) * c/src/ada-tests/sptests/sp17/sptest.adb (modified) * c/src/ada-tests/sptests/sp17/sptest.ads (modified) * c/src/ada-tests/sptests/sp19/sptest.ads (modified) * c/src/ada-tests/sptests/sp20/sptest.adb (modified) * c/src/ada-tests/sptests/sp20/sptest.ads (modified) * c/src/ada-tests/sptests/sp21/sptest.adb (modified) * c/src/ada-tests/sptests/sp21/sptest.ads (modified) * c/src/ada-tests/sptests/sp22/sptest.adb (modified) * c/src/ada-tests/sptests/sp22/sptest.ads (modified) * c/src/ada-tests/sptests/sp23/sptest.adb (modified) * c/src/ada-tests/sptests/sp23/sptest.ads (modified) * c/src/ada-tests/sptests/sp24/sptest.adb (modified) * c/src/ada-tests/sptests/sp24/sptest.ads (modified) * c/src/ada-tests/sptests/sp25/sptest.adb (modified) * c/src/ada-tests/sptests/sp25/sptest.ads (modified) * c/src/ada-tests/sptests/spsize/sptest.adb (modified) * c/src/ada-tests/sptests/spsize/sptest.ads (modified) * c/src/ada-tests/tmtests/tm01/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm01/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm02/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm02/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm03/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm03/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm04/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm04/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm05/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm05/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm06/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm06/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm07/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm07/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm08/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm08/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm09/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm09/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm10/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm10/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm11/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm11/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm12/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm12/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm13/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm13/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm14/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm14/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm15/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm15/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm16/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm16/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm17/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm17/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm18/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm18/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm19/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm19/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm20/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm20/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm21/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm21/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm22/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm22/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm23/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm23/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm24/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm24/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm25/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm25/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm26/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm27/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm27/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm28/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm28/tmtest.ads (modified) * c/src/ada-tests/tmtests/tm29/tmtest.adb (modified) * c/src/ada-tests/tmtests/tm29/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmck/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmck/tmtest.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (modified) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (modified) modified copyright notice to be the same as RTEMS 4.0.0. changed ... Mon, 02 Jun 1997 20:19:03 GMT Joel Sherrill [6d4e604b] * c/src/ada-tests/mptests/mp01/mptest.adb (added) * c/src/ada-tests/mptests/mp01/mptest.ads (added) * c/src/ada-tests/mptests/mp01/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp01/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp02/mptest.adb (added) * c/src/ada-tests/mptests/mp02/mptest.ads (added) * c/src/ada-tests/mptests/mp02/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp02/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp03/mptest.adb (added) * c/src/ada-tests/mptests/mp03/mptest.ads (added) * c/src/ada-tests/mptests/mp03/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp03/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp04/mptest.adb (added) * c/src/ada-tests/mptests/mp04/mptest.ads (added) * c/src/ada-tests/mptests/mp04/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp04/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp05/mptest.adb (added) * c/src/ada-tests/mptests/mp05/mptest.ads (added) * c/src/ada-tests/mptests/mp05/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp05/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp06/mptest.adb (added) * c/src/ada-tests/mptests/mp06/mptest.ads (added) * c/src/ada-tests/mptests/mp06/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp06/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp07/mptest.adb (added) * c/src/ada-tests/mptests/mp07/mptest.ads (added) * c/src/ada-tests/mptests/mp07/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp07/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp08/mptest.adb (added) * c/src/ada-tests/mptests/mp08/mptest.ads (added) * c/src/ada-tests/mptests/mp08/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp08/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp09/mptest.adb (added) * c/src/ada-tests/mptests/mp09/mptest.ads (added) * c/src/ada-tests/mptests/mp09/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp09/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp10/mptest.adb (added) * c/src/ada-tests/mptests/mp10/mptest.ads (added) * c/src/ada-tests/mptests/mp10/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp10/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp11/mptest.adb (added) * c/src/ada-tests/mptests/mp11/mptest.ads (added) * c/src/ada-tests/mptests/mp11/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp11/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp12/mptest.adb (added) * c/src/ada-tests/mptests/mp12/mptest.ads (added) * c/src/ada-tests/mptests/mp12/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp12/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp13/mptest.adb (added) * c/src/ada-tests/mptests/mp13/mptest.ads (added) * c/src/ada-tests/mptests/mp13/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp13/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp14/mptest.adb (added) * c/src/ada-tests/mptests/mp14/mptest.ads (added) * c/src/ada-tests/mptests/mp14/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/mptests/mp14/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_mp/mptest.adb (added) * c/src/ada-tests/samples/base_mp/mptest.ads (added) * c/src/ada-tests/samples/base_mp/node1/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_mp/node2/mptest-per_node_configuration.adb (added) * c/src/ada-tests/samples/base_sp/sptest.adb (added) * c/src/ada-tests/samples/base_sp/sptest.ads (added) * c/src/ada-tests/samples/hello/sptest.adb (added) * c/src/ada-tests/samples/hello/sptest.ads (added) * c/src/ada-tests/samples/ticker/sptest.adb (added) * c/src/ada-tests/samples/ticker/sptest.ads (added) * c/src/ada-tests/sptests/sp01/sptest.adb (added) * c/src/ada-tests/sptests/sp01/sptest.ads (added) * c/src/ada-tests/sptests/sp02/sptest.adb (added) * c/src/ada-tests/sptests/sp02/sptest.ads (added) * c/src/ada-tests/sptests/sp03/sptest.adb (added) * c/src/ada-tests/sptests/sp03/sptest.ads (added) * c/src/ada-tests/sptests/sp04/sptest.adb (added) * c/src/ada-tests/sptests/sp04/sptest.ads (added) * c/src/ada-tests/sptests/sp05/sptest.adb (added) * c/src/ada-tests/sptests/sp05/sptest.ads (added) * c/src/ada-tests/sptests/sp06/sptest.adb (added) * c/src/ada-tests/sptests/sp06/sptest.ads (added) * c/src/ada-tests/sptests/sp07/sptest.adb (added) * c/src/ada-tests/sptests/sp07/sptest.ads (added) * c/src/ada-tests/sptests/sp08/sptest.adb (added) * c/src/ada-tests/sptests/sp08/sptest.ads (added) * c/src/ada-tests/sptests/sp09/sptest.adb (added) * c/src/ada-tests/sptests/sp09/sptest.ads (added) * c/src/ada-tests/sptests/sp11/sptest.adb (added) * c/src/ada-tests/sptests/sp11/sptest.ads (added) * c/src/ada-tests/sptests/sp12/sptest.adb (added) * c/src/ada-tests/sptests/sp12/sptest.ads (added) * c/src/ada-tests/sptests/sp13/sptest.adb (added) * c/src/ada-tests/sptests/sp13/sptest.ads (added) * c/src/ada-tests/sptests/sp14/sptest.adb (added) * c/src/ada-tests/sptests/sp14/sptest.ads (added) * c/src/ada-tests/sptests/sp15/sptest.adb (added) * c/src/ada-tests/sptests/sp15/sptest.ads (added) * c/src/ada-tests/sptests/sp16/sptest.adb (added) * c/src/ada-tests/sptests/sp16/sptest.ads (added) * c/src/ada-tests/sptests/sp17/sptest.adb (added) * c/src/ada-tests/sptests/sp17/sptest.ads (added) * c/src/ada-tests/sptests/sp19/sptest.ads (added) * c/src/ada-tests/sptests/sp20/sptest.adb (added) * c/src/ada-tests/sptests/sp20/sptest.ads (added) * c/src/ada-tests/sptests/sp21/sptest.adb (added) * c/src/ada-tests/sptests/sp21/sptest.ads (added) * c/src/ada-tests/sptests/sp22/sptest.adb (added) * c/src/ada-tests/sptests/sp22/sptest.ads (added) * c/src/ada-tests/sptests/sp23/sptest.adb (added) * c/src/ada-tests/sptests/sp23/sptest.ads (added) * c/src/ada-tests/sptests/sp24/sptest.adb (added) * c/src/ada-tests/sptests/sp24/sptest.ads (added) * c/src/ada-tests/sptests/sp25/sptest.adb (added) * c/src/ada-tests/sptests/sp25/sptest.ads (added) * c/src/ada-tests/sptests/spsize/sptest.adb (added) * c/src/ada-tests/sptests/spsize/sptest.ads (added) * c/src/ada-tests/tmtests/tm01/tmtest.adb (added) * c/src/ada-tests/tmtests/tm01/tmtest.ads (added) * c/src/ada-tests/tmtests/tm02/tmtest.adb (added) * c/src/ada-tests/tmtests/tm02/tmtest.ads (added) * c/src/ada-tests/tmtests/tm03/tmtest.adb (added) * c/src/ada-tests/tmtests/tm03/tmtest.ads (added) * c/src/ada-tests/tmtests/tm04/tmtest.adb (added) * c/src/ada-tests/tmtests/tm04/tmtest.ads (added) * c/src/ada-tests/tmtests/tm05/tmtest.adb (added) * c/src/ada-tests/tmtests/tm05/tmtest.ads (added) * c/src/ada-tests/tmtests/tm06/tmtest.adb (added) * c/src/ada-tests/tmtests/tm06/tmtest.ads (added) * c/src/ada-tests/tmtests/tm07/tmtest.adb (added) * c/src/ada-tests/tmtests/tm07/tmtest.ads (added) * c/src/ada-tests/tmtests/tm08/tmtest.adb (added) * c/src/ada-tests/tmtests/tm08/tmtest.ads (added) * c/src/ada-tests/tmtests/tm09/tmtest.adb (added) * c/src/ada-tests/tmtests/tm09/tmtest.ads (added) * c/src/ada-tests/tmtests/tm10/tmtest.adb (added) * c/src/ada-tests/tmtests/tm10/tmtest.ads (added) * c/src/ada-tests/tmtests/tm11/tmtest.adb (added) * c/src/ada-tests/tmtests/tm11/tmtest.ads (added) * c/src/ada-tests/tmtests/tm12/tmtest.adb (added) * c/src/ada-tests/tmtests/tm12/tmtest.ads (added) * c/src/ada-tests/tmtests/tm13/tmtest.adb (added) * c/src/ada-tests/tmtests/tm13/tmtest.ads (added) * c/src/ada-tests/tmtests/tm14/tmtest.adb (added) * c/src/ada-tests/tmtests/tm14/tmtest.ads (added) * c/src/ada-tests/tmtests/tm15/tmtest.adb (added) * c/src/ada-tests/tmtests/tm15/tmtest.ads (added) * c/src/ada-tests/tmtests/tm16/tmtest.adb (added) * c/src/ada-tests/tmtests/tm16/tmtest.ads (added) * c/src/ada-tests/tmtests/tm17/tmtest.adb (added) * c/src/ada-tests/tmtests/tm17/tmtest.ads (added) * c/src/ada-tests/tmtests/tm18/tmtest.adb (added) * c/src/ada-tests/tmtests/tm18/tmtest.ads (added) * c/src/ada-tests/tmtests/tm19/tmtest.adb (added) * c/src/ada-tests/tmtests/tm19/tmtest.ads (added) * c/src/ada-tests/tmtests/tm20/tmtest.adb (added) * c/src/ada-tests/tmtests/tm20/tmtest.ads (added) * c/src/ada-tests/tmtests/tm21/tmtest.adb (added) * c/src/ada-tests/tmtests/tm21/tmtest.ads (added) * c/src/ada-tests/tmtests/tm22/tmtest.adb (added) * c/src/ada-tests/tmtests/tm22/tmtest.ads (added) * c/src/ada-tests/tmtests/tm23/tmtest.adb (added) * c/src/ada-tests/tmtests/tm23/tmtest.ads (added) * c/src/ada-tests/tmtests/tm24/tmtest.adb (added) * c/src/ada-tests/tmtests/tm24/tmtest.ads (added) * c/src/ada-tests/tmtests/tm25/tmtest.adb (added) * c/src/ada-tests/tmtests/tm25/tmtest.ads (added) * c/src/ada-tests/tmtests/tm26/tmtest.ads (added) * c/src/ada-tests/tmtests/tm27/tmtest.adb (added) * c/src/ada-tests/tmtests/tm27/tmtest.ads (added) * c/src/ada-tests/tmtests/tm28/tmtest.adb (added) * c/src/ada-tests/tmtests/tm28/tmtest.ads (added) * c/src/ada-tests/tmtests/tm29/tmtest.adb (added) * c/src/ada-tests/tmtests/tm29/tmtest.ads (added) * c/src/ada-tests/tmtests/tmck/tmtest.adb (added) * c/src/ada-tests/tmtests/tmck/tmtest.ads (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.adb (added) * c/src/ada-tests/tmtests/tmoverhd/dummy_rtems.ads (added) * c/src/ada-tests/tmtests/tmoverhd/tmtest.adb (added) * c/src/ada-tests/tmtests/tmoverhd/tmtest.ads (added) Initial revision
